  4. Rollosteuerung-Umstieg CCU3 Programmen zu ioBroker
iobrokerskriptrollorollladenrollladensteuerung
145 Beiträge 7 Kommentatoren 20.9k Aufrufe 2 Beobachtet
  • Uli977U Uli977
    @paul53 Suuuuper! Sendest du mir das noch mal
    @Uli977 sagte:
    Dann musst Du wieder die IDs zuweisen.
     <variables>
       <variable type="" id="Ncm:X[qf:qS{6|5({cYM">tuer_offen</variable>
       <variable type="" id="j6xqRg,0SMV@dV4NHczA">dunkel</variable>
     </variables>
     <block type="variables_set" id="gAb$7n%a,,J.a~f]K77{" x="188" y="-113">
       <field name="VAR" id="Ncm:X[qf:qS{6|5({cYM" variabletype="">tuer_offen</field>
       <value name="VALUE">
         <block type="get_value" id="{9C%B.~.TrN)fEce(/JE">
           <field name="OID">ID auswählen</field>
         </block>
       </value>
       <next>
         <block type="variables_set" id="UkN0UD6R.OlLKRQ%^uBV">
           <field name="VAR" id="j6xqRg,0SMV@dV4NHczA" variabletype="">dunkel</field>
             <block type="get_value" id="^BbmswjqJ,bm/]D$i|Kl">
             </block>
           </value>
           <next>
             <block type="comment" id=")T/!1_tE#M,@]tghE6Vf">
               <field name="COMMENT">Schiebetür</field>
               <next>
                 <block type="on_ext" id="G0X`qA)3/2u@!M/okZRK">
                   <mutation items="1"></mutation>
                   <value name="OID0">
                     <shadow type="field_oid" id="T6nnPV.6Ufkya4tl%RfN">
                     </shadow>
                   </value>
                   <statement name="STATEMENT">
                     <block type="variables_set" id="5xajAGtkxz{^!,(W=(^:">
                         <block type="on_source" id="9#^L{LOd`WZ{O/}Bn(ns">
                         </block>
                       </value>
                       <next>
                         <block type="procedures_callnoreturn" id="P@!4RMF;=J|_rhpD~r.9">
                           <mutation name="Rollo_runter"></mutation>
                         </block>
                       </next>
                     </block>
                   </statement>
                   <next>
                     <block type="comment" id="|,79-+_kjZ898uw,Up1%">
                       <field name="COMMENT">Helligkeitsschwelle erreicht</field>
                       <next>
                         <block type="on_ext" id="6+BS?{POpim1T~DugodW">
                           <value name="OID0">
                             <shadow type="field_oid" id="+9+j.T_9FOd%|dfm0z2:">
                             </shadow>
                           </value>
                             <block type="variables_set" id="5],2lBC-8i$=iUS6D]v[">
                                 <block type="on_source" id="H]Wf{f,Z[@kYNQCorCCA">
                                 </block>
                               </value>
                               <next>
                                 <block type="procedures_callnoreturn" id="m6j/x(hMJ4}xYMY)ltmN">
                                 </block>
                               </next>
                             </block>
                           </statement>
                           <next>
                             <block type="schedule" id="z}9=peP`Np}HCGcG]H4N">
                               <field name="SCHEDULE">16 17 * * *</field>
                                 <block type="procedures_callnoreturn" id="JgWWs`v3dCrP3Nl*i2VJ">
                                 </block>
                               </statement>
                             </block>
                           </next>
                         </block>
                       </next>
                     </block>
                   </next>
                 </block>
               </next>
             </block>
           </next>
         </block>
       </next>
     </block>
     <block type="procedures_defnoreturn" id="DG*{%6FZcIc4OF!,i|%R" x="388" y="263">
       <field name="NAME">Rollo_runter</field>
       <statement name="STACK">
         <block type="controls_if" id="tdGRY_XXa2{VzcrPdo`X">
           <value name="IF0">
             <block type="logic_operation" id="#Sqmhh]+HY4bK|A}g4aV" inline="false">
               <field name="OP">AND</field>
               <value name="A">
                 <block type="logic_operation" id="H+swYqDLmHSkPA77RCSm" inline="false">
                   <value name="A">
                     <block type="logic_operation" id="~FWc]L|Rh!.[hZol#S@k" inline="false">
                       <value name="A">
                         <block type="logic_negate" id="5PB*=4m[(kSm5m0WlDxb">
                           <value name="BOOL">
                             <block type="variables_get" id="IvB#K}=Fq/H@uO3U2|m3">
                             </block>
                           </value>
                         </block>
                       </value>
                       <value name="B">
                         <block type="variables_get" id="B.S~!in1KdFCNM_lbIbk">
                         </block>
                       </value>
                     </block>
                   </value>
                   <value name="B">
                     <block type="logic_compare" id="F7N]QkM}NS*f=B[/k$e%">
                       <field name="OP">GT</field>
                       <value name="A">
                         <block type="get_value" id="OJ.T4e%WQ7q9`3E{`Sfq">
                         </block>
                       </value>
                       <value name="B">
                         <block type="math_number" id="`w$Z/-wnD;[)ZJV(z)%u">
                           <field name="NUM">60</field>
                         </block>
                       </value>
                     </block>
                   </value>
                 </block>
               </value>
               <value name="B">
                 <block type="logic_operation" id="$VioK9^FeRBjeFaN]4Yx" inline="false">
                   <value name="A">
                     <block type="logic_negate" id="?[]Ik3_heYZz:@.;L_BX">
                       <value name="BOOL">
                         <block type="get_value" id="J$lhf1:m-M(E]h|iq*h#">
                         </block>
                       </value>
                     </block>
                   </value>
                   <value name="B">
                     <block type="time_compare" id="1}33Tf8ODVa8[j:0yJG/">
                       <mutation end_time="false"></mutation>
                       <field name="OPTION">&gt;</field>
                       <field name="START_TIME">17:15</field>
                     </block>
                   </value>
                 </block>
               </value>
             </block>
           </value>
           <statement name="DO0">
             <block type="control" id="gQWTv7A5fMV%1l7v^DhD">
               <mutation delay_input="true"></mutation>
               <field name="DELAY_MS">8</field>
                 <block type="math_number" id="2vW,eFl#4D4NS^nVICxe">
                 </block>
               </value>
             </block>
           </statement>
         </block>
       </statement>
     </block>
     <block type="comment" id="gxRodVCk{$PGmo1krlu3" x="988" y="387">
       <field name="COMMENT">Auto</field>
     </block>
    </xml>
    EDIT: Habe noch die Initialisierung der Variablen bei Skriptstart ergänzt.
      @Uli977 sagte:
      Also doch mit Zeitplan
      Ja, mehrere Trigger, Variablen und eine Funktion verwenden.
      Uli977U Offline
      Uli977U Offline
      Uli977
      lasse ich die beiden Bausteine so unverbunden im Raum stehen?
      • Uli977U Uli977
        @Uli977 sagte:
        Welche Bausteine ?
        Die nachträgliche Ergänzung um die Variableninitialisierung hast Du gesehen ?
        Uli977U 1 Antwort Letzte Antwort
          @Uli977 sagte:
          Welche Bausteine ?
          Uli977U Offline
          Uli977U Offline
          Uli977
          Das der hier so einzel steht, siehe Kreis.
          • Uli977U Uli977
            @Uli977 sagte:
            siehe Kreis.
            Das ist die Funktion Rollo_runter, die in jedem Trigger aufgerufen wird.
              @Uli977 sagte:
              siehe Kreis.
              Uli977U Offline
              Uli977U Offline
              Uli977
              @paul53 So?
              • Uli977U Uli977
                @paul53 So?
                @Uli977 sagte:
                So?
                Nicht ganz: BRIGHTNESS ist der Helligkeitswert. Nimm die SV "Helligkeitsschwelle Rollos" solange keine eigener Datenpunkt in ioBroker dafür existiert.
                  @Uli977 sagte:
                  So?
                  Uli977U Offline
                  Uli977U Offline
                  Uli977
                  @paul53 Habe ich angepasst und es funktioniert! Vielen Dank dafür!
                  Ich will dies nun mal nachvollziehen..
                  setze tuer_offen
                  setze dunkel auf
                  • die Bedeutung verstehe ich nicht
                  Schiebetür
                  • wenn Schiebetür Wert geändert, dann setze auf tuer_offen ->ich mache die Tür auf und Rollo runter wird gesetzt... aber nicht aus geführt weil
                    a8808090-320b-436d-9c60-0f8fe7646af7-image.png nicht erfüllt ist
                  Richtig?
                  Ich habe den Zeitplan wie folgt geändert.
                  Wieso fährt das Rollo nicht herunter wenn ich das Rollo zuvor manuell hoch gefahren habe aber die Tür nicht geöffnet habe?
                  • Uli977U Uli977
                    setze tuer_offen
                    setze dunkel auf
                    Schiebetür
                    Richtig?
                    @Uli977 sagte:
                    Habe ich angepasst
                    Die Variable dunkel wird noch falsch initialisiert. Es ist doch dunkel, wenn die SV "Helligkeitsschwelle Rollos" true ist ?
                      @Uli977 sagte:
                      Habe ich angepasst
                      Uli977U Offline
                      Uli977U Offline
                      Uli977
                      schrieb am zuletzt editiert von Uli977
                      @paul53 So
                      Und warum löst der Zeitplan nicht aus?
                      • Uli977U Uli977
                        @paul53 So
                        @Uli977 sagte:
                        So
                        Nein, dann wird die Variable dunkel nie wieder false.
                        Meine Frage bezog sich darauf, ob bei Dunkelheit der Wert der SV true ist.
                        @Uli977 sagte in Rollosteuerung-Umstieg CCU3 Programmen zu ioBroker:
                        Keine Ahnung ? Die anderen Bedingungen sind erfüllt ?
                          @Uli977 sagte:
                          So
                          Uli977U Offline
                          Uli977U Offline
                          Uli977
                          SV Helligkeitsschwelle Rollos ist auf true
                          • Uli977U Uli977
                            @paul53 So?
                            @Uli977
                            Eine Bedingung ist "aktuelle Zeit ist größer als 17:15". Dann muss nach 17:15 Uhr getriggert werden (ich hatte 17:16 Uhr vorgegeben).
                              @Uli977
                              Uli977U Offline
                              Uli977U Offline
                              Uli977
                              @paul53 So hab ich es jetzt gemacht
                              • Objekte in ioBroker
                              • Auslöser für Rollo runter sind Helligkeitsschwelle_halb bzw. Helligkeitsschwelle_schließen und das schließen des Fensters/Tür
                              • Auslöser für Rollo hoch ist die Uhrzeit Werktag oder Wochenende
                              Dies spiegelt nun meine Programm in der HM CCU wieder.
                              Danke für deine Hilfe und Denkanstöße!
                              Viele Grüße!
                              dslraserD paul53P 2 Antworten Letzte Antwort
                              • Uli977U Uli977
                                Viele Grüße!
                                dslraserD Offline
                                dslraserD Offline
                                dslraser
                                @Uli977
                                Du wolltest ja den Wert der Helligkeitsschwelle nicht in jedem Script ändern müssen, wenn es noch mehr Scripte werden....
                                Lege Dir doch zwei Datenpunkte vom Typ Zahl an und schreibe da Deine Helligkeitsschwellen rein. Dann kannst Du in Deinen Scripten immer diesen Bezug verwenden.
                                Also Sensorwert kleiner neuer Datenpunkt, dann Schwelle auf wahr, sonst falsch.
                                Wenn Du dann mal den "Bezugswert" ändern möchtest, dann brauchst Du es nur ein einer Stelle ändern und nicht in jedem Script.
                                Werde ich für mein Beispiel von weiter oben für die Lichtschaltung auch noch ändern.
                                Uli977U paul53P 2 Antworten Letzte Antwort
                                • Uli977U Uli977
                                  Viele Grüße!
                                  @Uli977
                                  Zwei identische Trigger vermeidet man (Resourcenverschwendung), indem die zugehörigen Aktionen (2 Datenpunkte "Helligkeitsschwelle" setzen) innerhalb eines Triggers erfolgen.
                                  • dslraserD dslraser
                                    @Uli977
                                    Uli977U Offline
                                    Uli977U Offline
                                    Uli977
                                    @dslraser Das habe ich nicht verstanden....
                                      @Uli977
                                      #66
                                      @dslraser sagte:
                                      Die beiden Datenpunkte "Helligkeitsschwelle_halb" und "Helligkeitsschwelle_schließen" können in weiteren Scripts verwendet werden.
                                      @Uli977 sagte:
                                      @dslraser schlägt vor, die beiden Grenzwerte (100, 120) in Datenpunkten zu halten.
                                        @dslraser sagte:
                                        @Uli977 sagte:
                                        Uli977U Offline
                                        Uli977U Offline
                                        Uli977
                                        #67
                                        @paul53 Ich glaube ich weiss ungefährt was ihr meint, aber ich weiss nicht wie ich es umsetze.
                                        Wiso kann ich eigentlich mein Skript nicht Spoilern. Der sagt mir immer zu viele zeichen.
                                        Gruß!
                                        • Uli977U Uli977
                                          Gruß!
                                          #68
                                          @Uli977 sagte:
                                          Lass es wie es ist, aber packe die Schwellwert-Geschichte in einen Trigger.
                                          Übrigens, was passiert wenn es vor 17:15 Uhr schon dunkel (< 100) ist ?
