  4. Adapter: ioBroker.unifi
unifi
1.0k Beiträge 172 Kommentatoren 722.2k Aufrufe 93 Beobachtet
  • liv-in-skyL liv-in-sky
    @dslraser
    hab noch was gefunden und positiv getestet - ist ein linux-bash-script
    https://community.openhab.org/t/solved-exec-commandline-bash-script-unifi-via-rule/66136/7
    #!/bin/bash
    unifi_username=user
    unifi_password='pass'
    unifi_controller=https://192.168.x.xx:xxxx
    wifi_id=dsa4fsda6g46fdsg984
    cookie=/tmp/cookie
    #site_id=""             // deprecated
    curl_cmd="curl -s -S --cookie ${cookie} --cookie-jar ${cookie} --insecure "
    unifi_login() {
     # authenticate against unifi controller
     # Mute response by adding > /dev/null
     ${curl_cmd} -H "Content-Type: application/json" -X POST -d "{\"password\":\"$unifi_password\",\"username\":\"$unifi_username\"}" $unifi_controller/api/login #> /dev/null
    unifi_logout() {
     # logout
     ${curl_cmd} $unifi_controller/logout
    enable_wifi() {
     # enables guest wifi network
     ${curl_cmd} "$unifi_controller"'/api/s/default/rest/wlanconf/'"$wifi_id" -X PUT --data-binary '{"_id":"'$site_id'","enabled":true}' --compressed #> /dev/null
    disable_wifi() {
     ${curl_cmd} "$unifi_controller"'/api/s/default/rest/wlanconf/'"$wifi_id" -X PUT --data-binary '{"_id":"'$site_id'","enabled":false}' --compressed #> /dev/null
    check_status() {
     # checks wifi network status
     response=$(${curl_cmd} "$unifi_controller"'/api/s/default/rest/wlanconf/'"$wifi_id" --compressed)
     status=$(echo $response | jq ".data[0].enabled")
     if [ "$status" == "true" ]; then
     exit 0
     elif [ "$status" == "false" ]; then
     exit 1
     else
     echo exit -1
     fi
    unifi_login
    if [ "$1" == "enable" ]; then
     echo "Enabling WiFi."
     enable_wifi
    elif [ "$1" == "disable" ]; then
     echo "Disabling WiFi."
     disable_wifi
    elif [ "$1" == "status" ]; then
     check_status
    else
     echo "Must include command line parameter [enable|disable|status]."
    fi
    unifi_logout
    rm $cookie
    mit diesem script kann ich mein wlan ein und ausschalten ode den status abfragen
    • es muss "apt-get install jq" ausgeführt werden (nur nötig, wenn man status will) (damit es bei mir funktionierte, mußte ich den jq pfad im script bei dem jq befehle angeben (unter bereich status)) - die wifi_id findet man so:
    Getting your wifi_id:
    Navigate to your controller and sign in.
    Navigate to Settings > Wifi Networks.
    Click Edit next to the SSID you’d like to control.
    Copy the ID from the end of the URL.
    In the following example, the ID is ( 000d00c0e0b0e00d00000000 ):
    url://example:8443/manage/site/default/settings/wlans/00bd00a6e0000e9da2cde10c/edit/000d00c0e0b0e00d00000000
    dslraserD
    dslraserD
    dslraser
    #309
    @liv-in-sky sagte in Adapter: ioBroker.unifi:
    Hi, kann man das auch in ein normal Script oder Blockly umwandeln ?
    Oder wo/wie wendest Du das linux-bash-script an ?
    Ich würde es gern in z.B iQontrol nutzen.
    z.B. Gäste WLAN an oder Gäste WLAN aus
    • dslraserD dslraser
      liv-in-skyL
      liv-in-skyL
      #310
      @dslraser
      wenn du das linux script erzeugst auf einer console :
      • am besten im /opt/iobroker - ordner - da solltest du die rechte haben
      • nano unifi.sh (dann inhalt reinkopieren) - mit "<ALT>-x speichern unter dem namen unifi.sh
      • dann "chmod +x unifi.sh" - danmit es ausführbar ist
      dann kannst du mit einem blockly und result aktiviert (variable result einfach erstellen) das script aufrufen und das result weiterverarbeiten
        @dslraser
        dslraserD
        dslraserD
        dslraser
        #311
        @liv-in-sky
        Danke für Deine Geduld und Mühe.
        Also muss ich tatsächlich erst dieses Script installieren und dann über Blockly aufrufen.
        Ich dachte es gäbe eine Möglichkeit dies gleich mit "ioBroker Boardmitteln" zu erledigen ?
          @liv-in-sky
          liv-in-skyL
          liv-in-skyL
          #312
          @dslraser
          ja - ich steh auf diese linux scripts - dabei bin ich schneller als in javascript - old school halt!
          ein richtiger profi könnte das sicher in javascript umwandeln - aber das kann ich leider nicht bieten :-(
          ansonsten mit nodered - weiß nicht, ob du das magst
            @dslraser
            dslraserD
            dslraserD
            dslraser
            #313
            Ich weiß nicht ob ich das mag, habe ich noch nie benutzt 😅
            thewhoboxT 1 Antwort Letzte Antwort
              thewhoboxT
              thewhoboxT
              thewhobox
              #314
              @dslraser Hab ich noch nicht getestet, sollte aber eig funktionieren.
              const request = require('request');
              const unifi_username = "user";
              const unifi_password = "pass";
              const unifi_controller = "https://192.168.x.xx:xxxx";
              const wifi_id = "dsa4fsda6g46fdsg984";
              function login() {
                  request.post({
                          url: unifi_controller + "/api/login",
                          body: JSON.stringify({ username: unifi_username, password: unifi_password }),
                          headers: { 'Content-Type': 'application/json' }
                      }, (err, resp) => {
                      if(!err) {
                          console.log("Login war erfolgreich!");
                          getStatus();
                      } else {
                          console.log("Login Fehler! " + err);
              function getStatus() {
                  request.get(unifi_controller + "/api/s/default/rest/wlanconf/" + wifi_id, (err, resp) => {
                      if(!err) {
                          console.log("Status erfolgreich geholt!");
                          console.log(resp);
                          let status = JSON.parse(resp);
                          let wlanOn = status.data[0].enabled;
                          console.log("WLAN ist: " + (wlanOn ? "an" : "aus"));
                      } else {
                          console.log("Status konnte nicht geholt werden. " + err);
              login();
              Meine Adapter: emby | discovery
              dslraserD liv-in-skyL 3 Antworten Letzte Antwort
              • thewhoboxT thewhobox
                function login() {
                    request.post({
                        }, (err, resp) => {
                        if(!err) {
                            getStatus();
                        } else {
                        if(!err) {
                            console.log(resp);
                        } else {
                login();
                dslraserD
                dslraserD
                dslraser
                #315
                @thewhobox
                danke Dir, probiere ich heute Abend mal aus. Ich sage hier Bescheid ob es funktioniert.
                  function login() {
                      request.post({
                          }, (err, resp) => {
                          if(!err) {
                              getStatus();
                          } else {
                          if(!err) {
                              console.log(resp);
                          } else {
                  login();
                  liv-in-skyL
                  liv-in-skyL
                  #316
                  @thewhobox hi,
                  bekomme das zurück
                  unifiWLAN: Login Fehler! Error: self signed certificate
                    function login() {
                        request.post({
                            }, (err, resp) => {
                            if(!err) {
                                getStatus();
                            } else {
                            if(!err) {
                                console.log(resp);
                            } else {
                    login();
                    dslraserD
                    dslraserD
                    dslraser
                    #317
                    @thewhobox
                    habe es doch schnell probiert, gleicher Fehler wie @liv-in-sky
                      @thewhobox hi,
                      bekomme das zurück
                      thewhoboxT
                      thewhoboxT
                      thewhobox
                      schrieb am zuletzt editiert von thewhobox
                      #318
                      @liv-in-sky @dslraser dann probiert mal in der ersten zeile
                      const request = require('request').defaults({ rejectUnauthorized: false });
                      dslraserD liv-in-skyL 4 Antworten Letzte Antwort
                        dslraserD
                        dslraserD
                        dslraser
                        #319
                        @thewhobox sagte in Adapter: ioBroker.unifi:
                        18:10:40.222	error	javascript.0 script.js.Heiko.04Telegram.Unifi: SyntaxError: Unexpected token o in JSON at position 1
                        18:10:40.222	error	javascript.0 at Request.request.get [as _callback] (script.js.Heiko.04Telegram.Unifi:29:31)
                          liv-in-skyL
                          liv-in-skyL
                          #320
                          @thewhobox
                            dslraserD
                            dslraserD
                            dslraser
                            #321
                            @thewhobox
                            javascript.0	2019-08-26 18:12:12.553	error	at endReadableNT (_stream_readable.js:1145:12)
                            javascript.0	2019-08-26 18:12:12.553	error	at IncomingMessage.emit (events.js:203:15)
                            javascript.0	2019-08-26 18:12:12.553	error	at Object.onceWrapper (events.js:286:20)
                            javascript.0	2019-08-26 18:12:12.553	error	at IncomingMessage.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/request/request.js:1083:12)
                            javascript.0	2019-08-26 18:12:12.553	error	at Request.emit (events.js:198:13)
                            javascript.0	2019-08-26 18:12:12.553	error	at Request.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/request/request.js:1161:10)
                            javascript.0	2019-08-26 18:12:12.553	error	at Request.self.callback (/opt/iobroker/node_modules/iobroker.javascript/node_modules/request/request.js:185:22)
                            javascript.0	2019-08-26 18:12:12.553	error	at Request.request.get [as _callback] (script.js.Heiko.04Telegram.Unifi:29:31)
                            javascript.0	2019-08-26 18:12:12.553	error	at JSON.parse (<anonymous>:null:null)
                            javascript.0	2019-08-26 18:12:12.552	error	script.js.Heiko.04Telegram.Unifi: SyntaxError: Unexpected token o in JSON at position 1
                            javascript.0	2019-08-26 18:12:12.552	info	script.js.Heiko.04Telegram.Unifi: {'statusCode':401,'body':'{\'meta\':{\'rc\':\'error\',\'msg\':\'api.err.LoginRequired\'},\'data\':[]}','headers':{'cache-control':'private','expires':'Thu, 01 Jan 19
                              liv-in-skyL
                              liv-in-skyL
                              #322
                              @thewhobox
                              falls nützlich: info vor fehler
                              javascript.2 script.js.Armin_Schalter.ALLERLEI.UnifiWLAN1: {'statusCode':401,'body':'{\'meta\':{\'rc\':\'error\',\'msg\':\'api.err.LoginRequired\'},\'data\':[]}','headers':{'cache-control':'private','expires':'Thu, 01 Jan 1970 00:00:00 GMT','vary':'Origin','access-control-allow-credentials':'true','access-control-expose-headers':'Access-Control-Allow-Origin,Access-Control-Allow-Credentials','x-frame-options':'DENY','content-type':'application/json;charset=UTF-8','content-length':'63','date':'Mon, 26 Aug 2019 16:15:40 GMT','connection':'close'},'request':{'uri':{'protocol':'https:','slashes':true,'auth':null,'host':'192.168.178.157:8443','port':'8443','hostname':'192.168.178.157','hash':null,'search':null,'query':null,'pathname':'/api/s/default/rest/wlanconf/5cadxxxxxxxxxxxxd7e5381','path':'/api/s/default/rest/wlanconf/5cadxxxxxxxxxxdd7e5381','href':'https://192.168.178.157:8443/api/s/default/rest/wlanconf/5cadca8e3b6a3967dd7e5381'},'method':'GET','headers':{}}}
                                @thewhobox
                                dslraserD
                                dslraserD
                                dslraser
                                #323
                                @liv-in-sky
                                @thewhobox
                                das aus aus dem Log unterm Script
                                26.8.2019, 18:16:40.833	[info ]: javascript.0 Start javascript script.js.Heiko.Unifi.unifi_wifi
                                26.8.2019, 18:16:40.833	[info ]: javascript.0 script.js.Heiko.Unifi.unifi_wifi: registered 0 subscriptions and 0 schedules
                                26.8.2019, 18:16:41.126	[info ]: javascript.0 script.js.Heiko.Unifi.unifi_wifi: Login war erfolgreich!
                                26.8.2019, 18:16:41.149	[info ]: javascript.0 script.js.Heiko.Unifi.unifi_wifi: Status erfolgreich geholt!
                                26.8.2019, 18:16:41.149	[info ]: javascript.0 script.js.Heiko.Unifi.unifi_wifi: {'statusCode':401,'body':'{\'meta\':{\'rc\':\'error\',\'msg\':\'api.err.LoginRequired\'},\'data\':[]}','headers':{'cache-control':'private','expires':'Thu, 01 Jan 1970 00:00:00 GMT','vary':'Origin','access-control-allow-credentials':'true','access-control-expose-headers':'Access-Control-Allow-Origin,Access-Control-Allow-Credentials','x-frame-options':'DENY','content-type':'application/json;charset=UTF-8','content-length':'63','date':'Mon, 26 Aug 2019 16:16:41 GMT','connection':'close'},'request':{'uri':{'protocol':'https:','slashes':true,'auth':null,'host':'192.168.180.110:8443','port':'8443','hostname':'192.168.180.110','hash':null,'search':null,'query':null,'pathname':'/api/s/default/rest/wlanconf/5d3c5be0bc96040011365fe5','path':'/api/s/default/rest/wlanconf/5d3c5be0bc96040011365fe5','href':'https://192.168.180.110:8443/api/s/default/rest/wlanconf/5d3c5be0bc96040011365fe5'},'method':'GET','headers':{}}}
                                26.8.2019, 18:16:41.149	[error]: javascript.0 script.js.Heiko.Unifi.unifi_wifi: SyntaxError: Unexpected token o in JSON at position 1
                                26.8.2019, 18:16:41.149	[error]: javascript.0     at Request.request.get [as _callback] (script.js.Heiko.Unifi.unifi_wifi:29:31)
                                thewhoboxT 2 Antworten Letzte Antwort
                                  @liv-in-sky
                                  @thewhobox
                                  thewhoboxT
                                  thewhoboxT
                                  thewhobox
                                  #324
                                  @dslraser Okay, dann speichert er leider den Login cookie nicht automatisch. Muss ich mir heute Abend nochmal anschauen
                                    @liv-in-sky
                                    @thewhobox
                                    thewhoboxT
                                    thewhoboxT
                                    thewhobox
                                    #325
                                    @dslraser @liv-in-sky Könnte einer von euch mal nach "Login erfolgreich" folgende Zeilen einfügen?
                                    console.log('HEADERS: ' + JSON.stringify(resp.headers));
                                    onsole.log('Cookies: ' + resp.getHeader("Set-Cookie"));
                                      liv-in-skyL
                                      liv-in-skyL
                                      #326
                                      moin @thewhobox
                                        moin @thewhobox
                                        thewhoboxT
                                        thewhoboxT
                                        thewhobox
                                        #327
                                        @liv-in-sky Moin. Danke fürs ausprobieren. Hier nochmal das angepasste Script für die cookies.
                                        Edit: Siehe unten
                                        liv-in-skyL dslraserD 2 Antworten Letzte Antwort
                                          Edit: Siehe unten
                                          liv-in-skyL
                                          liv-in-skyL
                                          #328
                                          @thewhobox - danke fürs programmieren
                                          jetzt kommt der erste fehler wieder :-(
                                          bei "const request = require('request');"
                                          10:08:00.824	info	javascript.2 Stop script script.js.Armin_Schalter.ALLERLEI.UnifiWLAN1
                                          10:08:01.924	info	javascript.2 Start javascript script.js.Armin_Schalter.ALLERLEI.UnifiWLAN1
                                          10:08:01.924	info	javascript.2 script.js.Armin_Schalter.ALLERLEI.UnifiWLAN1: registered 0 subscriptions and 0 schedules
                                          10:08:01.941	info	javascript.2 script.js.Armin_Schalter.ALLERLEI.UnifiWLAN1: Login Fehler! Error: self signed certificate
                                          10:08:03.833	info	javascript.2 Stop script script.js.Armin_Schalter.ALLERLEI.UnifiWLAN1
                                          bei "const request = require('request').defaults({ rejectUnauthorized: false });"
                                          33.2k
                                          84.3k
