  3. Off Topic
  4. Fingerprint an einem ESP8266
    apollon77A
126 Beiträge 19 Kommentatoren 34.3k Aufrufe 20 Beobachtet
  • Ralla66R
    Ralla66R
    Ralla66
    #105
    Hier noch mal der gesamte Sketch mit Confidence :
    Fingerprint am Wemos D1 mini per MQTT nach IO Broker
    #include <Adafruit_Fingerprint.h>
    #include <ESP8266WiFi.h> // Aus Wifi Mqtt
    #include <PubSubClient.h> // Aus Wifi Mqtt
    Pinbelegung Fingerprint Sensor ist GND,Rx,TX,Vcc
    Am Wemos Rx ist D6 also GPIO 12
    Am Wemos Tx ist D5 also GPIO 14
    SoftwareSerial mySerial(14, 12, false, 128);
    Adafruit_Fingerprint finger = Adafruit_Fingerprint(&mySerial);
    // Eigene Daten eintragen
    const char* ssid = "abc"; // Netzwerknahme
    const char* password = "abc"; // PW Netzwerk
    const char* mqttServer = "abc"; // Broker PI
    const int mqttPort = 1883; // Broker PI Port
    const char* mqttUser = "abc"; // Broker PI Name
    const char* mqttPassword = "abc"; // Broker PI Password
    // Ab hier nix mehr machen
    char* mqttio = "12345"; // Broker PI Wert
    char* confidence = "67890"; // Broker PI Wert
    WiFiClient espClient;
    PubSubClient client(espClient);
    void setup()
    // set the data rate for the sensor serial port
    finger.begin(57600);
    if (finger.verifyPassword()) {
    Serial.println("Found fingerprint sensor!");
    } else {
    Serial.println("Did not find fingerprint sensor :(");
    while (1) { delay(1); }
    finger.getTemplateCount();
    Serial.print("Sensor contains "); Serial.print(finger.templateCount); Serial.println(" templates");
    Serial.println("Waiting for valid finger...");
    Serial.begin(115200); // Baud Wemos nach IDE Serieller Monitor
    WiFi.begin(ssid, password);
    while (WiFi.status() != WL_CONNECTED) {
    delay(500);
    Serial.println("Connecting to WiFi..");
    Serial.println("Connected to the WiFi network");
    client.setServer(mqttServer, mqttPort);
    client.setCallback(callback);
    while (!client.connected()) {
    Serial.println("Connecting to MQTT...");
    if (client.connect("ESP8266Client", mqttUser, mqttPassword )) {
      Serial.println("connected");
    } else {
      Serial.print("failed with state ");
      Serial.print(client.state());
      delay(2000);
    void callback(char* topic, byte* payload, unsigned int length) {
    Serial.print("Message arrived in topic: ");
    Serial.println(topic);
    Serial.print("Message:");
    for (int i = 0; i < length; i++) {
    Serial.print((char)payload[i]);
    Serial.println();
    Serial.println("-----------------------");
    void loop() // run over and over again
    getFingerprintIDez();
    delay(50); //don't ned to run this at full speed.
    uint8_t getFingerprintID() {
    uint8_t p = finger.getImage();
    switch (p) {
    case FINGERPRINT_OK:
    Serial.println("Image taken");
    break;
    case FINGERPRINT_NOFINGER:
    Serial.println("No finger detected");
    return p;
    case FINGERPRINT_PACKETRECIEVEERR:
    Serial.println("Communication error");
    return p;
    case FINGERPRINT_IMAGEFAIL:
    Serial.println("Imaging error");
    return p;
    default:
    Serial.println("Unknown error");
    return p;
    // OK success!
    p = finger.image2Tz();
    switch (p) {
    Serial.println("Image converted");
    break;
    case FINGERPRINT_IMAGEMESS:
    Serial.println("Image too messy");
    return p;
    return p;
    case FINGERPRINT_FEATUREFAIL:
    Serial.println("Could not find fingerprint features");
    return p;
    case FINGERPRINT_INVALIDIMAGE:
    return p;
    default:
    return p;
    // OK converted!
    p = finger.fingerFastSearch();
    if (p == FINGERPRINT_OK) {
    Serial.println("Found a print match!");
    } else if (p == FINGERPRINT_PACKETRECIEVEERR) {
    return p;
    } else if (p == FINGERPRINT_NOTFOUND) {
    Serial.println("Did not find a match");
    return p;
    } else {
    return p;
    // found a match!
    Serial.print("Found ID #"); Serial.print(finger.fingerID);
    Serial.print(" with confidence of "); Serial.println(finger.confidence);
    return finger.fingerID;
    // returns -1 if failed, otherwise returns ID #
    int getFingerprintIDez() {
    if (p != FINGERPRINT_OK) return -1;
    // found a match!
    sprintf(mqttio,"%d",finger.fingerID);
    sprintf(confidence,"%d",finger.confidence);
      client.subscribe("Confidence");
       client.publish("Confidence", confidence);
     client.subscribe("FingerprintNr");
       client.publish("FingerprintNr", mqttio);
    client.loop();
    • H
      H
      Hansi1234
      #106
      ich finde das Projekt hier sehr spannend und hätte dafür auch ein sinnvolles Einsatzgebiet. Ich würde gerne einen Fingerabdrucksensor an meine Gartenlaube hängen. Dann muss ich nicht immer meinen Schlüssel dabei haben.
      Könnte man das auch mit einem Auslöser, zB. einer Lichtschranke oder Bewegungsmelder koppeln? Dass das Licht nicht ständig leuchtet?
      • Ralla66R
        Ralla66R
        Ralla66
        #107
        @Hansi1234
        Was soll denn passieren wenn ein Fingerprint erkannt wurde ?
        Was soll denn passieren wenn eine Bewegung erkannt wurde ?
        Wann soll welches Licht ausgeschaltet werden das vom FP ?
        Wenn ja geht das Licht nur aus wenn der FP kein Strom bekommt.
        Könntest den Strom des FP mit Relais schalten.
        Wenn Bewegung erkannt -> Relais ein.
        Danach ein Timeout 2 min -> Relais aus.
        Mit oder ohne IoBroker ?
        Mit IOBroker relativ einfach umzusetzen.
        Ohne mußt du die Routine / Sketch selbst umschreiben.
        Liegt mehr oder weniger daran welche Fähigkeiten du hast.
        Bewegungsmelder kannst du ein PIR HC-SR501 nehmen.
        Solltest du nicht proggen können und du mit IO arbeitest, könntest du
        2 Wemos nehmen.
        An Wemos 2 könntest du noch Temp, Luftdruck , Wasserstand der Regentonne usw anschließen.
        siehe Bild :-)
        H 1 Antwort Letzte Antwort
        • coyoteC
          coyoteC
          coyote
          #108
          @Ralla66 Verbindungsabbrüche hast du keine mehr? Habe auch jetzt die 2.0.1 ausprobiert, ist da aber genau so
          • Ralla66R
            Ralla66R
            Ralla66
            #109
            @coyote
            Alles ruhig bei mir, keine Verbindungsabbrüche.
            Was steht denn im Log bei dir bezüglich Verbindung ?
            Da sollte ja was zu sehen sein.
            Port ist bei mir 1883 kein SSL.
            Auf die schnelle fällt mir nur ein auf dem Wemos mal Tasmota flashen
            und dort Mqtt einrichten.
            Dann schauen ob diese Verbindung stabil bleibt.
            In der Tasmota Console siehst du dann was kommuniziert wird.
            Eben schauen ob mqtt.0 oder Routine zicken macht.
            Wenn Tasmota auch abbricht kann das nur richtung Adapter sein.
            coyoteC 1 Antwort Letzte Antwort
            • Ralla66R Ralla66
              @coyote
              coyoteC
              coyoteC
              coyote
              #110
              @Ralla66 meinst du iobroker Log?
              Ich habe noch 3 ESP im Netzwerk hängen, die laufen aber stabil.
              Werde mir das morgen vllt mal anschauen, ob ich da was finde. Es ist immer ca. 6-10 Sekunden nach dem der letzte Fingerprint erkannt wurde. Löse ich alle 5 Sekunden den Fingerprint aus, bleibt die Verbindung stehen
              • Ralla66R
                Ralla66R
                Ralla66
                #111
                @coyote
                ja IoBroker Log.
                Das hatte ich ja auch mit dem Verbindungsabbruch bis zum Versionswechsel.
                Dann kann das ja nur Npm oder js.controller oder so was sein.
                Da hab ich aber überhaupt keine Ahnung von.
                Da müssen die Profis helfen.
                W 1 Antwort Letzte Antwort
                • Ralla66R Ralla66
                  @Hansi1234
                  2 Wemos nehmen.
                  siehe Bild :-)
                  H
                  H
                  Hansi1234
                  #112
                  Guten Morgen Ralla66,
                  danke für deine Auflistung. Ich habe unten deine Fragen beantwortet.
                  @Ralla66 said in Fingerprint an einem ESP8266:
                  @Hansi1234
                  • Hi :-)
                  • In Meinem Fall den 12V Schnapper vom Schloss öffnen. Kabel liegt bereits an.
                  • Dann sollte der Fingerprint selber erstmal aktiviert werden (Licht vom Fingerprint geht an). Wäre aber auch nicht zwingend. Dann leuchtet der FP eben immer. Hier muss aber der retriggerbaren Monoflop beachtet werden (evtl. mit einem zusätzlichen Arduino Nano? FP -> Arduino Nano -> RPI?)
                  • Nach z.B. 2 Minuten
                  • Das habe ich mir gedacht. Aber wie gesagt, ist nicht schlimm wenn er dauernd leuchtet.
                  • Mit natürlich :-) Habe auch schon einen Reedkontakt angebracht, welchen ich auch in io integriere.
                  • Daran wird es scheitern. Alles was ich bis jetzt umgesetzt habe, stand iwo hier im Forum oder habe ich bei Google gefunden. Außer die VIS, diese habe ich selber erstellt und passe ich selber an meine Bedürfnisse an.
                  • Liegen bereits einige hier ;-)
                  2 Wemos nehmen.
                  • Von diesen Wemos habe ich zum ersten Mal in diesem Forum gelesen. Ich würde es gerne aber alles per Kabel machen. Wireless nur wenn absolut nötig. Ein RPI mit LAN und Strom kann ich in der Laube sehr leicht unterbringen
                  • An einem RPI aber ebenso ;-)
                  siehe Bild :-)
                  • Oben habe ich bereits erfragt, warum kein UART benutzt wird. Die Antwort habe ich nicht so richtig verstanden. Aber ist auch nicht weiter wild, wenn ich den FP direkt an zB. den RPI anstecke.
                  • Sorry für die vielen Fragen. Aber ist ja erstmal alles nur Theorie. Danke für die Hilfe
                  • Ralla66R
                    Ralla66R
                    Ralla66
                    #113
                    @Hansi1234
                    Wofür denn Uart für welche Anwendung ?
                    Hatte ja oben geschrieben :
                    Das ist bei den meisten NodeMCU / Wemos mit an Board über Mini Usb.
                    TTL <-> RS232
                    Du kannst ja in der Arduino IDE per Mini USB über einen Com Port auf dem Wemos zugreifen.
                    Das ist ja Uart. Möglich auch an RX TX.
                    Wlan brauchste nicht unbedingt,
                    Lan kannste ja mit einem Arduino Uno verwirklichen.
                    Da du nicht proggen kannst bleibt ja das Problem mit dem Sensor und deren Auswertung.
                    Fertige Routinen kenne ich nicht mit FP,Schließer und PIR.
                    Es gibt aber im Netz fertige Routinen für Fingerprint Door opener, ohne PIR.
                    Na ja, ich persönlich würde mit 2 Wemos und Wlan arbeiten.
                    So ist auch meine Statusanzeige mit FP geplant.
                    Brauchst keine Routine umschreiben und Tasmota bietet dir ja an viele Sensoren einzubinden.
                    Na klar kannste mit Tasmota auch Relais schalten oder Reedkontakte verwalten.
                    Dein Projekt wird ja wachsen und irgend wann willste Led Stripes einbinden.
                    Das bietet Tasmota ja auch.
                    Warum einen schweren Weg gehen wenn es einfacher geht.
                    Und denk an eine manuelle Entriegelung falls der FP mal ausfällt.
                    Wenn du unbedingt RPI und FP nutzen möchtest ist das ein ganz eigenes Projekt.
                    Hier ging es um Wemos ( ESP8266 ) mit FP.
                    Dann mach bitte einen eigenen Fred auf RPI trifft FP.
                    Eine ganz andere Welt.
                    Denke das verwirrt viele wenn wir jetzt hier ESP und RPI mischen.
                    Link:
                    https://tutorials-raspberrypi.de/raspberry-pi-fingerprint-sensor-authentifizierung-nutzen/
                    L 1 Antwort Letzte Antwort
                    • Ralla66R Ralla66
                      @coyote
                      ja IoBroker Log.
                      W
                      W
                      WS
                      #114
                      @Ralla66 Vielen Dank für Deine Mühe!!
                      Ich habe mir erlaubt, Deinen Sketch ein wenig zu überarbeiten. Er läuft jetzt bei mir mit allen mqtt-Versionen ohne Verbindungsabbrüche. (Habe ihn 'mal angehängt)
                      Wolfgang
                      //#include <WiFiClient.h>
                      #include <SoftwareSerial.h>
                      #include <NTPClient.h>
                      const char* ssid = ""; // Netzwerknahme
                      const char* password = ""; // PW Netzwerk
                      const char* mqttServer = ""; // Broker PI
                      const char* mqttUser = ""; // Broker PI Name
                      const char* mqttPassword = ""; // Broker PI Password
                      WiFiClient espClientfp;
                      PubSubClient client(espClientfp);
                      int cnt=300;
                      void setup()
                      } else {
                      delay(500);
                      Serial.print("=> ESP8266 IP Adresse: ");
                      Serial.println(WiFi.localIP());
                      void reconnect(){
                      if (client.connect("ESP8266Clientfp", mqttUser, mqttPassword)) {
                      } else {
                      delay(5000);
                      client.subscribe("print/Confidence");
                      client.subscribe("print/FingerprintNr1");
                      client.publish("print/FingerprintNr1","Print verbunden");
                      client.publish("print/Confidence","Genauigkeit verbunden");
                      Serial.println();
                      void loop() { // run over and over again
                      if (!client.connected()) {
                      reconnect();
                      if(cnt==0){
                      Serial.println("Reset...");
                      ESP.restart();
                      cnt--;
                      delay(1000);
                      Serial.println(cnt);
                      client.loop();
                      switch (p) {
                      break;
                      return p;
                      return p;
                      return p;
                      default:
                      return p;
                      // OK success!
                      switch (p) {
                      break;
                      return p;
                      return p;
                      return p;
                      return p;
                      default:
                      return p;
                      // OK converted!
                      return p;
                      return p;
                      } else {
                      return p;
                      client.publish("print/Confidence", confidence);
                      client.publish("print/FingerprintNr1", mqttio);
                      Serial.print("Erkannter Fingerabdruck Nr. "); Serial.print(mqttio);
                      Serial.print(" mit einer Genauigkeit von "); Serial.println(confidence);
                      client.loop();
                      F 1 Antwort Letzte Antwort
                      • BenkiB
                        BenkiB
                        Benki
                        #115
                        Servus,
                        dank eurer Hilfe habe ich den Fingerprint-Reader jetzt halbwegs am Laufen, allerdings habe ich ein reproduzierbares, seltsames Problem:
                        Nach fünf Scans, oder einer Wartezeit von ca. 20 Sek. passiert einfach nichts mehr. Keine Scanns werden mehr angenommen. Das passiert sowohl mit meinem umfangreichen Sketch, als auch mit dem sehr einfachen Adafruit Beispiel - Sketch. Nach Reset oder Stromlosschalten des Boards funktioniert es wieder für fünf Scans oder ca. 20 Sek. Auch ein Abklemmen der VCC-Leitung des FP-Readers für fünf Sek. reicht (meistens), um ihn wieder zum Leben zu erwecken - aber nur wieder für kurze Zeit. Hat jemand ne Idee, woran das liegen kann?
                        Meine Konfiguration:
                        • LoLin Wemos Mini D1 ESP8266
                        • FP-Reader "Wald und Wiese" DY50-2V1 17-12-22 Chip: AS608 QCCF TR9S1B (3,3 - 6V)
                        • Levelshifter baugleich wie oben angegeben
                        • Relais (zum Öffnen eines E-Öffners einer Tür)
                        • Display 20x4
                        • Taster mit Pulldown-Widerstand(100K) zum Initiieren des Anlernens der Finger
                        Verkabelung:
                        • VCC, GND über Levelshifter, wie oben angegeben
                        • RX, TX über D5(GPIO14) und D6(GPIO14)
                        • Signalleitung D3, VCC 5V und GND an Relais
                        • D1, D2 für Display + VCC 5V, GND
                        • D7 PD-Widerstand und Taster an GND
                        Was ich versucht habe:
                        • nackte Verkabelung ohne Display, Taster, PD, Relais
                        • neues Lolin Board
                        • Lolin nodeMCU V3 12E (damit habe ich gar keinen Kontakt zum FP bekommen)
                        • alternativen Levelshifter
                        • verschiedene USB-Netzteile und direkt am PC
                        Danke vorab
                        Grüße! Benki
                        • H
                          H
                          Hansi1234
                          #116
                          Habe gesehen, dass jemand ein request dazu gestartet hat. Wäre hier ein Adapter aufwendig?
                          Würde auch gerne sehen wie man ihn erstellt. Hätte nämlich noch andere Projekte, die es schon auf Github gibt ;)
                          Hier der link
                          link text
                          • D
                            D
                            Dragon
                            schrieb am zuletzt editiert von Dragon
                            #117
                            Hallo alle miteinander
                            Habe mich hier durch den Fred gelesen und muss mittlerweile sagen viel Informatives, aber leider auch viel verwirrendes....
                            Etwas weiter oben gab es einen Post in dem Stand hier noch einmal der ganze Sketch... leider ist ein Post vorher etwas geschrieben, was in diesem leider nicht eingebaut ist. Gibt es einen Sketch den ich so übertragen kann und der out of the Box funktioniert?
                            Wie lerne ich Fingerabdrücke an und wie lösche ich sie wieder?
                            Habe das Problem, dass Hardwarebasteleien und auch Blockly mir viel Spaß machen aber mit der programmiererei habe ich so meine Probleme.
                            Bestellt sind ein Wemos D1 mini und AS608 Sensor... Hoffe es gibt da etwas Hilfe für mich Mausklicker....
                            LG
                            David
                            • H
                              H
                              Hansi1234
                              #118
                              Hier wurde ein Request zu d Thema gestartet
                              • H Hansi1234
                                D
                                D
                                Dragon
                                #119
                                @Hansi1234 gleich mal ein Daumen hoch verteilt! Da müssen aber noch einige kommen... Sind erst zwei....
                                • W WS
                                  Wolfgang
                                  int cnt=300;
                                  void setup()
                                  } else {
                                  delay(500);
                                  void reconnect(){
                                  } else {
                                  delay(5000);
                                  Serial.println();
                                  reconnect();
                                  if(cnt==0){
                                  ESP.restart();
                                  cnt--;
                                  delay(1000);
                                  client.loop();
                                  switch (p) {
                                  break;
                                  return p;
                                  return p;
                                  return p;
                                  default:
                                  return p;
                                  // OK success!
                                  switch (p) {
                                  break;
                                  return p;
                                  return p;
                                  return p;
                                  return p;
                                  default:
                                  return p;
                                  // OK converted!
                                  return p;
                                  return p;
                                  } else {
                                  return p;
                                  client.loop();
                                  F
                                  F
                                  Frank_y
                                  schrieb am zuletzt editiert von Frank_y
                                  #120
                                  @WS sagte in Fingerprint an einem ESP8266:
                                  Wolfgang
                                  int cnt=300;
                                  void setup()
                                  } else {
                                  delay(500);
                                  void reconnect(){
                                  } else {
                                  delay(5000);
                                  Serial.println();
                                  reconnect();
                                  if(cnt==0){
                                  ESP.restart();
                                  cnt--;
                                  delay(1000);
                                  client.loop();
                                  switch (p) {
                                  break;
                                  return p;
                                  return p;
                                  return p;
                                  default:
                                  return p;
                                  // OK success!
                                  switch (p) {
                                  break;
                                  return p;
                                  return p;
                                  return p;
                                  return p;
                                  default:
                                  return p;
                                  // OK converted!
                                  return p;
                                  return p;
                                  } else {
                                  return p;
                                  client.loop();
                                  @WS ich bekomme immer Fehler beim kompilieren.
                                  meine SoftwareSerial.h läßt nur 3 Argumente zu. Im Sketch werden aber vier Argumente angegeben.
                                  (ich verwende Arduino15\packages\esp8266\hardware\esp8266\2.7.4\libraries\SoftwareSerial)
                                  benötige ich eine andere library?
                                  NACHTRAG: Hat sich erledig, einfach ohne das dritte Argument: SoftwareSerial mySerial(14, 12, false);
                                  • T tööö
                                    Ich habe eine Instanz vom Adapter MQTT installiert. Im Sketch dann folgenden Codeauszug:
                                    Die relevanten Variablen (der Rest ergibt sich aus dem Code):
                                    const char* ssid = "[DEIN SSID]";
                                    const char* password = "[Dein WLAN-Passwort]";
                                    const char* mqtt_server = "[IP vom ioBroker-Server";
                                    const char* feuchtigkeitMQTT = "[Name, unter der der Wert im ioBroker im MQTT gespeichert werden soll]";
                                    const char* zeitMQTT = "FeuchtigkeitPalmeObenZeit";
                                    char charBuf[50];
                                    WiFiUDP ntpUDP;
                                    NTPClient timeClient(ntpUDP);
                                    Meine #includes:
                                    #include <Smartdebug.h>
                                    #include <WiFiUdp.h>
                                    wobei "Smartdebug.h" meine eigene Klasse ist, um schöner debuggen zu können und im fertigen Zustand die Debugausgaben eleganter ausschalten zu können, um Speicher zu sparen.
                                    WLAN-Verbindung aufbauen:
                                    void setup_wifi() {
                                      delay(10);
                                      DEBUG_PRINTLN();
                                      DEBUG_PRINT("Connecting to ");
                                      DEBUG_PRINTLN(ssid);
                                        delay(500);
                                        DEBUG_PRINT(".");
                                      randomSeed(micros());
                                      DEBUG_PRINTLN("");
                                      DEBUG_PRINTLN("WiFi connected");
                                      DEBUG_PRINTLN("IP address: ");
                                      DEBUG_PRINTLN(WiFi.localIP());
                                    Falls die Verbindung zum MQTT-Server mal abbricht, wird sie hier wiederhergestellt:
                                    void reconnect() {
                                        DEBUG_PRINT("Attempting MQTT connection...");
                                        String clientIdFeuchtigkeit = feuchtigkeitMQTT;
                                        if (client.connect(clientIdFeuchtigkeit.c_str())) {
                                          DEBUG_PRINTLN("connected");
                                        } else {
                                          DEBUG_PRINT("failed, rc=");
                                          DEBUG_PRINT(client.state());
                                          DEBUG_PRINTLN(" try again in 5 seconds");
                                          delay(5000);
                                        String clientIdZeit = zeitMQTT;
                                        if (client.connect(clientIdZeit.c_str())) {
                                        } else {
                                          delay(5000);
                                    Und hier die setup-Funktion:
                                    void setup() {
                                      timeClient.begin();
                                      // Offset für die Zeitzone einstellen
                                      // GMT +1 = 3600
                                      // GMT +8 = 28800
                                      // GMT -1 = -3600
                                      // GMT 0 = 0
                                      timeClient.setTimeOffset(7200);
                                      DEBUG_INIT(115200);
                                      setup_wifi();
                                      client.setServer(mqtt_server, 1883);
                                      feuchtigkeit = analogRead(FEUCHTIGKEIT);
                                        reconnect();
                                      client.loop();
                                      DEBUG_PRINTLN(feuchtigkeit);
                                      String(feuchtigkeit).toCharArray(charBuf, 50);
                                      client.publish(feuchtigkeitMQTT, charBuf);
                                      while(!timeClient.update()) {
                                        timeClient.forceUpdate();
                                      // Zeit kommt im folgendem Format
                                      // 2018-05-28T16:00:13Z
                                      formattedDate = timeClient.getFormattedDate();
                                      DEBUG_PRINTLN(formattedDate);
                                      int splitT = formattedDate.indexOf("T");
                                      dayStamp = formattedDate.substring(0, splitT);
                                      timeStamp = formattedDate.substring(splitT+1, formattedDate.length()-1);
                                      String zeitAusgabe = dayStamp + " - " + timeStamp;
                                      zeitAusgabe.toCharArray(charBuf, 50);
                                      client.publish(zeitMQTT, charBuf);
                                      delay (2000);
                                      DEBUG_PRINTLN("Ich gehe nun in Schlafmodus für 60 Minuten (3600 Sekunden)");
                                      ESP.deepSleep(3600 * 1000000);
                                    Julian RaabJ
                                    Julian RaabJ
                                    Julian Raab
                                    schrieb am zuletzt editiert von Julian Raab
                                    #121
                                    @tööö Hallo, ich bin absoluter neuling habe mir den Fingerprint Sketch auch zugelegt was auch funktioniert .. jedoch mit dem MQTT auszügen komm ich nicht klar.
                                    Könntest du mir evtl. den Sketch komplett zur verfügung stellen damit ich den Fingerprint in IObroker intigrieren kann,
                                    Hab es nun hinbekommen, spielt ihr eure Finger immer mit dem Sketch auf oder gibt es die Möglichkeit auf eine grafischen Oberfläche ähnlich die von Home Assistant?
                                    Grüße Julian
                                    E 1 Antwort Letzte Antwort
                                    • Julian RaabJ Julian Raab
                                      Grüße Julian
                                      E
                                      E
                                      exitus
                                      #122
                                      @julian-raab das würde mich auch intressieren hat jemand es schon am laufen???
                                      Julian RaabJ 1 Antwort Letzte Antwort
                                      • E exitus
                                        Julian RaabJ
                                        Julian RaabJ
                                        Julian Raab
                                        #123
                                        @exitus bei mir funktioniert es .. aber zum anlernen immer skech aufspielen
                                        • Ralla66R Ralla66
                                          @Hansi1234
                                          TTL <-> RS232
                                          Link:
                                          L
                                          L
                                          locito09
                                          #124
                                          @ralla66
                                          bei mir kommt immer diese fehler meldung beim versuch den Scetch hochzuladen auf einen Wemos D1 Mini
                                          'SoftwareSerial' does not name a type; did you mean 'HardwareSerial'?
                                          ketch_feb14a:191:10: error: 'FINGERPRINT_OK' was not declared in this scope
                                          sketch_feb14a:194:10: error: 'FINGERPRINT_OK' was not declared in this scope
                                          sketch_feb14a:197:10: error: 'FINGERPRINT_OK' was not declared in this scope
                                          sketch_feb14a:202:1: error: 'client' was not declared in this scope
                                          C:\Users\migue\Documents\Arduino\sketch_feb14a\sketch_feb14a.ino:202:1: note: suggested alternative: 'cnt'
                                          Ralla66R 1 Antwort Letzte Antwort
                                          84.0k
