  4. Node-Red
  5. (gelöst) Node-Red "Alexa local" nicht mehr möglich
    6.5k
86 Beiträge 10 Kommentatoren 15.9k Aufrufe 8 Beobachtet
  • IssiI Issi
    @Jan1 So hab mal ein wenig rum probiert bin bei node red nicht grade ein Profi also habt ein wenig nachsicht mit mir so wird es z.B. für dein Ventilator funktionieren.
            "id": "8bedb076.43c908",
            "type": "tab",
            "label": "Flow 1",
            "disabled": false,
            "info": ""
            "id": "8379e91.9890918",
            "type": "amazon-echo-hub",
            "z": "8bedb076.43c908",
            "port": "80",
            "enableinput": false,
            "x": 120,
            "y": 260,
            "wires": [
                    "b565567a.b4ae48"
            "id": "b565567a.b4ae48",
            "type": "amazon-echo-device",
            "name": "Büro",
            "topic": "",
            "x": 290,
            "y": 260,
            "wires": [
                    "c1189dc9.72282"
            "id": "c1189dc9.72282",
            "type": "function",
            "name": "Brightness von 1 bis 254",
            "func": "var newMsg = { payload: msg.bri } ;\n\nreturn newMsg\n",
            "outputs": 1,
            "noerr": 0,
            "x": 490,
            "y": 260,
            "wires": [
                    "9f4ece87.8e2b2"
            "id": "80a66f1.c7b599",
            "type": "debug",
            "name": "",
            "active": true,
            "tosidebar": true,
            "console": false,
            "tostatus": false,
            "complete": "payload",
            "targetType": "msg",
            "x": 1440,
            "y": 250,
            "wires": []
            "id": "7e9ad637.1b6e18",
            "type": "function",
            "name": "von 2 auf 1",
            "func": "msg.payload = msg.payload.toFixed(0).replace('2', '1');\nreturn msg;\n",
            "outputs": 1,
            "noerr": 0,
            "x": 880,
            "y": 220,
            "wires": [
                    "ec4ec1ea.8594"
            "id": "ec4ec1ea.8594",
            "type": "change",
            "name": "von string auf number ",
            "rules": [
                    "t": "set",
                    "p": "payload",
                    "pt": "msg",
                    "to": "$number(payload)",
                    "tot": "jsonata"
            "action": "",
            "property": "",
            "from": "",
            "to": "",
            "reg": false,
            "x": 1150,
            "y": 250,
            "wires": [
                    "80a66f1.c7b599"
            "id": "6482fd75.164ae4",
            "type": "function",
            "name": "von 5 auf 2",
            "func": "msg.payload = msg.payload.toFixed(0).replace('5', '2');\nreturn msg;\n",
            "outputs": 1,
            "noerr": 0,
            "x": 880,
            "y": 260,
            "wires": [
                    "ec4ec1ea.8594"
            "id": "33de9c1a.78dd74",
            "type": "function",
            "name": "von 7 auf 3",
            "func": "msg.payload = msg.payload.toFixed(0).replace('7', '3');\nreturn msg;\n",
            "outputs": 1,
            "noerr": 0,
            "x": 880,
            "y": 300,
            "wires": [
                    "ec4ec1ea.8594"
            "id": "9f4ece87.8e2b2",
            "type": "switch",
            "name": "",
            "property": "payload",
            "propertyType": "msg",
            "rules": [
                    "t": "eq",
                    "v": "2",
                    "vt": "num"
                    "t": "eq",
                    "v": "5",
                    "vt": "str"
                    "t": "eq",
                    "v": "7",
                    "vt": "str"
            "checkall": "true",
            "repair": false,
            "outputs": 3,
            "x": 680,
            "y": 260,
            "wires": [
                    "7e9ad637.1b6e18"
                    "6482fd75.164ae4"
                    "33de9c1a.78dd74"
    und hir noch von 10% bis 100% in 10ner schritten.
           "id": "4b75b843.d57a08",
           "type": "function",
           "name": "von 25 auf 10",
           "func": "msg.payload = msg.payload.toFixed(0).replace('25', '10');\nreturn msg;\n",
           "outputs": 1,
           "noerr": 0,
           "x": 900,
           "y": 190,
           "wires": [
                   "afc0ad7a.2d973"
           "id": "52b8dd38.adc534",
           "type": "function",
           "name": "von 51 auf 20",
           "func": "msg.payload = msg.payload.toFixed(0).replace('51', '20');\nreturn msg;\n",
           "outputs": 1,
           "noerr": 0,
           "x": 900,
           "y": 230,
           "wires": [
                   "afc0ad7a.2d973"
           "id": "5c73d88c.20ee28",
           "type": "function",
           "name": "von 76 auf 30",
           "func": "msg.payload = msg.payload.toFixed(0).replace('76', '30');\nreturn msg;\n",
           "outputs": 1,
           "noerr": 0,
           "x": 900,
           "y": 270,
           "wires": [
                   "afc0ad7a.2d973"
           "id": "df8c47a2.aefe78",
           "type": "function",
           "name": "von 102 auf 40",
           "func": "msg.payload = msg.payload.toFixed(0).replace('102', '40');\nreturn msg;\n",
           "outputs": 1,
           "noerr": 0,
           "x": 900,
           "y": 310,
           "wires": [
                   "afc0ad7a.2d973"
           "id": "864d5a0b.debc78",
           "type": "function",
           "name": "von 127 auf 50",
           "func": "msg.payload = msg.payload.toFixed(0).replace('127', '50');\nreturn msg;\n",
           "outputs": 1,
           "noerr": 0,
           "x": 900,
           "y": 350,
           "wires": [
                   "afc0ad7a.2d973"
           "id": "95f10198.ca70e",
           "type": "function",
           "name": "von 153 auf 60",
           "func": "msg.payload = msg.payload.toFixed(0).replace('153', '60');\nreturn msg;\n",
           "outputs": 1,
           "noerr": 0,
           "x": 900,
           "y": 390,
           "wires": [
                   "afc0ad7a.2d973"
           "id": "391c9c56.087fd4",
           "type": "function",
           "name": "von 178 auf 70",
           "func": "msg.payload = msg.payload.toFixed(0).replace('178', '70');\nreturn msg;\n",
           "outputs": 1,
           "noerr": 0,
           "x": 900,
           "y": 430,
           "wires": [
                   "afc0ad7a.2d973"
           "id": "65d08b93.14afb4",
           "type": "function",
           "name": "von 204 auf 80",
           "func": "msg.payload = msg.payload.toFixed(0).replace('204', '80');\nreturn msg;\n",
           "outputs": 1,
           "noerr": 0,
           "x": 900,
           "y": 470,
           "wires": [
                   "afc0ad7a.2d973"
           "id": "3eca08c4.cd98e8",
           "type": "function",
           "name": "von 229 auf 90",
           "func": "msg.payload = msg.payload.toFixed(0).replace('229', '90');\nreturn msg;\n",
           "outputs": 1,
           "noerr": 0,
           "x": 900,
           "y": 510,
           "wires": [
                   "afc0ad7a.2d973"
           "id": "82a1abb3.f36918",
           "type": "function",
           "name": "von 255 auf 100",
           "func": "msg.payload = msg.payload.toFixed(0).replace('255', '100');\nreturn msg;\n",
           "outputs": 1,
           "noerr": 0,
           "x": 900,
           "y": 550,
           "wires": [
                   "afc0ad7a.2d973"
           "id": "43383ae1.62cbb4",
           "port": "80",
           "x": 110,
           "y": 360,
           "wires": [
                   "d1375ba6.0932a8",
                   "82350ee9.90093"
           "id": "d5477c5.c81c78",
           "type": "function",
           "outputs": 1,
           "noerr": 0,
           "x": 500,
           "y": 360,
           "wires": [
                   "8cef745b.eeb438"
           "id": "8cef745b.eeb438",
           "type": "switch",
           "name": "",
           "rules": [
                   "t": "eq",
                   "v": "25",
                   "vt": "num"
                   "t": "eq",
                   "v": "51",
                   "vt": "str"
                   "t": "eq",
                   "v": "76",
                   "vt": "str"
                   "t": "eq",
                   "v": "102",
                   "vt": "str"
                   "t": "eq",
                   "v": "127",
                   "vt": "str"
                   "t": "eq",
                   "v": "153",
                   "vt": "str"
                   "t": "eq",
                   "v": "178",
                   "vt": "str"
                   "t": "eq",
                   "v": "204",
                   "vt": "str"
                   "t": "eq",
                   "v": "229",
                   "vt": "str"
                   "t": "eq",
                   "v": "255",
                   "vt": "str"
           "checkall": "true",
           "repair": false,
           "outputs": 10,
           "x": 690,
           "y": 360,
           "wires": [
                   "4b75b843.d57a08"
                   "52b8dd38.adc534"
                   "5c73d88c.20ee28"
                   "df8c47a2.aefe78"
                   "864d5a0b.debc78"
                   "95f10198.ca70e"
                   "391c9c56.087fd4"
                   "65d08b93.14afb4"
                   "3eca08c4.cd98e8"
                   "82a1abb3.f36918"
           "id": "93f1533f.ef096",
           "type": "debug",
           "name": "",
           "active": true,
           "tosidebar": true,
           "console": false,
           "tostatus": false,
           "x": 1540,
           "y": 360,
           "wires": []
           "id": "afc0ad7a.2d973",
           "type": "change",
           "rules": [
                   "t": "set",
                   "p": "payload",
                   "pt": "msg",
                   "tot": "jsonata"
           "action": "",
           "property": "",
           "from": "",
           "to": "",
           "reg": false,
           "x": 1310,
           "y": 360,
           "wires": [
                   "93f1533f.ef096"
           "id": "d1375ba6.0932a8",
           "name": "Test",
           "topic": "",
           "x": 290,
           "y": 360,
           "wires": [
                   "d5477c5.c81c78"
    Jan1
    @Issi
    Danke für Deine Mühe. Da hätte ich wohl wesentlich länger basteln müssen.
    Probier ich morgen mal aus, wobei das schon verdammt viel Aufwand ist, was vorher mir 3 einfachen Nodes funltioniert hat.
    IssiI 1 Antwort Letzte Antwort
    • J Jan1
      @Issi
      IssiI Offline
      IssiI Offline
      Issi
      @Jan1 ja schon ich kanns mir auch nicht erklären warum es bei dir nicht mehr funktionirt
      • IssiI Issi
        Jan1
        @Issi
        Kannst mir bitte mal ein Screenshot von einem funktionietenden Flow mit der Alexa local Node machen.
        Am besten ein frisch angelegter und das gefundene Gerät dazu auf der Amazon Seite?
        • J Jan1
          @Issi
          IssiI Offline
          IssiI Offline
          Issi
          @Jan1 hir bitte
          • IssiI Issi
            @Jan1 hir bitte
            Jan1
            @Issi
            Was zum Geier ist da bei mir faul?
            Kannst auch mal Deiner Versionsstände posten?
            IssiI 3 Antworten Letzte Antwort
            • J Jan1
              @Issi
              IssiI Offline
              IssiI Offline
              Issi
              @Jan1
              alex@Iobroker-lxc:~$ node -v
              v10.16.0
              alex@Iobroker-lxc:~$ nodejs -v
              v10.16.0
              alex@Iobroker-lxc:~$ npm -v
              6.9.0
              • J Jan1
                @Issi
                IssiI Offline
                IssiI Offline
                Issi
                @Jan1 ich update mal mein test system auf die neuste node version und teste es noch mal
                • J Jan1
                  @Issi
                  IssiI Offline
                  IssiI Offline
                  Issi
                  @Jan1 so nach update funktionirt es auch
                  alex@Iobroker:/opt/iobroker$ node -v
                  v10.16.3
                  alex@Iobroker:/opt/iobroker$ nodejs -v
                  v10.16.3
                  alex@Iobroker:/opt/iobroker$ npm -v
                  6.9.0
                  • IssiI Offline
                    IssiI Offline
                    Issi
                    @Jan1 kannst ja mal im TeamSpeak vorbei schauen vllt kann man da ja was machen gibt genug Leute hier die sich einigermaßen gut auskennen
                    • IssiI Issi
                      Jan1
                      @Issi
                      Wo muss ich denn da hin?
                      • J Jan1
                        @Issi
                        IssiI Offline
                        IssiI Offline
                        Issi
                        @Jan1 62.104.20.86:10038
                        • IssiI Issi
                          Jan1
                          @Issi
                          Noch bin ich auf Arbeit
                          • J Jan1
                            @Issi
                            IssiI Offline
                            IssiI Offline
                            Issi
                            @Jan1 kommst dann wenn du daheim bist ich bin noch länger da
                            • IssiI Issi
                              Jan1
                              @Issi
                              Heute wird das nix mehr. Frau würde mir den Stecker ziehen.
                              • J Jan1
                                @Issi
                                IssiI Offline
                                IssiI Offline
                                Issi
                                @Jan1 wann hast du dann zeit ?
                                • IssiI Issi
                                  Jan1
                                  @Issi
                                  Im Spätdienst ab 8 bis 12.
                                  • J Jan1
                                    @Issi
                                    IssiI Offline
                                    IssiI Offline
                                    Issi
                                    @Jan1 jo dan halt morgen's oder am Wochenende
                                    • IssiI Issi
                                      Jan1
                                      @Issi
                                      Ist das immer die selbe IP?
                                      IssiI 2 Antworten Letzte Antwort
                                      • J Jan1
                                        @Issi
                                        IssiI Offline
                                        IssiI Offline
                                        Issi
                                        @Jan1 ja das ist das Iobroker TS
                                        • J Jan1
                                          @Issi
                                          IssiI Offline
                                          IssiI Offline
                                          Issi
                                          @Jan1 sobald du rein kommst musst du im Chat die
                                          Grundregeln für den Server akzeptieren unten im Chat wirst von einem bot angeschrieben und dann in ein anderen Chanel verschoben bis ein Mod oder admin zu dir kommt, wenn ich dich sehe komme ich hoch
