  4. Iobroker Oberfläche öffnet nicht
Geplant Angeheftet Gesperrt Verschoben Gelöst Error/Bug
iobroker
16 Beiträge 4 Kommentatoren 3.2k Aufrufe 4 Beobachtet
  • R Offline
    Rocket85
    Hab alles schritt für schritt gemacht, ohne erfolg.
    • R Offline
      Rocket85
      pi@raspberrypi:~ $ cd /opt/iobroker
      pi@raspberrypi:/opt/iobroker $ iobroker start
      Starting iobroker controller daemon...
      iobroker controller daemon failed to start:  Failed to write pidfile (EACCES)
      Error: Failed to write pidfile (EACCES)
      pi@raspberrypi:/opt/iobroker $ node node_modules/iobroker.js-controller/controll        er.js --logs
      2019-11-22 14:18:17.200  - info: host.raspberrypi iobroker.js-controller version        1.5.14 js-controller starting
      2019-11-22 14:18:17.207  - info: host.raspberrypi Copyright (c) 2014-2018 bluefo        x, 2014 hobbyquaker
      2019-11-22 14:18:17.208  - info: host.raspberrypi hostname: raspberrypi, node: v        10.17.0
      2019-11-22 14:18:17.212  - info: host.raspberrypi ip addresses: 192.168.178.87 2        a02:810c:ccc0:45a0:6733:40f8:70dd:257f fe80::3b7f:ed1c:96e6:b13b
      2019-11-22 14:18:17.359  - info: host.raspberrypi  inMem-states listening on por        t 9000
      2019-11-22 14:18:18.061  - info: host.raspberrypi  inMem-objects listening on po        rt 9001
      2019-11-22 14:18:18.100  - info: host.raspberrypi InMemoryDB connected
      2019-11-22 14:18:18.144  - info: host.raspberrypi 19 instances found
      host.raspberrypi check instance "system.adapter.admin.0" for host "raspberrypi"
      host.raspberrypi check instance "system.adapter.discovery.0" for host "raspberrypi"
      host.raspberrypi check instance "system.adapter.cloud.0" for host "raspberrypi"
      host.raspberrypi check instance "system.adapter.web.0" for host "raspberrypi"
      host.raspberrypi check instance "system.adapter.rpi2.0" for host "raspberrypi"
      host.raspberrypi check instance "system.adapter.vis.0" for host "raspberrypi"
      host.raspberrypi check instance "system.adapter.terminal.0" for host "raspberrypi"
      host.raspberrypi check instance "system.adapter.alexa2.0" for host "raspberrypi"
      host.raspberrypi check instance "system.adapter.vis-players.0" for host "raspberrypi"
      host.raspberrypi check instance "system.adapter.scenes.0" for host "raspberrypi"
      host.raspberrypi check instance "system.adapter.mihome.0" for host "raspberrypi"
      host.raspberrypi check instance "system.adapter.javascript.0" for host "raspberrypi"
      host.raspberrypi check instance "system.adapter.telegram.0" for host "raspberrypi"
      host.raspberrypi check instance "system.adapter.text2command.0" for host "raspberrypi"
      host.raspberrypi check instance "system.adapter.shelly.0" for host "raspberrypi"
      host.raspberrypi check instance "system.adapter.pushover.0" for host "raspberrypi"
      host.raspberrypi check instance "system.adapter.info.0" for host "raspberrypi"
      host.raspberrypi check instance "system.adapter.shelly.1" for host "raspberrypi"
      host.raspberrypi check instance "system.adapter.backitup.0" for host "raspberrypi"
      2019-11-22 14:18:18.190  - info: host.raspberrypi starting 14 instances
      2019-11-22 14:18:18.304  - info: host.raspberrypi instance system.adapter.admin.0 started with pid 18290
      2019-11-22 14:18:19.309  - error: uncaught exception: EACCES: permission denied, open '/opt/iobroker/node_modules/iobroker.js-controller/pids.txt'
      2019-11-22 14:18:19.313  - error: Error: EACCES: permission denied, open '/opt/iobroker/node_modules/iobroker.js-controller/pids.txt'
          at Object.openSync (fs.js:443:3)
          at Object.writeFileSync (fs.js:1194:35)
          at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.js-controller/controller.js:2024:16)
          at ontimeout (timers.js:436:11)
          at tryOnTimeout (timers.js:300:5)
          at listOnTimeout (timers.js:263:5)
          at Timer.processTimers (timers.js:223:10)
      2019-11-22 14:18:19.319  - info: iobroker _restart
      2019-11-22 14:18:20.059  - info: iobroker Starting node restart.js
      2019-11-22 14:18:20.087  - info: iobroker exit 0
      2019-11-22 14:18:29.331  - info: host.raspberrypi force terminating
      2019-11-22 14:18:29.332  - info: Adapter admin still running
      2019-11-22 14:18:30.234  - info: host.raspberrypi instance system.adapter.alexa2.0 started with pid 18323
      R 1 Antwort Letzte Antwort
      • R Rocket85
        Hallo Liebe Leute,
        folgender Fehler:
        Wollte heute morgen den Iobroker öffnen und erhielt nur einen Seite Ladefehler. Wollte dann rebooten und es kam folgendes:
        pi@raspberrypi:/opt/iobroker $ iobroker reboot
        internal/modules/cjs/loader.js:638
            throw err;
        Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
            at Function.Module._resolveFilename (internal/modules/cjs/loader.js:636:15)
            at Function.Module._load (internal/modules/cjs/loader.js:562:25)
            at Function.Module.runMain (internal/modules/cjs/loader.js:831:12)
            at startup (internal/bootstrap/node.js:283:19)
            at bootstrapNodeJSCore (internal/bootstrap/node.js:623:3)
        NegaleinN Offline
        NegaleinN Offline
        Negalein
        @Rocket85 sagte in Iobroker Oberfläche öffnet nicht:
        folgender Fehler:
        Mod-Edit: Thema ins passende Forum verschoben!
        ° Fixer ---> iob fix
        • R Rocket85
          Rocket85
           iobroker list instances
            system.adapter.admin.0                 : admin       -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
            system.adapter.alexa2.0                : alexa2      -  enabled
            system.adapter.backitup.0              : backitup    -  enabled
            system.adapter.cloud.0                 : cloud       -  enabled
            system.adapter.discovery.0             : discovery   - disabled
            system.adapter.info.0                  : info        -  enabled
            system.adapter.javascript.0            : javascript  -  enabled
            system.adapter.mihome.0                : mihome      -  enabled, port: 9898, bind: 0.0.0.0
            system.adapter.pushover.0              : pushover    -  enabled
            system.adapter.rpi2.0                  : rpi2        - disabled
            system.adapter.scenes.0                : scenes      - disabled
            system.adapter.shelly.0                : shelly      -  enabled, port: 1882, bind: 0.0.0.0
            system.adapter.shelly.1                : shelly      -  enabled, port: 1882, bind: 0.0.0.0
            system.adapter.telegram.0              : telegram    -  enabled, port: 8443, bind: 0.0.0.0
            system.adapter.terminal.0              : terminal    -  enabled, port: 8088, bind: 0.0.0.0, run as: admin
            system.adapter.text2command.0          : text2command -  enabled
            system.adapter.vis-players.0           : vis-players -  enabled
            system.adapter.vis.0                   : vis         - disabled
            system.adapter.web.0                   : web         - disabled, port: 8082, bind: 0.0.0.0, run as: admin
          • R Rocket85
            dslraserD Offline
            dslraserD Offline
            dslraser
            @Rocket85
            hast Du mal den Fixer laufen lassen ?
            Das hier sieht nach einem Rechte Problem aus...
            Fixer
            curl -sL https://iobroker.net/fix.sh | bash -
            • R Offline
              Rocket85
              @dslraser sagte in Iobroker Oberfläche öffnet nicht:
              moment läuft
              • dslraserD dslraser
                @Rocket85
                Fixer
                Rocket85
                @dslraser
                geht wieder.
                Ich danke dir vielmals bzw. euch allen.
                jetzt will er ein update des admin. kann man das ohne probleme machen?
                • R Rocket85
                  @dslraser
                  geht wieder.
                  dslraserD Offline
                  dslraserD Offline
                  dslraser
                  @dslraser
                  geht wieder.
                  Ich denke schon. Immer wenn Du nicht sicher bist was Du machst, vorher Backup machen.
                  • R Offline
                    Rocket85
                    Jetzt versteh ich nix mehr. Es läuft wieder alles.
                    Allerdings hatte ich den js-controller vor Tagen schon auf die neuste verseion upgedatet. Und jetzt steht er wieder verfügbar auf 2.1.0 und installiert 1.5.14??
                    • R Rocket85
                      dslraserD Offline
                      dslraserD Offline
                      dslraser
                      wahrscheinlich hattest Du den Verwahrungsort auf default und hast dann nach der verlinkten Anleitung alles wieder hergestellt ?
                      PS:
                      Es gibt heute Abend dann 2.1.1 in latest.
                      • R Offline
                        Rocket85
                        Na dann warte ich bis morgen :-)
                        • R Rocket85
                          dslraserD Offline
                          dslraserD Offline
                          dslraser
                          Ich habe 2.1.1 schon installiert und es läuft bisher alles ohne Auffälligkeiten.
