  4. Test Adapter lovelace v0.2.x
    6.5k
testcall for actionlovelacevisualisierung
1.1k Beiträge 131 Kommentatoren 455.1k Aufrufe 99 Beobachtet
  • X xADDRx
    @WW1983 Ich habe den Code kopiert, jedoch ändert sich nicht am Theme.
    # Main colors
    primary-color: '#5294E2'                                                        # Header
    accent-color: '#E45E65'                                                         # Accent color
    dark-primary-color: 'var(--accent-color)'                                       # Hyperlinks
    light-primary-color: 'var(--accent-color)'                                      # Horizontal line in about
    ha-card-border-radius: '20px'
    ha-card-background: 'rgba(150, 150, 150, 0.1)'
    # Text colors
    primary-text-color: '#FFFFFF'                                                   # Primary text colour, here is referencing dark-primary-color
    text-primary-color: 'var(--primary-text-color)'                                 # Primary text colour
    secondary-text-color: '#5294E2'                                                 # For secondary titles in more info boxes etc.
    disabled-text-color: '#7F848E'                                                  # Disabled text colour
    label-badge-border-color: 'green'                                               # Label badge border, just a reference value
    # Background colors
    primary-background-color: '#383C45'                                             # Settings background
    secondary-background-color: '#383C45'                                           # Main card UI background
    divider-color: 'rgba(0, 0, 0, .12)'                                             # Divider
    # Table rows
    table-row-background-color: '#353840'                                           # Table row
    table-row-alternative-background-color: '#3E424B'                               # Table row alternative
    # Nav Menu
    paper-listbox-color: 'var(--primary-color)'                                     # Navigation menu selection hoover
    paper-listbox-background-color: '#2E333A'                                       # Navigation menu background
    paper-grey-50: 'var(--primary-text-color)'
    paper-grey-200: '#414A59'                                                       # Navigation menu selection
    # Paper card
    paper-card-header-color: 'var(--accent-color)'                                  # Card header text colour
    paper-card-background-color: 'rgba(150, 150, 150, 0.1)'                         # Card background colour
    paper-dialog-background-color: '#434954'                                        # Card dialog background colour
    paper-item-icon-color: 'var(--primary-text-color)'                              # Icon color
    paper-item-icon-active-color: '#F9C536'                                         # Icon color active
    paper-item-icon_-_color: 'green'
    paper-item-selected_-_background-color: '#434954'                               # Popup item select
    paper-tabs-selection-bar-color: 'green'
    # Labels
    label-badge-red: 'var(--accent-color)'                                          # References the brand colour label badge border
    label-badge-text-color: 'var(--primary-text-color)'                             # Now same as label badge border but that's a matter of taste
    label-badge-background-color: '#2E333A'                                         # Same, but can also be set to transparent here
    label-badge-background: 'rgba(255, 255, 255, 0.1)'
    # Switches
    paper-toggle-button-checked-button-color: 'var(--accent-color)'
    paper-toggle-button-checked-bar-color: 'var(--accent-color)'
    paper-toggle-button-checked-ink-color: 'var(--accent-color)'
    paper-toggle-button-unchecked-button-color: 'var(--disabled-text-color)'
    paper-toggle-button-unchecked-bar-color: 'var(--disabled-text-color)'
    paper-toggle-button-unchecked-ink-color: 'var(--disabled-text-color)'
    # Sliders
    paper-slider-knob-color: 'var(--accent-color)'
    paper-slider-knob-start-color: 'var(--accent-color)'
    paper-slider-pin-color: 'var(--accent-color)'
    paper-slider-active-color: 'var(--accent-color)'
    paper-slider-container-color: 'linear-gradient(var(--primary-background-color), var(--secondary-background-color)) no-repeat'
    paper-slider-secondary-color: 'var(--secondary-background-color)'
    paper-slider-disabled-active-color: 'var(--disabled-text-color)'
    paper-slider-disabled-secondary-color: 'var(--disabled-text-color)'
    # Google colors
    google-red-500: '#E45E65'
    google-green-500: '#39E949'
    marcusklM Offline
    marcusklM Offline
    marcuskl
    #252
    @xADDRx
    Hat bei mir auch nicht so funktioniert.
    Du musst vorher "transparent:" hinzufügen, so:
    transparent:
       # Main colors
    dann funktioniert es.
    Ich habe noch das Hintergrund Bild bei den Cards hochgeladen und die Zeile Backround image hinzugefügt.
    #Background images
    background: center / cover no-repeat url("/cards/background.jpg") fixed
    Host: Intel Nuc6cayh (16GB Ram, 240GB SSD) mit Proxmox.
    Iobroker VM, InfluxDB LXC, Pihole LXC, Tasmoadmin LXC, Easy2connect VM
    X marcusklM 2 Antworten Letzte Antwort
    • BBTownB BBTown
      @WW1983 sagte in Test Adapter lovelace v0.2.x:
      Hat jemand die Wetter-Card zum laufen gebracht? Bei mir werden keine Icons angezeigt. Das war aber nicht immer so.
      Hast Du die Icon irgendwann mal selbst kopiert/hochgeladen und kann es sein dass dies erst seit der Aktualisierung auf js-controller v2.x so ist?, dann könnte es mit den Hinweisen hier zu tun haben.
      Weiterhin wird der ioBroke-Eigene-Dateibereich (im Normalfall bisher unter <ioBroker-Verzeichnis>/iobroker-data/files/...) nun strikter behandelt und manuell oder per Skript (fs.write) dort direkt abgelegte/hinkopierte Dateien sind ggf. nicht mehr in Visualisierungen anzeigbar!
      Skripte müssen angepasst werden (Nutzung von writeFile) bzw. die Dateien müssen in offiziell definierte Adpater-Basisverzeichnisse (z.B. vis.0, iqontrol.meta u.ä.) abgelegt werden. Nutzt am besten auch die offiziellen Uploader via Vis oder iqontrol, damit diese Dateien korrekt registriert sind. Diese Änderung wurde auch zur Erhöhung der Sicherheit umgesetzt! Der positive Nebeneffekt ist auch das die Files dann mit im Backup landen, was bisher nicht gegeben war!
      W Offline
      W Offline
      WW1983
      #253
      @BBTown
      Habe eigentlich nichts selbst kopiert / hochgeladen. Sind die Icons von DasWetter
      • G g.polat
        Hier das gleiche, hast du eine Lösung gefunden?
        W Offline
        W Offline
        WW1983
        #254
        @g-polat
        Leider nein
        • X xADDRx
          # Main colors
          # Text colors
          # Background colors
          # Table rows
          # Nav Menu
          # Paper card
          # Labels
          # Switches
          # Sliders
          # Google colors
          W Offline
          W Offline
          WW1983
          schrieb am zuletzt editiert von WW1983
          #255
          @xADDRx
          Das Theme musst du manuell hinzufügen. In den Einstellungen von Lovelace gibt es einen Extra Reiter "Theme". Dort habe ich die Theme Einstellungen hineinkopiert. Kann gerne mal den Theme "Code" heute Abend hier rein stellen.
          Edit: Sehe gerade dass @marcuskl es schon gepostet hat
          marcusklM 1 Antwort Letzte Antwort
          • W WW1983
            @xADDRx
            marcusklM Offline
            marcusklM Offline
            marcuskl
            #256
            @WW1983 hast du es hinbekommen den header transparent zu bekommen mit der compact-custom-header card ?
            W 1 Antwort Letzte Antwort
            • marcusklM marcuskl
              W Offline
              W Offline
              WW1983
              #257
              @marcuskl
              Nein. Leider nicht. Habe nicht wirklich verstanden wo und wie man es einstellen kann. Deshalb habe ich den Header einfach farblich halbwegs angepasst
              • marcusklM Offline
                marcusklM Offline
                marcuskl
                #258
                @WW1983
                Ich habe alles mögliche versucht aber die Card hat nicht funktioniert.
                Ich habe es auch nur dunkler gemacht
                  @WW1983
                  W Offline
                  W Offline
                  WW1983
                  #259
                  @marcuskl
                  es funktionieren derzeit so einige Cards nicht. Ich hoffe das wird irgendwann noch behoben.
                  Man kann zwar jetzt schon was brauchbares basteln. Aber schade das noch so vieles nicht funktioniert. Auch die "Standard-Entitys"
                  • W WW1983
                    @marcuskl
                    marcusklM Offline
                    marcusklM Offline
                    marcuskl
                    #260
                    @WW1983 Ja des stimmt.
                    Ich würde gerne mal meine RGB Beleuchtungen einbinden, aber die light entiy card funktioniert auch noch nicht.
                    https://github.com/ljmerza/light-entity-card
                      W Offline
                      W Offline
                      WW1983
                      #261
                      @marcuskl
                      Habe die auch schon getestet. Bei mir funktioniert die auch nicht. Aber auch die integrierte Light Card funktioniert bei mir nicht. Kann nur licht an und aus machen, aber mit der Card nicht die Dimmfunktion nutzen.
                      N 1 Antwort Letzte Antwort
                        @xADDRx
                        transparent:
                           # Main colors
                        #Background images
                        X Offline
                        X Offline
                        xADDRx
                        schrieb am zuletzt editiert von xADDRx
                        #262
                        @marcuskl danke
                        transparent:
                           # Main colors
                           # Text colors
                           # Background colors
                           # Table rows
                           # Nav Menu
                           # Paper card
                           # Labels
                           # Switches
                           # Sliders
                           # Google colors
                           # Background images
                        Sonos, Intel Nuc, Iobroker Pro, Proxmox, IPad Air (Wand), Vis, Xiaomi, Devolo, Bose, Philips Hue, Instar, Synology
                          schittl
                          #263
                          mal was zum Einstieg ehe ich mich tief darin verliere ;). Sollte man ebenfalls pro verschiedene Auflösung (z.B. Tablet & Smartphone) am besten 2 Views erstellen oder kann man das out of the box mit einer View bewerkstelligen.
                          Ansonsten klingt der Adapter sehr interessant und ich bin schon fleißig am rumprobieren. Guter Ansatz bzw. Umsetzung.
                          vg
                          Falk
                          HW: Lenovo M920q (Proxmox, ioBroker, RaspMatic & Z2M), QNAP (Docker, Influx), Arduino Mega 2560 R3 (I2C DS18B20 + LED)
                          SW: CT IoBroker, VM RaspMatic(v3.79.6.20241122)
                          • G g.polat
                            @Scrounger sagte in Test Adapter lovelace v0.2.x:
                            Hier mal ein paar Beispiele, was ich so mit lovelace realisiert habe.
                            Hauptsächlich verwende ich die button-card, da diese sehr viel Flexibilität ermöglicht und man so mit manuellen entities sehr gut arbeiten kann.
                            Anwesenheit
                            type: horizontal-stack
                            cards:
                              - type: 'custom:vertical-stack-in-card'
                                cards:
                                  - type: 'custom:button-card'
                                    entity: sensor.Netzwerk_Devices_Tussi_Anwesend
                                    layout: vertical
                                    show_name: true
                                    show_last_changed: true
                                    show_entity_picture: true
                                    show_icon: false
                                    tap_action:
                                      action: none
                                    styles:
                                      label:
                                        - font-size: small
                                        - font-style: italic
                                        - color: '#a1a1a1'
                                    state:
                                      - value: true
                                        entity_picture: /static/myimages/tussi_presence.png
                                      - value: false
                                        styles:
                                          icon:
                                            - filter: grayscale(100%)
                                    show_name: false
                                    show_icon: false
                                    styles:
                                      card:
                                        - width: 100%
                                        - padding: 2px
                                    state:
                                      - value: true
                                        styles:
                                          card:
                                            - background: green
                                      - value: false
                                        styles:
                                          card:
                                            - background: FireBrick
                                cards:
                                    entity: sensor.Netzwerk_Devices_Handy_Anwesend
                                    layout: vertical
                                    show_name: true
                                    show_icon: false
                                    tap_action:
                                      action: none
                                    styles:
                                      label:
                                        - font-size: small
                                        - color: '#a1a1a1'
                                    state:
                                      - value: true
                                        entity_picture: /static/myimages/ich_presence.png
                                      - value: false
                                        styles:
                                          icon:
                                    show_name: false
                                    show_icon: false
                                    styles:
                                      card:
                                        - width: 100%
                                        - padding: 2px
                                    state:
                                      - value: true
                                        styles:
                                          card:
                                            - background: green
                                      - value: false
                                        styles:
                                          card:
                            Fenster
                            cards:
                                cards:
                                    entity: sensor.Sensoren_Fenster_Bad_Offen
                                    layout: vertical
                                    show_name: false
                                    show_icon: false
                                    tap_action:
                                      action: none
                                    styles:
                                      label:
                                        - font-size: small
                                        - color: '#a1a1a1'
                                    state:
                                      - value: true
                                        entity_picture: /static/myimages/window_open.png
                                      - value: false
                                        entity_picture: /static/myimages/window_closed.png
                                        show_last_changed: false
                                cards:
                                    entity: sensor.Sensoren_Fenster_WC_Offen
                                    layout: vertical
                                    show_name: false
                                    show_icon: false
                                    tap_action:
                                      action: none
                                    styles:
                                      label:
                                        - font-size: small
                                        - color: '#a1a1a1'
                                    state:
                                      - value: true
                                      - value: false
                            Licht - Schalter
                            type: vertical-stack
                            cards:
                              - type: horizontal-stack
                                cards:
                                    cards:
                                      - type: entity-button
                                        tap_action:
                                          action: toggle
                                        hold_action:
                                          action: more-info
                                        show_icon: true
                                        show_name: true
                                        entity: light.Licht_Flur_Main_An
                                        cards:
                                            entity: sensor.Licht_Flur_Main_Leistung
                                            layout: vertical
                                            show_name: true
                                            show_icon: false
                                            show_state: false
                                            show_label: true
                                            label: |
                                                if(entity.state > 0)
                                                  return (entity.state + " " + entity.attributes.unit_of_measurement);
                                                else
                                                  return "0 " + entity.attributes.unit_of_measurement;
                                            styles:
                                              card:
                                                - background: '#a1a1a1'
                                                - border-radius: 0px
                                                - height: 50px
                                              name:
                                                - font-size: x-small
                                                - color: '#44739e'
                                                - font-weight: bold
                                                - font-style: oblique
                                              state:
                                                - font-size: smaller
                                              label:
                                            entity: sensor.Verbrauchszaehler_Licht_Flur_Main_Verbrauch_Tag
                                            layout: vertical
                                            show_name: true
                                            show_icon: false
                                            show_state: false
                                            show_label: true
                                            label: |
                                              [[[ return entity.state * 1000 + ' Wh']]]
                                            styles:
                                              card:
                                                - height: 50px
                                              name:
                                                - color: '#44739e'
                                                - font-weight: bold
                                              state:
                                              label:
                                            entity: sensor.Verbrauchszaehler_Licht_Flur_Main_Kosten_Jahr
                                            layout: vertical
                                            show_name: true
                                            show_icon: false
                                            show_state: false
                                            show_label: true
                                            label: |
                                                else
                                            styles:
                                              card:
                                                - height: 50px
                                              name:
                                                - color: '#44739e'
                                                - font-weight: bold
                                              state:
                                              label:
                                    cards:
                                        tap_action:
                                          action: toggle
                                        hold_action:
                                          action: more-info
                                        show_icon: true
                                        show_name: true
                                        entity: light.Licht_Flur_Nische_An
                                        cards:
                                            entity: sensor.Licht_Flur_Nische_Leistung
                                            layout: vertical
                                            show_name: true
                                            show_icon: false
                                            show_state: false
                                            show_label: true
                                            label: |
                                                else
                                            styles:
                                              card:
                                                - height: 50px
                                              name:
                                                - color: '#44739e'
                                                - font-weight: bold
                                              state:
                                              label:
                                            entity: sensor.Verbrauchszaehler_Licht_Flur_Nische_Verbrauch_Tag
                                            layout: vertical
                                            show_name: true
                                            show_icon: false
                                            show_state: false
                                            show_label: true
                                            label: |
                                            styles:
                                              card:
                                                - height: 50px
                                              name:
                                                - color: '#44739e'
                                                - font-weight: bold
                                              state:
                                              label:
                                            entity: sensor.Verbrauchszaehler_Licht_Flur_Nische_Kosten_Jahr
                                            layout: vertical
                                            show_name: true
                                            show_icon: false
                                            show_state: false
                                            show_label: true
                                            label: |
                                                else
                                            styles:
                                              card:
                                                - height: 50px
                                              name:
                                                - color: '#44739e'
                                                - font-weight: bold
                                              state:
                                              label:
                            Licht - Dimmer
                            title: Esszimmer
                            cards:
                                cards:
                                  - type: light
                                    entity: light.Licht_Esszimmer_Links_Dimmer
                                  - type: light
                                    entity: light.Licht_Esszimmer_Rechts_Dimmer
                                cards:
                                    entity: sensor.Licht_Esszimmer_Gruppe_SummeLeistung
                                    layout: vertical
                                    show_name: true
                                    show_icon: false
                                    show_state: false
                                    show_label: true
                                    label: |
                                        else
                                    styles:
                                      card:
                                        - height: 50px
                                      name:
                                        - color: '#44739e'
                                        - font-weight: bold
                                      state:
                                      label:
                                    entity: sensor.Verbrauchszaehler_Licht_Esszimmer_Gruppe_Verbrauch_Tag
                                    layout: vertical
                                    show_name: true
                                    show_icon: false
                                    show_state: false
                                    show_label: true
                                    label: |
                                    styles:
                                      card:
                                        - height: 50px
                                      name:
                                        - color: '#44739e'
                                        - font-weight: bold
                                      state:
                                      label:
                                    entity: sensor.Verbrauchszaehler_Licht_Esszimmer_Gruppe_Kosten_Jahr
                                    layout: vertical
                                    show_name: true
                                    show_icon: false
                                    show_state: false
                                    show_label: true
                                    label: |
                                        else
                                    styles:
                                      card:
                                        - height: 50px
                                      name:
                                        - color: '#44739e'
                                        - font-weight: bold
                                      state:
                                      label:
                            Geräte
                            cards:
                                entity: switch.Netzwerk_Devices_MusicCast_Esszimmer_An
                                layout: vertical
                                show_name: false
                                tap_action:
                                  action: toggle
                                state:
                                  - value: 'on'
                                    entity_picture: /static/myimages/MusicCast-WX-030.png
                                    styles:
                                      card:
                                        - background: LemonChiffon
                                  - value: 'off'
                                entity: sensor.Netzwerk_Devices_MusicCast_Esszimmer_PowerStatus
                                show_name: false
                                show_icon: false
                                tap_action:
                                  action: none
                                styles:
                                  card:
                                    - width: 100%
                                    - padding: 2px
                                    - margin-top: '-10px'
                                state:
                                  - value: An
                                    styles:
                                      card:
                                        - background: green
                                  - value: Aus
                                    styles:
                                      card:
                                  - value: Boot
                                    styles:
                                      card:
                                        - background: MediumSeaGreen
                                        - animation: blink 2s ease infinite
                                  - value: Standby
                                    styles:
                                      card:
                                        - background: Orange
                                  - value: Enter Standby
                                    styles:
                                      card:
                                  - value: Leave Standby
                                    styles:
                                      card:
                                cards:
                                    layout: vertical
                                    show_name: true
                                    show_icon: false
                                    show_state: true
                                    styles:
                                      card:
                                        - height: 50px
                                      name:
                                        - color: '#44739e'
                                        - font-weight: bold
                                      state:
                                    entity: sensor.Schalter_Esszimmer_MusicCast_Leistung
                                    layout: vertical
                                    show_name: true
                                    show_icon: false
                                    show_state: true
                                    show_label: true
                                    styles:
                                      card:
                                        - height: 50px
                                      name:
                                        - color: '#44739e'
                                        - font-weight: bold
                                      state:
                                      label:
                                    state:
                                      - value: 0
                                        label: 0 W
                                    entity: sensor.Verbrauchszaehler_Schalter_Esszimmer_MusicCast_Kosten_Jahr
                                    layout: vertical
                                    show_name: true
                                    show_icon: false
                                    show_state: true
                                    show_label: true
                                    styles:
                                      card:
                                        - height: 50px
                                      name:
                                        - color: '#44739e'
                                        - font-weight: bold
                                      state:
                                      label:
                                    state:
                                      - value: 0
                                        label: 0 €
                                    entity: switch.Schalter_Esszimmer_MusicCast_An
                                    layout: vertical
                                    show_name: false
                                    styles:
                                      card:
                                        - height: 50px
                            cards:
                                entity_picture: /static/myimages/nuc.png
                                styles:
                                  card:
                                    - height: 60px
                                    - padding: 0px
                                    - margin: 0px
                                  grid:
                                    - grid-template-areas: '"n i"'
                                    - grid-template-columns: 1fr 30%
                                  name:
                                    - justify-self: start
                                    - padding-left: 20px
                                    - color: '#0277bd'
                                    - font-size: x-large
                                  entity_picture:
                                    - padding-right: 20px
                                    - padding-top: 6px
                                    - padding-bottom: 6px
                                  img_cell:
                                    - justify-content: flex-end
                              - type: divider
                                style:
                                  height: 4px
                                  background: '#0277bd'
                              - type: divider
                                style:
                                  height: 6px
                                cards:
                                    layout: icon_name
                                    show_icon: true
                                    show_state: false
                                    icon: 'mdi:raspberry-pi'
                                    styles:
                                      card:
                                        - height: 100%
                                        - width: 100%
                                        - min-width: 160px
                                      grid:
                                        - grid-template-areas: '"i n"'
                                        - grid-template-columns: 1fr 70%
                                      name:
                                        - margin: 0px
                                      icon:
                                        - color: '#0277bd'
                                  - type: 'custom:bignumber-card'
                                    entity: sensor.System_CPU_Auslastung
                                    scale: 13px
                                    min: 0
                                    max: 100
                                    severity:
                                      - value: 60
                                        style: green
                                      - value: 80
                                        style: Gold
                                      - value: 100
                                        style: FireBrick
                              - type: divider
                                style:
                                  height: 6px
                                cards:
                                    layout: icon_name
                                    show_icon: true
                                    show_state: false
                                    styles:
                                      card:
                                        - height: 100%
                                        - width: 100%
                                        - min-width: 160px
                                      grid:
                                      name:
                                        - margin: 0px
                                      icon:
                                        - color: '#0277bd'
                                    entity: sensor.System_CPU_Durchschnitt
                                    scale: 13px
                                    min: 0
                                    max: 100
                                    severity:
                                      - value: 60
                                        style: green
                                      - value: 80
                                        style: Gold
                                      - value: 100
                                        style: FireBrick
                              - type: divider
                                style:
                                  height: 6px
                                cards:
                                    layout: icon_name
                                    show_icon: true
                                    show_state: false
                                    show_label: true
                                    icon: 'mdi:memory'
                                    label: >-
                                      [[[ return (states["sensor.System_RAM_used"].state + " GB / " +
                                      states["sensor.System_RAM_total"].state + " GB") ]]]
                                    styles:
                                      card:
                                        - height: 100%
                                        - width: 100%
                                        - min-width: 160px
                                        - padding: 2px
                                      grid:
                                        - grid-template-areas: '"i n" "i l"'
                                        - grid-template-rows: min-content min-content
                                        - grid-template-columns: 1fr 72%
                                      name:
                                        - margin: 0px
                                      label:
                                        - margin: 0px
                                        - color: '#0277bd'
                                      icon:
                                        - color: '#0277bd'
                                    entity: sensor.System_RAM_usedPercent
                                    scale: 13px
                                    min: 0
                                    max: 100
                                    severity:
                                      - value: 60
                                        style: green
                                      - value: 75
                                        style: Gold
                                      - value: 100
                                        style: FireBrick
                              - type: divider
                                style:
                                  height: 6px
                                cards:
                                    layout: icon_name
                                    show_icon: true
                                    show_state: false
                                    show_label: true
                                    icon: 'mdi:harddisk'
                                    label: >-
                                      [[[ return (states["sensor.System_Laufwerke_C_used"].state + " GB / "
                                      + states["sensor.System_Laufwerke_C_Size"].state + " GB") ]]]
                                    styles:
                                      card:
                                        - height: 100%
                                        - width: 100%
                                        - min-width: 160px
                                        - padding: 2px
                                      grid:
                                      name:
                                        - margin: 0px
                                      label:
                                        - margin: 0px
                                        - color: '#0277bd'
                                      icon:
                                        - color: '#0277bd'
                                    entity: sensor.System_Laufwerke_C_usedPercent
                                    scale: 13px
                                    min: 0
                                    max: 100
                                    severity:
                                      - value: 60
                                        style: green
                                      - value: 75
                                        style: Gold
                                      - value: 100
                                        style: FireBrick
                              - type: divider
                                style:
                                  height: 6px
                                cards:
                                    layout: icon_name
                                    show_icon: true
                                    show_state: false
                                    show_label: true
                                    label: >-
                                      [[[ return (states["sensor.System_Laufwerke_D_used"].state + " GB / "
                                      + states["sensor.System_Laufwerke_D_Size"].state + " GB") ]]]
                                    styles:
                                      card:
                                        - height: 100%
                                        - width: 100%
                                        - min-width: 160px
                                        - padding: 2px
                                      grid:
                                      name:
                                        - margin: 0px
                                      label:
                                        - margin: 0px
                                        - color: '#0277bd'
                                      icon:
                                        - color: '#0277bd'
                                    entity: sensor.System_Laufwerke_D_usedPercent
                                    scale: 13px
                                    min: 0
                                    max: 100
                                    severity:
                                      - value: 60
                                        style: green
                                      - value: 75
                                        style: Gold
                                      - value: 100
                                        style: FireBrick
                              - type: divider
                                style:
                                  height: 6px
                                cards:
                                    layout: icon_name
                                    show_icon: true
                                    show_state: false
                                    show_label: true
                                    label: >-
                                      [[[ return (states["sensor.System_Laufwerke_Y_used"].state + " GB / "
                                      + states["sensor.System_Laufwerke_Y_Size"].state + " GB") ]]]
                                    styles:
                                      card:
                                        - height: 100%
                                        - width: 100%
                                        - min-width: 160px
                                        - padding: 2px
                                      grid:
                                      name:
                                        - margin: 0px
                                      label:
                                        - margin: 0px
                                        - color: '#0277bd'
                                      icon:
                                        - color: '#0277bd'
                                    entity: sensor.System_Laufwerke_Y_usedPercent
                                    scale: 13px
                                    min: 0
                                    max: 100
                                    severity:
                                      - value: 60
                                        style: green
                                      - value: 75
                                        style: Gold
                                      - value: 100
                                        style: FireBrick
                              - type: divider
                                style:
                                  height: 6px
                                cards:
                                    layout: icon_name
                                    show_icon: true
                                    show_state: false
                                    show_label: true
                                    label: >-
                                      [[[ return (states["sensor.System_Laufwerke_Z_used"].state + " GB / "
                                      + states["sensor.System_Laufwerke_Z_Size"].state + " GB") ]]]
                                    styles:
                                      card:
                                        - height: 100%
                                        - width: 100%
                                        - min-width: 160px
                                        - padding: 2px
                                      grid:
                                      name:
                                        - margin: 0px
                                      label:
                                        - margin: 0px
                                        - color: '#0277bd'
                                      icon:
                                        - color: '#0277bd'
                                    entity: sensor.System_Laufwerke_Z_usedPercent
                                    scale: 13px
                                    min: 0
                                    max: 100
                                    severity:
                                      - value: 60
                                        style: green
                                      - value: 75
                                        style: Gold
                                      - value: 100
                                        style: FireBrick
                              - type: divider
                                style:
                                  height: 6px
                                entity: sensor.Schalter_Flur_Server_An
                                show_name: false
                                show_icon: false
                                tap_action:
                                  action: none
                                styles:
                                  card:
                                    - width: 100%
                                    - padding: 2px
                                state:
                                  - value: true
                                    styles:
                                      card:
                                        - background: green
                                  - value: false
                                    styles:
                                      card:
                                cards:
                                    entity: sensor.Schalter_Flur_Server_Leistung
                                    layout: vertical
                                    show_name: true
                                    show_icon: false
                                    show_state: false
                                    show_label: true
                                    label: |
                                        else
                                    styles:
                                      card:
                                        - height: 50px
                                      name:
                                        - color: '#44739e'
                                        - font-weight: bold
                                      state:
                                      label:
                                    entity: sensor.Verbrauchszaehler_Schalter_Flur_Server_Verbrauch_Tag
                                    layout: vertical
                                    show_name: true
                                    show_icon: false
                                    show_state: false
                                    show_label: true
                                    label: |
                                    styles:
                                      card:
                                        - height: 50px
                                      name:
                                        - color: '#44739e'
                                        - font-weight: bold
                                      state:
                                      label:
                                    entity: sensor.Verbrauchszaehler_Schalter_Flur_Server_Kosten_Jahr
                                    layout: vertical
                                    show_name: true
                                    show_icon: false
                                    show_state: false
                                    show_label: true
                                    label: |
                                        else
                                    styles:
                                      card:
                                        - height: 50px
                                      name:
                                        - color: '#44739e'
                                        - font-weight: bold
                                      state:
                                      label:
                            cards:
                                entity_picture: /static/myimages/raspberrymatic.png
                                tap_action:
                                  action: url
                                  url: 'http://10.0.124.189/login.htm'
                                styles:
                                  card:
                                    - height: 60px
                                    - padding: 0px
                                    - margin: 0px
                                  grid:
                                    - grid-template-columns: 1fr 20%
                                  name:
                                    - color: '#0277bd'
                                  entity_picture:
                                    - padding-top: 6px
                                  img_cell:
                                entity: sensor.Netzwerk_Devices_RaspiMatic_Verbunden
                                show_name: false
                                show_icon: false
                                tap_action:
                                  action: none
                                styles:
                                  card:
                                    - width: 100%
                                    - padding: 2px
                                state:
                                  - value: true
                                    styles:
                                      card:
                                        - background: green
                                  - value: false
                                    styles:
                                      card:
                                entity: sensor.Netzwerk_Devices_RaspiMatic_Betriebszeit
                                layout: icon_name
                                show_icon: true
                                show_state: false
                                show_label: true
                                icon: 'mdi:clock-outline'
                                label: |
                                  [[[ if (entity.state == "")
                                        return "0m";
                                      else
                                        return entity.state;
                                styles:
                                  card:
                                    - padding-top: 10px
                                    - padding-bottom: 10px
                                  grid:
                                    - grid-template-areas: '"i n l"'
                                    - grid-template-columns: 11% 1fr 19%
                                  name:
                                    - margin: 0px
                                  label:
                                    - justify-self: end
                                  icon:
                                    - color: '#0277bd'
                                entity: sensor.Netzwerk_Devices_RaspiMatic_upgradable
                                layout: icon_name
                                name: Neue Version verfügbar
                                show_icon: true
                                show_state: false
                                show_label: true
                                icon: 'mdi:update'
                                label: |
                                  [[[ if (entity.state == false)
                                        return "nein";
                                      else
                                        return "Ja";
                                styles:
                                  card:
                                    - padding-top: 10px
                                  grid:
                                  name:
                                    - margin: 0px
                                  label:
                                    - justify-self: end
                                  icon:
                                    - color: |
                                          if (entity.state === true)
                                            return "green";
                                          else
                                            return '#0277bd';
                                entity: sensor.Netzwerk_Devices_RaspiMatic_Alarmmeldungen
                                layout: icon_name
                                show_icon: true
                                show_state: false
                                show_label: true
                                icon: 'mdi:alert-octagon'
                                label: |
                                  [[[ if (entity.state == 0)
                                        return "0";
                                      else
                                styles:
                                  card:
                                    - padding-top: 10px
                                  grid:
                                  name:
                                    - margin: 0px
                                  label:
                                    - justify-self: end
                                  icon:
                                    - color: |
                                          if (entity.state > 0)
                                            return "FireBrick";
                                          else
                                            return '#0277bd';
                                entity: sensor.Netzwerk_Devices_RaspiMatic_Servicemeldungen
                                layout: icon_name
                                show_icon: true
                                show_state: false
                                show_label: true
                                label: |
                                        return "0";
                                      else
                                styles:
                                  card:
                                    - padding-top: 10px
                                  grid:
                                  name:
                                    - margin: 0px
                                  label:
                                    - justify-self: end
                                  icon:
                                    - color: |
                                            return "Gold";
                                          else
                                            return '#0277bd';
                              - type: divider
                                style:
                                  height: 1px
                                  margin-left: 10px
                                  margin-right: 10px
                              - type: divider
                                style:
                                  height: 6px
                                cards:
                                    layout: icon_name
                                    show_icon: true
                                    show_state: false
                                    icon: 'mdi:thermometer'
                                    styles:
                                      card:
                                        - height: 100%
                                        - width: 100%
                                        - min-width: 160px
                                      grid:
                                      name:
                                        - margin: 0px
                                      icon:
                                        - color: '#0277bd'
                                    entity: sensor.Netzwerk_Devices_RaspiMatic_Temperatur
                                    scale: 12px
                                    min: 0
                                    max: 100
                                    severity:
                                      - value: 50
                                        style: green
                                      - value: 55
                                        style: Gold
                                      - value: 65
                                        style: FireBrick
                              - type: divider
                                style:
                                  height: 6px
                                cards:
                                    layout: icon_name
                                    show_icon: true
                                    show_state: false
                                    styles:
                                      card:
                                        - height: 100%
                                        - width: 100%
                                        - min-width: 160px
                                      grid:
                                      name:
                                        - margin: 0px
                                      icon:
                                        - color: '#0277bd'
                                    entity: sensor.Netzwerk_Devices_RaspiMatic_Auslastung
                                    scale: 12px
                                    min: 0
                                    max: 100
                                    severity:
                                      - value: 60
                                        style: green
                                      - value: 80
                                        style: Gold
                                      - value: 100
                                        style: FireBrick
                              - type: divider
                                style:
                                  height: 6px
                                cards:
                                    layout: icon_name
                                    show_icon: true
                                    show_state: false
                                    icon: 'mdi:memory'
                                    styles:
                                      card:
                                        - height: 100%
                                        - width: 100%
                                        - min-width: 160px
                                      grid:
                                      name:
                                        - margin: 0px
                                      icon:
                                        - color: '#0277bd'
                                    entity: sensor.Netzwerk_Devices_RaspiMatic_RamUsed
                                    scale: 12px
                                    min: 0
                                    max: 100
                                    severity:
                                      - value: 60
                                        style: green
                                      - value: 80
                                        style: Gold
                                      - value: 100
                                        style: FireBrick
                              - type: divider
                                style:
                                  height: 6px
                                cards:
                                    layout: icon_name
                                    show_icon: true
                                    show_state: false
                                    icon: 'mdi:micro-sd'
                                    styles:
                                      card:
                                        - height: 100%
                                        - width: 100%
                                        - min-width: 160px
                                      grid:
                                      name:
                                        - margin: 0px
                                      icon:
                                        - color: '#0277bd'
                                    entity: sensor.Netzwerk_Devices_RaspiMatic_SdUsed
                                    scale: 12px
                                    min: 0
                                    max: 100
                                    severity:
                                      - value: 60
                                        style: green
                                      - value: 75
                                        style: Gold
                                      - value: 100
                                        style: FireBrick
                              - type: divider
                                style:
                                  height: 6px
                                cards:
                                    layout: icon_name
                                    show_icon: true
                                    show_state: false
                                    icon: 'mdi:chart-line-variant'
                                    styles:
                                      card:
                                        - height: 100%
                                        - width: 100%
                                        - min-width: 160px
                                      grid:
                                      name:
                                        - margin: 0px
                                      icon:
                                        - color: '#0277bd'
                                    entity: sensor.Netzwerk_Devices_RaspiMatic_DutyCycle
                                    scale: 12px
                                    min: 0
                                    max: 100
                                    severity:
                                      - value: 50
                                        style: green
                                      - value: 70
                                        style: Gold
                                      - value: 100
                                        style: FireBrick
                              - type: divider
                                style:
                                  height: 6px
                            Bar-Chart
                            cards:
                              - type: 'custom:mini-graph-card'
                                entities:
                                  - entity: sensor.Verbrauchszaehler_Licht_Summe_Verbrauch__Tag_Tag_1
                                    color: '#44739e'
                                    name: Lichter Energie gesamt
                                hour24: true
                                points_per_hour: 0.041
                                hours_to_show: 168
                                decimals: 3
                                show:
                                  graph: bar
                                  icon: false
                                cards:
                                    entity: sensor.Licht_Leistung
                                    layout: vertical
                                    show_name: true
                                    show_icon: false
                                    show_state: false
                                    show_label: true
                                    label: |
                                        else
                                    styles:
                                      card:
                                        - height: 50px
                                      name:
                                        - color: '#44739e'
                                        - font-weight: bold
                                      state:
                                      label:
                                    entity: sensor.Verbrauchszaehler_Licht_Summe_Kosten_Jahr
                                    layout: vertical
                                    show_name: true
                                    show_icon: false
                                    show_state: false
                                    show_label: true
                                    label: |
                                        else
                                    styles:
                                      card:
                                        - height: 50px
                                      name:
                                        - color: '#44739e'
                                        - font-weight: bold
                                      state:
                                      label:
                            tolle arbeit, wie hast u das mit den Pictures gelöst. Wie lautet der Pfad im Iobroker?
                            ScroungerS Offline
                            ScroungerS Offline
                            Scrounger
                            schrieb am zuletzt editiert von Scrounger
                            #264
                            @g-polat
                            Glaub node-modules/lovelace/hass-irgendwa/static/
                            Bin Grad nicht am Rechner.
                            Und da dann reinkopiert. Achtung nach Adapter Update sind die Bilder dann weg!
                            • ScroungerS Scrounger
                              @g-polat
                              W Offline
                              W Offline
                              WW1983
                              #265
                              @Scrounger
                              Könnte man den Ordner theoretisch mit Schreibschutz versehen, oder gibt dann ein Problem mit dem Update?
                              • B BobBruni
                                Bei mir passt noch alles nach dem Update.
                                Habe aber immer noch das Problem, dass die Bedienung sehr sehr träge ist. Gerade wenn das Display vom Tablet längere Zeit aus gewesen. Energiesparmodus für Fully habe ich deaktiviert. Die Motiton Detection dagegen funktioniert super.
                                Muss ich irgendwo noch etwas einstellen? Sonst keiner dieser Problem?
                                BobBruni
                                schrieb am zuletzt editiert von BobBruni
                                #266
                                @BobBruni said in Test Adapter lovelace v0.2.x:
                                Dieses Problem hat sich zum Glück nach einer kompletten Neuinstallation von ioBroker auf neuer Hardware (RPI4) erledigt.
                                Allerdings habe ich nun das Problem, dass nach einer gewissen Zeit (ich schätze ca. 24h), die Zustände meiner Objekte nicht mehr aktuell sind. z.B. eine Lampe deren Zustand noch als True angezeigt wird, obwohl in ioBroker auf False.
                                In diesem Fall hilft nur ein Neustart von Lovlace. Anschließend läuft wieder alles synchron... Für eine gewisse Zeit :(
                                Jemand ne Idee?
                                • marcusklM Offline
                                  marcusklM Offline
                                  marcuskl
                                  #267
                                  Mein Lovelace Adapter startet seit kurzen immer wieder neu?
                                  lovelace.0	2019-11-01 14:08:04.661	info	(2780) starting. Version 0.2.3 in /opt/iobroker/node_modules/iobroker.lovelace, node: v10.16.3
                                  host.iobroker	2019-11-01 14:08:01.552	info	instance system.adapter.lovelace.0 started with pid 2780
                                  host.iobroker	2019-11-01 14:08:00.537	info	Restart adapter system.adapter.lovelace.0 because enabled
                                  host.iobroker	2019-11-01 14:08:00.536	error	instance system.adapter.lovelace.0 terminated with code 156 (156)
                                  lovelace.0	2019-11-01 14:08:00.516	info	(2752) terminating
                                  lovelace.0	2019-11-01 14:08:00.017	info	(2752) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                                  lovelace.0	2019-11-01 14:08:00.016	info	(2752) terminating
                                  lovelace.0	2019-11-01 14:08:00.008	info	(2752) cleaned everything up...
                                  lovelace.0	2019-11-01 14:08:00.006	info	(2752) Scheduled restart.
                                  lovelace.0	2019-11-01 14:07:05.583	warn	(2752) no max value for light object 'shelly.0.SHRGBW2#5A38A7#1.color' defined -> using fallback max = 100
                                  lovelace.0	2019-11-01 14:07:04.947	info	(2752) http server listening on port 8091
                                  lovelace.0	2019-11-01 14:07:04.805	info	(2752) starting. Version 0.2.3 in /opt/iobroker/node_modules/iobroker.lovelace, node: v10.16.3
                                  host.iobroker	2019-11-01 14:07:01.552	info	instance system.adapter.lovelace.0 started with pid 2752
                                  host.iobroker	2019-11-01 14:07:00.537	info	Restart adapter system.adapter.lovelace.0 because enabled
                                  host.iobroker	2019-11-01 14:07:00.536	error	instance system.adapter.lovelace.0 terminated with code 156 (156)
                                  • apollon77A Offline
                                    #268
                                    Da steht scheduled restart ... den hast du eingestellt. Korrekt? Cron Regel korrekt?
                                      mathschut
                                      #269
                                      läuft der Adapter auch zusammen mit der HA App auf Android?
                                        mathschut
                                        #270
                                        nutzt jemand Lovelace und IObroker im Zusammenhang mit KNX. Ich bekomme es nicht hin, einen Dimmer anzusprechen.
                                        • apollon77A apollon77
                                          marcusklM Offline
                                          marcusklM Offline
                                          marcuskl
                                          #271
                                          @apollon77 sagte in Test Adapter lovelace v0.2.x:
                                          Stimmt, hatte den Cronjob falsch eingestellt.
                                          Danke 👍
