  4. Test Adapter tr-064-community v1.0.x
    6.0k
tr-064community
727 Beiträge 88 Kommentatoren 243.7k Aufrufe 66 Beobachtet
  • apollon77A Offline
    #463
    Ok, ich habe eine Code-Stelle gefunden wo glaube ich die Werte falsch geschrieben wurden ... versuch mal neu GitHub.
    PS: Einwas noch: States werden nur geschrieben wenn 200ms keine Änderungen waren ...
    conectasC 2 Antworten Letzte Antwort
    • apollon77A apollon77
      conectasC Offline
      conectasC Offline
      conectas
      schrieb am zuletzt editiert von conectas
      #464
      @apollon77
      Dauert noch ne Sek. .. Knallt bei Install
      host.raspberrypi	2019-12-12 17:12:15.366	error	Caught by controller[0]: at Timer.processTimers (timers.js:223:10)
      host.raspberrypi	2019-12-12 17:12:15.365	error	Caught by controller[0]: at listOnTimeout (timers.js:263:5)
      host.raspberrypi	2019-12-12 17:12:15.365	error	Caught by controller[0]: at tryOnTimeout (timers.js:300:5)
      host.raspberrypi	2019-12-12 17:12:15.365	error	Caught by controller[0]: at ontimeout (timers.js:436:11)
      host.raspberrypi	2019-12-12 17:12:15.364	error	Caught by controller[0]: at Timeout.doIt [as _onTimeout] (/opt/iobroker/node_modules/iobroker.tr-064-community/lib/phonebook.js:114:25)
      host.raspberrypi	2019-12-12 17:12:15.364	error	Caught by controller[0]: at /opt/iobroker/node_modules/iobroker.tr-064-community/main.js:948:62
      host.raspberrypi	2019-12-12 17:12:15.363	error	Caught by controller[0]: at JSON.stringify (<anonymous>)
      host.raspberrypi	2019-12-12 17:12:15.361	error	Caught by controller[0]: TypeError: Converting circular structure to JSON
      tr-064-community.0	2019-12-12 17:12:14.811	info	(27839) Terminated (NO_ERROR): Without reason
      tr-064-community.0	2019-12-12 17:12:14.806	info	(27839) terminating
      tr-064-community.0	2019-12-12 17:12:14.711	error	(27839) TypeError: Converting circular structure to JSON at JSON.stringify (<anonymous>) at /opt/iobroker/node_modules/iobroker.tr-064-community/main.js:948:62 at Timeout.doIt [as _onTimeo
      tr-064-community.0	2019-12-12 17:12:14.708	error	(27839) uncaught exception: Converting circular structure to JSON
      conectasC apollon77A 2 Antworten Letzte Antwort
      • conectasC conectas
        @apollon77
        conectasC Offline
        conectasC Offline
        conectas
        #465
        @conectas
        Ich starte mal die Fritze neu...
        2019-12-12 17:17:28.384  - info: host.raspberrypi Update repository "latest" under "http://download.iobroker.net/sources-dist-latest.json"
        2019-12-12 17:18:06.065  - info: host.raspberrypi iobroker add tr-064-community  --host raspberrypi
        2019-12-12 17:18:09.756  - info: host.raspberrypi iobroker host.raspberrypi create instance tr-064-community
        2019-12-12 17:18:09.782  - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.tr-064-community.0.sigKill created
        2019-12-12 17:18:09.827  - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.tr-064-community.0.eventLoopLag created
        2019-12-12 17:18:09.872  - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.tr-064-community.0.outputCount created
        2019-12-12 17:18:09.912  - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.tr-064-community.0.inputCount created
        2019-12-12 17:18:09.974  - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.tr-064-community.0.uptime created
        2019-12-12 17:18:10.016  - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.tr-064-community.0.memRss created
        2019-12-12 17:18:10.057  - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.tr-064-community.0.memHeapTotal created
        2019-12-12 17:18:10.104  - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.tr-064-community.0.memHeapUsed created
        2019-12-12 17:18:10.150  - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.tr-064-community.0.cputime created
        2019-12-12 17:18:10.187  - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.tr-064-community.0.cpu created
        2019-12-12 17:18:10.223  - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.tr-064-community.0.compactMode created
        2019-12-12 17:18:10.261  - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.tr-064-community.0.connected created
        2019-12-12 17:18:10.298  - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.tr-064-community.0.alive created
        2019-12-12 17:18:10.349  - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.tr-064-community.0 created
        2019-12-12 17:18:11.378  - info: host.raspberrypi iobroker exit 0
        2019-12-12 17:18:12.875  - info: host.raspberrypi instance system.adapter.tr-064-community.0 started with pid 6951
        2019-12-12 17:18:17.706  - info: tr-064-community.0 (6951) starting. Version 1.2.0 in /opt/iobroker/node_modules/iobroker.tr-064-community, node: v10.17.0
        2019-12-12 17:18:19.870  - error: tr-064-community.0 (6951) Error: sendSOAPActionRequest Error action=GetInfo serviceType=urn:dslforum-org:service:WLANConfiguration:1: 401 - {"code":401}
        2019-12-12 17:18:19.872  - error: tr-064-community.0 (6951) ~
        2019-12-12 17:18:19.873  - error: tr-064-community.0 (6951) ~~ Fatal error. Can not connect to your FritzBox.
        2019-12-12 17:18:19.875  - error: tr-064-community.0 (6951) ~~ If configuration, networt, IP address, etc. ok, try to restart your FritzBox
        2019-12-12 17:18:19.876  - error: tr-064-community.0 (6951) ~
        2019-12-12 17:18:24.922  - error: host.raspberrypi instance system.adapter.tr-064-community.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2019-12-12 17:18:24.923  - info: host.raspberrypi Restart adapter system.adapter.tr-064-community.0 because enabled
        tail: iobroker.2019-12-12.log: Datei abgeschnitten
        undefined2019-12-12 17:18:54.955  - info: host.raspberrypi instance system.adapter.tr-064-community.0 started with pid 8222
        2019-12-12 17:18:59.215  - info: tr-064-community.0 (8222) starting. Version 1.2.0 in /opt/iobroker/node_modules/iobroker.tr-064-community, node: v10.17.0
        2019-12-12 17:19:01.042  - error: tr-064-community.0 (8222) Error: sendSOAPActionRequest Error action=GetInfo serviceType=urn:dslforum-org:service:WLANConfiguration:1: 401 - {"code":401}
        2019-12-12 17:19:01.044  - error: tr-064-community.0 (8222) ~
        2019-12-12 17:19:01.045  - error: tr-064-community.0 (8222) ~~ Fatal error. Can not connect to your FritzBox.
        2019-12-12 17:19:01.046  - error: tr-064-community.0 (8222) ~~ If configuration, networt, IP address, etc. ok, try to restart your FritzBox
        2019-12-12 17:19:04.035  - info: host.raspberrypi stopInstance system.adapter.tr-064-community.0 (force=false, process=true)
        2019-12-12 17:19:04.039  - info: host.raspberrypi stopInstance system.adapter.tr-064-community.0 send kill signal
        2019-12-12 17:19:04.046  - info: tr-064-community.0 (8222) Got terminate signal TERMINATE_YOURSELF
        2019-12-12 17:19:04.050  - info: tr-064-community.0 (8222) terminating
        2019-12-12 17:19:04.052  - info: tr-064-community.0 (8222) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
        2019-12-12 17:19:04.597  - info: host.raspberrypi instance system.adapter.tr-064-community.0 terminated with code 156 (156)
        2019-12-12 17:19:06.602  - info: host.raspberrypi instance system.adapter.tr-064-community.0 started with pid 8513
        2019-12-12 17:19:10.630  - info: tr-064-community.0 (8513) starting. Version 1.2.0 in /opt/iobroker/node_modules/iobroker.tr-064-community, node: v10.17.0
        2019-12-12 17:19:15.996  - error: tr-064-community.0 (8513) uncaught exception: Converting circular structure to JSON
        2019-12-12 17:19:15.999  - error: tr-064-community.0 (8513) TypeError: Converting circular structure to JSON
        2019-12-12 17:19:16.010  - info: tr-064-community.0 (8513) terminating
        2019-12-12 17:19:16.014  - info: tr-064-community.0 (8513) Terminated (NO_ERROR): Without reason
        2019-12-12 17:19:16.565  - error: host.raspberrypi Caught by controller[0]: TypeError: Converting circular structure to JSON
        2019-12-12 17:19:16.567  - error: host.raspberrypi Caught by controller[0]:     at JSON.stringify (<anonymous>)
        2019-12-12 17:19:16.568  - error: host.raspberrypi Caught by controller[0]:     at /opt/iobroker/node_modules/iobroker.tr-064-community/main.js:948:62
        2019-12-12 17:19:16.568  - error: host.raspberrypi Caught by controller[0]:     at Timeout.doIt [as _onTimeout] (/opt/iobroker/node_modules/iobroker.tr-064-community/lib/phonebook.js:114:25)
        2019-12-12 17:19:16.569  - error: host.raspberrypi Caught by controller[0]:     at ontimeout (timers.js:436:11)
        2019-12-12 17:19:16.569  - error: host.raspberrypi Caught by controller[0]:     at tryOnTimeout (timers.js:300:5)
        2019-12-12 17:19:16.570  - error: host.raspberrypi Caught by controller[0]:     at listOnTimeout (timers.js:263:5)
        2019-12-12 17:19:16.570  - error: host.raspberrypi Caught by controller[0]:     at Timer.processTimers (timers.js:223:10)
        2019-12-12 17:19:16.571  - info: host.raspberrypi instance system.adapter.tr-064-community.0 terminated with code 0 (NO_ERROR)
        2019-12-12 17:19:16.571  - info: host.raspberrypi Restart adapter system.adapter.tr-064-community.0 because enabled
        2019-12-12 17:19:46.163  - info: host.raspberrypi "system.adapter.tr-064-community.0" disabled
        2019-12-12 17:19:50.354  - error: tr-064-community.0 (9678) adapter disabled
        2019-12-12 17:19:50.378  - warn: tr-064-community.0 (9678) Terminated (NO_ADAPTER_CONFIG_FOUND): Without reason
        2019-12-12 17:19:51.008  - error: host.raspberrypi instance system.adapter.tr-064-community.0 terminated with code 3 (NO_ADAPTER_CONFIG_FOUND)
        2019-12-12 17:19:51.010  - info: host.raspberrypi Do not restart adapter system.adapter.tr-064-community.0 because disabled or deleted
        2019-12-12 17:20:01.788  - info: host.raspberrypi "system.adapter.tr-064-community.0" enabled
        2019-12-12 17:20:01.827  - info: host.raspberrypi instance system.adapter.tr-064-community.0 started with pid 10215
        2019-12-12 17:20:05.857  - info: tr-064-community.0 (10215) starting. Version 1.2.0 in /opt/iobroker/node_modules/iobroker.tr-064-community, node: v10.17.0
        2019-12-12 17:20:10.848  - error: tr-064-community.0 (10215) uncaught exception: Converting circular structure to JSON
        2019-12-12 17:20:10.851  - error: tr-064-community.0 (10215) TypeError: Converting circular structure to JSON
        2019-12-12 17:20:10.871  - info: tr-064-community.0 (10215) terminating
        2019-12-12 17:20:10.875  - info: tr-064-community.0 (10215) Terminated (NO_ERROR): Without reason
        2019-12-12 17:20:11.414  - error: host.raspberrypi Caught by controller[0]: TypeError: Converting circular structure to JSON
        2019-12-12 17:20:11.415  - error: host.raspberrypi Caught by controller[0]:     at JSON.stringify (<anonymous>)
        2019-12-12 17:20:11.416  - error: host.raspberrypi Caught by controller[0]:     at /opt/iobroker/node_modules/iobroker.tr-064-community/main.js:948:62
        2019-12-12 17:20:11.417  - error: host.raspberrypi Caught by controller[0]:     at Timeout.doIt [as _onTimeout] (/opt/iobroker/node_modules/iobroker.tr-064-community/lib/phonebook.js:114:25)
        2019-12-12 17:20:11.417  - error: host.raspberrypi Caught by controller[0]:     at ontimeout (timers.js:436:11)
        2019-12-12 17:20:11.418  - error: host.raspberrypi Caught by controller[0]:     at tryOnTimeout (timers.js:300:5)
        2019-12-12 17:20:11.419  - error: host.raspberrypi Caught by controller[0]:     at listOnTimeout (timers.js:263:5)
        2019-12-12 17:20:11.419  - error: host.raspberrypi Caught by controller[0]:     at Timer.processTimers (timers.js:223:10)
        2019-12-12 17:20:11.420  - info: host.raspberrypi instance system.adapter.tr-064-community.0 terminated with code 0 (NO_ERROR)
        2019-12-12 17:20:11.420  - info: host.raspberrypi Restart adapter system.adapter.tr-064-community.0 because enabled
        2019-12-12 17:20:41.447  - info: host.raspberrypi instance system.adapter.tr-064-community.0 started with pid 11383
        2019-12-12 17:20:45.398  - info: tr-064-community.0 (11383) starting. Version 1.2.0 in /opt/iobroker/node_modules/iobroker.tr-064-community, node: v10.17.0
        2019-12-12 17:20:50.666  - error: tr-064-community.0 (11383) uncaught exception: Converting circular structure to JSON
        2019-12-12 17:20:50.669  - error: tr-064-community.0 (11383) TypeError: Converting circular structure to JSON
        2019-12-12 17:20:50.688  - info: tr-064-community.0 (11383) terminating
        2019-12-12 17:20:50.692  - info: tr-064-community.0 (11383) Terminated (NO_ERROR): Without reason
        2019-12-12 17:20:51.245  - error: host.raspberrypi Caught by controller[0]: TypeError: Converting circular structure to JSON
        2019-12-12 17:20:51.247  - error: host.raspberrypi Caught by controller[0]:     at JSON.stringify (<anonymous>)
        2019-12-12 17:20:51.248  - error: host.raspberrypi Caught by controller[0]:     at /opt/iobroker/node_modules/iobroker.tr-064-community/main.js:948:62
        2019-12-12 17:20:51.248  - error: host.raspberrypi Caught by controller[0]:     at Timeout.doIt [as _onTimeout] (/opt/iobroker/node_modules/iobroker.tr-064-community/lib/phonebook.js:114:25)
        2019-12-12 17:20:51.249  - error: host.raspberrypi Caught by controller[0]:     at ontimeout (timers.js:436:11)
        2019-12-12 17:20:51.249  - error: host.raspberrypi Caught by controller[0]:     at tryOnTimeout (timers.js:300:5)
        2019-12-12 17:20:51.249  - error: host.raspberrypi Caught by controller[0]:     at listOnTimeout (timers.js:263:5)
        2019-12-12 17:20:51.250  - error: host.raspberrypi Caught by controller[0]:     at Timer.processTimers (timers.js:223:10)
        2019-12-12 17:20:51.250  - info: host.raspberrypi instance system.adapter.tr-064-community.0 terminated with code 0 (NO_ERROR)
        2019-12-12 17:20:51.250  - info: host.raspberrypi Restart adapter system.adapter.tr-064-community.0 because enabled
          @apollon77
          #466
          @conectas mist ... mach Debug aus ... muss logging ändern - heute Abend dann
            #467
            Ok, bitte neu von GitHub und neu Starten ... sollte gefixt sein
              conectasC Offline
              conectasC Offline
              conectas
              #468
              @apollon77
              Knallt beim Start.. Änderungen waren nicht .. ;-)
              2019-12-12 17:31:01.655  - info: host.raspberrypi "system.adapter.tr-064-community.0" enabled
              2019-12-12 17:31:01.687  - info: host.raspberrypi instance system.adapter.tr-064-community.0 started with pid 6419
              2019-12-12 17:31:05.579  - info: tr-064-community.0 (6419) starting. Version 1.2.0 in /opt/iobroker/node_modules/iobroker.tr-064-community, node: v10.17.0
              2019-12-12 17:31:10.633  - error: tr-064-community.0 (6419) uncaught exception: Converting circular structure to JSON
              2019-12-12 17:31:10.636  - error: tr-064-community.0 (6419) TypeError: Converting circular structure to JSON
              2019-12-12 17:31:10.650  - info: tr-064-community.0 (6419) terminating
              2019-12-12 17:31:10.653  - info: tr-064-community.0 (6419) Terminated (NO_ERROR): Without reason
              2019-12-12 17:31:11.209  - error: host.raspberrypi Caught by controller[0]: TypeError: Converting circular structure to JSON
              2019-12-12 17:31:11.213  - error: host.raspberrypi Caught by controller[0]:     at JSON.stringify (<anonymous>)
              2019-12-12 17:31:11.214  - error: host.raspberrypi Caught by controller[0]:     at /opt/iobroker/node_modules/iobroker.tr-064-community/main.js:948:62
              2019-12-12 17:31:11.215  - error: host.raspberrypi Caught by controller[0]:     at Timeout.doIt [as _onTimeout] (/opt/iobroker/node_modules/iobroker.tr-064-community/lib/phonebook.js:114:25)
              2019-12-12 17:31:11.216  - error: host.raspberrypi Caught by controller[0]:     at ontimeout (timers.js:436:11)
              2019-12-12 17:31:11.217  - error: host.raspberrypi Caught by controller[0]:     at tryOnTimeout (timers.js:300:5)
              2019-12-12 17:31:11.218  - error: host.raspberrypi Caught by controller[0]:     at listOnTimeout (timers.js:263:5)
              2019-12-12 17:31:11.219  - error: host.raspberrypi Caught by controller[0]:     at Timer.processTimers (timers.js:223:10)
              2019-12-12 17:31:11.221  - info: host.raspberrypi instance system.adapter.tr-064-community.0 terminated with code 0 (NO_ERROR)
              2019-12-12 17:31:11.222  - info: host.raspberrypi Restart adapter system.adapter.tr-064-community.0 because enabled
              2019-12-12 17:31:41.251  - info: host.raspberrypi instance system.adapter.tr-064-community.0 started with pid 7583
              2019-12-12 17:31:44.853  - info: tr-064-community.0 (7583) starting. Version 1.2.0 in /opt/iobroker/node_modules/iobroker.tr-064-community, node: v10.17.0
              2019-12-12 17:31:49.924  - error: tr-064-community.0 (7583) uncaught exception: Converting circular structure to JSON
              2019-12-12 17:31:49.927  - error: tr-064-community.0 (7583) TypeError: Converting circular structure to JSON
              2019-12-12 17:31:49.940  - info: tr-064-community.0 (7583) terminating
              2019-12-12 17:31:49.943  - info: tr-064-community.0 (7583) Terminated (NO_ERROR): Without reason
              2019-12-12 17:31:50.490  - error: host.raspberrypi Caught by controller[0]: TypeError: Converting circular structure to JSON
              2019-12-12 17:31:50.492  - error: host.raspberrypi Caught by controller[0]:     at JSON.stringify (<anonymous>)
              2019-12-12 17:31:50.493  - error: host.raspberrypi Caught by controller[0]:     at /opt/iobroker/node_modules/iobroker.tr-064-community/main.js:948:62
              2019-12-12 17:31:50.494  - error: host.raspberrypi Caught by controller[0]:     at Timeout.doIt [as _onTimeout] (/opt/iobroker/node_modules/iobroker.tr-064-community/lib/phonebook.js:114:25)
              2019-12-12 17:31:50.494  - error: host.raspberrypi Caught by controller[0]:     at ontimeout (timers.js:436:11)
              2019-12-12 17:31:50.495  - error: host.raspberrypi Caught by controller[0]:     at tryOnTimeout (timers.js:300:5)
              2019-12-12 17:31:50.495  - error: host.raspberrypi Caught by controller[0]:     at listOnTimeout (timers.js:263:5)
              2019-12-12 17:31:50.495  - error: host.raspberrypi Caught by controller[0]:     at Timer.processTimers (timers.js:223:10)
              2019-12-12 17:31:50.496  - info: host.raspberrypi instance system.adapter.tr-064-community.0 terminated with code 0 (NO_ERROR)
              2019-12-12 17:31:50.496  - info: host.raspberrypi Restart adapter system.adapter.tr-064-community.0 because enabled
                @apollon77
                #469
                @conectas sicher das. Du vom GitHub neu drüber installiert hast? Hm ...
                HomoranH conectasC 2 Antworten Letzte Antwort
                  #470
                  @apollon77
                  Vielleicht hilft upload
                    #471
                    Ne ich hab Blödsinn gemacht.
                    Man kann die Zeile
                    Einfach mit // auskommentierrn.
                    Handy lässt mich gerade nicht editieren :-(
                    conectasC 1 Antwort Letzte Antwort
                      conectasC Offline
                      conectasC Offline
                      conectas
                      #472
                      @apollon77
                      Die Version geht jetzt wieder .. komplett neu Installiert.
                      Irgendwie bin ich zu Blöd um hier im Forum zu begreifen, wann hier wo was hingeschrieben wird.
                      (Firefox macht auch irgendwie komische Fenster)
                      .. bekomme ich aber schon irgendwann raus ;-)
                        Man kann die Zeile
                        conectasC Offline
                        conectasC Offline
                        conectas
                        #473
                        @apollon77 sagte in Test Adapter tr-064-community v1.0.x:
                        pollingTimer = setTimeout(updateAll, 2000);
                          #474
                          @conectas na wenn’s wieder tut mit debug dann kommentiert nix aus ;-)
                          Müsste ein Adapter.log.debug
                            conectasC Offline
                            conectasC Offline
                            conectas
                            #475
                            Adapter.log.debug
                            949 //adapter.log.debug('Final Phonebook: ' + JSON.stringify(phonebook));
                            Haste DU bereits raus gemacht ;-)
                              #476
                              Also dann neue logs bitte und Fälle neu checken.
                              conectasC 3 Antworten Letzte Antwort
                                conectasC Offline
                                conectasC Offline
                                conectas
                                #477
                                Fall 01: 2mal hintereinander gleicher OUT (0171) auf IN (628yxz6)
                                jetzt wird nix (selbst) tr-064-community.0.callmonitor.inbound.json nicht neu geschrieben
                                2019-12-12 19:58:38.454  - debug: tr-064-community.0 (15488) callmonitor raw data: "12.12.19 19:58:38;RING;2;0171xyz;628xyz6;SIP0;\r\n"
                                2019-12-12 19:58:38.456  - debug: tr-064-community.0 (15488) callmonitor handle inbound message: {"caller":"0171xyz","callee":"628xyz6"}
                                2019-12-12 19:58:38.457  - debug: tr-064-community.0 (15488) Set State callmonitor.inbound.timestamp: "12.12.19 19:58:38" / ack=true
                                2019-12-12 19:58:38.460  - debug: tr-064-community.0 (15488) Search number 0049171xyz in phonebook: {"name":"NNAme Stefan","normalizedName":"NNAmestefan","number":"0049171yxz","id":"634","phonebookId":"0"}
                                2019-12-12 19:58:38.463  - debug: tr-064-community.0 (15488) Search number 004930628xyz6 in phonebook: {"name":"NNAme Kerstin","normalizedName":"NNAmekerstin","number":"004930628xyz6","id":"631","phonebookId":"0"}
                                2019-12-12 19:58:38.465  - debug: tr-064-community.0 (15488) Set State callmonitor.toPauseState: "ring" / ack=true
                                2019-12-12 19:58:38.467  - debug: tr-064-community.0 (15488) callMonitor.set: type=inbound caller=0171xyz callee=628xyz6 callerName=NNAme Stefan calleeName=NNAme Kerstin
                                2019-12-12 19:58:38.671  - debug: tr-064-community.0 (15488) Set State callmonitor.ringing: true / ack=true
                                2019-12-12 19:58:38.841  - debug: tr-064-community.0 (15488) setting 0 enable=false
                                2019-12-12 19:58:38.843  - debug: tr-064-community.0 (15488) setting 1 enable=false
                                2019-12-12 19:58:38.843  - debug: tr-064-community.0 (15488) setting 2 enable=false
                                2019-12-12 19:58:38.844  - debug: tr-064-community.0 (15488) setting 3 enable=false
                                2019-12-12 19:58:38.844  - debug: tr-064-community.0 (15488) setting 4 enable=false
                                2019-12-12 19:58:38.845  - debug: tr-064-community.0 (15488) setting 5 enable=true
                                2019-12-12 19:58:38.845  - debug: tr-064-community.0 (15488) setting 6 enable=true
                                2019-12-12 19:58:38.846  - debug: tr-064-community.0 (15488) setting 7 enable=true
                                2019-12-12 19:58:38.846  - debug: tr-064-community.0 (15488) setting 8 enable=true
                                2019-12-12 19:58:38.847  - debug: tr-064-community.0 (15488) setting 9 enable=true
                                2019-12-12 19:58:45.625  - debug: tr-064-community.0 (15488) callmonitor raw data: "12.12.19 19:58:45;CONNECT;2;4;0171xyz;\r\n"
                                2019-12-12 19:58:45.627  - debug: tr-064-community.0 (15488) callmonitor handle connect message: {"caller":"0171xyz","callee":"628xyz6","_type":"inbound","callerName":"NNAme Stefan","calleeName":"NNAme Kerstin","extension":"4"}
                                2019-12-12 19:58:45.628  - debug: tr-064-community.0 (15488) Set State callmonitor.connect.timestamp: "12.12.19 19:58:45" / ack=true
                                2019-12-12 19:58:45.629  - debug: tr-064-community.0 (15488) Set State callmonitor.toPauseState: "connect" / ack=true
                                2019-12-12 19:58:45.630  - debug: tr-064-community.0 (15488) Set State callmonitor.toPauseState-4: "connect" / ack=true
                                2019-12-12 19:58:45.631  - debug: tr-064-community.0 (15488) callMonitor.set: type=connect caller=0171xyz callee=628xyz6 callerName=NNAme Stefan calleeName=NNAme Kerstin
                                2019-12-12 19:58:45.833  - debug: tr-064-community.0 (15488) Set State callmonitor.ringing: false / ack=true
                                2019-12-12 19:58:48.464  - debug: tr-064-community.0 (15488) callmonitor raw data: "12.12.19 19:58:48;DISCONNECT;2;3;\r\n"
                                2019-12-12 19:58:48.466  - debug: tr-064-community.0 (15488) callmonitor handle lastCall message: {"caller":"0171xyz","callee":"628xyz6","_type":"connect","callerName":"NNAme Stefan","calleeName":"NNAme Kerstin","extension":"4","type":"disconnect","duration":3}
                                2019-12-12 19:58:48.468  - debug: tr-064-community.0 (15488) Set State callmonitor.lastCall.type: "disconnect" / ack=true
                                2019-12-12 19:58:48.470  - debug: tr-064-community.0 (15488) Set State callmonitor.lastCall.duration: 3 / ack=true
                                2019-12-12 19:58:48.472  - debug: tr-064-community.0 (15488) Set State callmonitor.lastCall.timestamp: "12.12.19 19:58:48" / ack=true
                                2019-12-12 19:58:48.474  - debug: tr-064-community.0 (15488) Set State callmonitor.lastCall.json: "{\"caller\":\"0171xyz\",\"callee\":\"628xyz6\",\"_type\":\"lastCall\",\"callerName\":\"NNAme Stefan\",\"calleeName\":\"NNAme Kerstin\",\"extension\":\"4\",\"type\":\"disconnect\",\"duration\":3}" / ack=true
                                2019-12-12 19:58:48.476  - debug: tr-064-community.0 (15488) Set State callmonitor.toPauseState: "end" / ack=true
                                2019-12-12 19:58:48.478  - debug: tr-064-community.0 (15488) Set State callmonitor.toPauseState-4: "end" / ack=true
                                2019-12-12 19:58:48.479  - debug: tr-064-community.0 (15488) callMonitor.set: type=lastCall caller=0171xyz callee=628xyz6 callerName=NNAme Stefan calleeName=NNAme Kerstin
                                2019-12-12 19:58:48.851  - debug: tr-064-community.0 (15488) in updateAll
                                2019-12-12 19:58:48.853  - debug: tr-064-community.0 (15488) updateDevices
                                2019-12-12 19:58:48.854  - debug: tr-064-community.0 (15488) forEachConfiguredDevice
                                2019-12-12 19:58:51.289  - debug: tr-064-community.0 (15488) setting 0 enable=false
                                2019-12-12 19:58:51.290  - debug: tr-064-community.0 (15488) setting 1 enable=false
                                2019-12-12 19:58:51.291  - debug: tr-064-community.0 (15488) setting 2 enable=false
                                2019-12-12 19:58:51.291  - debug: tr-064-community.0 (15488) setting 3 enable=false
                                2019-12-12 19:58:51.292  - debug: tr-064-community.0 (15488) setting 4 enable=false
                                2019-12-12 19:58:51.292  - debug: tr-064-community.0 (15488) setting 5 enable=true
                                2019-12-12 19:58:51.292  - debug: tr-064-community.0 (15488) setting 6 enable=true
                                2019-12-12 19:58:51.293  - debug: tr-064-community.0 (15488) setting 7 enable=true
                                2019-12-12 19:58:51.293  - debug: tr-064-community.0 (15488) setting 8 enable=true
                                2019-12-12 19:58:51.295  - debug: tr-064-community.0 (15488) setting 9 enable=true
                                  conectasC Offline
                                  conectasC Offline
                                  conectas
                                  #478
                                  Fall2:
                                  abwechselt:
                                  OUT 0171 zu 628xy6
                                  danach
                                  OUT 0171 zu 628xy7
                                  tr-064-community.0.callmonitor.inbound.caller
                                  tr-064-community.0.callmonitor.inbound.callerName
                                  werden nicht aktualisiert...
                                  2019-12-12 20:07:10.493  - debug: tr-064-community.0 (15488) in updateAll
                                  2019-12-12 20:07:10.495  - debug: tr-064-community.0 (15488) updateDevices
                                  2019-12-12 20:07:10.496  - debug: tr-064-community.0 (15488) forEachConfiguredDevice
                                  2019-12-12 20:07:12.959  - debug: tr-064-community.0 (15488) callmonitor raw data: "12.12.19 20:07:12;RING;2;0171xyz;628yxz6;SIP0;\r\n"
                                  2019-12-12 20:07:12.960  - debug: tr-064-community.0 (15488) callmonitor handle inbound message: {"caller":"0171xyz","callee":"628yxz6"}
                                  2019-12-12 20:07:12.961  - debug: tr-064-community.0 (15488) Set State callmonitor.inbound.callee: "628yxz6" / ack=true
                                  2019-12-12 20:07:12.962  - debug: tr-064-community.0 (15488) Set State callmonitor.inbound.timestamp: "12.12.19 20:07:12" / ack=true
                                  2019-12-12 20:07:12.963  - debug: tr-064-community.0 (15488) Search number 0049171xyz in phonebook: {"name":"NName Stefan","normalizedName":"NNamestefan","number":"0049171xyz","id":"634","phonebookId":"0"}
                                  2019-12-12 20:07:12.964  - debug: tr-064-community.0 (15488) Search number 004930628yxz6 in phonebook: {"name":"NName Kerstin","normalizedName":"NNamekerstin","number":"004930628yxz6","id":"631","phonebookId":"0"}
                                  2019-12-12 20:07:12.964  - debug: tr-064-community.0 (15488) Set State callmonitor.inbound.calleeName: "NName Kerstin" / ack=true
                                  2019-12-12 20:07:12.965  - debug: tr-064-community.0 (15488) Set State callmonitor.inbound.json: "{\"caller\":\"0171xyz\",\"callee\":\"628yxz6\",\"_type\":\"inbound\",\"callerName\":\"NName Stefan\",\"calleeName\":\"NName Kerstin\"}" / ack=true
                                  2019-12-12 20:07:12.966  - debug: tr-064-community.0 (15488) Set State callmonitor.toPauseState: "ring" / ack=true
                                  2019-12-12 20:07:12.967  - debug: tr-064-community.0 (15488) callMonitor.set: type=inbound caller=0171xyz callee=628yxz6 callerName=NName Stefan calleeName=NName Kerstin
                                  2019-12-12 20:07:13.168  - debug: tr-064-community.0 (15488) Set State callmonitor.ringing: true / ack=true
                                  2019-12-12 20:07:13.225  - debug: tr-064-community.0 (15488) setting 0 enable=false
                                  2019-12-12 20:07:13.226  - debug: tr-064-community.0 (15488) setting 1 enable=false
                                  2019-12-12 20:07:13.227  - debug: tr-064-community.0 (15488) setting 2 enable=false
                                  2019-12-12 20:07:13.228  - debug: tr-064-community.0 (15488) setting 3 enable=false
                                  2019-12-12 20:07:13.229  - debug: tr-064-community.0 (15488) setting 4 enable=false
                                  2019-12-12 20:07:13.229  - debug: tr-064-community.0 (15488) setting 5 enable=true
                                  2019-12-12 20:07:13.230  - debug: tr-064-community.0 (15488) setting 6 enable=true
                                  2019-12-12 20:07:13.230  - debug: tr-064-community.0 (15488) setting 7 enable=true
                                  2019-12-12 20:07:13.231  - debug: tr-064-community.0 (15488) setting 8 enable=true
                                  2019-12-12 20:07:13.231  - debug: tr-064-community.0 (15488) setting 9 enable=true
                                  2019-12-12 20:07:19.126  - debug: tr-064-community.0 (15488) callmonitor raw data: "12.12.19 20:07:19;CONNECT;2;4;0171xyz;\r\n"
                                  2019-12-12 20:07:19.127  - debug: tr-064-community.0 (15488) callmonitor handle connect message: {"caller":"0171xyz","callee":"628yxz6","_type":"inbound","callerName":"NName Stefan","calleeName":"NName Kerstin","extension":"4"}
                                  2019-12-12 20:07:19.128  - debug: tr-064-community.0 (15488) Set State callmonitor.connect.callee: "628yxz6" / ack=true
                                  2019-12-12 20:07:19.129  - debug: tr-064-community.0 (15488) Set State callmonitor.connect.calleeName: "NName Kerstin" / ack=true
                                  2019-12-12 20:07:19.130  - debug: tr-064-community.0 (15488) Set State callmonitor.connect.timestamp: "12.12.19 20:07:19" / ack=true
                                  2019-12-12 20:07:19.131  - debug: tr-064-community.0 (15488) Set State callmonitor.connect.json: "{\"caller\":\"0171xyz\",\"callee\":\"628yxz6\",\"_type\":\"connect\",\"callerName\":\"NName Stefan\",\"calleeName\":\"NName Kerstin\",\"extension\":\"4\"}" / ack=true
                                  2019-12-12 20:07:19.135  - debug: tr-064-community.0 (15488) Set State callmonitor.toPauseState: "connect" / ack=true
                                  2019-12-12 20:07:19.136  - debug: tr-064-community.0 (15488) Set State callmonitor.toPauseState-4: "connect" / ack=true
                                  2019-12-12 20:07:19.137  - debug: tr-064-community.0 (15488) callMonitor.set: type=connect caller=0171xyz callee=628yxz6 callerName=NName Stefan calleeName=NName Kerstin
                                  2019-12-12 20:07:19.339  - debug: tr-064-community.0 (15488) Set State callmonitor.ringing: false / ack=true
                                  2019-12-12 20:07:20.343  - debug: tr-064-community.0 (15488) callmonitor raw data: "12.12.19 20:07:20;DISCONNECT;2;2;\r\n"
                                  2019-12-12 20:07:20.344  - debug: tr-064-community.0 (15488) callmonitor handle lastCall message: {"caller":"0171xyz","callee":"628yxz6","_type":"connect","callerName":"NName Stefan","calleeName":"NName Kerstin","extension":"4","type":"disconnect","duration":2}
                                  2019-12-12 20:07:20.345  - debug: tr-064-community.0 (15488) Set State callmonitor.lastCall.callee: "628yxz6" / ack=true
                                  2019-12-12 20:07:20.346  - debug: tr-064-community.0 (15488) Set State callmonitor.lastCall.calleeName: "NName Kerstin" / ack=true
                                  2019-12-12 20:07:20.347  - debug: tr-064-community.0 (15488) Set State callmonitor.lastCall.duration: 2 / ack=true
                                  2019-12-12 20:07:20.348  - debug: tr-064-community.0 (15488) Set State callmonitor.lastCall.timestamp: "12.12.19 20:07:20" / ack=true
                                  2019-12-12 20:07:20.350  - debug: tr-064-community.0 (15488) Set State callmonitor.lastCall.json: "{\"caller\":\"0171xyz\",\"callee\":\"628yxz6\",\"_type\":\"lastCall\",\"callerName\":\"NName Stefan\",\"calleeName\":\"NName Kerstin\",\"extension\":\"4\",\"type\":\"disconnect\",\"duration\":2}" / ack=true
                                  2019-12-12 20:07:20.351  - debug: tr-064-community.0 (15488) Set State callmonitor.toPauseState: "end" / ack=true
                                  2019-12-12 20:07:20.352  - debug: tr-064-community.0 (15488) Set State callmonitor.toPauseState-4: "end" / ack=true
                                  2019-12-12 20:07:20.353  - debug: tr-064-community.0 (15488) callMonitor.set: type=lastCall caller=0171xyz callee=628yxz6 callerName=NName Stefan calleeName=NName Kerstin
                                  2019-12-12 20:07:23.232  - debug: tr-064-community.0 (15488) in updateAll
                                  2019-12-12 20:07:23.234  - debug: tr-064-community.0 (15488) updateDevices
                                  2019-12-12 20:07:23.235  - debug: tr-064-community.0 (15488) forEachConfiguredDevice
                                    conectasC Offline
                                    conectasC Offline
                                    conectas
                                    #479
                                    Ich würde bei Tests dieses Script mitlaufen lassen.. oder bringt das in deinen Logs dann zu viel durcheinander?
                                    let tr064 = "tr-064-community.0.callmonitor.";
                                    var callerNumber    // Anrufernummer
                                    var callerName      // Name des Anrufers
                                    var calleeNumber    // angerufene Nummer
                                    var calleeName      // angerufener Name
                                    var callAllDataJson = { "caller": "caller Nr", "callee": "callee Nr", "_type": "_type inbound", "callerName": "Caller Name", "calleeName": "Callee Name" };
                                    on({ id: "tr-064-community.0.callmonitor.toPauseState", change: "any" }, function (obj) {
                                        console.log('---> Ringing?: ');
                                        let sToPauseState = getState(tr064 + "toPauseState").val;
                                        if ("ring" == sToPauseState) {
                                            callerNumber = getState(tr064 + "inbound.caller").val;          // Anrufernummer
                                            callerName = getState(tr064 + "inbound.callerName").val;        // Name des Anrufers
                                            calleeNumber = getState(tr064 + "inbound.callee").val;          // angerufene Nummer
                                            calleeName = getState(tr064 + "inbound.calleeName").val;        // angerufener Name
                                            callAllDataJson = getState(tr064 + "inbound.json").val;          // json
                                            console.log('---> Ringing? - callerNumber: ' + callerNumber);
                                            console.log('---> Ringing? - callerName: ' + callerName);
                                            console.log('---> Ringing? - calleeNumber: ' + calleeNumber);
                                            console.log('---> Ringing? - calleeName: ' + calleeName);
                                            console.log('---> Ringing? - callAllDataJson: ' + String(callAllDataJson));
                                        } else if ("end" == sToPauseState) {
                                            setState(tr064 + "inbound.caller", '');
                                            setState(tr064 + "inbound.callerName", '');
                                            setState(tr064 + "inbound.callee", '');
                                            setState(tr064 + "inbound.calleeName", '');
                                            setState(tr064 + "inbound.json", '');
                                      #480
                                      Oooook ... ich hab mal erste DInge verändert. Bitte nochmal neu versuchen vom GitHub, bitte checkt aber auch ob der ganze Rest (also auch IP.Devices und so) noch so tut wie es soll.
                                      Und bitte extra Skripte weglassen. Danke
                                        conectasC Offline
                                        conectasC Offline
                                        conectas
                                        #481
                                        Knallt...
                                        2019-12-12 21:24:14.636  - info: host.raspberrypi "system.adapter.tr-064-community.0" enabled
                                        2019-12-12 21:24:14.666  - info: host.raspberrypi instance system.adapter.tr-064-community.0 started with pid 18626
                                        2019-12-12 21:24:17.602  - debug: tr-064-community.0 (18626) Redis Objects: Use Redis connection: 127.0.0.1:9001
                                        2019-12-12 21:24:17.671  - debug: tr-064-community.0 (18626) Objects client ready ... initialize now
                                        2019-12-12 21:24:17.680  - debug: tr-064-community.0 (18626) Objects create PubSub Client
                                        2019-12-12 21:24:17.683  - debug: tr-064-community.0 (18626) Objects client initialize lua scripts
                                        2019-12-12 21:24:17.712  - debug: tr-064-community.0 (18626) objectDB connected
                                        2019-12-12 21:24:17.718  - debug: tr-064-community.0 (18626) Redis States: Use Redis connection: 127.0.0.1:9000
                                        2019-12-12 21:24:17.725  - debug: tr-064-community.0 (18626) Objects connected to redis: 127.0.0.1:9001
                                        2019-12-12 21:24:17.735  - debug: tr-064-community.0 (18626) States create PubSub Client
                                        2019-12-12 21:24:17.738  - debug: tr-064-community.0 (18626) statesDB connected
                                        2019-12-12 21:24:17.805  - debug: tr-064-community.0 (18626) States connected to redis: 127.0.0.1:9000
                                        2019-12-12 21:24:18.366  - info: tr-064-community.0 (18626) starting. Version 1.2.0 in /opt/iobroker/node_modules/iobroker.tr-064-community, node: v10.17.0
                                        2019-12-12 21:24:21.236  - error: tr-064-community.0 (18626) uncaught exception: st is not defined
                                        2019-12-12 21:24:21.241  - error: tr-064-community.0 (18626) ReferenceError: st is not defined
                                            at createObjects (/opt/iobroker/node_modules/iobroker.tr-064-community/main.js:102:59)
                                            at /opt/iobroker/node_modules/iobroker.tr-064-community/main.js:940:9
                                            at /opt/iobroker/node_modules/iobroker.tr-064-community/lib/soef.js:1610:28
                                            at /opt/iobroker/node_modules/tr-O64/lib/Service.js:267:17
                                            at Parser.<anonymous> (/opt/iobroker/node_modules/xml2js/lib/parser.js:306:18)
                                            at Parser.emit (events.js:198:13)
                                            at SAXParser.onclosetag (/opt/iobroker/node_modules/xml2js/lib/parser.js:264:26)
                                            at emit (/opt/iobroker/node_modules/sax/lib/sax.js:624:35)
                                            at emitNode (/opt/iobroker/node_modules/sax/lib/sax.js:629:5)
                                            at closeTag (/opt/iobroker/node_modules/sax/lib/sax.js:889:7)
                                        2019-12-12 21:24:21.300  - info: tr-064-community.0 (18626) terminating
                                        2019-12-12 21:24:21.303  - info: tr-064-community.0 (18626) Terminated (NO_ERROR): Without reason
                                        2019-12-12 21:24:21.861  - error: host.raspberrypi Caught by controller[0]: ReferenceError: st is not defined
                                        2019-12-12 21:24:21.864  - error: host.raspberrypi Caught by controller[0]:     at createObjects (/opt/iobroker/node_modules/iobroker.tr-064-community/main.js:102:59)
                                        2019-12-12 21:24:21.865  - error: host.raspberrypi Caught by controller[0]:     at /opt/iobroker/node_modules/iobroker.tr-064-community/main.js:940:9
                                        2019-12-12 21:24:21.866  - error: host.raspberrypi Caught by controller[0]:     at /opt/iobroker/node_modules/iobroker.tr-064-community/lib/soef.js:1610:28
                                        2019-12-12 21:24:21.866  - error: host.raspberrypi Caught by controller[0]:     at /opt/iobroker/node_modules/tr-O64/lib/Service.js:267:17
                                        2019-12-12 21:24:21.867  - error: host.raspberrypi Caught by controller[0]:     at Parser.<anonymous> (/opt/iobroker/node_modules/xml2js/lib/parser.js:306:18)
                                        2019-12-12 21:24:21.867  - error: host.raspberrypi Caught by controller[0]:     at Parser.emit (events.js:198:13)
                                        2019-12-12 21:24:21.868  - error: host.raspberrypi Caught by controller[0]:     at SAXParser.onclosetag (/opt/iobroker/node_modules/xml2js/lib/parser.js:264:26)
                                        2019-12-12 21:24:21.868  - error: host.raspberrypi Caught by controller[0]:     at emit (/opt/iobroker/node_modules/sax/lib/sax.js:624:35)
                                        2019-12-12 21:24:21.869  - error: host.raspberrypi Caught by controller[0]:     at emitNode (/opt/iobroker/node_modules/sax/lib/sax.js:629:5)
                                        2019-12-12 21:24:21.869  - error: host.raspberrypi Caught by controller[0]:     at closeTag (/opt/iobroker/node_modules/sax/lib/sax.js:889:7)
                                        2019-12-12 21:24:21.870  - info: host.raspberrypi instance system.adapter.tr-064-community.0 terminated with code 0 (NO_ERROR)
                                        2019-12-12 21:24:21.870  - info: host.raspberrypi Restart adapter system.adapter.tr-064-community.0 because enabled
                                          #482
                                          gggrrrr ... fixed on GitHub. Sorry
