  4. Test Adapter tr-064-community v1.0.x
    6.0k
tr-064community
727 Beiträge 88 Kommentatoren 243.7k Aufrufe 66 Beobachtet
  • apollon77A apollon77
    Ok, ich habe eine Code-Stelle gefunden wo glaube ich die Werte falsch geschrieben wurden ... versuch mal neu GitHub.
    PS: Einwas noch: States werden nur geschrieben wenn 200ms keine Änderungen waren ...
    conectasC Offline
    conectasC Offline
    conectas
    schrieb am zuletzt editiert von conectas
    #464
    @apollon77
    Dauert noch ne Sek. .. Knallt bei Install
    host.raspberrypi	2019-12-12 17:12:15.366	error	Caught by controller[0]: at Timer.processTimers (timers.js:223:10)
    host.raspberrypi	2019-12-12 17:12:15.365	error	Caught by controller[0]: at listOnTimeout (timers.js:263:5)
    host.raspberrypi	2019-12-12 17:12:15.365	error	Caught by controller[0]: at tryOnTimeout (timers.js:300:5)
    host.raspberrypi	2019-12-12 17:12:15.365	error	Caught by controller[0]: at ontimeout (timers.js:436:11)
    host.raspberrypi	2019-12-12 17:12:15.364	error	Caught by controller[0]: at Timeout.doIt [as _onTimeout] (/opt/iobroker/node_modules/iobroker.tr-064-community/lib/phonebook.js:114:25)
    host.raspberrypi	2019-12-12 17:12:15.364	error	Caught by controller[0]: at /opt/iobroker/node_modules/iobroker.tr-064-community/main.js:948:62
    host.raspberrypi	2019-12-12 17:12:15.363	error	Caught by controller[0]: at JSON.stringify (<anonymous>)
    host.raspberrypi	2019-12-12 17:12:15.361	error	Caught by controller[0]: TypeError: Converting circular structure to JSON
    tr-064-community.0	2019-12-12 17:12:14.811	info	(27839) Terminated (NO_ERROR): Without reason
    tr-064-community.0	2019-12-12 17:12:14.806	info	(27839) terminating
    tr-064-community.0	2019-12-12 17:12:14.711	error	(27839) TypeError: Converting circular structure to JSON at JSON.stringify (<anonymous>) at /opt/iobroker/node_modules/iobroker.tr-064-community/main.js:948:62 at Timeout.doIt [as _onTimeo
    tr-064-community.0	2019-12-12 17:12:14.708	error	(27839) uncaught exception: Converting circular structure to JSON
    conectasC apollon77A 2 Antworten Letzte Antwort
    • conectasC conectas
      @apollon77
      conectasC Offline
      conectasC Offline
      conectas
      #465
      @conectas
      Ich starte mal die Fritze neu...
      2019-12-12 17:17:28.384  - info: host.raspberrypi Update repository "latest" under "http://download.iobroker.net/sources-dist-latest.json"
      2019-12-12 17:18:06.065  - info: host.raspberrypi iobroker add tr-064-community  --host raspberrypi
      2019-12-12 17:18:09.756  - info: host.raspberrypi iobroker host.raspberrypi create instance tr-064-community
      2019-12-12 17:18:09.782  - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.tr-064-community.0.sigKill created
      2019-12-12 17:18:09.827  - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.tr-064-community.0.eventLoopLag created
      2019-12-12 17:18:09.872  - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.tr-064-community.0.outputCount created
      2019-12-12 17:18:09.912  - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.tr-064-community.0.inputCount created
      2019-12-12 17:18:09.974  - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.tr-064-community.0.uptime created
      2019-12-12 17:18:10.016  - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.tr-064-community.0.memRss created
      2019-12-12 17:18:10.057  - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.tr-064-community.0.memHeapTotal created
      2019-12-12 17:18:10.104  - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.tr-064-community.0.memHeapUsed created
      2019-12-12 17:18:10.150  - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.tr-064-community.0.cputime created
      2019-12-12 17:18:10.187  - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.tr-064-community.0.cpu created
      2019-12-12 17:18:10.223  - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.tr-064-community.0.compactMode created
      2019-12-12 17:18:10.261  - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.tr-064-community.0.connected created
      2019-12-12 17:18:10.298  - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.tr-064-community.0.alive created
      2019-12-12 17:18:10.349  - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.tr-064-community.0 created
      2019-12-12 17:18:11.378  - info: host.raspberrypi iobroker exit 0
      2019-12-12 17:18:12.875  - info: host.raspberrypi instance system.adapter.tr-064-community.0 started with pid 6951
      2019-12-12 17:18:17.706  - info: tr-064-community.0 (6951) starting. Version 1.2.0 in /opt/iobroker/node_modules/iobroker.tr-064-community, node: v10.17.0
      2019-12-12 17:18:19.870  - error: tr-064-community.0 (6951) Error: sendSOAPActionRequest Error action=GetInfo serviceType=urn:dslforum-org:service:WLANConfiguration:1: 401 - {"code":401}
      2019-12-12 17:18:19.872  - error: tr-064-community.0 (6951) ~
      2019-12-12 17:18:19.873  - error: tr-064-community.0 (6951) ~~ Fatal error. Can not connect to your FritzBox.
      2019-12-12 17:18:19.875  - error: tr-064-community.0 (6951) ~~ If configuration, networt, IP address, etc. ok, try to restart your FritzBox
      2019-12-12 17:18:19.876  - error: tr-064-community.0 (6951) ~
      2019-12-12 17:18:24.922  - error: host.raspberrypi instance system.adapter.tr-064-community.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      2019-12-12 17:18:24.923  - info: host.raspberrypi Restart adapter system.adapter.tr-064-community.0 because enabled
      tail: iobroker.2019-12-12.log: Datei abgeschnitten
      undefined2019-12-12 17:18:54.955  - info: host.raspberrypi instance system.adapter.tr-064-community.0 started with pid 8222
      2019-12-12 17:18:59.215  - info: tr-064-community.0 (8222) starting. Version 1.2.0 in /opt/iobroker/node_modules/iobroker.tr-064-community, node: v10.17.0
      2019-12-12 17:19:01.042  - error: tr-064-community.0 (8222) Error: sendSOAPActionRequest Error action=GetInfo serviceType=urn:dslforum-org:service:WLANConfiguration:1: 401 - {"code":401}
      2019-12-12 17:19:01.044  - error: tr-064-community.0 (8222) ~
      2019-12-12 17:19:01.045  - error: tr-064-community.0 (8222) ~~ Fatal error. Can not connect to your FritzBox.
      2019-12-12 17:19:01.046  - error: tr-064-community.0 (8222) ~~ If configuration, networt, IP address, etc. ok, try to restart your FritzBox
      2019-12-12 17:19:04.035  - info: host.raspberrypi stopInstance system.adapter.tr-064-community.0 (force=false, process=true)
      2019-12-12 17:19:04.039  - info: host.raspberrypi stopInstance system.adapter.tr-064-community.0 send kill signal
      2019-12-12 17:19:04.046  - info: tr-064-community.0 (8222) Got terminate signal TERMINATE_YOURSELF
      2019-12-12 17:19:04.050  - info: tr-064-community.0 (8222) terminating
      2019-12-12 17:19:04.052  - info: tr-064-community.0 (8222) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
      2019-12-12 17:19:04.597  - info: host.raspberrypi instance system.adapter.tr-064-community.0 terminated with code 156 (156)
      2019-12-12 17:19:06.602  - info: host.raspberrypi instance system.adapter.tr-064-community.0 started with pid 8513
      2019-12-12 17:19:10.630  - info: tr-064-community.0 (8513) starting. Version 1.2.0 in /opt/iobroker/node_modules/iobroker.tr-064-community, node: v10.17.0
      2019-12-12 17:19:15.996  - error: tr-064-community.0 (8513) uncaught exception: Converting circular structure to JSON
      2019-12-12 17:19:15.999  - error: tr-064-community.0 (8513) TypeError: Converting circular structure to JSON
      2019-12-12 17:19:16.010  - info: tr-064-community.0 (8513) terminating
      2019-12-12 17:19:16.014  - info: tr-064-community.0 (8513) Terminated (NO_ERROR): Without reason
      2019-12-12 17:19:16.565  - error: host.raspberrypi Caught by controller[0]: TypeError: Converting circular structure to JSON
      2019-12-12 17:19:16.567  - error: host.raspberrypi Caught by controller[0]:     at JSON.stringify (<anonymous>)
      2019-12-12 17:19:16.568  - error: host.raspberrypi Caught by controller[0]:     at /opt/iobroker/node_modules/iobroker.tr-064-community/main.js:948:62
      2019-12-12 17:19:16.568  - error: host.raspberrypi Caught by controller[0]:     at Timeout.doIt [as _onTimeout] (/opt/iobroker/node_modules/iobroker.tr-064-community/lib/phonebook.js:114:25)
      2019-12-12 17:19:16.569  - error: host.raspberrypi Caught by controller[0]:     at ontimeout (timers.js:436:11)
      2019-12-12 17:19:16.569  - error: host.raspberrypi Caught by controller[0]:     at tryOnTimeout (timers.js:300:5)
      2019-12-12 17:19:16.570  - error: host.raspberrypi Caught by controller[0]:     at listOnTimeout (timers.js:263:5)
      2019-12-12 17:19:16.570  - error: host.raspberrypi Caught by controller[0]:     at Timer.processTimers (timers.js:223:10)
      2019-12-12 17:19:16.571  - info: host.raspberrypi instance system.adapter.tr-064-community.0 terminated with code 0 (NO_ERROR)
      2019-12-12 17:19:16.571  - info: host.raspberrypi Restart adapter system.adapter.tr-064-community.0 because enabled
      2019-12-12 17:19:46.163  - info: host.raspberrypi "system.adapter.tr-064-community.0" disabled
      2019-12-12 17:19:50.354  - error: tr-064-community.0 (9678) adapter disabled
      2019-12-12 17:19:50.378  - warn: tr-064-community.0 (9678) Terminated (NO_ADAPTER_CONFIG_FOUND): Without reason
      2019-12-12 17:19:51.008  - error: host.raspberrypi instance system.adapter.tr-064-community.0 terminated with code 3 (NO_ADAPTER_CONFIG_FOUND)
      2019-12-12 17:19:51.010  - info: host.raspberrypi Do not restart adapter system.adapter.tr-064-community.0 because disabled or deleted
      2019-12-12 17:20:01.788  - info: host.raspberrypi "system.adapter.tr-064-community.0" enabled
      2019-12-12 17:20:01.827  - info: host.raspberrypi instance system.adapter.tr-064-community.0 started with pid 10215
      2019-12-12 17:20:05.857  - info: tr-064-community.0 (10215) starting. Version 1.2.0 in /opt/iobroker/node_modules/iobroker.tr-064-community, node: v10.17.0
      2019-12-12 17:20:10.848  - error: tr-064-community.0 (10215) uncaught exception: Converting circular structure to JSON
      2019-12-12 17:20:10.851  - error: tr-064-community.0 (10215) TypeError: Converting circular structure to JSON
      2019-12-12 17:20:10.871  - info: tr-064-community.0 (10215) terminating
      2019-12-12 17:20:10.875  - info: tr-064-community.0 (10215) Terminated (NO_ERROR): Without reason
      2019-12-12 17:20:11.414  - error: host.raspberrypi Caught by controller[0]: TypeError: Converting circular structure to JSON
      2019-12-12 17:20:11.415  - error: host.raspberrypi Caught by controller[0]:     at JSON.stringify (<anonymous>)
      2019-12-12 17:20:11.416  - error: host.raspberrypi Caught by controller[0]:     at /opt/iobroker/node_modules/iobroker.tr-064-community/main.js:948:62
      2019-12-12 17:20:11.417  - error: host.raspberrypi Caught by controller[0]:     at Timeout.doIt [as _onTimeout] (/opt/iobroker/node_modules/iobroker.tr-064-community/lib/phonebook.js:114:25)
      2019-12-12 17:20:11.417  - error: host.raspberrypi Caught by controller[0]:     at ontimeout (timers.js:436:11)
      2019-12-12 17:20:11.418  - error: host.raspberrypi Caught by controller[0]:     at tryOnTimeout (timers.js:300:5)
      2019-12-12 17:20:11.419  - error: host.raspberrypi Caught by controller[0]:     at listOnTimeout (timers.js:263:5)
      2019-12-12 17:20:11.419  - error: host.raspberrypi Caught by controller[0]:     at Timer.processTimers (timers.js:223:10)
      2019-12-12 17:20:11.420  - info: host.raspberrypi instance system.adapter.tr-064-community.0 terminated with code 0 (NO_ERROR)
      2019-12-12 17:20:11.420  - info: host.raspberrypi Restart adapter system.adapter.tr-064-community.0 because enabled
      2019-12-12 17:20:41.447  - info: host.raspberrypi instance system.adapter.tr-064-community.0 started with pid 11383
      2019-12-12 17:20:45.398  - info: tr-064-community.0 (11383) starting. Version 1.2.0 in /opt/iobroker/node_modules/iobroker.tr-064-community, node: v10.17.0
      2019-12-12 17:20:50.666  - error: tr-064-community.0 (11383) uncaught exception: Converting circular structure to JSON
      2019-12-12 17:20:50.669  - error: tr-064-community.0 (11383) TypeError: Converting circular structure to JSON
      2019-12-12 17:20:50.688  - info: tr-064-community.0 (11383) terminating
      2019-12-12 17:20:50.692  - info: tr-064-community.0 (11383) Terminated (NO_ERROR): Without reason
      2019-12-12 17:20:51.245  - error: host.raspberrypi Caught by controller[0]: TypeError: Converting circular structure to JSON
      2019-12-12 17:20:51.247  - error: host.raspberrypi Caught by controller[0]:     at JSON.stringify (<anonymous>)
      2019-12-12 17:20:51.248  - error: host.raspberrypi Caught by controller[0]:     at /opt/iobroker/node_modules/iobroker.tr-064-community/main.js:948:62
      2019-12-12 17:20:51.248  - error: host.raspberrypi Caught by controller[0]:     at Timeout.doIt [as _onTimeout] (/opt/iobroker/node_modules/iobroker.tr-064-community/lib/phonebook.js:114:25)
      2019-12-12 17:20:51.249  - error: host.raspberrypi Caught by controller[0]:     at ontimeout (timers.js:436:11)
      2019-12-12 17:20:51.249  - error: host.raspberrypi Caught by controller[0]:     at tryOnTimeout (timers.js:300:5)
      2019-12-12 17:20:51.249  - error: host.raspberrypi Caught by controller[0]:     at listOnTimeout (timers.js:263:5)
      2019-12-12 17:20:51.250  - error: host.raspberrypi Caught by controller[0]:     at Timer.processTimers (timers.js:223:10)
      2019-12-12 17:20:51.250  - info: host.raspberrypi instance system.adapter.tr-064-community.0 terminated with code 0 (NO_ERROR)
      2019-12-12 17:20:51.250  - info: host.raspberrypi Restart adapter system.adapter.tr-064-community.0 because enabled
        @apollon77
        #466
        @conectas mist ... mach Debug aus ... muss logging ändern - heute Abend dann
        • apollon77A Offline
          #467
          Ok, bitte neu von GitHub und neu Starten ... sollte gefixt sein
            conectasC Offline
            conectasC Offline
            conectas
            #468
            @apollon77
            Knallt beim Start.. Änderungen waren nicht .. ;-)
            2019-12-12 17:31:01.655  - info: host.raspberrypi "system.adapter.tr-064-community.0" enabled
            2019-12-12 17:31:01.687  - info: host.raspberrypi instance system.adapter.tr-064-community.0 started with pid 6419
            2019-12-12 17:31:05.579  - info: tr-064-community.0 (6419) starting. Version 1.2.0 in /opt/iobroker/node_modules/iobroker.tr-064-community, node: v10.17.0
            2019-12-12 17:31:10.633  - error: tr-064-community.0 (6419) uncaught exception: Converting circular structure to JSON
            2019-12-12 17:31:10.636  - error: tr-064-community.0 (6419) TypeError: Converting circular structure to JSON
            2019-12-12 17:31:10.650  - info: tr-064-community.0 (6419) terminating
            2019-12-12 17:31:10.653  - info: tr-064-community.0 (6419) Terminated (NO_ERROR): Without reason
            2019-12-12 17:31:11.209  - error: host.raspberrypi Caught by controller[0]: TypeError: Converting circular structure to JSON
            2019-12-12 17:31:11.213  - error: host.raspberrypi Caught by controller[0]:     at JSON.stringify (<anonymous>)
            2019-12-12 17:31:11.214  - error: host.raspberrypi Caught by controller[0]:     at /opt/iobroker/node_modules/iobroker.tr-064-community/main.js:948:62
            2019-12-12 17:31:11.215  - error: host.raspberrypi Caught by controller[0]:     at Timeout.doIt [as _onTimeout] (/opt/iobroker/node_modules/iobroker.tr-064-community/lib/phonebook.js:114:25)
            2019-12-12 17:31:11.216  - error: host.raspberrypi Caught by controller[0]:     at ontimeout (timers.js:436:11)
            2019-12-12 17:31:11.217  - error: host.raspberrypi Caught by controller[0]:     at tryOnTimeout (timers.js:300:5)
            2019-12-12 17:31:11.218  - error: host.raspberrypi Caught by controller[0]:     at listOnTimeout (timers.js:263:5)
            2019-12-12 17:31:11.219  - error: host.raspberrypi Caught by controller[0]:     at Timer.processTimers (timers.js:223:10)
            2019-12-12 17:31:11.221  - info: host.raspberrypi instance system.adapter.tr-064-community.0 terminated with code 0 (NO_ERROR)
            2019-12-12 17:31:11.222  - info: host.raspberrypi Restart adapter system.adapter.tr-064-community.0 because enabled
            2019-12-12 17:31:41.251  - info: host.raspberrypi instance system.adapter.tr-064-community.0 started with pid 7583
            2019-12-12 17:31:44.853  - info: tr-064-community.0 (7583) starting. Version 1.2.0 in /opt/iobroker/node_modules/iobroker.tr-064-community, node: v10.17.0
            2019-12-12 17:31:49.924  - error: tr-064-community.0 (7583) uncaught exception: Converting circular structure to JSON
            2019-12-12 17:31:49.927  - error: tr-064-community.0 (7583) TypeError: Converting circular structure to JSON
            2019-12-12 17:31:49.940  - info: tr-064-community.0 (7583) terminating
            2019-12-12 17:31:49.943  - info: tr-064-community.0 (7583) Terminated (NO_ERROR): Without reason
            2019-12-12 17:31:50.490  - error: host.raspberrypi Caught by controller[0]: TypeError: Converting circular structure to JSON
            2019-12-12 17:31:50.492  - error: host.raspberrypi Caught by controller[0]:     at JSON.stringify (<anonymous>)
            2019-12-12 17:31:50.493  - error: host.raspberrypi Caught by controller[0]:     at /opt/iobroker/node_modules/iobroker.tr-064-community/main.js:948:62
            2019-12-12 17:31:50.494  - error: host.raspberrypi Caught by controller[0]:     at Timeout.doIt [as _onTimeout] (/opt/iobroker/node_modules/iobroker.tr-064-community/lib/phonebook.js:114:25)
            2019-12-12 17:31:50.494  - error: host.raspberrypi Caught by controller[0]:     at ontimeout (timers.js:436:11)
            2019-12-12 17:31:50.495  - error: host.raspberrypi Caught by controller[0]:     at tryOnTimeout (timers.js:300:5)
            2019-12-12 17:31:50.495  - error: host.raspberrypi Caught by controller[0]:     at listOnTimeout (timers.js:263:5)
            2019-12-12 17:31:50.495  - error: host.raspberrypi Caught by controller[0]:     at Timer.processTimers (timers.js:223:10)
            2019-12-12 17:31:50.496  - info: host.raspberrypi instance system.adapter.tr-064-community.0 terminated with code 0 (NO_ERROR)
            2019-12-12 17:31:50.496  - info: host.raspberrypi Restart adapter system.adapter.tr-064-community.0 because enabled
              @apollon77
              #469
              @conectas sicher das. Du vom GitHub neu drüber installiert hast? Hm ...
              HomoranH conectasC 2 Antworten Letzte Antwort
                #470
                @apollon77
                Vielleicht hilft upload
                  #471
                  Ne ich hab Blödsinn gemacht.
                  Man kann die Zeile
                  Einfach mit // auskommentierrn.
                  Handy lässt mich gerade nicht editieren :-(
                  conectasC 1 Antwort Letzte Antwort
                    conectasC Offline
                    conectasC Offline
                    conectas
                    #472
                    @apollon77
                    Die Version geht jetzt wieder .. komplett neu Installiert.
                    Irgendwie bin ich zu Blöd um hier im Forum zu begreifen, wann hier wo was hingeschrieben wird.
                    (Firefox macht auch irgendwie komische Fenster)
                    .. bekomme ich aber schon irgendwann raus ;-)
                      Man kann die Zeile
                      conectasC Offline
                      conectasC Offline
                      conectas
                      #473
                      @apollon77 sagte in Test Adapter tr-064-community v1.0.x:
                      pollingTimer = setTimeout(updateAll, 2000);
                        #474
                        @conectas na wenn’s wieder tut mit debug dann kommentiert nix aus ;-)
                        Müsste ein Adapter.log.debug
                          conectasC Offline
                          conectasC Offline
                          conectas
                          #475
                          Adapter.log.debug
                          949 //adapter.log.debug('Final Phonebook: ' + JSON.stringify(phonebook));
                          Haste DU bereits raus gemacht ;-)
                            #476
                            Also dann neue logs bitte und Fälle neu checken.
                            conectasC 3 Antworten Letzte Antwort
                              conectasC Offline
                              conectasC Offline
                              conectas
                              #477
                              Fall 01: 2mal hintereinander gleicher OUT (0171) auf IN (628yxz6)
                              jetzt wird nix (selbst) tr-064-community.0.callmonitor.inbound.json nicht neu geschrieben
                              2019-12-12 19:58:38.454  - debug: tr-064-community.0 (15488) callmonitor raw data: "12.12.19 19:58:38;RING;2;0171xyz;628xyz6;SIP0;\r\n"
                              2019-12-12 19:58:38.456  - debug: tr-064-community.0 (15488) callmonitor handle inbound message: {"caller":"0171xyz","callee":"628xyz6"}
                              2019-12-12 19:58:38.457  - debug: tr-064-community.0 (15488) Set State callmonitor.inbound.timestamp: "12.12.19 19:58:38" / ack=true
                              2019-12-12 19:58:38.460  - debug: tr-064-community.0 (15488) Search number 0049171xyz in phonebook: {"name":"NNAme Stefan","normalizedName":"NNAmestefan","number":"0049171yxz","id":"634","phonebookId":"0"}
                              2019-12-12 19:58:38.463  - debug: tr-064-community.0 (15488) Search number 004930628xyz6 in phonebook: {"name":"NNAme Kerstin","normalizedName":"NNAmekerstin","number":"004930628xyz6","id":"631","phonebookId":"0"}
                              2019-12-12 19:58:38.465  - debug: tr-064-community.0 (15488) Set State callmonitor.toPauseState: "ring" / ack=true
                              2019-12-12 19:58:38.467  - debug: tr-064-community.0 (15488) callMonitor.set: type=inbound caller=0171xyz callee=628xyz6 callerName=NNAme Stefan calleeName=NNAme Kerstin
                              2019-12-12 19:58:38.671  - debug: tr-064-community.0 (15488) Set State callmonitor.ringing: true / ack=true
                              2019-12-12 19:58:38.841  - debug: tr-064-community.0 (15488) setting 0 enable=false
                              2019-12-12 19:58:38.843  - debug: tr-064-community.0 (15488) setting 1 enable=false
                              2019-12-12 19:58:38.843  - debug: tr-064-community.0 (15488) setting 2 enable=false
                              2019-12-12 19:58:38.844  - debug: tr-064-community.0 (15488) setting 3 enable=false
                              2019-12-12 19:58:38.844  - debug: tr-064-community.0 (15488) setting 4 enable=false
                              2019-12-12 19:58:38.845  - debug: tr-064-community.0 (15488) setting 5 enable=true
                              2019-12-12 19:58:38.845  - debug: tr-064-community.0 (15488) setting 6 enable=true
                              2019-12-12 19:58:38.846  - debug: tr-064-community.0 (15488) setting 7 enable=true
                              2019-12-12 19:58:38.846  - debug: tr-064-community.0 (15488) setting 8 enable=true
                              2019-12-12 19:58:38.847  - debug: tr-064-community.0 (15488) setting 9 enable=true
                              2019-12-12 19:58:45.625  - debug: tr-064-community.0 (15488) callmonitor raw data: "12.12.19 19:58:45;CONNECT;2;4;0171xyz;\r\n"
                              2019-12-12 19:58:45.627  - debug: tr-064-community.0 (15488) callmonitor handle connect message: {"caller":"0171xyz","callee":"628xyz6","_type":"inbound","callerName":"NNAme Stefan","calleeName":"NNAme Kerstin","extension":"4"}
                              2019-12-12 19:58:45.628  - debug: tr-064-community.0 (15488) Set State callmonitor.connect.timestamp: "12.12.19 19:58:45" / ack=true
                              2019-12-12 19:58:45.629  - debug: tr-064-community.0 (15488) Set State callmonitor.toPauseState: "connect" / ack=true
                              2019-12-12 19:58:45.630  - debug: tr-064-community.0 (15488) Set State callmonitor.toPauseState-4: "connect" / ack=true
                              2019-12-12 19:58:45.631  - debug: tr-064-community.0 (15488) callMonitor.set: type=connect caller=0171xyz callee=628xyz6 callerName=NNAme Stefan calleeName=NNAme Kerstin
                              2019-12-12 19:58:45.833  - debug: tr-064-community.0 (15488) Set State callmonitor.ringing: false / ack=true
                              2019-12-12 19:58:48.464  - debug: tr-064-community.0 (15488) callmonitor raw data: "12.12.19 19:58:48;DISCONNECT;2;3;\r\n"
                              2019-12-12 19:58:48.466  - debug: tr-064-community.0 (15488) callmonitor handle lastCall message: {"caller":"0171xyz","callee":"628xyz6","_type":"connect","callerName":"NNAme Stefan","calleeName":"NNAme Kerstin","extension":"4","type":"disconnect","duration":3}
                              2019-12-12 19:58:48.468  - debug: tr-064-community.0 (15488) Set State callmonitor.lastCall.type: "disconnect" / ack=true
                              2019-12-12 19:58:48.470  - debug: tr-064-community.0 (15488) Set State callmonitor.lastCall.duration: 3 / ack=true
                              2019-12-12 19:58:48.472  - debug: tr-064-community.0 (15488) Set State callmonitor.lastCall.timestamp: "12.12.19 19:58:48" / ack=true
                              2019-12-12 19:58:48.474  - debug: tr-064-community.0 (15488) Set State callmonitor.lastCall.json: "{\"caller\":\"0171xyz\",\"callee\":\"628xyz6\",\"_type\":\"lastCall\",\"callerName\":\"NNAme Stefan\",\"calleeName\":\"NNAme Kerstin\",\"extension\":\"4\",\"type\":\"disconnect\",\"duration\":3}" / ack=true
                              2019-12-12 19:58:48.476  - debug: tr-064-community.0 (15488) Set State callmonitor.toPauseState: "end" / ack=true
                              2019-12-12 19:58:48.478  - debug: tr-064-community.0 (15488) Set State callmonitor.toPauseState-4: "end" / ack=true
                              2019-12-12 19:58:48.479  - debug: tr-064-community.0 (15488) callMonitor.set: type=lastCall caller=0171xyz callee=628xyz6 callerName=NNAme Stefan calleeName=NNAme Kerstin
                              2019-12-12 19:58:48.851  - debug: tr-064-community.0 (15488) in updateAll
                              2019-12-12 19:58:48.853  - debug: tr-064-community.0 (15488) updateDevices
                              2019-12-12 19:58:48.854  - debug: tr-064-community.0 (15488) forEachConfiguredDevice
                              2019-12-12 19:58:51.289  - debug: tr-064-community.0 (15488) setting 0 enable=false
                              2019-12-12 19:58:51.290  - debug: tr-064-community.0 (15488) setting 1 enable=false
                              2019-12-12 19:58:51.291  - debug: tr-064-community.0 (15488) setting 2 enable=false
                              2019-12-12 19:58:51.291  - debug: tr-064-community.0 (15488) setting 3 enable=false
                              2019-12-12 19:58:51.292  - debug: tr-064-community.0 (15488) setting 4 enable=false
                              2019-12-12 19:58:51.292  - debug: tr-064-community.0 (15488) setting 5 enable=true
                              2019-12-12 19:58:51.292  - debug: tr-064-community.0 (15488) setting 6 enable=true
                              2019-12-12 19:58:51.293  - debug: tr-064-community.0 (15488) setting 7 enable=true
                              2019-12-12 19:58:51.293  - debug: tr-064-community.0 (15488) setting 8 enable=true
                              2019-12-12 19:58:51.295  - debug: tr-064-community.0 (15488) setting 9 enable=true
                                conectasC Offline
                                conectasC Offline
                                conectas
                                #478
                                Fall2:
                                abwechselt:
                                OUT 0171 zu 628xy6
                                danach
                                OUT 0171 zu 628xy7
                                tr-064-community.0.callmonitor.inbound.caller
                                tr-064-community.0.callmonitor.inbound.callerName
                                werden nicht aktualisiert...
                                2019-12-12 20:07:10.493  - debug: tr-064-community.0 (15488) in updateAll
                                2019-12-12 20:07:10.495  - debug: tr-064-community.0 (15488) updateDevices
                                2019-12-12 20:07:10.496  - debug: tr-064-community.0 (15488) forEachConfiguredDevice
                                2019-12-12 20:07:12.959  - debug: tr-064-community.0 (15488) callmonitor raw data: "12.12.19 20:07:12;RING;2;0171xyz;628yxz6;SIP0;\r\n"
                                2019-12-12 20:07:12.960  - debug: tr-064-community.0 (15488) callmonitor handle inbound message: {"caller":"0171xyz","callee":"628yxz6"}
                                2019-12-12 20:07:12.961  - debug: tr-064-community.0 (15488) Set State callmonitor.inbound.callee: "628yxz6" / ack=true
                                2019-12-12 20:07:12.962  - debug: tr-064-community.0 (15488) Set State callmonitor.inbound.timestamp: "12.12.19 20:07:12" / ack=true
                                2019-12-12 20:07:12.963  - debug: tr-064-community.0 (15488) Search number 0049171xyz in phonebook: {"name":"NName Stefan","normalizedName":"NNamestefan","number":"0049171xyz","id":"634","phonebookId":"0"}
                                2019-12-12 20:07:12.964  - debug: tr-064-community.0 (15488) Search number 004930628yxz6 in phonebook: {"name":"NName Kerstin","normalizedName":"NNamekerstin","number":"004930628yxz6","id":"631","phonebookId":"0"}
                                2019-12-12 20:07:12.964  - debug: tr-064-community.0 (15488) Set State callmonitor.inbound.calleeName: "NName Kerstin" / ack=true
                                2019-12-12 20:07:12.965  - debug: tr-064-community.0 (15488) Set State callmonitor.inbound.json: "{\"caller\":\"0171xyz\",\"callee\":\"628yxz6\",\"_type\":\"inbound\",\"callerName\":\"NName Stefan\",\"calleeName\":\"NName Kerstin\"}" / ack=true
                                2019-12-12 20:07:12.966  - debug: tr-064-community.0 (15488) Set State callmonitor.toPauseState: "ring" / ack=true
                                2019-12-12 20:07:12.967  - debug: tr-064-community.0 (15488) callMonitor.set: type=inbound caller=0171xyz callee=628yxz6 callerName=NName Stefan calleeName=NName Kerstin
                                2019-12-12 20:07:13.168  - debug: tr-064-community.0 (15488) Set State callmonitor.ringing: true / ack=true
                                2019-12-12 20:07:13.225  - debug: tr-064-community.0 (15488) setting 0 enable=false
                                2019-12-12 20:07:13.226  - debug: tr-064-community.0 (15488) setting 1 enable=false
                                2019-12-12 20:07:13.227  - debug: tr-064-community.0 (15488) setting 2 enable=false
                                2019-12-12 20:07:13.228  - debug: tr-064-community.0 (15488) setting 3 enable=false
                                2019-12-12 20:07:13.229  - debug: tr-064-community.0 (15488) setting 4 enable=false
                                2019-12-12 20:07:13.229  - debug: tr-064-community.0 (15488) setting 5 enable=true
                                2019-12-12 20:07:13.230  - debug: tr-064-community.0 (15488) setting 6 enable=true
                                2019-12-12 20:07:13.230  - debug: tr-064-community.0 (15488) setting 7 enable=true
                                2019-12-12 20:07:13.231  - debug: tr-064-community.0 (15488) setting 8 enable=true
                                2019-12-12 20:07:13.231  - debug: tr-064-community.0 (15488) setting 9 enable=true
                                2019-12-12 20:07:19.126  - debug: tr-064-community.0 (15488) callmonitor raw data: "12.12.19 20:07:19;CONNECT;2;4;0171xyz;\r\n"
                                2019-12-12 20:07:19.127  - debug: tr-064-community.0 (15488) callmonitor handle connect message: {"caller":"0171xyz","callee":"628yxz6","_type":"inbound","callerName":"NName Stefan","calleeName":"NName Kerstin","extension":"4"}
                                2019-12-12 20:07:19.128  - debug: tr-064-community.0 (15488) Set State callmonitor.connect.callee: "628yxz6" / ack=true
                                2019-12-12 20:07:19.129  - debug: tr-064-community.0 (15488) Set State callmonitor.connect.calleeName: "NName Kerstin" / ack=true
                                2019-12-12 20:07:19.130  - debug: tr-064-community.0 (15488) Set State callmonitor.connect.timestamp: "12.12.19 20:07:19" / ack=true
                                2019-12-12 20:07:19.131  - debug: tr-064-community.0 (15488) Set State callmonitor.connect.json: "{\"caller\":\"0171xyz\",\"callee\":\"628yxz6\",\"_type\":\"connect\",\"callerName\":\"NName Stefan\",\"calleeName\":\"NName Kerstin\",\"extension\":\"4\"}" / ack=true
                                2019-12-12 20:07:19.135  - debug: tr-064-community.0 (15488) Set State callmonitor.toPauseState: "connect" / ack=true
                                2019-12-12 20:07:19.136  - debug: tr-064-community.0 (15488) Set State callmonitor.toPauseState-4: "connect" / ack=true
                                2019-12-12 20:07:19.137  - debug: tr-064-community.0 (15488) callMonitor.set: type=connect caller=0171xyz callee=628yxz6 callerName=NName Stefan calleeName=NName Kerstin
                                2019-12-12 20:07:19.339  - debug: tr-064-community.0 (15488) Set State callmonitor.ringing: false / ack=true
                                2019-12-12 20:07:20.343  - debug: tr-064-community.0 (15488) callmonitor raw data: "12.12.19 20:07:20;DISCONNECT;2;2;\r\n"
                                2019-12-12 20:07:20.344  - debug: tr-064-community.0 (15488) callmonitor handle lastCall message: {"caller":"0171xyz","callee":"628yxz6","_type":"connect","callerName":"NName Stefan","calleeName":"NName Kerstin","extension":"4","type":"disconnect","duration":2}
                                2019-12-12 20:07:20.345  - debug: tr-064-community.0 (15488) Set State callmonitor.lastCall.callee: "628yxz6" / ack=true
                                2019-12-12 20:07:20.346  - debug: tr-064-community.0 (15488) Set State callmonitor.lastCall.calleeName: "NName Kerstin" / ack=true
                                2019-12-12 20:07:20.347  - debug: tr-064-community.0 (15488) Set State callmonitor.lastCall.duration: 2 / ack=true
                                2019-12-12 20:07:20.348  - debug: tr-064-community.0 (15488) Set State callmonitor.lastCall.timestamp: "12.12.19 20:07:20" / ack=true
                                2019-12-12 20:07:20.350  - debug: tr-064-community.0 (15488) Set State callmonitor.lastCall.json: "{\"caller\":\"0171xyz\",\"callee\":\"628yxz6\",\"_type\":\"lastCall\",\"callerName\":\"NName Stefan\",\"calleeName\":\"NName Kerstin\",\"extension\":\"4\",\"type\":\"disconnect\",\"duration\":2}" / ack=true
                                2019-12-12 20:07:20.351  - debug: tr-064-community.0 (15488) Set State callmonitor.toPauseState: "end" / ack=true
                                2019-12-12 20:07:20.352  - debug: tr-064-community.0 (15488) Set State callmonitor.toPauseState-4: "end" / ack=true
                                2019-12-12 20:07:20.353  - debug: tr-064-community.0 (15488) callMonitor.set: type=lastCall caller=0171xyz callee=628yxz6 callerName=NName Stefan calleeName=NName Kerstin
                                2019-12-12 20:07:23.232  - debug: tr-064-community.0 (15488) in updateAll
                                2019-12-12 20:07:23.234  - debug: tr-064-community.0 (15488) updateDevices
                                2019-12-12 20:07:23.235  - debug: tr-064-community.0 (15488) forEachConfiguredDevice
                                  conectasC Offline
                                  conectasC Offline
                                  conectas
                                  #479
                                  Ich würde bei Tests dieses Script mitlaufen lassen.. oder bringt das in deinen Logs dann zu viel durcheinander?
                                  let tr064 = "tr-064-community.0.callmonitor.";
                                  var callerNumber    // Anrufernummer
                                  var callerName      // Name des Anrufers
                                  var calleeNumber    // angerufene Nummer
                                  var calleeName      // angerufener Name
                                  var callAllDataJson = { "caller": "caller Nr", "callee": "callee Nr", "_type": "_type inbound", "callerName": "Caller Name", "calleeName": "Callee Name" };
                                  on({ id: "tr-064-community.0.callmonitor.toPauseState", change: "any" }, function (obj) {
                                      console.log('---> Ringing?: ');
                                      let sToPauseState = getState(tr064 + "toPauseState").val;
                                      if ("ring" == sToPauseState) {
                                          callerNumber = getState(tr064 + "inbound.caller").val;          // Anrufernummer
                                          callerName = getState(tr064 + "inbound.callerName").val;        // Name des Anrufers
                                          calleeNumber = getState(tr064 + "inbound.callee").val;          // angerufene Nummer
                                          calleeName = getState(tr064 + "inbound.calleeName").val;        // angerufener Name
                                          callAllDataJson = getState(tr064 + "inbound.json").val;          // json
                                          console.log('---> Ringing? - callerNumber: ' + callerNumber);
                                          console.log('---> Ringing? - callerName: ' + callerName);
                                          console.log('---> Ringing? - calleeNumber: ' + calleeNumber);
                                          console.log('---> Ringing? - calleeName: ' + calleeName);
                                          console.log('---> Ringing? - callAllDataJson: ' + String(callAllDataJson));
                                      } else if ("end" == sToPauseState) {
                                          setState(tr064 + "inbound.caller", '');
                                          setState(tr064 + "inbound.callerName", '');
                                          setState(tr064 + "inbound.callee", '');
                                          setState(tr064 + "inbound.calleeName", '');
                                          setState(tr064 + "inbound.json", '');
                                    #480
                                    Oooook ... ich hab mal erste DInge verändert. Bitte nochmal neu versuchen vom GitHub, bitte checkt aber auch ob der ganze Rest (also auch IP.Devices und so) noch so tut wie es soll.
                                    Und bitte extra Skripte weglassen. Danke
                                      conectasC Offline
                                      conectasC Offline
                                      conectas
                                      #481
                                      Knallt...
                                      2019-12-12 21:24:14.636  - info: host.raspberrypi "system.adapter.tr-064-community.0" enabled
                                      2019-12-12 21:24:14.666  - info: host.raspberrypi instance system.adapter.tr-064-community.0 started with pid 18626
                                      2019-12-12 21:24:17.602  - debug: tr-064-community.0 (18626) Redis Objects: Use Redis connection: 127.0.0.1:9001
                                      2019-12-12 21:24:17.671  - debug: tr-064-community.0 (18626) Objects client ready ... initialize now
                                      2019-12-12 21:24:17.680  - debug: tr-064-community.0 (18626) Objects create PubSub Client
                                      2019-12-12 21:24:17.683  - debug: tr-064-community.0 (18626) Objects client initialize lua scripts
                                      2019-12-12 21:24:17.712  - debug: tr-064-community.0 (18626) objectDB connected
                                      2019-12-12 21:24:17.718  - debug: tr-064-community.0 (18626) Redis States: Use Redis connection: 127.0.0.1:9000
                                      2019-12-12 21:24:17.725  - debug: tr-064-community.0 (18626) Objects connected to redis: 127.0.0.1:9001
                                      2019-12-12 21:24:17.735  - debug: tr-064-community.0 (18626) States create PubSub Client
                                      2019-12-12 21:24:17.738  - debug: tr-064-community.0 (18626) statesDB connected
                                      2019-12-12 21:24:17.805  - debug: tr-064-community.0 (18626) States connected to redis: 127.0.0.1:9000
                                      2019-12-12 21:24:18.366  - info: tr-064-community.0 (18626) starting. Version 1.2.0 in /opt/iobroker/node_modules/iobroker.tr-064-community, node: v10.17.0
                                      2019-12-12 21:24:21.236  - error: tr-064-community.0 (18626) uncaught exception: st is not defined
                                      2019-12-12 21:24:21.241  - error: tr-064-community.0 (18626) ReferenceError: st is not defined
                                          at createObjects (/opt/iobroker/node_modules/iobroker.tr-064-community/main.js:102:59)
                                          at /opt/iobroker/node_modules/iobroker.tr-064-community/main.js:940:9
                                          at /opt/iobroker/node_modules/iobroker.tr-064-community/lib/soef.js:1610:28
                                          at /opt/iobroker/node_modules/tr-O64/lib/Service.js:267:17
                                          at Parser.<anonymous> (/opt/iobroker/node_modules/xml2js/lib/parser.js:306:18)
                                          at Parser.emit (events.js:198:13)
                                          at SAXParser.onclosetag (/opt/iobroker/node_modules/xml2js/lib/parser.js:264:26)
                                          at emit (/opt/iobroker/node_modules/sax/lib/sax.js:624:35)
                                          at emitNode (/opt/iobroker/node_modules/sax/lib/sax.js:629:5)
                                          at closeTag (/opt/iobroker/node_modules/sax/lib/sax.js:889:7)
                                      2019-12-12 21:24:21.300  - info: tr-064-community.0 (18626) terminating
                                      2019-12-12 21:24:21.303  - info: tr-064-community.0 (18626) Terminated (NO_ERROR): Without reason
                                      2019-12-12 21:24:21.861  - error: host.raspberrypi Caught by controller[0]: ReferenceError: st is not defined
                                      2019-12-12 21:24:21.864  - error: host.raspberrypi Caught by controller[0]:     at createObjects (/opt/iobroker/node_modules/iobroker.tr-064-community/main.js:102:59)
                                      2019-12-12 21:24:21.865  - error: host.raspberrypi Caught by controller[0]:     at /opt/iobroker/node_modules/iobroker.tr-064-community/main.js:940:9
                                      2019-12-12 21:24:21.866  - error: host.raspberrypi Caught by controller[0]:     at /opt/iobroker/node_modules/iobroker.tr-064-community/lib/soef.js:1610:28
                                      2019-12-12 21:24:21.866  - error: host.raspberrypi Caught by controller[0]:     at /opt/iobroker/node_modules/tr-O64/lib/Service.js:267:17
                                      2019-12-12 21:24:21.867  - error: host.raspberrypi Caught by controller[0]:     at Parser.<anonymous> (/opt/iobroker/node_modules/xml2js/lib/parser.js:306:18)
                                      2019-12-12 21:24:21.867  - error: host.raspberrypi Caught by controller[0]:     at Parser.emit (events.js:198:13)
                                      2019-12-12 21:24:21.868  - error: host.raspberrypi Caught by controller[0]:     at SAXParser.onclosetag (/opt/iobroker/node_modules/xml2js/lib/parser.js:264:26)
                                      2019-12-12 21:24:21.868  - error: host.raspberrypi Caught by controller[0]:     at emit (/opt/iobroker/node_modules/sax/lib/sax.js:624:35)
                                      2019-12-12 21:24:21.869  - error: host.raspberrypi Caught by controller[0]:     at emitNode (/opt/iobroker/node_modules/sax/lib/sax.js:629:5)
                                      2019-12-12 21:24:21.869  - error: host.raspberrypi Caught by controller[0]:     at closeTag (/opt/iobroker/node_modules/sax/lib/sax.js:889:7)
                                      2019-12-12 21:24:21.870  - info: host.raspberrypi instance system.adapter.tr-064-community.0 terminated with code 0 (NO_ERROR)
                                      2019-12-12 21:24:21.870  - info: host.raspberrypi Restart adapter system.adapter.tr-064-community.0 because enabled
                                        #482
                                        gggrrrr ... fixed on GitHub. Sorry
                                          conectasC Offline
                                          conectasC Offline
                                          conectas
                                          #483
                                          @apollon77
                                          außer toPauseState werden im callmonitor nix angelegt.. 2x getestet
