  4. Error:ENOSPC: no space left
Geplant Angeheftet Gesperrt Verschoben Gelöst Error/Bug
erroriogo
5 Beiträge 2 Kommentatoren 1.4k Aufrufe 2 Beobachtet
  • crunchipC Offline
    crunchipC Offline
    Gestern schon versucht den iogo Adapter zu aktualisieren mit dem Ergebnis
    $ ./iobroker upgrade iogo
    Update iogo from @0.4.4 to @0.4.5
    NPM version: 6.9.0
    npm install iobroker.iogo@0.4.5 --production --save --prefix "/opt/iobroker" (System call)
    npm WARN
     @typescript-eslint/eslint-plugin@1.12.0 requires a peer of eslint@^5.0.0 but none is installed. You must install peer dependencies yourself.npm WARN @typescript-eslint/parser@1.12.0 requires a peer of eslint@^5.0.0 but none is installed. You must install peer dependencies yourself.
    npm WARN
     optional
     SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.4 (node_modules/osx-temperature-sensor):npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
    npm install --production (System call) in "/opt/iobroker/node_modules/iobroker.iogo"
    npm WARN deprecated gulp-util@3.0.8: gulp-util is deprecated - replace it, following the guidelines at https://medium.com/gulpjs/gulp-util-ca3b1f9f9ac5
    npm WARN deprecated natives@1.1.6: This module relies on Node.js's internals and will break at some point. Do not use it, and update to graceful-fs@4.x.
    npm WARN deprecated minimatch@2.0.10: Please update to minimatch 3.0.2 or higher to avoid a RegExp DoS issue
    npm
    WARN deprecated minimatch@0.2.14: Please update to minimatch 3.0.2 or higher to avoid a RegExp DoS issue
    npm WARN deprecated graceful-fs@1.2.3: please upgrade to graceful-fs 4 for compatibility with current and future versions of Node.js
    npm WARN
     tar ENOSPC: no space left on device, writenpm WARN tar ENOSPC: no space left on device, write
    npm WARN tar ENOSPC: no space left on device, writenpm WARN tar ENOSPC: no space left on device, write
    npm WARN
    npm
    npm WARN tar
    npm WARN
    npm WARN
    npm ERR! cb() never called!
    npm ERR! This is an error with npm itself. Please report this error at:
    npm ERR!     <https://npm.community>
    got /opt/iobroker/node_modules/iobroker.iogo/admin
    upload [3] iogo.admin /opt/iobroker/node_modules/iobroker.iogo/admin/words.js words.js application/javascript
    Update "system.adapter.iogo.0"
    upload [2] iogo.admin /opt/iobroker/node_modules/iobroker.iogo/admin/iogo.png iogo.png image/png
    upload [1] iogo.admin /opt/iobroker/node_modules/iobroker.iogo/admin/index_m.html index_m.html text/html
    upload [0] iogo.admin /opt/iobroker/node_modules/iobroker.iogo/admin/index.html index.html text/html
    Adapter "iogo" updated
    process exited with code 0
    Heute Nacht Punkt 0.00 Uhr ist dann IoBroker abgekackt
    2019-09-13 00:00:00.364 - error: iogo.0 uncaught exception: Function DocumentReference.set() called with invalid data. Unsupported field value: undefined (found in field min)
    2019-09-13 00:00:00.364 - error: iogo.0 FirebaseError: Function DocumentReference.set() called with invalid data. Unsupported field value: undefined (found in field min)
    at new FirestoreError (/opt/iobroker/node_modules/@firebase/firestore/dist/index.node.cjs.js:354:28)
    at ParseContext.createError (/opt/iobroker/node_modules/@firebase/firestore/dist/index.node.cjs.js:19832:16)
    at UserDataConverter.parseScalarValue (/opt/iobroker/node_modules/@firebase/firestore/dist/index.node.cjs.js:20179:27)
    at UserDataConverter.parseData (/opt/iobroker/node_modules/@firebase/firestore/dist/index.node.cjs.js:20045:29)
    at /opt/iobroker/node_modules/@firebase/firestore/dist/index.node.cjs.js:20061:41
    at forEach (/opt/iobroker/node_modules/@firebase/firestore/dist/index.node.cjs.js:458:13)
    at UserDataConverter.parseObject (/opt/iobroker/node_modules/@firebase/firestore/dist/index.node.cjs.js:20060:13)
    at UserDataConverter.parseData (/opt/iobroker/node_modules/@firebase/firestore/dist/index.node.cjs.js:20019:25)
    at UserDataConverter.parseSetData (/opt/iobroker/node_modules/@firebase/firestore/dist/index.node.cjs.js:19884:31)
    at DocumentReference.set (/opt/iobroker/node_modules/@firebase/firestore/dist/index.node.cjs.js:20829:45)
    2019-09-13 00:00:00.365 - info: iogo.0 cleaned everything up...
    2019-09-13 00:00:00.365 - info: iogo.0 triggered listener removed
    2019-09-13 00:00:00.369 - info: iogo.0 listener removed
    2019-09-13 00:00:00.375 - info: iogo.0 signed out
    2019-09-13 00:00:00.392 - info: iogo.0 triggered listener removed
    2019-09-13 00:00:00.392 - info: iogo.0 listener removed
    2019-09-13 00:00:00.099 - info: host.IoBroker instance system.adapter.dwd.0 started with pid 24147
    2019-09-13 00:00:00.379 - info: javascript.0 script.js.Visualisierung.Wegezeit_Arbeit_Landstraße: Anzahl Wegepunkte: 28
    2019-09-13 00:00:00.445 - info: javascript.0 script.js.Visualisierung.Wegezeit_Arbeit_Autobahn: Anzahl Wegepunkte: 19
    2019-09-13 00:00:00.284 - info: host.IoBroker instance system.adapter.daswetter.0 started with pid 24155
    2019-09-13 00:00:00.500 - info: sourceanalytix.0 Updated SourceAnalytix configuration for : wiffi-wz.0.root.192_168_178_33.w_counter_1
    2019-09-13 00:00:00.503 - info: sourceanalytix.0 Setting start value Day for device : wiffi-wz.0.root.192_168_178_33.w_counter_2 succeeded with value + 2591.14
    2019-09-13 00:00:00.512 - info: influxdb.0 enabled logging of wiffi-wz.0.root.192_168_178_33.w_counter_1, Alias=false
    2019-09-13 00:00:00.515 - warn: iogo.0 You are not logged in
    2019-09-13 00:00:00.362 - info: host.IoBroker instance system.adapter.ical.0 started with pid 24157
    2019-09-13 00:00:00.494 - info: host.IoBroker instance system.adapter.feiertage.0 started with pid 24169
    2019-09-13 00:00:00.535 - info: iogo.0 terminating
    2019-09-13 00:00:00.544 - info: sourceanalytix.0 Setting start value Day for device : wiffi-wz.0.root.192_168_178_33.w_counter_1 succeeded with value + 112242.41
    2019-09-13 00:00:00.966 - error: Caught by controller[0]: { FirebaseError: Function DocumentReference.set() called with invalid data. Unsupported field value: undefined (found in field min)
    2019-09-13 00:00:02.143 - info: javascript.0 script.js.common.System.Logfiles2: Start new Tail process. File path to current log: [/opt/iobroker/log/iobroker.2019-09-13.log]
    2019-09-13 00:00:00.967 - error: Caught by controller[0]: at new FirestoreError (/opt/iobroker/node_modules/@firebase/firestore/dist/index.node.cjs.js:354:28)
    2019-09-13 00:00:00.967 - error: Caught by controller[0]: at ParseContext.createError (/opt/iobroker/node_modules/@firebase/firestore/dist/index.node.cjs.js:19832:16)
    2019-09-13 00:00:00.967 - error: Caught by controller[0]: at UserDataConverter.parseScalarValue (/opt/iobroker/node_modules/@firebase/firestore/dist/index.node.cjs.js:20179:27)
    2019-09-13 00:00:00.967 - error: Caught by controller[0]: at UserDataConverter.parseData (/opt/iobroker/node_modules/@firebase/firestore/dist/index.node.cjs.js:20045:29)
    2019-09-13 00:00:00.967 - error: Caught by controller[0]: at /opt/iobroker/node_modules/@firebase/firestore/dist/index.node.cjs.js:20061:41
    2019-09-13 00:00:00.967 - error: Caught by controller[0]: at forEach (/opt/iobroker/node_modules/@firebase/firestore/dist/index.node.cjs.js:458:13)
    2019-09-13 00:00:01.012 - error: Caught by controller[0]: at UserDataConverter.parseObject (/opt/iobroker/node_modules/@firebase/firestore/dist/index.node.cjs.js:20060:13)
    2019-09-13 00:00:01.012 - error: Caught by controller[0]: at UserDataConverter.parseData (/opt/iobroker/node_modules/@firebase/firestore/dist/index.node.cjs.js:20019:25)
    2019-09-13 00:00:01.012 - error: Caught by controller[0]: at UserDataConverter.parseSetData (/opt/iobroker/node_modules/@firebase/firestore/dist/index.node.cjs.js:19884:31)
    2019-09-13 00:00:01.012 - error: Caught by controller[0]: at DocumentReference.set (/opt/iobroker/node_modules/@firebase/firestore/dist/index.node.cjs.js:20829:45)
    2019-09-13 00:00:01.012 - error: Caught by controller[0]: code: 'invalid-argument',
    2019-09-13 00:00:01.012 - error: Caught by controller[0]: name: 'FirebaseError',
    2019-09-13 00:00:01.012 - error: Caught by controller[0]: toString: [Function] }
    2019-09-13 00:00:01.012 - error: host.IoBroker instance system.adapter.iogo.0 terminated with code 0 (OK)
    Hab nun ein Backup eingespielt und nochmal versucht
    vm in proxmox
    node.js10.16
    npm6.9.0
    admin 3.6.4
    rootdisk 15G
    Iobroker 6.5G
    Ram 3G von 4,5
    • crunchipC Offline
      crunchipC Offline
      Den Adapter habe ich nun mal komplett gelöscht und neu installiert
      $ ./iobroker add iogo  --host IoBroker
      NPM version: 6.9.0
      node-pre-gyp
       WARN Using request for node-pre-gyp https download
      npm WARN @typescript-eslint/eslint-plugin@1.12.0 requires a peer of eslint@^5.0.0 but none is installed. You must install peer dependencies yourself.npm WARN @typescript-eslint/parser@1.12.0 requires a peer of eslint@^5.0.0 but none is installed. You must install peer dependencies yourself.
      npm
       WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.4 (node_modules/osx-temperature-sensor):
      host.IoBroker install adapter iogo
      host.IoBroker object system.adapter.iogo created
      host.IoBroker create instance iogo
      host.IoBroker object iogo.0.info.ts created
      host.IoBroker object iogo.0.info.connection created
      host.IoBroker object system.adapter.iogo.0.outputCount created
      host.IoBroker object system.adapter.iogo.0.inputCount created
      host.IoBroker object system.adapter.iogo.0.uptime created
      host.IoBroker object system.adapter.iogo.0.memRss created
      host.IoBroker object system.adapter.iogo.0.memHeapTotal created
      host.IoBroker object system.adapter.iogo.0.memHeapUsed created
      host.IoBroker object system.adapter.iogo.0.cputime created
      host.IoBroker object system.adapter.iogo.0.cpu created
      host.IoBroker object system.adapter.iogo.0.connected created
      host.IoBroker object system.adapter.iogo.0.alive created
      host.IoBroker object system.adapter.iogo.0 created
      scheint wieder zu funktionieren
        NPM version: 6.9.0
        node-pre-gyp
        npm
        NegaleinN Offline
        NegaleinN Offline
        Negalein
        @crunchip sagte in Error:ENOSPC: no space left:
        Wenn ein Thema gelöst wurde bitte den Beitrag der die Lösung beinhaltet als gelöst markieren.
        -> 3 Punkte Menü rechts unten am Beitrag -> Mark this post as the correct answer
        ° Fixer ---> iob fix
        • NegaleinN Negalein
          crunchipC Offline
          crunchipC Offline
          @Negalein wollte ich noch nicht, da vllt sich jemand noch dazu meldet, was den Fehler verursacht haben könnte, bzw was diese Meldungen bedeuten.
            NegaleinN Offline
            NegaleinN Offline
            Negalein
            Oki Doki :)
