  4. Beim Installieren von Zigbee Adapter abgestürzt!!!
zigbee adapter
34 Beiträge 4 Kommentatoren 1.8k Aufrufe 2 Beobachtet
  • J jwedenig
    root@raspberrypi:~# cd /opt
    root@raspberrypi:/opt# curl -sL https://iobroker.net/install.sh | bash -
        Welcome to the ioBroker installer!
        Installer version: 2019-07-21
        You might need to enter your password a couple of times.
        Installing prerequisites (1/4)
        Creating ioBroker user and directory (2/4)
    Directory /opt/iobroker created
        Installing ioBroker (3/4)
    In file included from ../src/main.cpp:3:
    ../../nan/nan.h: In function ‘void Nan::AsyncQueueWorker(Nan::AsyncWorker*)’:
    ../../nan/nan.h:2298:62: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka void (*)(uv_work_s*, int)’} [-Wcast-function-type]
         , reinterpret_cast<uv_after_work_cb>(AsyncExecuteComplete)
    In file included from ../../nan/nan.h:54,
    ../src/main.cpp: At global scope:
    /root/.node-gyp/10.16.3/include/node/node.h:573:43: warning: cast between incompatible function types from ‘void (*)(v8::Local<v8::Object>)’ to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]
           (node::addon_register_func) (regfunc),                          \
    /root/.node-gyp/10.16.3/include/node/node.h:607:3: note: in expansion of macro NODE_MODULE_X’
       NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)
    ../src/main.cpp:42:1: note: in expansion of macro ‘NODE_MODULE’
     NODE_MODULE(diskusage, Init)
    In file included from /root/.node-gyp/10.16.3/include/node/node.h:63,
    /root/.node-gyp/10.16.3/include/node/v8.h: In instantiation of ‘void v8::PersistentBase<T>::SetWeak(P*, typename v8::WeakCallbackInfo<P>::Callback, v8::WeakCallbackType) [with P = node::ObjectWrap; T = v8::Object; typename v8::WeakCallbackInfo<P>::Callback = void (*)(const v8::WeakCallbackInfo<node::ObjectWrap>&)]’:
    /root/.node-gyp/10.16.3/include/node/node_object_wrap.h:84:78:   required from here
    /root/.node-gyp/10.16.3/include/node/v8.h:9502:16: warning: cast between incompatible function types from ‘v8::WeakCallbackInfo<node::ObjectWrap>::Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<node::ObjectWrap>&)’} to ‘Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<void>&)’} [-Wcast-function-type]
                    reinterpret_cast<Callback>(callback), type);
    /root/.node-gyp/10.16.3/include/node/v8.h: In instantiation of ‘void v8::PersistentBase<T>::SetWeak(P*, typename v8::WeakCallbackInfo<P>::Callback, v8::WeakCallbackType) [with P = Nan::ObjectWrap; T = v8::Object; typename v8::WeakCallbackInfo<P>::Callback = void (*)(const v8::WeakCallbackInfo<Nan::ObjectWrap>&)]’:
    ../../nan/nan_object_wrap.h:65:61:   required from here
    /root/.node-gyp/10.16.3/include/node/v8.h:9502:16: warning: cast between incompatible function types from ‘v8::WeakCallbackInfo<Nan::ObjectWrap>::Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<Nan::ObjectWrap>&)’} to ‘Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<void>&)’} [-Wcast-function-type]
    In file included from ../src/./serialport.h:6,
                     from ../src/serialport.cpp:1:
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Open(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/serialport.cpp:41:49: warning: ‘v8::String::Utf8Value::Utf8Value(v8::Local<v8::Value>)’ is deprecated: Use Isolate version [-Wdeprecated-declarations]
       v8::String::Utf8Value path(info[0]->ToString());
    In file included from /root/.node-gyp/10.16.3/include/node/v8.h:26,
    /root/.node-gyp/10.16.3/include/node/v8.h:2892:28: note: declared here
                       explicit Utf8Value(Local<v8::Value> obj));
    /root/.node-gyp/10.16.3/include/node/v8config.h:324:3: note: in definition of macro ‘V8_DEPRECATED’
       declarator __attribute__((deprecated(message)))
    ../src/serialport.cpp:48:53: warning: ‘v8::Local<v8::Object> v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
       v8::Local<v8::Object> options = info[1]->ToObject();
    /root/.node-gyp/10.16.3/include/node/v8.h:10046:15: note: declared here
     Local<Object> Value::ToObject() const {
    ../src/serialport.cpp:78:69: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
       uv_queue_work(uv_default_loop(), req, EIO_Open, (uv_after_work_cb)EIO_AfterOpen);
    ../src/serialport.cpp: In function ‘void EIO_AfterOpen(uv_work_t*)’:
    ../src/serialport.cpp:95:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
       data->callback.Call(2, argv);
    ../../nan/nan.h:1740:3: note: declared here
       Call(int argc, v8::Local<v8::Value> argv[]) const {
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Update(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/serialport.cpp:113:53: warning: ‘v8::Local<v8::Object> v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
    ../src/serialport.cpp:135:71: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
       uv_queue_work(uv_default_loop(), req, EIO_Update, (uv_after_work_cb)EIO_AfterUpdate);
    ../src/serialport.cpp: In function ‘void EIO_AfterUpdate(uv_work_t*)’:
    ../src/serialport.cpp:150:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
       data->callback.Call(1, argv);
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Close(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/serialport.cpp:175:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
       uv_queue_work(uv_default_loop(), req, EIO_Close, (uv_after_work_cb)EIO_AfterClose);
    ../src/serialport.cpp: In function ‘void EIO_AfterClose(uv_work_t*)’:
    ../src/serialport.cpp:188:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Flush(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/serialport.cpp:215:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
       uv_queue_work(uv_default_loop(), req, EIO_Flush, (uv_after_work_cb)EIO_AfterFlush);
    ../src/serialport.cpp: In function ‘void EIO_AfterFlush(uv_work_t*)’:
    ../src/serialport.cpp:231:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Set(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/serialport.cpp:250:53: warning: ‘v8::Local<v8::Object> v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
    ../src/serialport.cpp:270:68: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
       uv_queue_work(uv_default_loop(), req, EIO_Set, (uv_after_work_cb)EIO_AfterSe);
    ../src/serialport.cpp: In function ‘void EIO_AfterSet(uv_work_t*)’:
    ../src/serialport.cpp:285:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Get(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/serialport.cpp:314:68: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
       uv_queue_work(uv_default_loop(), req, EIO_Get, (uv_after_work_cb)EIO_AfterGe);
    ../src/serialport.cpp: In function ‘void EIO_AfterGet(uv_work_t*)’:
    ../src/serialport.cpp:336:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE GetBaudRate(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/serialport.cpp:363:76: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
       uv_queue_work(uv_default_loop(), req, EIO_GetBaudRate, (uv_after_work_cb)EIO_AfterGetBaudRate);
    ../src/serialport.cpp: In function ‘void EIO_AfterGetBaudRate(uv_work_t*)’:
    ../src/serialport.cpp:383:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Drain(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/serialport.cpp:409:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
       uv_queue_work(uv_default_loop(), req, EIO_Drain, (uv_after_work_cb)EIO_AfterDrain);
    ../src/serialport.cpp: In function ‘void EIO_AfterDrain(uv_work_t*)’:
    ../src/serialport.cpp:424:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
    ../src/serialport.cpp: At global scope:
    ../src/serialport.cpp:430:28: warning: unnecessary parentheses in declaration of ‘ToParityEnum’ [-Wparentheses]
     SerialPortParity NAN_INLINE(ToParityEnum(const v8::Local<v8::String>& v8str)) {
    ../src/serialport.cpp:449:30: warning: unnecessary parentheses in declaration of ‘ToStopBitEnum’ [-Wparentheses]
     SerialPortStopBits NAN_INLINE(ToStopBitEnum(double stopBits)) {
    /root/.node-gyp/10.16.3/include/node/node.h:573:43: warning: cast between incompatible function types from ‘void (*)(v8::Handle<v8::Object>)’ {aka ‘void (*)(v8::Local<v8::Object>)’} to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]
    ../src/serialport.cpp:485:1: note: in expansion of macro ‘NODE_MODULE’
     NODE_MODULE(serialport, init);
    In file included from ../src/serialport.h:6,
                     from ../src/serialport_unix.cpp:2:
    ../src/serialport_unix.cpp: In function ‘int setup(int, OpenBaton*)’:
    ../src/serialport_unix.cpp:176:60: warning: ‘%s’ directive output may be truncated writing up to 1023 bytes into a region of size 1005 [-Wformat-truncation=]
         snprintf(data->errorString, sizeof(data->errorString), "Error %s Cannot open %s", strerror(errno), data->path);
    ../src/serialport_unix.cpp:176:13: note: ‘snprintf’ output 20 or more bytes (assuming 1043) into a destination of size 1024
    ../src/serialport_unix.cpp: In function ‘void EIO_Open(uv_work_t*)’:
    ../src/serialport_unix.cpp:86:60: warning: ‘%s’ directive output may be truncated writing up to 1023 bytes into a region of size 1003 [-Wformat-truncation=]
         snprintf(data->errorString, sizeof(data->errorString), "Error: %s, cannot open %s", strerror(errno), data->path);
    ../src/serialport_unix.cpp:86:13: note: ‘snprintf’ output 22 or more bytes (assuming 1045) into a destination of size 1024
    In file included from ../src/poller.cpp:1:
    ../src/poller.cpp: In static member function ‘static void Poller::onData(uv_poll_t*, int, int)’:
    ../src/poller.cpp:69:29: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
       obj->callback.Call(2, argv);
        Finalizing installation (4/4)
    Enabling autostart...
    Autostart enabled!
        ioBroker was installed successfully
        Open http://192.168.1.232:8081 in a browser and start configuring!
    You need to re-login before doing anything else on the console!
    arteckA Offline
    arteckA Offline
    arteck
    @jwedenig sagte in Beim Installieren von Zigbee Adapter abgestürzt!!!:
    so http://192.168.1.232:8081 im Browser
    und ??
    • J Offline
      jwedenig
      läuft! Vielen lieben Dank!
      Trotz allen Anleitungen schaffe ich es leider nie alleine, verschiedene Versionen, veraltete Anleitungen!
      Ich glaube eine Anleitung die immer 100% funktioniert gibt es nicht oder täusche ich mich da?
      Dieses Forum ist super dafür!
      Herzlichen Dank!"
      • J jwedenig
        Herzlichen Dank!"
        arteckA Offline
        arteckA Offline
        arteck
        @jwedenig die Systeme sind nicht alle gleich und eine software hat ja auch ein lebeszyklus.. und wir kommen nicht mit der Doku nach...
        schön das es läuft
        • arteckA arteck
          schön das es läuft
          jwedenig
          @arteck
          Danke Danke Danke!!!!
          • arteckA arteck
            @jwedenig einz nach dem anderen
            sudo apt-get install -y build-essential libavahi-compat-libdnssd-dev libudev-dev libpam0g-dev nodejs
            cd /opt
            AlCalzoneA Offline
            AlCalzoneA Offline
            AlCalzone
            @arteck
            FYI:
            Das meiste davon installiert der Installer bereits selbst.
            https://github.com/ioBroker/ioBroker/blob/master/installer.sh#L498
            Nodejs kommt in der nächsten Version.
            cd /opt
            Unnötig
            • AlCalzoneA AlCalzone
              @arteck
              FYI:
              cd /opt
              Unnötig
              arteckA Offline
              arteckA Offline
              arteck
              @AlCalzone im Eifer des Gefächts... jo und jo.... und jo.. 😊 😊
              • J Offline
                jwedenig
                schrieb am zuletzt editiert von jwedenig
                ich hätte jetzt noch eine Frage:
                Da mir ja gestern die SD Karte abgeschmiert ist und ich mir die ganze Neuinstallationsprozedur ersparen möchte, gibt es ein Programm für den Mac, um die Karte zu klonen?
                Ich habe schon einiges gesucht, aber keine 100% Lösung gefunden!
                Danke im voraus
                Jürgen
                • J jwedenig
                  Danke im voraus
                  Jürgen
                  AsgothianA Offline
                  AsgothianA Offline
                  Asgothian
                  @jwedenig du solltest in der Lage sein die Karte direkt mit den diskutilities von macOS zu clonen
                  • J Offline
                    jwedenig
                    alles klar, werde ich versuchen!
                    D.H klonen und wenn ich die 2te SD Karte in den Pi stecke, dann ist alles beim Alten?!
                    • J jwedenig
                      arteckA Offline
                      arteckA Offline
                      arteck
                      @jwedenig
                      https://forum.iobroker.net/topic/25450/livestream-backup-restore-einer-sd-karte
