  4. Funktion im Script lässt sich nicht erstellen
funktion script
29 Beiträge 3 Kommentatoren 3.4k Aufrufe 2 Beobachtet
    @streetracer
    Das sollte auch ohne Funktionen gehen. RegExp triggert auf alle Datenpunkte .CONTROL_MODE:
    Export:
     <variables>
       <variable type="" id="=t!1cC|1e%Ev0mw[[A;0">mode</variable>
       <variable type="" id="Lui6%|lSgCbn.vyo_^nS">val</variable>
     </variables>
     <block type="on_ext" id="1iaR/3eXB;~Z]SUYZC^;" x="-282" y="-38">
       <mutation items="1"></mutation>
       <field name="ACK_CONDITION">false</field>
       <value name="OID0">
         <shadow type="field_oid" id="!^oYbWf~?OSyU`WXl-w!">
         </shadow>
         <block type="regex" id="crFJEDNpNG`y]c2^g8XI">
           <field name="TEXT">*.CONTROL_MODE</field>
         </block>
       </value>
       <statement name="STATEMENT">
         <block type="controls_if" id="bmN[z081WkPaG{bHaMGo">
           <value name="IF0">
             <block type="logic_compare" id="Hb4_c]70W~PGSbNN3MsN">
               <field name="OP">EQ</field>
               <value name="A">
                 <block type="on_source" id="XI,+g]kF!G}pG)qo^k+|">
                 </block>
               </value>
               <value name="B">
                 <block type="math_number" id="X=%5NGnfEpcr4~Vir|^[">
                   <field name="NUM">0</field>
                 </block>
               </value>
             </block>
           </value>
           <statement name="DO0">
             <block type="variables_set" id=")8:OT8w~A$TT?jyBk1*j">
               <field name="VAR" id="=t!1cC|1e%Ev0mw[[A;0" variabletype="">mode</field>
               <value name="VALUE">
                 <block type="text" id="F%W8)^FaiskU-ffnp`?:">
                   <field name="TEXT">.AUTO_MODE</field>
                 </block>
               </value>
               <next>
                 <block type="variables_set" id="I[}A%N6G]RnOM_j+an.H">
                   <field name="VAR" id="Lui6%|lSgCbn.vyo_^nS" variabletype="">val</field>
                     <block type="logic_boolean" id="82d;kZyIKtYWI5Ai$)pJ">
                     </block>
                   </value>
                 </block>
               </next>
             </block>
           </statement>
           <value name="IF1">
             <block type="logic_compare" id="Vn*$wi`)#opkYSe-48xF">
               <value name="A">
                 <block type="on_source" id="ddO}7*8fbr5AI+z3}N7|">
                 </block>
               </value>
               <value name="B">
                 <block type="math_number" id="P_mn.o?zWP7vF7ax(A$r">
                   <field name="NUM">1</field>
                 </block>
               </value>
             </block>
           </value>
           <statement name="DO1">
             <block type="variables_set" id="n17FxbP+$z_3`@)OWt6l">
                 <block type="text" id="@3kX4#@$OhKao;YB.Of#">
                   <field name="TEXT">.MANU_MODE</field>
                 </block>
               </value>
               <next>
                 <block type="variables_set" id=",hM-0+jA!Nw)b}Xqu8=y">
                     <block type="get_value_var" id="|u+M.BU3@ZTlBqj3!5=k" inline="false">
                       <value name="OID">
                         <shadow type="text" id="BMPBqY5bC8mSR5J*%}+b">
                           <field name="TEXT"></field>
                         </shadow>
                         <block type="text_join" id="gTa#{}N~F8mUni9I,az-">
                           <value name="ADD0">
                             <block type="on_source" id="$=AmWh06P^U!^8%%%B9a">
                               <field name="ATTR">channelId</field>
                             </block>
                           </value>
                           <value name="ADD1">
                             <block type="text" id="?eJL%r2G0jj4Eenn*wLm">
                               <field name="TEXT">.SET_TEMPERATURE</field>
                             </block>
                           </value>
                         </block>
                       </value>
                     </block>
                   </value>
                 </block>
               </next>
             </block>
           </statement>
           <next>
             <block type="control_ex" id="D~dW`[Ubfv!+Y[GU-W]z">
               <field name="TYPE">false</field>
               <value name="OID">
                 <shadow type="field_oid" id="Y7_VcjK`Si=c9m(BzXtq">
                   <field name="oid">Object ID</field>
                 </shadow>
                 <block type="text_join" id="QTO!+?OB+pHK_3q,vG9z">
                   <value name="ADD0">
                     <block type="on_source" id="r4(SN!o-5D4*wKZftD`[">
                     </block>
                   </value>
                   <value name="ADD1">
                     <block type="variables_get" id="Z6K@GQ,n|9sF?rBGR#/=">
                     </block>
                   </value>
                 </block>
               </value>
                 <shadow type="logic_boolean" id="W,|74d+E2gL*L{w6{cnC">
                 </shadow>
                 <block type="variables_get" id="Hz5k1YKP)f4u}+U%OZMP">
                 </block>
               </value>
               <value name="DELAY_MS">
                 <shadow type="math_number" id="s-!bQC)@.A2twxTN1O?y">
                 </shadow>
               </value>
             </block>
           </next>
         </block>
       </statement>
     </block>
    </xml>
    streetracer
    schrieb am zuletzt editiert von streetracer
    ich kann machen was ich will... ich hab Deine Codezeile in der Funktion hinten (siehe roter Kreis) eingegeben. Trotzdem taucht der Rest wie oben beschrieben nicht in der Funktion beim Zahnrad auf...
    Auch in den Funktionen links gibt es diese Auswahl nicht.
    Könntest Du mir Dein Blockly eventuell exportieren und zukommen lassen?
    • S streetracer
      @streetracer sagte:
      Habe ich im Post vorher mit einem alternativen Blockly (ohne Funktionen) gemacht.
        @streetracer sagte:
        streetracer
        sorry, den Spoiler hatte ich übersehen.
        Da das Blockly mit dem regExp beim Importieren einen Fehler (nicht bekannt) gebracht hat hab ich jetzt mal testweise auf ein bestimmtes Thermostat abgeändert.
        Die Auswahl "control_mode" sollte da ja auch passen, oder?
        Blockly
        sigi234S paul53P 2 Antworten Letzte Antwort
        • S streetracer
          Blockly
          sigi234S Online
          sigi234S Online
          @streetracer sagte in Funktion im Script lässt sich nicht erstellen:
          Blockly
          Bitte keinen externen Hoster nehmen. ICON Bild hochladen verwenden.
          • sigi234S sigi234
            Blockly
            streetracer
            @sigi234 said in Funktion im Script lässt sich nicht erstellen:
            Blockly
            ok, sorry. Wurstel mich grad noch etwas durchs Forum. Aber ich gelobe Besserung ;)
            • S streetracer
              Blockly
              @streetracer sagte:
              Alte Version des Javascript-Adapters ?
              Ja.
                streetracer
                mit dem Script funktioniert es leider nicht. Aktueller Stand:
                Wenn ich im Homekit auf "heizen" stelle kann ich die Temperatur wählen und der Status des Thermostats bleibt auf "heizen".
                Ändert danach die CCU mittels ihres Automatikprogramms iwas am Thermostat wird dieser Wert nicht ins Homekit übernommen sondern das Thermostat schaltet sich dort auf "aus".
                Es muss doch möglich sein das der von der CCU geschaltete Status quasi als Aktualisierung auf den Adapter weitergereicht wird?
                • S streetracer
                  @streetracer sagte:
                  Was ist "heizen" ?
                    streetracer
                    ich versuchs mal anhand der Bilder zu erkären...
                    auf Bild 1 sieht man die möglichen Statuse des Thermostaten
                    Normal sollte dieser immer wie im zweiten Bild zu sehen auf "heizen" (siehe Pfeil) stehen. Wenn man das anfangs
                    da einstellt tut er das auch. Kommt aber ein Signal von der CCU geht der Status auf "Aus" und muss bei der nächsten
                    Benutzung erst wieder händisch auf "heizen" gestellt werden bevor man dann die Temperatur auswählen kann.
                    Ich hoffe ich konnte es einigermassen rüber bringen....
                    • S streetracer
                      @streetracer sagte:
                      Es handelt sich nicht um HomeMatic-Thermostate ? Dann bin ich raus.
                      Das Skript im ersten Post enthält typische Datenpunkt-Bezeichner von HomeMatic-Thermostaten. So sieht der CONTROL_MODE bei HomeMatic aus:
                      Parameter CONTROL_MODE
                      Typ: option
                      Zugriffsart:
                      • lesend
                      • über Ereignisse
                      Werteliste:
                      0 = AUTO-MODE (Standard)
                      1 = MANU-MODE
                      2 = PARTY-MODE
                      3 = BOOST-MODE
                        streetracer
                        doch, es handelt sich um ganz normale Homematic-Thermostate. (hatte nur auf der Arbeit keinen Zugriff auf das Homekit
                        und hab daher Beispielbilder aus dem Netz geladen zur Verdeutlichung was ich meine).
                        Vielleicht hab ich auch im yahka Adapter was übersehen einzustellen...? Dein Script habe ich jedenfalls 1:1 übernommen.
                        • S streetracer
                          @streetracer
                          Der CONTROL_MODE ist kein HeatingCoolingState ! Der HeatingCoolingState zeigt falsche Texte an.
                            streetracer
                            @paul53 said in Funktion im Script lässt sich nicht erstellen:
                            Was sollte man stattdessen nehmen?Mir fällt nämlich beim Lesen der anderen Threads zu dem Thema gerade auf
                            das mein Thermostat gar keinen Datenpunkt "HeatingCoolingState" hat. Weder unter :0 noch unter :4
                            • S streetracer
                              @streetracer sagte:
                              Mit dem yahka Adapter kenne ich mich nicht aus.
                                streetracer
                                Eigentlich sollte der ja hier iwo zu finden sein...
                                • S streetracer
                                  @streetracer
                                  Du brauchst einen zum CONTROL_MODE passenden "State" des yahka Adapters, zumindest einen "State", mit dem man zwischen "Auto" und "Manu" unterscheiden kann.
                                  • S streetracer
                                    @streetracer
                                    Habe mal in den Code für den Adapter geschaut: Dort gibt es eine Konvertierung CONTROL_MODE <--> HeatingCoolingState. Die Konvertierung ist nicht aktiviert !!
                                    export class TIoBrokerConversion_HomematicControlMode_To_CoolingState extends TIOBrokerConversionBase implements IConversionFunction {
                                        toHomeKit(value: any) {
                                            let num = TIOBrokerConversionBase.castToNumber(value)
                                            let result = undefined;
                                            switch (num) {
                                                case 0:
                                                    result = HAPCharacteristic.TargetHeatingCoolingState.AUTO;
                                                    break;
                                                case 1:
                                                    result = HAPCharacteristic.TargetHeatingCoolingState.HEAT;
                                                    break;
                                                case 2:
                                                    break;
                                                case 3:
                                                    break;
                                                default:
                                                    result = HAPCharacteristic.TargetHeatingCoolingState.OFF;
                                                    break;
                                            this.adapter.log.debug('HomematicDirectionToHomekitHeatingCoolingState.toHomeKit, from ' + JSON.stringify(value) + '[' + (typeof value) + '] to ' + JSON.stringify(result));
                                            return result;
                                        toIOBroker(value) {
                                            switch (num) {
                                                case HAPCharacteristic.TargetHeatingCoolingState.OFF:
                                                    result = 0;
                                                    break;
                                                case HAPCharacteristic.TargetHeatingCoolingState.HEAT:
                                                    result = 1;
                                                    break;
                                                case HAPCharacteristic.TargetHeatingCoolingState.COOL:
                                                    result = 0;
                                                    break;
                                                case HAPCharacteristic.TargetHeatingCoolingState.AUTO:
                                                    result = 0;
                                                    break;
                                                default:
                                                    result = 0;
                                                    break;
                                            this.adapter.log.debug('HomematicDirectionToHomekitHeatingCoolingState.toIOBroker, from ' + JSON.stringify(value) + '[' + (typeof value) + '] to ' + JSON.stringify(result));
                                            return result;
                                    Auto = "Auto-Mode"
                                    Heat = "Manu-Mode"
                                      streetracer
                                      reicht das wenn ich die Konvertierung in dem im Adapter eingebundenen Thermostat einstelle (siehe Bild)
                                      oder muss ich das Script auch noch iwo unterbringen?
                                      Danke tausend Mal für deine Hilfe bisher....!
                                      • S streetracer
                                        @streetracer sagte:
                                        Ja, dafür ist es da.
                                        Nein, der Code, der in meinem Beitrag zu sehen ist, ist ein Auszug aus dem Adapter-Quellcode.
