  4. Fehler backitup-Adapter
backitup
3 Beiträge 2 Kommentatoren 563 Aufrufe 2 Beobachtet
  • N Offline
    N Offline
    nathan1312
    wenn ich den backitup-Adapter inklusive redis-backup starten will bekomme ich folgende Fehlermeldung:
    host.ioBrokerRaspi4	2019-11-17 15:39:48.144	info	Restart adapter system.adapter.backitup.0 because enabled
    host.ioBrokerRaspi4	2019-11-17 15:39:48.144	info	instance system.adapter.backitup.0 terminated with code 0 (NO_ERROR)
    host.ioBrokerRaspi4	2019-11-17 15:39:48.143	error	Caught by controller[1]: at processImmediate (timers.js:658:5)
    host.ioBrokerRaspi4	2019-11-17 15:39:48.143	error	Caught by controller[1]: at tryOnImmediate (timers.js:676:5)
    host.ioBrokerRaspi4	2019-11-17 15:39:48.142	error	Caught by controller[1]: at runCallback (timers.js:705:18)
    host.ioBrokerRaspi4	2019-11-17 15:39:48.142	error	Caught by controller[1]: at Immediate.setImmediate (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4748:38)
    host.ioBrokerRaspi4	2019-11-17 15:39:48.142	error	Caught by controller[1]: at Adapter.emit (events.js:198:13)
    host.ioBrokerRaspi4	2019-11-17 15:39:48.141	error	Caught by controller[1]: at Adapter.adapter.on (/opt/iobroker/node_modules/iobroker.backitup/main.js:66:48)
    host.ioBrokerRaspi4	2019-11-17 15:39:48.141	error	Caught by controller[1]: at JSON.stringify (<anonymous>)
    host.ioBrokerRaspi4	2019-11-17 15:39:48.139	error	Caught by controller[1]: TypeError: Converting circular structure to JSON
    backitup.0	2019-11-17 15:39:47.598	info	(631) Terminated (NO_ERROR): Without reason
    backitup.0	2019-11-17 15:39:47.595	info	(631) terminating
    backitup.0	2019-11-17 15:39:47.090	error	at processImmediate (timers.js:658:5)
    backitup.0	2019-11-17 15:39:47.090	error	at tryOnImmediate (timers.js:676:5)
    backitup.0	2019-11-17 15:39:47.090	error	at runCallback (timers.js:705:18)
    backitup.0	2019-11-17 15:39:47.090	error	at Immediate.setImmediate (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4748:38)
    backitup.0	2019-11-17 15:39:47.090	error	at Adapter.emit (events.js:198:13)
    backitup.0	2019-11-17 15:39:47.090	error	at Adapter.adapter.on (/opt/iobroker/node_modules/iobroker.backitup/main.js:66:48)
    backitup.0	2019-11-17 15:39:47.090	error	at JSON.stringify (<anonymous>)
    backitup.0	2019-11-17 15:39:47.090	error	(631) TypeError: Converting circular structure to JSON
    backitup.0	2019-11-17 15:39:47.087	error	(631) uncaught exception: Converting circular structure to JSON
    Hab schon gegoogelt aber leider nichts gefunden.
    Kann mir jemand helfen?
    • N nathan1312
      simatecS Offline
      simatecS Offline
      simatec
      @nathan1312 sagte in Fehler backitup-Adapter:
      66
      Bitte poste mal deine aktuelle Versionen, die auf deinem System laufen
      • Besuche meine Github Seite
      • HowTo Restore ioBroker
      • N Offline
        N Offline
        nathan1312
        Der Adapter läuft in der Version 1.2.0. Das ist die aktuelle soweit ich sehen kann.
        Hab das Backup (standard) jetzt mal ohne redis laufen lassen. Das hat ohne Probleme funktioniert. Hab dann redis wieder eingebunden und danach hat es auch wieder geklappt. Komisch...
        Vielleicht kannst du ja mit meiner Nachricht noch irgendwo einen Fehler finden.
