  4. TR-64 Adapter soef Installation Probleme
tr64 community adapter
4 Beiträge 3 Kommentatoren 787 Aufrufe 2 Beobachtet
  • L Offline
    Lordcyber
    HAllo,
    ichhabe eben diesen Adapter von Gifthub installiert.
    Aber er startet nicht.
    Im Log steht:
    host.IoBroker	2019-09-05 19:07:56.240	info	Restart adapter system.adapter.tr-064.0 because enabled
    host.IoBroker	2019-09-05 19:07:56.239	error	instance system.adapter.tr-064.0 terminated with code 1 ()
    host.IoBroker	2019-09-05 19:07:56.239	error	Caught by controller[0]: at bootstrapNodeJSCore (internal/bootstrap/node.js:622:3)
    host.IoBroker	2019-09-05 19:07:56.239	error	Caught by controller[0]: at startup (internal/bootstrap/node.js:283:19)
    host.IoBroker	2019-09-05 19:07:56.239	error	Caught by controller[0]: at Function.Module.runMain (internal/modules/cjs/loader.js:831:12)
    host.IoBroker	2019-09-05 19:07:56.239	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:585:3)
    host.IoBroker	2019-09-05 19:07:56.239	error	Caught by controller[0]: at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
    host.IoBroker	2019-09-05 19:07:56.239	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:653:32)
    host.IoBroker	2019-09-05 19:07:56.239	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10)
    host.IoBroker	2019-09-05 19:07:56.239	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:778:30)
    host.IoBroker	2019-09-05 19:07:56.239	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.tr-064/tr-064.js:16:20)
    host.IoBroker	2019-09-05 19:07:56.239	error	Caught by controller[0]: at Object.exports.Adapter (/opt/iobroker/node_modules/soef/soef.js:1383:23)
    host.IoBroker	2019-09-05 19:07:56.239	error	Caught by controller[0]: TypeError: fns.adapter is not a function
    host.IoBroker	2019-09-05 19:07:56.239	error	Caught by controller[0]: ^
    host.IoBroker	2019-09-05 19:07:56.239	error	Caught by controller[0]: fns.adapter = fns.adapter(options);
    host.IoBroker	2019-09-05 19:07:56.238	error	Caught by controller[0]: /opt/iobroker/node_modules/soef/soef.js:1383
    host.IoBroker	2019-09-05 19:07:55.829	info	instance system.adapter.tr-064.0 started with pid 9987
    host.IoBroker	2019-09-05 19:07:25.824	info	Restart adapter system.adapter.tr-064.0 because enabled
    host.IoBroker	2019-09-05 19:07:25.824	error	instance system.adapter.tr-064.0 terminated with code 1 ()
    Caught	2019-09-05 19:07:25.824	error	by controller[0]: at bootstrapNodeJSCore (internal/bootstrap/node.js:622:3)
    Caught	2019-09-05 19:07:25.824	error	by controller[0]: at startup (internal/bootstrap/node.js:283:19)
    Caught	2019-09-05 19:07:25.824	error	by controller[0]: at Function.Module.runMain (internal/modules/cjs/loader.js:831:12)
    Caught	2019-09-05 19:07:25.824	error	by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:585:3)
    Caught	2019-09-05 19:07:25.824	error	by controller[0]: at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
    Caught	2019-09-05 19:07:25.824	error	by controller[0]: at Module.load (internal/modules/cjs/loader.js:653:32)
    Caught	2019-09-05 19:07:25.824	error	by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10)
    Caught	2019-09-05 19:07:25.823	error	by controller[0]: at Module._compile (internal/modules/cjs/loader.js:778:30)
    Caught	2019-09-05 19:07:25.823	error	by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.tr-064/tr-064.js:16:20)
    Caught	2019-09-05 19:07:25.823	error	by controller[0]: at Object.exports.Adapter (/opt/iobroker/node_modules/soef/soef.js:1383:23)
    Caught	2019-09-05 19:07:25.823	error	by controller[0]: TypeError: fns.adapter is not a function
    Caught	2019-09-05 19:07:25.823	error	by controller[0]: ^
    Caught	2019-09-05 19:07:25.823	error	by controller[0]: fns.adapter = fns.adapter(options);
    Caught	2019-09-05 19:07:25.822	error	by controller[0]: /opt/iobroker/node_modules/soef/soef.js:1383
    Was muss ich machen das der läuft?
    Mike
    Thinkcentre M92 mit Proxmox / Iobroker als VM unter Debian
    • L Lordcyber
      HAllo,
      Im Log steht:
      sigi234S Online
      sigi234S Online
      @Lordcyber
      Nimm den :
      https://forum.iobroker.net/topic/22782/aufruf-test-community-version-vom-tr-064-adapter
      Oder:
      cd /opt/iobroker/
      iobroker stop tr-064
      cd /opt/iobroker/node_modules/iobroker.tr-064
      npm install soef
      • Harald SchröderH Offline
        Harald Schröder
        Danke das Installieren vom soef hat bei mir das Problem beseitigt.
        Ich habe das "oder" durchgeführt.
        • Harald SchröderH Harald Schröder
          sigi234S Online
          sigi234S Online
          @Harald-Schröder
          Wenn ein Thema gelöst wurde bitte den Beitrag der die Lösung beinhaltet als gelöst Markieren. -> 3 Punkte Menü rechts unten am Beitrag -> Mark this post as the correct answer
          Und im [gelöst]..........TITEL auch. Danke
