  4. JavaScript
  5. Script - Info über Datenpunkte sammeln
    6.6k
javascripttemplate
291 Beiträge 11 Kommentatoren 63.9k Aufrufe 17 Beobachtet
  • sigi234S sigi234
    @liv-in-sky
    javascript.0	2019-11-16 19:22:03.598	error	(11832) at process._tickCallback (internal/process/next_tick.js:68:7)
    javascript.0	2019-11-16 19:22:03.598	error	(11832) at promise.then (C:\Program Files\iobroker\IOB\node_modules\iobroker.js-controller\node_modules\standard-as-callback\built\index.js:19:49)
    javascript.0	2019-11-16 19:22:03.598	error	(11832) at tryCatcher (C:\Program Files\iobroker\IOB\node_modules\iobroker.js-controller\node_modules\standard-as-callback\built\utils.js:11:23)
    javascript.0	2019-11-16 19:22:03.598	error	(11832) at client.get (C:\Program Files\iobroker\IOB\node_modules\iobroker.js-controller\lib\states\statesInRedis.js:483:33)
    javascript.0	2019-11-16 19:22:03.598	error	(11832) at adapter.getForeignState (C:\Program Files\iobroker\IOB\node_modules\iobroker.javascript\main.js:855:17)
    javascript.0	2019-11-16 19:22:03.598	error	(11832) at createProblemObject (C:\Program Files\iobroker\IOB\node_modules\iobroker.javascript\main.js:1264:17)
    javascript.0	2019-11-16 19:22:03.598	error	(11832) at prepareScript (C:\Program Files\iobroker\IOB\node_modules\iobroker.javascript\main.js:1211:37)
    javascript.0	2019-11-16 19:22:03.598	error	(11832) at compile (C:\Program Files\iobroker\IOB\node_modules\iobroker.javascript\main.js:988:28)
    javascript.0	2019-11-16 19:22:03.598	error	(11832) at Object.createScript (vm.js:277:10)
    javascript.0	2019-11-16 19:22:03.598	error	(11832) at new Script (vm.js:83:7)
    javascript.0	2019-11-16 19:22:03.598	error	(11832) SyntaxError: Identifier 'htmlPart5' has already been declared
    javascript.0	2019-11-16 19:22:03.598	error	(11832) ^
    javascript.0	2019-11-16 19:22:03.598	error	(11832) const htmlPart5="<p style=\"color:#01DF01;font-size:130%; font-family:"+schriftart+";\"></br><b>!!! Script successful ... in part 1 - Instanz-Count ?? !!!</b>"+
    javascript.0	2019-11-16 19:22:03.597	error	at script.js.System.Proofingdatapoints1:1137
    javascript.0	2019-11-16 19:22:03.597	error	(11832) script.js.System.Proofingdatapoints1 compile failed:
    liv-in-skyL Offline
    liv-in-skyL Offline
    #276
    @sigi234 hab das file nochmal kopiert - erstellt
    ProofingDatapoints16-11-19.txt
    • liv-in-skyL liv-in-sky
      sigi234S Online
      sigi234S Online
      #277
      @liv-in-sky sagte in Script - Info über Datenpunkte sammeln:
      Läuft 👍
      Widget angepasst:
      Widget_Proofing_Datapoints_sigi234.txt
        neues update mit anzeige von history daten -. dazu den neuen datenpunkt "HistoryAnalyse" auf true setzen
        @crunchip - es werden hier im script nur noch 90 zeichen bei den id's angezeigt - ich hoffe mal, es schneidet nicht zu viel weg
        feedback wäre erwünscht
        crunchipC Offline
        crunchipC Offline
        #278
        @liv-in-sky sieht gut aus, wobei 100 Zeichen würden auch gehen, dann wären die letzten paar Zeichen von den "normal" langen id`s gar mit drauf. Scrollen muss man dann eh, wenn man den Rest sehen möchte.
        hab da skript durchlaufen lassen, war ok, danach hab ich ein paar Haken entfernt um ne andere Suche zu starten, jedoch blieb es dann beim letzten Punkt stehn, siehe Screen
        es will auch nicht mehr laufen, Instanz hab ich neu gestartet, trotzdem der gleiche Fehler
        javascript.1	2019-11-16 21:37:16.574	info	(10149) script.js.common.System.Datenpunktprüfung7: ------------ERROR: TypeError: Cannot convert undefined or null to object
        javascript.1	2019-11-16 21:37:13.174	info	(10149) script.js.common.System.Datenpunktprüfung7: bin in check SmartIot und History
        javascript.1	2019-11-16 21:37:13.171	info	(10149) script.js.common.System.Datenpunktprüfung7: bin raus aus check aliase
        javascript.1	2019-11-16 21:37:13.025	info	(10149) script.js.common.System.Datenpunktprüfung7: bin in check aliase
        javascript.1	2019-11-16 21:37:12.223	info	(10149) script.js.common.System.Datenpunktprüfung7: fertig in checkType mit CheckType
        javascript.1	2019-11-16 21:37:12.222	info	(10149) script.js.common.System.Datenpunktprüfung7: fertg bei checkType mit: javascript.1 und 1180 Durchläufen bisher
        javascript.1	2019-11-16 21:37:12.134	info	(10149) script.js.common.System.Datenpunktprüfung7: fertg bei checkType mit: javascript.0 und 702 Durchläufen bisher
        javascript.1	2019-11-16 21:37:12.047	warn	(10149) at Promise (script.js.common.System.Datenpunktprüfung7:249:26)
        javascript.1	2019-11-16 21:37:12.047	warn	(10149) at Object.result.each (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:806:29)
        javascript.1	2019-11-16 21:37:12.047	warn	(10149) at script.js.common.System.Datenpunktprüfung7:300:18
        javascript.1	2019-11-16 21:37:12.047	warn	(10149) getState "javascript.0.Gute_Nacht" not found (3) states[id]=null
        javascript.1	2019-11-16 21:37:12.046	warn	(10149) at Promise (script.js.common.System.Datenpunktprüfung7:249:26)
        javascript.1	2019-11-16 21:37:12.046	warn	(10149) at Object.result.each (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:806:29)
        javascript.1	2019-11-16 21:37:12.046	warn	(10149) at script.js.common.System.Datenpunktprüfung7:282:35
        javascript.1	2019-11-16 21:37:12.045	warn	(10149) getState "javascript.0.Gute_Nacht" not found (3) states[id]=null
        javascript.1	2019-11-16 21:37:12.023	warn	(10149) at Promise (script.js.common.System.Datenpunktprüfung7:249:26)
        javascript.1	2019-11-16 21:37:12.023	warn	(10149) at Object.result.each (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:806:29)
        javascript.1	2019-11-16 21:37:12.023	warn	(10149) at script.js.common.System.Datenpunktprüfung7:300:18
        javascript.1	2019-11-16 21:37:12.023	warn	(10149) getState "javascript.0.Fussball" not found (3) states[id]=null
        javascript.1	2019-11-16 21:37:12.022	warn	(10149) at Promise (script.js.common.System.Datenpunktprüfung7:249:26)
        javascript.1	2019-11-16 21:37:12.022	warn	(10149) at Object.result.each (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:806:29)
        javascript.1	2019-11-16 21:37:12.022	warn	(10149) at script.js.common.System.Datenpunktprüfung7:282:35
        javascript.1	2019-11-16 21:37:12.021	warn	(10149) getState "javascript.0.Fussball" not found (3) states[id]=null
        javascript.1	2019-11-16 21:37:11.955	info	(10149) script.js.common.System.Datenpunktprüfung7: fertg bei checkType mit: 0_userdata.0 und 15 Durchläufen bisher
        javascript.1	2019-11-16 21:37:11.955	warn	(10149) at Promise (script.js.common.System.Datenpunktprüfung7:249:26)
        javascript.1	2019-11-16 21:37:11.954	warn	(10149) at Object.result.each (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:806:29)
        javascript.1	2019-11-16 21:37:11.954	warn	(10149) at script.js.common.System.Datenpunktprüfung7:300:18
        javascript.1	2019-11-16 21:37:11.953	warn	(10149) getState "0_userdata.0.example_state" not found (3) states[id]=null
        javascript.1	2019-11-16 21:37:11.952	warn	(10149) at Promise (script.js.common.System.Datenpunktprüfung7:249:26)
        javascript.1	2019-11-16 21:37:11.952	warn	(10149) at Object.result.each (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:806:29)
        javascript.1	2019-11-16 21:37:11.952	warn	(10149) at script.js.common.System.Datenpunktprüfung7:282:35
        javascript.1	2019-11-16 21:37:11.951	warn	(10149) getState "0_userdata.0.example_state" not found (3) states[id]=null
        javascript.1	2019-11-16 21:37:11.898	info	(10149) script.js.common.System.Datenpunktprüfung7: fertg bei checkType mit: kamera.0 und 14 Durchläufen bisher
        javascript.1	2019-11-16 21:37:11.841	info	(10149) script.js.common.System.Datenpunktprüfung7: fertg bei checkType mit: Meine_Geräte.0 und 8 Durchläufen bisher
        javascript.1	2019-11-16 21:37:11.786	info	(10149) script.js.common.System.Datenpunktprüfung7: fertg bei checkType mit: Mein_TV.0 und 3 Durchläufen bisher
        javascript.1	2019-11-16 21:37:10.930	info	(10149) script.js.common.System.Datenpunktprüfung7: bin in check types
        javascript.1	2019-11-16 21:37:10.926	info	(10149) script.js.common.System.Datenpunktprüfung7: bin raus aus check Werte
        javascript.1	2019-11-16 21:37:10.925	info	(10149) script.js.common.System.Datenpunktprüfung7: bin raus aus check Werte bei :javascript.1
        javascript.1	2019-11-16 21:37:10.847	info	(10149) script.js.common.System.Datenpunktprüfung7: bin raus aus check Werte bei :javascript.0
        javascript.1	2019-11-16 21:37:10.814	warn	(10149) at Promise (script.js.common.System.Datenpunktprüfung7:366:27)
        javascript.1	2019-11-16 21:37:10.814	warn	(10149) at Object.result.each (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:806:29)
        javascript.1	2019-11-16 21:37:10.814	warn	(10149) at script.js.common.System.Datenpunktprüfung7:400:74
        javascript.1	2019-11-16 21:37:10.813	warn	(10149) getState "javascript.0.Gute_Nacht" not found (3) states[id]=null
        javascript.1	2019-11-16 21:37:10.813	warn	(10149) at Promise (script.js.common.System.Datenpunktprüfung7:366:27)
        javascript.1	2019-11-16 21:37:10.812	warn	(10149) at Object.result.each (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:806:29)
        javascript.1	2019-11-16 21:37:10.812	warn	(10149) at script.js.common.System.Datenpunktprüfung7:399:44
        javascript.1	2019-11-16 21:37:10.811	warn	(10149) getState "javascript.0.Gute_Nacht" not found (3) states[id]=null
        javascript.1	2019-11-16 21:37:10.811	warn	(10149) at Promise (script.js.common.System.Datenpunktprüfung7:366:27)
        javascript.1	2019-11-16 21:37:10.810	warn	(10149) at Object.result.each (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:806:29)
        javascript.1	2019-11-16 21:37:10.810	warn	(10149) at script.js.common.System.Datenpunktprüfung7:389:36
        javascript.1	2019-11-16 21:37:10.809	warn	(10149) getState "javascript.0.Gute_Nacht" not found (3) states[id]=null
        javascript.1	2019-11-16 21:37:10.787	warn	(10149) at Promise (script.js.common.System.Datenpunktprüfung7:366:27)
        javascript.1	2019-11-16 21:37:10.787	warn	(10149) at Object.result.each (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:806:29)
        javascript.1	2019-11-16 21:37:10.787	warn	(10149) at script.js.common.System.Datenpunktprüfung7:400:74
        javascript.1	2019-11-16 21:37:10.786	warn	(10149) getState "javascript.0.Fussball" not found (3) states[id]=null
        javascript.1	2019-11-16 21:37:10.786	warn	(10149) at Promise (script.js.common.System.Datenpunktprüfung7:366:27)
        javascript.1	2019-11-16 21:37:10.785	warn	(10149) at Object.result.each (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:806:29)
        javascript.1	2019-11-16 21:37:10.776	warn	(10149) at script.js.common.System.Datenpunktprüfung7:399:44
        javascript.1	2019-11-16 21:37:10.775	warn	(10149) getState "javascript.0.Fussball" not found (3) states[id]=null
        javascript.1	2019-11-16 21:37:10.775	warn	(10149) at Promise (script.js.common.System.Datenpunktprüfung7:366:27)
        javascript.1	2019-11-16 21:37:10.775	warn	(10149) at Object.result.each (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:806:29)
        javascript.1	2019-11-16 21:37:10.774	warn	(10149) at script.js.common.System.Datenpunktprüfung7:389:36
        javascript.1	2019-11-16 21:37:10.774	warn	(10149) getState "javascript.0.Fussball" not found (3) states[id]=null
        javascript.1	2019-11-16 21:37:10.664	info	(10149) script.js.common.System.Datenpunktprüfung7: bin raus aus check Werte bei :0_userdata.0
        javascript.1	2019-11-16 21:37:10.664	warn	(10149) at Promise (script.js.common.System.Datenpunktprüfung7:366:27)
        javascript.1	2019-11-16 21:37:10.664	warn	(10149) at Object.result.each (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:806:29)
        javascript.1	2019-11-16 21:37:10.663	warn	(10149) at script.js.common.System.Datenpunktprüfung7:400:74
        javascript.1	2019-11-16 21:37:10.663	warn	(10149) getState "0_userdata.0.example_state" not found (3) states[id]=null
        javascript.1	2019-11-16 21:37:10.662	warn	(10149) at Promise (script.js.common.System.Datenpunktprüfung7:366:27)
        javascript.1	2019-11-16 21:37:10.662	warn	(10149) at Object.result.each (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:806:29)
        javascript.1	2019-11-16 21:37:10.661	warn	(10149) at script.js.common.System.Datenpunktprüfung7:399:44
        javascript.1	2019-11-16 21:37:10.660	warn	(10149) getState "0_userdata.0.example_state" not found (3) states[id]=null
        javascript.1	2019-11-16 21:37:10.659	warn	(10149) at Promise (script.js.common.System.Datenpunktprüfung7:366:27)
        javascript.1	2019-11-16 21:37:10.658	warn	(10149) at Object.result.each (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:806:29)
        javascript.1	2019-11-16 21:37:10.658	warn	(10149) at script.js.common.System.Datenpunktprüfung7:389:36
        javascript.1	2019-11-16 21:37:10.643	warn	(10149) getState "0_userdata.0.example_state" not found (3) states[id]=null
        javascript.1	2019-11-16 21:37:10.588	info	(10149) script.js.common.System.Datenpunktprüfung7: bin raus aus check Werte bei :kamera.0
        javascript.1	2019-11-16 21:37:10.514	info	(10149) script.js.common.System.Datenpunktprüfung7: bin raus aus check Werte bei :Meine_Geräte.0
        javascript.1	2019-11-16 21:37:10.461	info	(10149) script.js.common.System.Datenpunktprüfung7: bin raus aus check Werte bei :Mein_TV.0
        javascript.1	2019-11-16 21:37:09.603	info	(10149) script.js.common.System.Datenpunktprüfung7: bin in check Werte
        javascript.1	2019-11-16 21:37:09.601	info	(10149) script.js.common.System.Datenpunktprüfung7: bin raus aus count
        javascript.1	2019-11-16 21:37:09.586	info	(10149) script.js.common.System.Datenpunktprüfung7: bin richtig in count
        javascript.1	2019-11-16 21:37:08.225	info	(10149) script.js.common.System.Datenpunktprüfung7: _______bin raus aus check Instanz
        javascript.1	2019-11-16 21:37:07.416	info	(10149) script.js.common.System.Datenpunktprüfung7: _______bin in check Instanz
        javascript.1	2019-11-16 21:37:07.409	info	(10149) script.js.common.System.Datenpunktprüfung7: _______________________ starte MAIN
        javascript.1	2019-11-16 21:36:54.038	info	(10149) script.js.common.System.Datenpunktprüfung7: registered 2 subscriptions and 0 schedules
        javascript.1	2019-11-16 21:36:54.004	info	(10149) Start javascript script.js.common.System.Datenpunktprüfung7
          liv-in-skyL Offline
          liv-in-skyL Offline
          #279
          @crunchip das is ja "komisch" - das es einmal läuft und dann nicht mehr
          kommt der fehler auch, wenn du die history analyse nicht aktivierst
            crunchipC Offline
            crunchipC Offline
            #280
            @liv-in-sky ohne History funktioniert es
            wenn ich alleinig nur
            History Prüfung aktiviere, bleibt es auch fehlerhaft stehn, also liegt es dev an History Prüfung
              liv-in-skyL Offline
              liv-in-skyL Offline
              #281
              @crunchip
              ich mach morgen ein script mit log - es scheint, das eine definition bei dir drin ist, die ich nicht berücksichtige - wir müssen den datenpunkt finden un diese def finden
              wenn du lust hast - hier das log mal einfügen - vielleicht reicht das schon - dann wissen wir schon mal die id - und bei diesem datenpunkt das raw format ansehen
                @crunchip
                crunchipC Offline
                crunchipC Offline
                #282
                @liv-in-sky hab ich gemacht, kann aber nicht viel damit anfangen
                liegt bestimmt an deinen Rechtschreibfehlern im Script😁 Spass
                denke es ist der mclighting, der zwar installiert aber noch nie benutzt wurde
                javascript.1	2019-11-16 22:46:53.932	warn	(10149) at instanzCount (script.js.common.System.Datenpunktprüfung7:100:12)
                javascript.1	2019-11-16 22:46:53.932	warn	(10149) at new Promise (<anonymous>:null:null)
                javascript.1	2019-11-16 22:46:53.932	warn	(10149) at Promise (script.js.common.System.Datenpunktprüfung7:112:29)
                javascript.1	2019-11-16 22:46:53.931	warn	(10149) at Object.result.each (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:806:29)
                javascript.1	2019-11-16 22:46:53.931	warn	(10149) at script.js.common.System.Datenpunktprüfung7:131:9
                javascript.1	2019-11-16 22:46:53.930	warn	(10149) getState "system.adapter.mclighting.0.alive" not found (3) states[id]=null
                javascript.1	2019-11-16 22:46:53.930	warn	(10149) at instanzCount (script.js.common.System.Datenpunktprüfung7:100:12)
                javascript.1	2019-11-16 22:46:53.929	warn	(10149) at new Promise (<anonymous>:null:null)
                javascript.1	2019-11-16 22:46:53.929	warn	(10149) at Promise (script.js.common.System.Datenpunktprüfung7:112:29)
                javascript.1	2019-11-16 22:46:53.929	warn	(10149) at Object.result.each (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:806:29)
                javascript.1	2019-11-16 22:46:53.928	warn	(10149) at script.js.common.System.Datenpunktprüfung7:128:9
                javascript.1	2019-11-16 22:46:53.927	warn	(10149) getState "system.adapter.mclighting.0.alive" not found (3) states[id]=null
                  liv-in-skyL Offline
                  liv-in-skyL Offline
                  #283
                  @crunchip mit diesem ausschnitt kann ich nicht viel anfangen - das müßte ganz woanders sein und sorgt auch nicht für das stehenbleiben
                  diese rausschnitt ist doch mittendrin - denke ich - es muss aber am ende im log sein (also ganz oben im log-tab)
                  schalte auf jeden fall die wert und type analyse mal ab
                  diese zeile muss schon vorbei sein - anschliessend kommen dann die gesuchten id's
                    crunchipC Offline
                    crunchipC Offline
                    #284
                    @liv-in-sky
                    ich hatte alles ausgeschaltet, war nur History aktiviert.
                    Das waren die ersten Warnmeldungen bei scriptstart.
                    nach check smartIot
                    werden alle Datenpunke gelistet und die letzte Zeilenausgabe ist
                    info: javascript.1 (10149) script.js.common.System.Datenpunktprüfung7: ------------ERROR: TypeError: Cannot convert undefined or null to object
                      @liv-in-sky
                      nach check smartIot
                      liv-in-skyL Offline
                      liv-in-skyL Offline
                      #285
                      @crunchip und der datenpunkt davor (vor dieser ausgabe) ist das problem - du bist sehr sparsam mit den logs - zu sparsam
                        crunchipC Offline
                        crunchipC Offline
                        #286
                        @liv-in-sky haha, woher soll ich denn wissen das du den davor brauchst😂
                        die raw dazu
                          "_id": "mihome.0.devices.magnet_158d00023700c4.state",
                          "common": {
                            "name": "Haustür",
                            "role": "state",
                            "write": false,
                            "read": true,
                            "type": "boolean",
                            "custom": {
                              "influxdb.1": {
                                "enabled": true,
                                "changesOnly": true,
                                "debounce": "1000",
                                "maxLength": 10,
                                "retention": "31536000",
                                "changesRelogInterval": 0,
                                "changesMinDelta": 0,
                                "storageType": "",
                                "aliasId": "Haustür"
                              "telegram.0": {
                                "enabled": true,
                                "readOnly": true,
                                "report": true,
                                "alias": "Haustuer",
                                "onStatus": "offen",
                                "offStatus": "geschlossen",
                                "onCommand": "",
                                "offCommand": "geschlossen",
                                "onlyTrue": false,
                                "buttons": 1
                          "type": "state",
                          "native": {},
                          "from": "system.adapter.mihome.0",
                          "ts": 1537861679074,
                          "acl": {
                            "object": 1636,
                            "state": 1636,
                            "owner": "system.user.admin",
                          "user": "system.user.admin"
                          die raw dazu
                            "common": {
                              "name": "Haustür",
                              "role": "state",
                              "write": false,
                              "read": true,
                              "type": "boolean",
                              "custom": {
                                "influxdb.1": {
                                  "enabled": true,
                                  "debounce": "1000",
                                  "maxLength": 10,
                                  "storageType": "",
                                "telegram.0": {
                                  "enabled": true,
                                  "readOnly": true,
                                  "report": true,
                                  "onCommand": "",
                                  "onlyTrue": false,
                                  "buttons": 1
                            "type": "state",
                            "native": {},
                            "acl": {
                              "object": 1636,
                              "state": 1636,
                          liv-in-skyL Offline
                          liv-in-skyL Offline
                          #287
                          @crunchip auf den ersten blick schaut er ganz gut aus
                          ich schau mir das morgen an - gute nacht
                            crunchipC Offline
                            crunchipC Offline
                            #288
                            @liv-in-sky ich vergleich gerade mit den anderen
                            was mir auffällt, es fehlt der iot.0 smartname eintrag
                              liv-in-skyL Offline
                              liv-in-skyL Offline
                              #289
                              @crunchip
                              wir suchen ja das hier
                                  "custom": {
                                    "influxdb.1": {
                              das ist der history eintrag
                                liv-in-skyL Offline
                                liv-in-skyL Offline
                                #290
                                @crunchip moin - jetzt wieder etwas wacher - konnte fehler reproduzieren und hoffentlich bereinigen und natürlich konntest du nicht wissen, dass ich den datenpunkt davor brauche - irgendwann ist man so im script vertieft, dass man nicht mehr merkt, dass andere diese struktur garnicht kennen können - sorry dafür
                                aber hier mal eine neue version - wäre cool , wenn du es testen könntest
                                ProofingDatapoints17-11-19.txt
                                falls es wieder einen fehler geben sollte, könntest du oben - irgendwo in der variablen definition (ca: zeile 55)- die variable "histlogs" auf true setzen - , dann gibt es zusätzliche log-einträge
                                  crunchipC Offline
                                  crunchipC Offline
                                  #291
                                  @liv-in-sky läuft, Problem beseitigt👍
