  4. JavaScript
  5. Script - Info über Datenpunkte sammeln
    6.6k
javascripttemplate
291 Beiträge 11 Kommentatoren 63.9k Aufrufe 17 Beobachtet
  • sigi234S sigi234
    @liv-in-sky
    javascript.0	2019-11-16 19:22:03.598	error	(11832) at process._tickCallback (internal/process/next_tick.js:68:7)
    javascript.0	2019-11-16 19:22:03.598	error	(11832) at promise.then (C:\Program Files\iobroker\IOB\node_modules\iobroker.js-controller\node_modules\standard-as-callback\built\index.js:19:49)
    javascript.0	2019-11-16 19:22:03.598	error	(11832) at tryCatcher (C:\Program Files\iobroker\IOB\node_modules\iobroker.js-controller\node_modules\standard-as-callback\built\utils.js:11:23)
    javascript.0	2019-11-16 19:22:03.598	error	(11832) at client.get (C:\Program Files\iobroker\IOB\node_modules\iobroker.js-controller\lib\states\statesInRedis.js:483:33)
    javascript.0	2019-11-16 19:22:03.598	error	(11832) at adapter.getForeignState (C:\Program Files\iobroker\IOB\node_modules\iobroker.javascript\main.js:855:17)
    javascript.0	2019-11-16 19:22:03.598	error	(11832) at createProblemObject (C:\Program Files\iobroker\IOB\node_modules\iobroker.javascript\main.js:1264:17)
    javascript.0	2019-11-16 19:22:03.598	error	(11832) at prepareScript (C:\Program Files\iobroker\IOB\node_modules\iobroker.javascript\main.js:1211:37)
    javascript.0	2019-11-16 19:22:03.598	error	(11832) at compile (C:\Program Files\iobroker\IOB\node_modules\iobroker.javascript\main.js:988:28)
    javascript.0	2019-11-16 19:22:03.598	error	(11832) at Object.createScript (vm.js:277:10)
    javascript.0	2019-11-16 19:22:03.598	error	(11832) at new Script (vm.js:83:7)
    javascript.0	2019-11-16 19:22:03.598	error	(11832) SyntaxError: Identifier 'htmlPart5' has already been declared
    javascript.0	2019-11-16 19:22:03.598	error	(11832) ^
    javascript.0	2019-11-16 19:22:03.598	error	(11832) const htmlPart5="<p style=\"color:#01DF01;font-size:130%; font-family:"+schriftart+";\"></br><b>!!! Script successful ... in part 1 - Instanz-Count ?? !!!</b>"+
    javascript.0	2019-11-16 19:22:03.597	error	at script.js.System.Proofingdatapoints1:1137
    javascript.0	2019-11-16 19:22:03.597	error	(11832) script.js.System.Proofingdatapoints1 compile failed:
    liv-in-skyL Offline
    liv-in-skyL Offline
    #275
    @sigi234
    da scheint das file nicht richtig kopiert zu sein - ich check mal ob was beim kpoieren verloren gegangen ist
    • sigi234S sigi234
      @liv-in-sky
      liv-in-skyL Offline
      liv-in-skyL Offline
      #276
      @sigi234 hab das file nochmal kopiert - erstellt
      ProofingDatapoints16-11-19.txt
      • liv-in-skyL liv-in-sky
        sigi234S Online
        sigi234S Online
        #277
        @liv-in-sky sagte in Script - Info über Datenpunkte sammeln:
        Läuft 👍
        Widget angepasst:
        Widget_Proofing_Datapoints_sigi234.txt
          neues update mit anzeige von history daten -. dazu den neuen datenpunkt "HistoryAnalyse" auf true setzen
          @crunchip - es werden hier im script nur noch 90 zeichen bei den id's angezeigt - ich hoffe mal, es schneidet nicht zu viel weg
          feedback wäre erwünscht
          crunchipC Offline
          crunchipC Offline
          #278
          @liv-in-sky sieht gut aus, wobei 100 Zeichen würden auch gehen, dann wären die letzten paar Zeichen von den "normal" langen id`s gar mit drauf. Scrollen muss man dann eh, wenn man den Rest sehen möchte.
          hab da skript durchlaufen lassen, war ok, danach hab ich ein paar Haken entfernt um ne andere Suche zu starten, jedoch blieb es dann beim letzten Punkt stehn, siehe Screen
          es will auch nicht mehr laufen, Instanz hab ich neu gestartet, trotzdem der gleiche Fehler
          javascript.1	2019-11-16 21:37:16.574	info	(10149) script.js.common.System.Datenpunktprüfung7: ------------ERROR: TypeError: Cannot convert undefined or null to object
          javascript.1	2019-11-16 21:37:13.174	info	(10149) script.js.common.System.Datenpunktprüfung7: bin in check SmartIot und History
          javascript.1	2019-11-16 21:37:13.171	info	(10149) script.js.common.System.Datenpunktprüfung7: bin raus aus check aliase
          javascript.1	2019-11-16 21:37:13.025	info	(10149) script.js.common.System.Datenpunktprüfung7: bin in check aliase
          javascript.1	2019-11-16 21:37:12.223	info	(10149) script.js.common.System.Datenpunktprüfung7: fertig in checkType mit CheckType
          javascript.1	2019-11-16 21:37:12.222	info	(10149) script.js.common.System.Datenpunktprüfung7: fertg bei checkType mit: javascript.1 und 1180 Durchläufen bisher
          javascript.1	2019-11-16 21:37:12.134	info	(10149) script.js.common.System.Datenpunktprüfung7: fertg bei checkType mit: javascript.0 und 702 Durchläufen bisher
          javascript.1	2019-11-16 21:37:12.047	warn	(10149) at Promise (script.js.common.System.Datenpunktprüfung7:249:26)
          javascript.1	2019-11-16 21:37:12.047	warn	(10149) at Object.result.each (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:806:29)
          javascript.1	2019-11-16 21:37:12.047	warn	(10149) at script.js.common.System.Datenpunktprüfung7:300:18
          javascript.1	2019-11-16 21:37:12.047	warn	(10149) getState "javascript.0.Gute_Nacht" not found (3) states[id]=null
          javascript.1	2019-11-16 21:37:12.046	warn	(10149) at Promise (script.js.common.System.Datenpunktprüfung7:249:26)
          javascript.1	2019-11-16 21:37:12.046	warn	(10149) at Object.result.each (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:806:29)
          javascript.1	2019-11-16 21:37:12.046	warn	(10149) at script.js.common.System.Datenpunktprüfung7:282:35
          javascript.1	2019-11-16 21:37:12.045	warn	(10149) getState "javascript.0.Gute_Nacht" not found (3) states[id]=null
          javascript.1	2019-11-16 21:37:12.023	warn	(10149) at Promise (script.js.common.System.Datenpunktprüfung7:249:26)
          javascript.1	2019-11-16 21:37:12.023	warn	(10149) at Object.result.each (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:806:29)
          javascript.1	2019-11-16 21:37:12.023	warn	(10149) at script.js.common.System.Datenpunktprüfung7:300:18
          javascript.1	2019-11-16 21:37:12.023	warn	(10149) getState "javascript.0.Fussball" not found (3) states[id]=null
          javascript.1	2019-11-16 21:37:12.022	warn	(10149) at Promise (script.js.common.System.Datenpunktprüfung7:249:26)
          javascript.1	2019-11-16 21:37:12.022	warn	(10149) at Object.result.each (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:806:29)
          javascript.1	2019-11-16 21:37:12.022	warn	(10149) at script.js.common.System.Datenpunktprüfung7:282:35
          javascript.1	2019-11-16 21:37:12.021	warn	(10149) getState "javascript.0.Fussball" not found (3) states[id]=null
          javascript.1	2019-11-16 21:37:11.955	info	(10149) script.js.common.System.Datenpunktprüfung7: fertg bei checkType mit: 0_userdata.0 und 15 Durchläufen bisher
          javascript.1	2019-11-16 21:37:11.955	warn	(10149) at Promise (script.js.common.System.Datenpunktprüfung7:249:26)
          javascript.1	2019-11-16 21:37:11.954	warn	(10149) at Object.result.each (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:806:29)
          javascript.1	2019-11-16 21:37:11.954	warn	(10149) at script.js.common.System.Datenpunktprüfung7:300:18
          javascript.1	2019-11-16 21:37:11.953	warn	(10149) getState "0_userdata.0.example_state" not found (3) states[id]=null
          javascript.1	2019-11-16 21:37:11.952	warn	(10149) at Promise (script.js.common.System.Datenpunktprüfung7:249:26)
          javascript.1	2019-11-16 21:37:11.952	warn	(10149) at Object.result.each (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:806:29)
          javascript.1	2019-11-16 21:37:11.952	warn	(10149) at script.js.common.System.Datenpunktprüfung7:282:35
          javascript.1	2019-11-16 21:37:11.951	warn	(10149) getState "0_userdata.0.example_state" not found (3) states[id]=null
          javascript.1	2019-11-16 21:37:11.898	info	(10149) script.js.common.System.Datenpunktprüfung7: fertg bei checkType mit: kamera.0 und 14 Durchläufen bisher
          javascript.1	2019-11-16 21:37:11.841	info	(10149) script.js.common.System.Datenpunktprüfung7: fertg bei checkType mit: Meine_Geräte.0 und 8 Durchläufen bisher
          javascript.1	2019-11-16 21:37:11.786	info	(10149) script.js.common.System.Datenpunktprüfung7: fertg bei checkType mit: Mein_TV.0 und 3 Durchläufen bisher
          javascript.1	2019-11-16 21:37:10.930	info	(10149) script.js.common.System.Datenpunktprüfung7: bin in check types
          javascript.1	2019-11-16 21:37:10.926	info	(10149) script.js.common.System.Datenpunktprüfung7: bin raus aus check Werte
          javascript.1	2019-11-16 21:37:10.925	info	(10149) script.js.common.System.Datenpunktprüfung7: bin raus aus check Werte bei :javascript.1
          javascript.1	2019-11-16 21:37:10.847	info	(10149) script.js.common.System.Datenpunktprüfung7: bin raus aus check Werte bei :javascript.0
          javascript.1	2019-11-16 21:37:10.814	warn	(10149) at Promise (script.js.common.System.Datenpunktprüfung7:366:27)
          javascript.1	2019-11-16 21:37:10.814	warn	(10149) at Object.result.each (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:806:29)
          javascript.1	2019-11-16 21:37:10.814	warn	(10149) at script.js.common.System.Datenpunktprüfung7:400:74
          javascript.1	2019-11-16 21:37:10.813	warn	(10149) getState "javascript.0.Gute_Nacht" not found (3) states[id]=null
          javascript.1	2019-11-16 21:37:10.813	warn	(10149) at Promise (script.js.common.System.Datenpunktprüfung7:366:27)
          javascript.1	2019-11-16 21:37:10.812	warn	(10149) at Object.result.each (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:806:29)
          javascript.1	2019-11-16 21:37:10.812	warn	(10149) at script.js.common.System.Datenpunktprüfung7:399:44
          javascript.1	2019-11-16 21:37:10.811	warn	(10149) getState "javascript.0.Gute_Nacht" not found (3) states[id]=null
          javascript.1	2019-11-16 21:37:10.811	warn	(10149) at Promise (script.js.common.System.Datenpunktprüfung7:366:27)
          javascript.1	2019-11-16 21:37:10.810	warn	(10149) at Object.result.each (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:806:29)
          javascript.1	2019-11-16 21:37:10.810	warn	(10149) at script.js.common.System.Datenpunktprüfung7:389:36
          javascript.1	2019-11-16 21:37:10.809	warn	(10149) getState "javascript.0.Gute_Nacht" not found (3) states[id]=null
          javascript.1	2019-11-16 21:37:10.787	warn	(10149) at Promise (script.js.common.System.Datenpunktprüfung7:366:27)
          javascript.1	2019-11-16 21:37:10.787	warn	(10149) at Object.result.each (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:806:29)
          javascript.1	2019-11-16 21:37:10.787	warn	(10149) at script.js.common.System.Datenpunktprüfung7:400:74
          javascript.1	2019-11-16 21:37:10.786	warn	(10149) getState "javascript.0.Fussball" not found (3) states[id]=null
          javascript.1	2019-11-16 21:37:10.786	warn	(10149) at Promise (script.js.common.System.Datenpunktprüfung7:366:27)
          javascript.1	2019-11-16 21:37:10.785	warn	(10149) at Object.result.each (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:806:29)
          javascript.1	2019-11-16 21:37:10.776	warn	(10149) at script.js.common.System.Datenpunktprüfung7:399:44
          javascript.1	2019-11-16 21:37:10.775	warn	(10149) getState "javascript.0.Fussball" not found (3) states[id]=null
          javascript.1	2019-11-16 21:37:10.775	warn	(10149) at Promise (script.js.common.System.Datenpunktprüfung7:366:27)
          javascript.1	2019-11-16 21:37:10.775	warn	(10149) at Object.result.each (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:806:29)
          javascript.1	2019-11-16 21:37:10.774	warn	(10149) at script.js.common.System.Datenpunktprüfung7:389:36
          javascript.1	2019-11-16 21:37:10.774	warn	(10149) getState "javascript.0.Fussball" not found (3) states[id]=null
          javascript.1	2019-11-16 21:37:10.664	info	(10149) script.js.common.System.Datenpunktprüfung7: bin raus aus check Werte bei :0_userdata.0
          javascript.1	2019-11-16 21:37:10.664	warn	(10149) at Promise (script.js.common.System.Datenpunktprüfung7:366:27)
          javascript.1	2019-11-16 21:37:10.664	warn	(10149) at Object.result.each (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:806:29)
          javascript.1	2019-11-16 21:37:10.663	warn	(10149) at script.js.common.System.Datenpunktprüfung7:400:74
          javascript.1	2019-11-16 21:37:10.663	warn	(10149) getState "0_userdata.0.example_state" not found (3) states[id]=null
          javascript.1	2019-11-16 21:37:10.662	warn	(10149) at Promise (script.js.common.System.Datenpunktprüfung7:366:27)
          javascript.1	2019-11-16 21:37:10.662	warn	(10149) at Object.result.each (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:806:29)
          javascript.1	2019-11-16 21:37:10.661	warn	(10149) at script.js.common.System.Datenpunktprüfung7:399:44
          javascript.1	2019-11-16 21:37:10.660	warn	(10149) getState "0_userdata.0.example_state" not found (3) states[id]=null
          javascript.1	2019-11-16 21:37:10.659	warn	(10149) at Promise (script.js.common.System.Datenpunktprüfung7:366:27)
          javascript.1	2019-11-16 21:37:10.658	warn	(10149) at Object.result.each (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:806:29)
          javascript.1	2019-11-16 21:37:10.658	warn	(10149) at script.js.common.System.Datenpunktprüfung7:389:36
          javascript.1	2019-11-16 21:37:10.643	warn	(10149) getState "0_userdata.0.example_state" not found (3) states[id]=null
          javascript.1	2019-11-16 21:37:10.588	info	(10149) script.js.common.System.Datenpunktprüfung7: bin raus aus check Werte bei :kamera.0
          javascript.1	2019-11-16 21:37:10.514	info	(10149) script.js.common.System.Datenpunktprüfung7: bin raus aus check Werte bei :Meine_Geräte.0
          javascript.1	2019-11-16 21:37:10.461	info	(10149) script.js.common.System.Datenpunktprüfung7: bin raus aus check Werte bei :Mein_TV.0
          javascript.1	2019-11-16 21:37:09.603	info	(10149) script.js.common.System.Datenpunktprüfung7: bin in check Werte
          javascript.1	2019-11-16 21:37:09.601	info	(10149) script.js.common.System.Datenpunktprüfung7: bin raus aus count
          javascript.1	2019-11-16 21:37:09.586	info	(10149) script.js.common.System.Datenpunktprüfung7: bin richtig in count
          javascript.1	2019-11-16 21:37:08.225	info	(10149) script.js.common.System.Datenpunktprüfung7: _______bin raus aus check Instanz
          javascript.1	2019-11-16 21:37:07.416	info	(10149) script.js.common.System.Datenpunktprüfung7: _______bin in check Instanz
          javascript.1	2019-11-16 21:37:07.409	info	(10149) script.js.common.System.Datenpunktprüfung7: _______________________ starte MAIN
          javascript.1	2019-11-16 21:36:54.038	info	(10149) script.js.common.System.Datenpunktprüfung7: registered 2 subscriptions and 0 schedules
          javascript.1	2019-11-16 21:36:54.004	info	(10149) Start javascript script.js.common.System.Datenpunktprüfung7
            liv-in-skyL Offline
            liv-in-skyL Offline
            #279
            @crunchip das is ja "komisch" - das es einmal läuft und dann nicht mehr
            kommt der fehler auch, wenn du die history analyse nicht aktivierst
              crunchipC Offline
              crunchipC Offline
              #280
              @liv-in-sky ohne History funktioniert es
              wenn ich alleinig nur
              History Prüfung aktiviere, bleibt es auch fehlerhaft stehn, also liegt es dev an History Prüfung
                liv-in-skyL Offline
                liv-in-skyL Offline
                #281
                @crunchip
                ich mach morgen ein script mit log - es scheint, das eine definition bei dir drin ist, die ich nicht berücksichtige - wir müssen den datenpunkt finden un diese def finden
                wenn du lust hast - hier das log mal einfügen - vielleicht reicht das schon - dann wissen wir schon mal die id - und bei diesem datenpunkt das raw format ansehen
                  @crunchip
                  crunchipC Offline
                  crunchipC Offline
                  #282
                  @liv-in-sky hab ich gemacht, kann aber nicht viel damit anfangen
                  liegt bestimmt an deinen Rechtschreibfehlern im Script😁 Spass
                  denke es ist der mclighting, der zwar installiert aber noch nie benutzt wurde
                  javascript.1	2019-11-16 22:46:53.932	warn	(10149) at instanzCount (script.js.common.System.Datenpunktprüfung7:100:12)
                  javascript.1	2019-11-16 22:46:53.932	warn	(10149) at new Promise (<anonymous>:null:null)
                  javascript.1	2019-11-16 22:46:53.932	warn	(10149) at Promise (script.js.common.System.Datenpunktprüfung7:112:29)
                  javascript.1	2019-11-16 22:46:53.931	warn	(10149) at Object.result.each (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:806:29)
                  javascript.1	2019-11-16 22:46:53.931	warn	(10149) at script.js.common.System.Datenpunktprüfung7:131:9
                  javascript.1	2019-11-16 22:46:53.930	warn	(10149) getState "system.adapter.mclighting.0.alive" not found (3) states[id]=null
                  javascript.1	2019-11-16 22:46:53.930	warn	(10149) at instanzCount (script.js.common.System.Datenpunktprüfung7:100:12)
                  javascript.1	2019-11-16 22:46:53.929	warn	(10149) at new Promise (<anonymous>:null:null)
                  javascript.1	2019-11-16 22:46:53.929	warn	(10149) at Promise (script.js.common.System.Datenpunktprüfung7:112:29)
                  javascript.1	2019-11-16 22:46:53.929	warn	(10149) at Object.result.each (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:806:29)
                  javascript.1	2019-11-16 22:46:53.928	warn	(10149) at script.js.common.System.Datenpunktprüfung7:128:9
                  javascript.1	2019-11-16 22:46:53.927	warn	(10149) getState "system.adapter.mclighting.0.alive" not found (3) states[id]=null
                    liv-in-skyL Offline
                    liv-in-skyL Offline
                    #283
                    @crunchip mit diesem ausschnitt kann ich nicht viel anfangen - das müßte ganz woanders sein und sorgt auch nicht für das stehenbleiben
                    diese rausschnitt ist doch mittendrin - denke ich - es muss aber am ende im log sein (also ganz oben im log-tab)
                    schalte auf jeden fall die wert und type analyse mal ab
                    diese zeile muss schon vorbei sein - anschliessend kommen dann die gesuchten id's
                      crunchipC Offline
                      crunchipC Offline
                      #284
                      @liv-in-sky
                      ich hatte alles ausgeschaltet, war nur History aktiviert.
                      Das waren die ersten Warnmeldungen bei scriptstart.
                      nach check smartIot
                      werden alle Datenpunke gelistet und die letzte Zeilenausgabe ist
                      info: javascript.1 (10149) script.js.common.System.Datenpunktprüfung7: ------------ERROR: TypeError: Cannot convert undefined or null to object
                        @liv-in-sky
                        nach check smartIot
                        liv-in-skyL Offline
                        liv-in-skyL Offline
                        #285
                        @crunchip und der datenpunkt davor (vor dieser ausgabe) ist das problem - du bist sehr sparsam mit den logs - zu sparsam
                          crunchipC Offline
                          crunchipC Offline
                          #286
                          @liv-in-sky haha, woher soll ich denn wissen das du den davor brauchst😂
                          die raw dazu
                            "_id": "mihome.0.devices.magnet_158d00023700c4.state",
                            "common": {
                              "name": "Haustür",
                              "role": "state",
                              "write": false,
                              "read": true,
                              "type": "boolean",
                              "custom": {
                                "influxdb.1": {
                                  "enabled": true,
                                  "changesOnly": true,
                                  "debounce": "1000",
                                  "maxLength": 10,
                                  "retention": "31536000",
                                  "changesRelogInterval": 0,
                                  "changesMinDelta": 0,
                                  "storageType": "",
                                  "aliasId": "Haustür"
                                "telegram.0": {
                                  "enabled": true,
                                  "readOnly": true,
                                  "report": true,
                                  "alias": "Haustuer",
                                  "onStatus": "offen",
                                  "offStatus": "geschlossen",
                                  "onCommand": "",
                                  "offCommand": "geschlossen",
                                  "onlyTrue": false,
                                  "buttons": 1
                            "type": "state",
                            "native": {},
                            "from": "system.adapter.mihome.0",
                            "ts": 1537861679074,
                            "acl": {
                              "object": 1636,
                              "state": 1636,
                              "owner": "system.user.admin",
                            "user": "system.user.admin"
                            die raw dazu
                              "common": {
                                "name": "Haustür",
                                "role": "state",
                                "write": false,
                                "read": true,
                                "type": "boolean",
                                "custom": {
                                  "influxdb.1": {
                                    "enabled": true,
                                    "debounce": "1000",
                                    "maxLength": 10,
                                    "storageType": "",
                                  "telegram.0": {
                                    "enabled": true,
                                    "readOnly": true,
                                    "report": true,
                                    "onCommand": "",
                                    "onlyTrue": false,
                                    "buttons": 1
                              "type": "state",
                              "native": {},
                              "acl": {
                                "object": 1636,
                                "state": 1636,
                            liv-in-skyL Offline
                            liv-in-skyL Offline
                            #287
                            @crunchip auf den ersten blick schaut er ganz gut aus
                            ich schau mir das morgen an - gute nacht
                              crunchipC Offline
                              crunchipC Offline
                              #288
                              @liv-in-sky ich vergleich gerade mit den anderen
                              was mir auffällt, es fehlt der iot.0 smartname eintrag
                                liv-in-skyL Offline
                                liv-in-skyL Offline
                                #289
                                @crunchip
                                wir suchen ja das hier
                                    "custom": {
                                      "influxdb.1": {
                                das ist der history eintrag
                                  liv-in-skyL Offline
                                  liv-in-skyL Offline
                                  #290
                                  @crunchip moin - jetzt wieder etwas wacher - konnte fehler reproduzieren und hoffentlich bereinigen und natürlich konntest du nicht wissen, dass ich den datenpunkt davor brauche - irgendwann ist man so im script vertieft, dass man nicht mehr merkt, dass andere diese struktur garnicht kennen können - sorry dafür
                                  aber hier mal eine neue version - wäre cool , wenn du es testen könntest
                                  ProofingDatapoints17-11-19.txt
                                  falls es wieder einen fehler geben sollte, könntest du oben - irgendwo in der variablen definition (ca: zeile 55)- die variable "histlogs" auf true setzen - , dann gibt es zusätzliche log-einträge
                                    crunchipC Offline
                                    crunchipC Offline
                                    #291
                                    @liv-in-sky läuft, Problem beseitigt👍
