  4. History überarbeitet
149 Beiträge 18 Kommentatoren 46.9k Aufrufe
  • sissiwupS Offline
    sissiwupS Offline
    sissiwup
    #69
    @eric2905:
    Hab den neuen SQL (0.0.3) installiert, aber immer noch die Fehlermeldungen:
    ` > sql-0 2015-12-08 08:14:46 error Cannot insert INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES(18, 1449558876000, 2.5, 1, 2, 0);: Error: SQLITE_BUSY: database is locked
    sql-0 2015-12-08 08:09:12 error Cannot insert INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES(18, 1449558541000, -0.9, 1, 2, 0);: Error: SQLITE_BUSY: database is locked
    sql-0 2015-12-08 08:07:08 error Cannot insert INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES(18, 1449558418000, 1, 1, 2, 0);: Error: SQLITE_BUSY: database is locked
    sql-0 2015-12-08 08:04:49 error Cannot insert INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES(18, 1449558278000, 4.9, 1, 2, 0);: Error: SQLITE_BUSY: database is locked
    sql-0 2015-12-08 08:02:15 error Cannot insert INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES(18, 1449558125000, 11.4, 1, 2, 0);: Error: SQLITE_BUSY: database is locked
    sql-0 2015-12-08 07:59:28 error Cannot insert INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES(18, 1449557957000, 11.2, 1, 2, 0);: Error: SQLITE_BUSY: database is locked
    sql-0 2015-12-08 07:56:26 error Cannot insert INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES(18, 1449557776000, -0.4, 1, 2, 0);: Error: SQLITE_BUSY: database is locked
    sql-0 2015-12-08 07:51:47 error Cannot insert INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES(18, 1449557496000, 2.2, 1, 2, 0);: Error: SQLITE_BUSY: database is locked
    sql-0 2015-12-08 07:46:10 error Cannot insert INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES(18, 1449557159000, 1.1, 1, 2, 0);: Error: SQLITE_BUSY: database is locked
    sql-0 2015-12-08 07:39:10 error Cannot delete DELETE FROM ts_number WHERE id=18 AND ts < 1449470340;: Error: SQLITE_BUSY: database is locked
    sql-0 2015-12-08 07:38:35 warn Cannot get index of 'hm-rpc.0.xxxxxxxx.1.HUMIDITY': Error: SQLITE_BUSY: database is locked
    sql-0 2015-12-08 07:38:35 error Cannot select SELECT id, type FROM datapoints WHERE name='hm-rpc.0. xxxxxxxx.1.HUMIDITY';: Error: SQLITE_BUSY: database is locked
    sql-0 2015-12-08 07:38:35 error Cannot delete DELETE FROM ts_number WHERE id=6 AND ts < 1449470281;: Error: SQLITE_BUSY: database is locked
    sql-0 2015-12-08 07:38:32 warn Cannot get index of 'hm-rpc.0. xxxxxxxx.1.HUMIDITY': Error: SQLITE_BUSY: database is locked
    sql-0 2015-12-08 07:38:32 error Cannot select SELECT id, type FROM datapoints WHERE name='hm-rpc.0.JEQ0553734.1.HUMIDITY';: Error: SQLITE_BUSY: database is locked
    sql-0 2015-12-08 07:38:32 error Cannot delete DELETE FROM ts_number WHERE id=34 AND ts < 1449470281;: Error: SQLITE_BUSY: database is locked
    sql-0 2015-12-08 07:38:29 warn Cannot get index of 'hm-rpc.0. xxxxxxxx.1.TEMPERATURE': Error: SQLITE_BUSY: database is locked `
    Hab ich evtl. was vergessen?
    Gruß,
    Eric
    PS: Habe den Screenshot jetzt durch einen Log-Auszug ersetzt. `
    Man sieht oben, das die Timestamps noch auf 000 enden, das darf nicht sein.
    Hier kannst du kurzzeitig den fix aus den Post einsetzen, wo die Zeile durch Date.now ersetzt wird.
    Das hat bei mir geholfen.
    MfG
    Sissi
    1 CCU3 1 CCU2-Gateway 1 LanGateway 1 Pi-Gateway 1 I7 für ioBroker/MySQL
    • sissiwupS Offline
      sissiwupS Offline
      sissiwup
      #70
      @versteckt:
      So, hab auch grad alles umgestellt. Erhalte leider auch den Fehler "Error: SQLITE_BUSY: database is locked" `
      Probier mal:
      Ja, es liegt offensichtlich an den fehlenden Millisekunden. Aber nicht nur auf dem Pi - ich arbeite mit Windows.
      Ich habe mich aber jetzt noch mal in den Code reingekniet und empfehle Dir folgendes zu testen - wenn Du Dir's zutraust.
      Und zwar musst Du in der Datei "..\iobroker\node_modules\iobroker.sql\main.js" die Zeile 552:
      Code:
      state.ts = parseInt(state.ts, 10) * 1000 + (parseInt(state.ms, 10) || 0);
      durch die folgende ersetzen:
      Code:
      state.ts = parseInt(Date.now());
      Dann die Datei speichern und den SQL-Adapter neustarten. Dann dürfte es keine doppelten Timestamps mehr geben (und ich hoffe dass ich damit nichts anderes durcheinanderbringe - aber wir sind ja hier noch in der Beta ;) )
      Gruß Thilo
      MfG
      Sissi
      • eric2905E Offline
        eric2905E Offline
        eric2905
        #71
        Hi sissiwup,
        den Vorschlag hatte Thisoft schon gemacht und ich habe es ausprobiert.
        Wirft bei mir weiterhin Fehler.
        Siehe hier : http://forum.iobroker.net/viewtopic.php … =40#p15492
        Gruß,
        Eric
        • V Offline
          V Offline
          versteckt
          #72
          Das ausprobieren und trauen ist bei mir kein Thema, hab schon ein paar Adapter entwickelt.
          Werde ich mir morgen ansehen, heute schon anderweitig beschäftigt.
          Gesendet von meinem iPhone mit Tapatalk
          Raspi 1, Raspi 2, iobroker, Mac Mini: alles mit aktueller ioBroker Version
          homegear für Homematic und MAX!
          occ, zWave, rpi, hmm und homekit Entwickler
          • eric2905E Offline
            eric2905E Offline
            eric2905
            #73
            @versteckt
            Vielleicht hast Du mehr Glück - bei mir hat's nicht wirklich g fruchtet.
            Auf welcher Plattform läuft es bei Dir? Ich hab's auf einem Cubietruck laufen (evtl. geht's bei anderer HW).
            Gruß,
            Eric
            • V Offline
              V Offline
              versteckt
              #74
              Mac bzw. Raspi bzw. Raspi 2
              • sissiwupS Offline
                sissiwupS Offline
                sissiwup
                #75
                @eric2905:
                Hi sissiwup,
                Gruß,
                Eric `
                der Fehler sollte aber nicht an der Anpassung liegen. Bei mir waren jedenfalls danach die Fehler bei den Inserts weg.
                Ich habe übrigens auch eine arm-Platform: Raspi 2
                MfG
                Sissi
                • sissiwupS Offline
                  sissiwupS Offline
                  sissiwup
                  #76
                  @Bluefox:
                  Es gibt neue Version von SQL-Adapter und flot. `
                  flot habe ich keine neue Version gefunden. Ist immer noch 0.2.0
                  SQL habe ich die 0.0.2 am laufen.
                  MfG
                  Sissi
                  • eric2905E Offline
                    eric2905E Offline
                    eric2905
                    #77
                    @sissiwup:
                    Ich habe übrigens auch eine arm-Platform: Raspi 2 `
                    Ok, wenn's nächste Woche (noch) keine Lösung gibt, probiere ich es nochmal. Fliege in ein paar Stunden in Urlaub und bastele jetzt nicht mehr rum :-)
                    Gruß,
                    Eric
                    • ThisoftT Offline
                      ThisoftT Offline
                      Thisoft
                      #78
                      Will mich auch mal wieder dazu melden…
                      Ich muss gestehen, der database-locked-Fehler kommt auch bei mir nach der Änderung des Timestamps immer noch. Da muss noch was anderes faul sein.
                      Mal so als Frage in die Runde: Kommt dieser Fehler eigentlich nur in VErbindung mit der Standard-SQLite-Db oder hat den Fehler auch jemand der eine andere Db einsetzt?
                      Ich würde ja gerne mal mit MS-SQLServer testen, aber dazu brauche ich erst noch nen Rechner, bei meinem ioBroker-Server geht der RAM in die Knie und nachrüsten kann ich da nix :( Wäre ein guter Grund, endlich mal meinen RasPi2 ans Laufen zu bekommen, hab aber gestern mal wieder einen erfolglosen Abend damit verbracht 😢
                      Gruß Thilo
                      22 HM-Geräte; PivCCU2 auf RasPi
                      ioBroker-Multihost; Ubuntu-Master auf Intel-Atom und 3 RasPi-Clients
                      • sissiwupS Offline
                        sissiwupS Offline
                        sissiwup
                        #79
                        ich habe allerdings auch auf mySQL gewechselt.
                        Bei mir belegt mySQL 21 KB Speicher.
                        Habe allerdings auch auf die Konfiguration für Kleinstrechner gewechselt.
                        In top ist mysql nicht unter den top ten.
                        MfG
                        Sissi
                        • ThisoftT Offline
                          ThisoftT Offline
                          Thisoft
                          #80
                          Hallo sissi,
                          verstehe ich das richtig dass bei Dir der Fehler weg ist seit Du auf MySQL gewechselt hast?
                          MySQL wäre schon auch eine Alternative - ich wollte nur gerne gleich auf MS-SQLServer gehen. Der braucht etwas mehr Ressourcen, ich könnte den dann aber auch ganz gut für andere Projektchen gebrauchen.
                          • P Offline
                            pix
                            #81
                            bei mir gab es heute morgen noch diesen Fehler:
                            2015-12-09 08:12:28.679 - info: history.0 moving 480 entries to couchdb
                            2015-12-09 08:12:28.709 - error: uncaught exception: Cannot read property 'ts' of null
                            2015-12-09 08:12:28.710 - error: TypeError: Cannot read property 'ts' of null
                            at Socket. <anonymous>(/Users/pix/Documents/iobroker/node_modules/iobroker.history/history.js:105:33)
                            at Socket.onack (/Users/pix/Documents/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:295:6)
                            at Socket.onpacket (/Users/pix/Documents/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:220:12)
                            at Manager. <anonymous>(/Users/pix/Documents/iobroker/node_modules/component-bind/index.js:21:15)
                            at Manager.Emitter.emit (/Users/pix/Documents/iobroker/node_modules/component-emitter/index.js:134:20)
                            at Manager.ondecoded (/Users/pix/Documents/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:301:8)
                            at Decoder. <anonymous>(/Users/pix/Documents/iobroker/node_modules/component-bind/index.js:21:15)
                            at Decoder.Emitter.emit (/Users/pix/Documents/iobroker/node_modules/component-emitter/index.js:134:20)
                            at Decoder.add (/Users/pix/Documents/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-parser/index.js:247:12)
                            at Manager.ondata (/Users/pix/Documents/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:291:16)
                            2015-12-09 08:12:28.731 - info: history.0 moving 480 entries to couchdb</anonymous></anonymous></anonymous>
                            Hat scheinbar auch etwas mit dem Timestamp zu tun.
                            Gruß,
                            Pix
                            [9054_1.png](/assets/uploads/files/9054_1.png)
                            [9054_2.png](/assets/uploads/files/9054_2.png)
                            [9054_3.png](/assets/uploads/files/9054_3.png)
                            [9054_4.png](/assets/uploads/files/9054_4.png)
                            [9054_5.png](/assets/uploads/files/9054_5.png)
                            [9054_6.png](/assets/uploads/files/9054_6.png)
                            [9054_7.png](/assets/uploads/files/9054_7.png)
                            [9054_8.png](/assets/uploads/files/9054_8.png)
                            [9054_9.png](/assets/uploads/files/9054_9.png)
                              starfish
                              #82
                              diese Fehler sind schon seltsam. Ich kann dies hier aber nicht nachvollziehen. Sowohl sqlite wie auch mysql laufen hier fehlerfrei, allerdings habe ich nur 2 Datenpunkte, die aufgezeichnet werden. Ich hatte früher woanders auch schon ein ähnliches Fehlerbild.Da war der Index auf den timestamp gesetzt Die Datensätze waren deshalb teilweise nicht unique.
                              • V Offline
                                V Offline
                                versteckt
                                #83
                                Hab grad mit einem Kollegen auf CentOS alles hochgezogen.
                                MySQL Integration funktioniert.
                                • sissiwupS Offline
                                  sissiwupS Offline
                                  sissiwup
                                  #84
                                  @Thisoft:
                                  Hallo sissi,
                                  MySQL wäre schon auch eine Alternative - ich wollte nur gerne gleich auf MS-SQLServer gehen. Der braucht etwas mehr Ressourcen, ich könnte den dann aber auch ganz gut für andere Projektchen gebrauchen. `
                                  ja, du mußt halt noch den Fix machen, den ich bei MySQL geposted habe (weiter vorne).
                                  Da ansonsten keine String-Datenpunkte gespeichert werden können.
                                  MfG
                                  Sissi
                                  • V Offline
                                    V Offline
                                    versteckt
                                    #85
                                    Morgähn, hab gestern Abend noch von SQLite auf mySQL umgestellt.
                                    Fehler sind keine mehr da, aber meine SETPOINTS meiner HM-CC-TC werden nicht ordentlich an ioBroker übermittelt.
                                    Somit sind meine Grafiken eher doof.
                                    Aber das ist ein anderes Thema, das ich mir genauer ansehen muss.
                                    Ansonsten läuft der Adapter korrekt.
                                    • sissiwupS Offline
                                      sissiwupS Offline
                                      sissiwup
                                      #86
                                      @versteckt:
                                      Ansonsten läuft der Adapter korrekt. `
                                      die Setpoints kommen schon korrekt. Leider hat der HM-CC-TC die eigenart, die Setpoints, die ja auf Kanal2 liegen, nur zu übermitteln, wenn diese sich ändern. Damit sehen die Grafiken eher merkwürdig aus.
                                      Bis flot angepaßt ist, und es dir Wichtig ist, wie die Grafiken aussehen,
                                      kannst du wie folgt vorgehen:
                                      Einstellung soll-Temperatur HM-CC-TC:
                                      8:00 - 11:59 18°
                                      12:00 - 20:59 22°
                                      ersetzen durch
                                      8:00 -- 11:58 18°
                                      11:58 -- 11:59 18°
                                      12:00 - 20:58 22°
                                      20:58 - 20:59 22°
                                      Mit den neuen Thermostaten gibt es das Problem übrigens nicht.
                                      MfG
                                      Sissi
                                      • V Offline
                                        V Offline
                                        versteckt
                                        #87
                                        Hallo, alles klar, danke für die Info.
                                        Nein, Grafiken sind mir im Moment nicht so wichtig, arbeite sonst gerne mit Grafana,
                                        das ist halt einfach ein cooles Grafik Werkzeug.
                                        Ansonsten ist das ja mittels occ recht einfach umzustellen.
                                        LG Christian
                                        • sissiwupS Offline
                                          sissiwupS Offline
                                          sissiwup
                                          #88
                                          wenn du mysql nutzt, dann kannst du auch einen Trigger nutzen, der vorm Insert einfach den letzten Eintrag
                                          eine ms vorm aktuellen inserted. Dann hast du einen ähnlichen Effekt.
                                          Da die meisten aber vermutlich sqlite nutzen, ist das wohl eher nicht so spannend für alle.
                                          MfG
                                          Sissi
