  3. Entwicklung
  4. ZigBee CC253x neue/unbekannte Geräte - ab 0.11.x
cc253xzigbee adapter
142 Beiträge 32 Kommentatoren 27.1k Aufrufe 34 Beobachtet
  • M Mac_Schmeck
    Darunter ist mein logfile.
    Mein Problem habe ich gestern geschildert, danke für Infos.
    host.raspberrypi 2019-11-28 07:49:25.954 info Restart adapter system.adapter.zigbee.0 because enabled
    host.raspberrypi 2019-11-28 07:49:25.952 error instance system.adapter.zigbee.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    host.raspberrypi 2019-11-28 07:49:25.949 error Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/@serialport/bindings/lib/index.js:14:22)
    host.raspberrypi 2019-11-28 07:49:25.947 error Caught by controller[0]: at require (internal/modules/cjs/helpers.js:25:18)
    host.raspberrypi 2019-11-28 07:49:25.945 error Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:692:17)
    host.raspberrypi 2019-11-28 07:49:25.943 error Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:585:3)
    host.raspberrypi 2019-11-28 07:49:25.941 error Caught by controller[0]: at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
    host.raspberrypi 2019-11-28 07:49:25.938 error Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:653:32)
    host.raspberrypi 2019-11-28 07:49:25.936 error Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10)
    host.raspberrypi 2019-11-28 07:49:25.934 error Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:778:30)
    host.raspberrypi 2019-11-28 07:49:25.932 error Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/@serialport/bindings/lib/linux.js:1:36)
    host.raspberrypi 2019-11-28 07:49:25.930 error Caught by controller[0]: at bindings (/opt/iobroker/node_modules/bindings/bindings.js:93:9)
    host.raspberrypi 2019-11-28 07:49:25.928 error Caught by controller[0]: → /opt/iobroker/node_modules/@serialport/bindings/compiled/10.17.0/linux/arm/bindings.node
    host.raspberrypi 2019-11-28 07:49:25.926 error Caught by controller[0]: → /opt/iobroker/node_modules/@serialport/bindings/build/default/bindings.node
    host.raspberrypi 2019-11-28 07:49:25.923 error Caught by controller[0]: → /opt/iobroker/node_modules/@serialport/bindings/Release/bindings.node
    host.raspberrypi 2019-11-28 07:49:25.921 error Caught by controller[0]: → /opt/iobroker/node_modules/@serialport/bindings/out/Release/bindings.node
    host.raspberrypi 2019-11-28 07:49:25.919 error Caught by controller[0]: → /opt/iobroker/node_modules/@serialport/bindings/Debug/bindings.node
    host.raspberrypi 2019-11-28 07:49:25.917 error Caught by controller[0]: → /opt/iobroker/node_modules/@serialport/bindings/out/Debug/bindings.node
    host.raspberrypi 2019-11-28 07:49:25.915 error Caught by controller[0]: → /opt/iobroker/node_modules/@serialport/bindings/build/Release/bindings.node
    host.raspberrypi 2019-11-28 07:49:25.913 error Caught by controller[0]: → /opt/iobroker/node_modules/@serialport/bindings/build/Debug/bindings.node
    host.raspberrypi 2019-11-28 07:49:25.911 error Caught by controller[0]: → /opt/iobroker/node_modules/@serialport/bindings/build/bindings.node
    host.raspberrypi 2019-11-28 07:49:25.908 error Caught by controller[0]: Error: Could not locate the bindings file. Tried:
    host.raspberrypi 2019-11-28 07:49:25.906 error Caught by controller[0]: ^
    host.raspberrypi 2019-11-28 07:49:25.904 error Caught by controller[0]: throw err
    host.raspberrypi 2019-11-28 07:49:25.901 error Caught by controller[0]: /opt/iobroker/node_modules/bindings/bindings.js:96
    host.raspberrypi 2019-11-28 07:49:18.222 info instance system.adapter.zigbee.0 started with pid 20256
    AsgothianA Offline
    AsgothianA Offline
    Asgothian
    #102
    @schmidti2007 sagte in ZigBee CC253x neue/unbekannte Geräte - ab 0.11.x:
    Moin zusammen,
    es geht noch mal im das Leuchtmittel IKEA TRADFRI bulb E27 WW clear 250lm
    Aber erst einmal eine kurze Bitte an euch. Könnt ihr mir bitte sagen, ob die folgenden Aussagen korrekt sind? Ich bin vor ein paar Tagen komplett neu in das Thema IOBroker und Zigbee eingestiegen und wusel mich nun durch und versuche zu begreifen :-)
    1. Zigbee-Shepherd wird nicht weiter programmiert
    Korrekt
    1. Der Zigbee-Shepherd-Converter wird noch immer mit neuen Geräten erweitert
    nicht Korrekt
    1. Der Zigbee-Herdsman und Herdsman-Converter lösen den Zigbee-Shepherd in Zukunft ab (derzeit noch alpha)
    Korrekt
    Nun zum Leuchtmittel: Die IKEA TRADFRI bulb E27 WW clear 250lm wurde schon kurz in "neue/unbekannte Geräte - ab 0.10.x" angesprochen. Kann dieses Leuchtmittel noch in die Shepherd Generation eingefügt werden? Ist dies überhaupt möglich? Wenn ja, könnte dies noch Beachtung bei den Entwicklern finden?
    Was ich bisher weiß und auch noch nicht weiß:
    1. Das Gerät muss im Shepherd-Converter in devices.js auftauchen. Tut es in der aktuellen Version 10.2.7 nicht. Es ist nur in der herdsman branch - dort allerdings auch nur im eingebundenem converter und nicht in der devstates.js.
    2. Muss der Zigbee-Shepherd (nicht Converter) auch jedes Mal für neue Geräte angepasst werden? Oder wird nur der Converter angepasst?
    1. Ich habe es mit eigener herdsman fork probiert, um die devstates anzupassen. Leider erfolglos und ich habe dabei irgendeine DB zerstört und musste den IOBroker neu installieren 🐶 . Bin halt ein Anfänger und weiß nicht wie man ein komplett Backup vom IOBroker erstellt ... das finde ich aber bestimmt hier im Forum.
    Die einzige db die du dir zerschiessen kannst ist die Datei shepherd.db in /opt/iobroker/iobroker-data/zigbee.0. Dieses Verzeichnis sichern ist notwendig
    A.
    • M Mac_Schmeck
      AsgothianA Offline
      AsgothianA Offline
      Asgothian
      #103
      @Mac_Schmeck
      • Bitte setz das Log in <code> tags - das macht das Log besser lesbar.
      • Bitte poste die folgenden Infos: nodeJS version, NPM version, JS-Controller version
      • Bitte installier erst einmal wieder die 0.10.2 aus dem stable baum - du scheinst die gleichen Fehlermeldungen wie ein anderer Nutzer zu haben - das muss ich mir im Detail anschauen, kann das aber frühestens am Wochenende tun.
      A.
      • AsgothianA Asgothian
        @Mac_Schmeck
        A.
        Mac_Schmeck
        #104
        Bin jetzt wieder auf 0.10.2 zurück und funzt wieder, danke.
        Nodejs ist 10.17
        Npm 6.11.3
        Js Controller 2.1.1
        Ich hoffe ich habe nichts verwechselt.
        @Asgothian said in ZigBee CC253x neue/unbekannte Geräte - ab 0.11.x:
        @Mac_Schmeck
        A.
        • M Mac_Schmeck
          arteckA Offline
          arteckA Offline
          arteck
          #105
          @Mac_Schmeck sagte in ZigBee CC253x neue/unbekannte Geräte - ab 0.11.x:
          @serialport
          da ist der serialport nicht mitgekommen
          machmal folgendes..
          stoppe den adapter
          lösche manuell aus /opt/iobroker/node-modules/@serialport Ordner
          danach installierst du nochmal den adapter vom GIT
          starte den adapter ..
          • arteckA arteck
            @serialport
            machmal folgendes..
            stoppe den adapter
            Mac_Schmeck
            #106
            Kannst du mir schreiben was ich genau eingeben muß zum Löschen?!
            @arteck said in ZigBee CC253x neue/unbekannte Geräte - ab 0.11.x:
            @serialport
            machmal folgendes..
            stoppe den adapter
            • arteckA arteck
              @fabster0815
              @Schrauberheld
              so ist drin aber.. nur im neuen Repo..
              https://forum.iobroker.net/topic/26834/zigbee-adapter-mit-neuem-converter/55
              Sicherung anlegen...
              fabster0815
              #107
              @arteck
              Danke nochmals für die Integration meiner Leuchtmittel 👍
              Hat im zweiten Anlauf geklappt. Der Wechsel auf den neuen Converter war kein Problem. Nur wollte das Leuchtmittel nicht so wie ich
              Das zurücksetzen auf Werkseinstellung führte dann zum Erfolg.... (Vielleicht auch die verbale Zuneigung 😊 )
                daniel_iobroker
                #108
                Ich habe mir heute die tradfi ein/aus schalter gekauft. Habe diese direkt im zigbee adapter anmelden können.
                Es kommt aber leider auch dieses Bild mit einem unbekannten Gerät:
                Diese Meldung erscheint, wenn ich ein der beiden Taster am Schalter drücke:
                (5077) Device ec1bbdfffe9c259d "TRADFRI on/off switch" not described in statesMapping.
                Hab es schon mehrmals versucht, das Gerät zu löschen und neu anzulernen. Einige andere Geräte funktionieren einwandfrei
                • D daniel_iobroker
                  AsgothianA Offline
                  AsgothianA Offline
                  Asgothian
                  #109
                  @daniel_iobroker
                  Bitte poste deine Adapter-Version.
                  Durch den Umstieg auf den Herdsman gibt es Geräte die wir im Adapter 0.11.x nicht mehr integrieren können.
                  A.
                    daniel_iobroker
                    #110
                    @Asgothian
                    wow, die Antwort kam ja schnell.
                    Adapter Version von Zigbee: 0.11.5
                    • D daniel_iobroker
                      @Asgothian
                      AsgothianA Offline
                      AsgothianA Offline
                      Asgothian
                      #111
                      @daniel_iobroker Installier mal bitte die letzte Version von Github, da sollte die FB drin sein.
                      A.
                        daniel_iobroker
                        #112
                        @Asgothian
                        Vielen Dank, das klappt. Mich wundert es nur, dass nach dem installieren der github version, die gleiche version 0.11.5 angezeigt wird.
                        • D daniel_iobroker
                          @Asgothian
                          AsgothianA Offline
                          AsgothianA Offline
                          Asgothian
                          #113
                          @daniel_iobroker
                          Das liegt daran das wir nicht für jedes neue Gerät die Versionsnummer hochzählen.
                            Siegfried
                            Forum Testing
                            #114
                            Neues Gerät :-)
                            https://www.zigbee2mqtt.io/devices/HS1RC-M.html
                            Hoffe sollte alles sein
                            Danke auch für eure tolle Arbeit
                              Desmond
                              #115
                              Hue Smart Button
                              new dev 0x0017880106076299 40447 ROM001
                              Serial 11BOA7
                              Funktion: An/Aus/Dimmen/Farbe/Farbtemperatur
                                Desmond
                                #116
                                Ledvance Smart+ Plug (=Osram Smart Plug)
                                new dev 0xf0d1b8000014b5d1 25726 Plug Z3
                                Serial AC10691
                                Funktion analog Osram Smart Plug (An/Aus)
                                • R Offline
                                  Ramses123
                                  #117
                                  Hallo in die Runde.
                                  Ich habe mir nun auch mal die oben bereits beschriebenen IKEA GU10 WW 400lm besorgt, verzweifel aber am Pairen. Ich bin auf der aktuellen Version 0.11.5.
                                  Beim allerersten Versuch erschien die Kachel sofort, mit richtiger Beschreibung aber ohne Bild. Dann bin ich auf "Speichern und Schließen" gegangen, danach war die Kachel weg und beim Pairen erschien die Lampe nie wieder. Muß ich vielleicht noch irgend einen Speicher wegen dem ersten Teilerfolg mal löschen?
                                    tobiaskowalzil
                                    #118
                                    ich habe Probleme beim Anlegen von optischen Rauchmeldern.
                                    Diese sind von Bitron.
                                    Die Modellnummer ist 902010/24
                                    Der Log ist :zigbee.0 2019-12-15 13:24:27.289 info (9410) new dev 0x00124b0005b29363 36490 902010/24
                                    Von den Funktionen bräuchte ich den Status vom Alarm. Und die Funktion, um den Alarm an- und auszuschalten.
                                    Vielen Dank für die Hilfe im vorraus
                                    • H Offline
                                      Haui74
                                      #119
                                      Moin :)
                                      Das ist ein 4 Kanal RGBW Controller.
                                      Funktion: An/Aus/Dimmen/Farbe/Farbtemperatur.
                                      Vielen Dank und besinnliche Feiertage :)
                                      • H Haui74
                                        Moin :)
                                        AsgothianA Offline
                                        AsgothianA Offline
                                        Asgothian
                                        #120
                                        @Haui74, @tobiaskowalzil , @Siegfried, @Desmond
                                        Welche Version des Adapters setzt ihr ein (Versionsnummer bitte)
                                        Leider ist es so das bis auf den Heimann Controller und den Plug Z3 alle angefragten Geräte bisher nicht im Zigbee-Herdsman-Converter unterstützt werden. Daher bitte Prüfen ob an diesem Projekt bereits ein Issue zur Implementation hinterlegt ist. Wenn nicht, dann bitte einen Issue aufmachen. Ohne die Unterstützung in diesem Projekt können wir die Geräte nur mit sehr hohem Aufwand einbinden.
                                        A.
                                        S T 2 Antworten Letzte Antwort
                                        • H Offline
                                          Haui74
                                          #121
                                          Zigbee Version 0.11.5
                                          Danke für deine Antwort, ich werde mal nach schauen.
                                          LG
