  4. JavaScript
  5. Sekunden in d/h/m umrechnen
    5.2k
19 Beiträge 5 Kommentatoren 2.8k Aufrufe 2 Beobachtet
  • MicM Mic
    @guergen sagte in Sekunden in d/h/m umrechnen:
    'system.host.NUC.uptime'
    1. welcher Datentyp ist denn der State "'system.host.NUC.uptime'"? Findest du unter Objekte, da den Datenpunkt auswählen, rechts auf den "Stift" klicken, da unter "Raw", Zeile "type":
    2. Kopiere hier mal ein Beispiel rein eines State-Inhaltes.
    guergen
    @Mic Hier der inhalt von NUC.uptime:
      "user": "system.user.admin",
      "ts": 1577495005124,
      "common": {
        "name": "Controller - uptime in seconds",
        "type": "string",
        "role": "value",
        "unit": "seconds",
        "read": true,
        "write": false
      "native": {},
      "acl": {
        "object": 1636,
        "owner": "system.user.admin",
        "state": 1636
      "_id": "system.host.NUC.uptime",
      "type": "state"
    Und hier mein DP:
      "ts": 1573829622690,
      "common": {
        "name": "Uptime_NUC",
        "role": "",
        "type": "string",
        "desc": "Manuell erzeugt",
        "read": true,
        "write": true
      "native": {},
      "acl": {
        "object": 1636,
        "state": 1636
      "_id": "javascript.0.Eigene_Datenpunkte.Haus.Uptime_NUC",
      "type": "state"
    Folgende Fehler kommen dann im Log:
    javascript.0 2019-12-29 09:20:25.538 error (1857) at processImmediate (timers.js:658:5)
    javascript.0 2019-12-29 09:20:25.538 error (1857) at tryOnImmediate (timers.js:676:5)
    javascript.0 2019-12-29 09:20:25.538 error (1857) at runCallback (timers.js:705:18)
    javascript.0 2019-12-29 09:20:25.538 error (1857) at Immediate.setImmediate (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:226:41)
    javascript.0 2019-12-29 09:20:25.538 error (1857) at change (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4745:37)
    javascript.0 2019-12-29 09:20:25.538 error (1857) at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:439:25)
    javascript.0 2019-12-29 09:20:25.538 error (1857) at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1101:38)
    javascript.0 2019-12-29 09:20:25.538 error (1857) at Object.<anonymous> (script.js.common.Diverse_Scripte.nuc-test:3:29)
    javascript.0 2019-12-29 09:20:25.537 error (1857) Error in callback: TypeError: dp.state.val.split is not a function
    Das Zeichen für das ausführen des Scriptes wird gelb
    • DolomitiD Offline
      DolomitiD Offline
      Dolomiti
      schrieb am zuletzt editiert von Dolomiti
      was werden den in beiden Fällen für Werte geliefert? Wenn ich die Uptime von meinem Host anzeigen lasse, steht dort eine Zahl. Mit der Split-Funktion versuchst du bei jedem Leerzeichen die Zahl zu trennen. Da du aber nur eine Zahl ohne Leerzeichen hast funktioniert das nicht.
      Versuch mal das Split wegzulassen und dann bei timesec die eckigen Klammern.
      on({id: 'system.host.ioBroker-Test.uptime'/*Controller - uptime in seconds*/, change: "ne"}, function (dp) {
       log (dp.state.val);
      	var timesec = dp.state.val;
      	var timenew = Math.floor(timesec / 3600 )+'h'+Math.floor( (timesec % 3600) / 60 )+'min';
          setState('javascript.0.Uptime_iobtest'/*javascript 0 Uptime iobtest*/,timenew);
       log (timenew);
      Intel N100 (32GB,256GB SSD), Proxmox -> Debian 13 in VM (Master) + Debian 13 in CT (Test) + Debmatic, HM-Aktoren, Wago 750-880, Shelly, Zigbee
      G 1 Antwort Letzte Antwort
      • NashraN Offline
        NashraN Offline
        Nashra
        Most Active Forum Testing
        schrieb am zuletzt editiert von Nashra
        Warum so kompliziert. Einfach ein Basic-html Widget in VIS (gehe mal davon aus das Du es dafür brauchst)
        und im html Bereich dies rein
        Uptime : {d:proxmox.0.node_Netzserver.uptime;Math.floor( ((d)/60/60/24) )} Tage‚{h:proxmox.0.node_Netzserver.uptime;Math.floor( ((h)/60/60) % 24 )} Std‚ {m:proxmox.0.node_Netzserver.uptime;Math.floor( ((m)/60) % 60 )} Min
        Gruß Ralf
        • DolomitiD Dolomiti
           log (dp.state.val);
           log (timenew);
          guergen
          @Dolomiti Das interessante ist ja, dass bei beiden die selben Werte gesetzt werden, bei dem einen Script geht es, bei dem anderen nicht
          • DolomitiD Offline
            DolomitiD Offline
            Dolomiti
            @guergen
            Du hast Recht. Hab es mit meinem NAS ausprobiert. Hier funktioniert es auch. Hängt es vielleicht mit der Struktur der Ausgangswerte zusammen?
            Edit: Bei der System-Uptime ist der Type Number, beim NAS ein String. Meines Wissens nach funktioniert Split nur beim String. Bei Number macht das ja auch keinen Sinn, das es nur einen Wert gibt ohne Leerzeichen o.Ä. Beim NAS findet er kein Leerzeichen und nimmt deshalb auromatisch die ganze Zahl.
              @guergen
              guergen
              @Dolomiti Mit Deinem Vorschlag des Scripts fängt er jetzt grade bei 1 minute an.... es sind aber 11700 sekunden
              • DolomitiD Offline
                DolomitiD Offline
                Dolomiti
                @guergen
                Bei mir passt es zusammen
                G 2 Antworten Letzte Antwort
                  @guergen
                  guergen
                  @Dolomiti Hmmh.....:
                    @guergen
                    guergen
                    @Dolomiti Wenn ich jetzt die eckigen Klammern einfüge kommt folgendes:
                    • DolomitiD Offline
                      DolomitiD Offline
                      Dolomiti
                      @guergen
                      Hat der Tag nicht nur 86400 Sekunden. Sind da nicht zwei Nullen zuviel?
                      Poste mal dein Skript.
                        @guergen
                        guergen
                        @Dolomiti Ähhh... ja.... habe es grade geändert, das andere waren hundertstel Sekunden....
                        Aber es nutzt trotzdem nichts:
                        on({id: 'system.host.NUC.uptime', change: "ne"}, function (dp) {
                         log (dp.state.val);
                        	var timenew = Math.floor(timesec[0] / 86400 )+'Tage'+Math.floor( (timesec[0] % 86400) / 3600 )+'h'+Math.floor( (timesec[0] % 3600) / 60 )+'min';
                            setState('javascript.0.Eigene_Datenpunkte.Haus.Uptime_NUC',timenew);
                         log (timenew);
                        Homer.J.H 1 Antwort Letzte Antwort
                        • DolomitiD Offline
                          DolomitiD Offline
                          Dolomiti
                          @guergen
                          Du musst die eckigen Klammern weglassen.
                            @guergen
                            guergen
                            @Dolomiti Oh man...
                            Manchmal sieht man vor lauter Bäumen den Wald nicht...
                            Danke!
                            Lauft!
                            • G guergen
                               log (dp.state.val);
                               log (timenew);
                              Homer.J.H Offline
                              Homer.J.H Offline
                              Homer.J.
                              schrieb am zuletzt editiert von Homer.J.
                              @guergen nimm mal das.
                              ({id: 'proxmox.0.qemu_iobroker.uptime'/*uptime*/, change: "ne"}, function (dp) {
                               //log (dp.state.val);
                              	var timenew = Math.floor(timesec /60/60/24 )+' Tag(e), '+Math.floor(timesec / 60/60 % 24)+' Std, '+Math.floor( (timesec / 60) % 60  )+' Min';
                                  setState('javascript.0.Vis.Anzeige.iobroker_Laufzeit'/*iobroker Laufzeit*/,timenew);
                               //log (timenew);
                              • Homer.J.H Homer.J.
                                 //log (timenew);
                                guergen
                                @Homer-J das "code_" und das "text" muss noch raus :-)
                                • G guergen
                                  Homer.J.H Offline
                                  Homer.J.H Offline
                                  Homer.J.
                                  @guergen jab ändere es. 😊
                                  funktioniert es. ?
                                    funktioniert es. ?
                                    guergen
                                    @Homer-J JA!
                                    Sieht einfacher aus... dann kommt man mit den Nullen nicht durcheinander!
