  4. ioBroker admin läuft nicht mehr durch
Geplant Angeheftet Gesperrt Verschoben Ungelöst ioBroker Allgemein
admin adapter läuft nicht
126 Beiträge 6 Kommentatoren 12.5k Aufrufe 5 Beobachtet
    DiveDancer
    #113
    Jetzt steh ich echt auf dem Schlauch.
    Kommt schon, das Siegerpodest ist breit genug für 2
    Ich hab die Instanz installiert ( +)
    Jetzt ist Sie da.
    Aber das habe ich doch sonst nie gemacht bei Adaptern aus Github
    $ ./iobroker add shuttercontrol  --host rock64
    host.rock64 install adapter shuttercontrol
    npm install --production (System call) in "/opt/iobroker/node_modules/iobroker.shuttercontrol"
    npm
     notice created a lockfile as package-lock.json. You should commit this file.
    npm
     WARN tslint@5.20.0 requires a peer of typescript@>=2.3.0-dev || >=2.4.0-dev || >=2.5.0-dev || >=2.6.0-dev || >=2.7.0-dev || >=2.8.0-dev || >=2.9.0-dev || >=3.0.0-dev || >= 3.1.0-dev || >= 3.2.0-dev but none is installed. You must install peer dependencies yourself.npm WARN tsutils@2.29.0 requires a peer of typescript@>=2.1.0 || >=2.1.0-dev || >=2.2.0-dev || >=2.3.0-dev || >=2.4.0-dev || >=2.5.0-dev || >=2.6.0-dev || >=2.7.0-dev || >=2.8.0-dev || >=2.9.0-dev || >= 3.0.0-dev || >= 3.1.0-dev but none is installed. You must install peer dependencies yourself.
    got /opt/iobroker/node_modules/iobroker.shuttercontrol/admin
    upload [4] shuttercontrol.admin /opt/iobroker/node_modules/iobroker.shuttercontrol/admin/words.js words.js application/javascript
    upload [3] shuttercontrol.admin /opt/iobroker/node_modules/iobroker.shuttercontrol/admin/tsconfig.json tsconfig.json application/json
    upload [2] shuttercontrol.admin /opt/iobroker/node_modules/iobroker.shuttercontrol/admin/style.css style.css text/css
    upload [1] shuttercontrol.admin /opt/iobroker/node_modules/iobroker.shuttercontrol/admin/shuttercontrol.png shuttercontrol.png image/png
    upload [0] shuttercontrol.admin /opt/iobroker/node_modules/iobroker.shuttercontrol/admin/index_m.html index_m.html text/html
    host.rock64 object system.adapter.shuttercontrol created
    host.rock64 create instance shuttercontrol
    host.rock64 object shuttercontrol.0.info.Azimut created
    host.rock64 object shuttercontrol.0.info.Elevation created
    host.rock64 object shuttercontrol.0.info.GoldenHourEnd created
    host.rock64 object shuttercontrol.0.info.GoldenHour created
    host.rock64 object shuttercontrol.0.info.Sunset created
    host.rock64 object shuttercontrol.0.info.Sunrise created
    host.rock64 object shuttercontrol.0.info.downTimeLiving created
    host.rock64 object shuttercontrol.0.info.downTimeSleep created
    host.rock64 object shuttercontrol.0.info.upTimeLiving created
    host.rock64 object shuttercontrol.0.info.upTimeSleep created
    host.rock64 object shuttercontrol.0.control.autoSleep created
    host.rock64 object shuttercontrol.0.control.autoLiving created
    host.rock64 object shuttercontrol.0.control.Holiday created
    host.rock64 object shuttercontrol.0.control created
    host.rock64 object shuttercontrol.0.info created
    host.rock64 object shuttercontrol.0.shutters.autoSun created
    host.rock64 object shuttercontrol.0.shutters.autoDown created
    host.rock64 object shuttercontrol.0.shutters.autoUp created
    host.rock64 object shuttercontrol.0.shutters created
    host.rock64 object system.adapter.shuttercontrol.0.outputCount created
    host.rock64 object system.adapter.shuttercontrol.0.inputCount created
    host.rock64 object system.adapter.shuttercontrol.0.uptime created
    host.rock64 object system.adapter.shuttercontrol.0.memRss created
    host.rock64 object system.adapter.shuttercontrol.0.memHeapTotal created
    host.rock64 object system.adapter.shuttercontrol.0.memHeapUsed created
    host.rock64 object system.adapter.shuttercontrol.0.cputime created
    host.rock64 object system.adapter.shuttercontrol.0.cpu created
    host.rock64 object system.adapter.shuttercontrol.0.connected created
    host.rock64 object system.adapter.shuttercontrol.0.alive created
    host.rock64 object system.adapter.shuttercontrol.0 created
    process exited with code 0
    LG DiveDancer
    • J Jan1
      @DiveDancer
      Du bringst was durcheinander. Wenn der Adapter nicht sichtbar wäre, könntest Du kein Upload machen weil der Adapter und der Button nicht da wären. Du suchst die Instanz und wie oben schon geschrieben muss die manuell erstellt werden mit dem Klick auf das +
      Jan1
      #114
      @Jan1 sagte in ioBroker admin läuft nicht mehr durch:
      @DiveDancer
      Hier
      • D DiveDancer
        Jetzt ist Sie da.
        npm
        npm
        Jan1
        #115
        @DiveDancer sagte in ioBroker admin läuft nicht mehr durch:
        Jetzt ist Sie da.
        npm
        npm
        Doch, weil ohne + nix Instanz
        • J Jan1
          Jetzt ist Sie da.
          npm
          npm
          sigi234S Online
          sigi234S Online
          #116
          Und jetzt zur Sicherheit ein Upload.😀
            DiveDancer
            #117
            Jetzt müsst ihr mir nur noch veraten wie ich mein Sorgenkind, den Zigbee Adapter wieder auf Vordermann bringe.
            Hab gar keine Einstellungen mehr.
            Kein Netzwer, etc.
            Das ganze neue Layout ist futsch
            LG DiveDancer
            sigi234S J 2 Antworten Letzte Antwort
            • D DiveDancer
              Kein Netzwer, etc.
              sigi234S Online
              sigi234S Online
              #118
              Deinstallieren und neu installieren.
              • D DiveDancer
                Kein Netzwer, etc.
                Jan1
                #119
                @DiveDancer
                Am besten neu installieren
                  DiveDancer
                  #120
                  Eindeutig,
                  beide flink
                  muss ich die Einstellungen sichern?
                  LG DiveDancer
                  • J Jan1
                    @DiveDancer
                    sigi234S Online
                    sigi234S Online
                    #121
                    @DiveDancer
                    So ich ziehe mich jetzt zurück😀
                      DiveDancer
                      #122
                      Danke Sigi
                      LG DiveDancer
                      • D DiveDancer
                        Eindeutig,
                        beide flink
                        Jan1
                        #123
                        @DiveDancer
                        Die beziehen sich aber nur auf den Adapter, die Geräte müssen danach neu gepairt werden.
                        Wenn Du mit Backitup zigbee gesichert hast, dann kannst das wieder herstellen und das Pairen sparen.
                          DiveDancer
                          schrieb am zuletzt editiert von DiveDancer
                          #124
                          Ich könnt schwören das hatte ich schon ausprobiert.
                          Seis drum.
                          Yeah, die Optik ist wieder da
                          LG DiveDancer
                            DiveDancer
                            #125
                            Aber jetzt werden die Sensoren unter Ojekte nicht mehr aufgelistet.
                            Komischerweise hat mein Bewegungsmelder mich Heute Morgen noch mit Dezentbeleuchtung begrüßt.
                            LG DiveDancer
                            • D DiveDancer
                              Jan1
                              #126
                              @DiveDancer
                              da hilf dann wohl nur neu pairen, wenn sie wieder dem Netz zugeordnet sind, werden sie auch wieder angezeigt.
