  4. [gelöst] Zigbee Ad. lässt sich nicht mehr install.
zigbee adapter
9 Beiträge 3 Kommentatoren 1.2k Aufrufe 2 Beobachtet
  • J Offline
    JRiddim
    schrieb am zuletzt editiert von JRiddim
    Hi Leute stehe vor folgendem Problem.
    Nachdem mein Zigbee adapter nicht mehr ging habe ich den zigbee-adapter deinstalliert. Jetzt lässt es sich nicht wieder installieren mit folgender Fehlermeldung!
    @serialport/bindings@2.0.8 install /opt/iobroker/node_modules/@serialport/bindings
    > prebuild-install --tag-prefix @serialport/bindings@ || node-gyp rebuild
    prebuild-install WARN install EACCES: permission denied, access '/root/.npm'
    gyp WARN EACCES user "root" does not have permission to access the dev dir "/root/.node-gyp/10.16.3"
    gyp WARN EACCES attempting to reinstall using temporary dev dir "/opt/iobroker/node_modules/@serialport/bindings/.node-gyp"
    gyp WARN install got an error, rolling back install
    gyp ERR! configure error
    gyp ERR! stack Error: EACCES: permission denied, mkdir '/opt/iobroker/node_modules/@serialport/bindings/.node-gyp'
    gyp ERR! System Linux 4.19.66-v7l+
    gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
    gyp ERR! cwd /opt/iobroker/node_modules/@serialport/bindings
    gyp ERR! node -v v10.16.3
    gyp ERR! node-gyp -v v3.8.0
    gyp ERR! not ok
    npm WARN bl@0.7.0 requires a peer of stream-browserify@* but none is installed. You must install peer dependencies yourself.
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.4 (node_modules/osx-temperature-sensor):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
    npm ERR! code ELIFECYCLE
    npm ERR! errno 1
    npm ERR! @serialport/bindings@2.0.8 install: `prebuild-install --tag-prefix @serialport/bindings@ || node-gyp rebuild`
    npm ERR! Exit status 1
    npm ERR!
    npm ERR! Failed at the @serialport/bindings@2.0.8 install script.
    npm ERR!     /root/.npm/_logs/2019-09-04T16_52_31_815Z-debug.log
    Langsam aber sicher.
    • arteckA Offline
      arteckA Offline
      arteck
      lösche mal den Ordner
      und versuch nochmal
      • J Offline
        JRiddim
        Hi das Löschen des Ordners hat mit dem Befehl rm -r @serialport funktioniert. Ich konnte auch den Adapter wieder installieren! Danke schonmal hierfür! Nun habe ich immernoch das Problem das der Adapter Rot bleibt.
        zigbee.0	2019-09-05 15:47:10.440	info	zigbee-shepherd stopped
        zigbee.0	2019-09-05 15:47:10.436	debug	cleaned everything up...
        zigbee.0	2019-09-05 15:47:10.436	error	at Timer.processTimers (timers.js:223:10)
        zigbee.0	2019-09-05 15:47:10.436	error	at listOnTimeout (timers.js:263:5)
        zigbee.0	2019-09-05 15:47:10.436	error	at tryOnTimeout (timers.js:300:5)
        zigbee.0	2019-09-05 15:47:10.436	error	at ontimeout (timers.js:436:11)
        zigbee.0	2019-09-05 15:47:10.436	error	at Timeout.setTimeout [as _onTimeout] (/opt/iobroker/node_modules/cc-znp/lib/ccznp.js:80:56)
        zigbee.0	2019-09-05 15:47:10.436	error	TypeError: Cannot read property 'path' of null
        zigbee.0	2019-09-05 15:47:10.435	error	uncaught exception: Cannot read property 'path' of null
        zigbee.0	2019-09-05 15:47:10.435	debug	TypeError: Cannot read property 'path' of null at Timeout.setTimeout [as _onTimeout] (/opt/iobroker/node_modules/cc-znp/lib/ccznp.js:80:56) at ontimeout (timers.js:436:11) at tryOnTimeout (t
        zigbee.0	2019-09-05 15:47:09.402	info	Reset coordinator
        zigbee.0	2019-09-05 15:47:09.388	info	Lib-Versions: ZShepherd 0.3.0, ZSConverters 10.2.1
        zigbee.0	2019-09-05 15:47:09.360	info	Queue is: true
        zigbee.0	2019-09-05 15:47:09.359	info	Start on port: /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B1214B90X00-if00 channel 11
        zigbee.0	2019-09-05 15:47:09.334	info	starting. Version 0.11.2 in /opt/iobroker/node_modules/iobroker.zigbee, node: v10.16.3
        zigbee.0	2019-09-05 15:47:09.279	debug	statesDB connected
        zigbee.0	2019-09-05 15:47:09.255	debug	objectDB connected
        nodejs -v
        v10.16.13
        node -v
        v10.16.13
        npm -v
        6.9.0
        lg
        • J JRiddim
          nodejs -v
          v10.16.13
          node -v
          v10.16.13
          npm -v
          6.9.0
          lg
          arteckA Offline
          arteckA Offline
          arteck
          @JRiddim sagte in Zigbee Adapter lässt sich nicht mehr installieren:
          dann löschen auch noch
          und nochmal adapter nochmal installieren
          • J Offline
            JRiddim
            @arteck
            Habe die Ordner cc-znp, zigbee-shepherd, zigbee-shepherd-converts, @serialport, serialport gelöscht und den Adapter wieder neu installiert da kam wieder die selbe Fehlermeldung!
            zigbee.0	2019-09-05 21:45:17.440	info	terminating
            zigbee.0	2019-09-05 21:45:17.438	info	zigbee-shepherd stopped
            zigbee.0	2019-09-05 21:45:17.435	debug	cleaned everything up...
            zigbee.0	2019-09-05 21:45:17.435	error	at Timer.processTimers (timers.js:223:10)
            zigbee.0	2019-09-05 21:45:17.435	error	at listOnTimeout (timers.js:263:5)
            zigbee.0	2019-09-05 21:45:17.435	error	at tryOnTimeout (timers.js:300:5)
            zigbee.0	2019-09-05 21:45:17.435	error	at ontimeout (timers.js:436:11)
            zigbee.0	2019-09-05 21:45:17.435	error	at Timeout.setTimeout [as _onTimeout] (/opt/iobroker/node_modules/cc-znp/lib/ccznp.js:80:56)
            zigbee.0	2019-09-05 21:45:17.435	error	TypeError: Cannot read property 'path' of null
            zigbee.0	2019-09-05 21:45:17.434	error	uncaught exception: Cannot read property 'path' of null
            zigbee.0	2019-09-05 21:45:17.434	debug	TypeError: Cannot read property 'path' of null at Timeout.setTimeout [as _onTimeout] (/opt/iobroker/node_modules/cc-znp/lib/ccznp.js:80:56) at ontimeout (timers.js:436:11) at tryOnTimeout (t
            zigbee.0	2019-09-05 21:45:16.397	info	Reset coordinator
            zigbee.0	2019-09-05 21:45:16.382	info	Lib-Versions: ZShepherd 0.3.0, ZSConverters 10.2.1
            zigbee.0	2019-09-05 21:45:16.353	info	Queue is: true
            zigbee.0	2019-09-05 21:45:16.353	info	Start on port: /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B0014B939B6-if00 channel 11
            zigbee.0	2019-09-05 21:45:16.328	info	starting. Version 0.11.2 in /opt/iobroker/node_modules/iobroker.zigbee, node: v10.16.3
            zigbee.0	2019-09-05 21:45:16.241	debug	statesDB connected
            zigbee.0	2019-09-05 21:45:16.208	debug	objectDB connected
            Diese Fehlermeldung kommt wenn ich Version 0.10.2 installiere...
            zigbee.0	2019-09-05 21:58:23.099	debug	system.adapter.admin.0: logging true
            zigbee.0	2019-09-05 21:57:51.085	debug	system.adapter.admin.0: logging false
            zigbee.0	2019-09-05 21:56:38.187	debug	User stateChange zigbee.0.info.connection {"val":false,"ack":false,"ts":1567716998183,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1567716998183}
            zigbee.0	2019-09-05 21:56:38.185	debug	User stateChange zigbee.0.info.pairingMessage {"val":"Error: Error while starting zigbee-shepherd!. Error: request timeout","ack":false,"ts":1567716998181,"q":0,"from":"system.adapter.zigbee.0","user
            zigbee.0	2019-09-05 21:56:38.181	error	Error while starting zigbee-shepherd!. Error: request timeout
            zigbee.0	2019-09-05 21:56:36.670	info	Starting zigbee-shepherd
            zigbee.0	2019-09-05 21:55:37.779	debug	system.adapter.admin.0: logging true
            zigbee.0	2019-09-05 21:55:36.667	info	Error while starting zigbee-shepherd, attempting to fix... (takes 60 seconds)
            zigbee.0	2019-09-05 21:55:35.482	debug	system.adapter.admin.0: logging false
            zigbee.0	2019-09-05 21:55:35.118	info	Reset coordinator
            zigbee.0	2019-09-05 21:55:35.068	info	Queue is: true
            zigbee.0	2019-09-05 21:55:35.068	info	Start on port: /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00154654544545-if00 with panID 6754 channel 11
            zigbee.0	2019-09-05 21:55:35.042	info	starting. Version 0.10.2 in /opt/iobroker/node_modules/iobroker.zigbee, node: v10.16.3
            zigbee.0	2019-09-05 21:55:34.990	debug	statesDB connected
            zigbee.0	2019-09-05 21:55:34.966	debug	objectDB connected
            zigbee.0	2019-09-05 21:55:31.536	info	zigbee-shepherd stopped
            zigbee.0	2019-09-05 21:55:07.264	info	Error while starting zigbee-shepherd, attempting to fix... (takes 60 seconds)
            zigbee.0	2019-09-05 21:55:05.726	info	Reset coordinator
            zigbee.0	2019-09-05 21:55:05.693	info	Queue is: true
            zigbee.0	2019-09-05 21:55:05.693	info	Start on port: /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00154654544545-if00 with panID 6754 channel 11
            zigbee.0	2019-09-05 21:55:05.665	info	starting. Version 0.10.2 in /opt/iobroker/node_modules/iobroker.zigbee, node: v10.16.3
            zigbee.0	2019-09-05 21:54:08.550	error	Serial port not selected! Go to settings page.
            zigbee.0	2019-09-05 21:54:08.517	info	starting. Version 0.10.2 in /opt/iobroker/node_modules/iobroker.zigbee, node: v10.16.3
            • J Offline
              JRiddim
              Hat jemand noch eine Idee warum der Adapter nicht funktioniert?
              • arteckA Offline
                arteckA Offline
                arteck
                deinstalliere den Adapter mal.. lösche nochmal alle
                dann den fixer laufen lassen
                curl -sL https://iobroker.net/fix.sh | bash -
                dann adapter neu istallieren
                wenn das nicht geht ... dann .. kein Plan
                • arteckA arteck
                  Jan1
                  @arteck
                  ich denke auch das der Fixer die Lösung beinhaltet, da bei den Logs einiges darauf hindeutet, dass Rechte fehlen.
                  • J Offline
                    JRiddim
                    Ich hatte den USB-Stick neu geflasht, das brachte die Lösung!
