  4. History überarbeitet
149 Beiträge 18 Kommentatoren 46.9k Aufrufe
  • sissiwupS Offline
    sissiwupS Offline
    sissiwup
    folgende Fehlermeldungen liefert der SQL-Lite Adapter:
    ` > sql-0 2015-12-04 18:25:12 error Cannot delete DELETE FROM ts_number WHERE id=179 AND ts < 1417713900;: Error: SQLITE_BUSY: database is locked
    sql-0 2015-12-04 17:08:28 error Cannot insert INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES(146, 1449245306000, 48, 1, 1, 0);: Error: SQLITE_BUSY: database is locked
    sql-0 2015-12-04 16:47:37 error Cannot insert INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES(134, 1449244055000, 697, 1, 1, 0);: Error: SQLITE_BUSY: database is locked
    sql-0 2015-12-04 16:26:37 error Cannot delete DELETE FROM ts_number WHERE id=175 AND ts < 1417706760;: Error: SQLITE_BUSY: database is locked
    sql-0 2015-12-04 16:16:19 error Cannot delete DELETE FROM ts_number WHERE id=177 AND ts < 1417706161;: Error: SQLITE_BUSY: database is locked
    sql-0 2015-12-04 14:42:09 error Cannot insert INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES(134, 1449236526000, 599, 1, 1, 0);: Error: SQLITE_BUSY: database is locked
    sql-0 2015-12-04 14:19:07 error Cannot insert INSERT INTO ts_string (id, ts, val, ack, _from, q) VALUES(223, 1449235146000, , 1, 6, 0);: Error: SQLITE_ERROR: near ',': syntax error
    sql-0 2015-12-04 13:34:07 error Cannot delete DELETE FROM ts_string WHERE id=222 AND ts < 1417696440;: Error: SQLITE_BUSY: database is locked
    sql-0 2015-12-04 12:33:35 error Cannot insert INSERT INTO ts_string (id, ts, val, ack, _from, q) VALUES(224, 1449228814000, ### ? ###, 1, 6, 0);: Error: SQLITE_ERROR: unrecognized token: '#'
    sql-0 2015-12-04 12:33:26 error Cannot insert INSERT INTO ts_string (id, ts, val, ack, _from, q) VALUES(223, 1449228805000, , 1, 6, 0);: Error: SQLITE_ERROR: near ',': syntax error
    sql-0 2015-12-04 12:32:56 error Cannot insert INSERT INTO ts_string (id, ts, val, ack, _from, q) VALUES(223, 1449228775000, ### ? ###, 1, 6, 0);: Error: SQLITE_ERROR: unrecognized token: '#'
    sql-0 2015-12-04 11:54:15 error Cannot delete DELETE FROM ts_number WHERE id=167 AND ts < 1417690440;: Error: SQLITE_BUSY: database is locked
    sql-0 2015-12-04 11:53:17 error Cannot delete DELETE FROM ts_number WHERE id=119 AND ts < 1417690381;: Error: SQLITE_BUSY: database is locked
    sql-0 2015-12-04 11:53:16 error Cannot insert INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES(122, 1449226395000, 0, 1, 1, 0);: Error: SQLITE_BUSY: database is locked
    sql-0 2015-12-04 11:53:16 error Cannot delete DELETE FROM ts_number WHERE id=117 AND ts < 1417690381;: Error: SQLITE_BUSY: database is locked
    sql-0 2015-12-04 11:53:15 error Cannot delete DELETE FROM ts_number WHERE id=150 AND ts < 1417690381;: Error: SQLITE_BUSY: database is locked
    sql-0 2015-12-04 11:52:58 error Cannot delete DELETE FROM ts_bool WHERE id=220 AND ts < 1417690321;: Error: SQLITE_BUSY: database is locked `
    MfG
    Sissi
    1 CCU3 1 CCU2-Gateway 1 LanGateway 1 Pi-Gateway 1 I7 für ioBroker/MySQL
    • eric2905E Offline
      eric2905E Offline
      eric2905
      Bei mir kommen "nur" Meldungen, das die DB locked ist:
      sql.0 Cannot insert INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES(18, 1449252034000, 9.2, 1, 2, 0);: Error: SQLITE_BUSY: database is locked
      sql.0	2015-12-04 19:00:35	error	sql.0 Cannot insert INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES(32, 1449252021000, 15.3867, 1, 4, 0);: Error: SQLITE_BUSY: database is locked
      Das sind auch derzeit die einzigen Meldungen vom sql.
      Gruß,
      Eric
      • sissiwupS Offline
        sissiwupS Offline
        sissiwup
        sql-0 2015-12-04 23:09:57 error Error: SQLITE_BUSY: database is locked
        Taucht auch noch auf, deutet auf einen Fehler in der Programmierung.
        MfG
        Sissi
        • BluefoxB Offline
          BluefoxB Offline
          @sissiwup:
          Taucht auch noch auf, deutet auf einen Fehler in der Programmierung. `
          Programmierung wo?
          • ThisoftT Offline
            ThisoftT Offline
            Thisoft
            Also ich hatte die "database locked" Fehler nur in der Zeit wo ich über ODBC sozusagen "nebenher" auf die SQLite-Db zugegriffen habe. Ansonsten ist bei mir jetzt alles sauber.
            Abgesehen davon dass sich mein ioBroker-Rechner heute verabschiedet hat weil der Arbeitsspeicher nicht mehr gereicht hat. Ich beobachte das mal weiter. Wäre schlecht wenn jetzt der neue SQL-Adapter zwar weniger Prozessorlast aber mehr Speicherverbrauch hat als der alte History. Ich beobachte das mal…
            Ein Db-lock ist meines Erachtens kein Programmierfehler sondern ein Zugriffsproblem auf die Db. @sissiwup und eric2905: habt ihr wirklich Schreibrechte auf die Db? Welche Db habt ihr?
            22 HM-Geräte; PivCCU2 auf RasPi
            ioBroker-Multihost; Ubuntu-Master auf Intel-Atom und 3 RasPi-Clients
            • eric2905E Offline
              eric2905E Offline
              eric2905
              Moin,
              @Thisoft:
              @sissiwup und eric2905: habt ihr wirklich Schreibrechte auf die Db? Welche Db habt ihr? `
              ich habe die DB, die bei der Installation mitkommt, benutzt.
              Schreibrecht muss ja da sein, da ich Werte protokolliert bekomme.
              Gruß,
              Eric
              Gesendet von iPad mit Tapatalk
                starfish
                bei mir läuft ja mysql nicht, das wird doch wohl nicht damit zusammenhängen, dass ich 2 sql-instanzen laufen habe, eine mit sqlite und die andere mit mysql? Hat sonst noch jemand mysql getestet?
                • sissiwupS Offline
                  sissiwupS Offline
                  sissiwup
                  der Fehler deutet darauf hin, das in einer UOW (Unit of Work) etwas gemacht wird, was nicht gehen kann.
                  Z.B. löschen von Zeilen und Update auf die gleichen Zeilen.
                  Es sind nicht zwei Instanzen, die sich behaken, sondern in einem Programm passiert etwas unlogisches.
                  Neues Phänomen:
                  Ich habe gestern mal flot getestet, danach war die DB tot.
                  Erst ein Neustart vom IOBroker hat geholfen.
                  Sieht man zwischen 1:00 und 23:00
                  MfG
                  Sissi
                  • BluefoxB Offline
                    BluefoxB Offline
                    @sissiwup:
                    Neues Phänomen:
                    filename="Bildschirmfoto 2015-12-05 um 21.31.57.png" index="0">~~
                    Sieht man zwischen 1:00 und 23:00 `
                    In solchen Fällen, bitte immer log anschauen und hier posten.
                    • BluefoxB Offline
                      BluefoxB Offline
                      @starfish:
                      bei mir läuft ja mysql nicht, das wird doch wohl nicht damit zusammenhängen, dass ich 2 sql-instanzen laufen habe, eine mit sqlite und die andere mit mysql? Hat sonst noch jemand mysql getestet? `
                      Kannst du mit andren Clients dadrauf zugegriffen?
                      Ich habe so verstanden, dass MySQL auf dem anderen Rechner läuft. Kannst du vom ioBroker Rechner auf MySQL mit normalem Client zugreifen?
                      • BluefoxB Offline
                        BluefoxB Offline
                        @sissiwup:
                        Wenn es denn läuft, wie werden dann die bestehenden History Einträge übernommen? `
                        Die werden nicht übernommen. Man startet zweiten Adapter und fängt an den zu nutzen. Es gibt noch keine Konvert-Funktion.
                        Ob es geben wird, weiß ich noch nicht. ;)
                        • BluefoxB Offline
                          BluefoxB Offline
                          @starfish:
                          Frage zu mysql.
                          ich versuche gerade auf meine mysql-datenbank auf einem anderen Rechner im Netzwerk zu verbinden. Da bekomm ich die Fehlermeldung:
                          Error: getaddrinfo ENOTFOUND . die bind-adresse in my.cnf ist auf 0.0.0.0, also sollten Verbindungen aus dem Netzwerk angenommen werden. Firewalls gibts keine. Das muss ich noch genauer anschauen, aber wie lautet der Datenbankname? filename="mysql.PNG" index="0">~~
                          Nachtrag: habe mysql lokal installiert, bei "Verbindung testen" kommt dieselbe Fehlermeldung " Error: getaddrinfo ENOTFOUND "
                          (host = localhost) `
                          " Error: getaddrinfo ENOTFOUND" Sagt, dass 192.168.0.61 nicht erreichbar ist.
                          Ich muss sagen. ich habe nur mit lokale Installation probiert (dazu noch Windows).
                          Datenbank wird automatisch erzeugt und heißt "iobroker"
                          • BluefoxB Offline
                            BluefoxB Offline
                            @starfish:
                            grad eben festgestellt: beim neuen flot kann ich die Legende nicht einblenden
                            Nachtrag 4.12.: hat sich erledigt, Namen werden nicht automatisch eingesetzt. Wenn man bei Input data Namen definiert, wird auch die Legende eingeblendet. `
                            Ist unklar. Bei sehe ich die Legende, ohne, dass ich Namen eigenen muss:
                            • BluefoxB Offline
                              BluefoxB Offline
                              @sissiwup:
                              Habe hetzt neue Version von SQL veröffentlicht. Bitte mit:
                              cd /opt/iobroker
                              iobroker stop sql
                              npm install iobroker.sql
                              iobroker start sql
                              updaten.
                              Ich erlaube nur ein Client für SQLite.
                              • eric2905E Offline
                                eric2905E Offline
                                eric2905
                                Hi Bluefox,
                                muss da noch ein
                                iobroker upload sql
                                hin, oder geht das auch so (da der Adapter schon da ist)?
                                Gruß,
                                Eric
                                • eric2905E Offline
                                  eric2905E Offline
                                  eric2905
                                  So, update ist durch.
                                  Direkt nach dem Start kamen nochmal einige Meldungen :
                                  ` > sql.0 2015-12-06 18:39:08 info sql.0 enabled logging of hm-rega.0.41482
                                  sql.0 2015-12-06 18:39:08 info sql.0 enabled logging of hm-rpc.0.xxxxxxxxxx.1.POWER
                                  sql.0 2015-12-06 18:39:08 info sql.0 enabled logging of hm-rpc.0.xxxxxxxxxx.1.TEMPERATURE
                                  sql.0 2015-12-06 18:39:08 info sql.0 enabled logging of hm-rpc.0.xxxxxxxxxx.1.HUMIDITY
                                  sql.0 2015-12-06 18:39:08 info sql.0 enabled logging of system.host.cubietruck.load
                                  sql.0 2015-12-06 18:39:08 info sql.0 enabled logging of system.host.cubietruck.mem
                                  sql.0 2015-12-06 18:39:08 info sql.0 Connected to sqlite
                                  sql.0 2015-12-06 18:39:07 info sql.0 starting. Version 0.0.2 in /opt/iobroker/node_modules/iobroker.sql
                                  host-cubietruck 2015-12-06 18:38:59 info instance system.adapter.sql.0 started with pid 5980
                                  host-cubietruck 2015-12-06 18:38:56 info instance system.adapter.sql.0 terminated with code 0 (OK)
                                  sql-0 2015-12-06 18:38:56 info terminating
                                  host-cubietruck 2015-12-06 18:38:56 info stopInstance system.adapter.sql.0 killing pid 5965
                                  host-cubietruck 2015-12-06 18:38:56 info object change system.adapter.sql.0
                                  sql-0 2015-12-06 18:38:45 error Cannot delete DELETE FROM ts_number WHERE id=21 AND ts < 1449337080;: Error: SQLITE_BUSY: database is locked
                                  sql-0 2015-12-06 18:38:40 error Cannot insert INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES(1, 1449423508000, 20, 1, 1, 0);: Error: SQLITE_BUSY: database is locked
                                  sql-0 2015-12-06 18:38:20 warn Cannot get index of 'hm-rpc.0.IEQ0150728.1.TEMPERATURE': Error: SQLITE_BUSY: database is locked
                                  sql-0 2015-12-06 18:38:20 error Cannot select SELECT id, type FROM datapoints WHERE name='hm-rpc.0.IEQ0150728.1.TEMPERATURE';: Error: SQLITE_BUSY: database is locked
                                  host-cubietruck 2015-12-06 18:38:17 info Update repository 'default' under 'conf/sources-dist.json'
                                  sql-0 2015-12-06 18:38:00 info Connected to sqlite
                                  sql-0 2015-12-06 18:38:00 info enabled logging of hm-rega.0.41482
                                  sql-0 2015-12-06 18:38:00 info enabled logging of hm-rpc.0.xxxxxxxxxx.1.POWER
                                  sql-0 2015-12-06 18:38:00 info enabled logging of system.host.cubietruck.load
                                  sql-0 2015-12-06 18:38:00 info enabled logging of system.host.cubietruck.mem
                                  sql-0 2015-12-06 18:38:00 info starting. Version 0.0.2 in /opt/iobroker/node_modules/iobroker.sql
                                  host-cubietruck 2015-12-06 18:37:51 info instance system.adapter.sql.0 started with pid 5965
                                  host-cubietruck 2015-12-06 18:37:51 info 'system.adapter.sql.0' enabled
                                  host-cubietruck 2015-12-06 18:37:51 info object change system.adapter.sql.0 `
                                  und kurz darauf wieder diese Meldungen:
                                  ` > sql.0 2015-12-06 18:44:41 warn sql.0 Cannot get index of 'hm-rpc.0.xxxxxxxxxx.3.TEMPERATURE': Error: SQLITE_BUSY: database is locked
                                  sql.0 2015-12-06 18:44:41 error sql.0 Cannot select SELECT id, type FROM datapoints WHERE name='hm-rpc.0.LEQ0773872.3.TEMPERATURE';: Error: SQLITE_BUSY: database is locked
                                  sql.0 2015-12-06 18:42:49 error sql.0 Cannot delete DELETE FROM ts_number WHERE id=11 AND ts < 1449337320;: Error: SQLITE_BUSY: database is locked
                                  sql.0 2015-12-06 18:42:48 error sql.0 Cannot delete DELETE FROM ts_number WHERE id=8 AND ts < 1449337320;: Error: SQLITE_BUSY: database is locked
                                  sql.0 2015-12-06 18:42:34 warn sql.0 Cannot get index of 'hm-rpc.0.xxxxxxxxxx.3.TEMPERATURE': Error: SQLITE_BUSY: database is locked
                                  sql.0 2015-12-06 18:42:34 error sql.0 Cannot select SELECT id, type FROM datapoints WHERE name='hm-rpc.0.LEQ0773872.3.TEMPERATURE';: Error: SQLITE_BUSY: database is locked
                                  sql.0 2015-12-06 18:41:40 error sql.0 Cannot delete DELETE FROM ts_number WHERE id=17 AND ts < 1449337261;: Error: SQLITE_BUSY: database is locked
                                  sql.0 2015-12-06 18:40:43 error sql.0 Cannot delete DELETE FROM ts_number WHERE id=14 AND ts < 1449337200;: Error: SQLITE_BUSY: database is locked
                                  sql.0 2015-12-06 18:40:42 error sql.0 Cannot delete DELETE FROM ts_number WHERE id=6 AND ts < 1449337201;: Error: SQLITE_BUSY: database is locked
                                  sql.0 2015-12-06 18:40:41 error sql.0 Cannot delete DELETE FROM ts_number WHERE id=23 AND ts < 1449337201;: Error: SQLITE_BUSY: database is locked
                                  sql.0 2015-12-06 18:40:25 error sql.0 Cannot delete DELETE FROM ts_number WHERE id=33 AND ts < 1449337201;: Error: SQLITE_BUSY: database is locked
                                  sql.0 2015-12-06 18:40:13 warn sql.0 Cannot get index of 'hm-rpc.0.xxxxxxxxxx.3.TEMPERATURE': Error: SQLITE_BUSY: database is locked
                                  sql.0 2015-12-06 18:40:13 error sql.0 Cannot select SELECT id, type FROM datapoints WHERE name='hm-rpc.0.xxxxxxxxxx.3.TEMPERATURE';: Error: SQLITE_BUSY: database is locked
                                  sql.0 2015-12-06 18:39:08 info sql.0 enabled logging of hm-rpc.0.xxxxxxxxxx.1.TEMPERATURE `
                                  Irgendwas klemmt da noch.
                                  Es läuft auch sonst nichts mit SQL auf dem Cubietruck - der macht nichts anderes als ioBroker.
                                  Gruß,
                                  Eric
                                  PS:
                                  Wenn ich versuche, Flot zu installieren, meckert die Installation am Ende, das die Version des History-Adapters >= 0.2.0 sein soll (error 30).
                                  Ich habe die Version 0.1.3 drauf.
                                  Hab ich irgendwas überlesen?
                                    starfish
                                    @Bluefox:
                                    Ich habe so verstanden, dass MySQL auf dem anderen Rechner läuft. Kannst du vom ioBroker Rechner auf MySQL mit normalem Client zugreifen? `
                                    ja, kann ich (mit mysql -u xxxx -h 192.168.0.61 -p) , allerdings habe ich jetzt auf dem iobroker testserver ein eigener mysql-server eingerichtet, über localhost müsste es eigentlich problemlos laufen.
                                    • sissiwupS Offline
                                      sissiwupS Offline
                                      sissiwup
                                      Habe das Update durchgeführt.
                                      ` > sql.0 Cannot delete DELETE FROM ts_number WHERE id=172 AND ts < 1417897381;: Error: SQLITE_BUSY: database is locked
                                      sql.0 2015-12-06 21:23:23 error sql.0 Cannot insert INSERT INTO ts_bool (id, ts, val, ack, _from, q) VALUES(112, 1449433400000, 0, 1, 4, 0);: Error: SQLITE_BUSY: database is locked
                                      sql.0 2015-12-06 21:23:23 error sql.0 Cannot delete DELETE FROM ts_bool WHERE id=111 AND ts < 1417897380;: Error: SQLITE_BUSY: database is locked
                                      sql.0 2015-12-06 21:23:23 error sql.0 Cannot delete DELETE FROM ts_bool WHERE id=110 AND ts < 1417897380;: Error: SQLITE_BUSY: database is locked
                                      sql.0 2015-12-06 21:23:21 error sql.0 Cannot select SELECT id, type FROM datapoints WHERE name='ping.0.raspberrypi.192_168_1_11';: Error: SQLITE_BUSY: database is locked `
                                      MfG
                                      Sissi
                                      • ThisoftT Offline
                                        ThisoftT Offline
                                        Thisoft
                                        ich hatte jetzt auch einmal den Zugriffsfehler:
                                        ` > sql.0 2015-12-06 21:23:05 error sql.0 Cannot insert INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES(10, 1449433373000, 271.35, 1, 1, 0);: Error: SQLITE_BUSY: database is locked
                                        sql.0 2015-12-06 21:23:04 debug sql.0 INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES(1, 1449433373000, 28, 1, 1, 0); `
                                        Und ich denke, man sieht hier im Vergleich mit dem unmittelbar zuvor (erfolgreich) ausgeführten Statement dass der Grund dafür ist, dass der zweite Datensatz hier mit einem bereits existierenden Timestamp eingefügt werden soll. Die Fehlermeldung "Database locked" ist da natürlich ziemlich irreführend ;)
                                        @Bluefox: Ich hab's mir zwar im Code mal angeschaut wie Du den Timestamp generierst, aber da sind meine JS-Kenntnisse noch zu rudimentär um herauszufinden warum der doppelt generiert wird :oops:
                                        • sissiwupS Offline
                                          sissiwupS Offline
                                          sissiwup
                                          Kannst du den .timeout auf 11000 setzen?
                                          Der Pi kann scheinbar nur Sekunden Sleeps und könnte damit ein Problem haben.
                                          MfG
                                          Sissi
