  4. Test Adapter hue v2.2.x
    6.6k
hue adapterhuezigbee
208 Beiträge 25 Kommentatoren 37.3k Aufrufe 15 Beobachtet
  • foxriver76F foxriver76
    @sigi234 danke, dann muss ich da doch noch was anpassen.
    integer63I Offline
    integer63I Offline
    integer63
    @foxriver76 ... ich bekomme jetzt auch immer diese Log Einträge, wenn ich über command etwas einstelle (2.1.0):
    hue.0	2019-10-17 07:45:50.674	warn	groupQueue: retry [10/10] job setGroupLightState:6:5df5d532aa62cdcb7c7b1a005768d82e
    hue.0	2019-10-17 07:45:50.674	warn	groupQueue: job setGroupLightState:6:5df5d532aa62cdcb7c7b1a005768d82e failed: Error: invalid value, [ 0.4578 ,, for parameter, xy,
    hue.0	2019-10-17 07:45:50.636	warn	groupQueue: retry [9/10] job setGroupLightState:6:5df5d532aa62cdcb7c7b1a005768d82e
    hue.0	2019-10-17 07:45:50.636	warn	groupQueue: job setGroupLightState:6:5df5d532aa62cdcb7c7b1a005768d82e failed: Error: invalid value, [ 0.4578 ,, for parameter, xy,
    hue.0	2019-10-17 07:45:50.596	warn	groupQueue: retry [8/10] job setGroupLightState:6:5df5d532aa62cdcb7c7b1a005768d82e
    hue.0	2019-10-17 07:45:50.596	warn	groupQueue: job setGroupLightState:6:5df5d532aa62cdcb7c7b1a005768d82e failed: Error: invalid value, [ 0.4578 ,, for parameter, xy,
    hue.0	2019-10-17 07:45:50.559	warn	groupQueue: retry [7/10] job setGroupLightState:6:5df5d532aa62cdcb7c7b1a005768d82e
    hue.0	2019-10-17 07:45:50.558	warn	groupQueue: job setGroupLightState:6:5df5d532aa62cdcb7c7b1a005768d82e failed: Error: invalid value, [ 0.4578 ,, for parameter, xy,
    hue.0	2019-10-17 07:45:50.520	warn	groupQueue: retry [6/10] job setGroupLightState:6:5df5d532aa62cdcb7c7b1a005768d82e
    hue.0	2019-10-17 07:45:50.519	warn	groupQueue: job setGroupLightState:6:5df5d532aa62cdcb7c7b1a005768d82e failed: Error: invalid value, [ 0.4578 ,, for parameter, xy,
    hue.0	2019-10-17 07:45:50.480	warn	groupQueue: retry [5/10] job setGroupLightState:6:5df5d532aa62cdcb7c7b1a005768d82e
    hue.0	2019-10-17 07:45:50.480	warn	groupQueue: job setGroupLightState:6:5df5d532aa62cdcb7c7b1a005768d82e failed: Error: invalid value, [ 0.4578 ,, for parameter, xy,
    hue.0	2019-10-17 07:45:50.402	warn	groupQueue: retry [4/10] job setGroupLightState:6:5df5d532aa62cdcb7c7b1a005768d82e
    hue.0	2019-10-17 07:45:50.402	warn	groupQueue: job setGroupLightState:6:5df5d532aa62cdcb7c7b1a005768d82e failed: Error: invalid value, [ 0.4578 ,, for parameter, xy,
    hue.0	2019-10-17 07:45:50.364	warn	groupQueue: retry [3/10] job setGroupLightState:6:5df5d532aa62cdcb7c7b1a005768d82e
    hue.0	2019-10-17 07:45:50.364	warn	groupQueue: job setGroupLightState:6:5df5d532aa62cdcb7c7b1a005768d82e failed: Error: invalid value, [ 0.4578 ,, for parameter, xy,
    hue.0	2019-10-17 07:45:50.301	warn	groupQueue: retry [2/10] job setGroupLightState:6:5df5d532aa62cdcb7c7b1a005768d82e
    hue.0	2019-10-17 07:45:50.301	warn	groupQueue: job setGroupLightState:6:5df5d532aa62cdcb7c7b1a005768d82e failed: Error: invalid value, [ 0.4578 ,, for parameter, xy,
    hue.0	2019-10-17 07:45:50.260	warn	groupQueue: retry [1/10] job setGroupLightState:6:5df5d532aa62cdcb7c7b1a005768d82e
    hue.0	2019-10-17 07:45:50.260	warn	groupQueue: job setGroupLightState:6:5df5d532aa62cdcb7c7b1a005768d82e failed: Error: invalid value, [ 0.4578 ,, for parameter, xy,
    B foxriver76F 2 Antworten Letzte Antwort
    • integer63I integer63
      brain
      @integer63 Meine Lösung war (vorerst): zurück zu 2.0.0.
      integer63I 1 Antwort Letzte Antwort
        foxriver76F Offline
        foxriver76F Offline
        foxriver76
        schrieb am zuletzt editiert von foxriver76
        @integer63 Kannst du mir den exakten Befehl geben, den du in command setzt und in dem Error endet? Ah scheint allgemein ein Problem mit dem xy zu sein und nicht mit dem Command.
        Videotutorials & mehr
          integer63I Offline
          integer63I Offline
          integer63
          @foxriver76 Aber gerne: {"on":true,"bri":150,"sat":255,"xy":"0.6062,0.3723"} - hat bisher immer funktioniert
            Apropo
            @foxriver76 Da es mit der 2.2 ja anscheinend noch Probleme gibt bleibe ich dann wohl erst mal auf 2.0 und warte auf eine 2.3 oder sowas. Oder soll ich trotzdem mal die 2.2 installieren um für dich was zu testen?
            • foxriver76F Offline
              foxriver76F Offline
              foxriver76
              Jop am besten erst mal auf stable bleiben. Also Fehler die ich bei 2.2.0 auf dem Schirm habe: xy fixen und Sensor DPs steuerbar machen. Falls noch was aufgefallen ist, bitte mitteilen.
              W 1 Antwort Letzte Antwort
                W Offline
                W Offline
                WulfR
                @foxriver76: Hue SmartPlug Steckdosen (die neuen und auch die alten LivingWhites) lassen sich nicht mehr an/ausschalten, der Fehler wurde vorher schon beschrieben (10 retries, dann error "(13400) lightQueue: job lights.setLightState:54:ddf37ce8845696dc1ab9cc71330de8e9 max retry reached: Error: Unknown type, On/Off plug-in unit".
                Ich nutze die Adapter Version 2.2.0 (über iobroker update, nicht über Github).
                Meine Installation: HueBridge1 mit 44 Lampen/Steckdosen + 18 Schalter/Dimmer/Sensoren, HueBridge2 mit 12 Lampen/Steckdosen + 7 Schalter/Dimmer/Sensoren, beide Bridges mit Firmware version 1934129020, API 1.34.0
                Gruß, Wulf.
                • B brain
                  integer63I Offline
                  integer63I Offline
                  integer63
                  @brain Danke für den Hinweis. Ich bin auch zurück auf 2.0 und kann bestätigen, dass der Fehler da nicht auftritt.
                    foxriver76F Offline
                    foxriver76
                    Das mit xy ist gefixt. Laut dem Entwickler der node-hue-api unterstützt sein Modul die Funktionalität für das ein/ausschalten von Sensoren derzeit nicht. Er wäre allerdings bereit es zu implementieren, hierfür benötigt er jedoch die Daten des Sensors.
                    Wenn mal jemand mit Presence Sensor auf den GitHub Stand updaten könnte + Upload, dann den on State ändert, sollte u. a. Send this info to developer geloggt werden. Bitte das JSON hier posten. Danke.
                    @WulfR Das mit den Plugs schaue ich mir heute Abend mal an.
                    sigi234S A 2 Antworten Letzte Antwort
                      sigi234S Online
                      sigi234S Online
                      @foxriver76 sagte in [Aufruf] Hue Adapter 2.0.0:
                      Nein, und wie das Json runterladen?
                      • sigi234S sigi234
                        foxriver76F Offline
                        foxriver76F Offline
                        foxriver76
                        @sigi234 ist nur ein Logeintrag
                          sigi234S Online
                          sigi234S Online
                          Ok, Adapter auf debug stellen?
                          • sigi234S sigi234
                            foxriver76F Offline
                            foxriver76F Offline
                            foxriver76
                            @sigi234 Ne wird auf warn geloggt, bsp von dem Daylight Sensor:
                            2019-10-17 15:40:59.059 - warn: hue.0 Send this info to developer: {"_rawData":{"state":{"daylight":null,"lastupdated":"none"},"config":{"on":true,"configured":false,"sunriseoffset":30,"sunsetoffset":-30},"name":"Daylight","type":"Daylight","modelid":"PHDL00","manufacturername":"Philips","swversion":"1.0"},"_id":1,"_type":"Daylight","_configAttributes":{"on":true,"configured":false,"sunriseoffset":30,"sunsetoffset":-30},"_stateAttributes":{"daylight":null,"lastupdated":"none"}}
                            2019-10-17 15:40:59.252 - warn: hue.0 lightQueue: job sensors.updateSensorState:Daylight
                            id: 1:a4673562807eb95955656f4ceefafe18 failed: Error: invalid value, null}, for parameter, daylight
                            2019-10-17 15:40:59.254 - warn: hue.0 lightQueue: retry [1/10] job sensors.updateSensorState:Daylight
                            2019-10-17 15:40:59.299 - warn: hue.0 lightQueue: job sensors.updateSensorState:Daylight
                            2019-10-17 15:40:59.300 - warn: hue.0 lightQueue: retry [2/10] job sensors.updateSensorState:Daylight
                            2019-10-17 15:40:59.344 - warn: hue.0 lightQueue: job sensors.updateSensorState:Daylight
                            2019-10-17 15:40:59.345 - warn: hue.0 lightQueue: retry [3/10] job sensors.updateSensorState:Daylight
                              Apropo
                              • Upload
                              Was meinst du mit + Upload?
                              Wenn ich auf den Github Stand update und den on State ändere kommt bei mir nur
                              hue.0	2019-10-17 16:41:47.872	error	lightQueue: job setLightState:undefined:d412f74df0a7913b2031e184eb96f7bd max retry reached: Api Error: The light id 'undefined' is not valid for this Hue Bridge.,
                              hue.0	2019-10-17 16:41:47.841	warn	lightQueue: retry [10/10] job setLightState:undefined:d412f74df0a7913b2031e184eb96f7bd
                              hue.0	2019-10-17 16:41:47.841	warn	lightQueue: job setLightState:undefined:d412f74df0a7913b2031e184eb96f7bd failed: Api Error: The light id 'undefined' is not valid for this Hue Bridge.,
                              hue.0	2019-10-17 16:41:47.814	warn	lightQueue: retry [9/10] job setLightState:undefined:d412f74df0a7913b2031e184eb96f7bd
                              hue.0	2019-10-17 16:41:47.813	warn	lightQueue: job setLightState:undefined:d412f74df0a7913b2031e184eb96f7bd failed: Api Error: The light id 'undefined' is not valid for this Hue Bridge.,
                              hue.0	2019-10-17 16:41:47.787	warn	lightQueue: retry [8/10] job setLightState:undefined:d412f74df0a7913b2031e184eb96f7bd
                              hue.0	2019-10-17 16:41:47.786	warn	lightQueue: job setLightState:undefined:d412f74df0a7913b2031e184eb96f7bd failed: Api Error: The light id 'undefined' is not valid for this Hue Bridge.,
                              hue.0	2019-10-17 16:41:47.759	warn	lightQueue: retry [7/10] job setLightState:undefined:d412f74df0a7913b2031e184eb96f7bd
                              hue.0	2019-10-17 16:41:47.758	warn	lightQueue: job setLightState:undefined:d412f74df0a7913b2031e184eb96f7bd failed: Api Error: The light id 'undefined' is not valid for this Hue Bridge.,
                              hue.0	2019-10-17 16:41:47.732	warn	lightQueue: retry [6/10] job setLightState:undefined:d412f74df0a7913b2031e184eb96f7bd
                              hue.0	2019-10-17 16:41:47.731	warn	lightQueue: job setLightState:undefined:d412f74df0a7913b2031e184eb96f7bd failed: Api Error: The light id 'undefined' is not valid for this Hue Bridge.,
                              hue.0	2019-10-17 16:41:47.705	warn	lightQueue: retry [5/10] job setLightState:undefined:d412f74df0a7913b2031e184eb96f7bd
                              hue.0	2019-10-17 16:41:47.704	warn	lightQueue: job setLightState:undefined:d412f74df0a7913b2031e184eb96f7bd failed: Api Error: The light id 'undefined' is not valid for this Hue Bridge.,
                              hue.0	2019-10-17 16:41:47.678	warn	lightQueue: retry [4/10] job setLightState:undefined:d412f74df0a7913b2031e184eb96f7bd
                              hue.0	2019-10-17 16:41:47.677	warn	lightQueue: job setLightState:undefined:d412f74df0a7913b2031e184eb96f7bd failed: Api Error: The light id 'undefined' is not valid for this Hue Bridge.,
                              hue.0	2019-10-17 16:41:47.650	warn	lightQueue: retry [3/10] job setLightState:undefined:d412f74df0a7913b2031e184eb96f7bd
                              hue.0	2019-10-17 16:41:47.650	warn	lightQueue: job setLightState:undefined:d412f74df0a7913b2031e184eb96f7bd failed: Api Error: The light id 'undefined' is not valid for this Hue Bridge.,
                              hue.0	2019-10-17 16:41:47.623	warn	lightQueue: retry [2/10] job setLightState:undefined:d412f74df0a7913b2031e184eb96f7bd
                              hue.0	2019-10-17 16:41:47.623	warn	lightQueue: job setLightState:undefined:d412f74df0a7913b2031e184eb96f7bd failed: Api Error: The light id 'undefined' is not valid for this Hue Bridge.,
                              hue.0	2019-10-17 16:41:47.596	warn	lightQueue: retry [1/10] job setLightState:undefined:d412f74df0a7913b2031e184eb96f7bd
                              hue.0	2019-10-17 16:41:47.595	warn	lightQueue: job setLightState:undefined:d412f74df0a7913b2031e184eb96f7bd failed: Api Error: The light id 'undefined' is not valid for this Hue Bridge.,
                              Nix mit Send this info ....
                              BBTownB 1 Antwort Letzte Antwort
                                sigi234S Online
                                sigi234S Online
                                @foxriver76
                                undefined2019-10-17 16:50:49.478 - warn: hue.0 (15000) Send this info to developer: {"_rawData":{"state":{"presence":false,"lastupdated":"2019-10-17T14:47:09"},"swupdate":{"state":"noupdates","lastinstall":"2019-03-11T13:39:24"},"config":{"on":true,"battery":100,"reachable":true,"alert":"none","ledindication":false,"usertest":false,"sensitivity":2,"sensitivitymax":2,"pending":[]},"name":"Küche Sensor","type":"ZLLPresence","modelid":"SML001","manufacturername":"Philips","productname":"Hue motion sensor","swversion":"6.1.1.27575","uniqueid":"00:17:88:01:03:29:d9:8a-02-0406","capabilities":{"certified":true,"primary":true}},"_id":13,"_type":"ZLLPresense","_configAttributes":{"on":true,"battery":100,"reachable":true,"alert":"none","ledindication":false,"usertest":false,"sensitivity":2,"sensitivitymax":2,"pending":[]},"_stateAttributes":{"presence":false,"lastupdated":"2019-10-17T14:47:09"}}
                                2019-10-17 16:50:49.495 - warn: hue.0 (15000) lightQueue: job sensors.updateSensorState:ZLLPresense
                                id: 13:130374a202d0bea0d2203edb099f01a3 failed: Error: parameter, presence, is not modifiable
                                2019-10-17 16:50:49.495 - warn: hue.0 (15000) lightQueue: retry [1/10] job sensors.updateSensorState:ZLLPresense
                                2019-10-17 16:50:49.531 - warn: hue.0 (15000) lightQueue: job sensors.updateSensorState:ZLLPresense
                                2019-10-17 16:50:49.531 - warn: hue.0 (15000) lightQueue: retry [2/10] job sensors.updateSensorState:ZLLPresense
                                2019-10-17 16:50:49.567 - warn: hue.0 (15000) lightQueue: job sensors.updateSensorState:ZLLPresense
                                2019-10-17 16:50:49.567 - warn: hue.0 (15000) lightQueue: retry [3/10] job sensors.updateSensorState:ZLLPresense
                                2019-10-17 16:50:49.603 - warn: hue.0 (15000) lightQueue: job sensors.updateSensorState:ZLLPresense
                                2019-10-17 16:50:49.603 - warn: hue.0 (15000) lightQueue: retry [4/10] job sensors.updateSensorState:ZLLPresense
                                2019-10-17 16:50:49.639 - warn: hue.0 (15000) lightQueue: job sensors.updateSensorState:ZLLPresense
                                2019-10-17 16:50:49.639 - warn: hue.0 (15000) lightQueue: retry [5/10] job sensors.updateSensorState:ZLLPresense
                                2019-10-17 16:50:49.673 - warn: hue.0 (15000) lightQueue: job sensors.updateSensorState:ZLLPresense
                                2019-10-17 16:50:49.673 - warn: hue.0 (15000) lightQueue: retry [6/10] job sensors.updateSensorState:ZLLPresense
                                2019-10-17 16:50:49.800 - warn: hue.0 (15000) lightQueue: job sensors.updateSensorState:ZLLPresense
                                2019-10-17 16:50:49.800 - warn: hue.0 (15000) lightQueue: retry [7/10] job sensors.updateSensorState:ZLLPresense
                                2019-10-17 16:50:49.836 - warn: hue.0 (15000) lightQueue: job sensors.updateSensorState:ZLLPresense
                                2019-10-17 16:50:49.836 - warn: hue.0 (15000) lightQueue: retry [8/10] job sensors.updateSensorState:ZLLPresense
                                2019-10-17 16:50:49.871 - warn: hue.0 (15000) lightQueue: job sensors.updateSensorState:ZLLPresense
                                2019-10-17 16:50:49.871 - warn: hue.0 (15000) lightQueue: retry [9/10] job sensors.updateSensorState:ZLLPresense
                                2019-10-17 16:50:49.906 - warn: hue.0 (15000) lightQueue: job sensors.updateSensorState:ZLLPresense
                                2019-10-17 16:50:49.906 - warn: hue.0 (15000) lightQueue: retry [10/10] job sensors.updateSensorState:ZLLPresense
                                2019-10-17 16:50:49.941 - error: hue.0 (15000) lightQueue: job sensors.updateSensorState:ZLLPresense
                                id: 13:130374a202d0bea0d2203edb099f01a3 max retry reached: Error: parameter, presence, is not modifiable
                                • A Apropo
                                  • Upload
                                  BBTownB Offline
                                  BBTownB Offline
                                  BBTown
                                  @Apropo sagte in [Aufruf] Hue Adapter 2.0.0:
                                  • lobomauL Offline
                                    lobomauL Offline
                                    lobomau
                                    schrieb am zuletzt editiert von lobomau
                                    Edit: Version 2.1.0 will auch nicht mehr. Hier funktioniert die Funktion neuen User suchen nicht mehr.
                                    Edit2: Version 2.0.0 funktioniert wieder.
                                    Hab geupdatet von 2.0.0. auf 2.2.0.
                                    Wird die alte Bridge (rund) noch unterstützt?
                                    Bekomme sie nicht ans laufen. Upload habe ich durchgeführt, aber es geht auch nicht mehr neuen User anlegen. Oder braucht man keinen User mehr?
                                    Hier paar Schaltversuche:
                                    hue.0	2019-10-17 20:44:04.555	error	(10799) lightQueue: job lights.setLightState:undefined:7a25cdc9d1d22373ca942eaa676f382b max retry reached: TypeError: Cannot read property 'lights' of undefined
                                    hue.0	2019-10-17 20:44:04.529	warn	(10799) lightQueue: retry [10/10] job lights.setLightState:undefined:7a25cdc9d1d22373ca942eaa676f382b
                                    hue.0	2019-10-17 20:44:04.528	warn	(10799) lightQueue: job lights.setLightState:undefined:7a25cdc9d1d22373ca942eaa676f382b failed: TypeError: Cannot read property 'lights' of undefined
                                    hue.0	2019-10-17 20:44:04.501	warn	(10799) lightQueue: retry [9/10] job lights.setLightState:undefined:7a25cdc9d1d22373ca942eaa676f382b
                                    hue.0	2019-10-17 20:44:04.500	warn	(10799) lightQueue: job lights.setLightState:undefined:7a25cdc9d1d22373ca942eaa676f382b failed: TypeError: Cannot read property 'lights' of undefined
                                    hue.0	2019-10-17 20:44:04.474	warn	(10799) lightQueue: retry [8/10] job lights.setLightState:undefined:7a25cdc9d1d22373ca942eaa676f382b
                                    hue.0	2019-10-17 20:44:04.474	warn	(10799) lightQueue: job lights.setLightState:undefined:7a25cdc9d1d22373ca942eaa676f382b failed: TypeError: Cannot read property 'lights' of undefined
                                    hue.0	2019-10-17 20:44:04.447	warn	(10799) lightQueue: retry [7/10] job lights.setLightState:undefined:7a25cdc9d1d22373ca942eaa676f382b
                                    hue.0	2019-10-17 20:44:04.447	warn	(10799) lightQueue: job lights.setLightState:undefined:7a25cdc9d1d22373ca942eaa676f382b failed: TypeError: Cannot read property 'lights' of undefined
                                    hue.0	2019-10-17 20:44:04.420	warn	(10799) lightQueue: retry [6/10] job lights.setLightState:undefined:7a25cdc9d1d22373ca942eaa676f382b
                                    hue.0	2019-10-17 20:44:04.420	warn	(10799) lightQueue: job lights.setLightState:undefined:7a25cdc9d1d22373ca942eaa676f382b failed: TypeError: Cannot read property 'lights' of undefined
                                    hue.0	2019-10-17 20:44:04.392	warn	(10799) lightQueue: retry [5/10] job lights.setLightState:undefined:7a25cdc9d1d22373ca942eaa676f382b
                                    hue.0	2019-10-17 20:44:04.392	warn	(10799) lightQueue: job lights.setLightState:undefined:7a25cdc9d1d22373ca942eaa676f382b failed: TypeError: Cannot read property 'lights' of undefined
                                    hue.0	2019-10-17 20:44:04.365	warn	(10799) lightQueue: retry [4/10] job lights.setLightState:undefined:7a25cdc9d1d22373ca942eaa676f382b
                                    hue.0	2019-10-17 20:44:04.365	warn	(10799) lightQueue: job lights.setLightState:undefined:7a25cdc9d1d22373ca942eaa676f382b failed: TypeError: Cannot read property 'lights' of undefined
                                    hue.0	2019-10-17 20:44:04.338	warn	(10799) lightQueue: retry [3/10] job lights.setLightState:undefined:7a25cdc9d1d22373ca942eaa676f382b
                                    hue.0	2019-10-17 20:44:04.337	warn	(10799) lightQueue: job lights.setLightState:undefined:7a25cdc9d1d22373ca942eaa676f382b failed: TypeError: Cannot read property 'lights' of undefined
                                    hue.0	2019-10-17 20:44:04.310	warn	(10799) lightQueue: retry [2/10] job lights.setLightState:undefined:7a25cdc9d1d22373ca942eaa676f382b
                                    hue.0	2019-10-17 20:44:04.309	warn	(10799) lightQueue: job lights.setLightState:undefined:7a25cdc9d1d22373ca942eaa676f382b failed: TypeError: Cannot read property 'lights' of undefined
                                    hue.0	2019-10-17 20:44:04.282	warn	(10799) lightQueue: retry [1/10] job lights.setLightState:undefined:7a25cdc9d1d22373ca942eaa676f382b
                                    hue.0	2019-10-17 20:44:04.281	warn	(10799) lightQueue: job lights.setLightState:undefined:7a25cdc9d1d22373ca942eaa676f382b failed: TypeError: Cannot read property 'lights' of undefined
                                    hue.0	2019-10-17 20:43:25.776	error	(10799) groupQueue: job groups.setGroupState:undefined:54ec10399cacd34164392f8c7ac69398 max retry reached: TypeError: Cannot read property 'groups' of undefined
                                    hue.0	2019-10-17 20:43:25.745	warn	(10799) groupQueue: retry [10/10] job groups.setGroupState:undefined:54ec10399cacd34164392f8c7ac69398
                                    hue.0	2019-10-17 20:43:25.744	warn	(10799) groupQueue: job groups.setGroupState:undefined:54ec10399cacd34164392f8c7ac69398 failed: TypeError: Cannot read property 'groups' of undefined
                                    hue.0	2019-10-17 20:43:25.718	warn	(10799) groupQueue: retry [9/10] job groups.setGroupState:undefined:54ec10399cacd34164392f8c7ac69398
                                    hue.0	2019-10-17 20:43:25.717	warn	(10799) groupQueue: job groups.setGroupState:undefined:54ec10399cacd34164392f8c7ac69398 failed: TypeError: Cannot read property 'groups' of undefined
                                    hue.0	2019-10-17 20:43:25.690	warn	(10799) groupQueue: retry [8/10] job groups.setGroupState:undefined:54ec10399cacd34164392f8c7ac69398
                                    hue.0	2019-10-17 20:43:25.689	warn	(10799) groupQueue: job groups.setGroupState:undefined:54ec10399cacd34164392f8c7ac69398 failed: TypeError: Cannot read property 'groups' of undefined
                                    hue.0	2019-10-17 20:43:25.663	warn	(10799) groupQueue: retry [7/10] job groups.setGroupState:undefined:54ec10399cacd34164392f8c7ac69398
                                    hue.0	2019-10-17 20:43:25.661	warn	(10799) groupQueue: job groups.setGroupState:undefined:54ec10399cacd34164392f8c7ac69398 failed: TypeError: Cannot read property 'groups' of undefined
                                    hue.0	2019-10-17 20:43:25.635	warn	(10799) groupQueue: retry [6/10] job groups.setGroupState:undefined:54ec10399cacd34164392f8c7ac69398
                                    hue.0	2019-10-17 20:43:25.634	warn	(10799) groupQueue: job groups.setGroupState:undefined:54ec10399cacd34164392f8c7ac69398 failed: TypeError: Cannot read property 'groups' of undefined
                                    hue.0	2019-10-17 20:43:25.608	warn	(10799) groupQueue: retry [5/10] job groups.setGroupState:undefined:54ec10399cacd34164392f8c7ac69398
                                    hue.0	2019-10-17 20:43:25.607	warn	(10799) groupQueue: job groups.setGroupState:undefined:54ec10399cacd34164392f8c7ac69398 failed: TypeError: Cannot read property 'groups' of undefined
                                    hue.0	2019-10-17 20:43:25.581	warn	(10799) groupQueue: retry [4/10] job groups.setGroupState:undefined:54ec10399cacd34164392f8c7ac69398
                                    hue.0	2019-10-17 20:43:25.580	warn	(10799) groupQueue: job groups.setGroupState:undefined:54ec10399cacd34164392f8c7ac69398 failed: TypeError: Cannot read property 'groups' of undefined
                                    hue.0	2019-10-17 20:43:25.548	warn	(10799) groupQueue: retry [3/10] job groups.setGroupState:undefined:54ec10399cacd34164392f8c7ac69398
                                    hue.0	2019-10-17 20:43:25.547	warn	(10799) groupQueue: job groups.setGroupState:undefined:54ec10399cacd34164392f8c7ac69398 failed: TypeError: Cannot read property 'groups' of undefined
                                    hue.0	2019-10-17 20:43:25.521	warn	(10799) groupQueue: retry [2/10] job groups.setGroupState:undefined:54ec10399cacd34164392f8c7ac69398
                                    hue.0	2019-10-17 20:43:25.520	warn	(10799) groupQueue: job groups.setGroupState:undefined:54ec10399cacd34164392f8c7ac69398 failed: TypeError: Cannot read property 'groups' of undefined
                                    hue.0	2019-10-17 20:43:25.493	warn	(10799) groupQueue: retry [1/10] job groups.setGroupState:undefined:54ec10399cacd34164392f8c7ac69398
                                    hue.0	2019-10-17 20:43:25.492	warn	(10799) groupQueue: job groups.setGroupState:undefined:54ec10399cacd34164392f8c7ac69398 failed: TypeError: Cannot read property 'groups' of undefined
                                    hue.0	2019-10-17 20:43:02.660	error	(10799) lightQueue: job lights.setLightState:undefined:a1638518de9b20e67f3e0e24e0f31721 max retry reached: TypeError: Cannot read property 'lights' of undefined
                                    hue.0	2019-10-17 20:43:02.634	warn	(10799) lightQueue: retry [10/10] job lights.setLightState:undefined:a1638518de9b20e67f3e0e24e0f31721
                                    hue.0	2019-10-17 20:43:02.633	warn	(10799) lightQueue: job lights.setLightState:undefined:a1638518de9b20e67f3e0e24e0f31721 failed: TypeError: Cannot read property 'lights' of undefined
                                    hue.0	2019-10-17 20:43:02.607	warn	(10799) lightQueue: retry [9/10] job lights.setLightState:undefined:a1638518de9b20e67f3e0e24e0f31721
                                    hue.0	2019-10-17 20:43:02.606	warn	(10799) lightQueue: job lights.setLightState:undefined:a1638518de9b20e67f3e0e24e0f31721 failed: TypeError: Cannot read property 'lights' of undefined
                                    hue.0	2019-10-17 20:43:02.580	warn	(10799) lightQueue: retry [8/10] job lights.setLightState:undefined:a1638518de9b20e67f3e0e24e0f31721
                                    hue.0	2019-10-17 20:43:02.579	warn	(10799) lightQueue: job lights.setLightState:undefined:a1638518de9b20e67f3e0e24e0f31721 failed: TypeError: Cannot read property 'lights' of undefined
                                    hue.0	2019-10-17 20:43:02.552	warn	(10799) lightQueue: retry [7/10] job lights.setLightState:undefined:a1638518de9b20e67f3e0e24e0f31721
                                    hue.0	2019-10-17 20:43:02.551	warn	(10799) lightQueue: job lights.setLightState:undefined:a1638518de9b20e67f3e0e24e0f31721 failed: TypeError: Cannot read property 'lights' of undefined
                                    hue.0	2019-10-17 20:43:02.525	warn	(10799) lightQueue: retry [6/10] job lights.setLightState:undefined:a1638518de9b20e67f3e0e24e0f31721
                                    hue.0	2019-10-17 20:43:02.524	warn	(10799) lightQueue: job lights.setLightState:undefined:a1638518de9b20e67f3e0e24e0f31721 failed: TypeError: Cannot read property 'lights' of undefined
                                    hue.0	2019-10-17 20:43:02.497	warn	(10799) lightQueue: retry [5/10] job lights.setLightState:undefined:a1638518de9b20e67f3e0e24e0f31721
                                    hue.0	2019-10-17 20:43:02.496	warn	(10799) lightQueue: job lights.setLightState:undefined:a1638518de9b20e67f3e0e24e0f31721 failed: TypeError: Cannot read property 'lights' of undefined
                                    hue.0	2019-10-17 20:43:02.470	warn	(10799) lightQueue: retry [4/10] job lights.setLightState:undefined:a1638518de9b20e67f3e0e24e0f31721
                                    hue.0	2019-10-17 20:43:02.469	warn	(10799) lightQueue: job lights.setLightState:undefined:a1638518de9b20e67f3e0e24e0f31721 failed: TypeError: Cannot read property 'lights' of undefined
                                    hue.0	2019-10-17 20:43:02.443	warn	(10799) lightQueue: retry [3/10] job lights.setLightState:undefined:a1638518de9b20e67f3e0e24e0f31721
                                    hue.0	2019-10-17 20:43:02.442	warn	(10799) lightQueue: job lights.setLightState:undefined:a1638518de9b20e67f3e0e24e0f31721 failed: TypeError: Cannot read property 'lights' of undefined
                                    hue.0	2019-10-17 20:43:02.416	warn	(10799) lightQueue: retry [2/10] job lights.setLightState:undefined:a1638518de9b20e67f3e0e24e0f31721
                                    hue.0	2019-10-17 20:43:02.415	warn	(10799) lightQueue: job lights.setLightState:undefined:a1638518de9b20e67f3e0e24e0f31721 failed: TypeError: Cannot read property 'lights' of undefined
                                    hue.0	2019-10-17 20:43:02.388	warn	(10799) lightQueue: retry [1/10] job lights.setLightState:undefined:a1638518de9b20e67f3e0e24e0f31721
                                    hue.0	2019-10-17 20:43:02.388	warn	(10799) lightQueue: job lights.setLightState:undefined:a1638518de9b20e67f3e0e24e0f31721 failed: TypeError: Cannot read property 'lights' of undefined
                                    Host: NUC8i3 mit Proxmox:
                                    • Slave: Pi4
                                    • BBTownB BBTown
                                      Apropo
                                      @BBTown Ahhh, super danke dir!
                                      • A Apropo
                                        foxriver76F Offline
                                        foxriver76F Offline
                                        foxriver76
                                        @Apropo 2.2.1 auf npm:
                                        • Osram Plug sollte nun wieder laufen (musste vom node-hue-api Entwickler in v3 noch integriert werden)
                                        • Bei der Nutzererstellung wurde statt dem Nutzernamen ein Objekt zurückgegeben -> ist gefixt
                                        • Sensor schalten geht vermutlich noch nicht
                                        • lobomauL lobomau
                                          foxriver76F Offline
                                          foxriver76F Offline
                                          foxriver76
                                          @lobomau Puh, weiß tatsächlich nicht ob der Support für die runde (v1) Bridge im npm Modul entfernt wurde. Im Changelog wird nichts erwähnt.
