  4. docker iobroker update
iobroker update
32 Beiträge 4 Kommentatoren 5.0k Aufrufe 3 Beobachtet
  • D doctorultra
    beim mir kommt beim update immer
    root@ioBroker:/opt# iobroker upgrade self
    Update js-controller from @1.5.11 to @1.5.14
    NPM version: 3.10.10
    npm install iobroker.js-controller@1.5.14 --unsafe-perm --production --save --prefix "/opt/iobroker" (System call)
    ../authenticate_pam.cc:30:31: fatal error: security/pam_appl.h: Datei oder Verzeichnis nicht gefunden
     #include <security/pam_appl.h>
    compilation terminated.
    make: *** [Release/obj.target/authenticate_pam/authenticate_pam.o] Fehler 1
    gyp ERR! build error
    gyp ERR! stack Error: `make` failed with exit code: 2
    gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:276:23)
    gyp ERR! stack     at emitTwo (events.js:106:13)
    gyp ERR! stack     at ChildProcess.emit (events.js:191:7)
    gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:219:12)
    gyp ERR! System Linux 4.2.8
    gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
    gyp ERR! cwd /opt/iobroker/node_modules/authenticate-pam
    gyp ERR! node -v v6.12.2
    gyp ERR! node-gyp -v v3.4.0
    gyp ERR! not ok
    npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/are-we-there-yet/package.json'
    npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/prebuild-install/package.json'
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: authenticate-pam@1.0.2 (node_modules/authenticate-pam):
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: authenticate-pam@1.0.2 install: `node-gyp rebuild`
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
    Host "ioBroker" (linux) updated
    Execute: chmod -R 777 /opt/iobroker
    Chmod finished. Restart controller
    Starting node restart.js
    root@ioBroker:/opt#
    haselchenH Offline
    haselchenH Offline
    haselchen
    @doctorultra
    Glasfaser hat Recht.
    Du solltest mindestens Nodejs 8.16.2 und NPM 6.4.1 haben für die JS Controller Version 1.5.14
    Zumindest ist das meine Config.
    Ich denke zur Zeit wird Nodejs 10. X X X von den Usern hier empfohlen.
    • D doctorultra
      gyp ERR! not ok
      root@ioBroker:/opt#
      dslraserD Offline
      dslraserD Offline
      dslraser
      @doctorultra
      ich nutze für Updates immer portainer/die console dort. So wie auch von buanet(andre) in den Anleitungen beschrieben. Ein Backup Script hat er auch zur Verfügung gestellt. Aber gerade beim Backup hast Du ja diverse Möglichkeiten mit der Syno und ioBroker selbst.
      Das ist der "Docker" Bereich
      https://forum.iobroker.net/post/4733
      und auf diesen Seiten findest Du auch alles
      https://buanet.de/category/iobroker/
        doctorultra
        gerade neuen Docker aufgebaut und das alte iobroker Verzeichnis genommen.
        NPM version: 6.11.3
        npm ERR! code EEXIST
        npm ERR! path /opt/iobroker/node_modules/.bin/iobroker
        npm ERR! Refusing to delete /opt/iobroker/node_modules/.bin/iobroker: is outside /opt/iobroker/node_modules/iobroker.js-controller and not a link
        npm ERR! File exists: /opt/iobroker/node_modules/.bin/iobroker
        npm ERR! Move it away, and try again.
        npm ERR!     /root/.npm/_logs/2019-10-31T20_56_06_101Z-debug.log
        # ^C
        # npm -v
        6.11.3
        # nodejs -v
        v10.17.0
        # node -v
        v10.17.0
        haselchenH GlasfaserG 2 Antworten Letzte Antwort
        • D doctorultra
          NPM version: 6.11.3
          # ^C
          # npm -v
          6.11.3
          # nodejs -v
          v10.17.0
          # node -v
          v10.17.0
          haselchenH Offline
          haselchenH Offline
          haselchen
          @doctorultra
          Ganz einfach.
          Die Datei musste löschen , die da angegeben steht.
          iobroker
          Diese Meldung bekommst du öfter mal beim Adapter Update. Einfach die angegebene Datei löschen und nochmal updaten, fertig.
          • D doctorultra
            NPM version: 6.11.3
            # ^C
            # npm -v
            6.11.3
            # nodejs -v
            v10.17.0
            # node -v
            v10.17.0
            GlasfaserG Offline
            GlasfaserG Offline
            @doctorultra
            vor dem iobroker upgrade self ein :
            iobroker update
            nochmal durchführen .
              doctorultra
              jetzt scheint es durch zu sein, nur der homekit adapter yahka macht Probleme?
              host.ioBroker	2019-10-31 22:14:42.203	error	instance system.adapter.yahka.0 terminated with code 1 ()
              Caught	2019-10-31 22:14:42.203	error	by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:585:3)
              Caught	2019-10-31 22:14:42.203	error	by controller[0]: at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
              Caught	2019-10-31 22:14:42.203	error	by controller[0]: at Module.load (internal/modules/cjs/loader.js:653:32)
              Caught	2019-10-31 22:14:42.203	error	by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10)
              Caught	2019-10-31 22:14:42.203	error	by controller[0]: at Module._compile (internal/modules/cjs/loader.js:778:30)
              Caught	2019-10-31 22:14:42.203	error	by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/mdns/lib/dns_sd.js:32:22)
              Caught	2019-10-31 22:14:42.203	error	by controller[0]: at require (internal/modules/cjs/helpers.js:25:18)
              Caught	2019-10-31 22:14:42.203	error	by controller[0]: at Module.require (internal/modules/cjs/loader.js:692:17)
              Caught	2019-10-31 22:14:42.203	error	by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:562:25)
              Caught	2019-10-31 22:14:42.202	error	by controller[0]: at Function.Module._resolveFilename (internal/modules/cjs/loader.js:636:15)
              Caught	2019-10-31 22:14:42.202	error	by controller[0]: Error: Cannot find module '../build/Release/dns_sd_bindings'
              Caught	2019-10-31 22:14:42.202	error	by controller[0]: ^
              Caught	2019-10-31 22:14:42.202	error	by controller[0]: throw err;
              Caught	2019-10-31 22:14:42.202	error	by controller[0]: internal/modules/cjs/loader.js:638
                doctorultra
                habe mal ein npm rebuild gemacht, da kommt leider am Ende folgender Fehler
                dns_sd_bindings.target.mk:165: die Regel für Ziel „Release/obj.target/dns_sd_bindings/src/dns_sd.o“ scheiterte
                make: *** [Release/obj.target/dns_sd_bindings/src/dns_sd.o] Fehler 1
                make: Verzeichnis „/opt/iobroker/node_modules/mdns/build“ wird verlassen
                gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:193:23)
                gyp ERR! stack     at ChildProcess.emit (events.js:198:13)
                gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)
                gyp ERR! cwd /opt/iobroker/node_modules/mdns
                gyp ERR! node -v v10.17.0
                gyp ERR! node-gyp -v v5.0.3
                gyp ERR! not ok
                npm ERR! code ELIFECYCLE
                npm ERR! errno 1
                npm ERR! mdns@2.3.4 install: `node-gyp rebuild`
                npm ERR! Exit status 1
                npm ERR!
                npm ERR! Failed at the mdns@2.3.4 install script.
                npm ERR!     /root/.npm/_logs/2019-10-31T21_22_25_110Z-debug.log
                • D doctorultra
                  gyp ERR! not ok
                  npm ERR! errno 1
                  npm ERR!
                  haselchenH Offline
                  haselchenH Offline
                  haselchen
                  @doctorultra
                  Hast du vorher mal nen
                  apt-get update / upgrade gemacht ?
                  Oder jetzt im Nachhinein?
                    doctorultra
                    sudo npm install --unsafe-perm mdns
                    sudo npm rebuild --unsafe-perm
                    Hat leider auch nichts gebracht, jetzt ist es noch schlimmer :-)
                    host.ioBroker	2019-10-31 22:45:11.462	error	instance system.adapter.yahka.0 terminated with code 0 (OK)
                    host.ioBroker	2019-10-31 22:45:11.462	error	Caught by controller[106]: Thu, 31 Oct 2019 21:45:11 GMT socket.io-parser encoded {"type":2,"data":["setState","system.adapter.yahka.0.alive",{"val":false,"ack":true,"from":"system.adapter.yahka.0"}],
                    host.ioBroker	2019-10-31 22:45:11.462	error	Caught by controller[106]: Thu, 31 Oct 2019 21:45:11 GMT socket.io-parser encoding packet {"type":2,"data":["setState","system.adapter.yahka.0.alive",{"val":false,"ack":true,"from":"system.adapter.yah
                    host.ioBroker	2019-10-31 22:45:11.462	error	Caught by controller[106]: Thu, 31 Oct 2019 21:45:11 GMT socket.io-client:manager writing packet {"type":2,"data":["setState","system.adapter.yahka.0.alive",{"val":false,"ack":true,"from":"system.adap
                    host.ioBroker	2019-10-31 22:45:11.462	error	Caught by controller[106]: Thu, 31 Oct 2019 21:45:11 GMT socket.io-client:socket emitting packet with ack id 4
                    host.ioBroker	2019-10-31 22:45:11.462	error	Caught by controller[106]: Thu, 31 Oct 2019 21:45:11 GMT socket.io-client:socket calling ack 2 with [null,"system.adapter.yahka.0.alive"]
                    host.ioBroker	2019-10-31 22:45:11.462	error	Caught by controller[106]: Thu, 31 Oct 2019 21:45:11 GMT socket.io-parser decoded 32[null,"system.adapter.yahka.0.alive"] as {"type":3,"nsp":"/","id":2,"data":[null,"system.adapter.yahka.0.alive"]}
                    host.ioBroker	2019-10-31 22:45:11.462	error	Caught by controller[106]: Thu, 31 Oct 2019 21:45:11 GMT engine.io-client:socket socket receive: type "message", data "32[null,"system.adapter.yahka.0.alive"]"
                    host.ioBroker	2019-10-31 22:45:11.462	error	Caught by controller[106]: Thu, 31 Oct 2019 21:45:11 GMT socket.io-parser encoded {"type":2,"data":["getStates",["system.adapter.admin.0.logging"]],"options":{"compress":true},"id":3,"nsp":"/"} as 23[
                    host.ioBroker	2019-10-31 22:45:11.462	error	Caught by controller[106]: Thu, 31 Oct 2019 21:45:11 GMT socket.io-parser encoding packet {"type":2,"data":["getStates",["system.adapter.admin.0.logging"]],"options":{"compress":true},"id":3,"nsp":"/"
                    host.ioBroker	2019-10-31 22:45:11.462	error	Caught by controller[106]: Thu, 31 Oct 2019 21:45:11 GMT socket.io-client:manager writing packet {"type":2,"data":["getStates",["system.adapter.admin.0.logging"]],"options":{"compress":true},"id":3,"n
                    host.ioBroker	2019-10-31 22:45:11.462	error	Caught by controller[106]: Thu, 31 Oct 2019 21:45:11 GMT socket.io-client:socket emitting packet with ack id 3
                    host.ioBroker	2019-10-31 22:45:11.462	error	Caught by controller[106]: Thu, 31 Oct 2019 21:45:11 GMT socket.io-client:socket calling ack 1 with [null,["system.adapter.admin.0.logging"]]
                    host.ioBroker	2019-10-31 22:45:11.462	error	Caught by controller[106]: Thu, 31 Oct 2019 21:45:11 GMT socket.io-parser decoded 31[null,["system.adapter.admin.0.logging"]] as {"type":3,"nsp":"/","id":1,"data":[null,["system.adapter.admin.0.loggin
                    host.ioBroker	2019-10-31 22:45:11.462	error	Caught by controller[106]: Thu, 31 Oct 2019 21:45:11 GMT engine.io-client:socket socket receive: type "message", data "31[null,["system.adapter.admin.0.logging"]]"
                    host.ioBroker	2019-10-31 22:45:11.461	error	Caught by controller[105]: Thu, 31 Oct 2019 21:45:11 GMT engine.io-client:socket flushing 17 packets in socket
                    host.ioBroker	2019-10-31 22:45:11.461	error	Caught by controller[104]: Thu, 31 Oct 2019 21:45:11 GMT engine.io-client:socket flushing 11 packets in socket
                    host.ioBroker	2019-10-31 22:45:11.461	error	Caught by controller[103]: Thu, 31 Oct 2019 21:45:11 GMT socket.io-parser encoded {"type":2,"data":["setState","system.adapter.yahka.0.alive",{"val":false,"ack":true,"from":"system.adapter.yahka.0"}],
                    host.ioBroker	2019-10-31 22:45:11.461	error	Caught by controller[102]: Thu, 31 Oct 2019 21:45:11 GMT socket.io-parser encoding packet {"type":2,"data":["setState","system.adapter.yahka.0.alive",{"val":false,"ack":true,"from":"system.adapter.yah
                    host.ioBroker	2019-10-31 22:45:11.461	error	Caught by controller[102]: Thu, 31 Oct 2019 21:45:11 GMT socket.io-client:manager writing packet {"type":2,"data":["setState","system.adapter.yahka.0.alive",{"val":false,"ack":true,"from":"system.adap
                    host.ioBroker	2019-10-31 22:45:11.461	error	Caught by controller[101]: Thu, 31 Oct 2019 21:45:11 GMT socket.io-client:socket emitting packet with ack id 2
                    host.ioBroker	2019-10-31 22:45:11.461	error	Caught by controller[100]: at emitListeningNT (net.js:1314:10) errorCode: -65537 }
                    host.ioBroker	2019-10-31 22:45:11.461	error	Caught by controller[100]: at Server.emit (events.js:198:13)
                    host.ioBroker	2019-10-31 22:45:11.461	error	Caught by controller[100]: at EventedHTTPServer.<anonymous> (/opt/iobroker/node_modules/hap-nodejs/lib/util/eventedhttp.js:65:10)
                    host.ioBroker	2019-10-31 22:45:11.461	error	Caught by controller[100]: at EventedHTTPServer.emit (events.js:198:13)
                    host.ioBroker	2019-10-31 22:45:11.461	error	Caught by controller[100]: at HAPServer._onListening (/opt/iobroker/node_modules/hap-nodejs/lib/HAPServer.js:190:8)
                    host.ioBroker	2019-10-31 22:45:11.461	error	Caught by controller[100]: at HAPServer.emit (events.js:198:13)
                    host.ioBroker	2019-10-31 22:45:11.461	error	Caught by controller[100]: at Bridge.Accessory._onListening (/opt/iobroker/node_modules/hap-nodejs/lib/Accessory.js:661:20)
                    host.ioBroker	2019-10-31 22:45:11.461	error	Caught by controller[100]: at Advertiser.startAdvertising (/opt/iobroker/node_modules/hap-nodejs/lib/Advertiser.js:47:30)
                    host.ioBroker	2019-10-31 22:45:11.461	error	Caught by controller[100]: at Object.create [as createAdvertisement] (/opt/iobroker/node_modules/mdns/lib/advertisement.js:64:10)
                    host.ioBroker	2019-10-31 22:45:11.461	error	Caught by controller[100]: at new Advertisement (/opt/iobroker/node_modules/mdns/lib/advertisement.js:56:10)
                    host.ioBroker	2019-10-31 22:45:11.461	error	Caught by controller[100]: { Error: dns service error: unknown
                    host.ioBroker	2019-10-31 22:45:11.461	error	Caught by controller[99]: Thu, 31 Oct 2019 21:45:11 GMT socket.io-parser encoded {"type":2,"data":["subscribe","yahka.0.checkLogging",null],"options":{"compress":true},"nsp":"/"} as 2["subscribe","yah
                    host.ioBroker	2019-10-31 22:45:11.461	error	Caught by controller[99]: Thu, 31 Oct 2019 21:45:11 GMT socket.io-parser encoding packet {"type":2,"data":["subscribe","yahka.0.checkLogging",null],"options":{"compress":true},"nsp":"/"}
                    host.ioBroker	2019-10-31 22:45:11.461	error	Caught by controller[98]: Thu, 31 Oct 2019 21:45:11 GMT socket.io-client:manager writing packet {"type":2,"data":["subscribe","yahka.0.checkLogging",null],"options":{"compress":true},"nsp":"/"}
                    host.ioBroker	2019-10-31 22:45:11.460	error	Caught by controller[97]: Thu, 31 Oct 2019 21:45:11 GMT socket.io-parser encoded {"type":2,"data":["subscribe","system.adapter.*",null,null],"options":{"compress":true},"nsp":"/"} as 2["subscribe","sy
                    host.ioBroker	2019-10-31 22:45:11.460	error	Caught by controller[96]: Thu, 31 Oct 2019 21:45:11 GMT socket.io-parser encoding packet {"type":2,"data":["subscribe","system.adapter.*",null,null],"options":{"compress":true},"nsp":"/"}
                    host.ioBroker	2019-10-31 22:45:11.460	error	Caught by controller[96]: Thu, 31 Oct 2019 21:45:11 GMT socket.io-client:manager writing packet {"type":2,"data":["subscribe","system.adapter.*",null,null],"options":{"compress":true},"nsp":"/"}
                    host.ioBroker	2019-10-31 22:45:11.460	error	Caught by controller[96]: Thu, 31 Oct 2019 21:45:11 GMT socket.io-parser encoded {"type":2,"data":["getObjectView","system","instance",{"startkey":"system.adapter.","endkey":"system.adapter.香"},{"name
                    host.ioBroker	2019-10-31 22:45:11.460	error	Caught by controller[95]: Thu, 31 Oct 2019 21:45:11 GMT socket.io-parser encoding packet {"type":2,"data":["getObjectView","system","instance",{"startkey":"system.adapter.","endkey":"system.adapter.香"
                    host.ioBroker	2019-10-31 22:45:11.460	error	Caught by controller[95]: Thu, 31 Oct 2019 21:45:11 GMT socket.io-client:manager writing packet {"type":2,"data":["getObjectView","system","instance",{"startkey":"system.adapter.","endkey":"system.ada
                    host.ioBroker	2019-10-31 22:45:11.460	error	Caught by controller[95]: Thu, 31 Oct 2019 21:45:11 GMT socket.io-client:socket emitting packet with ack id 9
                    host.ioBroker	2019-10-31 22:45:11.460	error	Caught by controller[95]: Thu, 31 Oct 2019 21:45:11 GMT socket.io-parser encoded {"type":2,"data":["subscribe","system.adapter.*",null,null],"options":{"compress":true},"nsp":"/"} as 2["subscribe","sy
                    host.ioBroker	2019-10-31 22:45:11.460	error	Caught by controller[95]: Thu, 31 Oct 2019 21:45:11 GMT socket.io-parser encoding packet {"type":2,"data":["subscribe","system.adapter.*",null,null],"options":{"compress":true},"nsp":"/"}
                    host.ioBroker	2019-10-31 22:45:11.460	error	Caught by controller[95]: Thu, 31 Oct 2019 21:45:11 GMT socket.io-client:manager writing packet {"type":2,"data":["subscribe","system.adapter.*",null,null],"options":{"compress":true},"nsp":"/"}
                    host.ioBroker	2019-10-31 22:45:11.460	error	Caught by controller[94]: Thu, 31 Oct 2019 21:45:11 GMT socket.io-parser encoded {"type":2,"data":["getObjectView","system","instance",{"startkey":"system.adapter.","endkey":"system.adapter.香"},{"name
                    host.ioBroker	2019-10-31 22:45:11.460	error	Caught by controller[94]: Thu, 31 Oct 2019 21:45:11 GMT socket.io-parser encoding packet {"type":2,"data":["getObjectView","system","instance",{"startkey":"system.adapter.","endkey":"system.adapter.香"
                    host.ioBroker	2019-10-31 22:45:11.460	error	Caught by controller[94]: Thu, 31 Oct 2019 21:45:11 GMT socket.io-client:manager writing packet {"type":2,"data":["getObjectView","system","instance",{"startkey":"system.adapter.","endkey":"system.ada
                    host.ioBroker	2019-10-31 22:45:11.460	error	Caught by controller[93]: Thu, 31 Oct 2019 21:45:11 GMT socket.io-client:socket emitting packet with ack id 8
                    host.ioBroker	2019-10-31 22:45:11.460	error	Caught by controller[92]: Thu, 31 Oct 2019 21:45:11 GMT socket.io-parser encoded {"type":2,"data":["subscribe","system.adapter.*",null,null],"options":{"compress":true},"nsp":"/"} as 2["subscribe","sy
                    host.ioBroker	2019-10-31 22:45:11.460	error	Caught by controller[91]: Thu, 31 Oct 2019 21:45:11 GMT socket.io-parser encoding packet {"type":2,"data":["subscribe","system.adapter.*",null,null],"options":{"compress":true},"nsp":"/"}
                    host.ioBroker	2019-10-31 22:45:11.460	error	Caught by controller[90]: Thu, 31 Oct 2019 21:45:11 GMT socket.io-client:manager writing packet {"type":2,"data":["subscribe","system.adapter.*",null,null],"options":{"compress":true},"nsp":"/"}
                    host.ioBroker	2019-10-31 22:45:11.460	error	Caught by controller[90]: Thu, 31 Oct 2019 21:45:11 GMT socket.io-parser encoded {"type":2,"data":["getObjectView","system","instance",{"startkey":"system.adapter.","endkey":"system.adapter.香"},{"name
                    host.ioBroker	2019-10-31 22:45:11.459	error	Caught by controller[89]: Thu, 31 Oct 2019 21:45:11 GMT socket.io-parser encoding packet {"type":2,"data":["getObjectView","system","instance",{"startkey":"system.adapter.","endkey":"system.adapter.香"
                    host.ioBroker	2019-10-31 22:45:11.459	error	Caught by controller[88]: Thu, 31 Oct 2019 21:45:11 GMT socket.io-client:manager writing packet {"type":2,"data":["getObjectView","system","instance",{"startkey":"system.adapter.","endkey":"system.ada
                    host.ioBroker	2019-10-31 22:45:11.459	error	Caught by controller[87]: Thu, 31 Oct 2019 21:45:11 GMT socket.io-client:socket emitting packet with ack id 7
                    host.ioBroker	2019-10-31 22:45:11.459	error	Caught by controller[86]: Thu, 31 Oct 2019 21:45:11 GMT socket.io-parser encoded {"type":2,"data":["subscribe","system.adapter.*",null,null],"options":{"compress":true},"nsp":"/"} as 2["subscribe","sy
                    host.ioBroker	2019-10-31 22:45:11.459	error	Caught by controller[85]: Thu, 31 Oct 2019 21:45:11 GMT socket.io-parser encoding packet {"type":2,"data":["subscribe","system.adapter.*",null,null],"options":{"compress":true},"nsp":"/"}
                    host.ioBroker	2019-10-31 22:45:11.459	error	Caught by controller[85]: Thu, 31 Oct 2019 21:45:11 GMT socket.io-client:manager writing packet {"type":2,"data":["subscribe","system.adapter.*",null,null],"options":{"compress":true},"nsp":"/"}
                    host.ioBroker	2019-10-31 22:45:11.459	error	Caught by controller[84]: Thu, 31 Oct 2019 21:45:11 GMT socket.io-parser encoded {"type":2,"data":["getObjectView","system","instance",{"startkey":"system.adapter.","endkey":"system.adapter.香"},{"name
                    host.ioBroker	2019-10-31 22:45:11.459	error	Caught by controller[83]: Thu, 31 Oct 2019 21:45:11 GMT socket.io-parser encoding packet {"type":2,"data":["getObjectView","system","instance",{"startkey":"system.adapter.","endkey":"system.adapter.香"
                    host.ioBroker	2019-10-31 22:45:11.459	error	Caught by controller[82]: Thu, 31 Oct 2019 21:45:11 GMT socket.io-client:manager writing packet {"type":2,"data":["getObjectView","system","instance",{"startkey":"system.adapter.","endkey":"system.ada
                    host.ioBroker	2019-10-31 22:45:11.459	error	Caught by controller[81]: Thu, 31 Oct 2019 21:45:11 GMT socket.io-client:socket emitting packet with ack id 6
                    host.ioBroker	2019-10-31 22:45:11.459	error	Caught by controller[80]: Thu, 31 Oct 2019 21:45:11 GMT socket.io-parser encoded {"type":2,"data":["subscribe","system.adapter.*",null,null],"options":{"compress":true},"nsp":"/"} as 2["subscribe","sy
                    host.ioBroker	2019-10-31 22:45:11.459	error	Caught by controller[80]: Thu, 31 Oct 2019 21:45:11 GMT socket.io-parser encoding packet {"type":2,"data":["subscribe","system.adapter.*",null,null],"options":{"compress":true},"nsp":"/"}
                    host.ioBroker	2019-10-31 22:45:11.459	error	Caught by controller[79]: Thu, 31 Oct 2019 21:45:11 GMT socket.io-client:manager writing packet {"type":2,"data":["subscribe","system.adapter.*",null,null],"options":{"compress":true},"nsp":"/"}
                    host.ioBroker	2019-10-31 22:45:11.459	error	Caught by controller[78]: Thu, 31 Oct 2019 21:45:11 GMT socket.io-parser encoded {"type":2,"data":["getObjectView","system","instance",{"startkey":"system.adapter.","endkey":"system.adapter.香"},{"name
                    host.ioBroker	2019-10-31 22:45:11.459	error	Caught by controller[78]: Thu, 31 Oct 2019 21:45:11 GMT socket.io-parser encoding packet {"type":2,"data":["getObjectView","system","instance",{"startkey":"system.adapter.","endkey":"system.adapter.香"
                    host.ioBroker	2019-10-31 22:45:11.459	error	Caught by controller[78]: Thu, 31 Oct 2019 21:45:11 GMT socket.io-client:manager writing packet {"type":2,"data":["getObjectView","system","instance",{"startkey":"system.adapter.","endkey":"system.ada
                    host.ioBroker	2019-10-31 22:45:11.459	error	Caught by controller[78]: Thu, 31 Oct 2019 21:45:11 GMT socket.io-client:socket emitting packet with ack id 5
                    host.ioBroker	2019-10-31 22:45:11.459	error	Caught by controller[77]: Thu, 31 Oct 2019 21:45:11 GMT socket.io-parser encoded {"type":2,"data":["subscribe","system.adapter.*",null,null],"options":{"compress":true},"nsp":"/"} as 2["subscribe","sy
                    host.ioBroker	2019-10-31 22:45:11.459	error	Caught by controller[77]: Thu, 31 Oct 2019 21:45:11 GMT socket.io-parser encoding packet {"type":2,"data":["subscribe","system.adapter.*",null,null],"options":{"compress":true},"nsp":"/"}
                    host.ioBroker	2019-10-31 22:45:11.458	error	Caught by controller[77]: Thu, 31 Oct 2019 21:45:11 GMT socket.io-client:manager writing packet {"type":2,"data":["subscribe","system.adapter.*",null,null],"options":{"compress":true},"nsp":"/"}
                    host.ioBroker	2019-10-31 22:45:11.458	error	Caught by controller[77]: Thu, 31 Oct 2019 21:45:11 GMT socket.io-parser encoded {"type":2,"data":["getObjectView","system","instance",{"startkey":"system.adapter.","endkey":"system.adapter.香"},{"name
                    host.ioBroker	2019-10-31 22:45:11.458	error	Caught by controller[77]: Thu, 31 Oct 2019 21:45:11 GMT socket.io-parser encoding packet {"type":2,"data":["getObjectView","system","instance",{"startkey":"system.adapter.","endkey":"system.adapter.香"
                    host.ioBroker	2019-10-31 22:45:11.458	error	Caught by controller[77]: Thu, 31 Oct 2019 21:45:11 GMT socket.io-client:manager writing packet {"type":2,"data":["getObjectView","system","instance",{"startkey":"system.adapter.","endkey":"system.ada
                    host.ioBroker	2019-10-31 22:45:11.458	error	Caught by controller[77]: Thu, 31 Oct 2019 21:45:11 GMT socket.io-client:socket emitting packet with ack id 4
                    host.ioBroker	2019-10-31 22:45:11.458	error	Caught by controller[77]: Thu, 31 Oct 2019 21:45:11 GMT socket.io-parser encoded {"type":2,"data":["subscribe","system.adapter.*",null,null],"options":{"compress":true},"nsp":"/"} as 2["subscribe","sy
                    host.ioBroker	2019-10-31 22:45:11.458	error	Caught by controller[77]: Thu, 31 Oct 2019 21:45:11 GMT socket.io-parser encoding packet {"type":2,"data":["subscribe","system.adapter.*",null,null],"options":{"compress":true},"nsp":"/"}
                    host.ioBroker	2019-10-31 22:45:11.458	error	Caught by controller[77]: Thu, 31 Oct 2019 21:45:11 GMT socket.io-client:socket emitting packet with ack id 3
                    host.ioBroker	2019-10-31 22:45:11.457	error	Caught by controller[77]: Thu, 31 Oct 2019 21:45:11 GMT socket.io-client:socket emitting packet with ack id 2
                    host.ioBroker	2019-10-31 22:45:11.457	error	Caught by controller[77]: Thu, 31 Oct 2019 21:45:11 GMT socket.io-parser encoded {"type":2,"data":["subscribe","system.adapter.*",null,null],"options":{"compress":true},"nsp":"/"} as 2["subscribe","sy
                    host.ioBroker	2019-10-31 22:45:11.457	error	Caught by controller[77]: Thu, 31 Oct 2019 21:45:11 GMT socket.io-parser encoding packet {"type":2,"data":["subscribe","system.adapter.*",null,null],"options":{"compress":true},"nsp":"/"}
                    host.ioBroker	2019-10-31 22:45:11.457	error	Caught by controller[77]: Thu, 31 Oct 2019 21:45:11 GMT socket.io-client:manager writing packet {"type":2,"data":["subscribe","system.adapter.*",null,null],"options":{"compress":true},"nsp":"/"}
                    host.ioBroker	2019-10-31 22:45:11.457	error	Caught by controller[76]: Thu, 31 Oct 2019 21:45:11 GMT engine.io-client:socket flushing 1 packets in socket
                    host.ioBroker	2019-10-31 22:45:11.457	error	Caught by controller[76]: Thu, 31 Oct 2019 21:45:11 GMT socket.io-parser encoded {"type":2,"data":["getObjectView","system","instance",{"startkey":"system.adapter.","endkey":"system.adapter.香"},{"name
                    host.ioBroker	2019-10-31 22:45:11.457	error	Caught by controller[75]: Thu, 31 Oct 2019 21:45:11 GMT socket.io-parser encoding packet {"type":2,"data":["getObjectView","system","instance",{"startkey":"system.adapter.","endkey":"system.adapter.香"
                    host.ioBroker	2019-10-31 22:45:11.457	error	Caught by controller[75]: Thu, 31 Oct 2019 21:45:11 GMT socket.io-client:manager writing packet {"type":2,"data":["getObjectView","system","instance",{"startkey":"system.adapter.","endkey":"system.ada
                    host.ioBroker	2019-10-31 22:45:11.457	error	Caught by controller[74]: Thu, 31 Oct 2019 21:45:11 GMT socket.io-client:socket emitting packet with ack id 1
                    host.ioBroker	2019-10-31 22:45:11.457	error	Caught by controller[73]: Thu, 31 Oct 2019 21:45:11 GMT socket.io-parser encoded {"type":2,"data":["setState","system.adapter.yahka.0.outputCount",{"val":8,"ack":true,"from":"system.adapter.yahka.0"},
                    host.ioBroker	2019-10-31 22:45:11.457	error	Caught by controller[73]: Thu, 31 Oct 2019 21:45:11 GMT socket.io-parser encoding packet {"type":2,"data":["setState","system.adapter.yahka.0.outputCount",{"val":8,"ack":true,"from":"system.adapter.ya
                    host.ioBroker	2019-10-31 22:45:11.457	error	Caught by controller[73]: Thu, 31 Oct 2019 21:45:11 GMT socket.io-client:manager writing packet {"type":2,"data":["setState","system.adapter.yahka.0.outputCount",{"val":8,"ack":true,"from":"system.ada
                    host.ioBroker	2019-10-31 22:45:11.457	error	Caught by controller[73]: Thu, 31 Oct 2019 21:45:11 GMT socket.io-parser encoded {"type":2,"data":["setState","system.adapter.yahka.0.inputCount",{"val":0,"ack":true,"from":"system.adapter.yahka.0"},n
                    host.ioBroker	2019-10-31 22:45:11.457	error	Caught by controller[73]: Thu, 31 Oct 2019 21:45:11 GMT socket.io-parser encoding packet {"type":2,"data":["setState","system.adapter.yahka.0.inputCount",{"val":0,"ack":true,"from":"system.adapter.yah
                    host.ioBroker	2019-10-31 22:45:11.457	error	Caught by controller[73]: Thu, 31 Oct 2019 21:45:11 GMT socket.io-client:manager writing packet {"type":2,"data":["setState","system.adapter.yahka.0.inputCount",{"val":0,"ack":true,"from":"system.adap
                    host.ioBroker	2019-10-31 22:45:11.457	error	Caught by controller[73]: Thu, 31 Oct 2019 21:45:11 GMT socket.io-parser encoded {"type":2,"data":["setState","system.adapter.yahka.0.uptime",{"val":1,"ack":true,"from":"system.adapter.yahka.0"},null]
                    host.ioBroker	2019-10-31 22:45:11.457	error	Caught by controller[73]: Thu, 31 Oct 2019 21:45:11 GMT socket.io-parser encoding packet {"type":2,"data":["setState","system.adapter.yahka.0.uptime",{"val":1,"ack":true,"from":"system.adapter.yahka.0
                    host.ioBroker	2019-10-31 22:45:11.456	error	Caught by controller[73]: Thu, 31 Oct 2019 21:45:11 GMT socket.io-client:manager writing packet {"type":2,"data":["setState","system.adapter.yahka.0.uptime",{"val":1,"ack":true,"from":"system.adapter.
                    host.ioBroker	2019-10-31 22:45:11.456	error	Caught by controller[73]: Thu, 31 Oct 2019 21:45:11 GMT socket.io-parser encoded {"type":2,"data":["setState","system.adapter.yahka.0.memHeapUsed",{"val":12.83,"ack":true,"from":"system.adapter.yahka.
                    host.ioBroker	2019-10-31 22:45:11.456	error	Caught by controller[73]: Thu, 31 Oct 2019 21:45:11 GMT socket.io-parser encoding packet {"type":2,"data":["setState","system.adapter.yahka.0.memHeapUsed",{"val":12.83,"ack":true,"from":"system.adapte
                    host.ioBroker	2019-10-31 22:45:11.456	error	Caught by controller[73]: Thu, 31 Oct 2019 21:45:11 GMT socket.io-client:manager writing packet {"type":2,"data":["setState","system.adapter.yahka.0.memHeapUsed",{"val":12.83,"ack":true,"from":"system
                    host.ioBroker	2019-10-31 22:45:11.456	error	Caught by controller[73]: Thu, 31 Oct 2019 21:45:11 GMT socket.io-parser encoded {"type":2,"data":["setState","system.adapter.yahka.0.memHeapTotal",{"val":22.23,"ack":true,"from":"system.adapter.yahka
                    host.ioBroker	2019-10-31 22:45:11.456	error	Caught by controller[73]: Thu, 31 Oct 2019 21:45:11 GMT socket.io-parser encoding packet {"type":2,"data":["setState","system.adapter.yahka.0.memHeapTotal",{"val":22.23,"ack":true,"from":"system.adapt
                    host.ioBroker	2019-10-31 22:45:11.456	error	Caught by controller[73]: Thu, 31 Oct 2019 21:45:11 GMT socket.io-client:manager writing packet {"type":2,"data":["setState","system.adapter.yahka.0.memHeapTotal",{"val":22.23,"ack":true,"from":"syste
                    host.ioBroker	2019-10-31 22:45:11.456	error	Caught by controller[73]: Thu, 31 Oct 2019 21:45:11 GMT socket.io-parser encoded {"type":2,"data":["setState","system.adapter.yahka.0.memRss",{"val":49.81,"ack":true,"from":"system.adapter.yahka.0"},n
                    host.ioBroker	2019-10-31 22:45:11.456	error	Caught by controller[73]: Thu, 31 Oct 2019 21:45:11 GMT socket.io-parser encoding packet {"type":2,"data":["setState","system.adapter.yahka.0.memRss",{"val":49.81,"ack":true,"from":"system.adapter.yah
                    host.ioBroker	2019-10-31 22:45:11.456	error	Caught by controller[73]: Thu, 31 Oct 2019 21:45:11 GMT socket.io-client:manager writing packet {"type":2,"data":["setState","system.adapter.yahka.0.memRss",{"val":49.81,"ack":true,"from":"system.adap
                    host.ioBroker	2019-10-31 22:45:11.456	error	Caught by controller[73]: Thu, 31 Oct 2019 21:45:11 GMT socket.io-parser encoded {"type":2,"data":["setState","system.adapter.yahka.0.connected",{"val":true,"ack":true,"expire":30,"from":"system.adapt
                    host.ioBroker	2019-10-31 22:45:11.456	error	Caught by controller[73]: Thu, 31 Oct 2019 21:45:11 GMT socket.io-parser encoding packet {"type":2,"data":["setState","system.adapter.yahka.0.connected",{"val":true,"ack":true,"expire":30,"from":"syst
                    host.ioBroker	2019-10-31 22:45:11.456	error	Caught by controller[73]: Thu, 31 Oct 2019 21:45:11 GMT socket.io-client:manager writing packet {"type":2,"data":["setState","system.adapter.yahka.0.connected",{"val":true,"ack":true,"expire":30,"from
                    host.ioBroker	2019-10-31 22:45:11.456	error	Caught by controller[73]: Thu, 31 Oct 2019 21:45:11 GMT socket.io-parser encoded {"type":2,"data":["setState","system.adapter.yahka.0.alive",{"val":true,"ack":true,"expire":25,"from":"system.adapter.y
                    host.ioBroker	2019-10-31 22:45:11.456	error	Caught by controller[73]: Thu, 31 Oct 2019 21:45:11 GMT socket.io-parser encoding packet {"type":2,"data":["setState","system.adapter.yahka.0.alive",{"val":true,"ack":true,"expire":25,"from":"system.a
                    host.ioBroker	2019-10-31 22:45:11.456	error	Caught by controller[73]: Thu, 31 Oct 2019 21:45:11 GMT socket.io-client:manager writing packet {"type":2,"data":["setState","system.adapter.yahka.0.alive",{"val":true,"ack":true,"expire":25,"from":"s
                    host.ioBroker	2019-10-31 22:45:11.456	error	Caught by controller[73]: Thu, 31 Oct 2019 21:45:11 GMT socket.io-parser encoded {"type":2,"data":["subscribe","*.logging",null],"options":{"compress":true},"nsp":"/"} as 2["subscribe","*.logging",nul
                    host.ioBroker	2019-10-31 22:45:11.455	error	Caught by controller[73]: Thu, 31 Oct 2019 21:45:11 GMT socket.io-parser encoding packet {"type":2,"data":["subscribe","*.logging",null],"options":{"compress":true},"nsp":"/"}
                    host.ioBroker	2019-10-31 22:45:11.455	error	Caught by controller[73]: Thu, 31 Oct 2019 21:45:11 GMT socket.io-client:manager writing packet {"type":2,"data":["subscribe","*.logging",null],"options":{"compress":true},"nsp":"/"}
                    host.ioBroker	2019-10-31 22:45:11.455	error	Caught by controller[72]: Thu, 31 Oct 2019 21:45:11 GMT engine.io-client:socket flushing 1 packets in socket
                    host.ioBroker	2019-10-31 22:45:11.455	error	Caught by controller[71]: Thu, 31 Oct 2019 21:45:11 GMT socket.io-parser encoded {"type":2,"data":["getKeys","*.logging"],"options":{"compress":true},"id":1,"nsp":"/"} as 21["getKeys","*.logging"]
                    host.ioBroker	2019-10-31 22:45:11.455	error	Caught by controller[71]: Thu, 31 Oct 2019 21:45:11 GMT socket.io-parser encoding packet {"type":2,"data":["getKeys","*.logging"],"options":{"compress":true},"id":1,"nsp":"/"}
                    host.ioBroker	2019-10-31 22:45:11.455	error	Caught by controller[71]: Thu, 31 Oct 2019 21:45:11 GMT socket.io-client:manager writing packet {"type":2,"data":["getKeys","*.logging"],"options":{"compress":true},"id":1,"nsp":"/"}
                    host.ioBroker	2019-10-31 22:45:11.455	error	Caught by controller[70]: Thu, 31 Oct 2019 21:45:11 GMT socket.io-client:socket emitting packet with ack id 1
                    host.ioBroker	2019-10-31 22:45:11.455	error	Caught by controller[69]: Thu, 31 Oct 2019 21:45:11 GMT socket.io-client:socket calling ack 0 with [null,{"_id":"system.adapter.yahka.0","type":"instance","common":{"name":"yahka","version":"0.7.1","n
                    host.ioBroker	2019-10-31 22:45:11.455	error	Caught by controller[68]: Thu, 31 Oct 2019 21:45:11 GMT socket.io-parser decoded 30[null,{"_id":"system.adapter.yahka.0","type":"instance","common":{"name":"yahka","version":"0.7.1","news":{"0.7.1":{"
                    host.ioBroker	2019-10-31 22:45:11.455	error	Caught by controller[67]: Thu, 31 Oct 2019 21:45:11 GMT engine.io-client:socket socket receive: type "message", data "30[null,{"_id":"system.adapter.yahka.0","type":"instance","common":{"name":"yahka"
                    host.ioBroker	2019-10-31 22:45:11.455	error	Caught by controller[66]: Thu, 31 Oct 2019 21:45:11 GMT engine.io-client:socket flushing 1 packets in socket
                    host.ioBroker	2019-10-31 22:45:11.455	error	Caught by controller[65]: Thu, 31 Oct 2019 21:45:11 GMT engine.io-client:polling ignoring poll - transport state "paused"
                    host.ioBroker	2019-10-31 22:45:11.455	error	Caught by controller[64]: Thu, 31 Oct 2019 21:45:11 GMT engine.io-client:socket clearing existing transport polling
                    host.ioBroker	2019-10-31 22:45:11.454	error	Caught by controller[63]: Thu, 31 Oct 2019 21:45:11 GMT engine.io-client:socket setting transport websocket
                    host.ioBroker	2019-10-31 22:45:11.454	error	Caught by controller[63]: Thu, 31 Oct 2019 21:45:11 GMT engine.io-client:socket changing transport and sending upgrade packet
                    host.ioBroker	2019-10-31 22:45:11.454	error	Caught by controller[63]: Thu, 31 Oct 2019 21:45:11 GMT engine.io-client:polling paused
                    host.ioBroker	2019-10-31 22:45:11.454	error	Caught by controller[62]: Thu, 31 Oct 2019 21:45:11 GMT engine.io-client:polling pre-pause polling complete
                    host.ioBroker	2019-10-31 22:45:11.454	error	Caught by controller[62]: Thu, 31 Oct 2019 21:45:11 GMT engine.io-client:socket socket receive: type "noop", data "undefined"
                    host.ioBroker	2019-10-31 22:45:11.454	error	Caught by controller[62]: Thu, 31 Oct 2019 21:45:11 GMT engine.io-client:polling polling got data 1:6
                    host.ioBroker	2019-10-31 22:45:11.454	error	Caught by controller[61]: Thu, 31 Oct 2019 21:45:11 GMT engine.io-client:polling ignoring poll - transport state "paused"
                    host.ioBroker	2019-10-31 22:45:11.454	error	Caught by controller[60]: Thu, 31 Oct 2019 21:45:11 GMT engine.io-client:socket clearing existing transport polling
                    host.ioBroker	2019-10-31 22:45:11.454	error	Caught by controller[60]: Thu, 31 Oct 2019 21:45:11 GMT engine.io-client:socket setting transport websocket
                    host.ioBroker	2019-10-31 22:45:11.454	error	Caught by controller[60]: Thu, 31 Oct 2019 21:45:11 GMT engine.io-client:socket changing transport and sending upgrade packet
                    host.ioBroker	2019-10-31 22:45:11.454	error	Caught by controller[59]: Thu, 31 Oct 2019 21:45:11 GMT engine.io-client:polling paused
                    host.ioBroker	2019-10-31 22:45:11.454	error	Caught by controller[58]: Thu, 31 Oct 2019 21:45:11 GMT engine.io-client:polling pre-pause polling complete
                    host.ioBroker	2019-10-31 22:45:11.454	error	Caught by controller[57]: Thu, 31 Oct 2019 21:45:11 GMT socket.io-parser encoded {"type":2,"data":["getObject","system.adapter.yahka.0",null],"options":{"compress":true},"id":0,"nsp":"/"} as 20["getOb
                    host.ioBroker	2019-10-31 22:45:11.454	error	Caught by controller[57]: Thu, 31 Oct 2019 21:45:11 GMT socket.io-parser encoding packet {"type":2,"data":["getObject","system.adapter.yahka.0",null],"options":{"compress":true},"id":0,"nsp":"/"}
                    host.ioBroker	2019-10-31 22:45:11.454	error	Caught by controller[57]: Thu, 31 Oct 2019 21:45:11 GMT socket.io-client:manager writing packet {"type":2,"data":["getObject","system.adapter.yahka.0",null],"options":{"compress":true},"id":0,"nsp":"/
                    host.ioBroker	2019-10-31 22:45:11.454	error	Caught by controller[57]: Thu, 31 Oct 2019 21:45:11 GMT socket.io-client:socket emitting packet with ack id 0
                    host.ioBroker	2019-10-31 22:45:11.454	error	Caught by controller[56]: Thu, 31 Oct 2019 21:45:11 GMT socket.io-client:socket calling ack 0 with [null,{"val":false,"ack":true,"ts":1572558279658,"q":0,"from":"system.host.ioBroker","lc":15725582795
                    host.ioBroker	2019-10-31 22:45:11.453	error	Caught by controller[55]: Thu, 31 Oct 2019 21:45:11 GMT socket.io-parser decoded 30[null,{"val":false,"ack":true,"ts":1572558279658,"q":0,"from":"system.host.ioBroker","lc":1572558279548}] as {"type":
                    host.ioBroker	2019-10-31 22:45:11.453	error	Caught by controller[54]: Thu, 31 Oct 2019 21:45:11 GMT engine.io-client:socket socket receive: type "message", data "30[null,{"val":false,"ack":true,"ts":1572558279658,"q":0,"from":"system.host.ioBro
                    host.ioBroker	2019-10-31 22:45:11.453	error	Caught by controller[54]: Thu, 31 Oct 2019 21:45:11 GMT engine.io-client:polling polling got data 108:430[null,{"val":false,"ack":true,"ts":1572558279658,"q":0,"from":"system.host.ioBroker","lc":15725
                    host.ioBroker	2019-10-31 22:45:11.453	error	Caught by controller[53]: Thu, 31 Oct 2019 21:45:11 GMT engine.io-client:polling pre-pause writing complete
                    host.ioBroker	2019-10-31 22:45:11.453	error	Caught by controller[52]: Thu, 31 Oct 2019 21:45:11 GMT engine.io-client:polling we are currently writing - waiting to pause
                    host.ioBroker	2019-10-31 22:45:11.453	error	Caught by controller[52]: Thu, 31 Oct 2019 21:45:11 GMT engine.io-client:polling we are currently polling - waiting to pause
                    host.ioBroker	2019-10-31 22:45:11.453	error	Caught by controller[52]: Thu, 31 Oct 2019 21:45:11 GMT engine.io-client:socket pausing current transport "polling"
                    host.ioBroker	2019-10-31 22:45:11.453	error	Caught by controller[52]: Thu, 31 Oct 2019 21:45:11 GMT engine.io-client:socket probe transport "websocket" pong
                    host.ioBroker	2019-10-31 22:45:11.453	error	Caught by controller[51]: Thu, 31 Oct 2019 21:45:11 GMT engine.io-client:polling-xhr xhr data null
                    host.ioBroker	2019-10-31 22:45:11.453	error	Caught by controller[50]: Thu, 31 Oct 2019 21:45:11 GMT engine.io-client:polling-xhr xhr open GET: http://127.0.0.1:9000/socket.io/?EIO=3&transport=polling&t=MuZnuwQ&b64=1&sid=7vbhbHPglgVJupN6AAAn
                    host.ioBroker	2019-10-31 22:45:11.453	error	Caught by controller[49]: Thu, 31 Oct 2019 21:45:11 GMT engine.io-client:polling-xhr xhr poll
                    host.ioBroker	2019-10-31 22:45:11.453	error	Caught by controller[48]: Thu, 31 Oct 2019 21:45:11 GMT engine.io-client:polling polling
                    host.ioBroker	2019-10-31 22:45:11.453	error	Caught by controller[47]: Thu, 31 Oct 2019 21:45:11 GMT engine.io-client:polling-xhr xhr data 46:420["getState","system.adapter.yahka.0.alive"]
                    host.ioBroker	2019-10-31 22:45:11.453	error	Caught by controller[47]: Thu, 31 Oct 2019 21:45:11 GMT engine.io-client:polling-xhr xhr open POST: http://127.0.0.1:9000/socket.io/?EIO=3&transport=polling&t=MuZnuwN&b64=1&sid=7vbhbHPglgVJupN6AAAn
                    host.ioBroker	2019-10-31 22:45:11.453	error	Caught by controller[46]: Thu, 31 Oct 2019 21:45:11 GMT engine.io-client:socket flushing 1 packets in socket
                    host.ioBroker	2019-10-31 22:45:11.453	error	Caught by controller[45]: Thu, 31 Oct 2019 21:45:11 GMT socket.io-parser encoded {"type":2,"data":["getState","system.adapter.yahka.0.alive"],"options":{"compress":true},"id":0,"nsp":"/"} as 20["getSt
                    host.ioBroker	2019-10-31 22:45:11.453	error	Caught by controller[45]: Thu, 31 Oct 2019 21:45:11 GMT socket.io-parser encoding packet {"type":2,"data":["getState","system.adapter.yahka.0.alive"],"options":{"compress":true},"id":0,"nsp":"/"}
                    host.ioBroker	2019-10-31 22:45:11.452	error	Caught by controller[45]: Thu, 31 Oct 2019 21:45:11 GMT socket.io-client:manager writing packet {"type":2,"data":["getState","system.adapter.yahka.0.alive"],"options":{"compress":true},"id":0,"nsp":"/
                    host.ioBroker	2019-10-31 22:45:11.452	error	Caught by controller[44]: Thu, 31 Oct 2019 21:45:11 GMT socket.io-client:socket emitting packet with ack id 0
                    host.ioBroker	2019-10-31 22:45:11.452	error	Caught by controller[43]: Thu, 31 Oct 2019 21:45:11 GMT socket.io-parser decoded 0 as {"type":0,"nsp":"/"}
                    host.ioBroker	2019-10-31 22:45:11.452	error	Caught by controller[42]: Thu, 31 Oct 2019 21:45:11 GMT engine.io-client:socket socket receive: type "message", data "0"
                    host.ioBroker	2019-10-31 22:45:11.452	error	Caught by controller[42]: Thu, 31 Oct 2019 21:45:11 GMT engine.io-client:polling polling got data 2:40
                    host.ioBroker	2019-10-31 22:45:11.452	error	Caught by controller[41]: Thu, 31 Oct 2019 21:45:11 GMT engine.io-client:socket probe transport "websocket" opened
                    host.ioBroker	2019-10-31 22:45:11.452	error	Caught by controller[40]: Thu, 31 Oct 2019 21:45:11 GMT engine.io-client:polling-xhr xhr data null
                    host.ioBroker	2019-10-31 22:45:11.452	error	Caught by controller[40]: Thu, 31 Oct 2019 21:45:11 GMT engine.io-client:polling-xhr xhr open GET: http://127.0.0.1:9000/socket.io/?EIO=3&transport=polling&t=MuZnuvh&b64=1&sid=7vbhbHPglgVJupN6AAAn
                    host.ioBroker	2019-10-31 22:45:11.452	error	Caught by controller[39]: Thu, 31 Oct 2019 21:45:11 GMT engine.io-client:polling-xhr xhr poll
                    host.ioBroker	2019-10-31 22:45:11.452	error	Caught by controller[39]: Thu, 31 Oct 2019 21:45:11 GMT engine.io-client:polling polling
                    host.ioBroker	2019-10-31 22:45:11.452	error	Caught by controller[38]: Thu, 31 Oct 2019 21:45:11 GMT engine.io-client:socket creating transport "websocket"
                    host.ioBroker	2019-10-31 22:45:11.452	error	Caught by controller[38]: Thu, 31 Oct 2019 21:45:11 GMT engine.io-client:socket probing transport "websocket"
                    host.ioBroker	2019-10-31 22:45:11.452	error	Caught by controller[38]: Thu, 31 Oct 2019 21:45:11 GMT engine.io-client:socket starting upgrade probes
                    host.ioBroker	2019-10-31 22:45:11.452	error	Caught by controller[38]: Thu, 31 Oct 2019 21:45:11 GMT socket.io-client:socket transport is open - connecting
                    host.ioBroker	2019-10-31 22:45:11.452	error	Caught by controller[38]: Thu, 31 Oct 2019 21:45:11 GMT socket.io-client:manager cleanup
                    host.ioBroker	2019-10-31 22:45:11.452	error	Caught by controller[38]: Thu, 31 Oct 2019 21:45:11 GMT socket.io-client:manager open
                    host.ioBroker	2019-10-31 22:45:11.451	error	Caught by controller[38]: Thu, 31 Oct 2019 21:45:11 GMT engine.io-client:socket socket open
                    host.ioBroker	2019-10-31 22:45:11.451	error	Caught by controller[38]: Thu, 31 Oct 2019 21:45:11 GMT engine.io-client:socket socket receive: type "open", data "{"sid":"7vbhbHPglgVJupN6AAAn","upgrades":["websocket"],"pingInterval":25000,"pingTime
                    host.ioBroker	2019-10-31 22:45:11.451	error	Caught by controller[38]: Thu, 31 Oct 2019 21:45:11 GMT engine.io-client:polling polling got data 97:0{"sid":"7vbhbHPglgVJupN6AAAn","upgrades":["websocket"],"pingInterval":25000,"pingTimeout":60000}
                    host.ioBroker	2019-10-31 22:45:11.451	error	Caught by controller[37]: Thu, 31 Oct 2019 21:45:11 GMT engine.io-client:polling we are currently polling - waiting to pause
                    host.ioBroker	2019-10-31 22:45:11.451	error	Caught by controller[37]: Thu, 31 Oct 2019 21:45:11 GMT engine.io-client:socket pausing current transport "polling"
                    host.ioBroker	2019-10-31 22:45:11.451	error	Caught by controller[36]: Thu, 31 Oct 2019 21:45:11 GMT engine.io-client:socket probe transport "websocket" pong
                    host.ioBroker	2019-10-31 22:45:11.451	error	Caught by controller[35]: Thu, 31 Oct 2019 21:45:11 GMT engine.io-client:polling-xhr xhr data null
                    host.ioBroker	2019-10-31 22:45:11.451	error	Caught by controller[35]: Thu, 31 Oct 2019 21:45:11 GMT engine.io-client:polling-xhr xhr open GET: http://127.0.0.1:9001/socket.io/?EIO=3&transport=polling&t=MuZnuvR&b64=1&sid=Qy0iSgyEY47IVGUDAAAm
                    host.ioBroker	2019-10-31 22:45:11.451	error	Caught by controller[35]: Thu, 31 Oct 2019 21:45:11 GMT engine.io-client:polling-xhr xhr poll
                    host.ioBroker	2019-10-31 22:45:11.451	error	Caught by controller[35]: Thu, 31 Oct 2019 21:45:11 GMT engine.io-client:polling polling
                    host.ioBroker	2019-10-31 22:45:11.451	error	Caught by controller[34]: Thu, 31 Oct 2019 21:45:11 GMT socket.io-client:manager readyState opening
                    host.ioBroker	2019-10-31 22:45:11.451	error	Caught by controller[34]: Thu, 31 Oct 2019 21:45:11 GMT socket.io-client:manager connect attempt will timeout after 20000
                    host.ioBroker	2019-10-31 22:45:11.451	error	Caught by controller[34]: Thu, 31 Oct 2019 21:45:11 GMT engine.io-client:socket setting transport polling
                    host.ioBroker	2019-10-31 22:45:11.451	error	Caught by controller[33]: Thu, 31 Oct 2019 21:45:10 GMT engine.io-client:polling-xhr xhr data null
                    host.ioBroker	2019-10-31 22:45:11.451	error	Caught by controller[32]: Thu, 31 Oct 2019 21:45:10 GMT engine.io-client:polling-xhr xhr open GET: http://127.0.0.1:9000/socket.io/?EIO=3&transport=polling&t=MuZnuvN&b64=1
                    host.ioBroker	2019-10-31 22:45:11.451	error	Caught by controller[32]: Thu, 31 Oct 2019 21:45:10 GMT engine.io-client:polling-xhr xhr poll
                    host.ioBroker	2019-10-31 22:45:11.450	error	Caught by controller[32]: Thu, 31 Oct 2019 21:45:10 GMT engine.io-client:polling polling
                    host.ioBroker	2019-10-31 22:45:11.450	error	Caught by controller[31]: Thu, 31 Oct 2019 21:45:10 GMT engine.io-client:socket creating transport "polling"
                    host.ioBroker	2019-10-31 22:45:11.450	error	Caught by controller[31]: Thu, 31 Oct 2019 21:45:10 GMT socket.io-client:manager opening http://127.0.0.1:9000
                    host.ioBroker	2019-10-31 22:45:11.450	error	Caught by controller[31]: Thu, 31 Oct 2019 21:45:10 GMT socket.io-client:manager readyState closed
                    host.ioBroker	2019-10-31 22:45:11.450	error	Caught by controller[30]: Thu, 31 Oct 2019 21:45:10 GMT socket.io-client new io instance for http://127.0.0.1:9000
                    host.ioBroker	2019-10-31 22:45:11.450	error	Caught by controller[29]: Thu, 31 Oct 2019 21:45:10 GMT socket.io-client:url parse http://127.0.0.1:9000
                    host.ioBroker	2019-10-31 22:45:11.450	error	Caught by controller[28]: Thu, 31 Oct 2019 21:45:10 GMT socket.io-parser decoded 0 as {"type":0,"nsp":"/"}
                    host.ioBroker	2019-10-31 22:45:11.450	error	Caught by controller[27]: Thu, 31 Oct 2019 21:45:10 GMT engine.io-client:socket socket receive: type "message", data "0"
                    host.ioBroker	2019-10-31 22:45:11.450	error	Caught by controller[26]: Thu, 31 Oct 2019 21:45:10 GMT engine.io-client:polling polling got data 2:40
                    host.ioBroker	2019-10-31 22:45:11.450	error	Caught by controller[25]: Thu, 31 Oct 2019 21:45:10 GMT engine.io-client:socket probe transport "websocket" opened
                    host.ioBroker	2019-10-31 22:45:11.450	error	Caught by controller[24]: Thu, 31 Oct 2019 21:45:10 GMT engine.io-client:polling-xhr xhr data null
                    host.ioBroker	2019-10-31 22:45:11.450	error	Caught by controller[23]: Thu, 31 Oct 2019 21:45:10 GMT engine.io-client:polling-xhr xhr open GET: http://127.0.0.1:9001/socket.io/?EIO=3&transport=polling&t=MuZnuum&b64=1&sid=Qy0iSgyEY47IVGUDAAAm
                    host.ioBroker	2019-10-31 22:45:11.450	error	Caught by controller[22]: Thu, 31 Oct 2019 21:45:10 GMT engine.io-client:polling-xhr xhr poll
                    host.ioBroker	2019-10-31 22:45:11.450	error	Caught by controller[22]: Thu, 31 Oct 2019 21:45:10 GMT engine.io-client:polling polling
                    host.ioBroker	2019-10-31 22:45:11.450	error	Caught by controller[21]: Thu, 31 Oct 2019 21:45:10 GMT engine.io-client:socket creating transport "websocket"
                    host.ioBroker	2019-10-31 22:45:11.450	error	Caught by controller[20]: Thu, 31 Oct 2019 21:45:10 GMT engine.io-client:socket probing transport "websocket"
                    host.ioBroker	2019-10-31 22:45:11.449	error	Caught by controller[19]: Thu, 31 Oct 2019 21:45:10 GMT engine.io-client:socket starting upgrade probes
                    host.ioBroker	2019-10-31 22:45:11.449	error	Caught by controller[18]: Thu, 31 Oct 2019 21:45:10 GMT socket.io-client:socket transport is open - connecting
                    host.ioBroker	2019-10-31 22:45:11.449	error	Caught by controller[17]: Thu, 31 Oct 2019 21:45:10 GMT socket.io-client:manager cleanup
                    host.ioBroker	2019-10-31 22:45:11.449	error	Caught by controller[17]: Thu, 31 Oct 2019 21:45:10 GMT socket.io-client:manager open
                    host.ioBroker	2019-10-31 22:45:11.449	error	Caught by controller[16]: Thu, 31 Oct 2019 21:45:10 GMT engine.io-client:socket socket open
                    host.ioBroker	2019-10-31 22:45:11.449	error	Caught by controller[15]: Thu, 31 Oct 2019 21:45:10 GMT engine.io-client:socket socket receive: type "open", data "{"sid":"Qy0iSgyEY47IVGUDAAAm","upgrades":["websocket"],"pingInterval":25000,"pingTime
                    host.ioBroker	2019-10-31 22:45:11.449	error	Caught by controller[14]: Thu, 31 Oct 2019 21:45:10 GMT engine.io-client:polling polling got data 97:0{"sid":"Qy0iSgyEY47IVGUDAAAm","upgrades":["websocket"],"pingInterval":25000,"pingTimeout":60000}
                    host.ioBroker	2019-10-31 22:45:11.449	error	Caught by controller[13]: Thu, 31 Oct 2019 21:45:10 GMT socket.io-client:manager readyState opening
                    host.ioBroker	2019-10-31 22:45:11.449	error	Caught by controller[12]: Thu, 31 Oct 2019 21:45:10 GMT socket.io-client:manager connect attempt will timeout after 20000
                    host.ioBroker	2019-10-31 22:45:11.449	error	Caught by controller[11]: Thu, 31 Oct 2019 21:45:10 GMT engine.io-client:socket setting transport polling
                    host.ioBroker	2019-10-31 22:45:11.449	error	Caught by controller[10]: Thu, 31 Oct 2019 21:45:10 GMT engine.io-client:polling-xhr xhr data null
                    host.ioBroker	2019-10-31 22:45:11.449	error	Caught by controller[9]: Thu, 31 Oct 2019 21:45:10 GMT engine.io-client:polling-xhr xhr open GET: http://127.0.0.1:9001/socket.io/?EIO=3&transport=polling&t=MuZnutH&b64=1
                    host.ioBroker	2019-10-31 22:45:11.449	error	Caught by controller[8]: Thu, 31 Oct 2019 21:45:10 GMT engine.io-client:polling-xhr xhr poll
                    host.ioBroker	2019-10-31 22:45:11.449	error	Caught by controller[7]: Thu, 31 Oct 2019 21:45:10 GMT engine.io-client:polling polling
                    host.ioBroker	2019-10-31 22:45:11.449	error	Caught by controller[6]: Thu, 31 Oct 2019 21:45:10 GMT engine.io-client:socket creating transport "polling"
                    host.ioBroker	2019-10-31 22:45:11.448	error	Caught by controller[5]: Thu, 31 Oct 2019 21:45:10 GMT socket.io-client:manager opening http://127.0.0.1:9001
                    host.ioBroker	2019-10-31 22:45:11.448	error	Caught by controller[4]: Thu, 31 Oct 2019 21:45:10 GMT socket.io-client:manager readyState closed
                    host.ioBroker	2019-10-31 22:45:11.448	error	Caught by controller[3]: Thu, 31 Oct 2019 21:45:10 GMT socket.io-client new io instance for http://127.0.0.1:9001
                    host.ioBroker	2019-10-31 22:45:11.448	error	Caught by controller[2]: Thu, 31 Oct 2019 21:45:10 GMT socket.io-client:url parse http://127.0.0.1:9001
                    host.ioBroker	2019-10-31 22:45:11.448	error	Caught by controller[1]: *** WARNING *** For more information see <http://0pointer.de/avahi-compat?s=libdns_sd&e=node&f=DNSServiceRegister>
                    host.ioBroker	2019-10-31 22:45:11.448	error	Caught by controller[1]: *** WARNING *** Please fix your application to use the native API of Avahi!
                    host.ioBroker	2019-10-31 22:45:11.448	error	Caught by controller[1]: *** WARNING *** The program 'node' called 'DNSServiceRegister()' which is not supported (or only supported partially) in the Apple Bonjour compatibility layer of Avahi.
                    host.ioBroker	2019-10-31 22:45:11.448	error	Caught by controller[1]: *** WARNING *** For more information see <http://0pointer.de/avahi-compat?s=libdns_sd&e=node>
                    host.ioBroker	2019-10-31 22:45:11.448	error	Caught by controller[0]: *** WARNING *** The program 'node' uses the Apple Bonjour compatibility layer of Avahi.
                    • D doctorultra
                      GlasfaserG Offline
                      GlasfaserG Offline
                      @doctorultra
                      lass mal den Fixer drüber laufen ...
                      curl -sL https://iobroker.net/fix.sh | bash -
                      und kein sudo vor npm .....
                        doctorultra
                        @haselchen said in docker iobroker update:
                        apt-get update
                        Was ist der Fixer sorry?
                        übrgigens apt-get hat auch nichts gebracht
                        Ign:1 http://deb.debian.org/debian stretch InRelease
                        Holen:2 http://security.debian.org/debian-security stretch/updates InRelease [94,3 kB]
                        Holen:3 http://deb.debian.org/debian stretch-updates InRelease [91,0 kB]
                        Holen:4 http://deb.debian.org/debian stretch Release [118 kB]
                        Holen:5 http://deb.debian.org/debian stretch Release.gpg [2.365 B]
                        Holen:6 https://deb.nodesource.com/node_10.x stretch InRelease [4.585 B]
                        Holen:7 http://security.debian.org/debian-security stretch/updates/main amd64 Packages [500 kB]
                        Holen:8 http://deb.debian.org/debian stretch-updates/main amd64 Packages [27,4 kB]
                        Holen:9 http://deb.debian.org/debian stretch/main amd64 Packages [7.086 kB]
                        Holen:10 https://deb.nodesource.com/node_10.x stretch/main amd64 Packages [768 B]
                        Es wurden 7.925 kB in 4 s geholt (1.636 kB/s).
                        # apt-get upgrade
                        Paketaktualisierung (Upgrade) wird berechnet... Fertig
                        0 aktualisiert, 0 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
                        • D doctorultra
                          apt-get update
                          # apt-get upgrade
                          GlasfaserG Offline
                          GlasfaserG Offline
                          @doctorultra
                            doctorultra
                            neid leider nicht
                            host.ioBroker	2019-10-31 22:53:42.245	error	instance system.adapter.yahka.0 terminated with code 0 (OK)
                            host.ioBroker	2019-10-31 22:53:42.245	error	Caught by controller[61]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-parser encoded {"type":2,"data":["setState","system.adapter.yahka.0.alive",{"val":false,"ack":true,"from":"system.adapter.yahka.0"}],"
                            host.ioBroker	2019-10-31 22:53:42.245	error	Caught by controller[61]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-parser encoding packet {"type":2,"data":["setState","system.adapter.yahka.0.alive",{"val":false,"ack":true,"from":"system.adapter.yahk
                            host.ioBroker	2019-10-31 22:53:42.245	error	Caught by controller[61]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-client:manager writing packet {"type":2,"data":["setState","system.adapter.yahka.0.alive",{"val":false,"ack":true,"from":"system.adapt
                            host.ioBroker	2019-10-31 22:53:42.245	error	Caught by controller[61]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-client:socket emitting packet with ack id 4
                            host.ioBroker	2019-10-31 22:53:42.245	error	Caught by controller[61]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-client:socket calling ack 2 with [null,"system.adapter.yahka.0.alive"]
                            host.ioBroker	2019-10-31 22:53:42.245	error	Caught by controller[61]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-parser decoded 32[null,"system.adapter.yahka.0.alive"] as {"type":3,"nsp":"/","id":2,"data":[null,"system.adapter.yahka.0.alive"]}
                            host.ioBroker	2019-10-31 22:53:42.245	error	Caught by controller[61]: Thu, 31 Oct 2019 21:53:42 GMT engine.io-client:socket socket receive: type "message", data "32[null,"system.adapter.yahka.0.alive"]"
                            host.ioBroker	2019-10-31 22:53:42.245	error	Caught by controller[61]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-parser encoded {"type":2,"data":["getStates",["system.adapter.admin.0.logging"]],"options":{"compress":true},"id":3,"nsp":"/"} as 23["
                            host.ioBroker	2019-10-31 22:53:42.245	error	Caught by controller[61]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-parser encoding packet {"type":2,"data":["getStates",["system.adapter.admin.0.logging"]],"options":{"compress":true},"id":3,"nsp":"/"}
                            host.ioBroker	2019-10-31 22:53:42.245	error	Caught by controller[61]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-client:manager writing packet {"type":2,"data":["getStates",["system.adapter.admin.0.logging"]],"options":{"compress":true},"id":3,"ns
                            host.ioBroker	2019-10-31 22:53:42.245	error	Caught by controller[61]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-client:socket emitting packet with ack id 3
                            host.ioBroker	2019-10-31 22:53:42.245	error	Caught by controller[61]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-client:socket calling ack 1 with [null,["system.adapter.admin.0.logging"]]
                            host.ioBroker	2019-10-31 22:53:42.245	error	Caught by controller[61]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-parser decoded 31[null,["system.adapter.admin.0.logging"]] as {"type":3,"nsp":"/","id":1,"data":[null,["system.adapter.admin.0.logging
                            host.ioBroker	2019-10-31 22:53:42.245	error	Caught by controller[61]: Thu, 31 Oct 2019 21:53:42 GMT engine.io-client:socket socket receive: type "message", data "31[null,["system.adapter.admin.0.logging"]]"
                            host.ioBroker	2019-10-31 22:53:42.244	error	Caught by controller[60]: Thu, 31 Oct 2019 21:53:42 GMT engine.io-client:socket flushing 17 packets in socket
                            host.ioBroker	2019-10-31 22:53:42.244	error	Caught by controller[59]: Thu, 31 Oct 2019 21:53:42 GMT engine.io-client:socket flushing 11 packets in socket
                            host.ioBroker	2019-10-31 22:53:42.244	error	Caught by controller[58]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-parser encoded {"type":2,"data":["setState","system.adapter.yahka.0.alive",{"val":false,"ack":true,"from":"system.adapter.yahka.0"}],"
                            host.ioBroker	2019-10-31 22:53:42.244	error	Caught by controller[58]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-parser encoding packet {"type":2,"data":["setState","system.adapter.yahka.0.alive",{"val":false,"ack":true,"from":"system.adapter.yahk
                            host.ioBroker	2019-10-31 22:53:42.244	error	Caught by controller[58]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-client:manager writing packet {"type":2,"data":["setState","system.adapter.yahka.0.alive",{"val":false,"ack":true,"from":"system.adapt
                            host.ioBroker	2019-10-31 22:53:42.244	error	Caught by controller[58]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-client:socket emitting packet with ack id 2
                            host.ioBroker	2019-10-31 22:53:42.244	error	Caught by controller[57]: at emitListeningNT (net.js:1314:10) errorCode: -65537 }
                            host.ioBroker	2019-10-31 22:53:42.244	error	Caught by controller[57]: at Server.emit (events.js:198:13)
                            host.ioBroker	2019-10-31 22:53:42.244	error	Caught by controller[57]: at EventedHTTPServer.<anonymous> (/opt/iobroker/node_modules/hap-nodejs/lib/util/eventedhttp.js:65:10)
                            host.ioBroker	2019-10-31 22:53:42.244	error	Caught by controller[57]: at EventedHTTPServer.emit (events.js:198:13)
                            host.ioBroker	2019-10-31 22:53:42.244	error	Caught by controller[57]: at HAPServer._onListening (/opt/iobroker/node_modules/hap-nodejs/lib/HAPServer.js:190:8)
                            host.ioBroker	2019-10-31 22:53:42.244	error	Caught by controller[57]: at HAPServer.emit (events.js:198:13)
                            host.ioBroker	2019-10-31 22:53:42.244	error	Caught by controller[57]: at Bridge.Accessory._onListening (/opt/iobroker/node_modules/hap-nodejs/lib/Accessory.js:661:20)
                            host.ioBroker	2019-10-31 22:53:42.244	error	Caught by controller[57]: at Advertiser.startAdvertising (/opt/iobroker/node_modules/hap-nodejs/lib/Advertiser.js:47:30)
                            host.ioBroker	2019-10-31 22:53:42.244	error	Caught by controller[57]: at Object.create [as createAdvertisement] (/opt/iobroker/node_modules/mdns/lib/advertisement.js:64:10)
                            host.ioBroker	2019-10-31 22:53:42.244	error	Caught by controller[57]: at new Advertisement (/opt/iobroker/node_modules/mdns/lib/advertisement.js:56:10)
                            host.ioBroker	2019-10-31 22:53:42.244	error	Caught by controller[57]: { Error: dns service error: unknown
                            host.ioBroker	2019-10-31 22:53:42.244	error	Caught by controller[56]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-parser encoded {"type":2,"data":["subscribe","yahka.0.checkLogging",null],"options":{"compress":true},"nsp":"/"} as 2["subscribe","yah
                            host.ioBroker	2019-10-31 22:53:42.243	error	Caught by controller[56]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-parser encoding packet {"type":2,"data":["subscribe","yahka.0.checkLogging",null],"options":{"compress":true},"nsp":"/"}
                            host.ioBroker	2019-10-31 22:53:42.243	error	Caught by controller[55]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-client:manager writing packet {"type":2,"data":["subscribe","yahka.0.checkLogging",null],"options":{"compress":true},"nsp":"/"}
                            host.ioBroker	2019-10-31 22:53:42.243	error	Caught by controller[54]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-parser encoded {"type":2,"data":["subscribe","system.adapter.*",null,null],"options":{"compress":true},"nsp":"/"} as 2["subscribe","sy
                            host.ioBroker	2019-10-31 22:53:42.243	error	Caught by controller[54]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-parser encoding packet {"type":2,"data":["subscribe","system.adapter.*",null,null],"options":{"compress":true},"nsp":"/"}
                            host.ioBroker	2019-10-31 22:53:42.243	error	Caught by controller[54]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-client:manager writing packet {"type":2,"data":["subscribe","system.adapter.*",null,null],"options":{"compress":true},"nsp":"/"}
                            host.ioBroker	2019-10-31 22:53:42.243	error	Caught by controller[54]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-parser encoded {"type":2,"data":["getObjectView","system","instance",{"startkey":"system.adapter.","endkey":"system.adapter.香"},{"name
                            host.ioBroker	2019-10-31 22:53:42.243	error	Caught by controller[54]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-parser encoding packet {"type":2,"data":["getObjectView","system","instance",{"startkey":"system.adapter.","endkey":"system.adapter.香"
                            host.ioBroker	2019-10-31 22:53:42.243	error	Caught by controller[54]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-client:manager writing packet {"type":2,"data":["getObjectView","system","instance",{"startkey":"system.adapter.","endkey":"system.ada
                            host.ioBroker	2019-10-31 22:53:42.243	error	Caught by controller[54]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-client:socket emitting packet with ack id 9
                            host.ioBroker	2019-10-31 22:53:42.243	error	Caught by controller[54]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-client:socket emitting packet with ack id 8
                            host.ioBroker	2019-10-31 22:53:42.243	error	Caught by controller[53]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-parser encoded {"type":2,"data":["subscribe","system.adapter.*",null,null],"options":{"compress":true},"nsp":"/"} as 2["subscribe","sy
                            host.ioBroker	2019-10-31 22:53:42.243	error	Caught by controller[52]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-parser encoding packet {"type":2,"data":["subscribe","system.adapter.*",null,null],"options":{"compress":true},"nsp":"/"}
                            host.ioBroker	2019-10-31 22:53:42.242	error	Caught by controller[52]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-client:manager writing packet {"type":2,"data":["subscribe","system.adapter.*",null,null],"options":{"compress":true},"nsp":"/"}
                            host.ioBroker	2019-10-31 22:53:42.242	error	Caught by controller[52]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-parser encoded {"type":2,"data":["getObjectView","system","instance",{"startkey":"system.adapter.","endkey":"system.adapter.香"},{"name
                            host.ioBroker	2019-10-31 22:53:42.242	error	Caught by controller[52]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-parser encoding packet {"type":2,"data":["getObjectView","system","instance",{"startkey":"system.adapter.","endkey":"system.adapter.香"
                            host.ioBroker	2019-10-31 22:53:42.242	error	Caught by controller[52]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-client:manager writing packet {"type":2,"data":["getObjectView","system","instance",{"startkey":"system.adapter.","endkey":"system.ada
                            host.ioBroker	2019-10-31 22:53:42.242	error	Caught by controller[51]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-client:socket emitting packet with ack id 7
                            host.ioBroker	2019-10-31 22:53:42.242	error	Caught by controller[50]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-parser encoded {"type":2,"data":["subscribe","system.adapter.*",null,null],"options":{"compress":true},"nsp":"/"} as 2["subscribe","sy
                            host.ioBroker	2019-10-31 22:53:42.242	error	Caught by controller[50]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-parser encoding packet {"type":2,"data":["subscribe","system.adapter.*",null,null],"options":{"compress":true},"nsp":"/"}
                            host.ioBroker	2019-10-31 22:53:42.242	error	Caught by controller[50]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-client:manager writing packet {"type":2,"data":["subscribe","system.adapter.*",null,null],"options":{"compress":true},"nsp":"/"}
                            host.ioBroker	2019-10-31 22:53:42.242	error	Caught by controller[50]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-parser encoded {"type":2,"data":["getObjectView","system","instance",{"startkey":"system.adapter.","endkey":"system.adapter.香"},{"name
                            host.ioBroker	2019-10-31 22:53:42.242	error	Caught by controller[50]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-parser encoding packet {"type":2,"data":["getObjectView","system","instance",{"startkey":"system.adapter.","endkey":"system.adapter.香"
                            host.ioBroker	2019-10-31 22:53:42.242	error	Caught by controller[50]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-client:manager writing packet {"type":2,"data":["getObjectView","system","instance",{"startkey":"system.adapter.","endkey":"system.ada
                            host.ioBroker	2019-10-31 22:53:42.242	error	Caught by controller[50]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-client:socket emitting packet with ack id 6
                            host.ioBroker	2019-10-31 22:53:42.242	error	Caught by controller[49]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-parser encoded {"type":2,"data":["subscribe","system.adapter.*",null,null],"options":{"compress":true},"nsp":"/"} as 2["subscribe","sy
                            host.ioBroker	2019-10-31 22:53:42.242	error	Caught by controller[49]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-parser encoding packet {"type":2,"data":["subscribe","system.adapter.*",null,null],"options":{"compress":true},"nsp":"/"}
                            host.ioBroker	2019-10-31 22:53:42.242	error	Caught by controller[49]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-client:manager writing packet {"type":2,"data":["subscribe","system.adapter.*",null,null],"options":{"compress":true},"nsp":"/"}
                            host.ioBroker	2019-10-31 22:53:42.242	error	Caught by controller[49]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-parser encoded {"type":2,"data":["getObjectView","system","instance",{"startkey":"system.adapter.","endkey":"system.adapter.香"},{"name
                            host.ioBroker	2019-10-31 22:53:42.242	error	Caught by controller[49]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-parser encoding packet {"type":2,"data":["getObjectView","system","instance",{"startkey":"system.adapter.","endkey":"system.adapter.香"
                            host.ioBroker	2019-10-31 22:53:42.241	error	Caught by controller[49]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-client:manager writing packet {"type":2,"data":["getObjectView","system","instance",{"startkey":"system.adapter.","endkey":"system.ada
                            host.ioBroker	2019-10-31 22:53:42.241	error	Caught by controller[49]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-client:socket emitting packet with ack id 5
                            host.ioBroker	2019-10-31 22:53:42.241	error	Caught by controller[48]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-parser encoded {"type":2,"data":["subscribe","system.adapter.*",null,null],"options":{"compress":true},"nsp":"/"} as 2["subscribe","sy
                            host.ioBroker	2019-10-31 22:53:42.241	error	Caught by controller[48]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-parser encoding packet {"type":2,"data":["subscribe","system.adapter.*",null,null],"options":{"compress":true},"nsp":"/"}
                            host.ioBroker	2019-10-31 22:53:42.241	error	Caught by controller[48]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-client:manager writing packet {"type":2,"data":["subscribe","system.adapter.*",null,null],"options":{"compress":true},"nsp":"/"}
                            host.ioBroker	2019-10-31 22:53:42.241	error	Caught by controller[48]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-parser encoded {"type":2,"data":["getObjectView","system","instance",{"startkey":"system.adapter.","endkey":"system.adapter.香"},{"name
                            host.ioBroker	2019-10-31 22:53:42.241	error	Caught by controller[47]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-parser encoding packet {"type":2,"data":["getObjectView","system","instance",{"startkey":"system.adapter.","endkey":"system.adapter.香"
                            host.ioBroker	2019-10-31 22:53:42.241	error	Caught by controller[47]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-client:manager writing packet {"type":2,"data":["getObjectView","system","instance",{"startkey":"system.adapter.","endkey":"system.ada
                            host.ioBroker	2019-10-31 22:53:42.241	error	Caught by controller[47]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-client:socket emitting packet with ack id 4
                            host.ioBroker	2019-10-31 22:53:42.241	error	Caught by controller[47]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-parser encoded {"type":2,"data":["subscribe","system.adapter.*",null,null],"options":{"compress":true},"nsp":"/"} as 2["subscribe","sy
                            host.ioBroker	2019-10-31 22:53:42.241	error	Caught by controller[47]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-parser encoding packet {"type":2,"data":["subscribe","system.adapter.*",null,null],"options":{"compress":true},"nsp":"/"}
                            host.ioBroker	2019-10-31 22:53:42.241	error	Caught by controller[47]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-client:manager writing packet {"type":2,"data":["subscribe","system.adapter.*",null,null],"options":{"compress":true},"nsp":"/"}
                            host.ioBroker	2019-10-31 22:53:42.241	error	Caught by controller[47]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-parser encoded {"type":2,"data":["getObjectView","system","instance",{"startkey":"system.adapter.","endkey":"system.adapter.香"},{"name
                            host.ioBroker	2019-10-31 22:53:42.241	error	Caught by controller[47]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-client:socket emitting packet with ack id 3
                            host.ioBroker	2019-10-31 22:53:42.240	error	Caught by controller[47]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-parser encoding packet {"type":2,"data":["subscribe","system.adapter.*",null,null],"options":{"compress":true},"nsp":"/"}
                            host.ioBroker	2019-10-31 22:53:42.240	error	Caught by controller[47]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-client:manager writing packet {"type":2,"data":["subscribe","system.adapter.*",null,null],"options":{"compress":true},"nsp":"/"}
                            host.ioBroker	2019-10-31 22:53:42.240	error	Caught by controller[47]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-parser encoded {"type":2,"data":["getObjectView","system","instance",{"startkey":"system.adapter.","endkey":"system.adapter.香"},{"name
                            host.ioBroker	2019-10-31 22:53:42.240	error	Caught by controller[47]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-parser encoding packet {"type":2,"data":["getObjectView","system","instance",{"startkey":"system.adapter.","endkey":"system.adapter.香"
                            host.ioBroker	2019-10-31 22:53:42.240	error	Caught by controller[47]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-client:manager writing packet {"type":2,"data":["getObjectView","system","instance",{"startkey":"system.adapter.","endkey":"system.ada
                            host.ioBroker	2019-10-31 22:53:42.240	error	Caught by controller[47]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-client:socket emitting packet with ack id 2
                            host.ioBroker	2019-10-31 22:53:42.240	error	Caught by controller[47]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-parser encoded {"type":2,"data":["subscribe","system.adapter.*",null,null],"options":{"compress":true},"nsp":"/"} as 2["subscribe","sy
                            host.ioBroker	2019-10-31 22:53:42.240	error	Caught by controller[46]: Thu, 31 Oct 2019 21:53:42 GMT engine.io-client:socket flushing 1 packets in socket
                            host.ioBroker	2019-10-31 22:53:42.240	error	Caught by controller[45]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-parser encoded {"type":2,"data":["getObjectView","system","instance",{"startkey":"system.adapter.","endkey":"system.adapter.香"},{"name
                            host.ioBroker	2019-10-31 22:53:42.240	error	Caught by controller[44]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-parser encoding packet {"type":2,"data":["getObjectView","system","instance",{"startkey":"system.adapter.","endkey":"system.adapter.香"
                            host.ioBroker	2019-10-31 22:53:42.240	error	Caught by controller[44]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-client:manager writing packet {"type":2,"data":["getObjectView","system","instance",{"startkey":"system.adapter.","endkey":"system.ada
                            host.ioBroker	2019-10-31 22:53:42.240	error	Caught by controller[43]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-client:socket emitting packet with ack id 1
                            host.ioBroker	2019-10-31 22:53:42.240	error	Caught by controller[42]: Thu, 31 Oct 2019 21:53:41 GMT socket.io-parser encoded {"type":2,"data":["setState","system.adapter.yahka.0.outputCount",{"val":8,"ack":true,"from":"system.adapter.yahka.0"},
                            host.ioBroker	2019-10-31 22:53:42.240	error	Caught by controller[42]: Thu, 31 Oct 2019 21:53:41 GMT socket.io-parser encoding packet {"type":2,"data":["setState","system.adapter.yahka.0.outputCount",{"val":8,"ack":true,"from":"system.adapter.ya
                            host.ioBroker	2019-10-31 22:53:42.240	error	Caught by controller[42]: Thu, 31 Oct 2019 21:53:41 GMT socket.io-client:manager writing packet {"type":2,"data":["setState","system.adapter.yahka.0.outputCount",{"val":8,"ack":true,"from":"system.ada
                            host.ioBroker	2019-10-31 22:53:42.239	error	Caught by controller[42]: Thu, 31 Oct 2019 21:53:41 GMT socket.io-parser encoded {"type":2,"data":["setState","system.adapter.yahka.0.inputCount",{"val":0,"ack":true,"from":"system.adapter.yahka.0"},n
                            host.ioBroker	2019-10-31 22:53:42.239	error	Caught by controller[42]: Thu, 31 Oct 2019 21:53:41 GMT socket.io-parser encoding packet {"type":2,"data":["setState","system.adapter.yahka.0.inputCount",{"val":0,"ack":true,"from":"system.adapter.yah
                            host.ioBroker	2019-10-31 22:53:42.239	error	Caught by controller[42]: Thu, 31 Oct 2019 21:53:41 GMT socket.io-client:manager writing packet {"type":2,"data":["setState","system.adapter.yahka.0.inputCount",{"val":0,"ack":true,"from":"system.adap
                            host.ioBroker	2019-10-31 22:53:42.239	error	Caught by controller[42]: Thu, 31 Oct 2019 21:53:41 GMT socket.io-parser encoded {"type":2,"data":["setState","system.adapter.yahka.0.uptime",{"val":1,"ack":true,"from":"system.adapter.yahka.0"},null]
                            host.ioBroker	2019-10-31 22:53:42.239	error	Caught by controller[42]: Thu, 31 Oct 2019 21:53:41 GMT socket.io-parser encoding packet {"type":2,"data":["setState","system.adapter.yahka.0.uptime",{"val":1,"ack":true,"from":"system.adapter.yahka.0
                            host.ioBroker	2019-10-31 22:53:42.239	error	Caught by controller[42]: Thu, 31 Oct 2019 21:53:41 GMT socket.io-client:manager writing packet {"type":2,"data":["setState","system.adapter.yahka.0.uptime",{"val":1,"ack":true,"from":"system.adapter.
                            host.ioBroker	2019-10-31 22:53:42.239	error	Caught by controller[42]: Thu, 31 Oct 2019 21:53:41 GMT socket.io-parser encoded {"type":2,"data":["setState","system.adapter.yahka.0.memHeapUsed",{"val":12.71,"ack":true,"from":"system.adapter.yahka.
                            host.ioBroker	2019-10-31 22:53:42.239	error	Caught by controller[42]: Thu, 31 Oct 2019 21:53:41 GMT socket.io-parser encoding packet {"type":2,"data":["setState","system.adapter.yahka.0.memHeapUsed",{"val":12.71,"ack":true,"from":"system.adapte
                            host.ioBroker	2019-10-31 22:53:42.239	error	Caught by controller[42]: Thu, 31 Oct 2019 21:53:41 GMT socket.io-client:manager writing packet {"type":2,"data":["setState","system.adapter.yahka.0.memHeapUsed",{"val":12.71,"ack":true,"from":"system
                            host.ioBroker	2019-10-31 22:53:42.239	error	Caught by controller[42]: Thu, 31 Oct 2019 21:53:41 GMT socket.io-parser encoded {"type":2,"data":["setState","system.adapter.yahka.0.memHeapTotal",{"val":22.73,"ack":true,"from":"system.adapter.yahka
                            host.ioBroker	2019-10-31 22:53:42.239	error	Caught by controller[42]: Thu, 31 Oct 2019 21:53:41 GMT socket.io-parser encoding packet {"type":2,"data":["setState","system.adapter.yahka.0.memHeapTotal",{"val":22.73,"ack":true,"from":"system.adapt
                            host.ioBroker	2019-10-31 22:53:42.239	error	Caught by controller[42]: Thu, 31 Oct 2019 21:53:41 GMT socket.io-client:manager writing packet {"type":2,"data":["setState","system.adapter.yahka.0.memHeapTotal",{"val":22.73,"ack":true,"from":"syste
                            host.ioBroker	2019-10-31 22:53:42.239	error	Caught by controller[42]: Thu, 31 Oct 2019 21:53:41 GMT socket.io-parser encoded {"type":2,"data":["setState","system.adapter.yahka.0.memRss",{"val":50.18,"ack":true,"from":"system.adapter.yahka.0"},n
                            host.ioBroker	2019-10-31 22:53:42.239	error	Caught by controller[42]: Thu, 31 Oct 2019 21:53:41 GMT socket.io-parser encoding packet {"type":2,"data":["setState","system.adapter.yahka.0.memRss",{"val":50.18,"ack":true,"from":"system.adapter.yah
                            host.ioBroker	2019-10-31 22:53:42.239	error	Caught by controller[42]: Thu, 31 Oct 2019 21:53:41 GMT socket.io-client:manager writing packet {"type":2,"data":["setState","system.adapter.yahka.0.memRss",{"val":50.18,"ack":true,"from":"system.adap
                            host.ioBroker	2019-10-31 22:53:42.239	error	Caught by controller[42]: Thu, 31 Oct 2019 21:53:41 GMT socket.io-parser encoded {"type":2,"data":["setState","system.adapter.yahka.0.connected",{"val":true,"ack":true,"expire":30,"from":"system.adapt
                            host.ioBroker	2019-10-31 22:53:42.239	error	Caught by controller[42]: Thu, 31 Oct 2019 21:53:41 GMT socket.io-parser encoding packet {"type":2,"data":["setState","system.adapter.yahka.0.connected",{"val":true,"ack":true,"expire":30,"from":"syst
                            host.ioBroker	2019-10-31 22:53:42.238	error	Caught by controller[42]: Thu, 31 Oct 2019 21:53:41 GMT socket.io-client:manager writing packet {"type":2,"data":["setState","system.adapter.yahka.0.connected",{"val":true,"ack":true,"expire":30,"from
                            host.ioBroker	2019-10-31 22:53:42.238	error	Caught by controller[42]: Thu, 31 Oct 2019 21:53:41 GMT socket.io-parser encoded {"type":2,"data":["setState","system.adapter.yahka.0.alive",{"val":true,"ack":true,"expire":25,"from":"system.adapter.y
                            host.ioBroker	2019-10-31 22:53:42.238	error	Caught by controller[42]: Thu, 31 Oct 2019 21:53:41 GMT socket.io-parser encoding packet {"type":2,"data":["setState","system.adapter.yahka.0.alive",{"val":true,"ack":true,"expire":25,"from":"system.a
                            host.ioBroker	2019-10-31 22:53:42.238	error	Caught by controller[42]: Thu, 31 Oct 2019 21:53:41 GMT socket.io-client:manager writing packet {"type":2,"data":["setState","system.adapter.yahka.0.alive",{"val":true,"ack":true,"expire":25,"from":"s
                            host.ioBroker	2019-10-31 22:53:42.238	error	Caught by controller[42]: Thu, 31 Oct 2019 21:53:41 GMT socket.io-parser encoded {"type":2,"data":["subscribe","*.logging",null],"options":{"compress":true},"nsp":"/"} as 2["subscribe","*.logging",nul
                            host.ioBroker	2019-10-31 22:53:42.238	error	Caught by controller[42]: Thu, 31 Oct 2019 21:53:41 GMT socket.io-parser encoding packet {"type":2,"data":["subscribe","*.logging",null],"options":{"compress":true},"nsp":"/"}
                            host.ioBroker	2019-10-31 22:53:42.238	error	Caught by controller[41]: Thu, 31 Oct 2019 21:53:41 GMT socket.io-client:manager writing packet {"type":2,"data":["subscribe","*.logging",null],"options":{"compress":true},"nsp":"/"}
                            host.ioBroker	2019-10-31 22:53:42.238	error	Caught by controller[41]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:socket flushing 1 packets in socket
                            host.ioBroker	2019-10-31 22:53:42.238	error	Caught by controller[41]: Thu, 31 Oct 2019 21:53:41 GMT socket.io-parser encoded {"type":2,"data":["getKeys","*.logging"],"options":{"compress":true},"id":1,"nsp":"/"} as 21["getKeys","*.logging"]
                            host.ioBroker	2019-10-31 22:53:42.238	error	Caught by controller[41]: Thu, 31 Oct 2019 21:53:41 GMT socket.io-parser encoding packet {"type":2,"data":["getKeys","*.logging"],"options":{"compress":true},"id":1,"nsp":"/"}
                            host.ioBroker	2019-10-31 22:53:42.238	error	Caught by controller[41]: Thu, 31 Oct 2019 21:53:41 GMT socket.io-client:manager writing packet {"type":2,"data":["getKeys","*.logging"],"options":{"compress":true},"id":1,"nsp":"/"}
                            host.ioBroker	2019-10-31 22:53:42.238	error	Caught by controller[41]: Thu, 31 Oct 2019 21:53:41 GMT socket.io-client:socket emitting packet with ack id 1
                            host.ioBroker	2019-10-31 22:53:42.238	error	Caught by controller[40]: Thu, 31 Oct 2019 21:53:41 GMT socket.io-client:socket calling ack 0 with [null,{"_id":"system.adapter.yahka.0","type":"instance","common":{"name":"yahka","version":"0.7.1","n
                            host.ioBroker	2019-10-31 22:53:42.237	error	Caught by controller[40]: Thu, 31 Oct 2019 21:53:41 GMT socket.io-parser decoded 30[null,{"_id":"system.adapter.yahka.0","type":"instance","common":{"name":"yahka","version":"0.7.1","news":{"0.7.1":{"
                            host.ioBroker	2019-10-31 22:53:42.237	error	Caught by controller[40]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:socket socket receive: type "message", data "30[null,{"_id":"system.adapter.yahka.0","type":"instance","common":{"name":"yahka"
                            host.ioBroker	2019-10-31 22:53:42.237	error	Caught by controller[39]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:polling ignoring poll - transport state "paused"
                            host.ioBroker	2019-10-31 22:53:42.237	error	Caught by controller[38]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:socket clearing existing transport polling
                            host.ioBroker	2019-10-31 22:53:42.237	error	Caught by controller[38]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:socket setting transport websocket
                            host.ioBroker	2019-10-31 22:53:42.237	error	Caught by controller[38]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:socket changing transport and sending upgrade packet
                            host.ioBroker	2019-10-31 22:53:42.237	error	Caught by controller[38]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:polling paused
                            host.ioBroker	2019-10-31 22:53:42.237	error	Caught by controller[38]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:polling pre-pause polling complete
                            host.ioBroker	2019-10-31 22:53:42.237	error	Caught by controller[38]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:socket flushing 1 packets in socket
                            host.ioBroker	2019-10-31 22:53:42.237	error	Caught by controller[37]: Thu, 31 Oct 2019 21:53:41 GMT socket.io-parser encoded {"type":2,"data":["getObject","system.adapter.yahka.0",null],"options":{"compress":true},"id":0,"nsp":"/"} as 20["getOb
                            host.ioBroker	2019-10-31 22:53:42.236	error	Caught by controller[37]: Thu, 31 Oct 2019 21:53:41 GMT socket.io-parser encoding packet {"type":2,"data":["getObject","system.adapter.yahka.0",null],"options":{"compress":true},"id":0,"nsp":"/"}
                            host.ioBroker	2019-10-31 22:53:42.236	error	Caught by controller[37]: Thu, 31 Oct 2019 21:53:41 GMT socket.io-client:manager writing packet {"type":2,"data":["getObject","system.adapter.yahka.0",null],"options":{"compress":true},"id":0,"nsp":"/
                            host.ioBroker	2019-10-31 22:53:42.236	error	Caught by controller[37]: Thu, 31 Oct 2019 21:53:41 GMT socket.io-client:socket emitting packet with ack id 0
                            host.ioBroker	2019-10-31 22:53:42.236	error	Caught by controller[37]: Thu, 31 Oct 2019 21:53:41 GMT socket.io-client:socket calling ack 0 with [null,{"val":false,"ack":true,"ts":1572558808623,"q":0,"from":"system.host.ioBroker","lc":15725588085
                            host.ioBroker	2019-10-31 22:53:42.236	error	Caught by controller[37]: Thu, 31 Oct 2019 21:53:41 GMT socket.io-parser decoded 30[null,{"val":false,"ack":true,"ts":1572558808623,"q":0,"from":"system.host.ioBroker","lc":1572558808526}] as {"type":
                            host.ioBroker	2019-10-31 22:53:42.236	error	Caught by controller[36]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:socket socket receive: type "message", data "30[null,{"val":false,"ack":true,"ts":1572558808623,"q":0,"from":"system.host.ioBro
                            host.ioBroker	2019-10-31 22:53:42.236	error	Caught by controller[36]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:polling polling got data 108:430[null,{"val":false,"ack":true,"ts":1572558808623,"q":0,"from":"system.host.ioBroker","lc":15725
                            host.ioBroker	2019-10-31 22:53:42.236	error	Caught by controller[36]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:polling pre-pause writing complete
                            host.ioBroker	2019-10-31 22:53:42.236	error	Caught by controller[35]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:polling we are currently writing - waiting to pause
                            host.ioBroker	2019-10-31 22:53:42.236	error	Caught by controller[34]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:polling we are currently polling - waiting to pause
                            host.ioBroker	2019-10-31 22:53:42.236	error	Caught by controller[34]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:socket pausing current transport "polling"
                            host.ioBroker	2019-10-31 22:53:42.236	error	Caught by controller[34]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:socket probe transport "websocket" pong
                            host.ioBroker	2019-10-31 22:53:42.236	error	Caught by controller[33]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:polling-xhr xhr data null
                            host.ioBroker	2019-10-31 22:53:42.236	error	Caught by controller[33]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:polling-xhr xhr open GET: http://127.0.0.1:9000/socket.io/?EIO=3&transport=polling&t=MuZprdt&b64=1&sid=Wsn4UOqXgtfLdCjYAAAp
                            host.ioBroker	2019-10-31 22:53:42.236	error	Caught by controller[33]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:polling-xhr xhr poll
                            host.ioBroker	2019-10-31 22:53:42.236	error	Caught by controller[33]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:polling polling
                            host.ioBroker	2019-10-31 22:53:42.235	error	Caught by controller[32]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:polling-xhr xhr data 46:420["getState","system.adapter.yahka.0.alive"]
                            host.ioBroker	2019-10-31 22:53:42.235	error	Caught by controller[32]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:polling-xhr xhr open POST: http://127.0.0.1:9000/socket.io/?EIO=3&transport=polling&t=MuZprdn&b64=1&sid=Wsn4UOqXgtfLdCjYAAAp
                            host.ioBroker	2019-10-31 22:53:42.235	error	Caught by controller[31]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:socket flushing 1 packets in socket
                            host.ioBroker	2019-10-31 22:53:42.235	error	Caught by controller[31]: Thu, 31 Oct 2019 21:53:41 GMT socket.io-parser encoded {"type":2,"data":["getState","system.adapter.yahka.0.alive"],"options":{"compress":true},"id":0,"nsp":"/"} as 20["getSt
                            host.ioBroker	2019-10-31 22:53:42.235	error	Caught by controller[31]: Thu, 31 Oct 2019 21:53:41 GMT socket.io-parser encoding packet {"type":2,"data":["getState","system.adapter.yahka.0.alive"],"options":{"compress":true},"id":0,"nsp":"/"}
                            host.ioBroker	2019-10-31 22:53:42.235	error	Caught by controller[31]: Thu, 31 Oct 2019 21:53:41 GMT socket.io-client:manager writing packet {"type":2,"data":["getState","system.adapter.yahka.0.alive"],"options":{"compress":true},"id":0,"nsp":"/
                            host.ioBroker	2019-10-31 22:53:42.235	error	Caught by controller[30]: Thu, 31 Oct 2019 21:53:41 GMT socket.io-client:socket emitting packet with ack id 0
                            host.ioBroker	2019-10-31 22:53:42.235	error	Caught by controller[29]: Thu, 31 Oct 2019 21:53:41 GMT socket.io-parser decoded 0 as {"type":0,"nsp":"/"}
                            host.ioBroker	2019-10-31 22:53:42.235	error	Caught by controller[29]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:socket socket receive: type "message", data "0"
                            host.ioBroker	2019-10-31 22:53:42.235	error	Caught by controller[29]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:polling polling got data 2:40
                            host.ioBroker	2019-10-31 22:53:42.235	error	Caught by controller[28]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:socket probe transport "websocket" opened
                            host.ioBroker	2019-10-31 22:53:42.235	error	Caught by controller[27]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:polling-xhr xhr data null
                            host.ioBroker	2019-10-31 22:53:42.235	error	Caught by controller[27]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:polling-xhr xhr open GET: http://127.0.0.1:9000/socket.io/?EIO=3&transport=polling&t=MuZprdN&b64=1&sid=Wsn4UOqXgtfLdCjYAAAp
                            host.ioBroker	2019-10-31 22:53:42.235	error	Caught by controller[27]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:polling-xhr xhr poll
                            host.ioBroker	2019-10-31 22:53:42.235	error	Caught by controller[27]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:polling polling
                            host.ioBroker	2019-10-31 22:53:42.235	error	Caught by controller[26]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:socket creating transport "websocket"
                            host.ioBroker	2019-10-31 22:53:42.234	error	Caught by controller[26]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:socket probing transport "websocket"
                            host.ioBroker	2019-10-31 22:53:42.234	error	Caught by controller[26]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:socket starting upgrade probes
                            host.ioBroker	2019-10-31 22:53:42.234	error	Caught by controller[26]: Thu, 31 Oct 2019 21:53:41 GMT socket.io-client:socket transport is open - connecting
                            host.ioBroker	2019-10-31 22:53:42.234	error	Caught by controller[26]: Thu, 31 Oct 2019 21:53:41 GMT socket.io-client:manager cleanup
                            host.ioBroker	2019-10-31 22:53:42.234	error	Caught by controller[26]: Thu, 31 Oct 2019 21:53:41 GMT socket.io-client:manager open
                            host.ioBroker	2019-10-31 22:53:42.234	error	Caught by controller[26]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:socket socket open
                            host.ioBroker	2019-10-31 22:53:42.234	error	Caught by controller[26]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:socket socket receive: type "open", data "{"sid":"Wsn4UOqXgtfLdCjYAAAp","upgrades":["websocket"],"pingInterval":25000,"pingTime
                            host.ioBroker	2019-10-31 22:53:42.234	error	Caught by controller[26]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:polling polling got data 97:0{"sid":"Wsn4UOqXgtfLdCjYAAAp","upgrades":["websocket"],"pingInterval":25000,"pingTimeout":60000}
                            host.ioBroker	2019-10-31 22:53:42.234	error	Caught by controller[25]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:polling ignoring poll - transport state "paused"
                            host.ioBroker	2019-10-31 22:53:42.234	error	Caught by controller[24]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:socket clearing existing transport polling
                            host.ioBroker	2019-10-31 22:53:42.234	error	Caught by controller[24]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:socket setting transport websocket
                            host.ioBroker	2019-10-31 22:53:42.234	error	Caught by controller[24]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:socket changing transport and sending upgrade packet
                            host.ioBroker	2019-10-31 22:53:42.234	error	Caught by controller[24]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:polling paused
                            host.ioBroker	2019-10-31 22:53:42.234	error	Caught by controller[24]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:polling pre-pause polling complete
                            host.ioBroker	2019-10-31 22:53:42.234	error	Caught by controller[23]: Thu, 31 Oct 2019 21:53:41 GMT socket.io-client:manager readyState opening
                            host.ioBroker	2019-10-31 22:53:42.234	error	Caught by controller[23]: Thu, 31 Oct 2019 21:53:41 GMT socket.io-client:manager connect attempt will timeout after 20000
                            host.ioBroker	2019-10-31 22:53:42.233	error	Caught by controller[23]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:socket setting transport polling
                            host.ioBroker	2019-10-31 22:53:42.233	error	Caught by controller[23]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:polling-xhr xhr data null
                            host.ioBroker	2019-10-31 22:53:42.233	error	Caught by controller[23]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:polling-xhr xhr open GET: http://127.0.0.1:9000/socket.io/?EIO=3&transport=polling&t=MuZprd3&b64=1
                            host.ioBroker	2019-10-31 22:53:42.233	error	Caught by controller[22]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:polling-xhr xhr poll
                            host.ioBroker	2019-10-31 22:53:42.233	error	Caught by controller[22]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:polling polling
                            host.ioBroker	2019-10-31 22:53:42.233	error	Caught by controller[22]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:socket creating transport "polling"
                            host.ioBroker	2019-10-31 22:53:42.233	error	Caught by controller[22]: Thu, 31 Oct 2019 21:53:41 GMT socket.io-client:manager opening http://127.0.0.1:9000
                            host.ioBroker	2019-10-31 22:53:42.233	error	Caught by controller[22]: Thu, 31 Oct 2019 21:53:41 GMT socket.io-client:manager readyState closed
                            host.ioBroker	2019-10-31 22:53:42.233	error	Caught by controller[22]: Thu, 31 Oct 2019 21:53:41 GMT socket.io-client new io instance for http://127.0.0.1:9000
                            host.ioBroker	2019-10-31 22:53:42.233	error	Caught by controller[21]: Thu, 31 Oct 2019 21:53:41 GMT socket.io-client:url parse http://127.0.0.1:9000
                            host.ioBroker	2019-10-31 22:53:42.233	error	Caught by controller[20]: Thu, 31 Oct 2019 21:53:41 GMT socket.io-parser decoded 0 as {"type":0,"nsp":"/"}
                            host.ioBroker	2019-10-31 22:53:42.233	error	Caught by controller[19]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:socket socket receive: type "message", data "0"
                            host.ioBroker	2019-10-31 22:53:42.233	error	Caught by controller[19]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:polling polling got data 2:40
                            host.ioBroker	2019-10-31 22:53:42.233	error	Caught by controller[18]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:polling we are currently polling - waiting to pause
                            host.ioBroker	2019-10-31 22:53:42.233	error	Caught by controller[18]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:socket pausing current transport "polling"
                            host.ioBroker	2019-10-31 22:53:42.233	error	Caught by controller[18]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:socket probe transport "websocket" pong
                            host.ioBroker	2019-10-31 22:53:42.232	error	Caught by controller[17]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:socket probe transport "websocket" opened
                            host.ioBroker	2019-10-31 22:53:42.232	error	Caught by controller[16]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:polling-xhr xhr data null
                            host.ioBroker	2019-10-31 22:53:42.232	error	Caught by controller[16]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:polling-xhr xhr open GET: http://127.0.0.1:9001/socket.io/?EIO=3&transport=polling&t=MuZprbp&b64=1&sid=OVYScHKOQzqVlOVhAAAo
                            host.ioBroker	2019-10-31 22:53:42.232	error	Caught by controller[15]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:polling-xhr xhr poll
                            host.ioBroker	2019-10-31 22:53:42.232	error	Caught by controller[15]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:polling polling
                            host.ioBroker	2019-10-31 22:53:42.232	error	Caught by controller[14]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:socket creating transport "websocket"
                            host.ioBroker	2019-10-31 22:53:42.232	error	Caught by controller[14]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:socket probing transport "websocket"
                            host.ioBroker	2019-10-31 22:53:42.232	error	Caught by controller[13]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:socket starting upgrade probes
                            host.ioBroker	2019-10-31 22:53:42.232	error	Caught by controller[13]: Thu, 31 Oct 2019 21:53:41 GMT socket.io-client:socket transport is open - connecting
                            host.ioBroker	2019-10-31 22:53:42.232	error	Caught by controller[12]: Thu, 31 Oct 2019 21:53:41 GMT socket.io-client:manager cleanup
                            host.ioBroker	2019-10-31 22:53:42.232	error	Caught by controller[12]: Thu, 31 Oct 2019 21:53:41 GMT socket.io-client:manager open
                            host.ioBroker	2019-10-31 22:53:42.232	error	Caught by controller[12]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:socket socket open
                            host.ioBroker	2019-10-31 22:53:42.232	error	Caught by controller[12]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:socket socket receive: type "open", data "{"sid":"OVYScHKOQzqVlOVhAAAo","upgrades":["websocket"],"pingInterval":25000,"pingTime
                            host.ioBroker	2019-10-31 22:53:42.232	error	Caught by controller[11]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:polling polling got data 97:0{"sid":"OVYScHKOQzqVlOVhAAAo","upgrades":["websocket"],"pingInterval":25000,"pingTimeout":60000}
                            host.ioBroker	2019-10-31 22:53:42.232	error	Caught by controller[10]: Thu, 31 Oct 2019 21:53:41 GMT socket.io-client:manager readyState opening
                            host.ioBroker	2019-10-31 22:53:42.232	error	Caught by controller[9]: Thu, 31 Oct 2019 21:53:41 GMT socket.io-client:manager connect attempt will timeout after 20000
                            host.ioBroker	2019-10-31 22:53:42.231	error	Caught by controller[9]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:socket setting transport polling
                            host.ioBroker	2019-10-31 22:53:42.231	error	Caught by controller[8]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:polling-xhr xhr data null
                            host.ioBroker	2019-10-31 22:53:42.231	error	Caught by controller[7]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:polling-xhr xhr open GET: http://127.0.0.1:9001/socket.io/?EIO=3&transport=polling&t=MuZprZm&b64=1
                            host.ioBroker	2019-10-31 22:53:42.231	error	Caught by controller[6]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:polling-xhr xhr poll
                            host.ioBroker	2019-10-31 22:53:42.231	error	Caught by controller[6]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:polling polling
                            host.ioBroker	2019-10-31 22:53:42.231	error	Caught by controller[5]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:socket creating transport "polling"
                            host.ioBroker	2019-10-31 22:53:42.231	error	Caught by controller[4]: Thu, 31 Oct 2019 21:53:41 GMT socket.io-client:manager opening http://127.0.0.1:9001
                            host.ioBroker	2019-10-31 22:53:42.231	error	Caught by controller[4]: Thu, 31 Oct 2019 21:53:41 GMT socket.io-client:manager readyState closed
                            host.ioBroker	2019-10-31 22:53:42.231	error	Caught by controller[3]: Thu, 31 Oct 2019 21:53:41 GMT socket.io-client new io instance for http://127.0.0.1:9001
                            host.ioBroker	2019-10-31 22:53:42.231	error	Caught by controller[2]: Thu, 31 Oct 2019 21:53:41 GMT socket.io-client:url parse http://127.0.0.1:9001
                            host.ioBroker	2019-10-31 22:53:42.231	error	Caught by controller[1]: *** WARNING *** For more information see <http://0pointer.de/avahi-compat?s=libdns_sd&e=node&f=DNSServiceRegister>
                            host.ioBroker	2019-10-31 22:53:42.231	error	Caught by controller[1]: *** WARNING *** Please fix your application to use the native API of Avahi!
                            host.ioBroker	2019-10-31 22:53:42.231	error	Caught by controller[1]: *** WARNING *** The program 'node' called 'DNSServiceRegister()' which is not supported (or only supported partially) in the Apple Bonjour compatibility layer of Avahi.
                            host.ioBroker	2019-10-31 22:53:42.231	error	Caught by controller[1]: *** WARNING *** For more information see <http://0pointer.de/avahi-compat?s=libdns_sd&e=node>
                            host.ioBroker	2019-10-31 22:53:42.230	error	Caught by controller[0]: *** WARNING *** The program 'node' uses the Apple Bonjour compatibility layer of Avahi.
                            host.ioBroker	2019-10-31 22:53:40.605	info	instance system.adapter.yahka.0 started with pid 1868
                            host.ioBroker	2019-10-31 22:53:40.591	info	object change system.adapter.yahka.0
                            admin.0	2019-10-31 22:53:35.626	info	successful connection to socket.io from ::ffff:192.168.10.119
                            host.ioBroker	2019-10-31 22:53:28.653	info	Restart adapter system.adapter.yahka.0 because enabled
                            host.ioBroker	2019-10-31 22:53:28.653	error	instance system.adapter.yahka.0 terminated with code 0 (OK)
                            Caught	2019-10-31 22:53:28.653	error	by controller[123]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-parser encoded {"type":2,"data":["setState","system.adapter.yahka.0.alive",{"val":false,"ack":true,"from":"system.adapter.yahka.0"}],"optio
                            Caught	2019-10-31 22:53:28.652	error	by controller[123]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-parser encoding packet {"type":2,"data":["setState","system.adapter.yahka.0.alive",{"val":false,"ack":true,"from":"system.adapter.yahka.0"}
                            Caught	2019-10-31 22:53:28.652	error	by controller[123]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-client:manager writing packet {"type":2,"data":["setState","system.adapter.yahka.0.alive",{"val":false,"ack":true,"from":"system.adapter.ya
                            Caught	2019-10-31 22:53:28.652	error	by controller[123]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-client:socket emitting packet with ack id 4
                            Caught	2019-10-31 22:53:28.652	error	by controller[123]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-client:socket calling ack 2 with [null,"system.adapter.yahka.0.alive"]
                            Caught	2019-10-31 22:53:28.652	error	by controller[123]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-parser decoded 32[null,"system.adapter.yahka.0.alive"] as {"type":3,"nsp":"/","id":2,"data":[null,"system.adapter.yahka.0.alive"]}
                            Caught	2019-10-31 22:53:28.652	error	by controller[123]: Thu, 31 Oct 2019 21:53:28 GMT engine.io-client:socket socket receive: type "message", data "32[null,"system.adapter.yahka.0.alive"]"
                            Caught	2019-10-31 22:53:28.652	error	by controller[123]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-parser encoded {"type":2,"data":["getStates",["system.adapter.admin.0.logging"]],"options":{"compress":true},"id":3,"nsp":"/"} as 23["getSt
                            Caught	2019-10-31 22:53:28.652	error	by controller[123]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-parser encoding packet {"type":2,"data":["getStates",["system.adapter.admin.0.logging"]],"options":{"compress":true},"id":3,"nsp":"/"}
                            Caught	2019-10-31 22:53:28.652	error	by controller[123]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-client:manager writing packet {"type":2,"data":["getStates",["system.adapter.admin.0.logging"]],"options":{"compress":true},"id":3,"nsp":"/
                            Caught	2019-10-31 22:53:28.652	error	by controller[123]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-client:socket emitting packet with ack id 3
                            Caught	2019-10-31 22:53:28.652	error	by controller[123]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-client:socket calling ack 1 with [null,["system.adapter.admin.0.logging"]]
                            Caught	2019-10-31 22:53:28.652	error	by controller[123]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-parser decoded 31[null,["system.adapter.admin.0.logging"]] as {"type":3,"nsp":"/","id":1,"data":[null,["system.adapter.admin.0.logging"]]}
                            Caught	2019-10-31 22:53:28.652	error	by controller[123]: Thu, 31 Oct 2019 21:53:28 GMT engine.io-client:socket socket receive: type "message", data "31[null,["system.adapter.admin.0.logging"]]"
                            Caught	2019-10-31 22:53:28.651	error	by controller[122]: Thu, 31 Oct 2019 21:53:28 GMT engine.io-client:socket flushing 17 packets in socket
                            Caught	2019-10-31 22:53:28.651	error	by controller[121]: Thu, 31 Oct 2019 21:53:28 GMT engine.io-client:socket flushing 11 packets in socket
                            Caught	2019-10-31 22:53:28.651	error	by controller[120]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-parser encoded {"type":2,"data":["setState","system.adapter.yahka.0.alive",{"val":false,"ack":true,"from":"system.adapter.yahka.0"}],"optio
                            Caught	2019-10-31 22:53:28.651	error	by controller[120]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-parser encoding packet {"type":2,"data":["setState","system.adapter.yahka.0.alive",{"val":false,"ack":true,"from":"system.adapter.yahka.0"}
                            Caught	2019-10-31 22:53:28.651	error	by controller[120]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-client:manager writing packet {"type":2,"data":["setState","system.adapter.yahka.0.alive",{"val":false,"ack":true,"from":"system.adapter.ya
                            Caught	2019-10-31 22:53:28.651	error	by controller[119]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-client:socket emitting packet with ack id 2
                            Caught	2019-10-31 22:53:28.651	error	by controller[118]: at emitListeningNT (net.js:1314:10) errorCode: -65537 }
                            Caught	2019-10-31 22:53:28.651	error	by controller[118]: at Server.emit (events.js:198:13)
                            Caught	2019-10-31 22:53:28.651	error	by controller[118]: at EventedHTTPServer.<anonymous> (/opt/iobroker/node_modules/hap-nodejs/lib/util/eventedhttp.js:65:10)
                            Caught	2019-10-31 22:53:28.651	error	by controller[118]: at EventedHTTPServer.emit (events.js:198:13)
                            Caught	2019-10-31 22:53:28.651	error	by controller[118]: at HAPServer._onListening (/opt/iobroker/node_modules/hap-nodejs/lib/HAPServer.js:190:8)
                            Caught	2019-10-31 22:53:28.651	error	by controller[118]: at HAPServer.emit (events.js:198:13)
                            Caught	2019-10-31 22:53:28.651	error	by controller[118]: at Bridge.Accessory._onListening (/opt/iobroker/node_modules/hap-nodejs/lib/Accessory.js:661:20)
                            Caught	2019-10-31 22:53:28.650	error	by controller[118]: at Advertiser.startAdvertising (/opt/iobroker/node_modules/hap-nodejs/lib/Advertiser.js:47:30)
                            Caught	2019-10-31 22:53:28.650	error	by controller[118]: at Object.create [as createAdvertisement] (/opt/iobroker/node_modules/mdns/lib/advertisement.js:64:10)
                            Caught	2019-10-31 22:53:28.650	error	by controller[118]: at new Advertisement (/opt/iobroker/node_modules/mdns/lib/advertisement.js:56:10)
                            Caught	2019-10-31 22:53:28.650	error	by controller[118]: { Error: dns service error: unknown
                            Caught	2019-10-31 22:53:28.650	error	by controller[117]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-parser encoded {"type":2,"data":["subscribe","yahka.0.checkLogging",null],"options":{"compress":true},"nsp":"/"} as 2["subscribe","yahka.0.
                            Caught	2019-10-31 22:53:28.650	error	by controller[117]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-parser encoding packet {"type":2,"data":["subscribe","yahka.0.checkLogging",null],"options":{"compress":true},"nsp":"/"}
                            Caught	2019-10-31 22:53:28.646	error	by controller[116]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-client:manager writing packet {"type":2,"data":["subscribe","yahka.0.checkLogging",null],"options":{"compress":true},"nsp":"/"}
                            Caught	2019-10-31 22:53:28.646	error	by controller[115]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-parser encoded {"type":2,"data":["subscribe","system.adapter.*",null,null],"options":{"compress":true},"nsp":"/"} as 2["subscribe","system.
                            Caught	2019-10-31 22:53:28.646	error	by controller[115]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-parser encoding packet {"type":2,"data":["subscribe","system.adapter.*",null,null],"options":{"compress":true},"nsp":"/"}
                            Caught	2019-10-31 22:53:28.646	error	by controller[114]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-client:manager writing packet {"type":2,"data":["subscribe","system.adapter.*",null,null],"options":{"compress":true},"nsp":"/"}
                            Caught	2019-10-31 22:53:28.646	error	by controller[113]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-parser encoded {"type":2,"data":["getObjectView","system","instance",{"startkey":"system.adapter.","endkey":"system.adapter.香"},{"name":"ya
                            Caught	2019-10-31 22:53:28.646	error	by controller[113]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-parser encoding packet {"type":2,"data":["getObjectView","system","instance",{"startkey":"system.adapter.","endkey":"system.adapter.香"},{"n
                            Caught	2019-10-31 22:53:28.646	error	by controller[112]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-client:manager writing packet {"type":2,"data":["getObjectView","system","instance",{"startkey":"system.adapter.","endkey":"system.adapter.
                            Caught	2019-10-31 22:53:28.646	error	by controller[111]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-client:socket emitting packet with ack id 9
                            Caught	2019-10-31 22:53:28.646	error	by controller[110]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-parser encoded {"type":2,"data":["subscribe","system.adapter.*",null,null],"options":{"compress":true},"nsp":"/"} as 2["subscribe","system.
                            Caught	2019-10-31 22:53:28.645	error	by controller[109]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-parser encoding packet {"type":2,"data":["subscribe","system.adapter.*",null,null],"options":{"compress":true},"nsp":"/"}
                            Caught	2019-10-31 22:53:28.645	error	by controller[109]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-client:manager writing packet {"type":2,"data":["subscribe","system.adapter.*",null,null],"options":{"compress":true},"nsp":"/"}
                            Caught	2019-10-31 22:53:28.645	error	by controller[108]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-parser encoded {"type":2,"data":["getObjectView","system","instance",{"startkey":"system.adapter.","endkey":"system.adapter.香"},{"name":"ya
                            Caught	2019-10-31 22:53:28.645	error	by controller[108]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-parser encoding packet {"type":2,"data":["getObjectView","system","instance",{"startkey":"system.adapter.","endkey":"system.adapter.香"},{"n
                            Caught	2019-10-31 22:53:28.645	error	by controller[108]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-client:manager writing packet {"type":2,"data":["getObjectView","system","instance",{"startkey":"system.adapter.","endkey":"system.adapter.
                            Caught	2019-10-31 22:53:28.645	error	by controller[107]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-client:socket emitting packet with ack id 8
                            Caught	2019-10-31 22:53:28.645	error	by controller[106]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-parser encoded {"type":2,"data":["subscribe","system.adapter.*",null,null],"options":{"compress":true},"nsp":"/"} as 2["subscribe","system.
                            Caught	2019-10-31 22:53:28.645	error	by controller[105]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-parser encoding packet {"type":2,"data":["subscribe","system.adapter.*",null,null],"options":{"compress":true},"nsp":"/"}
                            Caught	2019-10-31 22:53:28.645	error	by controller[105]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-client:manager writing packet {"type":2,"data":["subscribe","system.adapter.*",null,null],"options":{"compress":true},"nsp":"/"}
                            Caught	2019-10-31 22:53:28.645	error	by controller[104]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-parser encoded {"type":2,"data":["getObjectView","system","instance",{"startkey":"system.adapter.","endkey":"system.adapter.香"},{"name":"ya
                            Caught	2019-10-31 22:53:28.645	error	by controller[104]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-parser encoding packet {"type":2,"data":["getObjectView","system","instance",{"startkey":"system.adapter.","endkey":"system.adapter.香"},{"n
                            Caught	2019-10-31 22:53:28.644	error	by controller[104]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-client:manager writing packet {"type":2,"data":["getObjectView","system","instance",{"startkey":"system.adapter.","endkey":"system.adapter.
                            Caught	2019-10-31 22:53:28.644	error	by controller[103]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-client:socket emitting packet with ack id 7
                            Caught	2019-10-31 22:53:28.644	error	by controller[102]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-parser encoded {"type":2,"data":["subscribe","system.adapter.*",null,null],"options":{"compress":true},"nsp":"/"} as 2["subscribe","system.
                            Caught	2019-10-31 22:53:28.644	error	by controller[102]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-parser encoding packet {"type":2,"data":["subscribe","system.adapter.*",null,null],"options":{"compress":true},"nsp":"/"}
                            Caught	2019-10-31 22:53:28.644	error	by controller[102]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-client:manager writing packet {"type":2,"data":["subscribe","system.adapter.*",null,null],"options":{"compress":true},"nsp":"/"}
                            Caught	2019-10-31 22:53:28.644	error	by controller[102]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-parser encoded {"type":2,"data":["getObjectView","system","instance",{"startkey":"system.adapter.","endkey":"system.adapter.香"},{"name":"ya
                            Caught	2019-10-31 22:53:28.644	error	by controller[102]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-parser encoding packet {"type":2,"data":["getObjectView","system","instance",{"startkey":"system.adapter.","endkey":"system.adapter.香"},{"n
                            Caught	2019-10-31 22:53:28.644	error	by controller[102]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-client:manager writing packet {"type":2,"data":["getObjectView","system","instance",{"startkey":"system.adapter.","endkey":"system.adapter.
                            Caught	2019-10-31 22:53:28.644	error	by controller[102]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-client:socket emitting packet with ack id 6
                            Caught	2019-10-31 22:53:28.643	error	by controller[102]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-client:manager writing packet {"type":2,"data":["subscribe","system.adapter.*",null,null],"options":{"compress":true},"nsp":"/"}
                            Caught	2019-10-31 22:53:28.643	error	by controller[102]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-parser encoded {"type":2,"data":["getObjectView","system","instance",{"startkey":"system.adapter.","endkey":"system.adapter.香"},{"name":"ya
                            Caught	2019-10-31 22:53:28.643	error	by controller[102]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-parser encoding packet {"type":2,"data":["getObjectView","system","instance",{"startkey":"system.adapter.","endkey":"system.adapter.香"},{"n
                            Caught	2019-10-31 22:53:28.643	error	by controller[102]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-client:manager writing packet {"type":2,"data":["getObjectView","system","instance",{"startkey":"system.adapter.","endkey":"system.adapter.
                            Caught	2019-10-31 22:53:28.643	error	by controller[102]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-client:socket emitting packet with ack id 5
                            Caught	2019-10-31 22:53:28.643	error	by controller[102]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-parser encoded {"type":2,"data":["subscribe","system.adapter.*",null,null],"options":{"compress":true},"nsp":"/"} as 2["subscribe","system.
                            Caught	2019-10-31 22:53:28.643	error	by controller[102]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-parser encoding packet {"type":2,"data":["subscribe","system.adapter.*",null,null],"options":{"compress":true},"nsp":"/"}
                            Caught	2019-10-31 22:53:28.642	error	by controller[102]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-client:socket emitting packet with ack id 4
                            Caught	2019-10-31 22:53:28.642	error	by controller[102]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-parser encoded {"type":2,"data":["subscribe","system.adapter.*",null,null],"options":{"compress":true},"nsp":"/"} as 2["subscribe","system.
                            Caught	2019-10-31 22:53:28.642	error	by controller[102]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-parser encoding packet {"type":2,"data":["subscribe","system.adapter.*",null,null],"options":{"compress":true},"nsp":"/"}
                            Caught	2019-10-31 22:53:28.642	error	by controller[102]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-client:manager writing packet {"type":2,"data":["subscribe","system.adapter.*",null,null],"options":{"compress":true},"nsp":"/"}
                            Caught	2019-10-31 22:53:28.642	error	by controller[102]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-parser encoded {"type":2,"data":["getObjectView","system","instance",{"startkey":"system.adapter.","endkey":"system.adapter.香"},{"name":"ya
                            Caught	2019-10-31 22:53:28.642	error	by controller[102]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-parser encoding packet {"type":2,"data":["getObjectView","system","instance",{"startkey":"system.adapter.","endkey":"system.adapter.香"},{"n
                            Caught	2019-10-31 22:53:28.641	error	by controller[102]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-client:manager writing packet {"type":2,"data":["getObjectView","system","instance",{"startkey":"system.adapter.","endkey":"system.adapter.
                            Caught	2019-10-31 22:53:28.641	error	by controller[102]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-client:socket emitting packet with ack id 3
                            Caught	2019-10-31 22:53:28.641	error	by controller[102]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-parser encoded {"type":2,"data":["subscribe","system.adapter.*",null,null],"options":{"compress":true},"nsp":"/"} as 2["subscribe","system.
                            Caught	2019-10-31 22:53:28.641	error	by controller[102]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-parser encoding packet {"type":2,"data":["subscribe","system.adapter.*",null,null],"options":{"compress":true},"nsp":"/"}
                            Caught	2019-10-31 22:53:28.641	error	by controller[102]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-client:manager writing packet {"type":2,"data":["subscribe","system.adapter.*",null,null],"options":{"compress":true},"nsp":"/"}
                            Caught	2019-10-31 22:53:28.641	error	by controller[102]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-parser encoded {"type":2,"data":["getObjectView","system","instance",{"startkey":"system.adapter.","endkey":"system.adapter.香"},{"name":"ya
                            Caught	2019-10-31 22:53:28.641	error	by controller[102]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-parser encoding packet {"type":2,"data":["getObjectView","system","instance",{"startkey":"system.adapter.","endkey":"system.adapter.香"},{"n
                            Caught	2019-10-31 22:53:28.641	error	by controller[102]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-client:socket emitting packet with ack id 2
                            Caught	2019-10-31 22:53:28.640	error	by controller[101]: Thu, 31 Oct 2019 21:53:28 GMT engine.io-client:socket flushing 1 packets in socket
                            Caught	2019-10-31 22:53:28.640	error	by controller[100]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-parser encoded {"type":2,"data":["getObjectView","system","instance",{"startkey":"system.adapter.","endkey":"system.adapter.香"},{"name":"ya
                            Caught	2019-10-31 22:53:28.640	error	by controller[99]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-parser encoding packet {"type":2,"data":["getObjectView","system","instance",{"startkey":"system.adapter.","endkey":"system.adapter.香"},{"na
                            Caught	2019-10-31 22:53:28.640	error	by controller[99]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-client:manager writing packet {"type":2,"data":["getObjectView","system","instance",{"startkey":"system.adapter.","endkey":"system.adapter.香
                            Caught	2019-10-31 22:53:28.640	error	by controller[98]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-client:socket emitting packet with ack id 1
                            Caught	2019-10-31 22:53:28.640	error	by controller[97]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-parser encoded {"type":2,"data":["setState","system.adapter.yahka.0.outputCount",{"val":8,"ack":true,"from":"system.adapter.yahka.0"},null],
                            Caught	2019-10-31 22:53:28.640	error	by controller[97]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-parser encoding packet {"type":2,"data":["setState","system.adapter.yahka.0.outputCount",{"val":8,"ack":true,"from":"system.adapter.yahka.0"
                            Caught	2019-10-31 22:53:28.640	error	by controller[97]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-client:manager writing packet {"type":2,"data":["setState","system.adapter.yahka.0.outputCount",{"val":8,"ack":true,"from":"system.adapter.y
                            Caught	2019-10-31 22:53:28.640	error	by controller[97]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-parser encoded {"type":2,"data":["setState","system.adapter.yahka.0.inputCount",{"val":0,"ack":true,"from":"system.adapter.yahka.0"},null],"
                            Caught	2019-10-31 22:53:28.640	error	by controller[97]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-parser encoding packet {"type":2,"data":["setState","system.adapter.yahka.0.inputCount",{"val":0,"ack":true,"from":"system.adapter.yahka.0"}
                            Caught	2019-10-31 22:53:28.640	error	by controller[97]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-client:manager writing packet {"type":2,"data":["setState","system.adapter.yahka.0.inputCount",{"val":0,"ack":true,"from":"system.adapter.ya
                            Caught	2019-10-31 22:53:28.639	error	by controller[97]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-parser encoded {"type":2,"data":["setState","system.adapter.yahka.0.uptime",{"val":1,"ack":true,"from":"system.adapter.yahka.0"},null],"opti
                            Caught	2019-10-31 22:53:28.639	error	by controller[97]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-parser encoding packet {"type":2,"data":["setState","system.adapter.yahka.0.uptime",{"val":1,"ack":true,"from":"system.adapter.yahka.0"},nul
                            Caught	2019-10-31 22:53:28.639	error	by controller[97]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-client:manager writing packet {"type":2,"data":["setState","system.adapter.yahka.0.uptime",{"val":1,"ack":true,"from":"system.adapter.yahka.
                            Caught	2019-10-31 22:53:28.639	error	by controller[97]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-parser encoded {"type":2,"data":["setState","system.adapter.yahka.0.memHeapUsed",{"val":12.66,"ack":true,"from":"system.adapter.yahka.0"},nu
                            Caught	2019-10-31 22:53:28.639	error	by controller[97]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-parser encoding packet {"type":2,"data":["setState","system.adapter.yahka.0.memHeapUsed",{"val":12.66,"ack":true,"from":"system.adapte
                            GlasfaserG haselchenH 2 Antworten Letzte Antwort
                            • D doctorultra
                              neid leider nicht
                              host.ioBroker	2019-10-31 22:53:42.245	error	instance system.adapter.yahka.0 terminated with code 0 (OK)
                              host.ioBroker	2019-10-31 22:53:42.245	error	Caught by controller[61]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-parser encoded {"type":2,"data":["setState","system.adapter.yahka.0.alive",{"val":false,"ack":true,"from":"system.adapter.yahka.0"}],"
                              host.ioBroker	2019-10-31 22:53:42.245	error	Caught by controller[61]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-parser encoding packet {"type":2,"data":["setState","system.adapter.yahka.0.alive",{"val":false,"ack":true,"from":"system.adapter.yahk
                              host.ioBroker	2019-10-31 22:53:42.245	error	Caught by controller[61]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-client:manager writing packet {"type":2,"data":["setState","system.adapter.yahka.0.alive",{"val":false,"ack":true,"from":"system.adapt
                              host.ioBroker	2019-10-31 22:53:42.245	error	Caught by controller[61]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-client:socket emitting packet with ack id 4
                              host.ioBroker	2019-10-31 22:53:42.245	error	Caught by controller[61]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-client:socket calling ack 2 with [null,"system.adapter.yahka.0.alive"]
                              host.ioBroker	2019-10-31 22:53:42.245	error	Caught by controller[61]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-parser decoded 32[null,"system.adapter.yahka.0.alive"] as {"type":3,"nsp":"/","id":2,"data":[null,"system.adapter.yahka.0.alive"]}
                              host.ioBroker	2019-10-31 22:53:42.245	error	Caught by controller[61]: Thu, 31 Oct 2019 21:53:42 GMT engine.io-client:socket socket receive: type "message", data "32[null,"system.adapter.yahka.0.alive"]"
                              host.ioBroker	2019-10-31 22:53:42.245	error	Caught by controller[61]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-parser encoded {"type":2,"data":["getStates",["system.adapter.admin.0.logging"]],"options":{"compress":true},"id":3,"nsp":"/"} as 23["
                              host.ioBroker	2019-10-31 22:53:42.245	error	Caught by controller[61]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-parser encoding packet {"type":2,"data":["getStates",["system.adapter.admin.0.logging"]],"options":{"compress":true},"id":3,"nsp":"/"}
                              host.ioBroker	2019-10-31 22:53:42.245	error	Caught by controller[61]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-client:manager writing packet {"type":2,"data":["getStates",["system.adapter.admin.0.logging"]],"options":{"compress":true},"id":3,"ns
                              host.ioBroker	2019-10-31 22:53:42.245	error	Caught by controller[61]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-client:socket emitting packet with ack id 3
                              host.ioBroker	2019-10-31 22:53:42.245	error	Caught by controller[61]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-client:socket calling ack 1 with [null,["system.adapter.admin.0.logging"]]
                              host.ioBroker	2019-10-31 22:53:42.245	error	Caught by controller[61]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-parser decoded 31[null,["system.adapter.admin.0.logging"]] as {"type":3,"nsp":"/","id":1,"data":[null,["system.adapter.admin.0.logging
                              host.ioBroker	2019-10-31 22:53:42.245	error	Caught by controller[61]: Thu, 31 Oct 2019 21:53:42 GMT engine.io-client:socket socket receive: type "message", data "31[null,["system.adapter.admin.0.logging"]]"
                              host.ioBroker	2019-10-31 22:53:42.244	error	Caught by controller[60]: Thu, 31 Oct 2019 21:53:42 GMT engine.io-client:socket flushing 17 packets in socket
                              host.ioBroker	2019-10-31 22:53:42.244	error	Caught by controller[59]: Thu, 31 Oct 2019 21:53:42 GMT engine.io-client:socket flushing 11 packets in socket
                              host.ioBroker	2019-10-31 22:53:42.244	error	Caught by controller[58]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-parser encoded {"type":2,"data":["setState","system.adapter.yahka.0.alive",{"val":false,"ack":true,"from":"system.adapter.yahka.0"}],"
                              host.ioBroker	2019-10-31 22:53:42.244	error	Caught by controller[58]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-parser encoding packet {"type":2,"data":["setState","system.adapter.yahka.0.alive",{"val":false,"ack":true,"from":"system.adapter.yahk
                              host.ioBroker	2019-10-31 22:53:42.244	error	Caught by controller[58]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-client:manager writing packet {"type":2,"data":["setState","system.adapter.yahka.0.alive",{"val":false,"ack":true,"from":"system.adapt
                              host.ioBroker	2019-10-31 22:53:42.244	error	Caught by controller[58]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-client:socket emitting packet with ack id 2
                              host.ioBroker	2019-10-31 22:53:42.244	error	Caught by controller[57]: at emitListeningNT (net.js:1314:10) errorCode: -65537 }
                              host.ioBroker	2019-10-31 22:53:42.244	error	Caught by controller[57]: at Server.emit (events.js:198:13)
                              host.ioBroker	2019-10-31 22:53:42.244	error	Caught by controller[57]: at EventedHTTPServer.<anonymous> (/opt/iobroker/node_modules/hap-nodejs/lib/util/eventedhttp.js:65:10)
                              host.ioBroker	2019-10-31 22:53:42.244	error	Caught by controller[57]: at EventedHTTPServer.emit (events.js:198:13)
                              host.ioBroker	2019-10-31 22:53:42.244	error	Caught by controller[57]: at HAPServer._onListening (/opt/iobroker/node_modules/hap-nodejs/lib/HAPServer.js:190:8)
                              host.ioBroker	2019-10-31 22:53:42.244	error	Caught by controller[57]: at HAPServer.emit (events.js:198:13)
                              host.ioBroker	2019-10-31 22:53:42.244	error	Caught by controller[57]: at Bridge.Accessory._onListening (/opt/iobroker/node_modules/hap-nodejs/lib/Accessory.js:661:20)
                              host.ioBroker	2019-10-31 22:53:42.244	error	Caught by controller[57]: at Advertiser.startAdvertising (/opt/iobroker/node_modules/hap-nodejs/lib/Advertiser.js:47:30)
                              host.ioBroker	2019-10-31 22:53:42.244	error	Caught by controller[57]: at Object.create [as createAdvertisement] (/opt/iobroker/node_modules/mdns/lib/advertisement.js:64:10)
                              host.ioBroker	2019-10-31 22:53:42.244	error	Caught by controller[57]: at new Advertisement (/opt/iobroker/node_modules/mdns/lib/advertisement.js:56:10)
                              host.ioBroker	2019-10-31 22:53:42.244	error	Caught by controller[57]: { Error: dns service error: unknown
                              host.ioBroker	2019-10-31 22:53:42.244	error	Caught by controller[56]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-parser encoded {"type":2,"data":["subscribe","yahka.0.checkLogging",null],"options":{"compress":true},"nsp":"/"} as 2["subscribe","yah
                              host.ioBroker	2019-10-31 22:53:42.243	error	Caught by controller[56]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-parser encoding packet {"type":2,"data":["subscribe","yahka.0.checkLogging",null],"options":{"compress":true},"nsp":"/"}
                              host.ioBroker	2019-10-31 22:53:42.243	error	Caught by controller[55]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-client:manager writing packet {"type":2,"data":["subscribe","yahka.0.checkLogging",null],"options":{"compress":true},"nsp":"/"}
                              host.ioBroker	2019-10-31 22:53:42.243	error	Caught by controller[54]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-parser encoded {"type":2,"data":["subscribe","system.adapter.*",null,null],"options":{"compress":true},"nsp":"/"} as 2["subscribe","sy
                              host.ioBroker	2019-10-31 22:53:42.243	error	Caught by controller[54]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-parser encoding packet {"type":2,"data":["subscribe","system.adapter.*",null,null],"options":{"compress":true},"nsp":"/"}
                              host.ioBroker	2019-10-31 22:53:42.243	error	Caught by controller[54]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-client:manager writing packet {"type":2,"data":["subscribe","system.adapter.*",null,null],"options":{"compress":true},"nsp":"/"}
                              host.ioBroker	2019-10-31 22:53:42.243	error	Caught by controller[54]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-parser encoded {"type":2,"data":["getObjectView","system","instance",{"startkey":"system.adapter.","endkey":"system.adapter.香"},{"name
                              host.ioBroker	2019-10-31 22:53:42.243	error	Caught by controller[54]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-parser encoding packet {"type":2,"data":["getObjectView","system","instance",{"startkey":"system.adapter.","endkey":"system.adapter.香"
                              host.ioBroker	2019-10-31 22:53:42.243	error	Caught by controller[54]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-client:manager writing packet {"type":2,"data":["getObjectView","system","instance",{"startkey":"system.adapter.","endkey":"system.ada
                              host.ioBroker	2019-10-31 22:53:42.243	error	Caught by controller[54]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-client:socket emitting packet with ack id 9
                              host.ioBroker	2019-10-31 22:53:42.243	error	Caught by controller[54]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-client:socket emitting packet with ack id 8
                              host.ioBroker	2019-10-31 22:53:42.243	error	Caught by controller[53]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-parser encoded {"type":2,"data":["subscribe","system.adapter.*",null,null],"options":{"compress":true},"nsp":"/"} as 2["subscribe","sy
                              host.ioBroker	2019-10-31 22:53:42.243	error	Caught by controller[52]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-parser encoding packet {"type":2,"data":["subscribe","system.adapter.*",null,null],"options":{"compress":true},"nsp":"/"}
                              host.ioBroker	2019-10-31 22:53:42.242	error	Caught by controller[52]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-client:manager writing packet {"type":2,"data":["subscribe","system.adapter.*",null,null],"options":{"compress":true},"nsp":"/"}
                              host.ioBroker	2019-10-31 22:53:42.242	error	Caught by controller[52]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-parser encoded {"type":2,"data":["getObjectView","system","instance",{"startkey":"system.adapter.","endkey":"system.adapter.香"},{"name
                              host.ioBroker	2019-10-31 22:53:42.242	error	Caught by controller[52]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-parser encoding packet {"type":2,"data":["getObjectView","system","instance",{"startkey":"system.adapter.","endkey":"system.adapter.香"
                              host.ioBroker	2019-10-31 22:53:42.242	error	Caught by controller[52]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-client:manager writing packet {"type":2,"data":["getObjectView","system","instance",{"startkey":"system.adapter.","endkey":"system.ada
                              host.ioBroker	2019-10-31 22:53:42.242	error	Caught by controller[51]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-client:socket emitting packet with ack id 7
                              host.ioBroker	2019-10-31 22:53:42.242	error	Caught by controller[50]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-parser encoded {"type":2,"data":["subscribe","system.adapter.*",null,null],"options":{"compress":true},"nsp":"/"} as 2["subscribe","sy
                              host.ioBroker	2019-10-31 22:53:42.242	error	Caught by controller[50]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-parser encoding packet {"type":2,"data":["subscribe","system.adapter.*",null,null],"options":{"compress":true},"nsp":"/"}
                              host.ioBroker	2019-10-31 22:53:42.242	error	Caught by controller[50]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-client:manager writing packet {"type":2,"data":["subscribe","system.adapter.*",null,null],"options":{"compress":true},"nsp":"/"}
                              host.ioBroker	2019-10-31 22:53:42.242	error	Caught by controller[50]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-parser encoded {"type":2,"data":["getObjectView","system","instance",{"startkey":"system.adapter.","endkey":"system.adapter.香"},{"name
                              host.ioBroker	2019-10-31 22:53:42.242	error	Caught by controller[50]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-parser encoding packet {"type":2,"data":["getObjectView","system","instance",{"startkey":"system.adapter.","endkey":"system.adapter.香"
                              host.ioBroker	2019-10-31 22:53:42.242	error	Caught by controller[50]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-client:manager writing packet {"type":2,"data":["getObjectView","system","instance",{"startkey":"system.adapter.","endkey":"system.ada
                              host.ioBroker	2019-10-31 22:53:42.242	error	Caught by controller[50]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-client:socket emitting packet with ack id 6
                              host.ioBroker	2019-10-31 22:53:42.242	error	Caught by controller[49]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-parser encoded {"type":2,"data":["subscribe","system.adapter.*",null,null],"options":{"compress":true},"nsp":"/"} as 2["subscribe","sy
                              host.ioBroker	2019-10-31 22:53:42.242	error	Caught by controller[49]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-parser encoding packet {"type":2,"data":["subscribe","system.adapter.*",null,null],"options":{"compress":true},"nsp":"/"}
                              host.ioBroker	2019-10-31 22:53:42.242	error	Caught by controller[49]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-client:manager writing packet {"type":2,"data":["subscribe","system.adapter.*",null,null],"options":{"compress":true},"nsp":"/"}
                              host.ioBroker	2019-10-31 22:53:42.242	error	Caught by controller[49]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-parser encoded {"type":2,"data":["getObjectView","system","instance",{"startkey":"system.adapter.","endkey":"system.adapter.香"},{"name
                              host.ioBroker	2019-10-31 22:53:42.242	error	Caught by controller[49]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-parser encoding packet {"type":2,"data":["getObjectView","system","instance",{"startkey":"system.adapter.","endkey":"system.adapter.香"
                              host.ioBroker	2019-10-31 22:53:42.241	error	Caught by controller[49]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-client:manager writing packet {"type":2,"data":["getObjectView","system","instance",{"startkey":"system.adapter.","endkey":"system.ada
                              host.ioBroker	2019-10-31 22:53:42.241	error	Caught by controller[49]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-client:socket emitting packet with ack id 5
                              host.ioBroker	2019-10-31 22:53:42.241	error	Caught by controller[48]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-parser encoded {"type":2,"data":["subscribe","system.adapter.*",null,null],"options":{"compress":true},"nsp":"/"} as 2["subscribe","sy
                              host.ioBroker	2019-10-31 22:53:42.241	error	Caught by controller[48]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-parser encoding packet {"type":2,"data":["subscribe","system.adapter.*",null,null],"options":{"compress":true},"nsp":"/"}
                              host.ioBroker	2019-10-31 22:53:42.241	error	Caught by controller[48]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-client:manager writing packet {"type":2,"data":["subscribe","system.adapter.*",null,null],"options":{"compress":true},"nsp":"/"}
                              host.ioBroker	2019-10-31 22:53:42.241	error	Caught by controller[48]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-parser encoded {"type":2,"data":["getObjectView","system","instance",{"startkey":"system.adapter.","endkey":"system.adapter.香"},{"name
                              host.ioBroker	2019-10-31 22:53:42.241	error	Caught by controller[47]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-parser encoding packet {"type":2,"data":["getObjectView","system","instance",{"startkey":"system.adapter.","endkey":"system.adapter.香"
                              host.ioBroker	2019-10-31 22:53:42.241	error	Caught by controller[47]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-client:manager writing packet {"type":2,"data":["getObjectView","system","instance",{"startkey":"system.adapter.","endkey":"system.ada
                              host.ioBroker	2019-10-31 22:53:42.241	error	Caught by controller[47]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-client:socket emitting packet with ack id 4
                              host.ioBroker	2019-10-31 22:53:42.241	error	Caught by controller[47]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-parser encoded {"type":2,"data":["subscribe","system.adapter.*",null,null],"options":{"compress":true},"nsp":"/"} as 2["subscribe","sy
                              host.ioBroker	2019-10-31 22:53:42.241	error	Caught by controller[47]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-parser encoding packet {"type":2,"data":["subscribe","system.adapter.*",null,null],"options":{"compress":true},"nsp":"/"}
                              host.ioBroker	2019-10-31 22:53:42.241	error	Caught by controller[47]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-client:manager writing packet {"type":2,"data":["subscribe","system.adapter.*",null,null],"options":{"compress":true},"nsp":"/"}
                              host.ioBroker	2019-10-31 22:53:42.241	error	Caught by controller[47]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-parser encoded {"type":2,"data":["getObjectView","system","instance",{"startkey":"system.adapter.","endkey":"system.adapter.香"},{"name
                              host.ioBroker	2019-10-31 22:53:42.241	error	Caught by controller[47]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-client:socket emitting packet with ack id 3
                              host.ioBroker	2019-10-31 22:53:42.240	error	Caught by controller[47]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-parser encoding packet {"type":2,"data":["subscribe","system.adapter.*",null,null],"options":{"compress":true},"nsp":"/"}
                              host.ioBroker	2019-10-31 22:53:42.240	error	Caught by controller[47]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-client:manager writing packet {"type":2,"data":["subscribe","system.adapter.*",null,null],"options":{"compress":true},"nsp":"/"}
                              host.ioBroker	2019-10-31 22:53:42.240	error	Caught by controller[47]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-parser encoded {"type":2,"data":["getObjectView","system","instance",{"startkey":"system.adapter.","endkey":"system.adapter.香"},{"name
                              host.ioBroker	2019-10-31 22:53:42.240	error	Caught by controller[47]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-parser encoding packet {"type":2,"data":["getObjectView","system","instance",{"startkey":"system.adapter.","endkey":"system.adapter.香"
                              host.ioBroker	2019-10-31 22:53:42.240	error	Caught by controller[47]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-client:manager writing packet {"type":2,"data":["getObjectView","system","instance",{"startkey":"system.adapter.","endkey":"system.ada
                              host.ioBroker	2019-10-31 22:53:42.240	error	Caught by controller[47]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-client:socket emitting packet with ack id 2
                              host.ioBroker	2019-10-31 22:53:42.240	error	Caught by controller[47]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-parser encoded {"type":2,"data":["subscribe","system.adapter.*",null,null],"options":{"compress":true},"nsp":"/"} as 2["subscribe","sy
                              host.ioBroker	2019-10-31 22:53:42.240	error	Caught by controller[46]: Thu, 31 Oct 2019 21:53:42 GMT engine.io-client:socket flushing 1 packets in socket
                              host.ioBroker	2019-10-31 22:53:42.240	error	Caught by controller[45]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-parser encoded {"type":2,"data":["getObjectView","system","instance",{"startkey":"system.adapter.","endkey":"system.adapter.香"},{"name
                              host.ioBroker	2019-10-31 22:53:42.240	error	Caught by controller[44]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-parser encoding packet {"type":2,"data":["getObjectView","system","instance",{"startkey":"system.adapter.","endkey":"system.adapter.香"
                              host.ioBroker	2019-10-31 22:53:42.240	error	Caught by controller[44]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-client:manager writing packet {"type":2,"data":["getObjectView","system","instance",{"startkey":"system.adapter.","endkey":"system.ada
                              host.ioBroker	2019-10-31 22:53:42.240	error	Caught by controller[43]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-client:socket emitting packet with ack id 1
                              host.ioBroker	2019-10-31 22:53:42.240	error	Caught by controller[42]: Thu, 31 Oct 2019 21:53:41 GMT socket.io-parser encoded {"type":2,"data":["setState","system.adapter.yahka.0.outputCount",{"val":8,"ack":true,"from":"system.adapter.yahka.0"},
                              host.ioBroker	2019-10-31 22:53:42.240	error	Caught by controller[42]: Thu, 31 Oct 2019 21:53:41 GMT socket.io-parser encoding packet {"type":2,"data":["setState","system.adapter.yahka.0.outputCount",{"val":8,"ack":true,"from":"system.adapter.ya
                              host.ioBroker	2019-10-31 22:53:42.240	error	Caught by controller[42]: Thu, 31 Oct 2019 21:53:41 GMT socket.io-client:manager writing packet {"type":2,"data":["setState","system.adapter.yahka.0.outputCount",{"val":8,"ack":true,"from":"system.ada
                              host.ioBroker	2019-10-31 22:53:42.239	error	Caught by controller[42]: Thu, 31 Oct 2019 21:53:41 GMT socket.io-parser encoded {"type":2,"data":["setState","system.adapter.yahka.0.inputCount",{"val":0,"ack":true,"from":"system.adapter.yahka.0"},n
                              host.ioBroker	2019-10-31 22:53:42.239	error	Caught by controller[42]: Thu, 31 Oct 2019 21:53:41 GMT socket.io-parser encoding packet {"type":2,"data":["setState","system.adapter.yahka.0.inputCount",{"val":0,"ack":true,"from":"system.adapter.yah
                              host.ioBroker	2019-10-31 22:53:42.239	error	Caught by controller[42]: Thu, 31 Oct 2019 21:53:41 GMT socket.io-client:manager writing packet {"type":2,"data":["setState","system.adapter.yahka.0.inputCount",{"val":0,"ack":true,"from":"system.adap
                              host.ioBroker	2019-10-31 22:53:42.239	error	Caught by controller[42]: Thu, 31 Oct 2019 21:53:41 GMT socket.io-parser encoded {"type":2,"data":["setState","system.adapter.yahka.0.uptime",{"val":1,"ack":true,"from":"system.adapter.yahka.0"},null]
                              host.ioBroker	2019-10-31 22:53:42.239	error	Caught by controller[42]: Thu, 31 Oct 2019 21:53:41 GMT socket.io-parser encoding packet {"type":2,"data":["setState","system.adapter.yahka.0.uptime",{"val":1,"ack":true,"from":"system.adapter.yahka.0
                              host.ioBroker	2019-10-31 22:53:42.239	error	Caught by controller[42]: Thu, 31 Oct 2019 21:53:41 GMT socket.io-client:manager writing packet {"type":2,"data":["setState","system.adapter.yahka.0.uptime",{"val":1,"ack":true,"from":"system.adapter.
                              host.ioBroker	2019-10-31 22:53:42.239	error	Caught by controller[42]: Thu, 31 Oct 2019 21:53:41 GMT socket.io-parser encoded {"type":2,"data":["setState","system.adapter.yahka.0.memHeapUsed",{"val":12.71,"ack":true,"from":"system.adapter.yahka.
                              host.ioBroker	2019-10-31 22:53:42.239	error	Caught by controller[42]: Thu, 31 Oct 2019 21:53:41 GMT socket.io-parser encoding packet {"type":2,"data":["setState","system.adapter.yahka.0.memHeapUsed",{"val":12.71,"ack":true,"from":"system.adapte
                              host.ioBroker	2019-10-31 22:53:42.239	error	Caught by controller[42]: Thu, 31 Oct 2019 21:53:41 GMT socket.io-client:manager writing packet {"type":2,"data":["setState","system.adapter.yahka.0.memHeapUsed",{"val":12.71,"ack":true,"from":"system
                              host.ioBroker	2019-10-31 22:53:42.239	error	Caught by controller[42]: Thu, 31 Oct 2019 21:53:41 GMT socket.io-parser encoded {"type":2,"data":["setState","system.adapter.yahka.0.memHeapTotal",{"val":22.73,"ack":true,"from":"system.adapter.yahka
                              host.ioBroker	2019-10-31 22:53:42.239	error	Caught by controller[42]: Thu, 31 Oct 2019 21:53:41 GMT socket.io-parser encoding packet {"type":2,"data":["setState","system.adapter.yahka.0.memHeapTotal",{"val":22.73,"ack":true,"from":"system.adapt
                              host.ioBroker	2019-10-31 22:53:42.239	error	Caught by controller[42]: Thu, 31 Oct 2019 21:53:41 GMT socket.io-client:manager writing packet {"type":2,"data":["setState","system.adapter.yahka.0.memHeapTotal",{"val":22.73,"ack":true,"from":"syste
                              host.ioBroker	2019-10-31 22:53:42.239	error	Caught by controller[42]: Thu, 31 Oct 2019 21:53:41 GMT socket.io-parser encoded {"type":2,"data":["setState","system.adapter.yahka.0.memRss",{"val":50.18,"ack":true,"from":"system.adapter.yahka.0"},n
                              host.ioBroker	2019-10-31 22:53:42.239	error	Caught by controller[42]: Thu, 31 Oct 2019 21:53:41 GMT socket.io-parser encoding packet {"type":2,"data":["setState","system.adapter.yahka.0.memRss",{"val":50.18,"ack":true,"from":"system.adapter.yah
                              host.ioBroker	2019-10-31 22:53:42.239	error	Caught by controller[42]: Thu, 31 Oct 2019 21:53:41 GMT socket.io-client:manager writing packet {"type":2,"data":["setState","system.adapter.yahka.0.memRss",{"val":50.18,"ack":true,"from":"system.adap
                              host.ioBroker	2019-10-31 22:53:42.239	error	Caught by controller[42]: Thu, 31 Oct 2019 21:53:41 GMT socket.io-parser encoded {"type":2,"data":["setState","system.adapter.yahka.0.connected",{"val":true,"ack":true,"expire":30,"from":"system.adapt
                              host.ioBroker	2019-10-31 22:53:42.239	error	Caught by controller[42]: Thu, 31 Oct 2019 21:53:41 GMT socket.io-parser encoding packet {"type":2,"data":["setState","system.adapter.yahka.0.connected",{"val":true,"ack":true,"expire":30,"from":"syst
                              host.ioBroker	2019-10-31 22:53:42.238	error	Caught by controller[42]: Thu, 31 Oct 2019 21:53:41 GMT socket.io-client:manager writing packet {"type":2,"data":["setState","system.adapter.yahka.0.connected",{"val":true,"ack":true,"expire":30,"from
                              host.ioBroker	2019-10-31 22:53:42.238	error	Caught by controller[42]: Thu, 31 Oct 2019 21:53:41 GMT socket.io-parser encoded {"type":2,"data":["setState","system.adapter.yahka.0.alive",{"val":true,"ack":true,"expire":25,"from":"system.adapter.y
                              host.ioBroker	2019-10-31 22:53:42.238	error	Caught by controller[42]: Thu, 31 Oct 2019 21:53:41 GMT socket.io-parser encoding packet {"type":2,"data":["setState","system.adapter.yahka.0.alive",{"val":true,"ack":true,"expire":25,"from":"system.a
                              host.ioBroker	2019-10-31 22:53:42.238	error	Caught by controller[42]: Thu, 31 Oct 2019 21:53:41 GMT socket.io-client:manager writing packet {"type":2,"data":["setState","system.adapter.yahka.0.alive",{"val":true,"ack":true,"expire":25,"from":"s
                              host.ioBroker	2019-10-31 22:53:42.238	error	Caught by controller[42]: Thu, 31 Oct 2019 21:53:41 GMT socket.io-parser encoded {"type":2,"data":["subscribe","*.logging",null],"options":{"compress":true},"nsp":"/"} as 2["subscribe","*.logging",nul
                              host.ioBroker	2019-10-31 22:53:42.238	error	Caught by controller[42]: Thu, 31 Oct 2019 21:53:41 GMT socket.io-parser encoding packet {"type":2,"data":["subscribe","*.logging",null],"options":{"compress":true},"nsp":"/"}
                              host.ioBroker	2019-10-31 22:53:42.238	error	Caught by controller[41]: Thu, 31 Oct 2019 21:53:41 GMT socket.io-client:manager writing packet {"type":2,"data":["subscribe","*.logging",null],"options":{"compress":true},"nsp":"/"}
                              host.ioBroker	2019-10-31 22:53:42.238	error	Caught by controller[41]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:socket flushing 1 packets in socket
                              host.ioBroker	2019-10-31 22:53:42.238	error	Caught by controller[41]: Thu, 31 Oct 2019 21:53:41 GMT socket.io-parser encoded {"type":2,"data":["getKeys","*.logging"],"options":{"compress":true},"id":1,"nsp":"/"} as 21["getKeys","*.logging"]
                              host.ioBroker	2019-10-31 22:53:42.238	error	Caught by controller[41]: Thu, 31 Oct 2019 21:53:41 GMT socket.io-parser encoding packet {"type":2,"data":["getKeys","*.logging"],"options":{"compress":true},"id":1,"nsp":"/"}
                              host.ioBroker	2019-10-31 22:53:42.238	error	Caught by controller[41]: Thu, 31 Oct 2019 21:53:41 GMT socket.io-client:manager writing packet {"type":2,"data":["getKeys","*.logging"],"options":{"compress":true},"id":1,"nsp":"/"}
                              host.ioBroker	2019-10-31 22:53:42.238	error	Caught by controller[41]: Thu, 31 Oct 2019 21:53:41 GMT socket.io-client:socket emitting packet with ack id 1
                              host.ioBroker	2019-10-31 22:53:42.238	error	Caught by controller[40]: Thu, 31 Oct 2019 21:53:41 GMT socket.io-client:socket calling ack 0 with [null,{"_id":"system.adapter.yahka.0","type":"instance","common":{"name":"yahka","version":"0.7.1","n
                              host.ioBroker	2019-10-31 22:53:42.237	error	Caught by controller[40]: Thu, 31 Oct 2019 21:53:41 GMT socket.io-parser decoded 30[null,{"_id":"system.adapter.yahka.0","type":"instance","common":{"name":"yahka","version":"0.7.1","news":{"0.7.1":{"
                              host.ioBroker	2019-10-31 22:53:42.237	error	Caught by controller[40]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:socket socket receive: type "message", data "30[null,{"_id":"system.adapter.yahka.0","type":"instance","common":{"name":"yahka"
                              host.ioBroker	2019-10-31 22:53:42.237	error	Caught by controller[39]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:polling ignoring poll - transport state "paused"
                              host.ioBroker	2019-10-31 22:53:42.237	error	Caught by controller[38]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:socket clearing existing transport polling
                              host.ioBroker	2019-10-31 22:53:42.237	error	Caught by controller[38]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:socket setting transport websocket
                              host.ioBroker	2019-10-31 22:53:42.237	error	Caught by controller[38]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:socket changing transport and sending upgrade packet
                              host.ioBroker	2019-10-31 22:53:42.237	error	Caught by controller[38]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:polling paused
                              host.ioBroker	2019-10-31 22:53:42.237	error	Caught by controller[38]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:polling pre-pause polling complete
                              host.ioBroker	2019-10-31 22:53:42.237	error	Caught by controller[38]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:socket flushing 1 packets in socket
                              host.ioBroker	2019-10-31 22:53:42.237	error	Caught by controller[37]: Thu, 31 Oct 2019 21:53:41 GMT socket.io-parser encoded {"type":2,"data":["getObject","system.adapter.yahka.0",null],"options":{"compress":true},"id":0,"nsp":"/"} as 20["getOb
                              host.ioBroker	2019-10-31 22:53:42.236	error	Caught by controller[37]: Thu, 31 Oct 2019 21:53:41 GMT socket.io-parser encoding packet {"type":2,"data":["getObject","system.adapter.yahka.0",null],"options":{"compress":true},"id":0,"nsp":"/"}
                              host.ioBroker	2019-10-31 22:53:42.236	error	Caught by controller[37]: Thu, 31 Oct 2019 21:53:41 GMT socket.io-client:manager writing packet {"type":2,"data":["getObject","system.adapter.yahka.0",null],"options":{"compress":true},"id":0,"nsp":"/
                              host.ioBroker	2019-10-31 22:53:42.236	error	Caught by controller[37]: Thu, 31 Oct 2019 21:53:41 GMT socket.io-client:socket emitting packet with ack id 0
                              host.ioBroker	2019-10-31 22:53:42.236	error	Caught by controller[37]: Thu, 31 Oct 2019 21:53:41 GMT socket.io-client:socket calling ack 0 with [null,{"val":false,"ack":true,"ts":1572558808623,"q":0,"from":"system.host.ioBroker","lc":15725588085
                              host.ioBroker	2019-10-31 22:53:42.236	error	Caught by controller[37]: Thu, 31 Oct 2019 21:53:41 GMT socket.io-parser decoded 30[null,{"val":false,"ack":true,"ts":1572558808623,"q":0,"from":"system.host.ioBroker","lc":1572558808526}] as {"type":
                              host.ioBroker	2019-10-31 22:53:42.236	error	Caught by controller[36]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:socket socket receive: type "message", data "30[null,{"val":false,"ack":true,"ts":1572558808623,"q":0,"from":"system.host.ioBro
                              host.ioBroker	2019-10-31 22:53:42.236	error	Caught by controller[36]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:polling polling got data 108:430[null,{"val":false,"ack":true,"ts":1572558808623,"q":0,"from":"system.host.ioBroker","lc":15725
                              host.ioBroker	2019-10-31 22:53:42.236	error	Caught by controller[36]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:polling pre-pause writing complete
                              host.ioBroker	2019-10-31 22:53:42.236	error	Caught by controller[35]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:polling we are currently writing - waiting to pause
                              host.ioBroker	2019-10-31 22:53:42.236	error	Caught by controller[34]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:polling we are currently polling - waiting to pause
                              host.ioBroker	2019-10-31 22:53:42.236	error	Caught by controller[34]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:socket pausing current transport "polling"
                              host.ioBroker	2019-10-31 22:53:42.236	error	Caught by controller[34]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:socket probe transport "websocket" pong
                              host.ioBroker	2019-10-31 22:53:42.236	error	Caught by controller[33]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:polling-xhr xhr data null
                              host.ioBroker	2019-10-31 22:53:42.236	error	Caught by controller[33]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:polling-xhr xhr open GET: http://127.0.0.1:9000/socket.io/?EIO=3&transport=polling&t=MuZprdt&b64=1&sid=Wsn4UOqXgtfLdCjYAAAp
                              host.ioBroker	2019-10-31 22:53:42.236	error	Caught by controller[33]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:polling-xhr xhr poll
                              host.ioBroker	2019-10-31 22:53:42.236	error	Caught by controller[33]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:polling polling
                              host.ioBroker	2019-10-31 22:53:42.235	error	Caught by controller[32]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:polling-xhr xhr data 46:420["getState","system.adapter.yahka.0.alive"]
                              host.ioBroker	2019-10-31 22:53:42.235	error	Caught by controller[32]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:polling-xhr xhr open POST: http://127.0.0.1:9000/socket.io/?EIO=3&transport=polling&t=MuZprdn&b64=1&sid=Wsn4UOqXgtfLdCjYAAAp
                              host.ioBroker	2019-10-31 22:53:42.235	error	Caught by controller[31]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:socket flushing 1 packets in socket
                              host.ioBroker	2019-10-31 22:53:42.235	error	Caught by controller[31]: Thu, 31 Oct 2019 21:53:41 GMT socket.io-parser encoded {"type":2,"data":["getState","system.adapter.yahka.0.alive"],"options":{"compress":true},"id":0,"nsp":"/"} as 20["getSt
                              host.ioBroker	2019-10-31 22:53:42.235	error	Caught by controller[31]: Thu, 31 Oct 2019 21:53:41 GMT socket.io-parser encoding packet {"type":2,"data":["getState","system.adapter.yahka.0.alive"],"options":{"compress":true},"id":0,"nsp":"/"}
                              host.ioBroker	2019-10-31 22:53:42.235	error	Caught by controller[31]: Thu, 31 Oct 2019 21:53:41 GMT socket.io-client:manager writing packet {"type":2,"data":["getState","system.adapter.yahka.0.alive"],"options":{"compress":true},"id":0,"nsp":"/
                              host.ioBroker	2019-10-31 22:53:42.235	error	Caught by controller[30]: Thu, 31 Oct 2019 21:53:41 GMT socket.io-client:socket emitting packet with ack id 0
                              host.ioBroker	2019-10-31 22:53:42.235	error	Caught by controller[29]: Thu, 31 Oct 2019 21:53:41 GMT socket.io-parser decoded 0 as {"type":0,"nsp":"/"}
                              host.ioBroker	2019-10-31 22:53:42.235	error	Caught by controller[29]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:socket socket receive: type "message", data "0"
                              host.ioBroker	2019-10-31 22:53:42.235	error	Caught by controller[29]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:polling polling got data 2:40
                              host.ioBroker	2019-10-31 22:53:42.235	error	Caught by controller[28]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:socket probe transport "websocket" opened
                              host.ioBroker	2019-10-31 22:53:42.235	error	Caught by controller[27]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:polling-xhr xhr data null
                              host.ioBroker	2019-10-31 22:53:42.235	error	Caught by controller[27]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:polling-xhr xhr open GET: http://127.0.0.1:9000/socket.io/?EIO=3&transport=polling&t=MuZprdN&b64=1&sid=Wsn4UOqXgtfLdCjYAAAp
                              host.ioBroker	2019-10-31 22:53:42.235	error	Caught by controller[27]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:polling-xhr xhr poll
                              host.ioBroker	2019-10-31 22:53:42.235	error	Caught by controller[27]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:polling polling
                              host.ioBroker	2019-10-31 22:53:42.235	error	Caught by controller[26]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:socket creating transport "websocket"
                              host.ioBroker	2019-10-31 22:53:42.234	error	Caught by controller[26]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:socket probing transport "websocket"
                              host.ioBroker	2019-10-31 22:53:42.234	error	Caught by controller[26]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:socket starting upgrade probes
                              host.ioBroker	2019-10-31 22:53:42.234	error	Caught by controller[26]: Thu, 31 Oct 2019 21:53:41 GMT socket.io-client:socket transport is open - connecting
                              host.ioBroker	2019-10-31 22:53:42.234	error	Caught by controller[26]: Thu, 31 Oct 2019 21:53:41 GMT socket.io-client:manager cleanup
                              host.ioBroker	2019-10-31 22:53:42.234	error	Caught by controller[26]: Thu, 31 Oct 2019 21:53:41 GMT socket.io-client:manager open
                              host.ioBroker	2019-10-31 22:53:42.234	error	Caught by controller[26]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:socket socket open
                              host.ioBroker	2019-10-31 22:53:42.234	error	Caught by controller[26]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:socket socket receive: type "open", data "{"sid":"Wsn4UOqXgtfLdCjYAAAp","upgrades":["websocket"],"pingInterval":25000,"pingTime
                              host.ioBroker	2019-10-31 22:53:42.234	error	Caught by controller[26]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:polling polling got data 97:0{"sid":"Wsn4UOqXgtfLdCjYAAAp","upgrades":["websocket"],"pingInterval":25000,"pingTimeout":60000}
                              host.ioBroker	2019-10-31 22:53:42.234	error	Caught by controller[25]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:polling ignoring poll - transport state "paused"
                              host.ioBroker	2019-10-31 22:53:42.234	error	Caught by controller[24]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:socket clearing existing transport polling
                              host.ioBroker	2019-10-31 22:53:42.234	error	Caught by controller[24]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:socket setting transport websocket
                              host.ioBroker	2019-10-31 22:53:42.234	error	Caught by controller[24]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:socket changing transport and sending upgrade packet
                              host.ioBroker	2019-10-31 22:53:42.234	error	Caught by controller[24]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:polling paused
                              host.ioBroker	2019-10-31 22:53:42.234	error	Caught by controller[24]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:polling pre-pause polling complete
                              host.ioBroker	2019-10-31 22:53:42.234	error	Caught by controller[23]: Thu, 31 Oct 2019 21:53:41 GMT socket.io-client:manager readyState opening
                              host.ioBroker	2019-10-31 22:53:42.234	error	Caught by controller[23]: Thu, 31 Oct 2019 21:53:41 GMT socket.io-client:manager connect attempt will timeout after 20000
                              host.ioBroker	2019-10-31 22:53:42.233	error	Caught by controller[23]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:socket setting transport polling
                              host.ioBroker	2019-10-31 22:53:42.233	error	Caught by controller[23]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:polling-xhr xhr data null
                              host.ioBroker	2019-10-31 22:53:42.233	error	Caught by controller[23]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:polling-xhr xhr open GET: http://127.0.0.1:9000/socket.io/?EIO=3&transport=polling&t=MuZprd3&b64=1
                              host.ioBroker	2019-10-31 22:53:42.233	error	Caught by controller[22]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:polling-xhr xhr poll
                              host.ioBroker	2019-10-31 22:53:42.233	error	Caught by controller[22]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:polling polling
                              host.ioBroker	2019-10-31 22:53:42.233	error	Caught by controller[22]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:socket creating transport "polling"
                              host.ioBroker	2019-10-31 22:53:42.233	error	Caught by controller[22]: Thu, 31 Oct 2019 21:53:41 GMT socket.io-client:manager opening http://127.0.0.1:9000
                              host.ioBroker	2019-10-31 22:53:42.233	error	Caught by controller[22]: Thu, 31 Oct 2019 21:53:41 GMT socket.io-client:manager readyState closed
                              host.ioBroker	2019-10-31 22:53:42.233	error	Caught by controller[22]: Thu, 31 Oct 2019 21:53:41 GMT socket.io-client new io instance for http://127.0.0.1:9000
                              host.ioBroker	2019-10-31 22:53:42.233	error	Caught by controller[21]: Thu, 31 Oct 2019 21:53:41 GMT socket.io-client:url parse http://127.0.0.1:9000
                              host.ioBroker	2019-10-31 22:53:42.233	error	Caught by controller[20]: Thu, 31 Oct 2019 21:53:41 GMT socket.io-parser decoded 0 as {"type":0,"nsp":"/"}
                              host.ioBroker	2019-10-31 22:53:42.233	error	Caught by controller[19]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:socket socket receive: type "message", data "0"
                              host.ioBroker	2019-10-31 22:53:42.233	error	Caught by controller[19]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:polling polling got data 2:40
                              host.ioBroker	2019-10-31 22:53:42.233	error	Caught by controller[18]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:polling we are currently polling - waiting to pause
                              host.ioBroker	2019-10-31 22:53:42.233	error	Caught by controller[18]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:socket pausing current transport "polling"
                              host.ioBroker	2019-10-31 22:53:42.233	error	Caught by controller[18]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:socket probe transport "websocket" pong
                              host.ioBroker	2019-10-31 22:53:42.232	error	Caught by controller[17]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:socket probe transport "websocket" opened
                              host.ioBroker	2019-10-31 22:53:42.232	error	Caught by controller[16]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:polling-xhr xhr data null
                              host.ioBroker	2019-10-31 22:53:42.232	error	Caught by controller[16]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:polling-xhr xhr open GET: http://127.0.0.1:9001/socket.io/?EIO=3&transport=polling&t=MuZprbp&b64=1&sid=OVYScHKOQzqVlOVhAAAo
                              host.ioBroker	2019-10-31 22:53:42.232	error	Caught by controller[15]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:polling-xhr xhr poll
                              host.ioBroker	2019-10-31 22:53:42.232	error	Caught by controller[15]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:polling polling
                              host.ioBroker	2019-10-31 22:53:42.232	error	Caught by controller[14]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:socket creating transport "websocket"
                              host.ioBroker	2019-10-31 22:53:42.232	error	Caught by controller[14]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:socket probing transport "websocket"
                              host.ioBroker	2019-10-31 22:53:42.232	error	Caught by controller[13]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:socket starting upgrade probes
                              host.ioBroker	2019-10-31 22:53:42.232	error	Caught by controller[13]: Thu, 31 Oct 2019 21:53:41 GMT socket.io-client:socket transport is open - connecting
                              host.ioBroker	2019-10-31 22:53:42.232	error	Caught by controller[12]: Thu, 31 Oct 2019 21:53:41 GMT socket.io-client:manager cleanup
                              host.ioBroker	2019-10-31 22:53:42.232	error	Caught by controller[12]: Thu, 31 Oct 2019 21:53:41 GMT socket.io-client:manager open
                              host.ioBroker	2019-10-31 22:53:42.232	error	Caught by controller[12]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:socket socket open
                              host.ioBroker	2019-10-31 22:53:42.232	error	Caught by controller[12]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:socket socket receive: type "open", data "{"sid":"OVYScHKOQzqVlOVhAAAo","upgrades":["websocket"],"pingInterval":25000,"pingTime
                              host.ioBroker	2019-10-31 22:53:42.232	error	Caught by controller[11]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:polling polling got data 97:0{"sid":"OVYScHKOQzqVlOVhAAAo","upgrades":["websocket"],"pingInterval":25000,"pingTimeout":60000}
                              host.ioBroker	2019-10-31 22:53:42.232	error	Caught by controller[10]: Thu, 31 Oct 2019 21:53:41 GMT socket.io-client:manager readyState opening
                              host.ioBroker	2019-10-31 22:53:42.232	error	Caught by controller[9]: Thu, 31 Oct 2019 21:53:41 GMT socket.io-client:manager connect attempt will timeout after 20000
                              host.ioBroker	2019-10-31 22:53:42.231	error	Caught by controller[9]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:socket setting transport polling
                              host.ioBroker	2019-10-31 22:53:42.231	error	Caught by controller[8]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:polling-xhr xhr data null
                              host.ioBroker	2019-10-31 22:53:42.231	error	Caught by controller[7]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:polling-xhr xhr open GET: http://127.0.0.1:9001/socket.io/?EIO=3&transport=polling&t=MuZprZm&b64=1
                              host.ioBroker	2019-10-31 22:53:42.231	error	Caught by controller[6]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:polling-xhr xhr poll
                              host.ioBroker	2019-10-31 22:53:42.231	error	Caught by controller[6]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:polling polling
                              host.ioBroker	2019-10-31 22:53:42.231	error	Caught by controller[5]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:socket creating transport "polling"
                              host.ioBroker	2019-10-31 22:53:42.231	error	Caught by controller[4]: Thu, 31 Oct 2019 21:53:41 GMT socket.io-client:manager opening http://127.0.0.1:9001
                              host.ioBroker	2019-10-31 22:53:42.231	error	Caught by controller[4]: Thu, 31 Oct 2019 21:53:41 GMT socket.io-client:manager readyState closed
                              host.ioBroker	2019-10-31 22:53:42.231	error	Caught by controller[3]: Thu, 31 Oct 2019 21:53:41 GMT socket.io-client new io instance for http://127.0.0.1:9001
                              host.ioBroker	2019-10-31 22:53:42.231	error	Caught by controller[2]: Thu, 31 Oct 2019 21:53:41 GMT socket.io-client:url parse http://127.0.0.1:9001
                              host.ioBroker	2019-10-31 22:53:42.231	error	Caught by controller[1]: *** WARNING *** For more information see <http://0pointer.de/avahi-compat?s=libdns_sd&e=node&f=DNSServiceRegister>
                              host.ioBroker	2019-10-31 22:53:42.231	error	Caught by controller[1]: *** WARNING *** Please fix your application to use the native API of Avahi!
                              host.ioBroker	2019-10-31 22:53:42.231	error	Caught by controller[1]: *** WARNING *** The program 'node' called 'DNSServiceRegister()' which is not supported (or only supported partially) in the Apple Bonjour compatibility layer of Avahi.
                              host.ioBroker	2019-10-31 22:53:42.231	error	Caught by controller[1]: *** WARNING *** For more information see <http://0pointer.de/avahi-compat?s=libdns_sd&e=node>
                              host.ioBroker	2019-10-31 22:53:42.230	error	Caught by controller[0]: *** WARNING *** The program 'node' uses the Apple Bonjour compatibility layer of Avahi.
                              host.ioBroker	2019-10-31 22:53:40.605	info	instance system.adapter.yahka.0 started with pid 1868
                              host.ioBroker	2019-10-31 22:53:40.591	info	object change system.adapter.yahka.0
                              admin.0	2019-10-31 22:53:35.626	info	successful connection to socket.io from ::ffff:192.168.10.119
                              host.ioBroker	2019-10-31 22:53:28.653	info	Restart adapter system.adapter.yahka.0 because enabled
                              host.ioBroker	2019-10-31 22:53:28.653	error	instance system.adapter.yahka.0 terminated with code 0 (OK)
                              Caught	2019-10-31 22:53:28.653	error	by controller[123]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-parser encoded {"type":2,"data":["setState","system.adapter.yahka.0.alive",{"val":false,"ack":true,"from":"system.adapter.yahka.0"}],"optio
                              Caught	2019-10-31 22:53:28.652	error	by controller[123]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-parser encoding packet {"type":2,"data":["setState","system.adapter.yahka.0.alive",{"val":false,"ack":true,"from":"system.adapter.yahka.0"}
                              Caught	2019-10-31 22:53:28.652	error	by controller[123]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-client:manager writing packet {"type":2,"data":["setState","system.adapter.yahka.0.alive",{"val":false,"ack":true,"from":"system.adapter.ya
                              Caught	2019-10-31 22:53:28.652	error	by controller[123]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-client:socket emitting packet with ack id 4
                              Caught	2019-10-31 22:53:28.652	error	by controller[123]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-client:socket calling ack 2 with [null,"system.adapter.yahka.0.alive"]
                              Caught	2019-10-31 22:53:28.652	error	by controller[123]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-parser decoded 32[null,"system.adapter.yahka.0.alive"] as {"type":3,"nsp":"/","id":2,"data":[null,"system.adapter.yahka.0.alive"]}
                              Caught	2019-10-31 22:53:28.652	error	by controller[123]: Thu, 31 Oct 2019 21:53:28 GMT engine.io-client:socket socket receive: type "message", data "32[null,"system.adapter.yahka.0.alive"]"
                              Caught	2019-10-31 22:53:28.652	error	by controller[123]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-parser encoded {"type":2,"data":["getStates",["system.adapter.admin.0.logging"]],"options":{"compress":true},"id":3,"nsp":"/"} as 23["getSt
                              Caught	2019-10-31 22:53:28.652	error	by controller[123]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-parser encoding packet {"type":2,"data":["getStates",["system.adapter.admin.0.logging"]],"options":{"compress":true},"id":3,"nsp":"/"}
                              Caught	2019-10-31 22:53:28.652	error	by controller[123]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-client:manager writing packet {"type":2,"data":["getStates",["system.adapter.admin.0.logging"]],"options":{"compress":true},"id":3,"nsp":"/
                              Caught	2019-10-31 22:53:28.652	error	by controller[123]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-client:socket emitting packet with ack id 3
                              Caught	2019-10-31 22:53:28.652	error	by controller[123]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-client:socket calling ack 1 with [null,["system.adapter.admin.0.logging"]]
                              Caught	2019-10-31 22:53:28.652	error	by controller[123]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-parser decoded 31[null,["system.adapter.admin.0.logging"]] as {"type":3,"nsp":"/","id":1,"data":[null,["system.adapter.admin.0.logging"]]}
                              Caught	2019-10-31 22:53:28.652	error	by controller[123]: Thu, 31 Oct 2019 21:53:28 GMT engine.io-client:socket socket receive: type "message", data "31[null,["system.adapter.admin.0.logging"]]"
                              Caught	2019-10-31 22:53:28.651	error	by controller[122]: Thu, 31 Oct 2019 21:53:28 GMT engine.io-client:socket flushing 17 packets in socket
                              Caught	2019-10-31 22:53:28.651	error	by controller[121]: Thu, 31 Oct 2019 21:53:28 GMT engine.io-client:socket flushing 11 packets in socket
                              Caught	2019-10-31 22:53:28.651	error	by controller[120]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-parser encoded {"type":2,"data":["setState","system.adapter.yahka.0.alive",{"val":false,"ack":true,"from":"system.adapter.yahka.0"}],"optio
                              Caught	2019-10-31 22:53:28.651	error	by controller[120]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-parser encoding packet {"type":2,"data":["setState","system.adapter.yahka.0.alive",{"val":false,"ack":true,"from":"system.adapter.yahka.0"}
                              Caught	2019-10-31 22:53:28.651	error	by controller[120]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-client:manager writing packet {"type":2,"data":["setState","system.adapter.yahka.0.alive",{"val":false,"ack":true,"from":"system.adapter.ya
                              Caught	2019-10-31 22:53:28.651	error	by controller[119]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-client:socket emitting packet with ack id 2
                              Caught	2019-10-31 22:53:28.651	error	by controller[118]: at emitListeningNT (net.js:1314:10) errorCode: -65537 }
                              Caught	2019-10-31 22:53:28.651	error	by controller[118]: at Server.emit (events.js:198:13)
                              Caught	2019-10-31 22:53:28.651	error	by controller[118]: at EventedHTTPServer.<anonymous> (/opt/iobroker/node_modules/hap-nodejs/lib/util/eventedhttp.js:65:10)
                              Caught	2019-10-31 22:53:28.651	error	by controller[118]: at EventedHTTPServer.emit (events.js:198:13)
                              Caught	2019-10-31 22:53:28.651	error	by controller[118]: at HAPServer._onListening (/opt/iobroker/node_modules/hap-nodejs/lib/HAPServer.js:190:8)
                              Caught	2019-10-31 22:53:28.651	error	by controller[118]: at HAPServer.emit (events.js:198:13)
                              Caught	2019-10-31 22:53:28.651	error	by controller[118]: at Bridge.Accessory._onListening (/opt/iobroker/node_modules/hap-nodejs/lib/Accessory.js:661:20)
                              Caught	2019-10-31 22:53:28.650	error	by controller[118]: at Advertiser.startAdvertising (/opt/iobroker/node_modules/hap-nodejs/lib/Advertiser.js:47:30)
                              Caught	2019-10-31 22:53:28.650	error	by controller[118]: at Object.create [as createAdvertisement] (/opt/iobroker/node_modules/mdns/lib/advertisement.js:64:10)
                              Caught	2019-10-31 22:53:28.650	error	by controller[118]: at new Advertisement (/opt/iobroker/node_modules/mdns/lib/advertisement.js:56:10)
                              Caught	2019-10-31 22:53:28.650	error	by controller[118]: { Error: dns service error: unknown
                              Caught	2019-10-31 22:53:28.650	error	by controller[117]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-parser encoded {"type":2,"data":["subscribe","yahka.0.checkLogging",null],"options":{"compress":true},"nsp":"/"} as 2["subscribe","yahka.0.
                              Caught	2019-10-31 22:53:28.650	error	by controller[117]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-parser encoding packet {"type":2,"data":["subscribe","yahka.0.checkLogging",null],"options":{"compress":true},"nsp":"/"}
                              Caught	2019-10-31 22:53:28.646	error	by controller[116]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-client:manager writing packet {"type":2,"data":["subscribe","yahka.0.checkLogging",null],"options":{"compress":true},"nsp":"/"}
                              Caught	2019-10-31 22:53:28.646	error	by controller[115]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-parser encoded {"type":2,"data":["subscribe","system.adapter.*",null,null],"options":{"compress":true},"nsp":"/"} as 2["subscribe","system.
                              Caught	2019-10-31 22:53:28.646	error	by controller[115]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-parser encoding packet {"type":2,"data":["subscribe","system.adapter.*",null,null],"options":{"compress":true},"nsp":"/"}
                              Caught	2019-10-31 22:53:28.646	error	by controller[114]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-client:manager writing packet {"type":2,"data":["subscribe","system.adapter.*",null,null],"options":{"compress":true},"nsp":"/"}
                              Caught	2019-10-31 22:53:28.646	error	by controller[113]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-parser encoded {"type":2,"data":["getObjectView","system","instance",{"startkey":"system.adapter.","endkey":"system.adapter.香"},{"name":"ya
                              Caught	2019-10-31 22:53:28.646	error	by controller[113]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-parser encoding packet {"type":2,"data":["getObjectView","system","instance",{"startkey":"system.adapter.","endkey":"system.adapter.香"},{"n
                              Caught	2019-10-31 22:53:28.646	error	by controller[112]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-client:manager writing packet {"type":2,"data":["getObjectView","system","instance",{"startkey":"system.adapter.","endkey":"system.adapter.
                              Caught	2019-10-31 22:53:28.646	error	by controller[111]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-client:socket emitting packet with ack id 9
                              Caught	2019-10-31 22:53:28.646	error	by controller[110]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-parser encoded {"type":2,"data":["subscribe","system.adapter.*",null,null],"options":{"compress":true},"nsp":"/"} as 2["subscribe","system.
                              Caught	2019-10-31 22:53:28.645	error	by controller[109]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-parser encoding packet {"type":2,"data":["subscribe","system.adapter.*",null,null],"options":{"compress":true},"nsp":"/"}
                              Caught	2019-10-31 22:53:28.645	error	by controller[109]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-client:manager writing packet {"type":2,"data":["subscribe","system.adapter.*",null,null],"options":{"compress":true},"nsp":"/"}
                              Caught	2019-10-31 22:53:28.645	error	by controller[108]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-parser encoded {"type":2,"data":["getObjectView","system","instance",{"startkey":"system.adapter.","endkey":"system.adapter.香"},{"name":"ya
                              Caught	2019-10-31 22:53:28.645	error	by controller[108]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-parser encoding packet {"type":2,"data":["getObjectView","system","instance",{"startkey":"system.adapter.","endkey":"system.adapter.香"},{"n
                              Caught	2019-10-31 22:53:28.645	error	by controller[108]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-client:manager writing packet {"type":2,"data":["getObjectView","system","instance",{"startkey":"system.adapter.","endkey":"system.adapter.
                              Caught	2019-10-31 22:53:28.645	error	by controller[107]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-client:socket emitting packet with ack id 8
                              Caught	2019-10-31 22:53:28.645	error	by controller[106]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-parser encoded {"type":2,"data":["subscribe","system.adapter.*",null,null],"options":{"compress":true},"nsp":"/"} as 2["subscribe","system.
                              Caught	2019-10-31 22:53:28.645	error	by controller[105]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-parser encoding packet {"type":2,"data":["subscribe","system.adapter.*",null,null],"options":{"compress":true},"nsp":"/"}
                              Caught	2019-10-31 22:53:28.645	error	by controller[105]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-client:manager writing packet {"type":2,"data":["subscribe","system.adapter.*",null,null],"options":{"compress":true},"nsp":"/"}
                              Caught	2019-10-31 22:53:28.645	error	by controller[104]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-parser encoded {"type":2,"data":["getObjectView","system","instance",{"startkey":"system.adapter.","endkey":"system.adapter.香"},{"name":"ya
                              Caught	2019-10-31 22:53:28.645	error	by controller[104]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-parser encoding packet {"type":2,"data":["getObjectView","system","instance",{"startkey":"system.adapter.","endkey":"system.adapter.香"},{"n
                              Caught	2019-10-31 22:53:28.644	error	by controller[104]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-client:manager writing packet {"type":2,"data":["getObjectView","system","instance",{"startkey":"system.adapter.","endkey":"system.adapter.
                              Caught	2019-10-31 22:53:28.644	error	by controller[103]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-client:socket emitting packet with ack id 7
                              Caught	2019-10-31 22:53:28.644	error	by controller[102]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-parser encoded {"type":2,"data":["subscribe","system.adapter.*",null,null],"options":{"compress":true},"nsp":"/"} as 2["subscribe","system.
                              Caught	2019-10-31 22:53:28.644	error	by controller[102]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-parser encoding packet {"type":2,"data":["subscribe","system.adapter.*",null,null],"options":{"compress":true},"nsp":"/"}
                              Caught	2019-10-31 22:53:28.644	error	by controller[102]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-client:manager writing packet {"type":2,"data":["subscribe","system.adapter.*",null,null],"options":{"compress":true},"nsp":"/"}
                              Caught	2019-10-31 22:53:28.644	error	by controller[102]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-parser encoded {"type":2,"data":["getObjectView","system","instance",{"startkey":"system.adapter.","endkey":"system.adapter.香"},{"name":"ya
                              Caught	2019-10-31 22:53:28.644	error	by controller[102]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-parser encoding packet {"type":2,"data":["getObjectView","system","instance",{"startkey":"system.adapter.","endkey":"system.adapter.香"},{"n
                              Caught	2019-10-31 22:53:28.644	error	by controller[102]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-client:manager writing packet {"type":2,"data":["getObjectView","system","instance",{"startkey":"system.adapter.","endkey":"system.adapter.
                              Caught	2019-10-31 22:53:28.644	error	by controller[102]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-client:socket emitting packet with ack id 6
                              Caught	2019-10-31 22:53:28.643	error	by controller[102]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-client:manager writing packet {"type":2,"data":["subscribe","system.adapter.*",null,null],"options":{"compress":true},"nsp":"/"}
                              Caught	2019-10-31 22:53:28.643	error	by controller[102]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-parser encoded {"type":2,"data":["getObjectView","system","instance",{"startkey":"system.adapter.","endkey":"system.adapter.香"},{"name":"ya
                              Caught	2019-10-31 22:53:28.643	error	by controller[102]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-parser encoding packet {"type":2,"data":["getObjectView","system","instance",{"startkey":"system.adapter.","endkey":"system.adapter.香"},{"n
                              Caught	2019-10-31 22:53:28.643	error	by controller[102]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-client:manager writing packet {"type":2,"data":["getObjectView","system","instance",{"startkey":"system.adapter.","endkey":"system.adapter.
                              Caught	2019-10-31 22:53:28.643	error	by controller[102]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-client:socket emitting packet with ack id 5
                              Caught	2019-10-31 22:53:28.643	error	by controller[102]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-parser encoded {"type":2,"data":["subscribe","system.adapter.*",null,null],"options":{"compress":true},"nsp":"/"} as 2["subscribe","system.
                              Caught	2019-10-31 22:53:28.643	error	by controller[102]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-parser encoding packet {"type":2,"data":["subscribe","system.adapter.*",null,null],"options":{"compress":true},"nsp":"/"}
                              Caught	2019-10-31 22:53:28.642	error	by controller[102]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-client:socket emitting packet with ack id 4
                              Caught	2019-10-31 22:53:28.642	error	by controller[102]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-parser encoded {"type":2,"data":["subscribe","system.adapter.*",null,null],"options":{"compress":true},"nsp":"/"} as 2["subscribe","system.
                              Caught	2019-10-31 22:53:28.642	error	by controller[102]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-parser encoding packet {"type":2,"data":["subscribe","system.adapter.*",null,null],"options":{"compress":true},"nsp":"/"}
                              Caught	2019-10-31 22:53:28.642	error	by controller[102]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-client:manager writing packet {"type":2,"data":["subscribe","system.adapter.*",null,null],"options":{"compress":true},"nsp":"/"}
                              Caught	2019-10-31 22:53:28.642	error	by controller[102]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-parser encoded {"type":2,"data":["getObjectView","system","instance",{"startkey":"system.adapter.","endkey":"system.adapter.香"},{"name":"ya
                              Caught	2019-10-31 22:53:28.642	error	by controller[102]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-parser encoding packet {"type":2,"data":["getObjectView","system","instance",{"startkey":"system.adapter.","endkey":"system.adapter.香"},{"n
                              Caught	2019-10-31 22:53:28.641	error	by controller[102]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-client:manager writing packet {"type":2,"data":["getObjectView","system","instance",{"startkey":"system.adapter.","endkey":"system.adapter.
                              Caught	2019-10-31 22:53:28.641	error	by controller[102]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-client:socket emitting packet with ack id 3
                              Caught	2019-10-31 22:53:28.641	error	by controller[102]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-parser encoded {"type":2,"data":["subscribe","system.adapter.*",null,null],"options":{"compress":true},"nsp":"/"} as 2["subscribe","system.
                              Caught	2019-10-31 22:53:28.641	error	by controller[102]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-parser encoding packet {"type":2,"data":["subscribe","system.adapter.*",null,null],"options":{"compress":true},"nsp":"/"}
                              Caught	2019-10-31 22:53:28.641	error	by controller[102]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-client:manager writing packet {"type":2,"data":["subscribe","system.adapter.*",null,null],"options":{"compress":true},"nsp":"/"}
                              Caught	2019-10-31 22:53:28.641	error	by controller[102]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-parser encoded {"type":2,"data":["getObjectView","system","instance",{"startkey":"system.adapter.","endkey":"system.adapter.香"},{"name":"ya
                              Caught	2019-10-31 22:53:28.641	error	by controller[102]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-parser encoding packet {"type":2,"data":["getObjectView","system","instance",{"startkey":"system.adapter.","endkey":"system.adapter.香"},{"n
                              Caught	2019-10-31 22:53:28.641	error	by controller[102]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-client:socket emitting packet with ack id 2
                              Caught	2019-10-31 22:53:28.640	error	by controller[101]: Thu, 31 Oct 2019 21:53:28 GMT engine.io-client:socket flushing 1 packets in socket
                              Caught	2019-10-31 22:53:28.640	error	by controller[100]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-parser encoded {"type":2,"data":["getObjectView","system","instance",{"startkey":"system.adapter.","endkey":"system.adapter.香"},{"name":"ya
                              Caught	2019-10-31 22:53:28.640	error	by controller[99]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-parser encoding packet {"type":2,"data":["getObjectView","system","instance",{"startkey":"system.adapter.","endkey":"system.adapter.香"},{"na
                              Caught	2019-10-31 22:53:28.640	error	by controller[99]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-client:manager writing packet {"type":2,"data":["getObjectView","system","instance",{"startkey":"system.adapter.","endkey":"system.adapter.香
                              Caught	2019-10-31 22:53:28.640	error	by controller[98]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-client:socket emitting packet with ack id 1
                              Caught	2019-10-31 22:53:28.640	error	by controller[97]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-parser encoded {"type":2,"data":["setState","system.adapter.yahka.0.outputCount",{"val":8,"ack":true,"from":"system.adapter.yahka.0"},null],
                              Caught	2019-10-31 22:53:28.640	error	by controller[97]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-parser encoding packet {"type":2,"data":["setState","system.adapter.yahka.0.outputCount",{"val":8,"ack":true,"from":"system.adapter.yahka.0"
                              Caught	2019-10-31 22:53:28.640	error	by controller[97]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-client:manager writing packet {"type":2,"data":["setState","system.adapter.yahka.0.outputCount",{"val":8,"ack":true,"from":"system.adapter.y
                              Caught	2019-10-31 22:53:28.640	error	by controller[97]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-parser encoded {"type":2,"data":["setState","system.adapter.yahka.0.inputCount",{"val":0,"ack":true,"from":"system.adapter.yahka.0"},null],"
                              Caught	2019-10-31 22:53:28.640	error	by controller[97]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-parser encoding packet {"type":2,"data":["setState","system.adapter.yahka.0.inputCount",{"val":0,"ack":true,"from":"system.adapter.yahka.0"}
                              Caught	2019-10-31 22:53:28.640	error	by controller[97]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-client:manager writing packet {"type":2,"data":["setState","system.adapter.yahka.0.inputCount",{"val":0,"ack":true,"from":"system.adapter.ya
                              Caught	2019-10-31 22:53:28.639	error	by controller[97]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-parser encoded {"type":2,"data":["setState","system.adapter.yahka.0.uptime",{"val":1,"ack":true,"from":"system.adapter.yahka.0"},null],"opti
                              Caught	2019-10-31 22:53:28.639	error	by controller[97]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-parser encoding packet {"type":2,"data":["setState","system.adapter.yahka.0.uptime",{"val":1,"ack":true,"from":"system.adapter.yahka.0"},nul
                              Caught	2019-10-31 22:53:28.639	error	by controller[97]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-client:manager writing packet {"type":2,"data":["setState","system.adapter.yahka.0.uptime",{"val":1,"ack":true,"from":"system.adapter.yahka.
                              Caught	2019-10-31 22:53:28.639	error	by controller[97]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-parser encoded {"type":2,"data":["setState","system.adapter.yahka.0.memHeapUsed",{"val":12.66,"ack":true,"from":"system.adapter.yahka.0"},nu
                              Caught	2019-10-31 22:53:28.639	error	by controller[97]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-parser encoding packet {"type":2,"data":["setState","system.adapter.yahka.0.memHeapUsed",{"val":12.66,"ack":true,"from":"system.adapte
                              GlasfaserG Offline
                              GlasfaserG Offline
                              @doctorultra
                              hast du danach nochmal ein npm rebuild durchgeführt ?
                              • D doctorultra
                                neid leider nicht
                                host.ioBroker	2019-10-31 22:53:42.245	error	instance system.adapter.yahka.0 terminated with code 0 (OK)
                                host.ioBroker	2019-10-31 22:53:42.245	error	Caught by controller[61]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-parser encoded {"type":2,"data":["setState","system.adapter.yahka.0.alive",{"val":false,"ack":true,"from":"system.adapter.yahka.0"}],"
                                host.ioBroker	2019-10-31 22:53:42.245	error	Caught by controller[61]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-parser encoding packet {"type":2,"data":["setState","system.adapter.yahka.0.alive",{"val":false,"ack":true,"from":"system.adapter.yahk
                                host.ioBroker	2019-10-31 22:53:42.245	error	Caught by controller[61]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-client:manager writing packet {"type":2,"data":["setState","system.adapter.yahka.0.alive",{"val":false,"ack":true,"from":"system.adapt
                                host.ioBroker	2019-10-31 22:53:42.245	error	Caught by controller[61]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-client:socket emitting packet with ack id 4
                                host.ioBroker	2019-10-31 22:53:42.245	error	Caught by controller[61]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-client:socket calling ack 2 with [null,"system.adapter.yahka.0.alive"]
                                host.ioBroker	2019-10-31 22:53:42.245	error	Caught by controller[61]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-parser decoded 32[null,"system.adapter.yahka.0.alive"] as {"type":3,"nsp":"/","id":2,"data":[null,"system.adapter.yahka.0.alive"]}
                                host.ioBroker	2019-10-31 22:53:42.245	error	Caught by controller[61]: Thu, 31 Oct 2019 21:53:42 GMT engine.io-client:socket socket receive: type "message", data "32[null,"system.adapter.yahka.0.alive"]"
                                host.ioBroker	2019-10-31 22:53:42.245	error	Caught by controller[61]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-parser encoded {"type":2,"data":["getStates",["system.adapter.admin.0.logging"]],"options":{"compress":true},"id":3,"nsp":"/"} as 23["
                                host.ioBroker	2019-10-31 22:53:42.245	error	Caught by controller[61]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-parser encoding packet {"type":2,"data":["getStates",["system.adapter.admin.0.logging"]],"options":{"compress":true},"id":3,"nsp":"/"}
                                host.ioBroker	2019-10-31 22:53:42.245	error	Caught by controller[61]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-client:manager writing packet {"type":2,"data":["getStates",["system.adapter.admin.0.logging"]],"options":{"compress":true},"id":3,"ns
                                host.ioBroker	2019-10-31 22:53:42.245	error	Caught by controller[61]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-client:socket emitting packet with ack id 3
                                host.ioBroker	2019-10-31 22:53:42.245	error	Caught by controller[61]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-client:socket calling ack 1 with [null,["system.adapter.admin.0.logging"]]
                                host.ioBroker	2019-10-31 22:53:42.245	error	Caught by controller[61]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-parser decoded 31[null,["system.adapter.admin.0.logging"]] as {"type":3,"nsp":"/","id":1,"data":[null,["system.adapter.admin.0.logging
                                host.ioBroker	2019-10-31 22:53:42.245	error	Caught by controller[61]: Thu, 31 Oct 2019 21:53:42 GMT engine.io-client:socket socket receive: type "message", data "31[null,["system.adapter.admin.0.logging"]]"
                                host.ioBroker	2019-10-31 22:53:42.244	error	Caught by controller[60]: Thu, 31 Oct 2019 21:53:42 GMT engine.io-client:socket flushing 17 packets in socket
                                host.ioBroker	2019-10-31 22:53:42.244	error	Caught by controller[59]: Thu, 31 Oct 2019 21:53:42 GMT engine.io-client:socket flushing 11 packets in socket
                                host.ioBroker	2019-10-31 22:53:42.244	error	Caught by controller[58]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-parser encoded {"type":2,"data":["setState","system.adapter.yahka.0.alive",{"val":false,"ack":true,"from":"system.adapter.yahka.0"}],"
                                host.ioBroker	2019-10-31 22:53:42.244	error	Caught by controller[58]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-parser encoding packet {"type":2,"data":["setState","system.adapter.yahka.0.alive",{"val":false,"ack":true,"from":"system.adapter.yahk
                                host.ioBroker	2019-10-31 22:53:42.244	error	Caught by controller[58]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-client:manager writing packet {"type":2,"data":["setState","system.adapter.yahka.0.alive",{"val":false,"ack":true,"from":"system.adapt
                                host.ioBroker	2019-10-31 22:53:42.244	error	Caught by controller[58]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-client:socket emitting packet with ack id 2
                                host.ioBroker	2019-10-31 22:53:42.244	error	Caught by controller[57]: at emitListeningNT (net.js:1314:10) errorCode: -65537 }
                                host.ioBroker	2019-10-31 22:53:42.244	error	Caught by controller[57]: at Server.emit (events.js:198:13)
                                host.ioBroker	2019-10-31 22:53:42.244	error	Caught by controller[57]: at EventedHTTPServer.<anonymous> (/opt/iobroker/node_modules/hap-nodejs/lib/util/eventedhttp.js:65:10)
                                host.ioBroker	2019-10-31 22:53:42.244	error	Caught by controller[57]: at EventedHTTPServer.emit (events.js:198:13)
                                host.ioBroker	2019-10-31 22:53:42.244	error	Caught by controller[57]: at HAPServer._onListening (/opt/iobroker/node_modules/hap-nodejs/lib/HAPServer.js:190:8)
                                host.ioBroker	2019-10-31 22:53:42.244	error	Caught by controller[57]: at HAPServer.emit (events.js:198:13)
                                host.ioBroker	2019-10-31 22:53:42.244	error	Caught by controller[57]: at Bridge.Accessory._onListening (/opt/iobroker/node_modules/hap-nodejs/lib/Accessory.js:661:20)
                                host.ioBroker	2019-10-31 22:53:42.244	error	Caught by controller[57]: at Advertiser.startAdvertising (/opt/iobroker/node_modules/hap-nodejs/lib/Advertiser.js:47:30)
                                host.ioBroker	2019-10-31 22:53:42.244	error	Caught by controller[57]: at Object.create [as createAdvertisement] (/opt/iobroker/node_modules/mdns/lib/advertisement.js:64:10)
                                host.ioBroker	2019-10-31 22:53:42.244	error	Caught by controller[57]: at new Advertisement (/opt/iobroker/node_modules/mdns/lib/advertisement.js:56:10)
                                host.ioBroker	2019-10-31 22:53:42.244	error	Caught by controller[57]: { Error: dns service error: unknown
                                host.ioBroker	2019-10-31 22:53:42.244	error	Caught by controller[56]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-parser encoded {"type":2,"data":["subscribe","yahka.0.checkLogging",null],"options":{"compress":true},"nsp":"/"} as 2["subscribe","yah
                                host.ioBroker	2019-10-31 22:53:42.243	error	Caught by controller[56]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-parser encoding packet {"type":2,"data":["subscribe","yahka.0.checkLogging",null],"options":{"compress":true},"nsp":"/"}
                                host.ioBroker	2019-10-31 22:53:42.243	error	Caught by controller[55]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-client:manager writing packet {"type":2,"data":["subscribe","yahka.0.checkLogging",null],"options":{"compress":true},"nsp":"/"}
                                host.ioBroker	2019-10-31 22:53:42.243	error	Caught by controller[54]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-parser encoded {"type":2,"data":["subscribe","system.adapter.*",null,null],"options":{"compress":true},"nsp":"/"} as 2["subscribe","sy
                                host.ioBroker	2019-10-31 22:53:42.243	error	Caught by controller[54]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-parser encoding packet {"type":2,"data":["subscribe","system.adapter.*",null,null],"options":{"compress":true},"nsp":"/"}
                                host.ioBroker	2019-10-31 22:53:42.243	error	Caught by controller[54]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-client:manager writing packet {"type":2,"data":["subscribe","system.adapter.*",null,null],"options":{"compress":true},"nsp":"/"}
                                host.ioBroker	2019-10-31 22:53:42.243	error	Caught by controller[54]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-parser encoded {"type":2,"data":["getObjectView","system","instance",{"startkey":"system.adapter.","endkey":"system.adapter.香"},{"name
                                host.ioBroker	2019-10-31 22:53:42.243	error	Caught by controller[54]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-parser encoding packet {"type":2,"data":["getObjectView","system","instance",{"startkey":"system.adapter.","endkey":"system.adapter.香"
                                host.ioBroker	2019-10-31 22:53:42.243	error	Caught by controller[54]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-client:manager writing packet {"type":2,"data":["getObjectView","system","instance",{"startkey":"system.adapter.","endkey":"system.ada
                                host.ioBroker	2019-10-31 22:53:42.243	error	Caught by controller[54]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-client:socket emitting packet with ack id 9
                                host.ioBroker	2019-10-31 22:53:42.243	error	Caught by controller[54]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-client:socket emitting packet with ack id 8
                                host.ioBroker	2019-10-31 22:53:42.243	error	Caught by controller[53]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-parser encoded {"type":2,"data":["subscribe","system.adapter.*",null,null],"options":{"compress":true},"nsp":"/"} as 2["subscribe","sy
                                host.ioBroker	2019-10-31 22:53:42.243	error	Caught by controller[52]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-parser encoding packet {"type":2,"data":["subscribe","system.adapter.*",null,null],"options":{"compress":true},"nsp":"/"}
                                host.ioBroker	2019-10-31 22:53:42.242	error	Caught by controller[52]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-client:manager writing packet {"type":2,"data":["subscribe","system.adapter.*",null,null],"options":{"compress":true},"nsp":"/"}
                                host.ioBroker	2019-10-31 22:53:42.242	error	Caught by controller[52]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-parser encoded {"type":2,"data":["getObjectView","system","instance",{"startkey":"system.adapter.","endkey":"system.adapter.香"},{"name
                                host.ioBroker	2019-10-31 22:53:42.242	error	Caught by controller[52]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-parser encoding packet {"type":2,"data":["getObjectView","system","instance",{"startkey":"system.adapter.","endkey":"system.adapter.香"
                                host.ioBroker	2019-10-31 22:53:42.242	error	Caught by controller[52]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-client:manager writing packet {"type":2,"data":["getObjectView","system","instance",{"startkey":"system.adapter.","endkey":"system.ada
                                host.ioBroker	2019-10-31 22:53:42.242	error	Caught by controller[51]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-client:socket emitting packet with ack id 7
                                host.ioBroker	2019-10-31 22:53:42.242	error	Caught by controller[50]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-parser encoded {"type":2,"data":["subscribe","system.adapter.*",null,null],"options":{"compress":true},"nsp":"/"} as 2["subscribe","sy
                                host.ioBroker	2019-10-31 22:53:42.242	error	Caught by controller[50]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-parser encoding packet {"type":2,"data":["subscribe","system.adapter.*",null,null],"options":{"compress":true},"nsp":"/"}
                                host.ioBroker	2019-10-31 22:53:42.242	error	Caught by controller[50]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-client:manager writing packet {"type":2,"data":["subscribe","system.adapter.*",null,null],"options":{"compress":true},"nsp":"/"}
                                host.ioBroker	2019-10-31 22:53:42.242	error	Caught by controller[50]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-parser encoded {"type":2,"data":["getObjectView","system","instance",{"startkey":"system.adapter.","endkey":"system.adapter.香"},{"name
                                host.ioBroker	2019-10-31 22:53:42.242	error	Caught by controller[50]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-parser encoding packet {"type":2,"data":["getObjectView","system","instance",{"startkey":"system.adapter.","endkey":"system.adapter.香"
                                host.ioBroker	2019-10-31 22:53:42.242	error	Caught by controller[50]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-client:manager writing packet {"type":2,"data":["getObjectView","system","instance",{"startkey":"system.adapter.","endkey":"system.ada
                                host.ioBroker	2019-10-31 22:53:42.242	error	Caught by controller[50]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-client:socket emitting packet with ack id 6
                                host.ioBroker	2019-10-31 22:53:42.242	error	Caught by controller[49]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-parser encoded {"type":2,"data":["subscribe","system.adapter.*",null,null],"options":{"compress":true},"nsp":"/"} as 2["subscribe","sy
                                host.ioBroker	2019-10-31 22:53:42.242	error	Caught by controller[49]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-parser encoding packet {"type":2,"data":["subscribe","system.adapter.*",null,null],"options":{"compress":true},"nsp":"/"}
                                host.ioBroker	2019-10-31 22:53:42.242	error	Caught by controller[49]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-client:manager writing packet {"type":2,"data":["subscribe","system.adapter.*",null,null],"options":{"compress":true},"nsp":"/"}
                                host.ioBroker	2019-10-31 22:53:42.242	error	Caught by controller[49]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-parser encoded {"type":2,"data":["getObjectView","system","instance",{"startkey":"system.adapter.","endkey":"system.adapter.香"},{"name
                                host.ioBroker	2019-10-31 22:53:42.242	error	Caught by controller[49]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-parser encoding packet {"type":2,"data":["getObjectView","system","instance",{"startkey":"system.adapter.","endkey":"system.adapter.香"
                                host.ioBroker	2019-10-31 22:53:42.241	error	Caught by controller[49]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-client:manager writing packet {"type":2,"data":["getObjectView","system","instance",{"startkey":"system.adapter.","endkey":"system.ada
                                host.ioBroker	2019-10-31 22:53:42.241	error	Caught by controller[49]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-client:socket emitting packet with ack id 5
                                host.ioBroker	2019-10-31 22:53:42.241	error	Caught by controller[48]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-parser encoded {"type":2,"data":["subscribe","system.adapter.*",null,null],"options":{"compress":true},"nsp":"/"} as 2["subscribe","sy
                                host.ioBroker	2019-10-31 22:53:42.241	error	Caught by controller[48]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-parser encoding packet {"type":2,"data":["subscribe","system.adapter.*",null,null],"options":{"compress":true},"nsp":"/"}
                                host.ioBroker	2019-10-31 22:53:42.241	error	Caught by controller[48]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-client:manager writing packet {"type":2,"data":["subscribe","system.adapter.*",null,null],"options":{"compress":true},"nsp":"/"}
                                host.ioBroker	2019-10-31 22:53:42.241	error	Caught by controller[48]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-parser encoded {"type":2,"data":["getObjectView","system","instance",{"startkey":"system.adapter.","endkey":"system.adapter.香"},{"name
                                host.ioBroker	2019-10-31 22:53:42.241	error	Caught by controller[47]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-parser encoding packet {"type":2,"data":["getObjectView","system","instance",{"startkey":"system.adapter.","endkey":"system.adapter.香"
                                host.ioBroker	2019-10-31 22:53:42.241	error	Caught by controller[47]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-client:manager writing packet {"type":2,"data":["getObjectView","system","instance",{"startkey":"system.adapter.","endkey":"system.ada
                                host.ioBroker	2019-10-31 22:53:42.241	error	Caught by controller[47]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-client:socket emitting packet with ack id 4
                                host.ioBroker	2019-10-31 22:53:42.241	error	Caught by controller[47]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-parser encoded {"type":2,"data":["subscribe","system.adapter.*",null,null],"options":{"compress":true},"nsp":"/"} as 2["subscribe","sy
                                host.ioBroker	2019-10-31 22:53:42.241	error	Caught by controller[47]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-parser encoding packet {"type":2,"data":["subscribe","system.adapter.*",null,null],"options":{"compress":true},"nsp":"/"}
                                host.ioBroker	2019-10-31 22:53:42.241	error	Caught by controller[47]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-client:manager writing packet {"type":2,"data":["subscribe","system.adapter.*",null,null],"options":{"compress":true},"nsp":"/"}
                                host.ioBroker	2019-10-31 22:53:42.241	error	Caught by controller[47]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-parser encoded {"type":2,"data":["getObjectView","system","instance",{"startkey":"system.adapter.","endkey":"system.adapter.香"},{"name
                                host.ioBroker	2019-10-31 22:53:42.241	error	Caught by controller[47]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-client:socket emitting packet with ack id 3
                                host.ioBroker	2019-10-31 22:53:42.240	error	Caught by controller[47]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-parser encoding packet {"type":2,"data":["subscribe","system.adapter.*",null,null],"options":{"compress":true},"nsp":"/"}
                                host.ioBroker	2019-10-31 22:53:42.240	error	Caught by controller[47]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-client:manager writing packet {"type":2,"data":["subscribe","system.adapter.*",null,null],"options":{"compress":true},"nsp":"/"}
                                host.ioBroker	2019-10-31 22:53:42.240	error	Caught by controller[47]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-parser encoded {"type":2,"data":["getObjectView","system","instance",{"startkey":"system.adapter.","endkey":"system.adapter.香"},{"name
                                host.ioBroker	2019-10-31 22:53:42.240	error	Caught by controller[47]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-parser encoding packet {"type":2,"data":["getObjectView","system","instance",{"startkey":"system.adapter.","endkey":"system.adapter.香"
                                host.ioBroker	2019-10-31 22:53:42.240	error	Caught by controller[47]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-client:manager writing packet {"type":2,"data":["getObjectView","system","instance",{"startkey":"system.adapter.","endkey":"system.ada
                                host.ioBroker	2019-10-31 22:53:42.240	error	Caught by controller[47]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-client:socket emitting packet with ack id 2
                                host.ioBroker	2019-10-31 22:53:42.240	error	Caught by controller[47]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-parser encoded {"type":2,"data":["subscribe","system.adapter.*",null,null],"options":{"compress":true},"nsp":"/"} as 2["subscribe","sy
                                host.ioBroker	2019-10-31 22:53:42.240	error	Caught by controller[46]: Thu, 31 Oct 2019 21:53:42 GMT engine.io-client:socket flushing 1 packets in socket
                                host.ioBroker	2019-10-31 22:53:42.240	error	Caught by controller[45]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-parser encoded {"type":2,"data":["getObjectView","system","instance",{"startkey":"system.adapter.","endkey":"system.adapter.香"},{"name
                                host.ioBroker	2019-10-31 22:53:42.240	error	Caught by controller[44]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-parser encoding packet {"type":2,"data":["getObjectView","system","instance",{"startkey":"system.adapter.","endkey":"system.adapter.香"
                                host.ioBroker	2019-10-31 22:53:42.240	error	Caught by controller[44]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-client:manager writing packet {"type":2,"data":["getObjectView","system","instance",{"startkey":"system.adapter.","endkey":"system.ada
                                host.ioBroker	2019-10-31 22:53:42.240	error	Caught by controller[43]: Thu, 31 Oct 2019 21:53:42 GMT socket.io-client:socket emitting packet with ack id 1
                                host.ioBroker	2019-10-31 22:53:42.240	error	Caught by controller[42]: Thu, 31 Oct 2019 21:53:41 GMT socket.io-parser encoded {"type":2,"data":["setState","system.adapter.yahka.0.outputCount",{"val":8,"ack":true,"from":"system.adapter.yahka.0"},
                                host.ioBroker	2019-10-31 22:53:42.240	error	Caught by controller[42]: Thu, 31 Oct 2019 21:53:41 GMT socket.io-parser encoding packet {"type":2,"data":["setState","system.adapter.yahka.0.outputCount",{"val":8,"ack":true,"from":"system.adapter.ya
                                host.ioBroker	2019-10-31 22:53:42.240	error	Caught by controller[42]: Thu, 31 Oct 2019 21:53:41 GMT socket.io-client:manager writing packet {"type":2,"data":["setState","system.adapter.yahka.0.outputCount",{"val":8,"ack":true,"from":"system.ada
                                host.ioBroker	2019-10-31 22:53:42.239	error	Caught by controller[42]: Thu, 31 Oct 2019 21:53:41 GMT socket.io-parser encoded {"type":2,"data":["setState","system.adapter.yahka.0.inputCount",{"val":0,"ack":true,"from":"system.adapter.yahka.0"},n
                                host.ioBroker	2019-10-31 22:53:42.239	error	Caught by controller[42]: Thu, 31 Oct 2019 21:53:41 GMT socket.io-parser encoding packet {"type":2,"data":["setState","system.adapter.yahka.0.inputCount",{"val":0,"ack":true,"from":"system.adapter.yah
                                host.ioBroker	2019-10-31 22:53:42.239	error	Caught by controller[42]: Thu, 31 Oct 2019 21:53:41 GMT socket.io-client:manager writing packet {"type":2,"data":["setState","system.adapter.yahka.0.inputCount",{"val":0,"ack":true,"from":"system.adap
                                host.ioBroker	2019-10-31 22:53:42.239	error	Caught by controller[42]: Thu, 31 Oct 2019 21:53:41 GMT socket.io-parser encoded {"type":2,"data":["setState","system.adapter.yahka.0.uptime",{"val":1,"ack":true,"from":"system.adapter.yahka.0"},null]
                                host.ioBroker	2019-10-31 22:53:42.239	error	Caught by controller[42]: Thu, 31 Oct 2019 21:53:41 GMT socket.io-parser encoding packet {"type":2,"data":["setState","system.adapter.yahka.0.uptime",{"val":1,"ack":true,"from":"system.adapter.yahka.0
                                host.ioBroker	2019-10-31 22:53:42.239	error	Caught by controller[42]: Thu, 31 Oct 2019 21:53:41 GMT socket.io-client:manager writing packet {"type":2,"data":["setState","system.adapter.yahka.0.uptime",{"val":1,"ack":true,"from":"system.adapter.
                                host.ioBroker	2019-10-31 22:53:42.239	error	Caught by controller[42]: Thu, 31 Oct 2019 21:53:41 GMT socket.io-parser encoded {"type":2,"data":["setState","system.adapter.yahka.0.memHeapUsed",{"val":12.71,"ack":true,"from":"system.adapter.yahka.
                                host.ioBroker	2019-10-31 22:53:42.239	error	Caught by controller[42]: Thu, 31 Oct 2019 21:53:41 GMT socket.io-parser encoding packet {"type":2,"data":["setState","system.adapter.yahka.0.memHeapUsed",{"val":12.71,"ack":true,"from":"system.adapte
                                host.ioBroker	2019-10-31 22:53:42.239	error	Caught by controller[42]: Thu, 31 Oct 2019 21:53:41 GMT socket.io-client:manager writing packet {"type":2,"data":["setState","system.adapter.yahka.0.memHeapUsed",{"val":12.71,"ack":true,"from":"system
                                host.ioBroker	2019-10-31 22:53:42.239	error	Caught by controller[42]: Thu, 31 Oct 2019 21:53:41 GMT socket.io-parser encoded {"type":2,"data":["setState","system.adapter.yahka.0.memHeapTotal",{"val":22.73,"ack":true,"from":"system.adapter.yahka
                                host.ioBroker	2019-10-31 22:53:42.239	error	Caught by controller[42]: Thu, 31 Oct 2019 21:53:41 GMT socket.io-parser encoding packet {"type":2,"data":["setState","system.adapter.yahka.0.memHeapTotal",{"val":22.73,"ack":true,"from":"system.adapt
                                host.ioBroker	2019-10-31 22:53:42.239	error	Caught by controller[42]: Thu, 31 Oct 2019 21:53:41 GMT socket.io-client:manager writing packet {"type":2,"data":["setState","system.adapter.yahka.0.memHeapTotal",{"val":22.73,"ack":true,"from":"syste
                                host.ioBroker	2019-10-31 22:53:42.239	error	Caught by controller[42]: Thu, 31 Oct 2019 21:53:41 GMT socket.io-parser encoded {"type":2,"data":["setState","system.adapter.yahka.0.memRss",{"val":50.18,"ack":true,"from":"system.adapter.yahka.0"},n
                                host.ioBroker	2019-10-31 22:53:42.239	error	Caught by controller[42]: Thu, 31 Oct 2019 21:53:41 GMT socket.io-parser encoding packet {"type":2,"data":["setState","system.adapter.yahka.0.memRss",{"val":50.18,"ack":true,"from":"system.adapter.yah
                                host.ioBroker	2019-10-31 22:53:42.239	error	Caught by controller[42]: Thu, 31 Oct 2019 21:53:41 GMT socket.io-client:manager writing packet {"type":2,"data":["setState","system.adapter.yahka.0.memRss",{"val":50.18,"ack":true,"from":"system.adap
                                host.ioBroker	2019-10-31 22:53:42.239	error	Caught by controller[42]: Thu, 31 Oct 2019 21:53:41 GMT socket.io-parser encoded {"type":2,"data":["setState","system.adapter.yahka.0.connected",{"val":true,"ack":true,"expire":30,"from":"system.adapt
                                host.ioBroker	2019-10-31 22:53:42.239	error	Caught by controller[42]: Thu, 31 Oct 2019 21:53:41 GMT socket.io-parser encoding packet {"type":2,"data":["setState","system.adapter.yahka.0.connected",{"val":true,"ack":true,"expire":30,"from":"syst
                                host.ioBroker	2019-10-31 22:53:42.238	error	Caught by controller[42]: Thu, 31 Oct 2019 21:53:41 GMT socket.io-client:manager writing packet {"type":2,"data":["setState","system.adapter.yahka.0.connected",{"val":true,"ack":true,"expire":30,"from
                                host.ioBroker	2019-10-31 22:53:42.238	error	Caught by controller[42]: Thu, 31 Oct 2019 21:53:41 GMT socket.io-parser encoded {"type":2,"data":["setState","system.adapter.yahka.0.alive",{"val":true,"ack":true,"expire":25,"from":"system.adapter.y
                                host.ioBroker	2019-10-31 22:53:42.238	error	Caught by controller[42]: Thu, 31 Oct 2019 21:53:41 GMT socket.io-parser encoding packet {"type":2,"data":["setState","system.adapter.yahka.0.alive",{"val":true,"ack":true,"expire":25,"from":"system.a
                                host.ioBroker	2019-10-31 22:53:42.238	error	Caught by controller[42]: Thu, 31 Oct 2019 21:53:41 GMT socket.io-client:manager writing packet {"type":2,"data":["setState","system.adapter.yahka.0.alive",{"val":true,"ack":true,"expire":25,"from":"s
                                host.ioBroker	2019-10-31 22:53:42.238	error	Caught by controller[42]: Thu, 31 Oct 2019 21:53:41 GMT socket.io-parser encoded {"type":2,"data":["subscribe","*.logging",null],"options":{"compress":true},"nsp":"/"} as 2["subscribe","*.logging",nul
                                host.ioBroker	2019-10-31 22:53:42.238	error	Caught by controller[42]: Thu, 31 Oct 2019 21:53:41 GMT socket.io-parser encoding packet {"type":2,"data":["subscribe","*.logging",null],"options":{"compress":true},"nsp":"/"}
                                host.ioBroker	2019-10-31 22:53:42.238	error	Caught by controller[41]: Thu, 31 Oct 2019 21:53:41 GMT socket.io-client:manager writing packet {"type":2,"data":["subscribe","*.logging",null],"options":{"compress":true},"nsp":"/"}
                                host.ioBroker	2019-10-31 22:53:42.238	error	Caught by controller[41]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:socket flushing 1 packets in socket
                                host.ioBroker	2019-10-31 22:53:42.238	error	Caught by controller[41]: Thu, 31 Oct 2019 21:53:41 GMT socket.io-parser encoded {"type":2,"data":["getKeys","*.logging"],"options":{"compress":true},"id":1,"nsp":"/"} as 21["getKeys","*.logging"]
                                host.ioBroker	2019-10-31 22:53:42.238	error	Caught by controller[41]: Thu, 31 Oct 2019 21:53:41 GMT socket.io-parser encoding packet {"type":2,"data":["getKeys","*.logging"],"options":{"compress":true},"id":1,"nsp":"/"}
                                host.ioBroker	2019-10-31 22:53:42.238	error	Caught by controller[41]: Thu, 31 Oct 2019 21:53:41 GMT socket.io-client:manager writing packet {"type":2,"data":["getKeys","*.logging"],"options":{"compress":true},"id":1,"nsp":"/"}
                                host.ioBroker	2019-10-31 22:53:42.238	error	Caught by controller[41]: Thu, 31 Oct 2019 21:53:41 GMT socket.io-client:socket emitting packet with ack id 1
                                host.ioBroker	2019-10-31 22:53:42.238	error	Caught by controller[40]: Thu, 31 Oct 2019 21:53:41 GMT socket.io-client:socket calling ack 0 with [null,{"_id":"system.adapter.yahka.0","type":"instance","common":{"name":"yahka","version":"0.7.1","n
                                host.ioBroker	2019-10-31 22:53:42.237	error	Caught by controller[40]: Thu, 31 Oct 2019 21:53:41 GMT socket.io-parser decoded 30[null,{"_id":"system.adapter.yahka.0","type":"instance","common":{"name":"yahka","version":"0.7.1","news":{"0.7.1":{"
                                host.ioBroker	2019-10-31 22:53:42.237	error	Caught by controller[40]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:socket socket receive: type "message", data "30[null,{"_id":"system.adapter.yahka.0","type":"instance","common":{"name":"yahka"
                                host.ioBroker	2019-10-31 22:53:42.237	error	Caught by controller[39]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:polling ignoring poll - transport state "paused"
                                host.ioBroker	2019-10-31 22:53:42.237	error	Caught by controller[38]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:socket clearing existing transport polling
                                host.ioBroker	2019-10-31 22:53:42.237	error	Caught by controller[38]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:socket setting transport websocket
                                host.ioBroker	2019-10-31 22:53:42.237	error	Caught by controller[38]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:socket changing transport and sending upgrade packet
                                host.ioBroker	2019-10-31 22:53:42.237	error	Caught by controller[38]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:polling paused
                                host.ioBroker	2019-10-31 22:53:42.237	error	Caught by controller[38]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:polling pre-pause polling complete
                                host.ioBroker	2019-10-31 22:53:42.237	error	Caught by controller[38]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:socket flushing 1 packets in socket
                                host.ioBroker	2019-10-31 22:53:42.237	error	Caught by controller[37]: Thu, 31 Oct 2019 21:53:41 GMT socket.io-parser encoded {"type":2,"data":["getObject","system.adapter.yahka.0",null],"options":{"compress":true},"id":0,"nsp":"/"} as 20["getOb
                                host.ioBroker	2019-10-31 22:53:42.236	error	Caught by controller[37]: Thu, 31 Oct 2019 21:53:41 GMT socket.io-parser encoding packet {"type":2,"data":["getObject","system.adapter.yahka.0",null],"options":{"compress":true},"id":0,"nsp":"/"}
                                host.ioBroker	2019-10-31 22:53:42.236	error	Caught by controller[37]: Thu, 31 Oct 2019 21:53:41 GMT socket.io-client:manager writing packet {"type":2,"data":["getObject","system.adapter.yahka.0",null],"options":{"compress":true},"id":0,"nsp":"/
                                host.ioBroker	2019-10-31 22:53:42.236	error	Caught by controller[37]: Thu, 31 Oct 2019 21:53:41 GMT socket.io-client:socket emitting packet with ack id 0
                                host.ioBroker	2019-10-31 22:53:42.236	error	Caught by controller[37]: Thu, 31 Oct 2019 21:53:41 GMT socket.io-client:socket calling ack 0 with [null,{"val":false,"ack":true,"ts":1572558808623,"q":0,"from":"system.host.ioBroker","lc":15725588085
                                host.ioBroker	2019-10-31 22:53:42.236	error	Caught by controller[37]: Thu, 31 Oct 2019 21:53:41 GMT socket.io-parser decoded 30[null,{"val":false,"ack":true,"ts":1572558808623,"q":0,"from":"system.host.ioBroker","lc":1572558808526}] as {"type":
                                host.ioBroker	2019-10-31 22:53:42.236	error	Caught by controller[36]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:socket socket receive: type "message", data "30[null,{"val":false,"ack":true,"ts":1572558808623,"q":0,"from":"system.host.ioBro
                                host.ioBroker	2019-10-31 22:53:42.236	error	Caught by controller[36]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:polling polling got data 108:430[null,{"val":false,"ack":true,"ts":1572558808623,"q":0,"from":"system.host.ioBroker","lc":15725
                                host.ioBroker	2019-10-31 22:53:42.236	error	Caught by controller[36]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:polling pre-pause writing complete
                                host.ioBroker	2019-10-31 22:53:42.236	error	Caught by controller[35]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:polling we are currently writing - waiting to pause
                                host.ioBroker	2019-10-31 22:53:42.236	error	Caught by controller[34]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:polling we are currently polling - waiting to pause
                                host.ioBroker	2019-10-31 22:53:42.236	error	Caught by controller[34]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:socket pausing current transport "polling"
                                host.ioBroker	2019-10-31 22:53:42.236	error	Caught by controller[34]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:socket probe transport "websocket" pong
                                host.ioBroker	2019-10-31 22:53:42.236	error	Caught by controller[33]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:polling-xhr xhr data null
                                host.ioBroker	2019-10-31 22:53:42.236	error	Caught by controller[33]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:polling-xhr xhr open GET: http://127.0.0.1:9000/socket.io/?EIO=3&transport=polling&t=MuZprdt&b64=1&sid=Wsn4UOqXgtfLdCjYAAAp
                                host.ioBroker	2019-10-31 22:53:42.236	error	Caught by controller[33]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:polling-xhr xhr poll
                                host.ioBroker	2019-10-31 22:53:42.236	error	Caught by controller[33]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:polling polling
                                host.ioBroker	2019-10-31 22:53:42.235	error	Caught by controller[32]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:polling-xhr xhr data 46:420["getState","system.adapter.yahka.0.alive"]
                                host.ioBroker	2019-10-31 22:53:42.235	error	Caught by controller[32]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:polling-xhr xhr open POST: http://127.0.0.1:9000/socket.io/?EIO=3&transport=polling&t=MuZprdn&b64=1&sid=Wsn4UOqXgtfLdCjYAAAp
                                host.ioBroker	2019-10-31 22:53:42.235	error	Caught by controller[31]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:socket flushing 1 packets in socket
                                host.ioBroker	2019-10-31 22:53:42.235	error	Caught by controller[31]: Thu, 31 Oct 2019 21:53:41 GMT socket.io-parser encoded {"type":2,"data":["getState","system.adapter.yahka.0.alive"],"options":{"compress":true},"id":0,"nsp":"/"} as 20["getSt
                                host.ioBroker	2019-10-31 22:53:42.235	error	Caught by controller[31]: Thu, 31 Oct 2019 21:53:41 GMT socket.io-parser encoding packet {"type":2,"data":["getState","system.adapter.yahka.0.alive"],"options":{"compress":true},"id":0,"nsp":"/"}
                                host.ioBroker	2019-10-31 22:53:42.235	error	Caught by controller[31]: Thu, 31 Oct 2019 21:53:41 GMT socket.io-client:manager writing packet {"type":2,"data":["getState","system.adapter.yahka.0.alive"],"options":{"compress":true},"id":0,"nsp":"/
                                host.ioBroker	2019-10-31 22:53:42.235	error	Caught by controller[30]: Thu, 31 Oct 2019 21:53:41 GMT socket.io-client:socket emitting packet with ack id 0
                                host.ioBroker	2019-10-31 22:53:42.235	error	Caught by controller[29]: Thu, 31 Oct 2019 21:53:41 GMT socket.io-parser decoded 0 as {"type":0,"nsp":"/"}
                                host.ioBroker	2019-10-31 22:53:42.235	error	Caught by controller[29]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:socket socket receive: type "message", data "0"
                                host.ioBroker	2019-10-31 22:53:42.235	error	Caught by controller[29]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:polling polling got data 2:40
                                host.ioBroker	2019-10-31 22:53:42.235	error	Caught by controller[28]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:socket probe transport "websocket" opened
                                host.ioBroker	2019-10-31 22:53:42.235	error	Caught by controller[27]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:polling-xhr xhr data null
                                host.ioBroker	2019-10-31 22:53:42.235	error	Caught by controller[27]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:polling-xhr xhr open GET: http://127.0.0.1:9000/socket.io/?EIO=3&transport=polling&t=MuZprdN&b64=1&sid=Wsn4UOqXgtfLdCjYAAAp
                                host.ioBroker	2019-10-31 22:53:42.235	error	Caught by controller[27]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:polling-xhr xhr poll
                                host.ioBroker	2019-10-31 22:53:42.235	error	Caught by controller[27]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:polling polling
                                host.ioBroker	2019-10-31 22:53:42.235	error	Caught by controller[26]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:socket creating transport "websocket"
                                host.ioBroker	2019-10-31 22:53:42.234	error	Caught by controller[26]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:socket probing transport "websocket"
                                host.ioBroker	2019-10-31 22:53:42.234	error	Caught by controller[26]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:socket starting upgrade probes
                                host.ioBroker	2019-10-31 22:53:42.234	error	Caught by controller[26]: Thu, 31 Oct 2019 21:53:41 GMT socket.io-client:socket transport is open - connecting
                                host.ioBroker	2019-10-31 22:53:42.234	error	Caught by controller[26]: Thu, 31 Oct 2019 21:53:41 GMT socket.io-client:manager cleanup
                                host.ioBroker	2019-10-31 22:53:42.234	error	Caught by controller[26]: Thu, 31 Oct 2019 21:53:41 GMT socket.io-client:manager open
                                host.ioBroker	2019-10-31 22:53:42.234	error	Caught by controller[26]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:socket socket open
                                host.ioBroker	2019-10-31 22:53:42.234	error	Caught by controller[26]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:socket socket receive: type "open", data "{"sid":"Wsn4UOqXgtfLdCjYAAAp","upgrades":["websocket"],"pingInterval":25000,"pingTime
                                host.ioBroker	2019-10-31 22:53:42.234	error	Caught by controller[26]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:polling polling got data 97:0{"sid":"Wsn4UOqXgtfLdCjYAAAp","upgrades":["websocket"],"pingInterval":25000,"pingTimeout":60000}
                                host.ioBroker	2019-10-31 22:53:42.234	error	Caught by controller[25]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:polling ignoring poll - transport state "paused"
                                host.ioBroker	2019-10-31 22:53:42.234	error	Caught by controller[24]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:socket clearing existing transport polling
                                host.ioBroker	2019-10-31 22:53:42.234	error	Caught by controller[24]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:socket setting transport websocket
                                host.ioBroker	2019-10-31 22:53:42.234	error	Caught by controller[24]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:socket changing transport and sending upgrade packet
                                host.ioBroker	2019-10-31 22:53:42.234	error	Caught by controller[24]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:polling paused
                                host.ioBroker	2019-10-31 22:53:42.234	error	Caught by controller[24]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:polling pre-pause polling complete
                                host.ioBroker	2019-10-31 22:53:42.234	error	Caught by controller[23]: Thu, 31 Oct 2019 21:53:41 GMT socket.io-client:manager readyState opening
                                host.ioBroker	2019-10-31 22:53:42.234	error	Caught by controller[23]: Thu, 31 Oct 2019 21:53:41 GMT socket.io-client:manager connect attempt will timeout after 20000
                                host.ioBroker	2019-10-31 22:53:42.233	error	Caught by controller[23]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:socket setting transport polling
                                host.ioBroker	2019-10-31 22:53:42.233	error	Caught by controller[23]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:polling-xhr xhr data null
                                host.ioBroker	2019-10-31 22:53:42.233	error	Caught by controller[23]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:polling-xhr xhr open GET: http://127.0.0.1:9000/socket.io/?EIO=3&transport=polling&t=MuZprd3&b64=1
                                host.ioBroker	2019-10-31 22:53:42.233	error	Caught by controller[22]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:polling-xhr xhr poll
                                host.ioBroker	2019-10-31 22:53:42.233	error	Caught by controller[22]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:polling polling
                                host.ioBroker	2019-10-31 22:53:42.233	error	Caught by controller[22]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:socket creating transport "polling"
                                host.ioBroker	2019-10-31 22:53:42.233	error	Caught by controller[22]: Thu, 31 Oct 2019 21:53:41 GMT socket.io-client:manager opening http://127.0.0.1:9000
                                host.ioBroker	2019-10-31 22:53:42.233	error	Caught by controller[22]: Thu, 31 Oct 2019 21:53:41 GMT socket.io-client:manager readyState closed
                                host.ioBroker	2019-10-31 22:53:42.233	error	Caught by controller[22]: Thu, 31 Oct 2019 21:53:41 GMT socket.io-client new io instance for http://127.0.0.1:9000
                                host.ioBroker	2019-10-31 22:53:42.233	error	Caught by controller[21]: Thu, 31 Oct 2019 21:53:41 GMT socket.io-client:url parse http://127.0.0.1:9000
                                host.ioBroker	2019-10-31 22:53:42.233	error	Caught by controller[20]: Thu, 31 Oct 2019 21:53:41 GMT socket.io-parser decoded 0 as {"type":0,"nsp":"/"}
                                host.ioBroker	2019-10-31 22:53:42.233	error	Caught by controller[19]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:socket socket receive: type "message", data "0"
                                host.ioBroker	2019-10-31 22:53:42.233	error	Caught by controller[19]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:polling polling got data 2:40
                                host.ioBroker	2019-10-31 22:53:42.233	error	Caught by controller[18]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:polling we are currently polling - waiting to pause
                                host.ioBroker	2019-10-31 22:53:42.233	error	Caught by controller[18]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:socket pausing current transport "polling"
                                host.ioBroker	2019-10-31 22:53:42.233	error	Caught by controller[18]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:socket probe transport "websocket" pong
                                host.ioBroker	2019-10-31 22:53:42.232	error	Caught by controller[17]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:socket probe transport "websocket" opened
                                host.ioBroker	2019-10-31 22:53:42.232	error	Caught by controller[16]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:polling-xhr xhr data null
                                host.ioBroker	2019-10-31 22:53:42.232	error	Caught by controller[16]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:polling-xhr xhr open GET: http://127.0.0.1:9001/socket.io/?EIO=3&transport=polling&t=MuZprbp&b64=1&sid=OVYScHKOQzqVlOVhAAAo
                                host.ioBroker	2019-10-31 22:53:42.232	error	Caught by controller[15]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:polling-xhr xhr poll
                                host.ioBroker	2019-10-31 22:53:42.232	error	Caught by controller[15]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:polling polling
                                host.ioBroker	2019-10-31 22:53:42.232	error	Caught by controller[14]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:socket creating transport "websocket"
                                host.ioBroker	2019-10-31 22:53:42.232	error	Caught by controller[14]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:socket probing transport "websocket"
                                host.ioBroker	2019-10-31 22:53:42.232	error	Caught by controller[13]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:socket starting upgrade probes
                                host.ioBroker	2019-10-31 22:53:42.232	error	Caught by controller[13]: Thu, 31 Oct 2019 21:53:41 GMT socket.io-client:socket transport is open - connecting
                                host.ioBroker	2019-10-31 22:53:42.232	error	Caught by controller[12]: Thu, 31 Oct 2019 21:53:41 GMT socket.io-client:manager cleanup
                                host.ioBroker	2019-10-31 22:53:42.232	error	Caught by controller[12]: Thu, 31 Oct 2019 21:53:41 GMT socket.io-client:manager open
                                host.ioBroker	2019-10-31 22:53:42.232	error	Caught by controller[12]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:socket socket open
                                host.ioBroker	2019-10-31 22:53:42.232	error	Caught by controller[12]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:socket socket receive: type "open", data "{"sid":"OVYScHKOQzqVlOVhAAAo","upgrades":["websocket"],"pingInterval":25000,"pingTime
                                host.ioBroker	2019-10-31 22:53:42.232	error	Caught by controller[11]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:polling polling got data 97:0{"sid":"OVYScHKOQzqVlOVhAAAo","upgrades":["websocket"],"pingInterval":25000,"pingTimeout":60000}
                                host.ioBroker	2019-10-31 22:53:42.232	error	Caught by controller[10]: Thu, 31 Oct 2019 21:53:41 GMT socket.io-client:manager readyState opening
                                host.ioBroker	2019-10-31 22:53:42.232	error	Caught by controller[9]: Thu, 31 Oct 2019 21:53:41 GMT socket.io-client:manager connect attempt will timeout after 20000
                                host.ioBroker	2019-10-31 22:53:42.231	error	Caught by controller[9]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:socket setting transport polling
                                host.ioBroker	2019-10-31 22:53:42.231	error	Caught by controller[8]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:polling-xhr xhr data null
                                host.ioBroker	2019-10-31 22:53:42.231	error	Caught by controller[7]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:polling-xhr xhr open GET: http://127.0.0.1:9001/socket.io/?EIO=3&transport=polling&t=MuZprZm&b64=1
                                host.ioBroker	2019-10-31 22:53:42.231	error	Caught by controller[6]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:polling-xhr xhr poll
                                host.ioBroker	2019-10-31 22:53:42.231	error	Caught by controller[6]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:polling polling
                                host.ioBroker	2019-10-31 22:53:42.231	error	Caught by controller[5]: Thu, 31 Oct 2019 21:53:41 GMT engine.io-client:socket creating transport "polling"
                                host.ioBroker	2019-10-31 22:53:42.231	error	Caught by controller[4]: Thu, 31 Oct 2019 21:53:41 GMT socket.io-client:manager opening http://127.0.0.1:9001
                                host.ioBroker	2019-10-31 22:53:42.231	error	Caught by controller[4]: Thu, 31 Oct 2019 21:53:41 GMT socket.io-client:manager readyState closed
                                host.ioBroker	2019-10-31 22:53:42.231	error	Caught by controller[3]: Thu, 31 Oct 2019 21:53:41 GMT socket.io-client new io instance for http://127.0.0.1:9001
                                host.ioBroker	2019-10-31 22:53:42.231	error	Caught by controller[2]: Thu, 31 Oct 2019 21:53:41 GMT socket.io-client:url parse http://127.0.0.1:9001
                                host.ioBroker	2019-10-31 22:53:42.231	error	Caught by controller[1]: *** WARNING *** For more information see <http://0pointer.de/avahi-compat?s=libdns_sd&e=node&f=DNSServiceRegister>
                                host.ioBroker	2019-10-31 22:53:42.231	error	Caught by controller[1]: *** WARNING *** Please fix your application to use the native API of Avahi!
                                host.ioBroker	2019-10-31 22:53:42.231	error	Caught by controller[1]: *** WARNING *** The program 'node' called 'DNSServiceRegister()' which is not supported (or only supported partially) in the Apple Bonjour compatibility layer of Avahi.
                                host.ioBroker	2019-10-31 22:53:42.231	error	Caught by controller[1]: *** WARNING *** For more information see <http://0pointer.de/avahi-compat?s=libdns_sd&e=node>
                                host.ioBroker	2019-10-31 22:53:42.230	error	Caught by controller[0]: *** WARNING *** The program 'node' uses the Apple Bonjour compatibility layer of Avahi.
                                host.ioBroker	2019-10-31 22:53:40.605	info	instance system.adapter.yahka.0 started with pid 1868
                                host.ioBroker	2019-10-31 22:53:40.591	info	object change system.adapter.yahka.0
                                admin.0	2019-10-31 22:53:35.626	info	successful connection to socket.io from ::ffff:192.168.10.119
                                host.ioBroker	2019-10-31 22:53:28.653	info	Restart adapter system.adapter.yahka.0 because enabled
                                host.ioBroker	2019-10-31 22:53:28.653	error	instance system.adapter.yahka.0 terminated with code 0 (OK)
                                Caught	2019-10-31 22:53:28.653	error	by controller[123]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-parser encoded {"type":2,"data":["setState","system.adapter.yahka.0.alive",{"val":false,"ack":true,"from":"system.adapter.yahka.0"}],"optio
                                Caught	2019-10-31 22:53:28.652	error	by controller[123]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-parser encoding packet {"type":2,"data":["setState","system.adapter.yahka.0.alive",{"val":false,"ack":true,"from":"system.adapter.yahka.0"}
                                Caught	2019-10-31 22:53:28.652	error	by controller[123]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-client:manager writing packet {"type":2,"data":["setState","system.adapter.yahka.0.alive",{"val":false,"ack":true,"from":"system.adapter.ya
                                Caught	2019-10-31 22:53:28.652	error	by controller[123]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-client:socket emitting packet with ack id 4
                                Caught	2019-10-31 22:53:28.652	error	by controller[123]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-client:socket calling ack 2 with [null,"system.adapter.yahka.0.alive"]
                                Caught	2019-10-31 22:53:28.652	error	by controller[123]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-parser decoded 32[null,"system.adapter.yahka.0.alive"] as {"type":3,"nsp":"/","id":2,"data":[null,"system.adapter.yahka.0.alive"]}
                                Caught	2019-10-31 22:53:28.652	error	by controller[123]: Thu, 31 Oct 2019 21:53:28 GMT engine.io-client:socket socket receive: type "message", data "32[null,"system.adapter.yahka.0.alive"]"
                                Caught	2019-10-31 22:53:28.652	error	by controller[123]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-parser encoded {"type":2,"data":["getStates",["system.adapter.admin.0.logging"]],"options":{"compress":true},"id":3,"nsp":"/"} as 23["getSt
                                Caught	2019-10-31 22:53:28.652	error	by controller[123]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-parser encoding packet {"type":2,"data":["getStates",["system.adapter.admin.0.logging"]],"options":{"compress":true},"id":3,"nsp":"/"}
                                Caught	2019-10-31 22:53:28.652	error	by controller[123]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-client:manager writing packet {"type":2,"data":["getStates",["system.adapter.admin.0.logging"]],"options":{"compress":true},"id":3,"nsp":"/
                                Caught	2019-10-31 22:53:28.652	error	by controller[123]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-client:socket emitting packet with ack id 3
                                Caught	2019-10-31 22:53:28.652	error	by controller[123]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-client:socket calling ack 1 with [null,["system.adapter.admin.0.logging"]]
                                Caught	2019-10-31 22:53:28.652	error	by controller[123]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-parser decoded 31[null,["system.adapter.admin.0.logging"]] as {"type":3,"nsp":"/","id":1,"data":[null,["system.adapter.admin.0.logging"]]}
                                Caught	2019-10-31 22:53:28.652	error	by controller[123]: Thu, 31 Oct 2019 21:53:28 GMT engine.io-client:socket socket receive: type "message", data "31[null,["system.adapter.admin.0.logging"]]"
                                Caught	2019-10-31 22:53:28.651	error	by controller[122]: Thu, 31 Oct 2019 21:53:28 GMT engine.io-client:socket flushing 17 packets in socket
                                Caught	2019-10-31 22:53:28.651	error	by controller[121]: Thu, 31 Oct 2019 21:53:28 GMT engine.io-client:socket flushing 11 packets in socket
                                Caught	2019-10-31 22:53:28.651	error	by controller[120]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-parser encoded {"type":2,"data":["setState","system.adapter.yahka.0.alive",{"val":false,"ack":true,"from":"system.adapter.yahka.0"}],"optio
                                Caught	2019-10-31 22:53:28.651	error	by controller[120]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-parser encoding packet {"type":2,"data":["setState","system.adapter.yahka.0.alive",{"val":false,"ack":true,"from":"system.adapter.yahka.0"}
                                Caught	2019-10-31 22:53:28.651	error	by controller[120]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-client:manager writing packet {"type":2,"data":["setState","system.adapter.yahka.0.alive",{"val":false,"ack":true,"from":"system.adapter.ya
                                Caught	2019-10-31 22:53:28.651	error	by controller[119]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-client:socket emitting packet with ack id 2
                                Caught	2019-10-31 22:53:28.651	error	by controller[118]: at emitListeningNT (net.js:1314:10) errorCode: -65537 }
                                Caught	2019-10-31 22:53:28.651	error	by controller[118]: at Server.emit (events.js:198:13)
                                Caught	2019-10-31 22:53:28.651	error	by controller[118]: at EventedHTTPServer.<anonymous> (/opt/iobroker/node_modules/hap-nodejs/lib/util/eventedhttp.js:65:10)
                                Caught	2019-10-31 22:53:28.651	error	by controller[118]: at EventedHTTPServer.emit (events.js:198:13)
                                Caught	2019-10-31 22:53:28.651	error	by controller[118]: at HAPServer._onListening (/opt/iobroker/node_modules/hap-nodejs/lib/HAPServer.js:190:8)
                                Caught	2019-10-31 22:53:28.651	error	by controller[118]: at HAPServer.emit (events.js:198:13)
                                Caught	2019-10-31 22:53:28.651	error	by controller[118]: at Bridge.Accessory._onListening (/opt/iobroker/node_modules/hap-nodejs/lib/Accessory.js:661:20)
                                Caught	2019-10-31 22:53:28.650	error	by controller[118]: at Advertiser.startAdvertising (/opt/iobroker/node_modules/hap-nodejs/lib/Advertiser.js:47:30)
                                Caught	2019-10-31 22:53:28.650	error	by controller[118]: at Object.create [as createAdvertisement] (/opt/iobroker/node_modules/mdns/lib/advertisement.js:64:10)
                                Caught	2019-10-31 22:53:28.650	error	by controller[118]: at new Advertisement (/opt/iobroker/node_modules/mdns/lib/advertisement.js:56:10)
                                Caught	2019-10-31 22:53:28.650	error	by controller[118]: { Error: dns service error: unknown
                                Caught	2019-10-31 22:53:28.650	error	by controller[117]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-parser encoded {"type":2,"data":["subscribe","yahka.0.checkLogging",null],"options":{"compress":true},"nsp":"/"} as 2["subscribe","yahka.0.
                                Caught	2019-10-31 22:53:28.650	error	by controller[117]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-parser encoding packet {"type":2,"data":["subscribe","yahka.0.checkLogging",null],"options":{"compress":true},"nsp":"/"}
                                Caught	2019-10-31 22:53:28.646	error	by controller[116]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-client:manager writing packet {"type":2,"data":["subscribe","yahka.0.checkLogging",null],"options":{"compress":true},"nsp":"/"}
                                Caught	2019-10-31 22:53:28.646	error	by controller[115]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-parser encoded {"type":2,"data":["subscribe","system.adapter.*",null,null],"options":{"compress":true},"nsp":"/"} as 2["subscribe","system.
                                Caught	2019-10-31 22:53:28.646	error	by controller[115]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-parser encoding packet {"type":2,"data":["subscribe","system.adapter.*",null,null],"options":{"compress":true},"nsp":"/"}
                                Caught	2019-10-31 22:53:28.646	error	by controller[114]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-client:manager writing packet {"type":2,"data":["subscribe","system.adapter.*",null,null],"options":{"compress":true},"nsp":"/"}
                                Caught	2019-10-31 22:53:28.646	error	by controller[113]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-parser encoded {"type":2,"data":["getObjectView","system","instance",{"startkey":"system.adapter.","endkey":"system.adapter.香"},{"name":"ya
                                Caught	2019-10-31 22:53:28.646	error	by controller[113]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-parser encoding packet {"type":2,"data":["getObjectView","system","instance",{"startkey":"system.adapter.","endkey":"system.adapter.香"},{"n
                                Caught	2019-10-31 22:53:28.646	error	by controller[112]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-client:manager writing packet {"type":2,"data":["getObjectView","system","instance",{"startkey":"system.adapter.","endkey":"system.adapter.
                                Caught	2019-10-31 22:53:28.646	error	by controller[111]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-client:socket emitting packet with ack id 9
                                Caught	2019-10-31 22:53:28.646	error	by controller[110]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-parser encoded {"type":2,"data":["subscribe","system.adapter.*",null,null],"options":{"compress":true},"nsp":"/"} as 2["subscribe","system.
                                Caught	2019-10-31 22:53:28.645	error	by controller[109]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-parser encoding packet {"type":2,"data":["subscribe","system.adapter.*",null,null],"options":{"compress":true},"nsp":"/"}
                                Caught	2019-10-31 22:53:28.645	error	by controller[109]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-client:manager writing packet {"type":2,"data":["subscribe","system.adapter.*",null,null],"options":{"compress":true},"nsp":"/"}
                                Caught	2019-10-31 22:53:28.645	error	by controller[108]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-parser encoded {"type":2,"data":["getObjectView","system","instance",{"startkey":"system.adapter.","endkey":"system.adapter.香"},{"name":"ya
                                Caught	2019-10-31 22:53:28.645	error	by controller[108]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-parser encoding packet {"type":2,"data":["getObjectView","system","instance",{"startkey":"system.adapter.","endkey":"system.adapter.香"},{"n
                                Caught	2019-10-31 22:53:28.645	error	by controller[108]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-client:manager writing packet {"type":2,"data":["getObjectView","system","instance",{"startkey":"system.adapter.","endkey":"system.adapter.
                                Caught	2019-10-31 22:53:28.645	error	by controller[107]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-client:socket emitting packet with ack id 8
                                Caught	2019-10-31 22:53:28.645	error	by controller[106]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-parser encoded {"type":2,"data":["subscribe","system.adapter.*",null,null],"options":{"compress":true},"nsp":"/"} as 2["subscribe","system.
                                Caught	2019-10-31 22:53:28.645	error	by controller[105]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-parser encoding packet {"type":2,"data":["subscribe","system.adapter.*",null,null],"options":{"compress":true},"nsp":"/"}
                                Caught	2019-10-31 22:53:28.645	error	by controller[105]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-client:manager writing packet {"type":2,"data":["subscribe","system.adapter.*",null,null],"options":{"compress":true},"nsp":"/"}
                                Caught	2019-10-31 22:53:28.645	error	by controller[104]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-parser encoded {"type":2,"data":["getObjectView","system","instance",{"startkey":"system.adapter.","endkey":"system.adapter.香"},{"name":"ya
                                Caught	2019-10-31 22:53:28.645	error	by controller[104]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-parser encoding packet {"type":2,"data":["getObjectView","system","instance",{"startkey":"system.adapter.","endkey":"system.adapter.香"},{"n
                                Caught	2019-10-31 22:53:28.644	error	by controller[104]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-client:manager writing packet {"type":2,"data":["getObjectView","system","instance",{"startkey":"system.adapter.","endkey":"system.adapter.
                                Caught	2019-10-31 22:53:28.644	error	by controller[103]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-client:socket emitting packet with ack id 7
                                Caught	2019-10-31 22:53:28.644	error	by controller[102]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-parser encoded {"type":2,"data":["subscribe","system.adapter.*",null,null],"options":{"compress":true},"nsp":"/"} as 2["subscribe","system.
                                Caught	2019-10-31 22:53:28.644	error	by controller[102]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-parser encoding packet {"type":2,"data":["subscribe","system.adapter.*",null,null],"options":{"compress":true},"nsp":"/"}
                                Caught	2019-10-31 22:53:28.644	error	by controller[102]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-client:manager writing packet {"type":2,"data":["subscribe","system.adapter.*",null,null],"options":{"compress":true},"nsp":"/"}
                                Caught	2019-10-31 22:53:28.644	error	by controller[102]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-parser encoded {"type":2,"data":["getObjectView","system","instance",{"startkey":"system.adapter.","endkey":"system.adapter.香"},{"name":"ya
                                Caught	2019-10-31 22:53:28.644	error	by controller[102]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-parser encoding packet {"type":2,"data":["getObjectView","system","instance",{"startkey":"system.adapter.","endkey":"system.adapter.香"},{"n
                                Caught	2019-10-31 22:53:28.644	error	by controller[102]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-client:manager writing packet {"type":2,"data":["getObjectView","system","instance",{"startkey":"system.adapter.","endkey":"system.adapter.
                                Caught	2019-10-31 22:53:28.644	error	by controller[102]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-client:socket emitting packet with ack id 6
                                Caught	2019-10-31 22:53:28.643	error	by controller[102]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-client:manager writing packet {"type":2,"data":["subscribe","system.adapter.*",null,null],"options":{"compress":true},"nsp":"/"}
                                Caught	2019-10-31 22:53:28.643	error	by controller[102]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-parser encoded {"type":2,"data":["getObjectView","system","instance",{"startkey":"system.adapter.","endkey":"system.adapter.香"},{"name":"ya
                                Caught	2019-10-31 22:53:28.643	error	by controller[102]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-parser encoding packet {"type":2,"data":["getObjectView","system","instance",{"startkey":"system.adapter.","endkey":"system.adapter.香"},{"n
                                Caught	2019-10-31 22:53:28.643	error	by controller[102]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-client:manager writing packet {"type":2,"data":["getObjectView","system","instance",{"startkey":"system.adapter.","endkey":"system.adapter.
                                Caught	2019-10-31 22:53:28.643	error	by controller[102]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-client:socket emitting packet with ack id 5
                                Caught	2019-10-31 22:53:28.643	error	by controller[102]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-parser encoded {"type":2,"data":["subscribe","system.adapter.*",null,null],"options":{"compress":true},"nsp":"/"} as 2["subscribe","system.
                                Caught	2019-10-31 22:53:28.643	error	by controller[102]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-parser encoding packet {"type":2,"data":["subscribe","system.adapter.*",null,null],"options":{"compress":true},"nsp":"/"}
                                Caught	2019-10-31 22:53:28.642	error	by controller[102]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-client:socket emitting packet with ack id 4
                                Caught	2019-10-31 22:53:28.642	error	by controller[102]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-parser encoded {"type":2,"data":["subscribe","system.adapter.*",null,null],"options":{"compress":true},"nsp":"/"} as 2["subscribe","system.
                                Caught	2019-10-31 22:53:28.642	error	by controller[102]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-parser encoding packet {"type":2,"data":["subscribe","system.adapter.*",null,null],"options":{"compress":true},"nsp":"/"}
                                Caught	2019-10-31 22:53:28.642	error	by controller[102]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-client:manager writing packet {"type":2,"data":["subscribe","system.adapter.*",null,null],"options":{"compress":true},"nsp":"/"}
                                Caught	2019-10-31 22:53:28.642	error	by controller[102]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-parser encoded {"type":2,"data":["getObjectView","system","instance",{"startkey":"system.adapter.","endkey":"system.adapter.香"},{"name":"ya
                                Caught	2019-10-31 22:53:28.642	error	by controller[102]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-parser encoding packet {"type":2,"data":["getObjectView","system","instance",{"startkey":"system.adapter.","endkey":"system.adapter.香"},{"n
                                Caught	2019-10-31 22:53:28.641	error	by controller[102]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-client:manager writing packet {"type":2,"data":["getObjectView","system","instance",{"startkey":"system.adapter.","endkey":"system.adapter.
                                Caught	2019-10-31 22:53:28.641	error	by controller[102]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-client:socket emitting packet with ack id 3
                                Caught	2019-10-31 22:53:28.641	error	by controller[102]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-parser encoded {"type":2,"data":["subscribe","system.adapter.*",null,null],"options":{"compress":true},"nsp":"/"} as 2["subscribe","system.
                                Caught	2019-10-31 22:53:28.641	error	by controller[102]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-parser encoding packet {"type":2,"data":["subscribe","system.adapter.*",null,null],"options":{"compress":true},"nsp":"/"}
                                Caught	2019-10-31 22:53:28.641	error	by controller[102]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-client:manager writing packet {"type":2,"data":["subscribe","system.adapter.*",null,null],"options":{"compress":true},"nsp":"/"}
                                Caught	2019-10-31 22:53:28.641	error	by controller[102]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-parser encoded {"type":2,"data":["getObjectView","system","instance",{"startkey":"system.adapter.","endkey":"system.adapter.香"},{"name":"ya
                                Caught	2019-10-31 22:53:28.641	error	by controller[102]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-parser encoding packet {"type":2,"data":["getObjectView","system","instance",{"startkey":"system.adapter.","endkey":"system.adapter.香"},{"n
                                Caught	2019-10-31 22:53:28.641	error	by controller[102]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-client:socket emitting packet with ack id 2
                                Caught	2019-10-31 22:53:28.640	error	by controller[101]: Thu, 31 Oct 2019 21:53:28 GMT engine.io-client:socket flushing 1 packets in socket
                                Caught	2019-10-31 22:53:28.640	error	by controller[100]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-parser encoded {"type":2,"data":["getObjectView","system","instance",{"startkey":"system.adapter.","endkey":"system.adapter.香"},{"name":"ya
                                Caught	2019-10-31 22:53:28.640	error	by controller[99]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-parser encoding packet {"type":2,"data":["getObjectView","system","instance",{"startkey":"system.adapter.","endkey":"system.adapter.香"},{"na
                                Caught	2019-10-31 22:53:28.640	error	by controller[99]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-client:manager writing packet {"type":2,"data":["getObjectView","system","instance",{"startkey":"system.adapter.","endkey":"system.adapter.香
                                Caught	2019-10-31 22:53:28.640	error	by controller[98]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-client:socket emitting packet with ack id 1
                                Caught	2019-10-31 22:53:28.640	error	by controller[97]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-parser encoded {"type":2,"data":["setState","system.adapter.yahka.0.outputCount",{"val":8,"ack":true,"from":"system.adapter.yahka.0"},null],
                                Caught	2019-10-31 22:53:28.640	error	by controller[97]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-parser encoding packet {"type":2,"data":["setState","system.adapter.yahka.0.outputCount",{"val":8,"ack":true,"from":"system.adapter.yahka.0"
                                Caught	2019-10-31 22:53:28.640	error	by controller[97]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-client:manager writing packet {"type":2,"data":["setState","system.adapter.yahka.0.outputCount",{"val":8,"ack":true,"from":"system.adapter.y
                                Caught	2019-10-31 22:53:28.640	error	by controller[97]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-parser encoded {"type":2,"data":["setState","system.adapter.yahka.0.inputCount",{"val":0,"ack":true,"from":"system.adapter.yahka.0"},null],"
                                Caught	2019-10-31 22:53:28.640	error	by controller[97]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-parser encoding packet {"type":2,"data":["setState","system.adapter.yahka.0.inputCount",{"val":0,"ack":true,"from":"system.adapter.yahka.0"}
                                Caught	2019-10-31 22:53:28.640	error	by controller[97]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-client:manager writing packet {"type":2,"data":["setState","system.adapter.yahka.0.inputCount",{"val":0,"ack":true,"from":"system.adapter.ya
                                Caught	2019-10-31 22:53:28.639	error	by controller[97]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-parser encoded {"type":2,"data":["setState","system.adapter.yahka.0.uptime",{"val":1,"ack":true,"from":"system.adapter.yahka.0"},null],"opti
                                Caught	2019-10-31 22:53:28.639	error	by controller[97]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-parser encoding packet {"type":2,"data":["setState","system.adapter.yahka.0.uptime",{"val":1,"ack":true,"from":"system.adapter.yahka.0"},nul
                                Caught	2019-10-31 22:53:28.639	error	by controller[97]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-client:manager writing packet {"type":2,"data":["setState","system.adapter.yahka.0.uptime",{"val":1,"ack":true,"from":"system.adapter.yahka.
                                Caught	2019-10-31 22:53:28.639	error	by controller[97]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-parser encoded {"type":2,"data":["setState","system.adapter.yahka.0.memHeapUsed",{"val":12.66,"ack":true,"from":"system.adapter.yahka.0"},nu
                                Caught	2019-10-31 22:53:28.639	error	by controller[97]: Thu, 31 Oct 2019 21:53:28 GMT socket.io-parser encoding packet {"type":2,"data":["setState","system.adapter.yahka.0.memHeapUsed",{"val":12.66,"ack":true,"from":"system.adapte
                                haselchenH Offline
                                haselchenH Offline
                                haselchen
                                @doctorultra
                                https://github.com/jensweigele/ioBroker.yahka/issues/52
                                Hier der gleiche Fehler .
                                Der Entwickler gibt an den ganzen Iobroker auf den neuesten Stand zu bringen.
                                Ist die Frage ob der Adapter, der Js Controller etc.gemeint ist.
                                • GlasfaserG Glasfaser
                                  @doctorultra
                                  hast du danach nochmal ein npm rebuild durchgeführt ?
                                  doctorultra
                                  @Glasfaser said in docker iobroker update:
                                  npm rebuild
                                  soll ich nochmal machen?
                                  • haselchenH haselchen
                                    @doctorultra
                                    doctorultra
                                    @haselchen
                                    habe alles auf den neusten Stand gebracht?
                                    • D doctorultra
                                      @haselchen
                                      haselchenH Offline
                                      haselchenH Offline
                                      haselchen
                                      @doctorultra
                                      Ich kenne mich mit yakha nicht aus.
                                      Eventuell deinstallieren und mal über die Katze/Git installieren oder URL, wenn Du ihn vorher aus der Adapter Liste installiert hast.
                                      Ansonsten kann ich dir nur raten dich hier oder über Google nach dem Fehler aus dem Log schlau zu machen.
                                        @doctorultra
                                        doctorultra
                                        habe es gerade nochmal probiert, bleibe nach dem Update bei den Fehler hängen
                                        Error: The module '/opt/iobroker/node_modules/mdns/build/Release/dns_sd_bindings.node'
                                        was compiled against a different Node.js version using
                                        NODE_MODULE_VERSION 48. This version of Node.js requires
                                        NODE_MODULE_VERSION 64. Please try re-compiling or re-installing
                                        the module (for instance, using `npm rebuild` or `npm install`).
                                            at Object.Module._extensions..node (internal/modules/cjs/loader.js:807:18)
                                            at Module.load (internal/modules/cjs/loader.js:653:32)
                                            at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
                                            at Function.Module._load (internal/modules/cjs/loader.js:585:3)
                                            at Module.require (internal/modules/cjs/loader.js:692:17)
                                            at require (internal/modules/cjs/helpers.js:25:18)
                                            at Object.<anonymous> (/opt/iobroker/node_modules/mdns/lib/dns_sd.js:24:20)
                                          doctorultra
                                          habe jetzt nochmal einen rebuild gemacht aber ich habe ein problem mit mdns
                                          „Release/obj.target/dns_sd_bin        dings/src/dns_sd.o“ scheiterte
                                          make: *** [Release/obj.target/dns_sd_bindings/src/dns_sd.o] Fehler 1
                                          make: Verzeichnis „/opt/iobroker/node_modules/mdns/build“ wird verlassen
                                          gyp ERR! build error
                                          gyp ERR! stack Error: `make` failed with exit code: 2
                                          gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_module        s/node-gyp/lib/build.js:193:23)
                                          gyp ERR! stack     at ChildProcess.emit (events.js:198:13)
                                          gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_proces        s.js:248:12)
                                          gyp ERR! System Linux 4.2.8
                                          gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gy        p/bin/node-gyp.js" "rebuild"
                                          gyp ERR! cwd /opt/iobroker/node_modules/mdns
                                          gyp ERR! node -v v10.17.0
                                          gyp ERR! node-gyp -v v5.0.3
                                          gyp ERR! not ok
                                          npm ERR! code ELIFECYCLE
                                          npm ERR! errno 1
                                          npm ERR! mdns@2.3.4 install: `node-gyp rebuild`
                                          npm ERR! Exit status 1
                                          npm ERR!
                                          npm ERR! Failed at the mdns@2.3.4 install script.
                                          npm ERR! This is probably not a problem with npm. There is likely additional log        ging output above.
                                          npm ERR!     /home/iobroker/.npm/_logs/2019-11-01T13_32_44_072Z-debug.log
                                          [1]+  Exit 1                  node
