  4. LED Status Display [solved]
monitoringcommunication
30 Beiträge 7 Kommentatoren 8.2k Aufrufe 12 Beobachtet
  • C claus1993
    zu früh gefreut....leider schalten die einzelnen LEDs nicht wie gewünscht.
    Diesen Sketch habe ich auf meinen D1 geladen
    #include <Adafruit_NeoPixel.h>
    #include <ESP8266WiFi.h>
    #include <PubSubClient.h>
    #define PIN D4
    #define NUMPIXELS 16
    const char* ssid = "WIFI";
    const char* password = "Password";
    const char* mqtt_server = "192.xxx.xxx.xxx";
    const int mqtt_port = xxxx;
    const char* mqtt_user = "UserName";
    const char* mqtt_passwd = "Geheim";
    WiFiClient espClient;
    PubSubClient client(espClient);
    Adafruit_NeoPixel pixels = Adafruit_NeoPixel(NUMPIXELS, PIN, NEO_GRB + NEO_KHZ800);
    void setup_wifi() {
    delay(10);
    // We start by connecting to a WiFi network
    Serial.println();
    Serial.print("Connecting to ");
    Serial.println(ssid);
    WiFi.begin(ssid, password);
    while (WiFi.status() != WL_CONNECTED) {
    delay(500);
    Serial.print(".");
    randomSeed(micros());
    Serial.println("");
    Serial.println("WiFi connected");
    Serial.println("IP address: ");
    Serial.println(WiFi.localIP());
    void MQTTCallback(char* topic, byte* payload, unsigned int length) {
    Serial.print("Message arrived [");
    Serial.print(topic);
    Serial.print("] ");
    Serial.println(" ");
    String ColorName = "";
    for (int i = 0; i < length; i++) { ColorName = ColorName + (char)payload[i]; }
    Serial.println(ColorName);
    String TopicName = topic;
    TopicName.replace("LedStatusDisplay/led_","");
    int LedIndex = TopicName.toInt();
    LedIndex = LedIndex - 1;
    if (ColorName.equals("red")) { pixels.setPixelColor(LedIndex, pixels.Color(255,0,0)); }
    if (ColorName.equals("green")) { pixels.setPixelColor(LedIndex, pixels.Color(0,255,0)); }
    if (ColorName.equals("blue")) { pixels.setPixelColor(LedIndex, pixels.Color(0,0,255)); }
    if (ColorName.equals("yellow")) { pixels.setPixelColor(LedIndex, pixels.Color(255,255,0)); }
    if (ColorName.equals("white")) { pixels.setPixelColor(LedIndex, pixels.Color(255,255,255)); }
    if (ColorName.equals("off")) { pixels.setPixelColor(LedIndex, pixels.Color(0,0,0)); }
    pixels.show();
    void reconnect() {
    while (!client.connected()) {
    Serial.print("Attempting MQTT connection...");
    // Create a random client ID
    String clientId = "ESP8266Client-";
    clientId += String(random(0xffff), HEX);
    // Attempt to connect
    if (client.connect(clientId.c_str(), mqtt_user, mqtt_passwd)) {
    Serial.println("connected");
    client.subscribe("LedStatusDisplay/led_01");
    client.subscribe("LedStatusDisplay/led_02");
    client.subscribe("LedStatusDisplay/led_03");
    client.subscribe("LedStatusDisplay/led_04");
    client.subscribe("LedStatusDisplay/led_05");
    client.subscribe("LedStatusDisplay/led_06");
    client.subscribe("LedStatusDisplay/led_07");
    client.subscribe("LedStatusDisplay/led_08");
    client.subscribe("LedStatusDisplay/led_09");
    client.subscribe("LedStatusDisplay/led_10");
    client.subscribe("LedStatusDisplay/led_11");
    client.subscribe("LedStatusDisplay/led_12");
    client.subscribe("LedStatusDisplay/led_13");
    client.subscribe("LedStatusDisplay/led_14");
    client.subscribe("LedStatusDisplay/led_15");
    client.subscribe("LedStatusDisplay/led_16");
    else
    Serial.print("failed, rc=");
    Serial.print(client.state());
    Serial.println(" try again in 5 seconds");
    // Wait 5 seconds before retrying
    delay(5000);
    void setup() {
    pixels.begin(); // Initialisierung der NeoPixel
    pixels.setBrightness(255);
    Serial.begin(115200);
    setup_wifi();
    client.setServer(mqtt_server, mqtt_port);
    client.setCallback(MQTTCallback);
    void loop()
    if (!client.connected())
    reconnect();
    client.loop();
    Die Beiden Skripte habe ich im ioBroker angelegt, wobei ich mir mit dem zweiten Skript nicht ganz sicher bin ob das so korrekt ist;
    Die Funktion wird mittels folgendem Skript direkt bei einer Objektänderung aufgerufen:
    on({id: "hm-rpc.0.OEQ0167091.1.STATE", change: "ne"}, function (obj) { UpdateLEDStatus(); });
    on({id: "hm-rpc.0.NEQ1835804.1.STATE", change: "ne"}, function (obj) { UpdateLEDStatus(); });
    Wenn sich jetzt der Status eines Aktors ändert, sollte direkt der hinterlegte StatusColor-Wert geschrieben werden.
    habe das als zweiten Skript angelegt bin mir jedoch unsicher ob das richtig ist.
    Selbst wenn ich in meinen Datenpunkten (siehe unten) die Farbe direkt rein schreibe bleiben die LEDs aus
    mqtt.0.LedStatusDisplay.led_01
    Einzig die erste LED des Stripes leuchtet...hat das eventuell eine Bedeutung?
    claus1993
    schrieb am zuletzt editiert von claus1993
    Könnte sich bitte jemand mal meinen Skript anschauen was hier falsch ist.
    Wenn ich die Farbe im ioBroker Datenpunkt ändere bekomme ich im Serial Monitor folgende Meldung
    15:46:17.934 -> Message arrived [LedStatusDisplay/led_01]
    15:46:17.934 -> yellow
    die LED leuchtet jedoch nicht.
    Die Verkabelung habe ich mehrfach geprüft und kann hier keine Fehler finden. Insbesondere da die erste LED leuchtet.
    thewhoboxT 1 Antwort Letzte Antwort
    • C claus1993
      thewhoboxT Offline
      thewhoboxT Offline
      thewhobox
      @claus1993 was erwartest du denn dass passiert?
      Laut deinem Skript funktioniert alles wie es soll.
      Du schickst ein Topic mit dem led Index und stellst die eine LED auf die Farbe ein.
      Meine Adapter: emby | discovery
      C 1 Antwort Letzte Antwort
      • thewhoboxT thewhobox
        claus1993
        @thewhobox Danke dir!
        Wenn ich eine Farbe schicke soll die entsprechende LED leuchten. Wie im Beispiel oben soll die led_01 in "yellow" leuchten.
        • C claus1993
          thewhoboxT Offline
          thewhoboxT Offline
          thewhobox
          @claus1993 dann funktioniert es doch?
          Oder was funktioniert Genua nicht?
            claus1993
            @thewhobox Die LEDs leuchten nicht. Nur die erste LED leuchtet dauerhaft weiß.
            • C claus1993
              SBorgS Offline
              SBorgS Offline
              SBorg
              @claus1993 Richtiger Stripe und PIN?
              Was mich etwas wundert, aber ev. ist dass auch ein Unterschied zwischen NodeMCU und Wemos, D4 ist normalerweise die interne LED. Wenn man den benutzen möchte, muss man ihn auch definieren. Das würde auch erklären warum nur die erste LED leuchtet. Füge beim Sketch noch als erstes unter void setup() {... ein pinMode(LED_BUILTIN, OUTPUT); ein, also:
              void setup() {
              LG SBorg ( SBorg auf GitHub)
              • SBorgS SBorg
                void setup() {
                claus1993
                @SBorg Danke dir, hat jedoch leider nicht den Erfolg den ich erhofft hatte.
                Habe den Skript wie oben angepasst und den D1 neu geflasht. Nach dem flaschen leuchteten die ersten 3 LEDs weiß auf. Danach den Reset - USB Stecker raus und wieder rein - und nur noch die erste LED leuchtet weiß.
                Nach dem Abändern der Farben im ioBroker wurde dieses leider an den LEDs nicht angezeigt.
                • C claus1993
                  SBorgS Offline
                  SBorgS Offline
                  SBorg
                  @claus1993 bleibt noch
                  @SBorg sagte in LED Status Display:
                  Ev. könntest du auch mal einen anderen PIN (z.B. D3) probieren und im Sketch ändern.
                  Versorgst du den Stripe direkt über den Wemos mit Spannung? Könnte sein, dass der Wemos das nicht ab kann. Dann würde ich den Stripe mal über ein separates Netzteil versorgen (Minus von diesem Netzteil dann auch mit dem Wemos GND verbinden).
                  • SBorgS SBorg
                    claus1993
                    @SBorg
                    D4 ist auch beim Wemo D1 die interne LED, werde daher mal am Wochenende den Lötkolben anheizen und das ganze auf einen anderen Pin setzen. Werde wohl D1 oder D2 nutzen da dieses wohl keine andere Funktion hat, D1 und D2 werden beschrieben als "Normaler I/O Pin".
                    joergeliJ 1 Antwort Letzte Antwort
                    • C claus1993
                      @SBorg
                      joergeliJ Online
                      joergeliJ Online
                      joergeli
                      schrieb am zuletzt editiert von joergeli
                      @claus1993
                      Ich habe mir auch ein LED-Status-Display mit 32 RGB-LED gebaut, basierend allerdings auf NodeMCU, wobei das auch auf einem WEMOS D1 mini funktionieren sollte.
                      In ioBroker verwende ich folgendes JavaScript:
                      // Stati auf NodeMCU LED-Statusdisplay anzeigen via MQTT
                      var StatusColor = "";
                      var pfad = 'javascript.0.LedStatusDisplay.';
                      //Fenster
                      createState(pfad + 'led_01', { name: 'Büro Jörg', desc: 'Büro Jörg', type: 'string', read: true,  write: true  });
                      createState(pfad + 'led_02', { name: 'Schlafzimmer rechts', desc: 'Schlafzimmer rechts', type: 'string', read: true,  write: true  });
                      createState(pfad + 'led_03', { name: 'Schlafzimmer links', desc: 'Schlafzimmer links', type: 'string', read: true,  write: true  });
                      createState(pfad + 'led_04', { name: 'Bad OG', desc: 'Bad OG', type: 'string', read: true,  write: true  });
                      createState(pfad + 'led_05', { name: 'Büro Renate', desc: 'Büro Renate', type: 'string', read: true,  write: true  });
                      createState(pfad + 'led_06', { name: 'Balkontür', desc: 'Balkontür', type: 'string', read: true,  write: true  });
                      createState(pfad + 'led_07', { name: 'Essecke', desc: 'Essecke', type: 'string', read: true,  write: true  });
                      createState(pfad + 'led_08', { name: 'Küche Garten', desc: 'Küche Garten', type: 'string', read: true,  write: true  });
                      createState(pfad + 'led_09', { name: 'Küche Strasse', desc: 'Küche Strasse', type: 'string', read: true,  write: true  });
                      createState(pfad + 'led_10', { name: 'Haustür', desc: 'Haustür', type: 'string', read: true,  write: true  });
                      createState(pfad + 'led_11', { name: 'Gästebad EG', desc: 'Gästebad EG', type: 'string', read: true,  write: true  });
                      createState(pfad + 'led_12', { name: 'Terrassentür', desc: 'Terrassentür', type: 'string', read: true,  write: true  });
                      createState(pfad + 'led_13', { name: 'Keller rechts', desc: 'Keller rechts', type: 'string', read: true,  write: true  });
                      createState(pfad + 'led_14', { name: 'Keller links', desc: 'Keller rechts', type: 'string', read: true,  write: true  });
                      createState(pfad + 'led_15', { name: 'Waschküche', desc: 'Waschküche', type: 'string', read: true,  write: true  });
                      createState(pfad + 'led_16', { name: 'Bad UG', desc: 'Bad UG', type: 'string', read: true,  write: true  });
                      //Heizung
                      createState(pfad + 'led_17', { name: 'Hzg Bad OG', desc: 'Hzg Bad OG', type: 'string', read: true,  write: true  });
                      createState(pfad + 'led_18', { name: 'Hzg Küche', desc: 'Hzg Küche', type: 'string', read: true,  write: true  });
                      createState(pfad + 'led_19', { name: 'Hzg Essecke', desc: 'Hzg Essecke', type: 'string', read: true,  write: true  });
                      createState(pfad + 'led_20', { name: 'Hzg Couch', desc: 'Hzg Couch', type: 'string', read: true,  write: true  });
                      createState(pfad + 'led_21', { name: 'Hzg Regal', desc: 'Hzg Regal', type: 'string', read: true,  write: true  });
                      //PCs
                      createState(pfad + 'led_22', { name: 'SPY Computer', desc: 'SPY Computer', type: 'string', read: true,  write: true  });
                      createState(pfad + 'led_23', { name: 'Wetter Computer', desc: 'Wetter Computer', type: 'string', read: true,  write: true  });
                      createState(pfad + 'led_24', { name: 'Batterie Stati', desc: 'Batterie Stati', type: 'string', read: true,  write: true  });
                      //Muell und Sonstiges
                      createState(pfad + 'led_25', { name: 'Gelber Sack', desc: 'Gelber Sack', type: 'string', read: true,  write: true  });
                      createState(pfad + 'led_26', { name: 'Papiertonne', desc: 'Papiertonne', type: 'string', read: true,  write: true  });
                      createState(pfad + 'led_27', { name: 'Restmüll', desc: 'Restmüll', type: 'string', read: true,  write: true  });
                      createState(pfad + 'led_28', { name: 'Biotonne', desc: 'Biotonne', type: 'string', read: true,  write: true  });
                      createState(pfad + 'led_29', { name: 'Post ist da', desc: 'Post ist da', type: 'string', read: true,  write: true  });
                      createState(pfad + 'led_30', { name: 'Waschmaschine läuft', desc: 'Waschmaschine läuft', type: 'string', read: true,  write: true  });
                      createState(pfad + 'led_31', { name: 'Badezimmer besetzt', desc: 'Badezimmer besetzt', type: 'string', read: true,  write: true  });
                      createState(pfad + 'led_32', { name: 'DutyCycle > 50%', desc: 'DutyCycle > 50%', type: 'string', read: true,  write: true  });
                      const buero_joerg           = 'hm-rpc.0.OEQ0964559.1.STATE';
                      const schlafzimmer_rechts   = 'hm-rpc.1.00109709B13900.1.STATE';
                      const schlafzimmer_links    = 'hm-rpc.1.00109709B139C4.1.STATE';
                      const bad_og                = 'hm-rpc.0.OEQ1425279.1.STATE';
                      const buero_renate          = 'hm-rpc.0.OEQ1432688.1.STATE';
                      const balkontuer            = 'hm-rpc.1.00109709B13C79.1.STATE';
                      const essecke               = 'hm-rpc.1.00109709B13B6E.1.STATE';
                      const kueche_garten         = 'hm-rpc.1.00109709B136CD.1.STATE';
                      const kueche_strasse        = 'hm-rpc.1.00109709B139F6.1.STATE';
                      const haustuer              = 'hm-rpc.0.NEQ0682554.1.STATE';
                      const bad_eg                = 'hm-rpc.1.00109709B13901.1.STATE';
                      const terrassen_tuer        = 'hm-rpc.1.00109709B13937.1.STATE';
                      const keller_rechts         = 'hm-rpc.1.00109709B13999.1.STATE';
                      const keller_links          = 'hm-rpc.1.00109709B139D3.1.STATE';
                      const waschkueche           = 'hm-rpc.0.OEQ1425263.1.STATE';
                      const bad_ug                = 'hm-rpc.0.OEQ1425267.1.STATE';
                      const hzg_bad_og            = 'javascript.0.Heizung-Bad-OG.an-aus';
                      const hzg_kueche            = 'javascript.0.FS20.Hzg-Kueche';
                      const hzg_essecke           = 'javascript.0.FS20.Hzg-Essecke';
                      const hzg_couch             = 'javascript.0.FS20.Hzg-Couch';
                      const hzg_regal             = 'javascript.0.FS20.Hzg-Regal';
                      const pc_spy                = 'javascript.0.ping.PC Spy';
                      const pc_wetter             = 'javascript.0.ping.PC Wetter';
                      const batterie_stati        = 'javascript.0.zählenLowbat.anzahlLOWBAT';
                      const gelber_sack           = 'ical.1.events.1.GelberSack';
                      const papier_tonne          = 'ical.1.events.1.Papier';
                      const rest_muell            = 'ical.1.events.1.Restmüll';
                      const bio_tonne             = 'ical.1.events.1.Biomüll';
                      const post_ist_da           = 'hm-rega.0.15463';
                      const waschmaschine_laeuft  = 'hm-rega.0.11165';
                      const dutycycle             = 'hm-rega.0.1238' ;
                      on({id: [
                      buero_joerg, schlafzimmer_rechts, schlafzimmer_links, bad_og, buero_renate, balkontuer, essecke, kueche_garten,
                      kueche_strasse, haustuer, bad_eg, terrassen_tuer, keller_rechts, keller_links, waschkueche, bad_ug,
                      hzg_bad_og, hzg_kueche, hzg_essecke, hzg_couch, hzg_regal, pc_spy, pc_wetter, batterie_stati,
                      gelber_sack, papier_tonne, rest_muell, bio_tonne, post_ist_da, waschmaschine_laeuft, dutycycle
                      ], change: "ne"} , function (obj) {
                      UpdateLEDStatus();
                      //_________________________________________________________________
                      function UpdateLEDStatus(){
                      //Fenster Büro Jörg
                      if ( getState(buero_joerg).val == 0 ) { StatusColor = "off";  setState(pfad + 'led_01', StatusColor ) } // closed = 0
                      else if ( getState(buero_joerg).val == 1 ) { StatusColor = "yellow";  setState(pfad + 'led_01', StatusColor ) } //gekippt = 1
                      else if ( getState(buero_joerg).val == 2 ) { StatusColor = "red";  setState(pfad + 'led_01', StatusColor ) } //open = 2
                      //Fenster Schlafzimmer rechts
                      if ( getState(schlafzimmer_rechts).val == 0 ) { StatusColor = "off";  setState(pfad + 'led_02', StatusColor ) } // closed = 0
                      else if ( getState(schlafzimmer_rechts).val == 1 ) { StatusColor = "red";  setState(pfad + 'led_02', StatusColor ) } //offen = 1
                      //Fenster Schlafzimmer links
                      if ( getState(schlafzimmer_links).val == 0 ) { StatusColor = "off";  setState(pfad + 'led_03', StatusColor ) } // closed = 0
                      else if ( getState(schlafzimmer_links).val == 1 ) { StatusColor = "red";  setState(pfad + 'led_03', StatusColor ) } //offen = 1
                      //Fenster Bad OG
                      if ( getState(bad_og).val == 0 ) { StatusColor = "off";  setState(pfad + 'led_04', StatusColor ) } // closed = 0
                      else if ( getState(bad_og).val == 1 ) { StatusColor = "red";  setState(pfad + 'led_04', StatusColor ) } //offen = 1
                      //Büro Renate
                      if ( getState(buero_renate).val == 0 ) { StatusColor = "off";  setState(pfad + 'led_05', StatusColor ) } // closed = 0
                      else if ( getState(buero_renate).val == 1 ) { StatusColor = "red";  setState(pfad + 'led_05', StatusColor ) } //offen = 1
                      //Balkontür
                      if ( getState(balkontuer).val == 0 ) { StatusColor = "off";  setState(pfad + 'led_06', StatusColor ) } // closed = 0
                      else if ( getState(balkontuer).val == 1 ) { StatusColor = "tuerkis";  setState(pfad + 'led_06', StatusColor ) } //offen = 1
                      //Fenster Essecke
                      if ( getState(essecke).val == 0 ) { StatusColor = "off";  setState(pfad + 'led_07', StatusColor ) } // closed = 0
                      else if ( getState(essecke).val == 1 ) { StatusColor = "red";  setState(pfad + 'led_07', StatusColor ) } //offen = 1
                      //Küchenfenster Garten
                      if ( getState(kueche_garten).val == 0 ) { StatusColor = "off";  setState(pfad + 'led_08', StatusColor ) } // closed = 0
                      else if ( getState(kueche_garten).val == 1 ) { StatusColor = "red";  setState(pfad + 'led_08', StatusColor ) } //offen = 1
                      //Küchenfenster Strasse
                      if ( getState(kueche_strasse).val == 0 ) { StatusColor = "off";  setState(pfad + 'led_09', StatusColor ) } // closed = 0
                      else if ( getState(kueche_strasse).val == 1 ) { StatusColor = "red";  setState(pfad + 'led_09', StatusColor ) } //offen = 1
                      //Haustür
                      if ( getState(haustuer).val == 0 ) { StatusColor = "off";  setState(pfad + 'led_10', StatusColor ) } // closed = false
                      else if ( getState(haustuer).val == 1 ) { StatusColor = "tuerkis";  setState(pfad + 'led_10', StatusColor ) } //offen = true
                      //Fenster Gästebad EG
                      if ( getState(bad_eg).val == 0 ) { StatusColor = "off";  setState(pfad + 'led_11', StatusColor ) } // closed = 0
                      else if ( getState(bad_eg).val == 1 ) { StatusColor = "red";  setState(pfad + 'led_11', StatusColor ) } //offen = 1
                      //Terrassentür
                      if ( getState(terrassen_tuer).val == 0 ) { StatusColor = "off";  setState(pfad + 'led_12', StatusColor ) } // closed = 0
                      else if ( getState(terrassen_tuer).val == 1 ) { StatusColor = "tuerkis";  setState(pfad + 'led_12', StatusColor ) } //offen = 1
                      //Kellerfenster rechts
                      if ( getState(keller_rechts).val == 0 ) { StatusColor = "off";  setState(pfad + 'led_13', StatusColor ) } // closed = 0
                      else if ( getState(keller_rechts).val == 1 ) { StatusColor = "red";  setState(pfad + 'led_13', StatusColor ) } //offen = 1
                      //Kellerfenster links
                      if ( getState(keller_links).val == 0 ) { StatusColor = "off";  setState(pfad + 'led_14', StatusColor ) } // closed = 0
                      else if ( getState(keller_links).val == 1 ) { StatusColor = "red";  setState(pfad + 'led_14', StatusColor ) } //offen = 1
                      //Fenster Waschküche
                      if ( getState(waschkueche).val == 0 ) { StatusColor = "off";  setState(pfad + 'led_15', StatusColor ) } // closed = 0
                      else if ( getState(waschkueche).val == 1 ) { StatusColor = "red";  setState(pfad + 'led_15', StatusColor ) } //offen = 1
                      //Fenster Gästebad UG
                      if ( getState(bad_ug).val == 0 ) { StatusColor = "off";  setState(pfad + 'led_16', StatusColor ) } // closed = 0
                      else if ( getState(bad_ug).val == 1 ) { StatusColor = "red";  setState(pfad + 'led_16', StatusColor ) } //offen = 1
                      //Heizung Bad OG
                      if ( getState(hzg_bad_og).val == 0 ) { StatusColor = "off";  setState(pfad + 'led_17', StatusColor ) } // closed = 0
                      else if ( getState(hzg_bad_og).val == 1 ) { StatusColor = "orange";  setState(pfad + 'led_17', StatusColor ) } //offen = 1
                      //Heizung Küche
                      if ( getState(hzg_kueche).val == 0 ) { StatusColor = "off";  setState(pfad + 'led_18', StatusColor ) } // closed = 0
                      else if ( getState(hzg_kueche).val == 1 ) { StatusColor = "orange";  setState(pfad + 'led_18', StatusColor ) } //offen = 1
                      //Heizung Essecke
                      if ( getState(hzg_essecke).val == 0 ) { StatusColor = "off";  setState(pfad + 'led_19', StatusColor ) } // closed = 0
                      else if ( getState(hzg_essecke).val == 1 ) { StatusColor = "orange";  setState(pfad + 'led_19', StatusColor ) } //offen = 1
                      //Heizung Couch
                      if ( getState(hzg_couch).val == 0 ) { StatusColor = "off";  setState(pfad + 'led_20', StatusColor ) } // closed = 0
                      else if ( getState(hzg_couch).val == 1 ) { StatusColor = "orange";  setState(pfad + 'led_20', StatusColor ) } //offen = 1
                      //Heizung Regal
                      if ( getState(hzg_regal).val == 0 ) { StatusColor = "off";  setState(pfad + 'led_21', StatusColor ) } // closed = 0
                      else if ( getState(hzg_regal).val == 1 ) { StatusColor = "orange";  setState(pfad + 'led_21', StatusColor ) } //offen = 1
                      //PC SPY
                      if ( getState(pc_spy).val == 0 ) { StatusColor = "off";  setState(pfad + 'led_22', StatusColor ) } // aus = 0
                      else if ( getState(pc_spy).val == 1 ) { StatusColor = "green";  setState(pfad + 'led_22', StatusColor ) } //ein = 1
                      //PC Wetter
                      if ( getState(pc_wetter).val == 0 ) { StatusColor = "off";  setState(pfad + 'led_23', StatusColor ) } // aus = 0
                      else if ( getState(pc_wetter).val == 1 ) { StatusColor = "green";  setState(pfad + 'led_23', StatusColor ) } //ein = 1
                      //Batterie-Stati
                      if ( getState(batterie_stati).val == 0 ) { StatusColor = "off";  setState(pfad + 'led_24', StatusColor ) } // alles OK
                      else if ( getState(batterie_stati).val > 0 ) { StatusColor = "red";  setState(pfad + 'led_24', StatusColor ) } //mindestens 1 Batterie leer
                      //Morgen Gelber Sack
                      if ( getState(gelber_sack).val == 0 ) { StatusColor = "off";  setState(pfad + 'led_25', StatusColor ) }
                      else if ( getState(gelber_sack).val == 1 ) { StatusColor = "yellow";  setState(pfad + 'led_25', StatusColor ) }
                      //Morgen Papiertonne
                      if ( getState(papier_tonne).val == 0 ) { StatusColor = "off";  setState(pfad + 'led_26', StatusColor ) }
                      else if ( getState(papier_tonne).val == 1 ) { StatusColor = "blue";  setState(pfad + 'led_26', StatusColor ) }
                      //Morgen Restmüll
                      if ( getState(rest_muell).val == 0 ) { StatusColor = "off";  setState(pfad + 'led_27', StatusColor ) }
                      else if ( getState(rest_muell).val == 1 ) { StatusColor = "white";  setState(pfad + 'led_27', StatusColor ) }
                      //Morgen Bio-Abfall
                      if ( getState(bio_tonne).val == 0 ) { StatusColor = "off";  setState(pfad + 'led_28', StatusColor ) }
                      else if ( getState(bio_tonne).val == 1 ) { StatusColor = "violet";  setState(pfad + 'led_28', StatusColor ) }
                      //Post ist da
                      if ( getState(post_ist_da).val == 0 ) { StatusColor = "off";  setState(pfad + 'led_29', StatusColor ) }
                      else if ( getState(post_ist_da).val == 1 ) { StatusColor = "yellow";  setState(pfad + 'led_29', StatusColor ) }
                      //Waschmaschine läuft
                      if ( getState(waschmaschine_laeuft).val == 0 ) { StatusColor = "off";  setState(pfad + 'led_30', StatusColor ) }
                      else if ( getState(waschmaschine_laeuft).val == 1 ) { StatusColor = "orange";  setState(pfad + 'led_30', StatusColor ) }
                      //Badezimmer besetzt // deaktiviert, da dieser Datenpunkt von einem anderen Script gesetzt wird
                      //if ( getState(badezimmer_besetzt).val == 0 ) { StatusColor = "green";  setState(pfad + 'led_31', StatusColor ) }
                      //else if ( getState(badezimmer_besetzt).val == 1 ) { StatusColor = "red";  setState(pfad + 'led_31', StatusColor ) }
                      //DutyCycle > 50%
                      if ( getState(dutycycle).val < 50 ) { StatusColor = "off";  setState(pfad + 'led_32', StatusColor ) }
                      else if ( getState(dutycycle).val >= 50 ) { StatusColor = "violet";  setState(pfad + 'led_32', StatusColor ) }
                      }; // end of function UpdateLEDStatus
                      Dieser Sketch legt zuerst 32 Datenpunkte (Typ Zeichenkette) unterhalb von javascript.0.LedStatusDisplay an.
                      Das wären dann: led_01 bis led_32.
                      Dann werden permanent die einzelnen Aktoren auf Änderungen überwacht ( on({id: ....... )
                      Falls einer der Aktoren seinen Status ändert, wird der entspr. Datenpunkt (z.B. javascript.0.LedStatusDisplay.led_04) mit der entspr. Farbe gesetzt ( if ( getState .....)
                      Du müsstest bei Dir die Anzahl der Datenpunkte auf 16 reduzieren
                      Das LED-Display habe ich mit einem, gegenüber dem Original-Sketch, leicht abgeändertem Sketch geflashed:
                      ioBroker Stati auf LED-Statusdisplay anzeigen via MQTT
                      siehe: https://www.smarthome-tricks.de/software-iobroker/iobroker-led-status-display-prototyp/
                      Hardware: NodeMCU V3
                      modified by joergeli V 1.0 19.11.2019
                      Compiled with Arduino IDE V1.8.10
                      #include <ArduinoOTA.h>   // fuer Flashen ueber WLAN ( OTA = Over The Air)
                      #define PIN D2          // Daten-PIN fuer den WS2812-LED-Stripe, hier: D2
                      #define intLED D4       // interne, blaue LED
                      #define NUMPIXELS 32    // Anzahl vorhandener LEDs
                      // LDR fuer Helligkeits-Steuerung, ---> // ### wenn gewuenscht,  die 2 Folgezeilen aktivieren
                      //const int sensorPin = A0; // PIN analog 0 zum LDR
                      //int sensorValue = 0;      // Initialisiere LDR-Wert
                      // Hier die eigenen Netzwerk-Parameter eintragen !!!
                      IPAddress ip(192, 168, 192, 58);      //### statische ip-addresse
                      IPAddress gateway(192, 168, 192, 99); //### router
                      IPAddress subnet(255, 255, 255, 0);   //### subnet-mask
                      IPAddress dns(192, 168, 192, 99);     //### dns-server, ist meist identisch mit IP-Adresse des routers
                      const char* ssid  = "xxxxxxxx";       //### WLAN SSID
                      const char* pwd   = "xxxxxxxx";       //### WLAN Password
                      const char* mqtt_server = "192.168.192.29";   //### MQTT-Adapter in ioBroker, bzw. IP-Adresse des ioBrokers
                      int mqtt_port           = 1891;   //### MQTT-Port in ioBroker
                      const char* topic       = "javascript/0/LedStatusDisplay/#" ;   // alle Topics unterhalb von  javascript/0/LedStatusDisplay/  subscriben
                      const char* OTA_host = "LED Status-Display";  // Name unter welchem der virtuelle Port in der Arduino-IDE auftaucht
                      //_________________________________________________________________________________________
                      // Subroutine fuer WLAN-Verbindung
                      void setup_wifi(){
                        WiFi.config(ip, gateway, subnet, dns);
                        delay(100);
                        WiFi.mode(WIFI_STA);
                        WiFi.begin(ssid, pwd);
                        Serial.println("");
                        Serial.println("___________________________________________________");
                        Serial.print("Connecting to "); Serial.println(ssid);
                          uint32_t high = pixels.Color(0, 0, 255);  // So lange WLAN nicht verbunden ist, alle LEDs auf Blau
                          for( int i = 0; i<NUMPIXELS; i++){
                              pixels.setPixelColor(i, high);
                              pixels.show();
                            Serial.print(".");
                            delay(300);
                        Serial.println("");
                        Serial.print("   OK  ---> ");
                        Serial.print("IP: ");
                        uint32_t low = pixels.Color(0, 0, 0);   // Wenn WLAN verbunden, alle LEDs aus
                            pixels.setPixelColor(i, low);
                            pixels.show();
                      } // end of connectWIFI
                      Serial.print("] ");
                      Serial.print(" Color: ");
                      Serial.print(ColorName);
                      TopicName.replace("javascript/0/LedStatusDisplay/led_","");
                      //Serial.print("  LedIndex: ");
                      //Serial.println(LedIndex);
                      Serial.println("");
                      if (ColorName.equals("red"))     { pixels.setPixelColor(LedIndex, pixels.Color(255,0,0));}
                      if (ColorName.equals("green"))   { pixels.setPixelColor(LedIndex, pixels.Color(0,255,0));}
                      if (ColorName.equals("blue"))    { pixels.setPixelColor(LedIndex, pixels.Color(0,0,255));}
                      if (ColorName.equals("tuerkis")) { pixels.setPixelColor(LedIndex, pixels.Color(0,255,255));}
                      if (ColorName.equals("violet"))  { pixels.setPixelColor(LedIndex, pixels.Color(255,0,255));}
                      if (ColorName.equals("yellow"))  { pixels.setPixelColor(LedIndex, pixels.Color(255,255,0));}
                      if (ColorName.equals("orange"))  { pixels.setPixelColor(LedIndex, pixels.Color(255,127,0));}
                      if (ColorName.equals("white"))   { pixels.setPixelColor(LedIndex, pixels.Color(255,255,255));}
                      if (ColorName.equals("off"))     { pixels.setPixelColor(LedIndex, pixels.Color(0,0,0));}
                      pixels.show();
                      void reconnect() {
                          uint32_t kein_mqtt = pixels.Color(255, 255, 0);  // ### So lange MQTT nicht verbunden, alle LEDs auf Gelb
                          pixels.setBrightness(20);
                              pixels.setPixelColor(i, kein_mqtt);
                              pixels.show();
                      // Create client ID
                      String clientId = "NodeMCU-";
                      clientId += String("LED-Status-Display");
                      if (client.connect(clientId.c_str())) {
                        uint32_t mqtt_ok = pixels.Color(0, 0, 0);   // ### Wenn WLAN verbunden, alle LEDs aus
                            pixels.setPixelColor(i, mqtt_ok);
                            pixels.show();
                      client.subscribe(topic); // alle Topics unter javascript/0/LedStatusDisplay/  subscriben
                      else{
                      delay(5000);
                      } // end of else
                      } // end of while
                      } // end of void reconnect
                      void setup() {
                      //  pinMode(sensorPin, INPUT);  // LDR ---> ### wenn gewuenscht, aktivieren
                        pinMode(intLED, OUTPUT);    // interne blaue Board-LED
                        digitalWrite(intLED, HIGH); //off ---> interne blaue Board-LED ausschalten ( HIGH an PIN D4!)
                      pixels.setBrightness(10);
                      pixels.show();  // alle LEDs aus
                      setup_wifi();
                      client.setServer(mqtt_server, mqtt_port);  // mqtt.0 auf Port 1891 in ioBroker
                      ArduinoOTA.setHostname(OTA_host);   // fuer Flashen ueber WLAN
                      ArduinoOTA.begin();                 // fuer Flashen ueber WLAN
                      void loop(){
                        ArduinoOTA.handle();  //fuer Flashen ueber WLAN
                       // Helligkeits-Steuerung - ### wenn gewuenscht, alle Folgezeilen incl. delay(10) aktivieren
                       // sensorValue = analogRead(sensorPin);
                       // sensorValue = map(sensorValue, 0, 1023, 1, 30);	//--> Max Helligkeit ist hier 30
                       // if (sensorValue <=5){ sensorValue = 1; }			// --> Min Helligkeit ist hier 1
                       // pixels.setBrightness(sensorValue);
                       // pixels.show();
                        ////Serial.println(sensorValue);
                       // delay(10); // wichtig: nicht entfernen!
                      if (!client.connected()) { reconnect(); }
                      client.loop();
                      } // end of loop
                      Was gibt es im Sketch zu beachten:
                      1.) Ich bin ein Freund statischer IP-Adressen, also musst Du alle Netzwerkparameter auf Dein (W)LAN anpassen.
                      2.) Daten-PIN fuer die NEOPIXEL habe ich auf D2 gelegt.
                      3.) Anzahl der vorhandenen LEDs muß bei Dir auf 16 geändert werden ( #define NUMPIXELS 16 )
                      4.) MQTT-Port des mqtt-Adapters habe ich verändert, da bei mir auf dem Raspi noch ein Mosquitto läuft (aber das hast Du ja auch schon bei Dir entspr.geändert)
                      4. Der Topic muss auf "javascript/0/LedStatusDisplay/#" gesetzt werden.
                      Wichtig ist das #-Zeichen am Ende, da dann alles unterhalb von javascript/0/LedStatusDisplay/ subscribed wird.
                      5.) Ich verwende auf dem MQTT kein Passwort, musst Du also bei Dir - wie von Lenny.CB oben beschrieben - anpassen.
                      Meine Änderungen gegenüber dem Original:
                      1.) Die boardinterne blaue LED an D4 schalte ich nach dem Boot ab (brauche ich nicht).
                      2.) OTA ( = Flashen over the air) eingebaut. Damit kann man ggf. über WLAN neu flashen und braucht das LED-Display nicht über USB zu flashen. ( das erstmalige Flashen muss aber zwingend über USB gemacht werden).
                      3.) Solange das WLAN noch nicht verbunden ist, leuchten alle LEDs blau.
                      4.) Solange noch keine MQTT-Verbindung besteht, leuchten alle LEDs gelb.
                      5.) Wenn gewünscht, kann auch eine Helligkeits-Steuerung mit einem LDR (Photowiderstand) realisiert werden.
                      Der LDR wird zwischen 3V3 und A0 (analoger Eingang) angeschlossen.
                      Zusätzlich muß noch ein 10 KΩ-Widersatand von A0 nach Masse gelötet werden.
                      Im Sketch müssen anschl. alle!! Variablen bzgl. Helligkeits-Steuerung ( sensorPin, sensorValue) aktiviert werden,
                      d.h entfernen der 2 Slashes (//) am Anfang der jweiligen Zeile.
                      Prüfe bei Dir bitte, was der serielle Monitor der Arduino-IDE ausgibt.
                      Es sollte nach dem Boot so ähnlich aussehen:
                      Zuerst wird angezeigt, daß das WLAN verbunden ist.
                      Dann wird MQTT-Verbindung zum mqtt-Adapter hergestellt.
                      Anschließend werden alle 32 (bzw. 16) States empfangen.
                      Nach dem Ändern eines Aktors, bzw. States, sollte dann auch die entspr. "Message arrived [javascript/0/LedStatusDisplay/led_12] Color: off" im seriellen Monitor angezeigt werden.
                      Wenn Du mit der Maus über den (hoffentlich) grünen Punkt der mqqt-Instanz fährst, sollte da dann auch stehen " Verbunden mit mqqt: NodeMCU-LED-Status-Display"
                      Ggf. die mqtt-Instanz mal neu starten.
                      Ich hoffe, daß Du mit meinen Erläuterungen Dein Display zum Laufen bekommst.
                      Jörg
                      P.S.
                      Anbei noch 2 Fotos von meinem Display, eingebaut in einem 13cm x 18cm Bilderrahmen:
                      Verwendet habe ich diese "8fach RGB-LED-Sticks" (bei RGB-LED-Stripes sind die Abstände zwischen den einzelnen LEDs zu groß und es hätte nicht in den Bilderrahmen gepasst)
                      G 1 Antwort Letzte Antwort
                      • C Offline
                        claus1993
                        Kleines Update, erfreuliches Update….zumindest teilweise.
                        Habe die Datenleitung von D4 auf D1 gewechselt was im ersten Schritt keinen Erfolg hatte. Danach habe ich noch den Sketch angepasst was die Pin Benennung angeht.
                        "#define PIN D1" habe ich geändert in "#define PIN 5"
                        Jetzt leuchten bei mir alle LEDs bis auf die im letzten Modul. Hier werde ich den Lötkolben nochmal ansetzen und ggf das Modul austauschen.
                        • C claus1993
                          joergeliJ Online
                          joergeliJ Online
                          joergeli
                          @claus1993
                          D1 = GPIO5
                          sollte eigentlich beides funktionieren
                          • C Offline
                            claus1993
                            @joergeli & @SBorg
                            Danke für eure Unterstützung...ohne euch hätte ich aufgegeben und so leuchten nun alle LEDs in den gewünschten Farben.
                            @joergeli
                            das mit dem OTA finde ich cool...werde ich mir mal etwas näher ansehen.
                            • C claus1993
                              @joergeli & @SBorg
                              @joergeli
                              joergeliJ Online
                              joergeliJ Online
                              joergeli
                              @claus1993
                              OTA integrieren ist nicht weiter problematisch, sind insgesamt nur 5 Einträge:
                              1.) OTA-Library einbinden (muss natürlich im library-Ordner vorhanden sein)
                              2.) "OTA-Namen" nach eigenem Gusto vergeben:
                              3.) Im setup-Abschnitt OTA starten:
                              4.) Im loop-Abschnitt OTA zyklisch abfragen:
                              OTA ist ganz praktisch für Geräte, welche an unzugänglichen, oder schwer erreichbaren Standorten verbaut sind und man sie dehalb nur schwer per USB mit der Arduino-IDE verbinden kann, um sie neu zu flashen.
                              Freut mich, daß Dein Display jetzt funktioniert.
                              Jörg
                              • joergeliJ joergeli
                                @claus1993
                                //Fenster
                                //Heizung
                                //PCs
                                on({id: [
                                UpdateLEDStatus();
                                //Fenster Büro Jörg
                                //Fenster Bad OG
                                //Büro Renate
                                //Balkontür
                                //Fenster Essecke
                                //Haustür
                                //Terrassentür
                                //Heizung Bad OG
                                //Heizung Küche
                                //Heizung Essecke
                                //Heizung Couch
                                //Heizung Regal
                                //PC SPY
                                //PC Wetter
                                //Batterie-Stati
                                //Morgen Restmüll
                                //Morgen Bio-Abfall
                                //Post ist da
                                //DutyCycle > 50%
                                void setup_wifi(){
                                  delay(100);
                                  Serial.println("");
                                        pixels.show();
                                      Serial.print(".");
                                      delay(300);
                                  Serial.println("");
                                      pixels.show();
                                Serial.print("] ");
                                Serial.println("");
                                pixels.show();
                                void reconnect() {
                                        pixels.show();
                                // Create client ID
                                      pixels.show();
                                else{
                                delay(5000);
                                } // end of else
                                } // end of while
                                void setup() {
                                setup_wifi();
                                void loop(){
                                 // pixels.show();
                                client.loop();
                                } // end of loop
                                Jörg
                                P.S.
                                Gwenselah
                                @joergeli said in LED Status Display [solved]:
                                Welches meinst Du mit Original Sketch?
                                • G Gwenselah
                                  joergeliJ Online
                                  joergeliJ Online
                                  joergeli
                                  @Gwenselah
                                  Den im ersten Post verlinkten:
                                  • Rene55R Offline
                                    Rene55R Offline
                                    Rene55
                                    @joergeli
                                    Das ist, was ich schon länger gesucht habe. Danke dafür.
                                    Hab es soweit nachgebaut. Ich habe aber ein Problem mit dem MQTT. Es ist doch nicht das gleiche ob ich das 0_userdata/0/LedStatusDisplay/#oder das 0_userdata.0.LedStatusDisplay/# in mein Script für den esp schreibe. Oder funktioniert das nur mit dem ioBroker internen MQTT? Ich habe einen separaten MQTT-Server.
                                    Dazu die zweite Frage: Wenn der Datenpunkt mit der richtigen Farbe gefüllt ist, wie wird das dann gepublisht?
                                    LG Rainer
                                    • Rene55R Rene55
                                      @joergeli
                                      LG Rainer
                                      joergeliJ Online
                                      joergeliJ Online
                                      joergeli
                                      @Rene55
                                      Moin,
                                      ich verwende den ioBroker MQTT-Adapter als Server/broker:
                                      mit folgenden Einstellungen:
                                      Ich gebe dort als Maske für Bekanntgeben von eigenen States folgendes vor: mqtt.0.*,javascript.*.
                                      Also alles, was sich unter mqtt.0 und javascript befindet (alles, weil ich auch noch andere Ojekte unter javascript für andere MQTT-Sachen verwende).
                                      Meine LED-Objekte liegen unter javascript.0.LedStatusDisplay.
                                      ( Den Ordner 0_userdata gab es zum damaligen Stand seitens ioBroker noch nicht und ich war bisher zu faul zum Umstellen 😊 )
                                      Beachte bitte, daß im Arduino-Sketch der Topic-Name zwei Mal vorkommt:
                                      1.) In der Subroutine
                                      2.) und in der Subroutine
                                      void reconnect() {
                                      client.subscribe("javascript/0/LedStatusDisplay/#"); // alle subscriben
                                      Ich weiß leider nicht, ob das genau so mit einem externen MQTT-Broker funktioniert.
                                      Ich würde vorschlagen, Du installierst - testweise - das Ganze so, wie in meinen Einstellungen/Datenpunkten/Java-Script und schaust dann, ob es so funktioniert.
                                      Wenn es so funktioniert, kannst Du versuchen, wenn gewünscht, Zug um Zug auf Deinen externen MQTT-Broker umzustellen.
                                      Das macht bei mir der ioBroker-MQTT-Adapter gem. seiner Einstellung: "Publish nur bei Änderung".
                                      Also wenn sich der Status eines LED-Datenpunktes, bzw. seine Farbe ändert, wird automatisch gepublished.
                                      Bitte berichte.
                                      Jörg
                                      • Rene55R Offline
                                        Rene55R Offline
                                        Rene55
                                        @joergeli
                                        Danke für die schnelle und vor allem ausführliche Antwort. Das esp-Script läuft ja einwandfrei wenn ich es direkt mit MQTT.fx antriggere.
                                        Ich habe zwischenzeitlich weitergebastelt und das Script im ioBroker mal für einen Fensterkontakt auf meine Bedingungen (externer MQTT-Server) angepasst.
                                        on({id: "hm-rpc.0.NEQ1682288.1.STATE"/*at_links.STATE*/, change: "ne"}, function (obj) {
                                          var value = obj.state.val;
                                          if (value) {
                                            statusColor = 'red';
                                          } else {
                                            statusColor = 'green';
                                          sendTo('mqtt.0', 'sendMessage2Client', {topic: 'LedStatusDisplay/led_03', message: statusColor});
                                        Hier brauche ich gar keine besonderen Datenpunkte. Ob das so sinnvoll ist, lass ich mal als Frage stehen.
                                        LG Rainer
                                        • Rene55R Rene55
                                          @joergeli
                                            if (value) {
                                            } else {
                                          LG Rainer
                                          joergeliJ Online
                                          joergeliJ Online
                                          joergeli
                                          @Rene55
                                          Naja, ich habe mir der Übersichtlichkeit halber eigene Datenpunkte nur für die LED-Zustände angelegt.
                                          Die stehen dann in den ioBroker-Objekten als Datenpunkte led_01 - led_32 schön untereinander.
                                          Ich meine, bei mir werden bei Änderung auch nur eines Datenpunktes auch die Zustände aller anderen LED-Datenpunkte mit übertragen und dann im Sketch in einer Schleife abgefragt.
                                          Hintergrund ist der, daß sich sonst erstmalig jeder Datenpunkt/Topic mindestens 1 Mal ändern müsste, bis die entspr. LED leuchtet (vorher ist deren Zustand ja noch nicht bekannt).
                                          Tipp:
                                          Es gibt bei mir auch noch einen dritten Zustand, nämlich "off".
                                          Mir ist das bei 32 LEDs einfach zu bunt, bzw. zu unübersichtlich geworden, so daß z.B. wenn "keine Post da ist", die entspr. LED einfach ausgeschaltet wird.
                                          Jörg
