<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[TR-64 Adapter soef Installation Probleme]]></title><description><![CDATA[<p dir="auto">HAllo,<br />
ichhabe eben diesen Adapter von Gifthub installiert.<br />
Aber er startet nicht.<br />
Im Log steht:</p>
<pre><code>host.IoBroker	2019-09-05 19:07:56.240	info	Restart adapter system.adapter.tr-064.0 because enabled
host.IoBroker	2019-09-05 19:07:56.239	error	instance system.adapter.tr-064.0 terminated with code 1 ()
host.IoBroker	2019-09-05 19:07:56.239	error	Caught by controller[0]: at bootstrapNodeJSCore (internal/bootstrap/node.js:622:3)
host.IoBroker	2019-09-05 19:07:56.239	error	Caught by controller[0]: at startup (internal/bootstrap/node.js:283:19)
host.IoBroker	2019-09-05 19:07:56.239	error	Caught by controller[0]: at Function.Module.runMain (internal/modules/cjs/loader.js:831:12)
host.IoBroker	2019-09-05 19:07:56.239	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:585:3)
host.IoBroker	2019-09-05 19:07:56.239	error	Caught by controller[0]: at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
host.IoBroker	2019-09-05 19:07:56.239	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:653:32)
host.IoBroker	2019-09-05 19:07:56.239	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10)
host.IoBroker	2019-09-05 19:07:56.239	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:778:30)
host.IoBroker	2019-09-05 19:07:56.239	error	Caught by controller[0]: at Object.&lt;anonymous&gt; (/opt/iobroker/node_modules/iobroker.tr-064/tr-064.js:16:20)
host.IoBroker	2019-09-05 19:07:56.239	error	Caught by controller[0]: at Object.exports.Adapter (/opt/iobroker/node_modules/soef/soef.js:1383:23)
host.IoBroker	2019-09-05 19:07:56.239	error	Caught by controller[0]: TypeError: fns.adapter is not a function
host.IoBroker	2019-09-05 19:07:56.239	error	Caught by controller[0]: ^
host.IoBroker	2019-09-05 19:07:56.239	error	Caught by controller[0]: fns.adapter = fns.adapter(options);
host.IoBroker	2019-09-05 19:07:56.238	error	Caught by controller[0]: /opt/iobroker/node_modules/soef/soef.js:1383
host.IoBroker	2019-09-05 19:07:55.829	info	instance system.adapter.tr-064.0 started with pid 9987
host.IoBroker	2019-09-05 19:07:25.824	info	Restart adapter system.adapter.tr-064.0 because enabled
host.IoBroker	2019-09-05 19:07:25.824	error	instance system.adapter.tr-064.0 terminated with code 1 ()
Caught	2019-09-05 19:07:25.824	error	by controller[0]: at bootstrapNodeJSCore (internal/bootstrap/node.js:622:3)
Caught	2019-09-05 19:07:25.824	error	by controller[0]: at startup (internal/bootstrap/node.js:283:19)
Caught	2019-09-05 19:07:25.824	error	by controller[0]: at Function.Module.runMain (internal/modules/cjs/loader.js:831:12)
Caught	2019-09-05 19:07:25.824	error	by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:585:3)
Caught	2019-09-05 19:07:25.824	error	by controller[0]: at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
Caught	2019-09-05 19:07:25.824	error	by controller[0]: at Module.load (internal/modules/cjs/loader.js:653:32)
Caught	2019-09-05 19:07:25.824	error	by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10)
Caught	2019-09-05 19:07:25.823	error	by controller[0]: at Module._compile (internal/modules/cjs/loader.js:778:30)
Caught	2019-09-05 19:07:25.823	error	by controller[0]: at Object.&lt;anonymous&gt; (/opt/iobroker/node_modules/iobroker.tr-064/tr-064.js:16:20)
Caught	2019-09-05 19:07:25.823	error	by controller[0]: at Object.exports.Adapter (/opt/iobroker/node_modules/soef/soef.js:1383:23)
Caught	2019-09-05 19:07:25.823	error	by controller[0]: TypeError: fns.adapter is not a function
Caught	2019-09-05 19:07:25.823	error	by controller[0]: ^
Caught	2019-09-05 19:07:25.823	error	by controller[0]: fns.adapter = fns.adapter(options);
Caught	2019-09-05 19:07:25.822	error	by controller[0]: /opt/iobroker/node_modules/soef/soef.js:1383
</code></pre>
<p dir="auto">Was muss ich machen das der läuft?<br />
Danke</p>
]]></description><link>https://forum.iobroker.net/topic/24894/tr-64-adapter-soef-installation-probleme</link><generator>RSS for Node</generator><lastBuildDate>Sun, 26 Apr 2026 07:09:09 GMT</lastBuildDate><atom:link href="https://forum.iobroker.net/topic/24894.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 05 Sep 2019 17:10:53 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to TR-64 Adapter soef Installation Probleme on Tue, 15 Oct 2019 19:52:25 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/harald-schr%C3%B6der" aria-label="Profile: Harald-Schröder">@<bdi>Harald-Schröder</bdi></a></p>
<p dir="auto">Wenn ein Thema gelöst wurde bitte den Beitrag der die Lösung beinhaltet als gelöst Markieren. <span style="color:#2b00ff">-&gt; 3 Punkte Menü rechts unten am Beitrag -&gt; Mark this post as the correct answer</span></p>
<p dir="auto">Und im  [gelöst]..........TITEL auch. Danke</p>
]]></description><link>https://forum.iobroker.net/post/311648</link><guid isPermaLink="true">https://forum.iobroker.net/post/311648</guid><dc:creator><![CDATA[sigi234]]></dc:creator><pubDate>Tue, 15 Oct 2019 19:52:25 GMT</pubDate></item><item><title><![CDATA[Reply to TR-64 Adapter soef Installation Probleme on Tue, 15 Oct 2019 18:39:16 GMT]]></title><description><![CDATA[<p dir="auto">Danke das Installieren vom soef hat bei mir das Problem beseitigt.<br />
Ich habe das "oder" durchgeführt.</p>
]]></description><link>https://forum.iobroker.net/post/311565</link><guid isPermaLink="true">https://forum.iobroker.net/post/311565</guid><dc:creator><![CDATA[Harald Schröder]]></dc:creator><pubDate>Tue, 15 Oct 2019 18:39:16 GMT</pubDate></item><item><title><![CDATA[Reply to TR-64 Adapter soef Installation Probleme on Thu, 05 Sep 2019 18:12:24 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/lordcyber" aria-label="Profile: Lordcyber">@<bdi>Lordcyber</bdi></a></p>
<p dir="auto">Nimm den :</p>
<p dir="auto"><a href="https://forum.iobroker.net/topic/22782/aufruf-test-community-version-vom-tr-064-adapter">https://forum.iobroker.net/topic/22782/aufruf-test-community-version-vom-tr-064-adapter</a></p>
<p dir="auto">Oder:</p>
<p dir="auto">cd /opt/iobroker/<br />
iobroker stop tr-064<br />
cd /opt/iobroker/node_modules/iobroker.tr-064<br />
npm install soef</p>
]]></description><link>https://forum.iobroker.net/post/297395</link><guid isPermaLink="true">https://forum.iobroker.net/post/297395</guid><dc:creator><![CDATA[sigi234]]></dc:creator><pubDate>Thu, 05 Sep 2019 18:12:24 GMT</pubDate></item></channel></rss>
