  4. js-controller 2.0 ab sofort im Latest Repo
    6.4k
js-controller
1.1k Beiträge 89 Kommentatoren 437.1k Aufrufe 64 Beobachtet
    @apollon77 sagte in js-controller 2.0 ab sofort im Latest Repo:
    @telekom0815 Magst Du das Update nochmals versuchen? Ist bisher 2 mal von über 1500 Installationen passiert. Also müssen wir den grund finden.
    die erneute Installation bricht mit folgendem Log ab (hab es jetzt fast 20min gewartet)
    pi@raspberrypi:~ $ ps auxww|grep io
    root 12 0.0 0.0 0 0 ? S Okt17 0:05 [migration/0]
    root 15 0.0 0.0 0 0 ? S Okt17 0:05 [migration/1]
    root 20 0.0 0.0 0 0 ? S Okt17 0:04 [migration/2]
    root 25 0.0 0.0 0 0 ? S Okt17 0:04 [migration/3]
    root 42 0.0 0.0 0 0 ? I< Okt17 0:00 [rpciod]
    root 44 0.0 0.0 0 0 ? I< Okt17 0:00 [xprtiod]
    root 48 0.0 0.0 0 0 ? I< Okt17 0:00 [nfsiod]
    root 64 0.0 0.0 0 0 ? I< Okt17 0:00 [DWC Notificatio]
    message+ 321 0.0 0.0 6556 2976 ? Ss Okt17 0:00 /usr/bin/dbus-daemon --system --address=systemd: -- nofork --nopidfile --systemd-activation --syslog-only
    pi 24954 0.0 0.0 7360 492 pts/0 S+ 20:18 0:00 grep --color=auto io
    pi@raspberrypi:~ $ iobroker upgrade self
    Update js-controller from @1.5.14 to @2.0.34
    NPM version: 6.9.0
    npm install iobroker.js-controller@2.0.34 --unsafe-perm --production --save --prefix "/opt/iobroker" (System call)
    In file included from ../src/unix_dgram.cc:5:
    ../../../../nan/nan.h: In function ‘void Nan::AsyncQueueWorker(Nan::AsyncWorker*)’:
    ../../../../nan/nan.h:2200:62: warning: cast between incompatible function types from ‘void ()(uv_work_t)’ {aka ‘void ()(uv_w ork_s)’} to ‘uv_after_work_cb’ {aka ‘void ()(uv_work_s, int)’} [-Wcast-function-type]
    , reinterpret_cast<uv_after_work_cb>(AsyncExecuteComplete)
    ../src/unix_dgram.cc: In function ‘void {anonymous}::OnRecv({anonymous}::SocketContext*)’:
    ../src/unix_dgram.cc:121:25: warning: ‘v8::Localv8::Value Nan::MakeCallback(v8::Localv8::Object, v8::Localv8::Function, in t, v8::Localv8::Value)’ is deprecated [-Wdeprecated-declarations]
    argv);
    ../../../../nan/nan.h:958:46: note: declared here
    NAN_DEPRECATED inline v8::Localv8::Value MakeCallback(
    argv);
    ../src/unix_dgram.cc: In function ‘void {anonymous}::OnWritable({anonymous}::SocketContext*)’:
    ../src/unix_dgram.cc:129:28: warning: ‘v8::Localv8::Value Nan::MakeCallback(v8::Localv8::Object, v8::Localv8::Function, in t, v8::Localv8::Value)’ is deprecated [-Wdeprecated-declarations]
    0, NULL);
    0, NULL);
    ../src/unix_dgram.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE {anonymous}::Socket(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/unix_dgram.cc:189:37: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-dec larations]
    domain = info[0]->Int32Value();
    In file included from /home/iobroker/.node-gyp/10.16.3/include/node/v8.h:26,
    from /home/iobroker/.node-gyp/10.16.3/include/node/node.h:63,
    from ../../../../nan/nan.h:52,
    /home/iobroker/.node-gyp/10.16.3/include/node/v8.h:2478:46: note: declared here
    V8_DEPRECATED("Use maybe version", int32_t Int32Value() const);
    /home/iobroker/.node-gyp/10.16.3/include/node/v8config.h:324:3: note: in definition of macro ‘V8_DEPRECATED’
    declarator attribute((deprecated(message)))
    ../src/unix_dgram.cc:190:37: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-dec larations]
    type = info[1]->Int32Value();
    ../src/unix_dgram.cc:191:37: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-dec larations]
    protocol = info[2]->Int32Value();
    ../src/unix_dgram.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE {anonymous}::Bind(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/unix_dgram.cc:230:28: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-dec larations]
    fd = info[0]->Int32Value();
    ../src/unix_dgram.cc:231:33: warning: ‘v8::String::Utf8Value::Utf8Value(v8::Localv8::Value)’ is deprecated: Use Isolate versio n [-Wdeprecated-declarations]
    String::Utf8Value path(info[1]);
    /home/iobroker/.node-gyp/10.16.3/include/node/v8.h:2892:28: note: declared here
    explicit Utf8Value(Localv8::Value obj));
    ../src/unix_dgram.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE {anonymous}::SendTo(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/unix_dgram.cc:258:28: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-dec larations]
    ../src/unix_dgram.cc:259:27: warning: ‘v8::Localv8::Object v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wde precated-declarations]
    buf = info[1]->ToObject();
    In file included from /home/iobroker/.node-gyp/10.16.3/include/node/node.h:63,
    /home/iobroker/.node-gyp/10.16.3/include/node/v8.h:10046:15: note: declared here
    Local<Object> Value::ToObject() const {
    ../src/unix_dgram.cc:260:33: warning: ‘uint32_t v8::Value::Uint32Value() const’ is deprecated: Use maybe version [-Wdeprecated-d eclarations]
    offset = info[2]->Uint32Value();
    /home/iobroker/.node-gyp/10.16.3/include/node/v8.h:2477:47: note: declared here
    V8_DEPRECATED("Use maybe version", uint32_t Uint32Value() const);
    ../src/unix_dgram.cc:261:33: warning: ‘uint32_t v8::Value::Uint32Value() const’ is deprecated: Use maybe version [-Wdeprecated-d eclarations]
    length = info[3]->Uint32Value();
    ../src/unix_dgram.cc:262:33: warning: ‘v8::String::Utf8Value::Utf8Value(v8::Localv8::Value)’ is deprecated: Use Isolate versio n [-Wdeprecated-declarations]
    String::Utf8Value path(info[4]);
    ../src/unix_dgram.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE {anonymous}::Send(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/unix_dgram.cc:302:28: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-dec larations]
    ../src/unix_dgram.cc:303:27: warning: ‘v8::Localv8::Object v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wde precated-declarations]
    ../src/unix_dgram.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE {anonymous}::Connect(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/unix_dgram.cc:340:28: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-dec larations]
    ../src/unix_dgram.cc:341:33: warning: ‘v8::String::Utf8Value::Utf8Value(v8::Localv8::Value)’ is deprecated: Use Isolate versio n [-Wdeprecated-declarations]
    ../src/unix_dgram.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE {anonymous}::Close(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/unix_dgram.cc:361:28: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-dec larations]
    In file included from ../../../../nan/nan.h:52,
    ../src/unix_dgram.cc: At global scope:
    /home/iobroker/.node-gyp/10.16.3/include/node/node.h:573:43: warning: cast between incompatible function types from ‘void ()(v8 ::Localv8::Object)’ to ‘node::addon_register_func’ {aka ‘void ()(v8::Localv8::Object, v8::Localv8::Value, void*)’} [-Wcas t-function-type]
    (node::addon_register_func) (regfunc),
    /home/iobroker/.node-gyp/10.16.3/include/node/node.h:607:3: note: in expansion of macro ‘NODE_MODULE_X’
    NODE_MODULE_X(modname, regfunc, NULL, 0) // NOLINT (readability/null_usage)
    ../src/unix_dgram.cc:420:1: note: in expansion of macro ‘NODE_MODULE’
    NODE_MODULE(unix_dgram, Initialize)
    /home/iobroker/.node-gyp/10.16.3/include/node/v8.h: In instantiation of ‘void v8::PersistentBase<T>::SetWeak(P*, typename v8::We akCallbackInfo<P>::Callback, v8::WeakCallbackType) [with P = node::ObjectWrap; T = v8::Object; typename v8::WeakCallbackInfo<P>: :Callback = void ()(const v8::WeakCallbackInfonode::ObjectWrap&)]’:
    /home/iobroker/.node-gyp/10.16.3/include/node/node_object_wrap.h:84:78: required from here
    /home/iobroker/.node-gyp/10.16.3/include/node/v8.h:9502:16: warning: cast between incompatible function types from ‘v8::WeakCall backInfonode::ObjectWrap::Callback’ {aka ‘void (
    )(const v8::WeakCallbackInfonode::ObjectWrap&)’} to ‘Callback’ {aka ‘void ( )(const v8::WeakCallbackInfo<void>&)’} [-Wcast-function-type]
    reinterpret_cast<Callback>(callback), type);
    , typename v8::We akCallbackInfo<P>::Callback, v8::WeakCallbackType) [with P = Nan::ObjectWrap; T = v8::Object; typename v8::WeakCallbackInfo<P>:: Callback = void ()(const v8::WeakCallbackInfoNan::ObjectWrap&)]’:
    ../../../../nan/nan_object_wrap.h:66:61: required from here
    /home/iobroker/.node-gyp/10.16.3/include/node/v8.h:9502:16: warning: cast between incompatible function types from ‘v8::WeakCall backInfoNan::ObjectWrap::Callback’ {aka ‘void (
    )(const v8::WeakCallbackInfoNan::ObjectWrap&)’} to ‘Callback’ {aka ‘void (*) (const v8::WeakCallbackInfo<void>&)’} [-Wcast-function-type]
    (node:25079) UnhandledPromiseRejectionWarning: ParserError: Protocol error, got "H" as reply type byte. Please report this.
    at handleError (/opt/iobroker/node_modules/redis-parser/lib/parser.js:190:15)
    at parseType (/opt/iobroker/node_modules/redis-parser/lib/parser.js:304:14)
    (node:25079) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of a n async function without a catch block, or by rejecting a promise which was not handled with .catch(). (rejection id: 1)
    (node:25079) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that a re not handled will terminate the Node.js process with a non-zero exit code.
    (node:25079) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of a n async function without a catch block, or by rejecting a promise which was not handled with .catch(). (rejection id: 2)
    LOG nach sudo -H -u iobroker npm install iobroker.js-controller
    pi@raspberrypi:~ $ sudo -H -u iobroker npm install iobroker.js-controller
    npm WARN checkPermissions Missing write access to /home/pi
    npm WARN enoent ENOENT: no such file or directory, open '/home/pi/package.json'
    npm WARN pi No description
    npm WARN pi No repository field.
    npm WARN pi No README data
    npm WARN pi No license field.
    npm ERR! path /home/pi
    npm ERR! code EACCES
    npm ERR! errno -13
    npm ERR! syscall access
    npm ERR! Error: EACCES: permission denied, access '/home/pi'
    npm ERR! { [Error: EACCES: permission denied, access '/home/pi']
    npm ERR! stack: 'Error: EACCES: permission denied, access '/home/pi'',
    npm ERR! errno: -13,
    npm ERR! code: 'EACCES',
    npm ERR! syscall: 'access',
    npm ERR! path: '/home/pi' }
    npm ERR!
    npm ERR! The operation was rejected by your operating system.
    npm ERR! It is likely you do not have the permissions to access this file as the current user
    npm ERR!
    npm ERR! If you believe this might be a permissions issue, please double-check the
    npm ERR! permissions of the file and its containing directories, or try running
    npm ERR! the command again as root/Administrator (though this is not recommended).
    npm ERR! /home/iobroker/.npm/_logs/2019-10-18T18_43_24_847Z-debug.log
    LOG im Detail: 2019-10-18T18_43_24_847Z-debug.log
    nach Abbruch mit ctrl-c und reboot ist die .34 installiert, VIS über Web nicht erreichbar.
    und nun?
    #371
    @telekom0815 in dem Fall ist die Meldung klar: iobroker läuft noch. Kann das sein? Versuch nochmal bitte und schau genau das sie Prozesse beendet sind.
      NPM version: 6.9.0
      argv);
      argv);
      0, NULL);
      0, NULL);
      npm ERR! errno -13
      npm ERR!
      npm ERR!
      und nun?
      #372
      @telekom0815 ps: das zweite log zeigt einen npm install ins falsche Verzeichnis!! Musst vorher cd /opt/iobroker machen
      • MathiasJM MathiasJ
        @apollon77
        Zu spät, ich bin jetzt auf der letzten Version.
        Wie komme ich zum Log des Slaves, nachdem er stehen geblieben ist?
        Heute früh habe ich ihn komplett herunter gefahren und neu gestartet.
        Jetzt warte ich erst mal auf die nächste Pushnachricht, dass er ausgefallen ist.
        #373
        @MathiasJ wie mehrfach gesagt und in meiner signatur enthalten: logfile liegt in /opt/iobroker/log/...
          @apollon77 also @helfi9999 hatte auch admin und Js-controller update gemacht und nach Neustart de Iobrokers der selbe Fehler
          #374
          @crunchip mehr Kontext bitte?
          • apollon77A apollon77
            crunchipC Offline
            crunchipC Offline
            #375
            @apollon77 https://forum.iobroker.net/post/312986
            schliesst sich nur daraus, das beide admin und js update und neustart von iobroker gemacht haben, mit der selbigen anhaltenden Fehlermeldung
              #376
              pi@raspberrypi:/opt/iobroker $ iobroker upgrade self
              Host "raspberrypi" is up to date.
              pi@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controller
              iobroker.js-controller@2.0.34 preinstall /opt/iobroker/node_modules/iobroker.js-controller
              node lib/preinstallCheck.js
              NPM version: 6.9.0
              iobroker.js-controller@2.0.34 install /opt/iobroker/node_modules/iobroker.js-controller
              node iobroker.js setup first
              npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/needle/package.json'
              npm WARN hoist-non-react-statics@3.1.0 requires a peer of react@>=14.x but none is installed. You must install peer dependencies yourself.
              npm WARN react-beautiful-dnd@9.0.2 requires a peer of react@^16.3.1 but none is installed. You must install peer dependencies yourself.
              npm WARN react-motion@0.5.2 requires a peer of react@^0.14.9 || ^15.3.0 || ^16.0.0 but none is installed. You must install peer dependencies yourself.
              npm WARN react-redux@5.1.0 requires a peer of react@^0.14.0 || ^15.0.0-0 || ^16.0.0-0 but none is installed. You must install peer dependencies yourself.
              npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.1 (node_modules/fsevents):
              npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.1: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
              • iobroker.js-controller@2.0.34
                updated 1 package in 39.49s
                pi@raspberrypi:/opt/iobroker $ iobroker start
              Fehler bleibt leider, VIS nicht erreichbar
                #377
                pi@raspberrypi:/opt/iobroker $ sudo pkill io
                pi@raspberrypi:/opt/iobroker $ ps auxww|grep io
                root 12 0.0 0.0 0 0 ? S 20:30 0:00 [migration/0]
                root 15 0.0 0.0 0 0 ? S 20:30 0:00 [migration/1]
                root 20 0.0 0.0 0 0 ? S 20:30 0:00 [migration/2]
                root 25 0.0 0.0 0 0 ? S 20:30 0:00 [migration/3]
                root 42 0.0 0.0 0 0 ? I< 20:30 0:00 [rpciod]
                root 44 0.0 0.0 0 0 ? I< 20:30 0:00 [xprtiod]
                root 48 0.0 0.0 0 0 ? I< 20:30 0:00 [nfsiod]
                root 64 0.0 0.0 0 0 ? I< 20:30 0:00 [DWC Notificatio]
                message+ 351 0.0 0.0 6644 3568 ? Ss 20:30 0:00 /usr/bin/dbus-daemon --system --address=systemd: --nofork --nopidfile --systemd-activation --syslog-only
                pi 15087 0.0 0.0 7360 516 pts/0 S+ 21:02 0:00 grep --color=auto io
                  NPM version: 6.9.0
                  #378
                  @telekom0815 was sagt iobroker log?
                    #379
                    @telekom0815 hast du Master Slave oder Single Host System und was ist das gerade hier?
                      #380
                      keine Fehler, ausser den vom Pollenadapter
                        #381
                        @telekom0815 und was heißt dann das Vis nicht lädt? Fehler? Was? Wie? Fehlen icons?
                          #382
                          Single Host, auf dem 2. Raspberry läuft nur die HomematicsCCU
                            #383
                            File edit.html not found: permissionError
                              #384
                              @telekom0815 dann kommen wir der Sache näher. Bitte mal „iobroker upload vis“ ausführen. Tut es dann?
                                #385
                                nein, Fehler bleibt
                                  nein, Fehler bleibt
                                  #386
                                  @telekom0815 wie ist die Ausgabe von
                                  iobroker list files vis
                                    #387
                                    ist länger wie 50.000 Zeichen, wie kann ich es hier posten?
                                      #388
                                      @telekom0815 als txt file hochladen? Zip?
                                        #389
                                        @apollon77 danke, hätte ich selbst drauf kommen können ;)
                                        log.txt
                                          log.txt
                                          #390
                                          @telekom0815 welche Versionen von Vis, Web, ?
