  4. Yet another HomeKit adapter
1.8k Beiträge 206 Kommentatoren 1.1m Aufrufe 68 Beobachtet
    Domoe
    schrieb am zuletzt editiert von Domoe
    #877
    Moin zusammen,
    ich bin relativ neu im Thema ioBroker und versuche seit gestern verzweifelt Homekit zu installieren.
    ioBroker habe ich ohne Probleme installiert bekommen. Wenn ich den Homekit Adapter über das Webinterface installiere (Version: 0.9.1) bekomme ich wenn der Adapter starten will folgende Fehlermeldungen im Logbuch:
    host.06ff814918d1	2019-03-03 12:48:42.541	info	Restart adapter system.adapter.yahka.0 because enabled
    host.06ff814918d1	2019-03-03 12:48:42.541	error	instance system.adapter.yahka.0 terminated with code 1 ()
    Caught	2019-03-03 12:48:42.541	error	by controller[0]: at /opt/iobroker/node_modules/iobroker.yahka/main.js:84:18
    Caught	2019-03-03 12:48:42.541	error	by controller[0]: at __webpack_require__ (/opt/iobroker/node_modules/iobroker.yahka/main.js:20:30)
    Caught	2019-03-03 12:48:42.540	error	by controller[0]: at Object../main.ts (/opt/iobroker/node_modules/iobroker.yahka/main.js:290:30)
    Caught	2019-03-03 12:48:42.540	error	by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.yahka/main.js:271:17)
    Caught	2019-03-03 12:48:42.539	error	by controller[0]: at __webpack_require__ (/opt/iobroker/node_modules/iobroker.yahka/main.js:20:30)
    Caught	2019-03-03 12:48:42.539	error	by controller[0]: at Object../yahka.ioBroker-adapter.ts (/opt/iobroker/node_modules/iobroker.yahka/main.js:2326:16)
    Caught	2019-03-03 12:48:42.539	error	by controller[0]: at Object../yahka.homekit-bridge.ts (/opt/iobroker/node_modules/iobroker.yahka/main.js:1764:25)
    Caught	2019-03-03 12:48:42.539	error	by controller[0]: at Object.importHAPCommunityTypesAndFixes (/opt/iobroker/node_modules/iobroker.yahka/main.js:382:26)
    Caught	2019-03-03 12:48:42.539	error	by controller[0]: at module.exports (/opt/iobroker/node_modules/hap-nodejs-community-types/types.js:856:45)
    Caught	2019-03-03 12:48:42.538	error	by controller[0]: TypeError: Cannot read property 'generate' of undefined
    Caught	2019-03-03 12:48:42.538	error	by controller[0]: ^
    Caught	2019-03-03 12:48:42.538	error	by controller[0]: CommunityTypes.InputVoltageAC.UUID = UUID.generate('CommunityTypes:usagedevice:InputVoltageAC');
    Caught	2019-03-03 12:48:42.538	error	by controller[0]: /opt/iobroker/node_modules/hap-nodejs-community-types/types.js:856
    host.06ff814918d1	2019-03-03 12:48:41.920	info	instance system.adapter.yahka.0 started with pid 7833
    Wenn ich die Version 0.8.2 installiere läuft diese. Sobald ich dann wieder ein Update auf 0.9 mache kommen wieder die Fehler.
    Ich habe schon alle versucht was ich in diesem Forum und diversen Suchmaschienen gefunden habe aber irgendwie bekomme ich den Adapter unter der neusten Version einfach nicht ans laufen.
    Ich hoffe mir kann jemand einen Tipp geben was ich noch machen kann.
    node -v : 8.15.1
    nodejs -v: 8.15.1
    npm -v: 6.4.1
    Vielen Dank für eure Hilfe.
    Dominik
      danw
      #878
      Hast du schon Services hinzugefügt?
      It's not a Bug, it's a Feature
        Domoe
        #879
        Moin danw,
        ja habe ich auch schon versucht.
        Das Problem ist das die Bridge nicht ausgefüllt ist.
        Wenn ich alles Manuell ausfülle und dann ein Gerät mit Service hinzufüge passiert leider auch nichts.
          danw
          #880
          Instanz löschen, Adapter löschen, Verzeichnis löschen, falls noch vorhanden (/opt/iobroker/node_modules/iobroker.yahka)
          Neuinstallation von GitHub
            Domoe
            #881
            Habe es nochmal genau so gemacht wie du geschrieben hast.
            Alles gelöscht, Ordner war nicht mehr vorhanden das wegen musste ich diesen nicht mehr löschen.
            Dann auf "Adapter" -> "Installieren aus eigener URL" -> "Beliebig" URL :https://github.com/jensweigele/ioBroker.yahka.git eingetragen auf "Installieren" geklickt.
            Folgende Meldung erhalten:
            $ ./iobroker url "https://github.com/jensweigele/ioBroker.yahka.git" --debug
            install https://github.com/jensweigele/ioBroker.yahka/tarball/master
            npm install https://github.com/jensweigele/ioBroker.yahka/tarball/master --production --save --prefix "/opt/iobroker" (System call)
            + iobroker.yahka@0.9.1added 1 package from 1 contributor and audited 1863 packages in 22.013s
            found 23 vulnerabilities (17 low, 6 high)  run `npm audit fix` to fix them, or `npm audit` for details
            process exited with code 0
            Dann Unter "Adapter" auf das Plus beim HomeKit und wieder folgendes erhalten.
            $ ./iobroker add yahka  --host b910ae2888e0
            host.b910ae2888e0 install adapter yahka
            npm install --production (System call) in "/opt/iobroker/node_modules/iobroker.yahka"
            got /opt/iobroker/node_modules/iobroker.yahka/admin
            upload [19] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/yahka.png yahka.png image/png
            upload [18] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/yahka.admin.js.map yahka.admin.js.map application/json
            upload [17] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/yahka.admin.js yahka.admin.js application/javascript
            upload [16] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/words.js words.js application/javascript
            upload [15] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/index_m.html index_m.html text/html
            upload [14] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/index.html index.html text/html
            upload [13] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/home_icon_large.png home_icon_large.png image/png
            upload [12] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/ext/metroui/js/metro.min.js ext/metroui/js/metro.min.js application/javascript
            upload [11] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/ext/metroui/fonts/selection.json ext/metroui/fonts/selection.json application/json
            upload [10] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/ext/metroui/fonts/metro.woff ext/metroui/fonts/metro.woff application/font-woff
            upload [9] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/ext/metroui/fonts/metro.ttf ext/metroui/fonts/metro.ttf application/x-font-ttf
            upload [8] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/ext/metroui/fonts/metro.svg ext/metroui/fonts/metro.svg image/svg+xml
            upload [7] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/ext/metroui/fonts/metro.eot ext/metroui/fonts/metro.eot application/vnd.ms-fontobject
            upload [6] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/ext/metroui/css/metro.min.css ext/metroui/css/metro.min.css text/css
            upload [5] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/ext/metroui/css/metro-schemes.min.css ext/metroui/css/metro-schemes.min.css text/css
            upload [4] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/ext/metroui/css/metro-rtl.min.css ext/metroui/css/metro-rtl.min.css text/css
            upload [3] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/ext/metroui/css/metro-responsive.min.css ext/metroui/css/metro-responsive.min.css text/css
            upload [2] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/ext/metroui/css/metro-icons.min.css ext/metroui/css/metro-icons.min.css text/css
            upload [1] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/ext/metroui/css/metro-colors.min.css ext/metroui/css/metro-colors.min.css text/css
            upload [0] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/css/yahka.admin.css css/yahka.admin.css text/css
            host.b910ae2888e0 object system.adapter.yahka created
            host.b910ae2888e0 object yahka.meta._accessoryCategories created
            host.b910ae2888e0 create instance yahka
            host.b910ae2888e0 object system.adapter.yahka.0.outputCount created
            host.b910ae2888e0 object system.adapter.yahka.0.inputCount created
            host.b910ae2888e0 object system.adapter.yahka.0.uptime created
            host.b910ae2888e0 object system.adapter.yahka.0.memRss created
            host.b910ae2888e0 object system.adapter.yahka.0.memHeapTotal created
            host.b910ae2888e0 object system.adapter.yahka.0.memHeapUsed created
            host.b910ae2888e0 object system.adapter.yahka.0.connected created
            host.b910ae2888e0 object system.adapter.yahka.0.alive created
            host.b910ae2888e0 object system.adapter.yahka.0 created
            Adapter Startet nicht alle Felder bleiben leer wie oben gezeigt und in der Log folgendes:
            host.b910ae2888e0	2019-03-03 14:35:31.848	error	instance system.adapter.yahka.0 terminated with code 1 ()
            Caught	2019-03-03 14:35:31.848	error	by controller[0]: at /opt/iobroker/node_modules/iobroker.yahka/main.js:84:18
            Caught	2019-03-03 14:35:31.848	error	by controller[0]: at __webpack_require__ (/opt/iobroker/node_modules/iobroker.yahka/main.js:20:30)
            Caught	2019-03-03 14:35:31.848	error	by controller[0]: at Object../main.ts (/opt/iobroker/node_modules/iobroker.yahka/main.js:290:30)
            Caught	2019-03-03 14:35:31.848	error	by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.yahka/main.js:271:17)
            Caught	2019-03-03 14:35:31.847	error	by controller[0]: at Object../yahka.ioBroker-adapter.ts (/opt/iobroker/node_modules/iobroker.yahka/main.js:2326:16)
            Caught	2019-03-03 14:35:31.847	error	by controller[0]: at __webpack_require__ (/opt/iobroker/node_modules/iobroker.yahka/main.js:20:30)
            Caught	2019-03-03 14:35:31.847	error	by controller[0]: at Object../yahka.homekit-bridge.ts (/opt/iobroker/node_modules/iobroker.yahka/main.js:1764:25)
            Caught	2019-03-03 14:35:31.847	error	by controller[0]: at Object.importHAPCommunityTypesAndFixes (/opt/iobroker/node_modules/iobroker.yahka/main.js:382:26)
            Caught	2019-03-03 14:35:31.847	error	by controller[0]: at module.exports (/opt/iobroker/node_modules/iobroker.yahka/node_modules/hap-nodejs-community-types/types.js:856:45)
            Caught	2019-03-03 14:35:31.847	error	by controller[0]: TypeError: Cannot read property 'generate' of undefined
            Caught	2019-03-03 14:35:31.847	error	by controller[0]: ^
            Caught	2019-03-03 14:35:31.847	error	by controller[0]: CommunityTypes.InputVoltageAC.UUID = UUID.generate('CommunityTypes:usagedevice:InputVoltageAC');
            Caught	2019-03-03 14:35:31.846	error	by controller[0]: /opt/iobroker/node_modules/iobroker.yahka/node_modules/hap-nodejs-community-types/types.js:856
            Ich habe alles so detailliert aufgeschrieben damit du vielleicht einen Fehler findest in meinem Ablauf.
            Vielen Dank für deine Hilfe.
            • P Offline
              pi_noob15
              schrieb am zuletzt editiert von pi_noob15
              #882
              habe auch das Problem mit dem Adapter :(
              https://forum.iobroker.net/topic/20545/yahka-homekit-0-9-1-startet-nicht
              aber mit der älteren version 0.82 gehts :)
              • HiltexH Offline
                HiltexH Offline
                Hiltex
                schrieb am zuletzt editiert von Hiltex
                #883
                ich habe bereits mehrfach auf Screenshots der Home-App gesehen, dass man bei Lampen auch das Symbol einer Decken- oder Schreibtischlampe anzeigen lassen kann.
                Weiß jemand, was man da einstellen muss, damit dieses Symbol angezeigt wird oder ist das bei Yahka nicht möglich?
                EDIT: Ich ziehe die Frage zurück. Nachdem mich das über Wochen immer mal wieder beschäftigt hat, hab ich nun zufällig die Lösung gefunden:
                Das Symbol wird direkt in der Home-App eingestellt - in den Einstellungen des jeweiligen Gerätes. Funktioniert nicht bei allen, aber zumindest bei Lampen.
                Blog: indibit.de
                  mucki
                  #884
                  mit dem Yahka Adapter lasse sich ja auch diverse Kameras in Homekit "einschleusen".
                  Wäre es in der Zukunft eventuell auch möglich, dass dem System eine Homekit Secure Video Fähigkeit vorgegaukelt wird?
                  Wäre top :-)
                    Kugelkopf
                    #885
                    Moin Moin!!
                    Ich probiere nun schon seit 2 Tagen meine ESP32Cam in Yahka einzubinden. Leider bislang ohne erfolg.
                    Nodejs v10.16.3
                    npm v6.9.0
                    Rasbian Stretch
                    RaspberryPi 3b+
                    Yahka ist die aktuellste Version 0.9.2
                    FFMPEG:
                    ffmpeg version git-2019-09-30-8b36968 Copyright (c) 2000-2019 the FFmpeg developers
                    built with gcc 6.3.0 (Raspbian 6.3.0-18+rpi1+deb9u1) 20170516
                    configuration: --arch=armel --target-os=linux --enable-gpl --enable-libx264 --enable-nonfree
                    libavutil      56. 35.100 / 56. 35.100
                    libavcodec     58. 59.101 / 58. 59.101
                    libavformat    58. 33.100 / 58. 33.100
                    libavdevice    58.  9.100 / 58.  9.100
                    libavfilter     7. 59.100 /  7. 59.100
                    libswscale      5.  6.100 /  5.  6.100
                    libswresample   3.  6.100 /  3.  6.100
                    libpostproc    55.  6.100 / 55.  6.100
                    Quelle: http://192.168.1.81
                    Die Einzelbilder funktionieren:
                      "-re",
                      "-i",
                      "${source}/capture",
                      "-t",
                      "1",
                      "-s",
                      "${width}x${height}",
                      "-f",
                      "image2",
                    Das Livebild leider nicht:
                    Der Stream im Browser funktioniert allerdings Problemlos: http://192.168.1.81:81/stream
                    er sendet im Mjpeg Format.
                      "-re -f mjpeg",
                      "-i",
                      "${source}:81/stream",
                      "-vcodec",
                      "${codec}",
                      "-an",
                      "-pix_fmt",
                      "yuv420p",
                      "-r",
                      "${fps}",
                      "-f",
                      "rawvideo",
                      "-tune",
                      "zerolatency",
                      "-vf",
                      "scale=${width}:${height}",
                      "-b:v",
                      "${bitrate}k",
                      "-bufsize",
                      "${bitrate}k",
                      "-payload_type",
                      "99",
                      "-ssrc",
                      "1",
                      "-f",
                      "rtp",
                      "-srtp_out_suite",
                      "AES_CM_128_HMAC_SHA1_80",
                      "-srtp_out_params",
                      "${videokey}",
                      "\"srtp://${targetAddress}:${targetVideoPort}?rtcpport=${targetVideoPort}&localrtcpport=${targetVideoPort}&pkt_size=1378\""
                    Einige Dinge konnte ich bisher feststellen indem ich den YAHKA Adapter auf Debug stellte und die URL, die aufgerufen wird beim Öffnen des Livebildes in der Home app, via ssh in der Konsole öffne.
                    • Mit der reinen URL gab es Input Probleme > Input wurde nicht erkannt. Geholfen hat: "-f mjpeg"
                    • FFMPEG hang sich immer weg ohne etwas zu tun solange die srtp:// url nicht in Anführungszeichen stand.
                    Mit der, aus meinem oben genannten Beispiel generierten URL läuft FFMPEG und codiert und sendet auch scheinbar irgendetwas.
                    Prüfen kann ich das nicht, weil der Sicherheitscode ja bei jedem Aufruf geändert wird.
                    Wenn ich "top" in einer zweiten Konsole öffne, kann ich, sofern ich URL von Hand in die erste Konsole eingegeben habe, erkennen das ffmpeg läuft und reichlich CPU Last produziert. Wohingegen beim Aufruf über die Homeapp in "top" keine Last zu verzeichnen ist. Nachgeprüft mit "pgrep" ist auch keine laufende ffmpeg Instanze zu finden.
                    Ich bin mit meinen Ideen am Ende. Ich weiß nicht ob es daran liegt, dass möglicherweise yahka keine Rechte hat um ffmpeg auszuführen, oder ob es es irgendwo anders dran liegt.
                    Leider sind auch alle Versuche fehlgeschlagen, einen LOG zu erzeugen. Weder mit nachgestelltem "2> /opt/iobroker/ffmpeg.txt" noch vorangestellten "-loglevel debug -report"
                    Die beiden Optionen funktionieren wenn ich sie per selbst aufrufe aber nicht wenn Yahka ffmpeg aufruft.
                    Habt ihr noch eine Idee?
                    • Alexandre MarietA Offline
                      Alexandre Mariet
                      #886
                      ich benütze die neue Conversion Funktion "script".
                      Dabei möchte ich mit getstate einen anderen Datenpunkt abfragen.
                      Ich bekomme den Fehler "controller[0]: ReferenceError: getState is not defined".
                      Hat jemand Erfahrung wie man Datenpunkte innerhalb der Script Funktion abfragt?
                        MattN
                        schrieb am zuletzt editiert von MattN
                        #887
                        also falls das jetzt eine saublöde Frage ist und/oder ich entsprechende Informationen irgendwo überlesen habe, tuts mir leid....aber:
                        Warum wird mir die aktuell bei mir installierte Version von Yahka (0.7.1) als neuste Version angezeigt während es auf GitHub bis 0.9.2 hochgeht?
                        Ich bin auch, zumindest nach 1h rumklicken, nirgends auf eine Dokumentation gestoßen, wie man die in Iobroker installierte Version manuell auf 0.9.2 aktualisiert.
                        Hab ich da grad ein Brett vor dem Kopf? Wäre echt nett, wenn mich mal jemand in die richtige Richtung weisen könnte. :-)
                        Edit: Und die Info, ob ein Update eine Neueinrichtung der Geräte zur Folge hat, wäre ein toller Bonus :)
                        E 1 Antwort Letzte Antwort
                        • M MattN
                          el_malto
                          #888
                          @MattN
                          https://forum.iobroker.net/topic/6694/adapterversionen-in-den-repositories
                            MattN
                            #889
                            @el_malto
                            Danke! :-) Die Links in den Beitrag sind tot, aber der Kontext hat gereicht.
                            Da bin ich jetzt echt erleichtert, dass ich dem Drang wild Kommandozeilenbefehle reinzudonnern, nicht nachgegeben habe
                            • F Offline
                              fabib
                              #890
                              Hallo liebe Community!
                              Bin immer ein stiller Leser gewesen und ich konnte mir mit euren Erfahrungen immer sehr gut helfen. Leider komme ich aktuell nicht weiter...
                              Was muss ich in der Kommandozeile für den Livestream einstellen, damit FFmpeg den Ton der ip Kamera an die Home App weiterleitet?
                              Ich bin am verzweifeln und habe alle möglichen Foren durchstöbert.
                              Vielen Dank schon jetzt!
                              LG aus Dortmund
                              Fabian
                              oberfraggerO 1 Antwort Letzte Antwort
                              • F fabib
                                LG aus Dortmund
                                Fabian
                                oberfraggerO Offline
                                oberfragger
                                #891
                                ich habe den Adapter in Version 0.9.2 installiert.
                                Nun habe ich einen Sonoff eingebunden und übergebe den via Yahka. Leider verschwindet der eingerichtete Schalter immer wieder nachdem ich in den Homekit-Einstellungen beispielsweise den Raum angepasst habe.
                                Das gleiche ist auch bei einem eingerichteten Fernseher so.
                                Bei einem Aussenthermometer- kein Problem.
                                Nur ein Neustart der Instanz/ Adapter hilft.
                                Neueste/ lastest Versionen "von allem" installiert.
                                Ideen?
                                HiltexH 1 Antwort Letzte Antwort
                                • oberfraggerO oberfragger
                                  Ideen?
                                  HiltexH Offline
                                  HiltexH Offline
                                  Hiltex
                                  #892
                                  @oberfragger ich habe leider keine Antwort auf deine Frage, wäre aber sehr daran interessiert zu erfahren, wie du den Fernseher eingebunden hast.
                                  Würdest du mir das verraten? Ich hab mich schon mehrfach daran versucht, es aber nie richtig hinbekommen...
                                  Blog: indibit.de
                                  oberfraggerO 3 Antworten Letzte Antwort
                                  • HiltexH Hiltex
                                    oberfragger
                                    #893
                                    @Hiltex Naja. So richtig läuft das nicht. Gerät auswählen und als Service (Service hinzufügen) den Typ TV wählen. Da dann irgendwie rumgefummelt, Angeschaltet habe ich Ich den nur via "Eigenschaften-> Setup". Plötzlich ging der dann an.
                                    Aber wenn ich irgendwas in den Einstellungen ändere ändere... verschwindet das Gerät aus der Übersicht.
                                    • HiltexH Hiltex
                                      oberfragger
                                      #894
                                      @Hiltex Ich habe das wie hier eingerichet.
                                      Für mich scheint es so, dass ich was bei dem Service falsch gemacht habe! Zumindest was den Schalter betrifft.
                                      Der kann ja nur on/off... da habe ich unter ServiceTyp nun Switch und bei "on" "Multistate", satt wie vorher state genommen. Nun bleibt das Gerät auch in der Liste...
                                      Denke mal mit dem Fernseher funzt das dnan vielleicht auch. Mal gucken.
                                      • E Offline
                                        el_malto
                                        #895
                                        Ich bin jetzt mit ioBroker vom Raspberry Pi auf eine Hyper-V VM Debian Buster umgezogen. Um keine Altlasten von irgendwelchen Adaptern mit rüber zu nehmen, habe ich alles per Hand neu installiert.
                                        Kann ich irgendwie die Geräte von meinem Pi auf die neue VM übertragen? Da das doch sehr viele sind, möchte ich mir das neu einrichten ersparen.
                                        • E el_malto
                                          oberfragger
                                          #896
                                          @el_malto minimal Backup (backitup) einspielen?
