  4. Test Adapter tr-064-community v1.0.x
    6.0k
tr-064community
727 Beiträge 88 Kommentatoren 243.7k Aufrufe 66 Beobachtet
  • conectasC conectas
    @apollon77
    Dauert noch ne Sek. .. Knallt bei Install
    host.raspberrypi	2019-12-12 17:12:15.366	error	Caught by controller[0]: at Timer.processTimers (timers.js:223:10)
    host.raspberrypi	2019-12-12 17:12:15.365	error	Caught by controller[0]: at listOnTimeout (timers.js:263:5)
    host.raspberrypi	2019-12-12 17:12:15.365	error	Caught by controller[0]: at tryOnTimeout (timers.js:300:5)
    host.raspberrypi	2019-12-12 17:12:15.365	error	Caught by controller[0]: at ontimeout (timers.js:436:11)
    host.raspberrypi	2019-12-12 17:12:15.364	error	Caught by controller[0]: at Timeout.doIt [as _onTimeout] (/opt/iobroker/node_modules/iobroker.tr-064-community/lib/phonebook.js:114:25)
    host.raspberrypi	2019-12-12 17:12:15.364	error	Caught by controller[0]: at /opt/iobroker/node_modules/iobroker.tr-064-community/main.js:948:62
    host.raspberrypi	2019-12-12 17:12:15.363	error	Caught by controller[0]: at JSON.stringify (<anonymous>)
    host.raspberrypi	2019-12-12 17:12:15.361	error	Caught by controller[0]: TypeError: Converting circular structure to JSON
    tr-064-community.0	2019-12-12 17:12:14.811	info	(27839) Terminated (NO_ERROR): Without reason
    tr-064-community.0	2019-12-12 17:12:14.806	info	(27839) terminating
    tr-064-community.0	2019-12-12 17:12:14.711	error	(27839) TypeError: Converting circular structure to JSON at JSON.stringify (<anonymous>) at /opt/iobroker/node_modules/iobroker.tr-064-community/main.js:948:62 at Timeout.doIt [as _onTimeo
    tr-064-community.0	2019-12-12 17:12:14.708	error	(27839) uncaught exception: Converting circular structure to JSON
    conectasC Offline
    conectasC Offline
    conectas
    #465
    @conectas
    Ich starte mal die Fritze neu...
    2019-12-12 17:17:28.384  - info: host.raspberrypi Update repository "latest" under "http://download.iobroker.net/sources-dist-latest.json"
    2019-12-12 17:18:06.065  - info: host.raspberrypi iobroker add tr-064-community  --host raspberrypi
    2019-12-12 17:18:09.756  - info: host.raspberrypi iobroker host.raspberrypi create instance tr-064-community
    2019-12-12 17:18:09.782  - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.tr-064-community.0.sigKill created
    2019-12-12 17:18:09.827  - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.tr-064-community.0.eventLoopLag created
    2019-12-12 17:18:09.872  - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.tr-064-community.0.outputCount created
    2019-12-12 17:18:09.912  - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.tr-064-community.0.inputCount created
    2019-12-12 17:18:09.974  - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.tr-064-community.0.uptime created
    2019-12-12 17:18:10.016  - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.tr-064-community.0.memRss created
    2019-12-12 17:18:10.057  - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.tr-064-community.0.memHeapTotal created
    2019-12-12 17:18:10.104  - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.tr-064-community.0.memHeapUsed created
    2019-12-12 17:18:10.150  - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.tr-064-community.0.cputime created
    2019-12-12 17:18:10.187  - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.tr-064-community.0.cpu created
    2019-12-12 17:18:10.223  - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.tr-064-community.0.compactMode created
    2019-12-12 17:18:10.261  - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.tr-064-community.0.connected created
    2019-12-12 17:18:10.298  - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.tr-064-community.0.alive created
    2019-12-12 17:18:10.349  - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.tr-064-community.0 created
    2019-12-12 17:18:11.378  - info: host.raspberrypi iobroker exit 0
    2019-12-12 17:18:12.875  - info: host.raspberrypi instance system.adapter.tr-064-community.0 started with pid 6951
    2019-12-12 17:18:17.706  - info: tr-064-community.0 (6951) starting. Version 1.2.0 in /opt/iobroker/node_modules/iobroker.tr-064-community, node: v10.17.0
    2019-12-12 17:18:19.870  - error: tr-064-community.0 (6951) Error: sendSOAPActionRequest Error action=GetInfo serviceType=urn:dslforum-org:service:WLANConfiguration:1: 401 - {"code":401}
    2019-12-12 17:18:19.872  - error: tr-064-community.0 (6951) ~
    2019-12-12 17:18:19.873  - error: tr-064-community.0 (6951) ~~ Fatal error. Can not connect to your FritzBox.
    2019-12-12 17:18:19.875  - error: tr-064-community.0 (6951) ~~ If configuration, networt, IP address, etc. ok, try to restart your FritzBox
    2019-12-12 17:18:19.876  - error: tr-064-community.0 (6951) ~
    2019-12-12 17:18:24.922  - error: host.raspberrypi instance system.adapter.tr-064-community.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    2019-12-12 17:18:24.923  - info: host.raspberrypi Restart adapter system.adapter.tr-064-community.0 because enabled
    tail: iobroker.2019-12-12.log: Datei abgeschnitten
    undefined2019-12-12 17:18:54.955  - info: host.raspberrypi instance system.adapter.tr-064-community.0 started with pid 8222
    2019-12-12 17:18:59.215  - info: tr-064-community.0 (8222) starting. Version 1.2.0 in /opt/iobroker/node_modules/iobroker.tr-064-community, node: v10.17.0
    2019-12-12 17:19:01.042  - error: tr-064-community.0 (8222) Error: sendSOAPActionRequest Error action=GetInfo serviceType=urn:dslforum-org:service:WLANConfiguration:1: 401 - {"code":401}
    2019-12-12 17:19:01.044  - error: tr-064-community.0 (8222) ~
    2019-12-12 17:19:01.045  - error: tr-064-community.0 (8222) ~~ Fatal error. Can not connect to your FritzBox.
    2019-12-12 17:19:01.046  - error: tr-064-community.0 (8222) ~~ If configuration, networt, IP address, etc. ok, try to restart your FritzBox
    2019-12-12 17:19:04.035  - info: host.raspberrypi stopInstance system.adapter.tr-064-community.0 (force=false, process=true)
    2019-12-12 17:19:04.039  - info: host.raspberrypi stopInstance system.adapter.tr-064-community.0 send kill signal
    2019-12-12 17:19:04.046  - info: tr-064-community.0 (8222) Got terminate signal TERMINATE_YOURSELF
    2019-12-12 17:19:04.050  - info: tr-064-community.0 (8222) terminating
    2019-12-12 17:19:04.052  - info: tr-064-community.0 (8222) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2019-12-12 17:19:04.597  - info: host.raspberrypi instance system.adapter.tr-064-community.0 terminated with code 156 (156)
    2019-12-12 17:19:06.602  - info: host.raspberrypi instance system.adapter.tr-064-community.0 started with pid 8513
    2019-12-12 17:19:10.630  - info: tr-064-community.0 (8513) starting. Version 1.2.0 in /opt/iobroker/node_modules/iobroker.tr-064-community, node: v10.17.0
    2019-12-12 17:19:15.996  - error: tr-064-community.0 (8513) uncaught exception: Converting circular structure to JSON
    2019-12-12 17:19:15.999  - error: tr-064-community.0 (8513) TypeError: Converting circular structure to JSON
    2019-12-12 17:19:16.010  - info: tr-064-community.0 (8513) terminating
    2019-12-12 17:19:16.014  - info: tr-064-community.0 (8513) Terminated (NO_ERROR): Without reason
    2019-12-12 17:19:16.565  - error: host.raspberrypi Caught by controller[0]: TypeError: Converting circular structure to JSON
    2019-12-12 17:19:16.567  - error: host.raspberrypi Caught by controller[0]:     at JSON.stringify (<anonymous>)
    2019-12-12 17:19:16.568  - error: host.raspberrypi Caught by controller[0]:     at /opt/iobroker/node_modules/iobroker.tr-064-community/main.js:948:62
    2019-12-12 17:19:16.568  - error: host.raspberrypi Caught by controller[0]:     at Timeout.doIt [as _onTimeout] (/opt/iobroker/node_modules/iobroker.tr-064-community/lib/phonebook.js:114:25)
    2019-12-12 17:19:16.569  - error: host.raspberrypi Caught by controller[0]:     at ontimeout (timers.js:436:11)
    2019-12-12 17:19:16.569  - error: host.raspberrypi Caught by controller[0]:     at tryOnTimeout (timers.js:300:5)
    2019-12-12 17:19:16.570  - error: host.raspberrypi Caught by controller[0]:     at listOnTimeout (timers.js:263:5)
    2019-12-12 17:19:16.570  - error: host.raspberrypi Caught by controller[0]:     at Timer.processTimers (timers.js:223:10)
    2019-12-12 17:19:16.571  - info: host.raspberrypi instance system.adapter.tr-064-community.0 terminated with code 0 (NO_ERROR)
    2019-12-12 17:19:16.571  - info: host.raspberrypi Restart adapter system.adapter.tr-064-community.0 because enabled
    2019-12-12 17:19:46.163  - info: host.raspberrypi "system.adapter.tr-064-community.0" disabled
    2019-12-12 17:19:50.354  - error: tr-064-community.0 (9678) adapter disabled
    2019-12-12 17:19:50.378  - warn: tr-064-community.0 (9678) Terminated (NO_ADAPTER_CONFIG_FOUND): Without reason
    2019-12-12 17:19:51.008  - error: host.raspberrypi instance system.adapter.tr-064-community.0 terminated with code 3 (NO_ADAPTER_CONFIG_FOUND)
    2019-12-12 17:19:51.010  - info: host.raspberrypi Do not restart adapter system.adapter.tr-064-community.0 because disabled or deleted
    2019-12-12 17:20:01.788  - info: host.raspberrypi "system.adapter.tr-064-community.0" enabled
    2019-12-12 17:20:01.827  - info: host.raspberrypi instance system.adapter.tr-064-community.0 started with pid 10215
    2019-12-12 17:20:05.857  - info: tr-064-community.0 (10215) starting. Version 1.2.0 in /opt/iobroker/node_modules/iobroker.tr-064-community, node: v10.17.0
    2019-12-12 17:20:10.848  - error: tr-064-community.0 (10215) uncaught exception: Converting circular structure to JSON
    2019-12-12 17:20:10.851  - error: tr-064-community.0 (10215) TypeError: Converting circular structure to JSON
    2019-12-12 17:20:10.871  - info: tr-064-community.0 (10215) terminating
    2019-12-12 17:20:10.875  - info: tr-064-community.0 (10215) Terminated (NO_ERROR): Without reason
    2019-12-12 17:20:11.414  - error: host.raspberrypi Caught by controller[0]: TypeError: Converting circular structure to JSON
    2019-12-12 17:20:11.415  - error: host.raspberrypi Caught by controller[0]:     at JSON.stringify (<anonymous>)
    2019-12-12 17:20:11.416  - error: host.raspberrypi Caught by controller[0]:     at /opt/iobroker/node_modules/iobroker.tr-064-community/main.js:948:62
    2019-12-12 17:20:11.417  - error: host.raspberrypi Caught by controller[0]:     at Timeout.doIt [as _onTimeout] (/opt/iobroker/node_modules/iobroker.tr-064-community/lib/phonebook.js:114:25)
    2019-12-12 17:20:11.417  - error: host.raspberrypi Caught by controller[0]:     at ontimeout (timers.js:436:11)
    2019-12-12 17:20:11.418  - error: host.raspberrypi Caught by controller[0]:     at tryOnTimeout (timers.js:300:5)
    2019-12-12 17:20:11.419  - error: host.raspberrypi Caught by controller[0]:     at listOnTimeout (timers.js:263:5)
    2019-12-12 17:20:11.419  - error: host.raspberrypi Caught by controller[0]:     at Timer.processTimers (timers.js:223:10)
    2019-12-12 17:20:11.420  - info: host.raspberrypi instance system.adapter.tr-064-community.0 terminated with code 0 (NO_ERROR)
    2019-12-12 17:20:11.420  - info: host.raspberrypi Restart adapter system.adapter.tr-064-community.0 because enabled
    2019-12-12 17:20:41.447  - info: host.raspberrypi instance system.adapter.tr-064-community.0 started with pid 11383
    2019-12-12 17:20:45.398  - info: tr-064-community.0 (11383) starting. Version 1.2.0 in /opt/iobroker/node_modules/iobroker.tr-064-community, node: v10.17.0
    2019-12-12 17:20:50.666  - error: tr-064-community.0 (11383) uncaught exception: Converting circular structure to JSON
    2019-12-12 17:20:50.669  - error: tr-064-community.0 (11383) TypeError: Converting circular structure to JSON
    2019-12-12 17:20:50.688  - info: tr-064-community.0 (11383) terminating
    2019-12-12 17:20:50.692  - info: tr-064-community.0 (11383) Terminated (NO_ERROR): Without reason
    2019-12-12 17:20:51.245  - error: host.raspberrypi Caught by controller[0]: TypeError: Converting circular structure to JSON
    2019-12-12 17:20:51.247  - error: host.raspberrypi Caught by controller[0]:     at JSON.stringify (<anonymous>)
    2019-12-12 17:20:51.248  - error: host.raspberrypi Caught by controller[0]:     at /opt/iobroker/node_modules/iobroker.tr-064-community/main.js:948:62
    2019-12-12 17:20:51.248  - error: host.raspberrypi Caught by controller[0]:     at Timeout.doIt [as _onTimeout] (/opt/iobroker/node_modules/iobroker.tr-064-community/lib/phonebook.js:114:25)
    2019-12-12 17:20:51.249  - error: host.raspberrypi Caught by controller[0]:     at ontimeout (timers.js:436:11)
    2019-12-12 17:20:51.249  - error: host.raspberrypi Caught by controller[0]:     at tryOnTimeout (timers.js:300:5)
    2019-12-12 17:20:51.249  - error: host.raspberrypi Caught by controller[0]:     at listOnTimeout (timers.js:263:5)
    2019-12-12 17:20:51.250  - error: host.raspberrypi Caught by controller[0]:     at Timer.processTimers (timers.js:223:10)
    2019-12-12 17:20:51.250  - info: host.raspberrypi instance system.adapter.tr-064-community.0 terminated with code 0 (NO_ERROR)
    2019-12-12 17:20:51.250  - info: host.raspberrypi Restart adapter system.adapter.tr-064-community.0 because enabled
      @apollon77
      #466
      @conectas mist ... mach Debug aus ... muss logging ändern - heute Abend dann
      • apollon77A Offline
        #467
        Ok, bitte neu von GitHub und neu Starten ... sollte gefixt sein
        • apollon77A apollon77
          Ok, ich habe eine Code-Stelle gefunden wo glaube ich die Werte falsch geschrieben wurden ... versuch mal neu GitHub.
          PS: Einwas noch: States werden nur geschrieben wenn 200ms keine Änderungen waren ...
          conectasC Offline
          conectasC Offline
          conectas
          #468
          @apollon77
          Knallt beim Start.. Änderungen waren nicht .. ;-)
          2019-12-12 17:31:01.655  - info: host.raspberrypi "system.adapter.tr-064-community.0" enabled
          2019-12-12 17:31:01.687  - info: host.raspberrypi instance system.adapter.tr-064-community.0 started with pid 6419
          2019-12-12 17:31:05.579  - info: tr-064-community.0 (6419) starting. Version 1.2.0 in /opt/iobroker/node_modules/iobroker.tr-064-community, node: v10.17.0
          2019-12-12 17:31:10.633  - error: tr-064-community.0 (6419) uncaught exception: Converting circular structure to JSON
          2019-12-12 17:31:10.636  - error: tr-064-community.0 (6419) TypeError: Converting circular structure to JSON
          2019-12-12 17:31:10.650  - info: tr-064-community.0 (6419) terminating
          2019-12-12 17:31:10.653  - info: tr-064-community.0 (6419) Terminated (NO_ERROR): Without reason
          2019-12-12 17:31:11.209  - error: host.raspberrypi Caught by controller[0]: TypeError: Converting circular structure to JSON
          2019-12-12 17:31:11.213  - error: host.raspberrypi Caught by controller[0]:     at JSON.stringify (<anonymous>)
          2019-12-12 17:31:11.214  - error: host.raspberrypi Caught by controller[0]:     at /opt/iobroker/node_modules/iobroker.tr-064-community/main.js:948:62
          2019-12-12 17:31:11.215  - error: host.raspberrypi Caught by controller[0]:     at Timeout.doIt [as _onTimeout] (/opt/iobroker/node_modules/iobroker.tr-064-community/lib/phonebook.js:114:25)
          2019-12-12 17:31:11.216  - error: host.raspberrypi Caught by controller[0]:     at ontimeout (timers.js:436:11)
          2019-12-12 17:31:11.217  - error: host.raspberrypi Caught by controller[0]:     at tryOnTimeout (timers.js:300:5)
          2019-12-12 17:31:11.218  - error: host.raspberrypi Caught by controller[0]:     at listOnTimeout (timers.js:263:5)
          2019-12-12 17:31:11.219  - error: host.raspberrypi Caught by controller[0]:     at Timer.processTimers (timers.js:223:10)
          2019-12-12 17:31:11.221  - info: host.raspberrypi instance system.adapter.tr-064-community.0 terminated with code 0 (NO_ERROR)
          2019-12-12 17:31:11.222  - info: host.raspberrypi Restart adapter system.adapter.tr-064-community.0 because enabled
          2019-12-12 17:31:41.251  - info: host.raspberrypi instance system.adapter.tr-064-community.0 started with pid 7583
          2019-12-12 17:31:44.853  - info: tr-064-community.0 (7583) starting. Version 1.2.0 in /opt/iobroker/node_modules/iobroker.tr-064-community, node: v10.17.0
          2019-12-12 17:31:49.924  - error: tr-064-community.0 (7583) uncaught exception: Converting circular structure to JSON
          2019-12-12 17:31:49.927  - error: tr-064-community.0 (7583) TypeError: Converting circular structure to JSON
          2019-12-12 17:31:49.940  - info: tr-064-community.0 (7583) terminating
          2019-12-12 17:31:49.943  - info: tr-064-community.0 (7583) Terminated (NO_ERROR): Without reason
          2019-12-12 17:31:50.490  - error: host.raspberrypi Caught by controller[0]: TypeError: Converting circular structure to JSON
          2019-12-12 17:31:50.492  - error: host.raspberrypi Caught by controller[0]:     at JSON.stringify (<anonymous>)
          2019-12-12 17:31:50.493  - error: host.raspberrypi Caught by controller[0]:     at /opt/iobroker/node_modules/iobroker.tr-064-community/main.js:948:62
          2019-12-12 17:31:50.494  - error: host.raspberrypi Caught by controller[0]:     at Timeout.doIt [as _onTimeout] (/opt/iobroker/node_modules/iobroker.tr-064-community/lib/phonebook.js:114:25)
          2019-12-12 17:31:50.494  - error: host.raspberrypi Caught by controller[0]:     at ontimeout (timers.js:436:11)
          2019-12-12 17:31:50.495  - error: host.raspberrypi Caught by controller[0]:     at tryOnTimeout (timers.js:300:5)
          2019-12-12 17:31:50.495  - error: host.raspberrypi Caught by controller[0]:     at listOnTimeout (timers.js:263:5)
          2019-12-12 17:31:50.495  - error: host.raspberrypi Caught by controller[0]:     at Timer.processTimers (timers.js:223:10)
          2019-12-12 17:31:50.496  - info: host.raspberrypi instance system.adapter.tr-064-community.0 terminated with code 0 (NO_ERROR)
          2019-12-12 17:31:50.496  - info: host.raspberrypi Restart adapter system.adapter.tr-064-community.0 because enabled
            @apollon77
            #469
            @conectas sicher das. Du vom GitHub neu drüber installiert hast? Hm ...
            HomoranH conectasC 2 Antworten Letzte Antwort
              #470
              @apollon77
              Vielleicht hilft upload
                #471
                Ne ich hab Blödsinn gemacht.
                Man kann die Zeile
                Einfach mit // auskommentierrn.
                Handy lässt mich gerade nicht editieren :-(
                conectasC 1 Antwort Letzte Antwort
                  conectasC Offline
                  conectasC Offline
                  conectas
                  schrieb am zuletzt editiert von conectas
                  #472
                  @apollon77
                  Die Version geht jetzt wieder .. komplett neu Installiert.
                  Irgendwie bin ich zu Blöd um hier im Forum zu begreifen, wann hier wo was hingeschrieben wird.
                  (Firefox macht auch irgendwie komische Fenster)
                  .. bekomme ich aber schon irgendwann raus ;-)
                    Man kann die Zeile
                    conectasC Offline
                    conectasC Offline
                    conectas
                    #473
                    @apollon77 sagte in Test Adapter tr-064-community v1.0.x:
                    pollingTimer = setTimeout(updateAll, 2000);
                      #474
                      @conectas na wenn’s wieder tut mit debug dann kommentiert nix aus ;-)
                      Müsste ein Adapter.log.debug
                        conectasC Offline
                        conectasC Offline
                        conectas
                        #475
                        Adapter.log.debug
                        949 //adapter.log.debug('Final Phonebook: ' + JSON.stringify(phonebook));
                        Haste DU bereits raus gemacht ;-)
                          #476
                          Also dann neue logs bitte und Fälle neu checken.
                          conectasC 3 Antworten Letzte Antwort
                            conectasC Offline
                            conectasC Offline
                            conectas
                            #477
                            Fall 01: 2mal hintereinander gleicher OUT (0171) auf IN (628yxz6)
                            jetzt wird nix (selbst) tr-064-community.0.callmonitor.inbound.json nicht neu geschrieben
                            2019-12-12 19:58:38.454  - debug: tr-064-community.0 (15488) callmonitor raw data: "12.12.19 19:58:38;RING;2;0171xyz;628xyz6;SIP0;\r\n"
                            2019-12-12 19:58:38.456  - debug: tr-064-community.0 (15488) callmonitor handle inbound message: {"caller":"0171xyz","callee":"628xyz6"}
                            2019-12-12 19:58:38.457  - debug: tr-064-community.0 (15488) Set State callmonitor.inbound.timestamp: "12.12.19 19:58:38" / ack=true
                            2019-12-12 19:58:38.460  - debug: tr-064-community.0 (15488) Search number 0049171xyz in phonebook: {"name":"NNAme Stefan","normalizedName":"NNAmestefan","number":"0049171yxz","id":"634","phonebookId":"0"}
                            2019-12-12 19:58:38.463  - debug: tr-064-community.0 (15488) Search number 004930628xyz6 in phonebook: {"name":"NNAme Kerstin","normalizedName":"NNAmekerstin","number":"004930628xyz6","id":"631","phonebookId":"0"}
                            2019-12-12 19:58:38.465  - debug: tr-064-community.0 (15488) Set State callmonitor.toPauseState: "ring" / ack=true
                            2019-12-12 19:58:38.467  - debug: tr-064-community.0 (15488) callMonitor.set: type=inbound caller=0171xyz callee=628xyz6 callerName=NNAme Stefan calleeName=NNAme Kerstin
                            2019-12-12 19:58:38.671  - debug: tr-064-community.0 (15488) Set State callmonitor.ringing: true / ack=true
                            2019-12-12 19:58:38.841  - debug: tr-064-community.0 (15488) setting 0 enable=false
                            2019-12-12 19:58:38.843  - debug: tr-064-community.0 (15488) setting 1 enable=false
                            2019-12-12 19:58:38.843  - debug: tr-064-community.0 (15488) setting 2 enable=false
                            2019-12-12 19:58:38.844  - debug: tr-064-community.0 (15488) setting 3 enable=false
                            2019-12-12 19:58:38.844  - debug: tr-064-community.0 (15488) setting 4 enable=false
                            2019-12-12 19:58:38.845  - debug: tr-064-community.0 (15488) setting 5 enable=true
                            2019-12-12 19:58:38.845  - debug: tr-064-community.0 (15488) setting 6 enable=true
                            2019-12-12 19:58:38.846  - debug: tr-064-community.0 (15488) setting 7 enable=true
                            2019-12-12 19:58:38.846  - debug: tr-064-community.0 (15488) setting 8 enable=true
                            2019-12-12 19:58:38.847  - debug: tr-064-community.0 (15488) setting 9 enable=true
                            2019-12-12 19:58:45.625  - debug: tr-064-community.0 (15488) callmonitor raw data: "12.12.19 19:58:45;CONNECT;2;4;0171xyz;\r\n"
                            2019-12-12 19:58:45.627  - debug: tr-064-community.0 (15488) callmonitor handle connect message: {"caller":"0171xyz","callee":"628xyz6","_type":"inbound","callerName":"NNAme Stefan","calleeName":"NNAme Kerstin","extension":"4"}
                            2019-12-12 19:58:45.628  - debug: tr-064-community.0 (15488) Set State callmonitor.connect.timestamp: "12.12.19 19:58:45" / ack=true
                            2019-12-12 19:58:45.629  - debug: tr-064-community.0 (15488) Set State callmonitor.toPauseState: "connect" / ack=true
                            2019-12-12 19:58:45.630  - debug: tr-064-community.0 (15488) Set State callmonitor.toPauseState-4: "connect" / ack=true
                            2019-12-12 19:58:45.631  - debug: tr-064-community.0 (15488) callMonitor.set: type=connect caller=0171xyz callee=628xyz6 callerName=NNAme Stefan calleeName=NNAme Kerstin
                            2019-12-12 19:58:45.833  - debug: tr-064-community.0 (15488) Set State callmonitor.ringing: false / ack=true
                            2019-12-12 19:58:48.464  - debug: tr-064-community.0 (15488) callmonitor raw data: "12.12.19 19:58:48;DISCONNECT;2;3;\r\n"
                            2019-12-12 19:58:48.466  - debug: tr-064-community.0 (15488) callmonitor handle lastCall message: {"caller":"0171xyz","callee":"628xyz6","_type":"connect","callerName":"NNAme Stefan","calleeName":"NNAme Kerstin","extension":"4","type":"disconnect","duration":3}
                            2019-12-12 19:58:48.468  - debug: tr-064-community.0 (15488) Set State callmonitor.lastCall.type: "disconnect" / ack=true
                            2019-12-12 19:58:48.470  - debug: tr-064-community.0 (15488) Set State callmonitor.lastCall.duration: 3 / ack=true
                            2019-12-12 19:58:48.472  - debug: tr-064-community.0 (15488) Set State callmonitor.lastCall.timestamp: "12.12.19 19:58:48" / ack=true
                            2019-12-12 19:58:48.474  - debug: tr-064-community.0 (15488) Set State callmonitor.lastCall.json: "{\"caller\":\"0171xyz\",\"callee\":\"628xyz6\",\"_type\":\"lastCall\",\"callerName\":\"NNAme Stefan\",\"calleeName\":\"NNAme Kerstin\",\"extension\":\"4\",\"type\":\"disconnect\",\"duration\":3}" / ack=true
                            2019-12-12 19:58:48.476  - debug: tr-064-community.0 (15488) Set State callmonitor.toPauseState: "end" / ack=true
                            2019-12-12 19:58:48.478  - debug: tr-064-community.0 (15488) Set State callmonitor.toPauseState-4: "end" / ack=true
                            2019-12-12 19:58:48.479  - debug: tr-064-community.0 (15488) callMonitor.set: type=lastCall caller=0171xyz callee=628xyz6 callerName=NNAme Stefan calleeName=NNAme Kerstin
                            2019-12-12 19:58:48.851  - debug: tr-064-community.0 (15488) in updateAll
                            2019-12-12 19:58:48.853  - debug: tr-064-community.0 (15488) updateDevices
                            2019-12-12 19:58:48.854  - debug: tr-064-community.0 (15488) forEachConfiguredDevice
                            2019-12-12 19:58:51.289  - debug: tr-064-community.0 (15488) setting 0 enable=false
                            2019-12-12 19:58:51.290  - debug: tr-064-community.0 (15488) setting 1 enable=false
                            2019-12-12 19:58:51.291  - debug: tr-064-community.0 (15488) setting 2 enable=false
                            2019-12-12 19:58:51.291  - debug: tr-064-community.0 (15488) setting 3 enable=false
                            2019-12-12 19:58:51.292  - debug: tr-064-community.0 (15488) setting 4 enable=false
                            2019-12-12 19:58:51.292  - debug: tr-064-community.0 (15488) setting 5 enable=true
                            2019-12-12 19:58:51.292  - debug: tr-064-community.0 (15488) setting 6 enable=true
                            2019-12-12 19:58:51.293  - debug: tr-064-community.0 (15488) setting 7 enable=true
                            2019-12-12 19:58:51.293  - debug: tr-064-community.0 (15488) setting 8 enable=true
                            2019-12-12 19:58:51.295  - debug: tr-064-community.0 (15488) setting 9 enable=true
                              conectasC Offline
                              conectasC Offline
                              conectas
                              #478
                              Fall2:
                              abwechselt:
                              OUT 0171 zu 628xy6
                              danach
                              OUT 0171 zu 628xy7
                              tr-064-community.0.callmonitor.inbound.caller
                              tr-064-community.0.callmonitor.inbound.callerName
                              werden nicht aktualisiert...
                              2019-12-12 20:07:10.493  - debug: tr-064-community.0 (15488) in updateAll
                              2019-12-12 20:07:10.495  - debug: tr-064-community.0 (15488) updateDevices
                              2019-12-12 20:07:10.496  - debug: tr-064-community.0 (15488) forEachConfiguredDevice
                              2019-12-12 20:07:12.959  - debug: tr-064-community.0 (15488) callmonitor raw data: "12.12.19 20:07:12;RING;2;0171xyz;628yxz6;SIP0;\r\n"
                              2019-12-12 20:07:12.960  - debug: tr-064-community.0 (15488) callmonitor handle inbound message: {"caller":"0171xyz","callee":"628yxz6"}
                              2019-12-12 20:07:12.961  - debug: tr-064-community.0 (15488) Set State callmonitor.inbound.callee: "628yxz6" / ack=true
                              2019-12-12 20:07:12.962  - debug: tr-064-community.0 (15488) Set State callmonitor.inbound.timestamp: "12.12.19 20:07:12" / ack=true
                              2019-12-12 20:07:12.963  - debug: tr-064-community.0 (15488) Search number 0049171xyz in phonebook: {"name":"NName Stefan","normalizedName":"NNamestefan","number":"0049171xyz","id":"634","phonebookId":"0"}
                              2019-12-12 20:07:12.964  - debug: tr-064-community.0 (15488) Search number 004930628yxz6 in phonebook: {"name":"NName Kerstin","normalizedName":"NNamekerstin","number":"004930628yxz6","id":"631","phonebookId":"0"}
                              2019-12-12 20:07:12.964  - debug: tr-064-community.0 (15488) Set State callmonitor.inbound.calleeName: "NName Kerstin" / ack=true
                              2019-12-12 20:07:12.965  - debug: tr-064-community.0 (15488) Set State callmonitor.inbound.json: "{\"caller\":\"0171xyz\",\"callee\":\"628yxz6\",\"_type\":\"inbound\",\"callerName\":\"NName Stefan\",\"calleeName\":\"NName Kerstin\"}" / ack=true
                              2019-12-12 20:07:12.966  - debug: tr-064-community.0 (15488) Set State callmonitor.toPauseState: "ring" / ack=true
                              2019-12-12 20:07:12.967  - debug: tr-064-community.0 (15488) callMonitor.set: type=inbound caller=0171xyz callee=628yxz6 callerName=NName Stefan calleeName=NName Kerstin
                              2019-12-12 20:07:13.168  - debug: tr-064-community.0 (15488) Set State callmonitor.ringing: true / ack=true
                              2019-12-12 20:07:13.225  - debug: tr-064-community.0 (15488) setting 0 enable=false
                              2019-12-12 20:07:13.226  - debug: tr-064-community.0 (15488) setting 1 enable=false
                              2019-12-12 20:07:13.227  - debug: tr-064-community.0 (15488) setting 2 enable=false
                              2019-12-12 20:07:13.228  - debug: tr-064-community.0 (15488) setting 3 enable=false
                              2019-12-12 20:07:13.229  - debug: tr-064-community.0 (15488) setting 4 enable=false
                              2019-12-12 20:07:13.229  - debug: tr-064-community.0 (15488) setting 5 enable=true
                              2019-12-12 20:07:13.230  - debug: tr-064-community.0 (15488) setting 6 enable=true
                              2019-12-12 20:07:13.230  - debug: tr-064-community.0 (15488) setting 7 enable=true
                              2019-12-12 20:07:13.231  - debug: tr-064-community.0 (15488) setting 8 enable=true
                              2019-12-12 20:07:13.231  - debug: tr-064-community.0 (15488) setting 9 enable=true
                              2019-12-12 20:07:19.126  - debug: tr-064-community.0 (15488) callmonitor raw data: "12.12.19 20:07:19;CONNECT;2;4;0171xyz;\r\n"
                              2019-12-12 20:07:19.127  - debug: tr-064-community.0 (15488) callmonitor handle connect message: {"caller":"0171xyz","callee":"628yxz6","_type":"inbound","callerName":"NName Stefan","calleeName":"NName Kerstin","extension":"4"}
                              2019-12-12 20:07:19.128  - debug: tr-064-community.0 (15488) Set State callmonitor.connect.callee: "628yxz6" / ack=true
                              2019-12-12 20:07:19.129  - debug: tr-064-community.0 (15488) Set State callmonitor.connect.calleeName: "NName Kerstin" / ack=true
                              2019-12-12 20:07:19.130  - debug: tr-064-community.0 (15488) Set State callmonitor.connect.timestamp: "12.12.19 20:07:19" / ack=true
                              2019-12-12 20:07:19.131  - debug: tr-064-community.0 (15488) Set State callmonitor.connect.json: "{\"caller\":\"0171xyz\",\"callee\":\"628yxz6\",\"_type\":\"connect\",\"callerName\":\"NName Stefan\",\"calleeName\":\"NName Kerstin\",\"extension\":\"4\"}" / ack=true
                              2019-12-12 20:07:19.135  - debug: tr-064-community.0 (15488) Set State callmonitor.toPauseState: "connect" / ack=true
                              2019-12-12 20:07:19.136  - debug: tr-064-community.0 (15488) Set State callmonitor.toPauseState-4: "connect" / ack=true
                              2019-12-12 20:07:19.137  - debug: tr-064-community.0 (15488) callMonitor.set: type=connect caller=0171xyz callee=628yxz6 callerName=NName Stefan calleeName=NName Kerstin
                              2019-12-12 20:07:19.339  - debug: tr-064-community.0 (15488) Set State callmonitor.ringing: false / ack=true
                              2019-12-12 20:07:20.343  - debug: tr-064-community.0 (15488) callmonitor raw data: "12.12.19 20:07:20;DISCONNECT;2;2;\r\n"
                              2019-12-12 20:07:20.344  - debug: tr-064-community.0 (15488) callmonitor handle lastCall message: {"caller":"0171xyz","callee":"628yxz6","_type":"connect","callerName":"NName Stefan","calleeName":"NName Kerstin","extension":"4","type":"disconnect","duration":2}
                              2019-12-12 20:07:20.345  - debug: tr-064-community.0 (15488) Set State callmonitor.lastCall.callee: "628yxz6" / ack=true
                              2019-12-12 20:07:20.346  - debug: tr-064-community.0 (15488) Set State callmonitor.lastCall.calleeName: "NName Kerstin" / ack=true
                              2019-12-12 20:07:20.347  - debug: tr-064-community.0 (15488) Set State callmonitor.lastCall.duration: 2 / ack=true
                              2019-12-12 20:07:20.348  - debug: tr-064-community.0 (15488) Set State callmonitor.lastCall.timestamp: "12.12.19 20:07:20" / ack=true
                              2019-12-12 20:07:20.350  - debug: tr-064-community.0 (15488) Set State callmonitor.lastCall.json: "{\"caller\":\"0171xyz\",\"callee\":\"628yxz6\",\"_type\":\"lastCall\",\"callerName\":\"NName Stefan\",\"calleeName\":\"NName Kerstin\",\"extension\":\"4\",\"type\":\"disconnect\",\"duration\":2}" / ack=true
                              2019-12-12 20:07:20.351  - debug: tr-064-community.0 (15488) Set State callmonitor.toPauseState: "end" / ack=true
                              2019-12-12 20:07:20.352  - debug: tr-064-community.0 (15488) Set State callmonitor.toPauseState-4: "end" / ack=true
                              2019-12-12 20:07:20.353  - debug: tr-064-community.0 (15488) callMonitor.set: type=lastCall caller=0171xyz callee=628yxz6 callerName=NName Stefan calleeName=NName Kerstin
                              2019-12-12 20:07:23.232  - debug: tr-064-community.0 (15488) in updateAll
                              2019-12-12 20:07:23.234  - debug: tr-064-community.0 (15488) updateDevices
                              2019-12-12 20:07:23.235  - debug: tr-064-community.0 (15488) forEachConfiguredDevice
                                conectasC Offline
                                conectasC Offline
                                conectas
                                #479
                                Ich würde bei Tests dieses Script mitlaufen lassen.. oder bringt das in deinen Logs dann zu viel durcheinander?
                                let tr064 = "tr-064-community.0.callmonitor.";
                                var callerNumber    // Anrufernummer
                                var callerName      // Name des Anrufers
                                var calleeNumber    // angerufene Nummer
                                var calleeName      // angerufener Name
                                var callAllDataJson = { "caller": "caller Nr", "callee": "callee Nr", "_type": "_type inbound", "callerName": "Caller Name", "calleeName": "Callee Name" };
                                on({ id: "tr-064-community.0.callmonitor.toPauseState", change: "any" }, function (obj) {
                                    console.log('---> Ringing?: ');
                                    let sToPauseState = getState(tr064 + "toPauseState").val;
                                    if ("ring" == sToPauseState) {
                                        callerNumber = getState(tr064 + "inbound.caller").val;          // Anrufernummer
                                        callerName = getState(tr064 + "inbound.callerName").val;        // Name des Anrufers
                                        calleeNumber = getState(tr064 + "inbound.callee").val;          // angerufene Nummer
                                        calleeName = getState(tr064 + "inbound.calleeName").val;        // angerufener Name
                                        callAllDataJson = getState(tr064 + "inbound.json").val;          // json
                                        console.log('---> Ringing? - callerNumber: ' + callerNumber);
                                        console.log('---> Ringing? - callerName: ' + callerName);
                                        console.log('---> Ringing? - calleeNumber: ' + calleeNumber);
                                        console.log('---> Ringing? - calleeName: ' + calleeName);
                                        console.log('---> Ringing? - callAllDataJson: ' + String(callAllDataJson));
                                    } else if ("end" == sToPauseState) {
                                        setState(tr064 + "inbound.caller", '');
                                        setState(tr064 + "inbound.callerName", '');
                                        setState(tr064 + "inbound.callee", '');
                                        setState(tr064 + "inbound.calleeName", '');
                                        setState(tr064 + "inbound.json", '');
                                  #480
                                  Oooook ... ich hab mal erste DInge verändert. Bitte nochmal neu versuchen vom GitHub, bitte checkt aber auch ob der ganze Rest (also auch IP.Devices und so) noch so tut wie es soll.
                                  Und bitte extra Skripte weglassen. Danke
                                    conectasC Offline
                                    conectasC Offline
                                    conectas
                                    #481
                                    Knallt...
                                    2019-12-12 21:24:14.636  - info: host.raspberrypi "system.adapter.tr-064-community.0" enabled
                                    2019-12-12 21:24:14.666  - info: host.raspberrypi instance system.adapter.tr-064-community.0 started with pid 18626
                                    2019-12-12 21:24:17.602  - debug: tr-064-community.0 (18626) Redis Objects: Use Redis connection: 127.0.0.1:9001
                                    2019-12-12 21:24:17.671  - debug: tr-064-community.0 (18626) Objects client ready ... initialize now
                                    2019-12-12 21:24:17.680  - debug: tr-064-community.0 (18626) Objects create PubSub Client
                                    2019-12-12 21:24:17.683  - debug: tr-064-community.0 (18626) Objects client initialize lua scripts
                                    2019-12-12 21:24:17.712  - debug: tr-064-community.0 (18626) objectDB connected
                                    2019-12-12 21:24:17.718  - debug: tr-064-community.0 (18626) Redis States: Use Redis connection: 127.0.0.1:9000
                                    2019-12-12 21:24:17.725  - debug: tr-064-community.0 (18626) Objects connected to redis: 127.0.0.1:9001
                                    2019-12-12 21:24:17.735  - debug: tr-064-community.0 (18626) States create PubSub Client
                                    2019-12-12 21:24:17.738  - debug: tr-064-community.0 (18626) statesDB connected
                                    2019-12-12 21:24:17.805  - debug: tr-064-community.0 (18626) States connected to redis: 127.0.0.1:9000
                                    2019-12-12 21:24:18.366  - info: tr-064-community.0 (18626) starting. Version 1.2.0 in /opt/iobroker/node_modules/iobroker.tr-064-community, node: v10.17.0
                                    2019-12-12 21:24:21.236  - error: tr-064-community.0 (18626) uncaught exception: st is not defined
                                    2019-12-12 21:24:21.241  - error: tr-064-community.0 (18626) ReferenceError: st is not defined
                                        at createObjects (/opt/iobroker/node_modules/iobroker.tr-064-community/main.js:102:59)
                                        at /opt/iobroker/node_modules/iobroker.tr-064-community/main.js:940:9
                                        at /opt/iobroker/node_modules/iobroker.tr-064-community/lib/soef.js:1610:28
                                        at /opt/iobroker/node_modules/tr-O64/lib/Service.js:267:17
                                        at Parser.<anonymous> (/opt/iobroker/node_modules/xml2js/lib/parser.js:306:18)
                                        at Parser.emit (events.js:198:13)
                                        at SAXParser.onclosetag (/opt/iobroker/node_modules/xml2js/lib/parser.js:264:26)
                                        at emit (/opt/iobroker/node_modules/sax/lib/sax.js:624:35)
                                        at emitNode (/opt/iobroker/node_modules/sax/lib/sax.js:629:5)
                                        at closeTag (/opt/iobroker/node_modules/sax/lib/sax.js:889:7)
                                    2019-12-12 21:24:21.300  - info: tr-064-community.0 (18626) terminating
                                    2019-12-12 21:24:21.303  - info: tr-064-community.0 (18626) Terminated (NO_ERROR): Without reason
                                    2019-12-12 21:24:21.861  - error: host.raspberrypi Caught by controller[0]: ReferenceError: st is not defined
                                    2019-12-12 21:24:21.864  - error: host.raspberrypi Caught by controller[0]:     at createObjects (/opt/iobroker/node_modules/iobroker.tr-064-community/main.js:102:59)
                                    2019-12-12 21:24:21.865  - error: host.raspberrypi Caught by controller[0]:     at /opt/iobroker/node_modules/iobroker.tr-064-community/main.js:940:9
                                    2019-12-12 21:24:21.866  - error: host.raspberrypi Caught by controller[0]:     at /opt/iobroker/node_modules/iobroker.tr-064-community/lib/soef.js:1610:28
                                    2019-12-12 21:24:21.866  - error: host.raspberrypi Caught by controller[0]:     at /opt/iobroker/node_modules/tr-O64/lib/Service.js:267:17
                                    2019-12-12 21:24:21.867  - error: host.raspberrypi Caught by controller[0]:     at Parser.<anonymous> (/opt/iobroker/node_modules/xml2js/lib/parser.js:306:18)
                                    2019-12-12 21:24:21.867  - error: host.raspberrypi Caught by controller[0]:     at Parser.emit (events.js:198:13)
                                    2019-12-12 21:24:21.868  - error: host.raspberrypi Caught by controller[0]:     at SAXParser.onclosetag (/opt/iobroker/node_modules/xml2js/lib/parser.js:264:26)
                                    2019-12-12 21:24:21.868  - error: host.raspberrypi Caught by controller[0]:     at emit (/opt/iobroker/node_modules/sax/lib/sax.js:624:35)
                                    2019-12-12 21:24:21.869  - error: host.raspberrypi Caught by controller[0]:     at emitNode (/opt/iobroker/node_modules/sax/lib/sax.js:629:5)
                                    2019-12-12 21:24:21.869  - error: host.raspberrypi Caught by controller[0]:     at closeTag (/opt/iobroker/node_modules/sax/lib/sax.js:889:7)
                                    2019-12-12 21:24:21.870  - info: host.raspberrypi instance system.adapter.tr-064-community.0 terminated with code 0 (NO_ERROR)
                                    2019-12-12 21:24:21.870  - info: host.raspberrypi Restart adapter system.adapter.tr-064-community.0 because enabled
                                      #482
                                      gggrrrr ... fixed on GitHub. Sorry
                                        conectasC Offline
                                        conectasC Offline
                                        conectas
                                        #483
                                        @apollon77
                                        außer toPauseState werden im callmonitor nix angelegt.. 2x getestet
                                          @apollon77
                                          #484
                                          @conectas Hast Du wieder ein Log?
