  4. [gelöst] BLE, Zigbee, Radar Adapter rot....
npmbluetoothradar2zigbeebleconbeedeconz
13 Beiträge 3 Kommentatoren 915 Aufrufe 3 Beobachtet
  • sigi234S sigi234
    @jhuebner1
    Was kommt bei:
    cd /opt/iobroker
    iobroker list instances
    node -v
    nodejs -v
    npm -v
    jhuebner1
    @sigi234
    + system.adapter.admin.0                 : admin       -  enabled, port: 8081, b                    ind: 0.0.0.0, run as: admin
    + system.adapter.backitup.0              : backitup    -  enabled
      system.adapter.ble.0                   : ble         -  enabled
    + system.adapter.broadlink2.0            : broadlink2  -  enabled
    + system.adapter.cloud.0                 : cloud       -  enabled
      system.adapter.daswetter.0             : daswetter   -  enabled
      system.adapter.deconz.0                : deconz      -  enabled, port: 80
    + system.adapter.discovery.0             : discovery   -  enabled
      system.adapter.dwd.0                   : dwd         -  enabled
      system.adapter.flot.0                  : flot        -  enabled
    + system.adapter.history.0               : history     -  enabled
    + system.adapter.hmip.0                  : hmip        -  enabled
    + system.adapter.hue.0                   : hue         -  enabled, port: 80
      system.adapter.ical.0                  : ical        -  enabled
    + system.adapter.influxdb.0              : influxdb    -  enabled, port: 8086
    + system.adapter.info.0                  : info        -  enabled
    + system.adapter.javascript.0            : javascript  -  enabled
    + system.adapter.mihome.0                : mihome      -  enabled, port: 9898, b                    ind: 0.0.0.0
      system.adapter.mobile.0                : mobile      -  enabled
    + system.adapter.ping.0                  : ping        -  enabled
    + system.adapter.pushbullet.0            : pushbullet  -  enabled
      system.adapter.radar2.0                : radar2      -  enabled
    + system.adapter.scenes.0                : scenes      -  enabled
    + system.adapter.sonoff.0                : sonoff      -  enabled, port: 1884, b                    ind: 0.0.0.0
    + system.adapter.tankerkoenig.0          : tankerkoenig -  enabled
      system.adapter.tvspielfilm.0           : tvspielfilm -  enabled
      system.adapter.vis-colorpicker.0       : vis-colorpicker -  enabled
      system.adapter.vis-hqwidgets.0         : vis-hqwidgets -  enabled
      system.adapter.vis-metro.0             : vis-metro   -  enabled
      system.adapter.vis-timeandweather.0    : vis-timeandweather -  enabled
      system.adapter.vis-weather.0           : vis-weather -  enabled
      system.adapter.vis.0                   : vis         -  enabled
    + system.adapter.web.0                   : web         -  enabled, port: 8082, b                    ind: 0.0.0.0, run as: admin
      system.adapter.zigbee.0                : zigbee      -  enabled
    + instance is alive
    Node ist v12.13.0
    NodeJS ist v10.15.2
    NPM ist 6.12.1
    • Jey CeeJ Jey Cee
      @jhuebner1 bitte code und logs in Code tags (6) Packen. Es ist super schlecht zu lesen und unübersichtlich vor allem auf Mobilen Geräten.
      Bitte hol das nach, dafür gibt es die Bearbeiten funktion rechts unten am Beitrag im 3 Punkte Menü.
      Du meinst wohl alles was über USB angeschlossen ist geht nicht mehr.
      jhuebner1
      @Jey-Cee
      Erledigt, sorry, kannte die Funktion nicht...
      • J jhuebner1
        @sigi234
        + instance is alive
        Node ist v12.13.0
        NodeJS ist v10.15.2
        NPM ist 6.12.1
        sigi234S Online
        sigi234S Online
        @jhuebner1 sagte in BLE, Zigbee, Radar und Decon Adapter rot....:
        Node ist v12.13.0
        NodeJS ist v10.15.2
        NPM ist 6.12.1
        Node Versionen sollten gleich sein, gehe auf Node 10..... !
        https://forum.iobroker.net/topic/22867/how-to-node-js-für-iobroker-richtig-updaten
        • sigi234S sigi234
          Node ist v12.13.0
          NodeJS ist v10.15.2
          NPM ist 6.12.1
          jhuebner1
          @sigi234
          Klappt nicht... er will auf Teufel komm raus nicht von der 12er weg....
          Und ja, ich hab den Link gelöesen und dort auch die Schritte ausgeführt, aber irgendwie will was nicht...
          • J jhuebner1
            @sigi234
            sigi234S Online
            sigi234S Online
            @sigi234
            https://www.iobroker.net/#de/documentation/trouble/RunsNoMore.md
            Letzer Teil
            • sigi234S sigi234
              @sigi234
              Letzer Teil
              jhuebner1
              schrieb am zuletzt editiert von jhuebner1
              @sigi234
              Alles gemacht (Link letzter Block ganz unten):
              pi@raspberrypi:~ $ sudo apt-get install -y nodejs
              Die folgenden NEUEN Pakete werden installiert:
                nodejs
              0 aktualisiert, 1 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
              Es müssen noch 0 B von 14,2 MB an Archiven heruntergeladen werden.
              Nach dieser Operation werden 72,5 MB Plattenplatz zusätzlich benutzt.
              Vormals nicht ausgewähltes Paket nodejs wird gewählt.
              (Lese Datenbank ... 148352 Dateien und Verzeichnisse sind derzeit installiert.)
              Vorbereitung zum Entpacken von .../nodejs_10.17.0-1nodesource1_armhf.deb ...
              Entpacken von nodejs (10.17.0-1nodesource1) ...
              nodejs (10.17.0-1nodesource1) wird eingerichtet ...
              Trigger für man-db (2.8.5-2) werden verarbeitet ...
              pi@raspberrypi:~ $ node -v
              v12.13.0
              Jetzt hab ich bei NODEJS zwar 10, aber bei Node immer noch 12
              Und ich alles das hier laufen lassen:
              sudo apt-get --purge remove node
              sudo apt-get --purge remove nodejs
              sudo apt-get autoremove
              curl -sL https://deb.nodesource.com/setup_10.x | sudo -E bash -
              node -v
              • J jhuebner1
                @sigi234
                  nodejs
                v12.13.0
                node -v
                sigi234S Online
                sigi234S Online
                @sigi234
                  nodejs
                v12.13.0
                node -v
                Das auch:
                cd /opt/iobroker
                npm rebuild
                • sigi234S sigi234
                  @sigi234
                    nodejs
                  v12.13.0
                  node -v
                  Das auch:
                  cd /opt/iobroker
                  npm rebuild
                  jhuebner1
                  @sigi234
                  Läuft gerade....
                  Ich dachte (ohne AHnung zu haben), das Node und NodeJS zusammenhängen, aber das das nicht was mit dem iobroker NPM zu tun hat....
                  Das sieht nicht so gut aus... lief jetzt ganz gut durch und am Schluss das hier:
                  gyp ERR! build error
                  gyp ERR! stack Error: `make` failed with exit code: 2
                  gyp ERR! stack     at ChildProcess.onExit (/usr/local/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:194:23)
                  gyp ERR! stack     at ChildProcess.emit (events.js:210:5)
                  gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:272:12)
                  gyp ERR! System Linux 4.19.75-v7+
                  gyp ERR! command "/usr/local/bin/node" "/usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
                  gyp ERR! cwd /opt/iobroker/node_modules/iobroker.discovery/node_modules/serialport
                  gyp ERR! node -v v12.13.0
                  gyp ERR! node-gyp -v v5.0.5
                  gyp ERR! not ok
                  npm ERR! code ELIFECYCLE
                  npm ERR! errno 1
                  npm ERR! serialport@6.2.2 install: `prebuild-install || node-gyp rebuild`
                  npm ERR! Exit status 1
                  npm ERR!
                  npm ERR! Failed at the serialport@6.2.2 install script.
                  npm ERR!     /home/iobroker/.npm/_logs/2019-10-30T11_59_33_460Z-debug.log
                  • J Offline
                    jhuebner1
                    HAllo,
                    keiner eine Ahnung, wie ich den Pi zum Zwangs-Downgrade zwingen kann?
                    • J Offline
                      jhuebner1
                      hat sich erledigt....
                      Lag nicht an der Node oder NPM VBersion (da hab ich jetzt nichts neues geschafft), aber ich habe die Adapter mal händisch gelöscht und neu installiert im iobroker.
                      Jetzt klappt es wieder (jedenfalls ist es jetzt wieder grün, muss als nächstes da mal weiterarbeiten).
                      Danke für den Support.
