<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Fehler backitup-Adapter]]></title><description><![CDATA[<p dir="auto">Hallo,</p>
<p dir="auto">wenn ich den backitup-Adapter inklusive redis-backup starten will bekomme ich folgende Fehlermeldung:</p>
<pre><code>host.ioBrokerRaspi4	2019-11-17 15:39:48.144	info	Restart adapter system.adapter.backitup.0 because enabled
host.ioBrokerRaspi4	2019-11-17 15:39:48.144	info	instance system.adapter.backitup.0 terminated with code 0 (NO_ERROR)
host.ioBrokerRaspi4	2019-11-17 15:39:48.143	error	Caught by controller[1]: at processImmediate (timers.js:658:5)
host.ioBrokerRaspi4	2019-11-17 15:39:48.143	error	Caught by controller[1]: at tryOnImmediate (timers.js:676:5)
host.ioBrokerRaspi4	2019-11-17 15:39:48.142	error	Caught by controller[1]: at runCallback (timers.js:705:18)
host.ioBrokerRaspi4	2019-11-17 15:39:48.142	error	Caught by controller[1]: at Immediate.setImmediate (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4748:38)
host.ioBrokerRaspi4	2019-11-17 15:39:48.142	error	Caught by controller[1]: at Adapter.emit (events.js:198:13)
host.ioBrokerRaspi4	2019-11-17 15:39:48.141	error	Caught by controller[1]: at Adapter.adapter.on (/opt/iobroker/node_modules/iobroker.backitup/main.js:66:48)
host.ioBrokerRaspi4	2019-11-17 15:39:48.141	error	Caught by controller[1]: at JSON.stringify (&lt;anonymous&gt;)
host.ioBrokerRaspi4	2019-11-17 15:39:48.139	error	Caught by controller[1]: TypeError: Converting circular structure to JSON
backitup.0	2019-11-17 15:39:47.598	info	(631) Terminated (NO_ERROR): Without reason
backitup.0	2019-11-17 15:39:47.595	info	(631) terminating
backitup.0	2019-11-17 15:39:47.090	error	at processImmediate (timers.js:658:5)
backitup.0	2019-11-17 15:39:47.090	error	at tryOnImmediate (timers.js:676:5)
backitup.0	2019-11-17 15:39:47.090	error	at runCallback (timers.js:705:18)
backitup.0	2019-11-17 15:39:47.090	error	at Immediate.setImmediate (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4748:38)
backitup.0	2019-11-17 15:39:47.090	error	at Adapter.emit (events.js:198:13)
backitup.0	2019-11-17 15:39:47.090	error	at Adapter.adapter.on (/opt/iobroker/node_modules/iobroker.backitup/main.js:66:48)
backitup.0	2019-11-17 15:39:47.090	error	at JSON.stringify (&lt;anonymous&gt;)
backitup.0	2019-11-17 15:39:47.090	error	(631) TypeError: Converting circular structure to JSON
backitup.0	2019-11-17 15:39:47.087	error	(631) uncaught exception: Converting circular structure to JSON
</code></pre>
<p dir="auto">Hab schon gegoogelt aber leider nichts gefunden.</p>
<p dir="auto">Kann mir jemand helfen?</p>
]]></description><link>https://forum.iobroker.net/topic/26810/fehler-backitup-adapter</link><generator>RSS for Node</generator><lastBuildDate>Mon, 27 Apr 2026 19:13:30 GMT</lastBuildDate><atom:link href="https://forum.iobroker.net/topic/26810.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 17 Nov 2019 14:51:21 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Fehler backitup-Adapter on Wed, 20 Nov 2019 21:17:47 GMT]]></title><description><![CDATA[<p dir="auto">Hallo,</p>
<p dir="auto">Der Adapter läuft in der Version 1.2.0. Das ist die aktuelle soweit ich sehen kann.</p>
<p dir="auto">Hab das Backup (standard) jetzt mal ohne redis laufen lassen. Das hat ohne Probleme funktioniert. Hab dann redis wieder eingebunden und danach hat es auch wieder geklappt. Komisch...</p>
<p dir="auto">Vielleicht kannst du ja mit meiner Nachricht noch irgendwo einen Fehler finden.</p>
]]></description><link>https://forum.iobroker.net/post/328287</link><guid isPermaLink="true">https://forum.iobroker.net/post/328287</guid><dc:creator><![CDATA[nathan1312]]></dc:creator><pubDate>Wed, 20 Nov 2019 21:17:47 GMT</pubDate></item><item><title><![CDATA[Reply to Fehler backitup-Adapter on Mon, 18 Nov 2019 07:39:01 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/nathan1312" aria-label="Profile: nathan1312">@<bdi>nathan1312</bdi></a> sagte in <a href="/post/326577">Fehler backitup-Adapter</a>:</p>
<blockquote>
<p dir="auto">66</p>
</blockquote>
<p dir="auto">Bitte poste mal deine aktuelle Versionen, die auf deinem System laufen</p>
]]></description><link>https://forum.iobroker.net/post/326885</link><guid isPermaLink="true">https://forum.iobroker.net/post/326885</guid><dc:creator><![CDATA[simatec]]></dc:creator><pubDate>Mon, 18 Nov 2019 07:39:01 GMT</pubDate></item></channel></rss>
