  4. Beim Installieren von Zigbee Adapter abgestürzt!!!
zigbee adapter
34 Beiträge 4 Kommentatoren 1.8k Aufrufe 2 Beobachtet
  • J Offline
    jwedenig
    jetzt habe ich npm installiert dank Dir!
    und wie bekomm ich noch den iobroker installiert?
    Danke schon mal!
    • J jwedenig
      Danke schon mal!
      arteckA Offline
      arteckA Offline
      arteck
      @jwedenig einz nach dem anderen
      sudo apt-get install -y build-essential libavahi-compat-libdnssd-dev libudev-dev libpam0g-dev nodejs
      cd /opt
      curl -sL https://iobroker.net/install.sh | bash -
      • J Offline
        jwedenig
        root@raspberrypi:~# cd /opt
        root@raspberrypi:/opt# curl -sL https://iobroker.net/install.sh | bash -
            Welcome to the ioBroker installer!
            Installer version: 2019-07-21
            You might need to enter your password a couple of times.
            Installing prerequisites (1/4)
            Creating ioBroker user and directory (2/4)
        Directory /opt/iobroker created
            Installing ioBroker (3/4)
        In file included from ../src/main.cpp:3:
        ../../nan/nan.h: In function ‘void Nan::AsyncQueueWorker(Nan::AsyncWorker*)’:
        ../../nan/nan.h:2298:62: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka void (*)(uv_work_s*, int)’} [-Wcast-function-type]
             , reinterpret_cast<uv_after_work_cb>(AsyncExecuteComplete)
        In file included from ../../nan/nan.h:54,
        ../src/main.cpp: At global scope:
        /root/.node-gyp/10.16.3/include/node/node.h:573:43: warning: cast between incompatible function types from ‘void (*)(v8::Local<v8::Object>)’ to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]
               (node::addon_register_func) (regfunc),                          \
        /root/.node-gyp/10.16.3/include/node/node.h:607:3: note: in expansion of macro NODE_MODULE_X’
           NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)
        ../src/main.cpp:42:1: note: in expansion of macro ‘NODE_MODULE’
         NODE_MODULE(diskusage, Init)
        In file included from /root/.node-gyp/10.16.3/include/node/node.h:63,
        /root/.node-gyp/10.16.3/include/node/v8.h: In instantiation of ‘void v8::PersistentBase<T>::SetWeak(P*, typename v8::WeakCallbackInfo<P>::Callback, v8::WeakCallbackType) [with P = node::ObjectWrap; T = v8::Object; typename v8::WeakCallbackInfo<P>::Callback = void (*)(const v8::WeakCallbackInfo<node::ObjectWrap>&)]’:
        /root/.node-gyp/10.16.3/include/node/node_object_wrap.h:84:78:   required from here
        /root/.node-gyp/10.16.3/include/node/v8.h:9502:16: warning: cast between incompatible function types from ‘v8::WeakCallbackInfo<node::ObjectWrap>::Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<node::ObjectWrap>&)’} to ‘Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<void>&)’} [-Wcast-function-type]
                        reinterpret_cast<Callback>(callback), type);
        /root/.node-gyp/10.16.3/include/node/v8.h: In instantiation of ‘void v8::PersistentBase<T>::SetWeak(P*, typename v8::WeakCallbackInfo<P>::Callback, v8::WeakCallbackType) [with P = Nan::ObjectWrap; T = v8::Object; typename v8::WeakCallbackInfo<P>::Callback = void (*)(const v8::WeakCallbackInfo<Nan::ObjectWrap>&)]’:
        ../../nan/nan_object_wrap.h:65:61:   required from here
        /root/.node-gyp/10.16.3/include/node/v8.h:9502:16: warning: cast between incompatible function types from ‘v8::WeakCallbackInfo<Nan::ObjectWrap>::Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<Nan::ObjectWrap>&)’} to ‘Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<void>&)’} [-Wcast-function-type]
        In file included from ../src/./serialport.h:6,
                         from ../src/serialport.cpp:1:
        ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Open(Nan::NAN_METHOD_ARGS_TYPE)’:
        ../src/serialport.cpp:41:49: warning: ‘v8::String::Utf8Value::Utf8Value(v8::Local<v8::Value>)’ is deprecated: Use Isolate version [-Wdeprecated-declarations]
           v8::String::Utf8Value path(info[0]->ToString());
        In file included from /root/.node-gyp/10.16.3/include/node/v8.h:26,
        /root/.node-gyp/10.16.3/include/node/v8.h:2892:28: note: declared here
                           explicit Utf8Value(Local<v8::Value> obj));
        /root/.node-gyp/10.16.3/include/node/v8config.h:324:3: note: in definition of macro ‘V8_DEPRECATED’
           declarator __attribute__((deprecated(message)))
        ../src/serialport.cpp:48:53: warning: ‘v8::Local<v8::Object> v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
           v8::Local<v8::Object> options = info[1]->ToObject();
        /root/.node-gyp/10.16.3/include/node/v8.h:10046:15: note: declared here
         Local<Object> Value::ToObject() const {
        ../src/serialport.cpp:78:69: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
           uv_queue_work(uv_default_loop(), req, EIO_Open, (uv_after_work_cb)EIO_AfterOpen);
        ../src/serialport.cpp: In function ‘void EIO_AfterOpen(uv_work_t*)’:
        ../src/serialport.cpp:95:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
           data->callback.Call(2, argv);
        ../../nan/nan.h:1740:3: note: declared here
           Call(int argc, v8::Local<v8::Value> argv[]) const {
        ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Update(Nan::NAN_METHOD_ARGS_TYPE)’:
        ../src/serialport.cpp:113:53: warning: ‘v8::Local<v8::Object> v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
        ../src/serialport.cpp:135:71: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
           uv_queue_work(uv_default_loop(), req, EIO_Update, (uv_after_work_cb)EIO_AfterUpdate);
        ../src/serialport.cpp: In function ‘void EIO_AfterUpdate(uv_work_t*)’:
        ../src/serialport.cpp:150:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
           data->callback.Call(1, argv);
        ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Close(Nan::NAN_METHOD_ARGS_TYPE)’:
        ../src/serialport.cpp:175:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
           uv_queue_work(uv_default_loop(), req, EIO_Close, (uv_after_work_cb)EIO_AfterClose);
        ../src/serialport.cpp: In function ‘void EIO_AfterClose(uv_work_t*)’:
        ../src/serialport.cpp:188:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
        ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Flush(Nan::NAN_METHOD_ARGS_TYPE)’:
        ../src/serialport.cpp:215:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
           uv_queue_work(uv_default_loop(), req, EIO_Flush, (uv_after_work_cb)EIO_AfterFlush);
        ../src/serialport.cpp: In function ‘void EIO_AfterFlush(uv_work_t*)’:
        ../src/serialport.cpp:231:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
        ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Set(Nan::NAN_METHOD_ARGS_TYPE)’:
        ../src/serialport.cpp:250:53: warning: ‘v8::Local<v8::Object> v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
        ../src/serialport.cpp:270:68: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
           uv_queue_work(uv_default_loop(), req, EIO_Set, (uv_after_work_cb)EIO_AfterSe);
        ../src/serialport.cpp: In function ‘void EIO_AfterSet(uv_work_t*)’:
        ../src/serialport.cpp:285:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
        ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Get(Nan::NAN_METHOD_ARGS_TYPE)’:
        ../src/serialport.cpp:314:68: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
           uv_queue_work(uv_default_loop(), req, EIO_Get, (uv_after_work_cb)EIO_AfterGe);
        ../src/serialport.cpp: In function ‘void EIO_AfterGet(uv_work_t*)’:
        ../src/serialport.cpp:336:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
        ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE GetBaudRate(Nan::NAN_METHOD_ARGS_TYPE)’:
        ../src/serialport.cpp:363:76: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
           uv_queue_work(uv_default_loop(), req, EIO_GetBaudRate, (uv_after_work_cb)EIO_AfterGetBaudRate);
        ../src/serialport.cpp: In function ‘void EIO_AfterGetBaudRate(uv_work_t*)’:
        ../src/serialport.cpp:383:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
        ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Drain(Nan::NAN_METHOD_ARGS_TYPE)’:
        ../src/serialport.cpp:409:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
           uv_queue_work(uv_default_loop(), req, EIO_Drain, (uv_after_work_cb)EIO_AfterDrain);
        ../src/serialport.cpp: In function ‘void EIO_AfterDrain(uv_work_t*)’:
        ../src/serialport.cpp:424:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
        ../src/serialport.cpp: At global scope:
        ../src/serialport.cpp:430:28: warning: unnecessary parentheses in declaration of ‘ToParityEnum’ [-Wparentheses]
         SerialPortParity NAN_INLINE(ToParityEnum(const v8::Local<v8::String>& v8str)) {
        ../src/serialport.cpp:449:30: warning: unnecessary parentheses in declaration of ‘ToStopBitEnum’ [-Wparentheses]
         SerialPortStopBits NAN_INLINE(ToStopBitEnum(double stopBits)) {
        /root/.node-gyp/10.16.3/include/node/node.h:573:43: warning: cast between incompatible function types from ‘void (*)(v8::Handle<v8::Object>)’ {aka ‘void (*)(v8::Local<v8::Object>)’} to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]
        ../src/serialport.cpp:485:1: note: in expansion of macro ‘NODE_MODULE’
         NODE_MODULE(serialport, init);
        In file included from ../src/serialport.h:6,
                         from ../src/serialport_unix.cpp:2:
        ../src/serialport_unix.cpp: In function ‘int setup(int, OpenBaton*)’:
        ../src/serialport_unix.cpp:176:60: warning: ‘%s’ directive output may be truncated writing up to 1023 bytes into a region of size 1005 [-Wformat-truncation=]
             snprintf(data->errorString, sizeof(data->errorString), "Error %s Cannot open %s", strerror(errno), data->path);
        ../src/serialport_unix.cpp:176:13: note: ‘snprintf’ output 20 or more bytes (assuming 1043) into a destination of size 1024
        ../src/serialport_unix.cpp: In function ‘void EIO_Open(uv_work_t*)’:
        ../src/serialport_unix.cpp:86:60: warning: ‘%s’ directive output may be truncated writing up to 1023 bytes into a region of size 1003 [-Wformat-truncation=]
             snprintf(data->errorString, sizeof(data->errorString), "Error: %s, cannot open %s", strerror(errno), data->path);
        ../src/serialport_unix.cpp:86:13: note: ‘snprintf’ output 22 or more bytes (assuming 1045) into a destination of size 1024
        In file included from ../src/poller.cpp:1:
        ../src/poller.cpp: In static member function ‘static void Poller::onData(uv_poll_t*, int, int)’:
        ../src/poller.cpp:69:29: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
           obj->callback.Call(2, argv);
            Finalizing installation (4/4)
        Enabling autostart...
        Autostart enabled!
            ioBroker was installed successfully
            Open http://192.168.1.232:8081 in a browser and start configuring!
        You need to re-login before doing anything else on the console!
        • J jwedenig
          Autostart enabled!
          arteckA Offline
          arteckA Offline
          arteck
          @jwedenig sagte in Beim Installieren von Zigbee Adapter abgestürzt!!!:
          so http://192.168.1.232:8081 im Browser
          und ??
          • J Offline
            jwedenig
            läuft! Vielen lieben Dank!
            Trotz allen Anleitungen schaffe ich es leider nie alleine, verschiedene Versionen, veraltete Anleitungen!
            Ich glaube eine Anleitung die immer 100% funktioniert gibt es nicht oder täusche ich mich da?
            Dieses Forum ist super dafür!
            Herzlichen Dank!"
            • J jwedenig
              Herzlichen Dank!"
              arteckA Offline
              arteckA Offline
              arteck
              @jwedenig die Systeme sind nicht alle gleich und eine software hat ja auch ein lebeszyklus.. und wir kommen nicht mit der Doku nach...
              schön das es läuft
              • arteckA arteck
                schön das es läuft
                jwedenig
                @arteck
                Danke Danke Danke!!!!
                • arteckA arteck
                  cd /opt
                  AlCalzoneA Offline
                  AlCalzoneA Offline
                  AlCalzone
                  @arteck
                  FYI:
                  Das meiste davon installiert der Installer bereits selbst.
                  https://github.com/ioBroker/ioBroker/blob/master/installer.sh#L498
                  Nodejs kommt in der nächsten Version.
                  cd /opt
                  Unnötig
                  • AlCalzoneA AlCalzone
                    @arteck
                    FYI:
                    cd /opt
                    Unnötig
                    arteckA Offline
                    arteckA Offline
                    arteck
                    @AlCalzone im Eifer des Gefächts... jo und jo.... und jo.. 😊 😊
                    • J Offline
                      jwedenig
                      schrieb am zuletzt editiert von jwedenig
                      ich hätte jetzt noch eine Frage:
                      Da mir ja gestern die SD Karte abgeschmiert ist und ich mir die ganze Neuinstallationsprozedur ersparen möchte, gibt es ein Programm für den Mac, um die Karte zu klonen?
                      Ich habe schon einiges gesucht, aber keine 100% Lösung gefunden!
                      Danke im voraus
                      Jürgen
                      • J jwedenig
                        Danke im voraus
                        Jürgen
                        AsgothianA Offline
                        AsgothianA Offline
                        Asgothian
                        @jwedenig du solltest in der Lage sein die Karte direkt mit den diskutilities von macOS zu clonen
                        • J Offline
                          jwedenig
                          alles klar, werde ich versuchen!
                          D.H klonen und wenn ich die 2te SD Karte in den Pi stecke, dann ist alles beim Alten?!
                          • J jwedenig
                            arteckA Offline
                            arteckA Offline
                            arteck
                            @jwedenig
                            https://forum.iobroker.net/topic/25450/livestream-backup-restore-einer-sd-karte
