  4. js-controller 2.0 ab sofort im Latest Repo
js-controller
1.1k Beiträge 89 Kommentatoren 509.0k Aufrufe 64 Beobachtet
  • apollon77A apollon77
    @telekom0815 in dem Fall ist die Meldung klar: iobroker läuft noch. Kann das sein? Versuch nochmal bitte und schau genau das sie Prozesse beendet sind.
    #377
    @apollon77 sagte in js-controller 2.0 ab sofort im Latest Repo:
    pi@raspberrypi:/opt/iobroker $ sudo pkill io
    pi@raspberrypi:/opt/iobroker $ ps auxww|grep io
    root 12 0.0 0.0 0 0 ? S 20:30 0:00 [migration/0]
    root 15 0.0 0.0 0 0 ? S 20:30 0:00 [migration/1]
    root 20 0.0 0.0 0 0 ? S 20:30 0:00 [migration/2]
    root 25 0.0 0.0 0 0 ? S 20:30 0:00 [migration/3]
    root 42 0.0 0.0 0 0 ? I< 20:30 0:00 [rpciod]
    root 44 0.0 0.0 0 0 ? I< 20:30 0:00 [xprtiod]
    root 48 0.0 0.0 0 0 ? I< 20:30 0:00 [nfsiod]
    root 64 0.0 0.0 0 0 ? I< 20:30 0:00 [DWC Notificatio]
    message+ 351 0.0 0.0 6644 3568 ? Ss 20:30 0:00 /usr/bin/dbus-daemon --system --address=systemd: --nofork --nopidfile --systemd-activation --syslog-only
    pi 15087 0.0 0.0 7360 516 pts/0 S+ 21:02 0:00 grep --color=auto io
      @telekom0815 ps: das zweite log zeigt einen npm install ins falsche Verzeichnis!! Musst vorher cd /opt/iobroker machen
      pi@raspberrypi:/opt/iobroker $ iobroker upgrade self
      Host "raspberrypi" is up to date.
      pi@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controller
      iobroker.js-controller@2.0.34 preinstall /opt/iobroker/node_modules/iobroker.js-controller
      node lib/preinstallCheck.js
      NPM version: 6.9.0
      iobroker.js-controller@2.0.34 install /opt/iobroker/node_modules/iobroker.js-controller
      node iobroker.js setup first
      npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/needle/package.json'
      npm WARN hoist-non-react-statics@3.1.0 requires a peer of react@>=14.x but none is installed. You must install peer dependencies yourself.
      npm WARN react-beautiful-dnd@9.0.2 requires a peer of react@^16.3.1 but none is installed. You must install peer dependencies yourself.
      npm WARN react-motion@0.5.2 requires a peer of react@^0.14.9 || ^15.3.0 || ^16.0.0 but none is installed. You must install peer dependencies yourself.
      npm WARN react-redux@5.1.0 requires a peer of react@^0.14.0 || ^15.0.0-0 || ^16.0.0-0 but none is installed. You must install peer dependencies yourself.
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.1 (node_modules/fsevents):
      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.1: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
      • iobroker.js-controller@2.0.34
        updated 1 package in 39.49s
        pi@raspberrypi:/opt/iobroker $ iobroker start
      Fehler bleibt leider, VIS nicht erreichbar
      apollon77A
      apollon77A
      #378
      @telekom0815 was sagt iobroker log?
        apollon77A
        apollon77A
        #379
        @telekom0815 hast du Master Slave oder Single Host System und was ist das gerade hier?
          #380
          keine Fehler, ausser den vom Pollenadapter
            apollon77A
            apollon77A
            #381
            @telekom0815 und was heißt dann das Vis nicht lädt? Fehler? Was? Wie? Fehlen icons?
              #382
              Single Host, auf dem 2. Raspberry läuft nur die HomematicsCCU
                #383
                File edit.html not found: permissionError
                  apollon77A
                  apollon77A
                  #384
                  @telekom0815 dann kommen wir der Sache näher. Bitte mal „iobroker upload vis“ ausführen. Tut es dann?
                    #385
                    nein, Fehler bleibt
                      nein, Fehler bleibt
                      apollon77A
                      apollon77A
                      #386
                      @telekom0815 wie ist die Ausgabe von
                      iobroker list files vis
                        #387
                        ist länger wie 50.000 Zeichen, wie kann ich es hier posten?
                          apollon77A
                          apollon77A
                          #388
                          @telekom0815 als txt file hochladen? Zip?
                            #389
                            @apollon77 danke, hätte ich selbst drauf kommen können ;)
                            log.txt
                              log.txt
                              apollon77A
                              apollon77A
                              #390
                              @telekom0815 welche Versionen von Vis, Web, ?
                                #391
                                VIS 1.2.1
                                web 2.4.6
                                -1
                                  VIS 1.2.1
                                  web 2.4.6
                                  apollon77A
                                  apollon77A
                                  #392
                                  @telekom0815 ok ich checke nachher mal. Web läuft als Admin oder unter einem User?
                                  wie ist die genaue url wenn die Fehlermeldung zu edit.html kommt?
                                  Iobroker upload all bitte mal machen.
                                    #393
                                    • web läuft als admin
                                    • http://192.168.178.20:8082/vis/edit.html?Tablet#700wetter
                                    • "iobroker upload all" ist erledigt, Fehler bleibt.
                                    restliche System läuft, also keinen Stress
                                    • apollon77A
                                      apollon77A
                                      #394
                                      Kannst du es nochmal drüber installieren?!
                                      Also:
                                      • stoppen
                                      • cd /opt/iobroker
                                      • npm install iobroker.js-controller@2.0.34
                                      Läuft es jetzt ohne weitere Fehler und Hänger durch? Die Unix-dgram Warnungen sind weiter ok.
                                      Zuletzt: welche nodejs Version?
                                        Also:
                                        • stoppen
                                        • cd /opt/iobroker
                                        #395
                                        Also:
                                        • stoppen
                                        • cd /opt/iobroker
                                        pi@raspberrypi:/opt/iobroker $ npm install iobroker.js-controller@2.0.34
                                        NPM version: 6.9.0
                                          updated 1 package in 37.989s
                                        Node.js v10.16.3
                                        apollon77A 2 Antworten Letzte Antwort
                                          @apollon77 https://forum.iobroker.net/post/312986
                                          schliesst sich nur daraus, das beide admin und js update und neustart von iobroker gemacht haben, mit der selbigen anhaltenden Fehlermeldung
                                          apollon77A
                                          apollon77A
                                          #396
                                          @crunchip Der Entwickler schaut es sich morgen an
                                          84.1k
