Füllstandsmessung per Pegelsonde.
Ich benötige noch einmal ein wenig Hilfe. Ich bekomme den Arduion Sketch nicht auf den Nano.
Es kommt immer diese Meldung nach eine längeren Wartezeit.
Beim Hochladen des Sketches ist ein Fehler aufgetreten avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xed avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0xed avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0xed avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0xed avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0xed avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0xed avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0xed avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0xed avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0xed avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0xed -
Beim Hochladen des Sketches ist ein Fehler aufgetreten avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xed avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0xed avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0xed avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0xed avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0xed avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0xed avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0xed avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0xed avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0xed avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0xed@Beowolf Du musst im Arduino IDE die richtigen Einstellungen suchen. Schau mal hier nach: Link Text
Und bei mir war noch der alte Bootloader drauf. Die Meldung heisst auf jeden Fall, dass du keine Verbindung zum Nano hast. Der USB-Anschluss emuliert einen COM-Port. Den musst du auswählen.
Gruß Eisbaeeer -
Hallo, @Eisbaeeer,
ich habe ne Frage zu dem Strom-Spannungswandler. Du hast den so
auf Deiner Platine. Ich habe gelesen, dass bei Ausgangsspannungen zwischen 0 und 3,3 V die beiden Jumper, die ich rot eingekreist habe, entfernt werden müssen. Oder habe ich das falsch interpretiert?
Laut Beschreibung:
Ist aus der Beschreibung bei aliexpress.comAH: sorry, falsches Bild genommen. In dem Bild, wo Du den Abgleich vorgenommen hast, sind beide Jumper offen.
Gruß Eisbaeeer@Eisbaeeer sagte in Füllstandsmessung per Pegelsonde.:
Gruß EisbaeeerKaum nimmt man ein anderes USB-Kabel läuft alles. Danke für die Hilfe.
Noch mal ein paar Fragen.
Da ich ein 20x4 LCD Display habe, habe ich jetzt unter LCD_COLS = 20 und unter LCD_NB_COLUMS = 20 eingestellt. Nun wird der Text auch richtig angezeigt. Muß ich für die Anzeige noch etwas ändern?
Ich habe bis jetzt am NANO nur das Display angeschlossen. In der Anzeige schwanken die Werte sehr stark. Das ist aber wohl normal, oder?
Im Sketch wird die IP des MQTT Server benötigt. Das ist wohl die IP von iobroker, richtig? Bei mir wird auch ein Passwort verlangt. Wie/wo gebe ich das ein? Wird keine Portangabe benötigt?
Wenn ich den Nano auf den Netzwerkshield stecke, als was sollte sich das alles im Netzwerk melden? Ein MAC-Adresse ist nicht zu finden. Kann ich im Sketch eine "Wunschadresse" eingeben?
Manfred -
Manfred@Beowolf sagte in Füllstandsmessung per Pegelsonde.:
- Da ich ein 20x4 LCD Display habe, habe ich jetzt unter LCD_COLS = 20 und unter LCD_NB_COLUMS = 20 eingestellt. Nun wird der Text auch richtig angezeigt. Muß ich für die Anzeige noch etwas ändern?
Nein, ich glaube das wars, was man anpassen muss.
- Ich habe bis jetzt am NANO nur das Display angeschlossen. In der Anzeige schwanken die Werte sehr stark. Das ist aber wohl normal, oder?
Du schreibst unbeschaltet, nur das Display. Dann ist das normal. Du kannst den A0 auch einfach auf Masse schalten oder mit einem Poti testen. Aber bitte nur mit 3.3V
- Im Sketch wird die IP des MQTT Server benötigt. Das ist wohl die IP von iobroker, richtig? Bei mir wird auch ein Passwort verlangt. Wie/wo gebe ich das ein? Wird keine Portangabe benötigt?
Derzeit ist im Sketch keine Authentifizierung realisiert. Ich probiere mal bei Gelegenheit, das noch einzubauen.
Port brauchst du keinen, ausser du hast das in iobroker geändert!?
Die MQTT Server IP ist der iobroker.- Wenn ich den Nano auf den Netzwerkshield stecke, als was sollte sich das alles im Netzwerk melden? Ein MAC-Adresse ist nicht zu finden. Kann ich im Sketch eine "Wunschadresse" eingeben?
Bitte unbedingt die MAC-Adresse im Sketch anpassen. Falls es einen DHCP-Server gibt, bezieht das shield die IP vom DHCP. Wenn es keinen DHCP gibt oder der nicht erreichbar ist (z.B. weil er gerade bootet oder einfach nicht erreichbar ist) dann wird die IP-Adresse verwendet, die im Sketch unter den Einstellungen steht.
Du solltest die IP-Adresse aber schon unter den leases vom DHCP finden.Grüße
Manfred -
Der Port im ioBroker ist 1886. Normal ist glaube ich 1883. Der wird aber schon von den Sonoff Geräten belegt.
Ungetestet !
@Beowolf habe eben die neue Version hochgeladen. MQTT Port ist jetzt konfigurierbar und Benutzerauthentifizierung. Konnte aber noch nicht testen.
Wer die Authentifizierung nicht braucht oder nicht will, muss diese Zeile hier kommentieren:vorher:
#define mqttauthnachher:
//#define mqttauthhttps://github.com/Eisbaeeer/Arduino.Ethernet.Zisterne
Grüße Eisbaeeer -
Habe die geänderte Version aufgespielt und alles eingetragen.
Fritzbox zeigt keine neue Netzwerkadresse an.
Das ist das, was ich hier habe.
Die LED auf dem Nano blinkt kurz vier mal, kleine Pause, dann wieder vier mal usw.
Der serielle Monitor bleibt stumm. Dort erscheint nichts.
Wenn ich mal zur Kontrolle das "Blink-Sketch" aufspiele, so blinkt die LED so wie sie soll. Der ser. Monitor bleibt aber dort auch stumm.
So, bin einen Schritt weiter. Ich habe jetzt ein neues "Gerät" in der Übersicht. Nennt sich "WIZnetD579ED".
Das sollte es sein. Eine eigene Weboberfläche ist dort nicht, richtig?
Allerdings erscheint unterioBroker leider noch nichts.
HAAALLLTTT
Mein Fehler. Ich hatte nur den Bereich des Sketches übernommen in dem das Passwort usw. gesetzt wurde. Dabei habe ich übersehen, das weiter unter im Sketch der Port noch einmal fest eingetragen war.
Habe den neuen Sketch jetzt komplett genommen - alles gut - alles tut.
HAAALLLTTT
@Beowolf Na dann passt es ja. Habe es eben bei mir getestet. Authentifizierung funktioniert bei mir auch.
Drucke gerade meinen 2. Adapter für die Nano Platine auf Hutschiene.
Hast du inzwischen alles zusammengebaut?
Im Testbetrieb läuft bei mir alles einwandfrei. Gebe ich Druck auf die Sonde, erhöht sich der Füllstand. Alles andere ist dann noch Feinarbeit.
Bin echt schon auf den Echtbetrieb gespannt. Hoffe es gibt diese Woche noch gutes Wetter. Heute hat es geregnet. Da hab ich keine Lust in den Schacht zu klettern. -
Morgen kommen die "Lochplatinen". Da kommt dann alles drauf.
Wie war das jetzt noch mal mit der Kalibrierung?
Noch einmal eine Frage zur Kalibrierung.
Ich muß bald Öl bestellen. Tank ist fast leer.
Es sollte doch auch funktionieren, wenn ich vorher einen "geschätzten" Restinhalt einstelle, und nach dem Betanken die erhaltene Ölmenge hinzuaddiere, oder? Per Einstellung am Poti.
