<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Kein restore mit backitup 1.3.6 oder console]]></title><description><![CDATA[<p dir="auto">Hi folks,</p>
<p dir="auto">wollte meinen iobroker vom Raspi auf Proxmox  umziehen. Leider schlägt der Restore meiner Daten fehl:</p>
<pre><code>root@proxiobroker:/opt/iobroker# sudo iobroker stop
root@proxiobroker:/opt/iobroker# sudo iobroker restore 0
host.proxiobroker Using backup file iobroker_2019_12_26-16_49_28_backupiobroker.tar.gz
host.proxiobroker Cannot extract from file "/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/../../../../backups/iobroker_2019_12_26-16_49_28_backupiobroker.tar.gz"
host.proxiobroker Cannot find extracted file from file "/opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/backup.json"
iobroker controller daemon is not running
host.proxiobroker OK.
(node:693) UnhandledPromiseRejectionWarning: Error: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/backup.json'
    at Object.openSync (fs.js:443:3)
    at Object.readFileSync (fs.js:343:35)
    at BackupRestore.restoreAfterStop (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupBackup.js:566:23)
    at Daemon.daemon.on (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupBackup.js:843:22)
    at Daemon.emit (events.js:203:15)
    at Daemon._kill (/opt/iobroker/node_modules/daemonize2/lib/daemonize.js:246:14)
    at Daemon.stop (/opt/iobroker/node_modules/daemonize2/lib/daemonize.js:185:17)
    at tar.extract.err (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupBackup.js:845:20)
(node:693) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). (rejection id: 1)
(node:693) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code.
</code></pre>
<p dir="auto">Jemenad eine Idee woran das liegt ?</p>
]]></description><link>https://forum.iobroker.net/topic/28109/kein-restore-mit-backitup-1-3-6-oder-console</link><generator>RSS for Node</generator><lastBuildDate>Sat, 02 May 2026 02:18:31 GMT</lastBuildDate><atom:link href="https://forum.iobroker.net/topic/28109.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 26 Dec 2019 16:18:15 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Kein restore mit backitup 1.3.6 oder console on Tue, 25 Feb 2020 15:41:29 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/torsten-weggen" aria-label="Profile: Torsten-Weggen">@<bdi>Torsten-Weggen</bdi></a> Ich habe genau das gleiche Problem, finde und lese deinen Thread um am Ende festzustellen, dass kein Feedback gab.... wie hast du denn das nun hinbekommen?</p>
]]></description><link>https://forum.iobroker.net/post/383901</link><guid isPermaLink="true">https://forum.iobroker.net/post/383901</guid><dc:creator><![CDATA[tr1plx]]></dc:creator><pubDate>Tue, 25 Feb 2020 15:41:29 GMT</pubDate></item><item><title><![CDATA[Reply to Kein restore mit backitup 1.3.6 oder console on Thu, 26 Dec 2019 20:55:17 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/simatec" aria-label="Profile: simatec">@<bdi>simatec</bdi></a> ist alles aktuell. Ich werde aber morgen den Container noch mal neu aufsetzen. Vielleicht klappt dann besser...</p>
]]></description><link>https://forum.iobroker.net/post/345943</link><guid isPermaLink="true">https://forum.iobroker.net/post/345943</guid><dc:creator><![CDATA[Torsten Weggen]]></dc:creator><pubDate>Thu, 26 Dec 2019 20:55:17 GMT</pubDate></item><item><title><![CDATA[Reply to Kein restore mit backitup 1.3.6 oder console on Thu, 26 Dec 2019 19:38:12 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/torsten-weggen" aria-label="Profile: Torsten-Weggen">@<bdi>Torsten-Weggen</bdi></a><br />
Sehr komisch... wenn die Rechte passen, kann maximal noch was mit iobroker / js-controller nicht passen.</p>
<p dir="auto">Was für Versionen hast du laufen<br />
js-controller, node, npm</p>
]]></description><link>https://forum.iobroker.net/post/345917</link><guid isPermaLink="true">https://forum.iobroker.net/post/345917</guid><dc:creator><![CDATA[simatec]]></dc:creator><pubDate>Thu, 26 Dec 2019 19:38:12 GMT</pubDate></item><item><title><![CDATA[Reply to Kein restore mit backitup 1.3.6 oder console on Thu, 26 Dec 2019 18:17:06 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/simatec" aria-label="Profile: simatec">@<bdi>simatec</bdi></a> Ja die backup.json ist im Archiv. Die Rechte hab ich auch auf "iobroker" gesetzt. Die Installation proxmox / iobroker ist erfolgt nach der Youtube Anleitung <a href="https://www.youtube.com/watch?v=492AQDA89GU" rel="nofollow ugc">https://www.youtube.com/watch?v=492AQDA89GU</a>  mit dem Teil iobroker im Proxmox Container nach <a href="https://www.youtube.com/watch?v=xyI2FCQuSYQ" rel="nofollow ugc">https://www.youtube.com/watch?v=xyI2FCQuSYQ</a> .</p>
<p dir="auto">Noch ein Hinweis: im Backup in der iobroker_2019_12_26-16_19_20_backupiobroker.tar.gz - Datei befindet sich das Archiv iobroker_2019_12_26-16_19_20_backupiobroker.tar (was dann wieder die einzelnen Verzeichnisse und die backup.json enthält)</p>
]]></description><link>https://forum.iobroker.net/post/345865</link><guid isPermaLink="true">https://forum.iobroker.net/post/345865</guid><dc:creator><![CDATA[Torsten Weggen]]></dc:creator><pubDate>Thu, 26 Dec 2019 18:17:06 GMT</pubDate></item><item><title><![CDATA[Reply to Kein restore mit backitup 1.3.6 oder console on Thu, 26 Dec 2019 17:26:54 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/torsten-weggen" aria-label="Profile: Torsten-Weggen">@<bdi>Torsten-Weggen</bdi></a><br />
Wenn die Datei sich entpacken lässt, existiert denn auch die backup.json im Archiv?<br />
Passen die Dateirechte der Backup Datei?</p>
<p dir="auto">Wie hast du iobroker installiert?</p>
]]></description><link>https://forum.iobroker.net/post/345848</link><guid isPermaLink="true">https://forum.iobroker.net/post/345848</guid><dc:creator><![CDATA[simatec]]></dc:creator><pubDate>Thu, 26 Dec 2019 17:26:54 GMT</pubDate></item><item><title><![CDATA[Reply to Kein restore mit backitup 1.3.6 oder console on Thu, 26 Dec 2019 16:46:36 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/simatec" aria-label="Profile: simatec">@<bdi>simatec</bdi></a> Das Verhalten im Backitup-Adapter und an der Konsole ist das gleiche.<br />
Das Archiv ist nicht defekt, konnte es problemlos manuell entpacken.<br />
Die Fehlermeldung ist mit und ohne sudo die gleiche.<br />
Installerfix hatte ich auch schon laufen lassen.</p>
<p dir="auto">Jetzt fällt mir nichts mehr ein...</p>
]]></description><link>https://forum.iobroker.net/post/345821</link><guid isPermaLink="true">https://forum.iobroker.net/post/345821</guid><dc:creator><![CDATA[Torsten Weggen]]></dc:creator><pubDate>Thu, 26 Dec 2019 16:46:36 GMT</pubDate></item><item><title><![CDATA[Reply to Kein restore mit backitup 1.3.6 oder console on Thu, 26 Dec 2019 16:43:08 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/torsten-weggen" aria-label="Profile: Torsten-Weggen">@<bdi>Torsten-Weggen</bdi></a><br />
Kannst du bitte den Titel ändern.<br />
Hier wird ein restore über Konsole und nicht mit Backitup versucht.</p>
<p dir="auto">Ansonsten kann ich dir nur empfehlen, die Backup Datei zu prüfen.<br />
Mit schaut es so aus, als ob die Datei beschädigt ist und nicht gelesen werden kann.</p>
<p dir="auto">Wenn du dein System neu aufgesetzt hast und dies auch mit dem neuen Installer gemacht hast, dann lass das sudo im Befehl weg.</p>
<p dir="auto">Ansonsten kannst du auch noch einmal den Installer Fix probieren.</p>
<p dir="auto">Ich tippe aber auf eine beschädigte Backup Datei</p>
]]></description><link>https://forum.iobroker.net/post/345819</link><guid isPermaLink="true">https://forum.iobroker.net/post/345819</guid><dc:creator><![CDATA[simatec]]></dc:creator><pubDate>Thu, 26 Dec 2019 16:43:08 GMT</pubDate></item></channel></rss>
