  4. Test Adapter Alexa2 3.0.x
    6.3k
alexa2
209 Beiträge 31 Kommentatoren 37.1k Aufrufe 31 Beobachtet
  • Matten MattenM Matten Matten
    wenn ich von github installiere steht bei mir immer noch V2.6.4
    deta
    @Matten-Matten sagte in Test Adapter Alexa2 3.0.x:
    Oben direkt mit dem Link vom Git installieren
      @Matten-Matten ggf mal upload manuell ausführen (vor allem bei Controller 1.5 oder so).
      Matten MattenM 1 Antwort Letzte Antwort
      • padrinoP Offline
        padrinoP Offline
        padrino
        Ein "delete" (über Datenpunkt) löscht das Objekt zwar aus der Shoppingliste, aber es kommt zu einer Menge Fehler im Log:
        host.raspberrypi	2019-12-22 18:51:02.580	error	instance system.adapter.alexa2.0 terminated with code 0 (OK)
        host.raspberrypi	2019-12-22 18:51:02.580	error	Caught by controller[1]: at process._tickDomainCallback (internal/process/next_tick.js:218:9)
        host.raspberrypi	2019-12-22 18:51:02.580	error	Caught by controller[1]: at _combinedTickCallback (internal/process/next_tick.js:138:11)
        host.raspberrypi	2019-12-22 18:51:02.580	error	Caught by controller[1]: at endReadableNT (_stream_readable.js:1064:12)
        host.raspberrypi	2019-12-22 18:51:02.579	error	Caught by controller[1]: at IncomingMessage.emit (events.js:208:7)
        host.raspberrypi	2019-12-22 18:51:02.579	error	Caught by controller[1]: at emitNone (events.js:111:20)
        host.raspberrypi	2019-12-22 18:51:02.579	error	Caught by controller[1]: at IncomingMessage.res.on (/opt/iobroker/node_modules/iobroker.alexa2/node_modules/alexa-remote2/alexa-remote.js:778:28)
        host.raspberrypi	2019-12-22 18:51:02.579	error	Caught by controller[1]: at alexa.getList (/opt/iobroker/node_modules/iobroker.alexa2/main.js:2587:13)
        host.raspberrypi	2019-12-22 18:51:02.579	error	Caught by controller[1]: TypeError: adapter.getObjectList is not a function
        host.raspberrypi	2019-12-22 18:51:02.579	error	Caught by controller[0]: at process._tickDomainCallback (internal/process/next_tick.js:218:9)
        host.raspberrypi	2019-12-22 18:51:02.579	error	Caught by controller[0]: at _combinedTickCallback (internal/process/next_tick.js:138:11)
        host.raspberrypi	2019-12-22 18:51:02.579	error	Caught by controller[0]: at endReadableNT (_stream_readable.js:1064:12)
        host.raspberrypi	2019-12-22 18:51:02.579	error	Caught by controller[0]: at IncomingMessage.emit (events.js:208:7)
        host.raspberrypi	2019-12-22 18:51:02.579	error	Caught by controller[0]: at emitNone (events.js:111:20)
        host.raspberrypi	2019-12-22 18:51:02.579	error	Caught by controller[0]: at IncomingMessage.res.on (/opt/iobroker/node_modules/iobroker.alexa2/node_modules/alexa-remote2/alexa-remote.js:778:28)
        host.raspberrypi	2019-12-22 18:51:02.578	error	Caught by controller[0]: at alexa.getList (/opt/iobroker/node_modules/iobroker.alexa2/main.js:2587:13)
        host.raspberrypi	2019-12-22 18:51:02.578	error	Caught by controller[0]: TypeError: adapter.getObjectList is not a function
        • padrinoP Offline
          padrinoP Offline
          padrino
          schrieb am zuletzt editiert von padrino
          Das mit den Listen ist spitze!
          Spinne grad ein wenig damit rum, da lässt sich sicher was Schickes machen... 😎
          ("Füge Einkaufsstätte Produkt zu meiner Einkaufsliste hinzu")
          Dank an @Zefau & @apollon77 😁
          • padrinoP padrino
            @padrino äääähm welche js-Controller version hast du? @Zefau kann es Sein das wir jetzt 2.0 brauchen??
            • apollon77A apollon77
              padrinoP Offline
              padrinoP Offline
              padrino
              @apollon77
              V1 - hab mich an des V2 Update noch nicht getraut, ist mir zu komplex... :(
              apollon77A ostseereiterO 2 Antworten Letzte Antwort
              • padrinoP padrino
                @apollon77
                @padrino solltest du. Ist sehr simpel. Was ist da komplex? Die listenfunktion braucht das beim löschen wie du jetzt weißt. ;-)
                Ich füge das nachher zum Changelog und als Abhängigkeit hinzu.
                • padrinoP padrino
                  @apollon77
                  ostseereiterO Offline
                  ostseereiter
                  @padrino lach bin ich ja nicht alleine ich zöger auch. Trau mich einfach nicht.
                  Gruß OSR
                  Plattform
                  • ostseereiterO ostseereiter
                    @ostseereiter Dann sagen wir es doch mal so ... Schaut Euch mal den 2.0er Thread an und was so an Problemen gemeldet wurde nach der 2.1.1 und jetzt sage ich Euch das Stand vorhin fast 12.000 User die 2.1.1 installiert haben ... ... ... :-)
                    • apollon77A Offline
                      Auf GitHub gibt es die 3.0.2 ... Es könnten/sollten jetzt vllt ein paar mehr Antworten von Madam Alexa im "answerText" landen als vorher. Ansonsten hat die io-package jetzt offiziell die Info zur js-controller 2.0 Abhängigkeit.
                      padrinoP ? 3 Antworten Letzte Antwort
                        padrinoP Offline
                        padrinoP Offline
                        padrino
                        @apollon77
                        Hm, sollte es dann nicht auch die Installation verhindern?
                        Was es nicht tut und jetzt ist der Adapter hin, weil er nicht mehr startet. 😁
                        (downgrade auf 2.6.4 läuft 😌)
                          padrinoP Offline
                          padrinoP Offline
                          padrino
                          @apollon77
                          Argh, ich kann nicht mehr zurück? 😢
                          2.6.4 ist installiert, startet aber nicht, da es nun auch JS controller V2 verlangt? 🤔
                          • padrinoP padrino
                            @apollon77
                            @padrino Musst Du mal versuchen. Admin blendet es in jedem Fall aus.
                            Aber naja es ist am Ende nur beim löschen von Listen-Einträgen relevant ... also hättest die 3.0.1 drauf lassen können :-)
                            • padrinoP padrino
                              @apollon77
                              @padrino upload nochmal machen nach 2.6.4 downgrade? Ggf iobroker js.controller neu starten
                              • padrinoP Offline
                                padrinoP Offline
                                padrino
                                Ja, upload gemacht.
                                iobroker komplett neu gestartet.
                                Geht nicht. :(
                                • padrinoP padrino
                                  Ja, upload gemacht.
                                  Geht nicht. :(
                                  @padrino Dann schau mal auf der Platte in /opt/iobroker/node_modules/iobroker.alexa2/io-package.json ob es da drin ist. Wenn nicht schau bitte in Objekten system.adapter.alexa2.0 ... und lösch es da raus :-)
                                    DocGame
                                    @apollon77
                                    Die 3.01 ist prima gelaufen. Ich hatte einen Computerabsturz und nun ist er gelb.
                                    Was könnte die Fehlermeldung bedeuten?
                                    2019-12-22 22:56:57.952 - info: host.IOBroker(SmartHome) stopInstance system.adapter.iot.0 (force=false, process=true)
                                    2019-12-22 22:56:57.953 - info: host.IOBroker(SmartHome) stopInstance system.adapter.iot.0 send kill signal
                                    2019-12-22 22:56:58.007 - info: iot.0 (9076) Got terminate signal TERMINATE_YOURSELF
                                    2019-12-22 22:56:58.010 - info: iot.0 (9076) terminating
                                    2019-12-22 22:56:58.012 - info: iot.0 (9076) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                                    2019-12-22 22:56:58.550 - info: host.IOBroker(SmartHome) instance system.adapter.iot.0 terminated with code 4294967196 (START_IMMEDIATELY_AFTER_STOP_HEX)
                                    2019-12-22 22:57:00.495 - info: host.IOBroker(SmartHome) instance system.adapter.iot.0 started with pid 10904
                                    2019-12-22 22:57:04.866 - info: iot.0 (10904) starting. Version 1.1.9 in C:/Iobroker/SmartHome/node_modules/iobroker.iot, node: v10.16.3
                                    2019-12-22 22:57:04.903 - info: iot.0 (10904) Connecting with a18wym7vjdl22g.iot.eu-west-1.amazonaws.com
                                    2019-12-22 22:57:06.180 - error: iot.0 (10904) Cannot read keys: "error:0909006C:PEM routines:get_name:no start line" / Error: error:0909006C:PEM routines:get_name:no start line
                                    • D DocGame
                                      @apollon77
                                      @DocGame Bist Du im richtigen Thread? :-) in dem Log Auszug ist nur "iot" drin ... Hat mit Alexa2 nichts zu tun
                                        DocGame
                                        @apollon77 Oh....
                                        Wollte es noch kurz loswerden vor dem schlafengehen.
                                        Sorry.
                                          padrinoP Offline
                                          padrinoP Offline
                                          padrino
                                          @apollon77 sagte in Test Adapter Alexa2 3.0.x:
                                          Was meinst Du mit "ob es da drin ist", was ist "es"? 😳
