  4. Test js-controller v2.0.x (GitHub)
js-controller
1.0k Beiträge 48 Kommentatoren 514.8k Aufrufe 35 Beobachtet
  • apollon77A apollon77
    @ChrisXY ich hab nochmal was geändert: Installier nochmal neu. Version bleibt gleich. Was ist jetzt die Ausgabe?
    coyoteC
    coyoteC
    coyote
    #371
    @apollon77 jetzt bekomm ich das hier (neueste Version):
    Connecting to previous DB "file"...
    Creating backup ...
    This can take some time ... please be patient!
    host.debian 38611 states saved
    host.debian 44497 objects saved
    Backup created: /opt/iobroker/backups/2019_10_01-17_30_24_backupiobroker-migration.tar.gz
    Connecting to new DB "redis" ...
    States  NOT connected
    Objects NOT connected
    New Database could not be connected. Please check your settings. No settings have been changed.
    root@debian:/opt/iobroker#
    • C
      C
      ChrisXY
      #372
      @apollon77 exakt das selbe wie bei coyote
      • C ChrisXY
        @apollon77 Danke für die Info aber keine besserung:
        ring.0	2019-10-01 16:26:22.305	info	(8516) TypeError: Converting circular structure to JSON
        ring.0	2019-10-01 16:26:22.304	debug	(8516) Ring: {"events":{"_events":{},"_eventsCount":0,"_maxListeners":100}}
        ring.0	2019-10-01 16:26:04.957	info	(8516) TypeError: Converting circular structure to JSON
        ring.0	2019-10-01 16:26:04.956	debug	(8516) Ring: {"events":{"_events":{},"_eventsCount":0,"_maxListeners":100}}
        ring.0	2019-10-01 16:26:02.373	info	(8516) Ring adapter uses API: ring-api
        ring.0	2019-10-01 16:26:02.372	info	(8516) Starting Adapter ring.0 in version 1.0.5
        ring.0	2019-10-01 16:26:02.339	info	(8516) starting. Version 1.0.5 in /opt/iobroker/node_modules/iobroker.ring, node: v10.16.3
        ring.0	2019-10-01 16:25:57.656	info	(8483) Got terminate signal TERMINATE_YOURSELF
        ring.0	2019-10-01 16:25:55.804	info	(8483) TypeError: Converting circular structure to JSON
        ring.0	2019-10-01 16:25:38.393	info	(8483) TypeError: Converting circular structure to JSON
        ring.0	2019-10-01 16:25:35.798	info	(8483) Ring adapter uses API: ring-api
        ring.0	2019-10-01 16:25:35.797	info	(8483) Starting Adapter ring.0 in version 1.0.5
        ring.0	2019-10-01 16:25:35.763	info	(8483) starting. Version 1.0.5 in /opt/iobroker/node_modules/iobroker.ring, node: v10.16.3
        StuebiS
        StuebiS
        Stuebi
        #373
        @ChrisXY , den Ring Fehler habe ich behoben, aber die Version befindet sich noch lokal auf meiner Entwicklungsumgebung.
        Ich werde das heute Abend hoffentlich freigeben. Ich muss nur neue Features die noch nicht fertig umgesetzt sind (habe wenig Zeit, da ich einen neuen Job habe) ausbauen.
        ioBroker auf Synology DS216+II im Docker Container
        C 1 Antwort Letzte Antwort
        • StuebiS Stuebi
          C
          C
          ChrisXY
          #374
          @Stuebi Uhh das hört sich ja sehr gut an. Bin sehr gespannt :) Danke
          StuebiS 1 Antwort Letzte Antwort
          • coyoteC coyote
            Creating backup ...
            apollon77A
            apollon77A
            #375
            @coyote und redis-cli tut? Ihr kommt auf den redis selbst drauf von dem Host aus?
            coyoteC 1 Antwort Letzte Antwort
            • D darkiop
              @apollon77
              Hab das heute nochmal nachgestellt:
              Ausgangsbasis:
              1. iobroker-master 1.5.14, im docker-container unter node 8, file/file
              2. iobroker-hwr 1.5.14, auf RPI4 unter Node 10, file/file
              3. Upgrade mit sudo -H -u iobroker npm install ioBroker/ioBroker.js-controller, zuerst der Slave, dann der Master
              Nach den beiden Upgrades folgendes im Log:
              Dann Reboot des Slaves + Master, Log:
              Der Slave kommt dann auch nicht mehr automatisch auf die Beine nach einen Reboot, starte ich ihn aber manuell mit iobroker start schafft er es:
              StabilostickS
              StabilostickS
              Stabilostick
              schrieb am zuletzt editiert von Stabilostick
              #376
              @darkiop sagte in [Aufruf] js-controller 2.0 Beta Test:
              Mir fällt auf, dass Du dann Probleme hast, wenn der Slave keine IPv4-Adresse hat:
              Hast Du schon einmal nachgesehen, was in Deiner Infrastruktur zu diesem Zustand nach dem Booten führt?
              Wenn der Fehler das nächste Mal passiert, dann gib in der Konsole ifconfig eth0 ein (falls Dein Netzwerkinterface eth0 ist).
              Wenn dort im Inet-Eintrag Deine IPv4-Adresse erscheint, dann ist die Konfiguration in Ordnung. Sonst gibst Du in der Konsole einfach sudo dhclient eth0 ein.
              Dann sollte eine neue ipv4-Adresse vom DHCP-Server gezogen werden. Mit dem Befehl von oben kannst Du das dann wieder prüfen.
              Und: Kann Dein Master überhaupt IPv6?
              • StabilostickS Stabilostick
                D
                D
                darkiop
                schrieb am zuletzt editiert von darkiop
                #377
                @Stabilostick Stimmt, das sieht stark danach aus als hätte der RPI zu diesem Zeitpunkt noch keine IPv4 Adresse.
                Die kommt bei mir von einem Unifi Security Gateway. IPv6 habe ich da eigentlich auch nicht aktiv.
                Startet der js-controller2.0 schneller als der 1.5 und es kommt so zu diesem Zustand? :)
                ioBroker Object Explorer: https://forum.iobroker.net/topic/84117/iobroker-object-explorer-dashboard-zum-verwalten-von-dps?_=1789113045261 | Proxmox-ioBroker-Redis-HA Doku: https://forum.iobroker.net/topic/47478/dokumentation-einer-proxmox-iobroker-redis-ha-umgebung
                apollon77A StabilostickS 2 Antworten Letzte Antwort
                • D darkiop
                  apollon77A
                  apollon77A
                  #378
                  @darkiop schneller starten : mag sein. Wie oben schon gesagt sind es jetzt auch reine TCP Verbindungen. Interessanter Effekt.
                  Versuch doch mal ein Delay im init Skript ..
                  • D darkiop
                    StabilostickS
                    StabilostickS
                    Stabilostick
                    #379
                    @darkiop Auf dem Master IPv6 aktivieren und glücklich sein. 😎
                      coyoteC
                      coyoteC
                      coyote
                      #380
                      @apollon77 was brauchst du denn genau? Reicht ein redis-cli ping und es kommt ein PONG zurück?
                      Oder brauchst du redis-cli info?
                      Redis Server habe ich in der gleichen VM installiert wie iobroker
                        D
                        D
                        darkiop
                        #381
                        @apollon77 Das habe ich, siehe ein paar Beiträge weiter oben. Mit nem sleep 10 bzw. zur Sicherheit sleep 15 läuft es erstmal Quick n Dirty.
                        Aktuell habe ich das Probelm, das sich ioBroker nicht merkt welche Adapter gestartet sind. Nach einen Reboot sind alle bis auf admin.0 und backitup.0 deaktiviert. Das war der Ausgangszustand nach dem Restore aus dem minimal Backup. Fixer hab ich bereits laufen lassen.
                        Wo wird denn gespeichert welcher Adapter aktiv sein soll?
                        paul53P StabilostickS apollon77A 3 Antworten Letzte Antwort
                          D
                          D
                          darkiop
                          #382
                          @Stabilostick der Master ist ein Docker Container welcher mit
                          --network=mac0 \
                          --ip=192.168.1.82 \
                          --dns=192.168.1.43 \
                          mit einer fixen IPv4 versehen wurde. Auf diese IP habe ich hier im lokalen LAN auch einen DNS Namen vergeben.
                          IPv6 ist aktuell noch eine Blackbox für mich :)
                          • D darkiop
                            paul53P
                            paul53P
                            #383
                            @darkiop sagte:
                            In der Eigenschaft common.enabled des Instanz-Objektes system.adapter.adaptername.N.
                            Produktiv: Asus PN42: N100 / 8 GB / 500 GB; Proxmox mit 2 VM (ioBroker / openCCU)
                            • D darkiop
                              StabilostickS
                              StabilostickS
                              Stabilostick
                              #384
                              @darkiop
                              Im Ernst:
                              Hast Du einen Pi 4? Da haben mehr Leute Probleme:
                              https://github.com/raspberrypi/linux/issues/3034
                              https://github.com/raspberrypi/linux/issues/3108
                              mii-tool -r eth0
                              ist da der Workaround.
                              D 2 Antworten Letzte Antwort
                                @darkiop
                                Im Ernst:
                                mii-tool -r eth0
                                D
                                D
                                darkiop
                                #385
                                @Stabilostick Ja ist ein Pi4. Danke schaue ich gleich mal rein.
                                  @darkiop sagte:
                                  D
                                  D
                                  darkiop
                                  #386
                                  @paul53 Hier? Da gibt es die nicht.
                                  • D darkiop
                                    paul53P
                                    paul53P
                                    #387
                                    @darkiop sagte:
                                    Hier?
                                    Nein, das ist ein Datenpunkt, der den Zustand anzeigt.
                                    Direkt darüber ist das Objekt "system.adapter.bring.0", dessen Eigenschaften man mit dem Bleistift-Symbol rechts sehen kann.
                                      @darkiop sagte:
                                      Hier?
                                      D
                                      D
                                      darkiop
                                      #388
                                      @paul53 Ok, wieder was gelernt :)
                                      Aber ... ich habe darüber die Instanz bring.0 aktiviert und nach dem durchstarten des iobroker vergisst er das wieder ... irgendwie ist bei mir der Wurm drin :D
                                        @darkiop
                                        Im Ernst:
                                        mii-tool -r eth0
                                        D
                                        D
                                        darkiop
                                        #389
                                        @Stabilostick hat hier leider nicht geholfen.
                                        StabilostickS 1 Antwort Letzte Antwort
                                        • D
                                          D
                                          darkiop
                                          #390
                                          Bin zurück mit beiden auf 1.5.14 - jetzt klappt das auch wieder mit dem Merken welchen Instanzen aktiv sein sollen nach einem Neustart ...
                                          84.1k
