  4. Test Adapter Alexa2 3.0.x
    6.3k
alexa2
209 Beiträge 31 Kommentatoren 37.1k Aufrufe 31 Beobachtet
  • padrinoP padrino
    Hm, muss man etwas beachten, wenn man eine zweite Instanz hat?
    Ich habe eine für den Echo Dot/Account meiner Eltern.
    Wenn ich den nun neu startet, kommt er in eine endlos Neustartschleife.
    Log ist:
    host.raspberrypi	2019-12-22 14:12:42.318	error	instance system.adapter.alexa2.1 terminated with code 0 (OK)
    host.raspberrypi	2019-12-22 14:12:42.318	error	Caught by controller[1]: at process._tickDomainCallback (internal/process/next_tick.js:218:9)
    host.raspberrypi	2019-12-22 14:12:42.318	error	Caught by controller[1]: at _combinedTickCallback (internal/process/next_tick.js:138:11)
    host.raspberrypi	2019-12-22 14:12:42.318	error	Caught by controller[1]: at endReadableNT (_stream_readable.js:1064:12)
    host.raspberrypi	2019-12-22 14:12:42.318	error	Caught by controller[1]: at IncomingMessage.emit (events.js:208:7)
    host.raspberrypi	2019-12-22 14:12:42.318	error	Caught by controller[1]: at emitNone (events.js:111:20)
    host.raspberrypi	2019-12-22 14:12:42.317	error	Caught by controller[1]: at IncomingMessage.res.on (/opt/iobroker/node_modules/iobroker.alexa2/node_modules/alexa-remote2/alexa-remote.js:767:79)
    host.raspberrypi	2019-12-22 14:12:42.317	error	Caught by controller[1]: at alexa.getSmarthomeEntities (/opt/iobroker/node_modules/iobroker.alexa2/main.js:939:26)
    host.raspberrypi	2019-12-22 14:12:42.317	error	Caught by controller[1]: TypeError: res2.forEach is not a function
    host.raspberrypi	2019-12-22 14:12:42.317	error	Caught by controller[0]: at process._tickDomainCallback (internal/process/next_tick.js:218:9)
    host.raspberrypi	2019-12-22 14:12:42.317	error	Caught by controller[0]: at _combinedTickCallback (internal/process/next_tick.js:138:11)
    host.raspberrypi	2019-12-22 14:12:42.317	error	Caught by controller[0]: at endReadableNT (_stream_readable.js:1064:12)
    host.raspberrypi	2019-12-22 14:12:42.317	error	Caught by controller[0]: at IncomingMessage.emit (events.js:208:7)
    host.raspberrypi	2019-12-22 14:12:42.317	error	Caught by controller[0]: at emitNone (events.js:111:20)
    host.raspberrypi	2019-12-22 14:12:42.316	error	Caught by controller[0]: at IncomingMessage.res.on (/opt/iobroker/node_modules/iobroker.alexa2/node_modules/alexa-remote2/alexa-remote.js:767:79)
    host.raspberrypi	2019-12-22 14:12:42.316	error	Caught by controller[0]: at alexa.getSmarthomeEntities (/opt/iobroker/node_modules/iobroker.alexa2/main.js:939:26)
    host.raspberrypi	2019-12-22 14:12:42.316	error	Caught by controller[0]: TypeError: res2.forEach is not a function
    @padrino checke ich nachher. Da scheinen bei einem call keine Daten zu kommen. Lass den erstmal aus.
    • apollon77A apollon77
      @Zefau hattest du nach dem install von GitHub auch die Instanz manuell neu gestartet?? Nicht das dir alte version noch lief ...
      ZefauZ Offline
      ZefauZ Offline
      Zefau
      @apollon77 hab ich in der Tat nicht. Ich beobachte das jetzt nochmal. Danke für den Hinweis.
        padrinoP Offline
        padrinoP Offline
        padrino
        @apollon77 sagte in Test Adapter Alexa2 3.0.x:
        @padrino die kommen denk bei dir bei jedem install egal welcher Adapter korrekt?! Npm prüft bei jedem install immer alle Abhängigkeiten. Kommt also von irgendeinem deiner Adapter.
        Muss zu meiner Schande gestehen, schon seit Ewigkeiten keinen Adapter mehr installiert zu haben. 😌 Muss das mal checken...
        Ok. Hab' ich direkt ausgemacht. Wird im Moment eh noch nicht genutzt. ;)
          Aktuelle Test Version 3.0.0
          Veröffentlichungsdatum 21.12.2019
          Github Link https://github.com/Apollon77/ioBroker.alexa2
          Hallo liebe Alexa2-Freunde,
          auch Alexa2 ist nun endlich an der Reihe. Ich habe einige Basisdinge aktualisiert und versucht alle Mails und GitHub Issues abzuarbeiten. Ich habe auch im alten Forum Thread etwas gestöbert und versucht noch Probleme die dort gemeldet worden zu prüfen, aber vieles konnte ich nicht nachvollziehen.
          Daher die Bitte: Checkt Eure Probleme nochmals mit der neuen 3.0 und meldet hier was los ist und legt in jedem Fall bitte ein GitHub Issue an! Debug-Logs bitte inklusive Link zu Eurem Beitrag hier oder besser der ID des GitHub Issues an iobroker@fischer-ka.de. Interessant ist meistens neben dem eigentlichen "Problem" (Schaltaktionen oder was auch immer noch so tut wie es soll) auch immer das Debug-Log vom gesamten Adapter-Start. Bitte fügt auch in der E-mail Infos hinzu WANN im log WAS passiert ist? Dann muss ich weniger Raten und Rätseln ;-)
          Ziel der 3.0.x Version ist erstmal wieder eine stabile Basis zu schaffen. Es sind nur wenige neue Features drin. Die kommen dann danach. Also je schneller Ihr bestätigt das alles tut ;-) umso schneller kommen neue Fetures ;-)
          Jetzt zu den Details der Verison:
          • ACHTUNG: Nodejs 8.x ist nun Minimalanforderung!! (daher auch die 3.0)
          • Neue Features:
            • Dank @Zefau sind nun auch die Listen (Shopping-Lists, Todo-Lists) mit dabei
            • Die Antwort von Alexa wird, wenn verfügbar, mit in den History Daten als "answerText" ausgegeben
          • Rest vom Changelog:
            • Generell: Siehe GitHub Issues: https://github.com/Apollon77/ioBroker.alexa2/issues Alles was mit "done-unreleased" getaggt ist sollte gefixt sein. Bugs mit "Question" warten auf mehr Details oder Retests!
            • (Apollon77) handle error for empty valueMaps for ColorTemperatures
            • (Apollon77) also support names for new special routines (Alarm Notifications, Sensor Detections, ..)
            • (Apollon77) GitHub Actions for Test& Build
            • (Apollon77) Add Sentry for error reporting
            • (Apollon77) prevent some crashed after changes by Amazon
            • (Apollon77) fix Routine names after changes by Amazon
            • (Apollon77) add some devices and new images
          Jetzt Happy Testing und Danke für Euren Support!
          Ingo
          padrinoP Offline
          padrinoP Offline
          padrino
          schrieb am zuletzt editiert von padrino
          Neue Features:
          Sehr cool. 😎👍
          Leider kann sich der Adapter wohl noch immer nicht alles "krallen".
          Die Antwort auf ein "Guten Morgen" klappt, aber auf "Regnet es gerade" leider nicht.
          Es tauchen aber beide in der App (bzw. bei mir auf alexa.amazon.de) auf.
          • apollon77A Offline
            Auf GitHub gibt es die 3.0.1.
            Der Fehler von @padrino sollte gefixt sein und ich hab nochmal eingebaut das an mehr Stellen Player-Daten aktualisiert werden weil Amazon scheinbar nicht mehr so oft Infos zu Titelwechseln gibt ... manchmal ...
            • padrinoP padrino
              Neue Features:
              Sehr cool. 😎👍
              @padrino Jupp, die Infos kommen nicht in den History-Daten. Das Regen Ding hab ich jetzt bei mir hinbekommen. Kommt ins nächste update regulär.
              Generell Wetterbericht nicht - Da gibts die "Rohdaten" ... aber nicht den finalen ausgesprochenen text. Ich könnte höchstens diese ganzen vollständigen Rohdaten als JSON zur Verfügung stellen.
              Wäre für wenner sowas:
                      "disambiguated": false,
                      "nBestList": [
                              "entryType": "Weather",
                              "hourlyEndIndex": 7,
                              "empty": false,
                              "weatherDataProvider": "ACW",
                              "alertAttributes": [],
                              "startIndex": 0,
                              "hourlyForecastAttributes": [
                                      "precipitationProbability": 56,
                                      "weatherIcon": 18,
                                      "dayLight": false,
                                      "forcastEpochDateTime": "1577030400",
                                      "temperature": {
                                          "scale": "C",
                                          "value": 8
                                      "link": "http://www.accuweather.com/de/de/knielingen/76187/hourly-weather-forecast/1013494?day=1&hbhhour=17&unit=c",
                                      "iconPhrase": "Regen",
                                      "realFeelTemperature": {
                                          "scale": "C",
                                          "value": 1
                                      "mobileLink": "http://m.accuweather.com/de/de/knielingen/76187/hourly-weather-forecast/1013494?day=1&hbhhour=17&unit=c",
                                      "forecastDate": "2019-12-22T17:00:00+01:00",
                                      "wind": {
                                          "windSpeedDegrees": 226,
                                          "windSpeedScale": "km/h",
                                          "windSpeedValue": 24.1,
                                          "windSpeedDirection": "SW"
                                      "precipitationProbability": 49,
                                      "weatherIcon": 7,
                                      "dayLight": false,
                                      "forcastEpochDateTime": "1577034000",
                                      "temperature": {
                                          "scale": "C",
                                          "value": 8
                                      "link": "http://www.accuweather.com/de/de/knielingen/76187/hourly-weather-forecast/1013494?day=1&hbhhour=18&unit=c",
                                      "iconPhrase": "Wolkig",
                                          "scale": "C",
                                          "value": 3
                                      "mobileLink": "http://m.accuweather.com/de/de/knielingen/76187/hourly-weather-forecast/1013494?day=1&hbhhour=18&unit=c",
                                      "forecastDate": "2019-12-22T18:00:00+01:00",
                                      "wind": {
                                          "windSpeedDegrees": 231,
                                      "precipitationProbability": 34,
                                      "weatherIcon": 7,
                                      "dayLight": false,
                                      "forcastEpochDateTime": "1577037600",
                                      "temperature": {
                                          "scale": "C",
                                          "value": 8
                                      "link": "http://www.accuweather.com/de/de/knielingen/76187/hourly-weather-forecast/1013494?day=1&hbhhour=19&unit=c",
                                          "scale": "C",
                                          "value": 3
                                      "mobileLink": "http://m.accuweather.com/de/de/knielingen/76187/hourly-weather-forecast/1013494?day=1&hbhhour=19&unit=c",
                                      "forecastDate": "2019-12-22T19:00:00+01:00",
                                      "wind": {
                                          "windSpeedDegrees": 236,
                                          "windSpeedValue": 22.2,
                                      "weatherIcon": 7,
                                      "dayLight": false,
                                      "forcastEpochDateTime": "1577041200",
                                      "temperature": {
                                          "scale": "C",
                                          "value": 8
                                      "link": "http://www.accuweather.com/de/de/knielingen/76187/hourly-weather-forecast/1013494?day=1&hbhhour=20&unit=c",
                                          "scale": "C",
                                          "value": 3
                                      "mobileLink": "http://m.accuweather.com/de/de/knielingen/76187/hourly-weather-forecast/1013494?day=1&hbhhour=20&unit=c",
                                      "forecastDate": "2019-12-22T20:00:00+01:00",
                                      "wind": {
                                          "windSpeedDegrees": 243,
                                          "windSpeedDirection": "WSW"
                                      "precipitationProbability": 40,
                                      "weatherIcon": 7,
                                      "dayLight": false,
                                      "forcastEpochDateTime": "1577044800",
                                      "temperature": {
                                          "scale": "C",
                                          "value": 7
                                      "link": "http://www.accuweather.com/de/de/knielingen/76187/hourly-weather-forecast/1013494?day=1&hbhhour=21&unit=c",
                                          "scale": "C",
                                          "value": 3
                                      "mobileLink": "http://m.accuweather.com/de/de/knielingen/76187/hourly-weather-forecast/1013494?day=1&hbhhour=21&unit=c",
                                      "forecastDate": "2019-12-22T21:00:00+01:00",
                                      "wind": {
                                          "windSpeedDegrees": 247,
                                      "precipitationProbability": 51,
                                      "weatherIcon": 18,
                                      "dayLight": false,
                                      "forcastEpochDateTime": "1577048400",
                                      "temperature": {
                                          "scale": "C",
                                          "value": 7
                                      "link": "http://www.accuweather.com/de/de/knielingen/76187/hourly-weather-forecast/1013494?day=1&hbhhour=22&unit=c",
                                          "scale": "C",
                                          "value": 1
                                      "mobileLink": "http://m.accuweather.com/de/de/knielingen/76187/hourly-weather-forecast/1013494?day=1&hbhhour=22&unit=c",
                                      "forecastDate": "2019-12-22T22:00:00+01:00",
                                      "wind": {
                                          "windSpeedDegrees": 248,
                                      "precipitationProbability": 47,
                                      "weatherIcon": 7,
                                      "dayLight": false,
                                      "forcastEpochDateTime": "1577052000",
                                      "temperature": {
                                          "scale": "C",
                                          "value": 7
                                      "link": "http://www.accuweather.com/de/de/knielingen/76187/hourly-weather-forecast/1013494?day=1&hbhhour=23&unit=c",
                                          "scale": "C",
                                          "value": 2
                                      "mobileLink": "http://m.accuweather.com/de/de/knielingen/76187/hourly-weather-forecast/1013494?day=1&hbhhour=23&unit=c",
                                      "forecastDate": "2019-12-22T23:00:00+01:00",
                                      "wind": {
                                      "weatherIcon": 7,
                                      "dayLight": false,
                                      "forcastEpochDateTime": "1577055600",
                                      "temperature": {
                                          "scale": "C",
                                          "value": 7
                                      "link": "http://www.accuweather.com/de/de/knielingen/76187/hourly-weather-forecast/1013494?day=2&hbhhour=0&unit=c",
                                          "scale": "C",
                                          "value": 3
                                      "mobileLink": "http://m.accuweather.com/de/de/knielingen/76187/hourly-weather-forecast/1013494?day=2&hbhhour=0&unit=c",
                                      "forecastDate": "2019-12-23T00:00:00+01:00",
                                      "wind": {
                                          "windSpeedValue": 20.4,
                              "endIndex": 1,
                              "conditionsAttributes": {
                                  "precipitation": {
                                      "scale": "mm",
                                      "value": 0
                                  "uvText": "Niedrig",
                                  "weatherIcon": 3,
                                  "weatherSummary": "Teils sonnig",
                                  "link": "http://www.accuweather.com/de/de/knielingen/76187/current-weather/1013494",
                                  "relativeHumidity": 84,
                                  "temperature": {
                                      "scale": "C",
                                      "value": 8
                                  "uvIndex": 0,
                                      "scale": "C",
                                      "value": 1
                                  "mobileLink": "http://m.accuweather.com/de/de/knielingen/76187/current-weather/1013494",
                                  "wind": {
                                      "windSpeedDegrees": 225,
                                      "windSpeedValue": 31.5,
                              "forecastAttributes": [
                                      "maxTemperature": {
                                          "scale": "C",
                                          "value": 9
                                      "minTemperature": {
                                          "scale": "C",
                                          "value": 7
                                      "minRealFeelTemperature": {
                                          "scale": "C",
                                          "value": 1
                                      "night": {
                                          "weatherShortPhrase": "Abends zeitweise Regen",
                                          "rain": {
                                              "scale": "mm",
                                              "value": 1.5
                                          "precipitationProbability": 60,
                                          "weatherLongPhrase": "Abends Nieselregen; windig; nachts einige Schauer",
                                          "weatherIcon": 12,
                                          "snow": {
                                              "scale": "cm",
                                              "value": 0
                                          "snowProbability": 0,
                                          "weatherText": "Schauer",
                                          "wind": {
                                              "windSpeedDegrees": 246,
                                          "rainProbability": 60
                                      "link": "http://www.accuweather.com/de/de/knielingen/76187/daily-weather-forecast/1013494?day=1&unit=c",
                                      "mobileLink": "http://m.accuweather.com/de/de/knielingen/76187/daily-weather-forecast/1013494?day=1&unit=c",
                                      "day": {
                                          "weatherShortPhrase": "Wolkig, Nieselregen",
                                          "rain": {
                                              "scale": "mm",
                                              "value": 3.8
                                          "precipitationProbability": 61,
                                          "weatherLongPhrase": "Wolkig, Nieselregen",
                                          "weatherIcon": 12,
                                          "snow": {
                                              "scale": "cm",
                                              "value": 0
                                          "wind": {
                                              "windSpeedDegrees": 186,
                                              "windSpeedValue": 13,
                                              "windSpeedDirection": "S"
                                          "rainProbability": 61
                                      "maxRealFeelTemperature": {
                                          "scale": "C",
                                          "value": 8
                                      "forecastDate": "2019-12-22T07:00:00+01:00"
                                      "maxTemperature": {
                                          "scale": "C",
                                          "value": 9
                                      "minTemperature": {
                                          "scale": "C",
                                          "value": 6
                                          "scale": "C",
                                          "value": 1
                                      "night": {
                                          "weatherShortPhrase": "Nachts zeitweise Regen",
                                          "rain": {
                                              "scale": "mm",
                                              "value": 4.8
                                          "precipitationProbability": 67,
                                          "weatherLongPhrase": "Viele Wolken; abends kurze Schauer; nachts Nieselregen",
                                          "weatherIcon": 12,
                                          "snow": {
                                              "scale": "cm",
                                              "value": 0
                                          "wind": {
                                              "windSpeedDegrees": 232,
                                              "windSpeedValue": 14.8,
                                          "rainProbability": 67
                                      "link": "http://www.accuweather.com/de/de/knielingen/76187/daily-weather-forecast/1013494?day=2&unit=c",
                                      "mobileLink": "http://m.accuweather.com/de/de/knielingen/76187/daily-weather-forecast/1013494?day=2&unit=c",
                                      "day": {
                                          "weatherShortPhrase": "Zeitweise Regen",
                                          "rain": {
                                              "scale": "mm",
                                              "value": 1.3
                                          "weatherLongPhrase": "Überwiegend bewölkt, Nieselregen",
                                          "weatherIcon": 12,
                                          "snow": {
                                              "scale": "cm",
                                              "value": 0
                                          "wind": {
                                              "windSpeedDegrees": 250,
                                              "windSpeedValue": 16.7,
                                          "rainProbability": 56
                                          "scale": "C",
                                          "value": 6
                                      "forecastDate": "2019-12-23T07:00:00+01:00"
                                      "maxTemperature": {
                                          "scale": "C",
                                          "value": 11
                                      "minTemperature": {
                                          "scale": "C",
                                          "value": 6
                                          "scale": "C",
                                          "value": 0
                                      "night": {
                                          "weatherShortPhrase": "Regen",
                                          "rain": {
                                              "scale": "mm",
                                              "value": 6.4
                                          "precipitationProbability": 68,
                                          "weatherLongPhrase": "Regen und Nieselregen mit Unterbrechungen",
                                          "weatherIcon": 18,
                                          "snow": {
                                              "scale": "cm",
                                              "value": 0
                                          "weatherText": "Regen",
                                          "wind": {
                                          "rainProbability": 68
                                      "link": "http://www.accuweather.com/de/de/knielingen/76187/daily-weather-forecast/1013494?day=3&unit=c",
                                      "mobileLink": "http://m.accuweather.com/de/de/knielingen/76187/daily-weather-forecast/1013494?day=3&unit=c",
                                      "day": {
                                          "weatherShortPhrase": "Am Morgen Regen; wolkig, mild",
                                          "rain": {
                                              "scale": "mm",
                                              "value": 3
                                          "precipitationProbability": 65,
                                          "weatherLongPhrase": "Am Morgen regnerische Abschnitte; wolkig und mild",
                                          "weatherIcon": 12,
                                          "snow": {
                                              "scale": "cm",
                                              "value": 0
                                          "wind": {
                                              "windSpeedDegrees": 224,
                                          "rainProbability": 65
                                          "scale": "C",
                                          "value": 7
                                      "forecastDate": "2019-12-24T07:00:00+01:00"
                                      "maxTemperature": {
                                          "scale": "C",
                                          "value": 9
                                      "minTemperature": {
                                          "scale": "C",
                                          "value": 0
                                          "scale": "C",
                                          "value": 0
                                      "night": {
                                          "rain": {
                                              "scale": "mm",
                                              "value": 1
                                          "precipitationProbability": 54,
                                          "weatherLongPhrase": "Erhebliche Bewölkung; abends gelegentlich Regen und Nieselregen; nachts möglicher Schauer",
                                          "weatherIcon": 12,
                                          "snow": {
                                              "scale": "cm",
                                              "value": 0
                                          "snowProbability": 22,
                                          "wind": {
                                              "windSpeedDegrees": 191,
                                              "windSpeedValue": 7.4,
                                          "rainProbability": 54
                                      "link": "http://www.accuweather.com/de/de/knielingen/76187/daily-weather-forecast/1013494?day=4&unit=c",
                                      "mobileLink": "http://m.accuweather.com/de/de/knielingen/76187/daily-weather-forecast/1013494?day=4&unit=c",
                                      "day": {
                                          "weatherShortPhrase": "Gelegentlich Regen",
                                          "rain": {
                                              "scale": "mm",
                                              "value": 7.6
                                          "precipitationProbability": 66,
                                          "weatherLongPhrase": "Gelegentlich Regen",
                                          "weatherIcon": 18,
                                          "snow": {
                                              "scale": "cm",
                                              "value": 0
                                          "wind": {
                                              "windSpeedDegrees": 258,
                                          "rainProbability": 66
                                          "scale": "C",
                                          "value": 6
                                      "forecastDate": "2019-12-25T07:00:00+01:00"
                                      "maxTemperature": {
                                          "scale": "C",
                                          "value": 6
                                      "minTemperature": {
                                          "scale": "C",
                                          "value": 3
                                          "scale": "C",
                                          "value": -1
                                      "night": {
                                          "weatherShortPhrase": "Regen und Nieselregen",
                                          "rain": {
                                              "scale": "mm",
                                              "value": 5.5
                                          "weatherLongPhrase": "Regen und Nieselregen",
                                          "weatherIcon": 18,
                                          "snow": {
                                              "scale": "cm",
                                              "value": 0
                                          "wind": {
                                              "windSpeedDegrees": 214,
                                              "windSpeedValue": 9.3,
                                      "link": "http://www.accuweather.com/de/de/knielingen/76187/daily-weather-forecast/1013494?day=5&unit=c",
                                      "mobileLink": "http://m.accuweather.com/de/de/knielingen/76187/daily-weather-forecast/1013494?day=5&unit=c",
                                      "day": {
                                          "weatherShortPhrase": "Leichter Regen",
                                          "rain": {
                                              "scale": "mm",
                                              "value": 1
                                          "precipitationProbability": 55,
                                          "weatherLongPhrase": "Überwiegend bewölkt, leichter Regen",
                                          "weatherIcon": 12,
                                          "snow": {
                                              "scale": "cm",
                                              "value": 0
                                          "snowProbability": 14,
                                          "wind": {
                                              "windSpeedDegrees": 101,
                                              "windSpeedDirection": "O"
                                          "rainProbability": 55
                                          "scale": "C",
                                          "value": 5
                                      "forecastDate": "2019-12-26T07:00:00+01:00"
                                      "maxTemperature": {
                                          "scale": "C",
                                          "value": 8
                                      "minTemperature": {
                                          "scale": "C",
                                          "value": 5
                                          "scale": "C",
                                          "value": 0
                                      "night": {
                                          "weatherShortPhrase": "Am Abend leichter Regen",
                                          "rain": {
                                              "scale": "mm",
                                              "value": 2.3
                                          "precipitationProbability": 63,
                                          "weatherLongPhrase": "Abends zeitweise leichter Regen; meist wolkig",
                                          "weatherIcon": 12,
                                          "snow": {
                                              "scale": "cm",
                                              "value": 0
                                          "wind": {
                                          "rainProbability": 63
                                      "link": "http://www.accuweather.com/de/de/knielingen/76187/daily-weather-forecast/1013494?day=6&unit=c",
                                      "mobileLink": "http://m.accuweather.com/de/de/knielingen/76187/daily-weather-forecast/1013494?day=6&unit=c",
                                      "day": {
                                          "rain": {
                                              "scale": "mm",
                                              "value": 6
                                          "weatherLongPhrase": "Zeitweise Regen",
                                          "weatherIcon": 18,
                                          "snow": {
                                              "scale": "cm",
                                              "value": 0
                                          "wind": {
                                              "windSpeedValue": 18.5,
                                          "scale": "C",
                                          "value": 4
                                      "forecastDate": "2019-12-27T07:00:00+01:00"
                                      "maxTemperature": {
                                          "scale": "C",
                                          "value": 9
                                      "minTemperature": {
                                          "scale": "C",
                                          "value": 5
                                          "scale": "C",
                                          "value": 3
                                      "night": {
                                          "weatherShortPhrase": "Wolkig; nachts Regen",
                                          "rain": {
                                              "scale": "mm",
                                              "value": 3.5
                                          "weatherLongPhrase": "Wolkig; nachts regnerische Abschnitte",
                                          "weatherIcon": 12,
                                          "snow": {
                                              "scale": "cm",
                                              "value": 0
                                          "wind": {
                                              "windSpeedDegrees": 228,
                                              "windSpeedValue": 5.6,
                                      "link": "http://www.accuweather.com/de/de/knielingen/76187/daily-weather-forecast/1013494?day=7&unit=c",
                                      "mobileLink": "http://m.accuweather.com/de/de/knielingen/76187/daily-weather-forecast/1013494?day=7&unit=c",
                                      "day": {
                                          "weatherShortPhrase": "Früh morgens leichter Regen",
                                          "rain": {
                                              "scale": "mm",
                                              "value": 1
                                          "precipitationProbability": 57,
                                          "weatherLongPhrase": "Am Morgen leichter Regen; überwiegend bewölkt",
                                          "weatherIcon": 12,
                                          "snow": {
                                              "scale": "cm",
                                              "value": 0
                                          "wind": {
                                              "windSpeedDegrees": 253,
                                              "windSpeedValue": 11.1,
                                          "rainProbability": 57
                                          "scale": "C",
                                          "value": 8
                                      "forecastDate": "2019-12-28T07:00:00+01:00"
                                      "maxTemperature": {
                                          "scale": "C",
                                          "value": 5
                                      "minTemperature": {
                                          "scale": "C",
                                          "value": 0
                                          "scale": "C",
                                          "value": -2
                                      "night": {
                                          "weatherShortPhrase": "Meist wolkig",
                                          "rain": {
                                              "scale": "mm",
                                              "value": 0.2
                                          "weatherLongPhrase": "Abends möglicherweise kurze Schauer, sonst überwiegend bewölkt",
                                          "weatherIcon": 38,
                                          "snow": {
                                              "scale": "cm",
                                              "value": 0
                                          "snowProbability": 16,
                                          "weatherText": "Stark bewölkt",
                                          "wind": {
                                              "windSpeedDegrees": 230,
                                          "rainProbability": 40
                                      "link": "http://www.accuweather.com/de/de/knielingen/76187/daily-weather-forecast/1013494?day=8&unit=c",
                                      "mobileLink": "http://m.accuweather.com/de/de/knielingen/76187/daily-weather-forecast/1013494?day=8&unit=c",
                                      "day": {
                                          "rain": {
                                              "scale": "mm",
                                              "value": 7.1
                                          "weatherLongPhrase": "Leichter Regen",
                                          "weatherIcon": 12,
                                          "snow": {
                                              "scale": "cm",
                                              "value": 0
                                          "snowProbability": 1,
                                          "wind": {
                                              "windSpeedDegrees": 227,
                                          "scale": "C",
                                          "value": 5
                                      "forecastDate": "2019-12-29T07:00:00+01:00"
                                      "maxTemperature": {
                                          "scale": "C",
                                          "value": 6
                                      "minTemperature": {
                                          "scale": "C",
                                          "value": 1
                                          "scale": "C",
                                          "value": -1
                                      "night": {
                                          "weatherShortPhrase": "Überwiegend bewölkt",
                                          "rain": {
                                              "scale": "mm",
                                              "value": 0
                                          "precipitationProbability": 22,
                                          "weatherLongPhrase": "Überwiegend bewölkt",
                                          "weatherIcon": 38,
                                          "snow": {
                                              "scale": "cm",
                                              "value": 0
                                          "wind": {
                                              "windSpeedDegrees": 233,
                                          "rainProbability": 22
                                      "link": "http://www.accuweather.com/de/de/knielingen/76187/daily-weather-forecast/1013494?day=9&unit=c",
                                      "mobileLink": "http://m.accuweather.com/de/de/knielingen/76187/daily-weather-forecast/1013494?day=9&unit=c",
                                      "day": {
                                          "weatherShortPhrase": "Teilweise sonnig",
                                          "rain": {
                                              "scale": "mm",
                                              "value": 0
                                          "precipitationProbability": 6,
                                          "weatherLongPhrase": "Teilweise sonnig",
                                          "weatherIcon": 3,
                                          "snow": {
                                              "scale": "cm",
                                              "value": 0
                                          "weatherText": "Teils sonnig",
                                          "wind": {
                                          "scale": "C",
                                          "value": 2
                                      "forecastDate": "2019-12-30T07:00:00+01:00"
                                      "maxTemperature": {
                                          "scale": "C",
                                          "value": 7
                                      "minTemperature": {
                                          "scale": "C",
                                          "value": 2
                                          "scale": "C",
                                          "value": -5
                                      "night": {
                                          "rain": {
                                              "scale": "mm",
                                              "value": 7.6
                                          "precipitationProbability": 74,
                                          "weatherLongPhrase": "Regen",
                                          "weatherIcon": 18,
                                          "snow": {
                                              "scale": "cm",
                                              "value": 0
                                          "snowProbability": 6,
                                          "wind": {
                                              "windSpeedDegrees": 245,
                                          "rainProbability": 74
                                      "link": "http://www.accuweather.com/de/de/knielingen/76187/daily-weather-forecast/1013494?day=10&unit=c",
                                      "mobileLink": "http://m.accuweather.com/de/de/knielingen/76187/daily-weather-forecast/1013494?day=10&unit=c",
                                      "day": {
                                          "weatherShortPhrase": "Niedrige Wolken",
                                          "rain": {
                                              "scale": "mm",
                                              "value": 0
                                          "precipitationProbability": 25,
                                          "weatherLongPhrase": "Niedrige Wolken",
                                          "weatherIcon": 8,
                                          "snow": {
                                              "scale": "cm",
                                              "value": 0
                                          "weatherText": "Bedeckt",
                                          "wind": {
                                              "windSpeedDegrees": 222,
                                          "rainProbability": 25
                                          "scale": "C",
                                          "value": 4
                                      "forecastDate": "2019-12-31T07:00:00+01:00"
                              "location": "Knielingen, Deutschland",
                              "hourlyStartIndex": 0,
                              "weatherReportType": "CURRENT_CONDITIONS_REPORT"
              Macht das Sinn?
              ALternativ könnte ich mal schauen ob man die Cards mit den "Aktivitäten" mappen kann ... ich schaue mal
                padrinoP Offline
                padrinoP Offline
                padrino
                Instanz Alexa2.1 läuft. 😁👍
                • Matten MattenM Offline
                  Matten Matten
                  wenn ich von github installiere steht bei mir immer noch V2.6.4
                  ioBroker auf Beelink mit WIN10 home|CCU3 (Raspberrymatic)|Neato BotVac D3|HYPERION Ambilight auf RPI3 und RPI ZeroW|HA-Bridge|Milight LED|Nodered&Redmatic|VU Duo2 & Solo se V2
                  D apollon77A 2 Antworten Letzte Antwort
                  • Matten MattenM Matten Matten
                    deta
                    @Matten-Matten sagte in Test Adapter Alexa2 3.0.x:
                    Oben direkt mit dem Link vom Git installieren
                      @Matten-Matten ggf mal upload manuell ausführen (vor allem bei Controller 1.5 oder so).
                      Matten MattenM 1 Antwort Letzte Antwort
                      • padrinoP Offline
                        padrinoP Offline
                        padrino
                        Ein "delete" (über Datenpunkt) löscht das Objekt zwar aus der Shoppingliste, aber es kommt zu einer Menge Fehler im Log:
                        host.raspberrypi	2019-12-22 18:51:02.580	error	instance system.adapter.alexa2.0 terminated with code 0 (OK)
                        host.raspberrypi	2019-12-22 18:51:02.580	error	Caught by controller[1]: at process._tickDomainCallback (internal/process/next_tick.js:218:9)
                        host.raspberrypi	2019-12-22 18:51:02.580	error	Caught by controller[1]: at _combinedTickCallback (internal/process/next_tick.js:138:11)
                        host.raspberrypi	2019-12-22 18:51:02.580	error	Caught by controller[1]: at endReadableNT (_stream_readable.js:1064:12)
                        host.raspberrypi	2019-12-22 18:51:02.579	error	Caught by controller[1]: at IncomingMessage.emit (events.js:208:7)
                        host.raspberrypi	2019-12-22 18:51:02.579	error	Caught by controller[1]: at emitNone (events.js:111:20)
                        host.raspberrypi	2019-12-22 18:51:02.579	error	Caught by controller[1]: at IncomingMessage.res.on (/opt/iobroker/node_modules/iobroker.alexa2/node_modules/alexa-remote2/alexa-remote.js:778:28)
                        host.raspberrypi	2019-12-22 18:51:02.579	error	Caught by controller[1]: at alexa.getList (/opt/iobroker/node_modules/iobroker.alexa2/main.js:2587:13)
                        host.raspberrypi	2019-12-22 18:51:02.579	error	Caught by controller[1]: TypeError: adapter.getObjectList is not a function
                        host.raspberrypi	2019-12-22 18:51:02.579	error	Caught by controller[0]: at process._tickDomainCallback (internal/process/next_tick.js:218:9)
                        host.raspberrypi	2019-12-22 18:51:02.579	error	Caught by controller[0]: at _combinedTickCallback (internal/process/next_tick.js:138:11)
                        host.raspberrypi	2019-12-22 18:51:02.579	error	Caught by controller[0]: at endReadableNT (_stream_readable.js:1064:12)
                        host.raspberrypi	2019-12-22 18:51:02.579	error	Caught by controller[0]: at IncomingMessage.emit (events.js:208:7)
                        host.raspberrypi	2019-12-22 18:51:02.579	error	Caught by controller[0]: at emitNone (events.js:111:20)
                        host.raspberrypi	2019-12-22 18:51:02.579	error	Caught by controller[0]: at IncomingMessage.res.on (/opt/iobroker/node_modules/iobroker.alexa2/node_modules/alexa-remote2/alexa-remote.js:778:28)
                        host.raspberrypi	2019-12-22 18:51:02.578	error	Caught by controller[0]: at alexa.getList (/opt/iobroker/node_modules/iobroker.alexa2/main.js:2587:13)
                        host.raspberrypi	2019-12-22 18:51:02.578	error	Caught by controller[0]: TypeError: adapter.getObjectList is not a function
                        • padrinoP Offline
                          padrinoP Offline
                          padrino
                          Das mit den Listen ist spitze!
                          Spinne grad ein wenig damit rum, da lässt sich sicher was Schickes machen... 😎
                          ("Füge Einkaufsstätte Produkt zu meiner Einkaufsliste hinzu")
                          Dank an @Zefau & @apollon77 😁
                          • padrinoP padrino
                            @padrino äääähm welche js-Controller version hast du? @Zefau kann es Sein das wir jetzt 2.0 brauchen??
                              padrinoP Offline
                              padrinoP Offline
                              padrino
                              @apollon77
                              V1 - hab mich an des V2 Update noch nicht getraut, ist mir zu komplex... :(
                              apollon77A ostseereiterO 2 Antworten Letzte Antwort
                              • padrinoP padrino
                                @apollon77
                                @padrino solltest du. Ist sehr simpel. Was ist da komplex? Die listenfunktion braucht das beim löschen wie du jetzt weißt. ;-)
                                Ich füge das nachher zum Changelog und als Abhängigkeit hinzu.
                                • padrinoP padrino
                                  @apollon77
                                  ostseereiterO Offline
                                  ostseereiter
                                  @padrino lach bin ich ja nicht alleine ich zöger auch. Trau mich einfach nicht.
                                  Gruß OSR
                                  Plattform
                                  • ostseereiterO ostseereiter
                                    @ostseereiter Dann sagen wir es doch mal so ... Schaut Euch mal den 2.0er Thread an und was so an Problemen gemeldet wurde nach der 2.1.1 und jetzt sage ich Euch das Stand vorhin fast 12.000 User die 2.1.1 installiert haben ... ... ... :-)
                                      Auf GitHub gibt es die 3.0.2 ... Es könnten/sollten jetzt vllt ein paar mehr Antworten von Madam Alexa im "answerText" landen als vorher. Ansonsten hat die io-package jetzt offiziell die Info zur js-controller 2.0 Abhängigkeit.
                                      padrinoP ? 3 Antworten Letzte Antwort
                                        padrinoP Offline
                                        padrinoP Offline
                                        padrino
                                        @apollon77
                                        Hm, sollte es dann nicht auch die Installation verhindern?
                                        Was es nicht tut und jetzt ist der Adapter hin, weil er nicht mehr startet. 😁
                                        (downgrade auf 2.6.4 läuft 😌)
                                          padrinoP Offline
                                          padrinoP Offline
                                          padrino
                                          @apollon77
                                          Argh, ich kann nicht mehr zurück? 😢
                                          2.6.4 ist installiert, startet aber nicht, da es nun auch JS controller V2 verlangt? 🤔
