  4. Skript LOWBAT
Skript LOWBAT
201 Beiträge 44 Kommentatoren 78.4k Aufrufe 14 Beobachtet
  • S
    S
    Saschag
    #149
    Super klappt!
    Vielen Dank!!!
    Edit: Danke nochmal! Habe nun auch verstanden wo der Fehler war und das dies schon ein paar mal im Fed Thema war ;) :(
    Deshalb noch mal Danke! :D
    • X
      X
      Xanon
      #150
      ich setzte dieses Skript ein, um mich über leere Batterien informieren zu lassen.
      //Add device rules
      addDeviceCounter("lowbat_ip",      $('channel[state.id=*.LOW_BAT]'),                     true);
      addDeviceCounter("lowbat",         $('channel[state.id=*.LOWBAT]'),                      true);
      addDeviceCounter("sticky_unreach", $('channel[state.id=*.STICKY_UNREACH]'),              true);
      addDeviceCounter("unreach",        $('channel[state.id=*.UNREACH]'),                     true);
      addDeviceCounter("config_pending", $('channel[state.id=*.CONFIG_PENDING]'),              true);
      //addDeviceCounter("open_windows",   $('channel{TYPE=SHUTTER_CONTACT}[state.id=*.STATE]'), true);
      //addDeviceCounter("on_lights",      $('channel{TYPE=DIMMER}[state.id=*.LEVEL]'),          function(state){return state>0;});
      addDeviceCounter("open_shutters",  $('channel{TYPE=BLIND}[state.id=*.LEVEL]'),           function(state){return state>0;});
      //addDeviceCounter("playing_music",  $('channel[state.id=*audio-*.playing]'),              true);
       * Code - do not change anything bellow this line *
      function addDeviceCounter(name, selector, val_to_count) {
          //Total amount of devices found by selector
          var state_total = 'deviceCounter.' + name + '.total';
          createState(state_total, 0);
          //List of devices that match condition
          var state_list = 'deviceCounter.' + name + '.list';
          createState(state_list, "");
          //Number of devices that match condition
          var state_counter = 'deviceCounter.' + name + '.counter';
          createState(state_counter, 0);
          function countDevs(obj) {
              var d_count = 0;
              var d_list  = [];
              selector.each(function (id, i) {
                  var status = getState(id).val;
                  var obj    = getObject(id);
                  if ((typeof val_to_count === 'function' && val_to_count(status)) ||
                      (typeof val_to_count === 'boolean'  && val_to_count == status)) {
                      //Get parent object
                      var parentChannelId = id.slice(id.lastIndexOf("."));
                      var parentDevicelId = id.split(".").slice(0,-2).join(".");
                      var deviceObject = getObject(parentDevicelId);
                      //remember device name
                      d_list.push(deviceObject.common.name);
                  ++d_count;                                                 // Zählt die Anzahl der vorhandenen Geräte unabhängig vom Status
              log(name + "(" + d_count + "): " + d_list);
              setState(state_list,     d_list.join(' '));
              setState(state_counter,  d_list.length);
              setState(state_total,    d_count);
          //Re-evaluate when a device status changes
          selector.on(function(obj) {    // bei Zustandänderung *. LOWBAT in allen Gewerken
              countDevs(obj);
          //Re-evaluate each hour
          schedule("*/1 * * * *", countDevs);
          //Evaluate for the first time
          countDevs();
      Ich habe LOWBAT und LOW_BAT (also IP Komponenten) im Einsatz.
      Nun wollte ich gerne die beiden States zu einer LOWBAT State zusammenfügen.
      Habe es mit
      addDeviceCounter("lowbat",      $('channel[state.id=*.LOW_BAT]'),                     true);
      versucht, aber statt beide States zusammenzuzählen werden mir bei jedem Timer Event (steht zu Testzwecken auf 1 Min.) mal der eine angezeigt / angesagt und mal der andere.
      Gibt es überhaupt eine Möglichkeit beide States in einem LOWBAT anzeigen zu lassen?
      Kann mir einer sagen, was ich falsch mache oder anders machen muß?
      Vielen Dank schon mal für die Hilfe.
      Xanon
      FoggF 1 Antwort Letzte Antwort
      • A
        A
        Alveran
        #151
        wo findet man die letzte Version vom Script?
        • D
          D
          deifel
          #152
          seit einiger Zeit habe ich ebenfalls Probleme mit dem Script.
          Es zählt immer die Geräte bis Geräte Nr. 83, danach erscheinen folgende Fehlermeldungen im Log:
          09:00:00.010	info	javascript.0 (848) script.js.common.Lowbat: Geräte Nr. 81: Bewegungsmelder vor Garage Haus:0.LOWBAT: false
          09:00:00.011	info	javascript.0 (848) script.js.common.Lowbat: Geräte Nr. 82: Licht Buehne Garage:0.LOWBAT: false
          09:00:00.011	info	javascript.0 (848) script.js.common.Lowbat: Geräte Nr. 83: LED Bild Pavillion:0.LOWBAT: false
          09:00:00.011	warn	javascript.0 (848) at script.js.common.Lowbat:20:10
          09:00:00.011	warn	javascript.0 (848) at countLowbat (script.js.common.Lowbat:18:24)
          09:00:00.011	warn	javascript.0 (848) at Object.<anonymous> (script.js.common.Lowbat:46:4)
          09:00:00.013	warn	javascript.0 (848) at script.js.common.Lowbat:21:19
          09:00:00.013	warn	javascript.0 (848) at countLowbat (script.js.common.Lowbat:18:24)
          09:00:00.013	warn	javascript.0 (848) at Object.<anonymous> (script.js.common.Lowbat:46:4)
          09:00:00.014	error	javascript.0 (848) at script.js.common.Lowbat:27:51
          09:00:00.014	error	javascript.0 (848) at countLowbat (script.js.common.Lowbat:18:24)
          09:00:00.014	error	javascript.0 (848) at Object.<anonymous> (script.js.common.Lowbat:46:4)
          Das Script sieht so aus:
          createState('zählenLowbat.möglicheLOWBAT', 0);   // wenn benötigt: Anzahl der Geräte mit Batterie
          createState('zählenLowbat.anzahlLOWBAT', 0);     // wenn benötigt: Anzahl der vorhandenen LOWBAT
          createState('zählenLowbat.textLOWBAT', " ");     // Namen LOWBAT, die an sind als Variable unter Javascript.0 anlegen
          var cacheSelectorLOWBAT  = $('channel[state.id=*0.LOWBAT]');
          function countLowbat(obj) {
             // Setzt die Zähler vor dem Durchlauf aller Elemente *.LOWBAT auf 0
             var moeglicheLOWBAT = 0;
             var textLOWBAT      = [];
             if (obj) {
                log('Auslösender Aktor: ' + obj.id + ': ' + obj.newState.val);  // Info im Log, welcher Zustand sich geändert hat
             } else {
                log('Ausgelöst bei Timer');
             cacheSelectorLOWBAT.each(function (id, i) {                         // Schleife für jedes gefundenen Element *0.LOWBAT
                var status = false;
                if(getState(id)) {
                   status = getState(id).val;                                  // Zustand *0.LOWBAT abfragen (jedes Element)
                if (status === true) {                                          // wenn Zustand = true, wird das Array erweitert
                   textLOWBAT.push(obj.common.name);                           // Zu Array hinzufügen
                log("Geräte Nr. " + i + ": " + getObject(id).common.name + ": " + status);
                ++moeglicheLOWBAT;                                                 // Zählt die Anzahl der vorhandenen Geräte unabhängig vom Status
             // Schleife ist durchlaufen. Im Log wird der aktuelle Status (Anzahl, davon LOWBAT zutreffend) ausgegeben
             log("Text: " + textLOWBAT);
             log("Anzahl Geräte: " + moeglicheLOWBAT + " # davon LOWBAT erkannt: " +  textLOWBAT.length);
             // die ermittelten Werte werden als javascript.0. Variable in ioBroker gespeichert (z.B. für die Verarbeitung in VIS)
             setState("zählenLowbat.textLOWBAT",     textLOWBAT.join(',<br>')); // Schreibt die Namen der Geräte mit LOWBAT Meldung
             setState("zählenLowbat.anzahlLOWBAT",   textLOWBAT.length);        // Schreibt die aktuelle Anzahl der LOWBAT-Meldungen
             setState("zählenLowbat.möglicheLOWBAT", moeglicheLOWBAT);          // Schreibt die Anzahl der vorhandenen Batterie-Geräte
          cacheSelectorLOWBAT.on(function(obj) {    // bei Zustandänderung *. LOWBAT in allen Gewerken
             countLowbat(obj);
          schedule("*/60 * * * *", function () {                                  //oder!! soll entweder ausgelöst werden alle 10 Minuten
             log("===>Will be triggered every 60 minutes!");
             countLowbat();
          Hat jemand eine Idee, wo hier der Fehler liegt?
          Vielen Dank im Voraus!
          Frank
          • arteckA
            arteckA
            arteck
            #153
            @deifel sagte in Skript LOWBAT:
            da ist ein Object leer oder das Object hat den unterpunkt nicht bzw. dieser ist null
            oder du läufts aus der Schleife... wie viele objecte erwartest du
            • arteckA arteck
              D
              D
              deifel
              #154
              @arteck said in Skript LOWBAT:
              Danke für Deine Hilfe.
              Kannst Du mir evtl. sagen, wie ich dieses Objekt herausfinde bzw. das Problem beheben kann?
              • D deifel
                arteckA
                arteckA
                arteck
                #155
                @deifel was kommt den danach
                LED Bild Pavillion
                für ein Gerät.. der knallt ja im 84 durchlauf
                lass dir mal die liste ausgeben
                log.console('liste->>>>>>>>' + JSON.stringify(cacheSelectorLOWBAT));
                • arteckA arteck
                  LED Bild Pavillion
                  D
                  D
                  deifel
                  #156
                  LED Bild Pavillion
                  Danke! Und sorry für die Noob-Frage:
                  Wo baue ich
                  das ein und was muss ich ergänzen, damit ich ne Liste bekomme? Habs als separates Script und im bestehenden versucht.
                  Sorry - ich bin nicht so tief in der Materie drin, lerne aber täglich dazu;)
                  • D deifel
                    LED Bild Pavillion
                    Wo baue ich
                    paul53P
                    paul53P
                    #157
                    @deifel Erstelle ein Test-Skript, das in der Logausgabe die Nummer und ID ausgibt:
                    $('channel[state.id=*0.LOWBAT]').each(function(id, i) {
                       if(i > 82) log(i + ': ' + id);
                    Produktiv: Asus PN42: N100 / 8 GB / 500 GB; Proxmox mit 2 VM (ioBroker / openCCU)
                      D
                      D
                      deifel
                      #158
                      @paul53 said in Skript LOWBAT:
                      Hat funktioniert, danke!
                      Habe jetzt zwar die Seriennummer des Gerätes - aber das Gerät gibt es bei mir gar nicht...!?
                      Gabs evtl. mal - sprich vermutlich eine Leiche?
                      Wie bekomme ich das jetzt raus? Finde es weder unter Homematic, noch bei Objekten in IOBroker...
                      • D
                        D
                        deifel
                        #159
                        Ich habe das Gerät jetzt manuell unter Objekte bei der Funktion "Batteriebetrieb" rausgenommen. Dort stand es drin.
                        Jetzt läuft das Script durch. Am Schluss erscheinen Warnmeldungen für die CUXD-Geräte, obwohl diese nicht im Gewerk "Batteriebetrieb" sind.
                        Ist diese Warnmeldung korrekt?
                        • D deifel
                          paul53P
                          paul53P
                          #160
                          @deifel sagte:
                          Das Gewerk wird in Deinem $Selector gar nicht ausgewertet. Gibt es unter CUxD Datenpunkte mit "LOWBAT" ?
                          • D
                            D
                            deifel
                            #161
                            Nein, unter meinen 5 CUXD-Geräten gibt es keinen LowBat Datenpunkt.
                            Warnmeldungen erscheinen aber genau für die 5 Geräte im Log.
                            • D deifel
                              paul53P
                              paul53P
                              #162
                              @deifel sagte:
                              Welche ?
                              • D
                                D
                                deifel
                                #163
                                10:30:00.016	warn	javascript.0 (28564) at script.js.common.Lowbat:20:10
                                10:30:00.016	warn	javascript.0 (28564) at countLowbat (script.js.common.Lowbat:18:24)
                                10:30:00.016	warn	javascript.0 (28564) at Object.<anonymous> (script.js.common.Lowbat:46:4)
                                10:30:00.017	warn	javascript.0 (28564) at script.js.common.Lowbat:21:19
                                10:30:00.017	warn	javascript.0 (28564) at countLowbat (script.js.common.Lowbat:18:24)
                                10:30:00.017	warn	javascript.0 (28564) at Object.<anonymous> (script.js.common.Lowbat:46:4)
                                10:30:00.018	info	javascript.0 (28564) script.js.common.Lowbat: Geräte Nr. 101: undefined: null
                                10:30:00.018	warn	javascript.0 (28564) at script.js.common.Lowbat:20:10
                                10:30:00.018	warn	javascript.0 (28564) at countLowbat (script.js.common.Lowbat:18:24)
                                10:30:00.018	warn	javascript.0 (28564) at Object.<anonymous> (script.js.common.Lowbat:46:4)
                                10:30:00.019	warn	javascript.0 (28564) at script.js.common.Lowbat:21:19
                                10:30:00.019	warn	javascript.0 (28564) at countLowbat (script.js.common.Lowbat:18:24)
                                10:30:00.019	warn	javascript.0 (28564) at Object.<anonymous> (script.js.common.Lowbat:46:4)
                                10:30:00.020	info	javascript.0 (28564) script.js.common.Lowbat: Geräte Nr. 102: undefined: null
                                10:30:00.021	warn	javascript.0 (28564) at script.js.common.Lowbat:20:10
                                10:30:00.021	warn	javascript.0 (28564) at countLowbat (script.js.common.Lowbat:18:24)
                                10:30:00.021	warn	javascript.0 (28564) at Object.<anonymous> (script.js.common.Lowbat:46:4)
                                10:30:00.022	warn	javascript.0 (28564) at script.js.common.Lowbat:21:19
                                10:30:00.022	warn	javascript.0 (28564) at countLowbat (script.js.common.Lowbat:18:24)
                                10:30:00.022	warn	javascript.0 (28564) at Object.<anonymous> (script.js.common.Lowbat:46:4)
                                10:30:00.023	info	javascript.0 (28564) script.js.common.Lowbat: Geräte Nr. 103: undefined: null
                                10:30:00.023	warn	javascript.0 (28564) at script.js.common.Lowbat:20:10
                                10:30:00.023	warn	javascript.0 (28564) at countLowbat (script.js.common.Lowbat:18:24)
                                10:30:00.023	warn	javascript.0 (28564) at Object.<anonymous> (script.js.common.Lowbat:46:4)
                                10:30:00.024	warn	javascript.0 (28564) at script.js.common.Lowbat:21:19
                                10:30:00.024	warn	javascript.0 (28564) at countLowbat (script.js.common.Lowbat:18:24)
                                10:30:00.024	warn	javascript.0 (28564) at Object.<anonymous> (script.js.common.Lowbat:46:4)
                                10:30:00.024	info	javascript.0 (28564) script.js.common.Lowbat: Geräte Nr. 104: undefined: null
                                10:30:00.025	warn	javascript.0 (28564) at script.js.common.Lowbat:20:10
                                10:30:00.025	warn	javascript.0 (28564) at countLowbat (script.js.common.Lowbat:18:24)
                                10:30:00.025	warn	javascript.0 (28564) at Object.<anonymous> (script.js.common.Lowbat:46:4)
                                10:30:00.026	warn	javascript.0 (28564) at script.js.common.Lowbat:21:19
                                10:30:00.026	warn	javascript.0 (28564) at countLowbat (script.js.common.Lowbat:18:24)
                                10:30:00.026	warn	javascript.0 (28564) at Object.<anonymous> (script.js.common.Lowbat:46:4)
                                10:30:00.026	info	javascript.0 (28564) script.js.common.Lowbat: Geräte Nr. 105: undefined: null
                                10:30:00.026	info	javascript.0 (28564) script.js.common.Lowbat: Text:
                                10:30:00.026	info	javascript.0 (28564) script.js.common.Lowbat: Anzahl Geräte: 106 # davon LOWBAT erkannt: 0
                                • D deifel
                                  paul53P
                                  paul53P
                                  #164
                                  @deifel Welche IDs gibt das Test-Skript mit den Nummern 101 bis 105 aus ?
                                  • D
                                    D
                                    deifel
                                    #165
                                    $('channel[state.id=*0.LOWBAT]').each(function(id, i) { if(i > 82) log(i + ': ' + id); });
                                    10:35:50.771	info	javascript.0 (28564) script.js.common.TEST: 100: hm-rpc.0.QEQ0087728.0.LOWBAT
                                    10:35:50.771	info	javascript.0 (28564) script.js.common.TEST: 101: hm-rpc.1.CUX2801001.0.LOWBAT
                                    10:35:50.771	info	javascript.0 (28564) script.js.common.TEST: 102: hm-rpc.1.CUX4000001.0.LOWBAT
                                    10:35:50.771	info	javascript.0 (28564) script.js.common.TEST: 103: hm-rpc.1.CUX9000002.0.LOWBAT
                                    10:35:50.771	info	javascript.0 (28564) script.js.common.TEST: 104: hm-rpc.1.CUX9000003.0.LOWBAT
                                    10:35:50.771	info	javascript.0 (28564) script.js.common.TEST: 105: hm-rpc.1.CUX9000004.0.LOWBAT
                                    • D
                                      D
                                      deifel
                                      #166
                                      Hab die Datenpunkte gefunden. Indicator.lowbat heißen die.
                                      Soll / muss ich die entfernen?
                                      • D deifel
                                        paul53P
                                        paul53P
                                        #167
                                        @deifel Erweitere mal den $Selector:
                                        $('channel[state.id=hm-rpc.0*0.LOWBAT]').each(function(id, i) {
                                        • D
                                          D
                                          deifel
                                          #168
                                          Damit bekomme ich die CUXD-Geräte nicht mehr angezeigt, nur die "korrekten" Geräte.
                                          33.2k
                                          84.3k
