  4. Kein restore mit backitup 1.3.6 oder console
restore backup
8 Beiträge 3 Kommentatoren 565 Aufrufe 4 Beobachtet
  • Torsten WeggenT Offline
    Torsten Weggen
    schrieb am zuletzt editiert von Torsten Weggen
    Hi folks,
    wollte meinen iobroker vom Raspi auf Proxmox umziehen. Leider schlägt der Restore meiner Daten fehl:
    root@proxiobroker:/opt/iobroker# sudo iobroker stop
    root@proxiobroker:/opt/iobroker# sudo iobroker restore 0
    host.proxiobroker Using backup file iobroker_2019_12_26-16_49_28_backupiobroker.tar.gz
    host.proxiobroker Cannot extract from file "/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/../../../../backups/iobroker_2019_12_26-16_49_28_backupiobroker.tar.gz"
    host.proxiobroker Cannot find extracted file from file "/opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/backup.json"
    iobroker controller daemon is not running
    host.proxiobroker OK.
    (node:693) UnhandledPromiseRejectionWarning: Error: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/backup.json'
        at Object.openSync (fs.js:443:3)
        at Object.readFileSync (fs.js:343:35)
        at BackupRestore.restoreAfterStop (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupBackup.js:566:23)
        at Daemon.daemon.on (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupBackup.js:843:22)
        at Daemon.emit (events.js:203:15)
        at Daemon._kill (/opt/iobroker/node_modules/daemonize2/lib/daemonize.js:246:14)
        at Daemon.stop (/opt/iobroker/node_modules/daemonize2/lib/daemonize.js:185:17)
        at tar.extract.err (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupBackup.js:845:20)
    (node:693) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). (rejection id: 1)
    (node:693) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code.
    Jemenad eine Idee woran das liegt ?
    • Torsten WeggenT Torsten Weggen
      Hi folks,
      simatecS Offline
      simatecS Offline
      simatec
      @Torsten-Weggen
      Kannst du bitte den Titel ändern.
      Hier wird ein restore über Konsole und nicht mit Backitup versucht.
      Ansonsten kann ich dir nur empfehlen, die Backup Datei zu prüfen.
      Mit schaut es so aus, als ob die Datei beschädigt ist und nicht gelesen werden kann.
      Wenn du dein System neu aufgesetzt hast und dies auch mit dem neuen Installer gemacht hast, dann lass das sudo im Befehl weg.
      Ansonsten kannst du auch noch einmal den Installer Fix probieren.
      Ich tippe aber auf eine beschädigte Backup Datei
      • Besuche meine Github Seite
      • HowTo Restore ioBroker
      Torsten WeggenT 1 Antwort Letzte Antwort
      • simatecS simatec
        @Torsten-Weggen
        Torsten Weggen
        @simatec Das Verhalten im Backitup-Adapter und an der Konsole ist das gleiche.
        Das Archiv ist nicht defekt, konnte es problemlos manuell entpacken.
        Die Fehlermeldung ist mit und ohne sudo die gleiche.
        Installerfix hatte ich auch schon laufen lassen.
        Jetzt fällt mir nichts mehr ein...
          simatecS Offline
          simatecS Offline
          simatec
          @Torsten-Weggen
          Wenn die Datei sich entpacken lässt, existiert denn auch die backup.json im Archiv?
          Passen die Dateirechte der Backup Datei?
          Wie hast du iobroker installiert?
            Torsten Weggen
            @simatec Ja die backup.json ist im Archiv. Die Rechte hab ich auch auf "iobroker" gesetzt. Die Installation proxmox / iobroker ist erfolgt nach der Youtube Anleitung https://www.youtube.com/watch?v=492AQDA89GU mit dem Teil iobroker im Proxmox Container nach https://www.youtube.com/watch?v=xyI2FCQuSYQ .
            Noch ein Hinweis: im Backup in der iobroker_2019_12_26-16_19_20_backupiobroker.tar.gz - Datei befindet sich das Archiv iobroker_2019_12_26-16_19_20_backupiobroker.tar (was dann wieder die einzelnen Verzeichnisse und die backup.json enthält)
              simatecS Offline
              simatecS Offline
              simatec
              @Torsten-Weggen
              Sehr komisch... wenn die Rechte passen, kann maximal noch was mit iobroker / js-controller nicht passen.
              Was für Versionen hast du laufen
              js-controller, node, npm
              • simatecS simatec
                @Torsten-Weggen
                Torsten Weggen
                @simatec ist alles aktuell. Ich werde aber morgen den Container noch mal neu aufsetzen. Vielleicht klappt dann besser...
                tr1plxT 1 Antwort Letzte Antwort
                  tr1plxT Offline
                  tr1plxT Offline
                  tr1plx
                  @Torsten-Weggen Ich habe genau das gleiche Problem, finde und lese deinen Thread um am Ende festzustellen, dass kein Feedback gab.... wie hast du denn das nun hinbekommen?
