  4. Wir helfen Altersrentner
    1.0k
Geplant Angeheftet Gesperrt Verschoben Gelöst ioBroker Allgemein
zigbee adapterinvalid option
224 Beiträge 8 Kommentatoren 33.3k Aufrufe 7 Beobachtet
  • A Altersrentner
    Cannot find io-package.json in null
    Cannot parse null/io-package.json:Error: ENOENT: no such file or directory, open 'null/io-package.json'
    got /opt/iobroker/node_modules/iobroker.backitup/admin
    upload [3] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/words.js words.js application/javascript
    upload [2] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.html index_m.html text/html
    upload [1] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index.html index.html text/html
    upload [0] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.png backitup.png image/png
    got /opt/iobroker/node_modules/iobroker.discovery/admin
    upload [5] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/words.js words.js application/javascript
    upload [4] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/settings_m.html settings_m.html text/html
    upload [3] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/settings.html settings.html text/html
    upload [2] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/index_m.html index_m.html text/html
    upload [1] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/index.html index.html text/html
    upload [0] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/discovery.png discovery.png image/png
    got /opt/iobroker/node_modules/iobroker.admin/admin
    upload [3] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/words.js words.js application/javascript
    upload [2] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/index_m.html index_m.html text/html
    upload [1] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/index.html index.html text/html
    upload [0] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/admin.png admin.png image/png
    pi@raspberrypi:~ $
    Ohne Erfolg
    GlasfaserG Offline
    GlasfaserG Offline
    @Altersrentner sagte in Zigbee Stick funktioniert nicht mehr:
    Hast du den Befehl im Verzeichnis ausgeführt !?
    /opt/iobroker
      Altersrentner
      ja habe ich.
      Mache jetzt die Kiste aus.
      Mir platzt der Schädel!!
      Gute Nacht
      Gruß Michael
      • A Altersrentner
        ja habe ich.
        Gute Nacht
        Gruß Michael
        GlasfaserG Offline
        GlasfaserG Offline
        @Altersrentner
        Lass dann den Fixer nochmal drüber laufen
          Altersrentner
          Guten Morgen
           Your installation was fixed successfully
              Run iobroker start to start ioBroker again!
          Das brachte keinen Erfolg.
          Habe festgestellt, das keine Adapter mehr vorhanden sind.
          Folgenden Beitrag durchgeackert und alles probiert.
          ohne Erfolg.
          pi@raspberrypi:/opt/iobroker $ sudo iobroker stop
          pi@raspberrypi:/opt/iobroker $ sudo npm cache clean
          npm ERR! As of npm@5, the npm cache self-heals from corruption issues and data extracted from the cache is guaranteed to be valid. If you want to make sure everything is consistent, use 'npm cache verify' instead. On the other hand, if you're debugging an issue with the installer, you can use `npm install --cache /tmp/empty-cache` to use a temporary cache instead of nuking the actual one.
          npm ERR!
          npm ERR! If you're sure you want to delete the entire cache, rerun this command with --force.
          npm ERR!     /root/.npm/_logs/2019-10-19T06_38_26_970Z-debug.log
          pi@raspberrypi:/opt/iobroker $ sudo iobroker upgrade admin
          Requested repository "stable" does not exit in config.
          pi@raspberrypi:/opt/iobroker $ sudo iobroker upgrade flot
          pi@raspberrypi:/opt/iobroker $ sudo iobroker start
          Gruß Michael
          • A Altersrentner
            Guten Morgen
            ohne Erfolg.
            npm ERR!
            Gruß Michael
            Altersrentner
            @Altersrentner Übrigens Backups wurden heute Nacht autom. erstellt.
            Minimal und Komplett
            • A Altersrentner
              Jan1
              @Altersrentner
              Wie ist denn der aktuelle Stand? Dein alter PI läuft noch und macht schön Backups, was jetzt auch auf den NAS klappt?
              Das Log oben ist vom neuen PI4?
                Altersrentner
                #66
                Moin,
                Der alte sowie auch der neue Pi haben beide auf der NAS min und komplett
                Backups gemacht.
                Auf dem 4er fehlen alle Adapter.
                Aktualisieren und die Vorschläge aus Beitrag
                https://forum.iobroker.net/topic/9734/gelöst-admin-reiter-bleibt-leer-und-hängt-bei-bearbeite-fest-admin-v2-und-v3/210
                brachten keine Veränderung.
                • A Altersrentner
                  Moin,
                  Backups gemacht.
                  Jan1
                  #67
                  @Altersrentner
                  Du bist noch auf default und nicht latest?
                  • J Jan1
                    @Altersrentner
                    Altersrentner
                    #68
                    @Jan1 Verstehe ich leider nicht??
                    • A Altersrentner
                      Jan1
                      #69
                      @Altersrentner
                      geh mal oben auf den Schraubenschlüssel und schau was unter "aktiver Verwahrungsort" steht.
                        Altersrentner
                        #70
                        ist das ok?
                        • A Altersrentner
                          ist das ok?
                          Jan1
                          #71
                          @Altersrentner
                          So jetzt aber mal auch genau lesen was ich schreibe und nicht nur die Hälfte 😇
                          Ich habe "aktiver Verwarungsort" geschrieben und wo bist Du? schon ein Reiter zu weit.
                            Altersrentner
                            #72
                            Habe unter 1 "stable" eingetragen und die Adapter sind wieder da.
                            Aber sonst bei den Instanzen keine Veränderung:
                            File index_m.html not found
                            • A Altersrentner
                              Jan1
                              #73
                              @Altersrentner
                              Du sollst nicht irgendwo was ändern, sondern erst mal da tun was hier von Dir verlangt wird.
                              stable sollte da nie eingetragen werden, sondern DU mir einfach mal sagen was bei Dir hier steht:
                              Wenn Du was anderes änderst, ist es sehr schwer zu helfen, da dann Dinge passieren, die eben nicht so geplant sind.
                                Altersrentner
                                #74
                                Entschuldige, das hatte ich übersehen.
                                J A 4 Antworten Letzte Antwort
                                • A Altersrentner
                                  Jan1
                                  #75
                                  @Altersrentner
                                  Ist ja lustig, hast da von Hand "stable" eingetragen?
                                  Und mach mal das Bild kleiner, oder willst dass jeder weiß wo Dein Haus wohnt 😂
                                  • A Altersrentner
                                    Altersrentner
                                    #76
                                    @Altersrentner said in Zigbee Stick funktioniert nicht mehr:
                                    • A Altersrentner
                                      Altersrentner
                                      #77
                                        Altersrentner
                                        #78
                                        wie kann ich das Bild löschen. Nichts von Hand eingetragen.
                                        • A Altersrentner
                                          Jan1
                                          #79
                                          @Altersrentner
                                          OK mittlerweile sind wir weit weg von dem was ich wollte. Da kommt normal kein "stable" als Auswahl. Oben hast geschrieben, dass Du das irgendwo eingetragen hast, mach das mal wieder schön so wie es vorher war.
                                          Den Beitrag mit dem Bild einfach bearbeiten und das Bild löschen.
                                          Ich denke, Du hast hier was von Hand geändert:
