<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[[gelöst] Zigbee Ad. lässt sich nicht mehr install.]]></title><description><![CDATA[<p dir="auto">Hi Leute stehe vor folgendem Problem.<br />
Nachdem mein Zigbee adapter nicht mehr ging habe ich den zigbee-adapter deinstalliert. Jetzt lässt es sich nicht wieder installieren mit folgender Fehlermeldung!</p>
<pre><code>@serialport/bindings@2.0.8 install /opt/iobroker/node_modules/@serialport/bindings
&gt; prebuild-install --tag-prefix @serialport/bindings@ || node-gyp rebuild
prebuild-install WARN install EACCES: permission denied, access '/root/.npm'
gyp WARN EACCES user "root" does not have permission to access the dev dir "/root/.node-gyp/10.16.3"
gyp WARN EACCES attempting to reinstall using temporary dev dir "/opt/iobroker/node_modules/@serialport/bindings/.node-gyp"
gyp WARN install got an error, rolling back install
gyp ERR! configure error
gyp ERR! stack Error: EACCES: permission denied, mkdir '/opt/iobroker/node_modules/@serialport/bindings/.node-gyp'
gyp ERR! System Linux 4.19.66-v7l+
gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
gyp ERR! cwd /opt/iobroker/node_modules/@serialport/bindings
gyp ERR! node -v v10.16.3
gyp ERR! node-gyp -v v3.8.0
gyp ERR! not ok
npm WARN bl@0.7.0 requires a peer of stream-browserify@* but none is installed. You must install peer dependencies yourself.
npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.4 (node_modules/osx-temperature-sensor):
npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
npm ERR! code ELIFECYCLE
npm ERR! errno 1
npm ERR! @serialport/bindings@2.0.8 install: `prebuild-install --tag-prefix @serialport/bindings@ || node-gyp rebuild`
npm ERR! Exit status 1
npm ERR!
npm ERR! Failed at the @serialport/bindings@2.0.8 install script.
npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
npm ERR!     /root/.npm/_logs/2019-09-04T16_52_31_815Z-debug.log
</code></pre>
]]></description><link>https://forum.iobroker.net/topic/24876/gelöst-zigbee-ad-lässt-sich-nicht-mehr-install</link><generator>RSS for Node</generator><lastBuildDate>Thu, 30 Apr 2026 21:11:29 GMT</lastBuildDate><atom:link href="https://forum.iobroker.net/topic/24876.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 04 Sep 2019 17:00:14 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to [gelöst] Zigbee Ad. lässt sich nicht mehr install. on Tue, 28 Jan 2020 12:47:17 GMT]]></title><description><![CDATA[<p dir="auto">Ich hatte den USB-Stick neu geflasht, das brachte die Lösung!</p>
]]></description><link>https://forum.iobroker.net/post/366498</link><guid isPermaLink="true">https://forum.iobroker.net/post/366498</guid><dc:creator><![CDATA[JRiddim]]></dc:creator><pubDate>Tue, 28 Jan 2020 12:47:17 GMT</pubDate></item><item><title><![CDATA[Reply to [gelöst] Zigbee Ad. lässt sich nicht mehr install. on Tue, 10 Sep 2019 05:36:47 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/arteck" aria-label="Profile: arteck">@<bdi>arteck</bdi></a><br />
ich denke auch das der Fixer die Lösung beinhaltet, da bei den Logs einiges darauf hindeutet, dass Rechte fehlen.</p>
]]></description><link>https://forum.iobroker.net/post/298818</link><guid isPermaLink="true">https://forum.iobroker.net/post/298818</guid><dc:creator><![CDATA[Jan1]]></dc:creator><pubDate>Tue, 10 Sep 2019 05:36:47 GMT</pubDate></item><item><title><![CDATA[Reply to [gelöst] Zigbee Ad. lässt sich nicht mehr install. on Tue, 10 Sep 2019 05:07:16 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jriddim" aria-label="Profile: JRiddim">@<bdi>JRiddim</bdi></a> sagte in <a href="/post/297492">Zigbee Adapter lässt sich nicht mehr installieren</a>:</p>
<blockquote>
<p dir="auto">annot read property 'path' of null</p>
</blockquote>
<p dir="auto">deinstalliere den Adapter mal.. lösche nochmal alle<br />
Ordner cc-znp, zigbee-shepherd, zigbee-shepherd-converts, @serialport, serialport</p>
<p dir="auto">dann den fixer laufen lassen</p>
<pre><code>curl -sL https://iobroker.net/fix.sh | bash -
</code></pre>
<p dir="auto">dann adapter neu istallieren</p>
<p dir="auto">wenn das nicht geht ... dann .. kein Plan</p>
]]></description><link>https://forum.iobroker.net/post/298810</link><guid isPermaLink="true">https://forum.iobroker.net/post/298810</guid><dc:creator><![CDATA[arteck]]></dc:creator><pubDate>Tue, 10 Sep 2019 05:07:16 GMT</pubDate></item><item><title><![CDATA[Reply to [gelöst] Zigbee Ad. lässt sich nicht mehr install. on Mon, 09 Sep 2019 15:08:38 GMT]]></title><description><![CDATA[<p dir="auto">Hat jemand noch eine Idee warum der Adapter nicht funktioniert?</p>
]]></description><link>https://forum.iobroker.net/post/298590</link><guid isPermaLink="true">https://forum.iobroker.net/post/298590</guid><dc:creator><![CDATA[JRiddim]]></dc:creator><pubDate>Mon, 09 Sep 2019 15:08:38 GMT</pubDate></item><item><title><![CDATA[Reply to [gelöst] Zigbee Ad. lässt sich nicht mehr install. on Sat, 07 Sep 2019 16:57:11 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/arteck" aria-label="Profile: arteck">@<bdi>arteck</bdi></a><br />
Habe die Ordner cc-znp, zigbee-shepherd, zigbee-shepherd-converts, @serialport, serialport gelöscht und den Adapter wieder neu installiert da kam wieder die selbe Fehlermeldung!</p>
<p dir="auto"></p><section class="spoiler-wrapper"><button class="spoiler-control btn btn-default">Spoiler</button><section style="display:none" class="spoiler-content"><p></p>
<pre><code>zigbee.0	2019-09-05 21:45:17.440	info	terminating
zigbee.0	2019-09-05 21:45:17.438	info	zigbee-shepherd stopped
zigbee.0	2019-09-05 21:45:17.435	debug	cleaned everything up...
zigbee.0	2019-09-05 21:45:17.435	error	at Timer.processTimers (timers.js:223:10)
zigbee.0	2019-09-05 21:45:17.435	error	at listOnTimeout (timers.js:263:5)
zigbee.0	2019-09-05 21:45:17.435	error	at tryOnTimeout (timers.js:300:5)
zigbee.0	2019-09-05 21:45:17.435	error	at ontimeout (timers.js:436:11)
zigbee.0	2019-09-05 21:45:17.435	error	at Timeout.setTimeout [as _onTimeout] (/opt/iobroker/node_modules/cc-znp/lib/ccznp.js:80:56)
zigbee.0	2019-09-05 21:45:17.435	error	TypeError: Cannot read property 'path' of null
zigbee.0	2019-09-05 21:45:17.434	error	uncaught exception: Cannot read property 'path' of null
zigbee.0	2019-09-05 21:45:17.434	debug	TypeError: Cannot read property 'path' of null at Timeout.setTimeout [as _onTimeout] (/opt/iobroker/node_modules/cc-znp/lib/ccznp.js:80:56) at ontimeout (timers.js:436:11) at tryOnTimeout (t
zigbee.0	2019-09-05 21:45:16.397	info	Reset coordinator
zigbee.0	2019-09-05 21:45:16.382	info	Lib-Versions: ZShepherd 0.3.0, ZSConverters 10.2.1
zigbee.0	2019-09-05 21:45:16.353	info	Queue is: true
zigbee.0	2019-09-05 21:45:16.353	info	Start on port: /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B0014B939B6-if00 channel 11
zigbee.0	2019-09-05 21:45:16.328	info	starting. Version 0.11.2 in /opt/iobroker/node_modules/iobroker.zigbee, node: v10.16.3
zigbee.0	2019-09-05 21:45:16.241	debug	statesDB connected
zigbee.0	2019-09-05 21:45:16.208	debug	objectDB connected
</code></pre>
<p dir="auto"></p></section></section><p></p>
<p dir="auto">Diese Fehlermeldung kommt wenn ich Version 0.10.2 installiere...</p>
<pre><code>zigbee.0	2019-09-05 21:58:23.099	debug	system.adapter.admin.0: logging true
zigbee.0	2019-09-05 21:57:51.085	debug	system.adapter.admin.0: logging false
zigbee.0	2019-09-05 21:56:38.187	debug	User stateChange zigbee.0.info.connection {"val":false,"ack":false,"ts":1567716998183,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1567716998183}
zigbee.0	2019-09-05 21:56:38.185	debug	User stateChange zigbee.0.info.pairingMessage {"val":"Error: Error while starting zigbee-shepherd!. Error: request timeout","ack":false,"ts":1567716998181,"q":0,"from":"system.adapter.zigbee.0","user
zigbee.0	2019-09-05 21:56:38.181	error	Error while starting zigbee-shepherd!. Error: request timeout
zigbee.0	2019-09-05 21:56:36.670	info	Starting zigbee-shepherd
zigbee.0	2019-09-05 21:55:37.779	debug	system.adapter.admin.0: logging true
zigbee.0	2019-09-05 21:55:36.667	info	Error while starting zigbee-shepherd, attempting to fix... (takes 60 seconds)
zigbee.0	2019-09-05 21:55:35.482	debug	system.adapter.admin.0: logging false
zigbee.0	2019-09-05 21:55:35.118	info	Reset coordinator
zigbee.0	2019-09-05 21:55:35.068	info	Queue is: true
zigbee.0	2019-09-05 21:55:35.068	info	Start on port: /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00154654544545-if00 with panID 6754 channel 11
zigbee.0	2019-09-05 21:55:35.042	info	starting. Version 0.10.2 in /opt/iobroker/node_modules/iobroker.zigbee, node: v10.16.3
zigbee.0	2019-09-05 21:55:34.990	debug	statesDB connected
zigbee.0	2019-09-05 21:55:34.966	debug	objectDB connected
zigbee.0	2019-09-05 21:55:31.536	info	zigbee-shepherd stopped
zigbee.0	2019-09-05 21:55:07.264	info	Error while starting zigbee-shepherd, attempting to fix... (takes 60 seconds)
zigbee.0	2019-09-05 21:55:05.726	info	Reset coordinator
zigbee.0	2019-09-05 21:55:05.693	info	Queue is: true
zigbee.0	2019-09-05 21:55:05.693	info	Start on port: /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00154654544545-if00 with panID 6754 channel 11
zigbee.0	2019-09-05 21:55:05.665	info	starting. Version 0.10.2 in /opt/iobroker/node_modules/iobroker.zigbee, node: v10.16.3
zigbee.0	2019-09-05 21:54:08.550	error	Serial port not selected! Go to settings page.
zigbee.0	2019-09-05 21:54:08.517	info	starting. Version 0.10.2 in /opt/iobroker/node_modules/iobroker.zigbee, node: v10.16.3
</code></pre>
]]></description><link>https://forum.iobroker.net/post/297492</link><guid isPermaLink="true">https://forum.iobroker.net/post/297492</guid><dc:creator><![CDATA[JRiddim]]></dc:creator><pubDate>Sat, 07 Sep 2019 16:57:11 GMT</pubDate></item><item><title><![CDATA[Reply to [gelöst] Zigbee Ad. lässt sich nicht mehr install. on Thu, 05 Sep 2019 16:37:29 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jriddim" aria-label="Profile: JRiddim">@<bdi>JRiddim</bdi></a> sagte in <a href="/post/297333">Zigbee Adapter lässt sich nicht mehr installieren</a>:</p>
<blockquote>
<p dir="auto">/opt/iobroker/node_modules/cc-znp</p>
</blockquote>
<p dir="auto">dann löschen auch noch</p>
<pre><code>/opt/iobroker/node_modules/cc-znp
</code></pre>
<p dir="auto">und nochmal adapter nochmal installieren</p>
]]></description><link>https://forum.iobroker.net/post/297365</link><guid isPermaLink="true">https://forum.iobroker.net/post/297365</guid><dc:creator><![CDATA[arteck]]></dc:creator><pubDate>Thu, 05 Sep 2019 16:37:29 GMT</pubDate></item><item><title><![CDATA[Reply to [gelöst] Zigbee Ad. lässt sich nicht mehr install. on Thu, 05 Sep 2019 16:27:43 GMT]]></title><description><![CDATA[<p dir="auto">Hi das Löschen des Ordners hat mit dem Befehl rm -r @serialport funktioniert. Ich konnte auch den Adapter wieder installieren! Danke schonmal hierfür! Nun habe ich immernoch das Problem das der Adapter Rot bleibt.<br />
<pre><code>zigbee.0	2019-09-05 15:47:10.440	info	zigbee-shepherd stopped
zigbee.0	2019-09-05 15:47:10.436	debug	cleaned everything up...
zigbee.0	2019-09-05 15:47:10.436	error	at Timer.processTimers (timers.js:223:10)
zigbee.0	2019-09-05 15:47:10.436	error	at listOnTimeout (timers.js:263:5)
zigbee.0	2019-09-05 15:47:10.436	error	at tryOnTimeout (timers.js:300:5)
zigbee.0	2019-09-05 15:47:10.436	error	at ontimeout (timers.js:436:11)
zigbee.0	2019-09-05 15:47:10.436	error	at Timeout.setTimeout [as _onTimeout] (/opt/iobroker/node_modules/cc-znp/lib/ccznp.js:80:56)
zigbee.0	2019-09-05 15:47:10.436	error	TypeError: Cannot read property 'path' of null
zigbee.0	2019-09-05 15:47:10.435	error	uncaught exception: Cannot read property 'path' of null
zigbee.0	2019-09-05 15:47:10.435	debug	TypeError: Cannot read property 'path' of null at Timeout.setTimeout [as _onTimeout] (/opt/iobroker/node_modules/cc-znp/lib/ccznp.js:80:56) at ontimeout (timers.js:436:11) at tryOnTimeout (t
zigbee.0	2019-09-05 15:47:09.402	info	Reset coordinator
zigbee.0	2019-09-05 15:47:09.388	info	Lib-Versions: ZShepherd 0.3.0, ZSConverters 10.2.1
zigbee.0	2019-09-05 15:47:09.360	info	Queue is: true
zigbee.0	2019-09-05 15:47:09.359	info	Start on port: /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B1214B90X00-if00 channel 11
zigbee.0	2019-09-05 15:47:09.334	info	starting. Version 0.11.2 in /opt/iobroker/node_modules/iobroker.zigbee, node: v10.16.3
zigbee.0	2019-09-05 15:47:09.279	debug	statesDB connected
zigbee.0	2019-09-05 15:47:09.255	debug	objectDB connected
</code></pre>
<p dir="auto">nodejs -v<br />
v10.16.13<br />
node -v<br />
v10.16.13<br />
npm -v<br />
6.9.0</p>
<p dir="auto"></p></section></section><br />
lg<p></p>
]]></description><link>https://forum.iobroker.net/post/297333</link><guid isPermaLink="true">https://forum.iobroker.net/post/297333</guid><dc:creator><![CDATA[JRiddim]]></dc:creator><pubDate>Thu, 05 Sep 2019 16:27:43 GMT</pubDate></item><item><title><![CDATA[Reply to [gelöst] Zigbee Ad. lässt sich nicht mehr install. on Thu, 05 Sep 2019 08:57:23 GMT]]></title><description><![CDATA[<p dir="auto">lösche mal den Ordner</p>
<pre><code>/opt/iobroker/node_modules/@serialport
</code></pre>
<p dir="auto">und versuch nochmal</p>
]]></description><link>https://forum.iobroker.net/post/297257</link><guid isPermaLink="true">https://forum.iobroker.net/post/297257</guid><dc:creator><![CDATA[arteck]]></dc:creator><pubDate>Thu, 05 Sep 2019 08:57:23 GMT</pubDate></item></channel></rss>
