  4. [Aufruf] Nina Gefahrenmeldung Adapter
ninakatwarngefahrengefahrenwarner
383 Beiträge 64 Kommentatoren 113.1k Aufrufe 60 Beobachtet
  • NashraN Nashra
    Moin, was ist denn jetzt los?
    Schau vorhin ins Log und sehe dies
    nina.0	2019-08-08 17:32:24.188	info	u C���Ć�S7�����Q��Û����a�7<���o�2�h�9w�Ɲ#�9w><~◡u���2��{��J@�P��wN�XpBgʭ��Ι.��_��WNGc����(� -��,H�ͮbǎ2�ܺ�Cֆr�N~ÄH�lŁ�V�E(�5�+w5����n��e�2|�/�"GsC�a�Ұ ��W�-Ĩ䠰�9D����4�R�G��� )!��8
    nina.0	2019-08-08 17:32:24.188	info	��>E�4Φn��:6A/�9�����s~�t��!ui�W]v��!j�)6�n�ÆFĭcߔ8xe0�dO�|�a4�N逊��QU�p�d/��W��?�<l�}�a: p+�x\�����p'Ά�IӀ��&c��$B�x��������#tJ2�^,@ž{��9>���,�R��1�n�j!!"��Ev,b��Z"�=b$��`��o
    nina.0	2019-08-08 17:32:24.188	info	�ii�IH<B�6�p"ϧ�g��X��h%���2@Ĵ>�H��'l�3�D�A��G� ���-��� �l�4I��!_�c��ra%&��+ c���;�xb� ����#�c���0"�]��1L%`Y~�ݔ�Fua�d^}��)��@�D -Po�(��q, �ɀ��H '�bA���]B�G��A#��,�
    nina.0	2019-08-08 17:32:24.188	info	�@�g)0�A��\��,��>d?��Wp�!PG5��`���=��)��Gl��4!'�:D?�QdD�@�1�8��fqd�OA�ZQd��Y��AD}�!f�"d$�i� b�Bƭ!-d�iT"�HF2�A�d$IN�U��d0�I�&ĉ�@��PPɏ��j�Hc2ƌz���m}�Y��M�u�f�
    nina.0	2019-08-08 17:32:24.188	info	'�3�F:�T�a�[�Ki�5��#�/j��`my���hy�H��D��q,o ����w����9�E�1-�0����θ���v�4�7��p��H�������F�_��}�yYž_|B��-�-O}ᬊ���U�/��:��0|��<)��D���pW��.�.ٶS]�l�v�+�g��.�h�*�;8���"�V��F��u]A�+�
    nina.0	2019-08-08 17:32:24.188	info	3gr@#�8Ic�����4��Q7��h\����R�7v�����p����~����J��ޖr
    nina.0	2019-08-08 17:32:24.188	info	|�>��+�I��%?�P0.s ����L�&�pBG'�wR�'�~R#8����:ƙ:B�*n�&@!��"3�"�73�#(�`?��X�dT�mM���h3�&�ݔ�I>x8n~�ٟ�"���>�2LN���F�_k�UG#�{a�UG#��{4�����~�)[ݴM�r�����J��K�^cⲋ�n:�}��-�Ch|Aý�;��aM�
    nina.0	2019-08-08 17:32:24.188	info	�>m�Wz�[�ȩ'����T���ւe�es��������X#���F�am�M�3T X�~����L:��1wt��M���]trs��ڸ��8�� �sr��n�/�u׿���[.!�iz�߀��fqh�tqh�ߕ"߄�FJ�9���J�* ���3(,a�4| ��4�I[�4�I���IÝ4��~�( �҈( ���( ��h�XB�q8��
    nina.0	2019-08-08 17:32:24.188	info	P����1����Zi�wζ��m1U��9��=��A�T�K��ؓ0>+�xރG�@٘��k�,ޯ���h(���b�TYP�j-���dM�`fL���D'O&W�i�vi��8� ���'����k���}�&, �h0�Ih,��a�a�3 LPn�K�4�
    nina.0	2019-08-08 17:32:24.188	info	P�R�K;% � �)��[y%0Yh���Si`S��r.�
    nina.0	2019-08-08 17:32:24.188	info	���4��n5�C��r��A���f S�� �F����ˆk�ֱ�Q��� �9��&e�B�"�:>8`-�` �&��[h� ��)�p����H�y=�(�Uc�y��Q�Ǫ���pr���h�/�~IK4�^,���VE"��O�x�UC�� ?�ˆ�{,�X�D�~"�>�->l�z�Ϡjr�{��-]��咗�A����g�
    nina.0	2019-08-08 17:32:24.188	info	0y[K�-���!�i�R�D�,h�bk/�-T�c)6��d����܄5Y�eFH\>�Y��Y�}(�f) *�G���յ�@��h��b����j�r��A)xX�C�A$�CRu$�JR�4SG4UR�5璂f��`���JV;g�S6,��E�-����K�9׎�J�;2ޫ��̵��Ը}T\:A�W78�}��A��:�˃,������
    nina.0	2019-08-08 17:32:24.188	info	F�� �]^��t_�Ѷ�*�Ѻ�������ԿЧ���Ӌ����z�xQ��v񯥚�g��C����3<����o��<9����_�T;�-�J_|}��_���-v���K�^�}�>�]yџmw��l]뼢�>�oN>~_�����#g�ſ�3�;:t>T҅��f�V��j}p]���u&4� ����ո�}H���Sg�6�q�ڤzO0��a ��0�
    nina.0	2019-08-08 17:32:24.188	info	t�9�>��:|hf%�ql&�N '��Z$!J�v\���9�(-�4�"��kCuGT� � 2�h�B�PC���0��8�oH�ǥD����ǁ�ԓ���ͣ �e(�p(�H�|��������M�ۗ��%ܘy����޽wt���q`
    nina.0	2019-08-08 17:32:24.188	info	Z̬x�A�\�/�0C�c�*�AC �=��L��%(�X��*U�"��rE���XU�ߨ�S���:�d�]��Ώ�SU�<C�#�<�h
    nina.0	2019-08-08 17:32:24.188	info	ʹ6�# �Vhi�J��:]�$*�E�����%�_$w�E�����GY*��*�R�AS$mF|�G$�.�l5*W^��A�@{�Ǽ�P���l�9=�J��Ha����*# ]X�d(���j2�@�~V�f̯�����4��P�r��4p
    nina.0	2019-08-08 17:32:24.188	info	����>�`l
    nina.0	2019-08-08 17:32:24.188	info	k�̨tM3'�GW�U��%PF 0H=}�q��4����"�"��"�8��G�0]����
    nina.0	2019-08-08 17:32:24.188	info	m��Z�mY:������8��R2<}v��<]|����g��mp�7]a?�=.�X#��<yT������|u�$J(<��k�ve��k���e�+��r��[_�C���v�tM�l�Y�+��Ժn���G�
    nina.0	2019-08-08 17:32:24.188	info	� ���֠%�A-�p�:>R�pM�#v����9�{;@���h��8�P��2q�p8\��JetX5��q��H8\����W���Fe�J�J����Şw��=����i.`OQe7J�$z4���.���o����پx��:�3�_��ܯ����^���n�3S���#�l�m�b����~�Cߕ?w�Q�����޼'�^n
    nina.0	2019-08-08 17:32:24.188	info	P#1�Ž���#>�TdH8IqÇ '|�SgY0,!'�mj��]<��)�(m��$��Ob�^�@I�2%��T�V�i%ޕXx�����k��,�vܰ�' ���@w�E��{h
    nina.0	2019-08-08 17:32:24.188	info	z*7�9��$X
    nina.0	2019-08-08 17:32:24.188	info	�5�|���.?^u��2c�Y k��<�ꤸ2)H2�� ��1V$,�rg��f�ypeX�BnEg!9=)�8�ѿ1�6"si�������HH��.�X�4,��ne4��<��!� �-F�$J��kVHh���!п3R��i3�0�&R�nR�C-u���Ay���� �Wh 6��������b����g<e�epmgtY
    nina.0	2019-08-08 17:32:24.188	info	lCm :��-��֞C�y� u5a*�h��B�~"�h?Y�Jc`�*���Q��x���<rz��y2�92�|ހ,��0HX_Jӹ�"�+H�i@΄a��'��W<^8ˬ'�H�4������%��(�#��U�,��:�fR!��E�c�"ZHkV���K� a=;�B�>���63b� 7A���r�ߵ���ö_���������
    nina.0	2019-08-08 17:32:24.188	info	CK��!aiDEe$L\�i��:�33N�%L�'ɢ��
    nina.0	2019-08-08 17:32:24.188	info	�s�o��/�eW��N�mu����]�騲{w���]R�_�K���������ڶ��o���W�"��'*��>��3k>S��T�_U���ծV����fuYj�S���~���X�*��6�Zg��Jn����Um剺]�j���zsZ䜜��u��//�<��P_�m�n��V/H�$�@R��,I)WI'_%�)��2�eH>!g"�R�5�$�!Y��!�SN��I
    nina.0	2019-08-08 17:32:24.188	info	��@L]�]ێGr���y�a���E��f�X�HJ,���gz���������/��a����1gƉ��(�({��y��b�1����9����d����z��'��,��t�K�ҽZ���2y��حB�C�l\�Y�֥��֧�6���&5ɞ�:�؝>��e_
    nina.0	2019-08-08 17:32:24.185	error	Parse error:SyntaxError: Unexpected token  in JSON at position 0 {}
    Es wurde nichts am System geändert.
    tombox
    #120
    @Nashra Die Webseite sendet manchmal komische Sachen. Ich wollte nur mal sehen wie es aussieht. Ich werde die Information dann mal in Debug verschieben
    • T tombox
      NashraN Offline
      NashraN Offline
      Nashra
      Most Active Forum Testing
      #121
      @tombox sagte in [Aufruf] Nina Gefahrenmeldung Adapter:
      Gruß Ralf
      siggi85S 1 Antwort Letzte Antwort
      • NashraN Nashra
        siggi85S Offline
        siggi85S Offline
        siggi85
        schrieb am zuletzt editiert von siggi85
        #122
        Ich habe einen Trigger auf "nina.0.Beispielwarnung.numberOfWarn" gesetzt der bei Änderung aktiv werden soll. Jedoch wird dieser Wert bei jedem Pollzyklus des Adapters auf 0 gesetzt und dann wieder hoch. Kann man das unterbinden? Wie finde ich heraus ob es eine neue Warnung oder eine bestehende gibt?
        Kann man "nina.0.Beispielwarnung.warnung01.identifier" nutzen um eine Warnung eindeutig zu identifizieren? (Aktuell bei mir der Wert: "HOCHWASSERZENTRALEN.DE.BB") Sodass man ggf. prüfen kann, ob man auf diese bereits reagiert hat?
        T 2 Antworten Letzte Antwort
        • siggi85S siggi85
          tombox
          #123
          @siggi85 ich werde das noch verbessern
          • T tombox
            siggi85S Offline
            siggi85S Offline
            siggi85
            #124
            Alles klar, hat keine Priorität, Google-IOT Anbindung ist wichtiger!!! 🙈 😁
            • siggi85S siggi85
              tombox
              #125
              @siggi85 Ich habe die numberofwarns verbessert das sie nicht vorher auf 0 gesetzt werden.
              Über github link installieren und testen ob noch alles geht
              • L Offline
                Lordcyber
                schrieb am zuletzt editiert von Lordcyber
                #126
                ich bekomme den nicht auf Grün.
                Bleibt auf Gelb stehen
                AGS hab ich 08315
                im Log steht:
                nina.0	2019-08-24 00:48:32.028	error	{}
                nina.0	2019-08-24 00:48:32.027	error	{"errno":"EPROTO","code":"EPROTO","syscall":"write"}
                nina.0	2019-08-24 00:48:32.024	error	{}
                nina.0	2019-08-24 00:48:32.024	error	{"errno":"EPROTO","code":"EPROTO","syscall":"write"}
                nina.0	2019-08-24 00:48:32.023	error	{}
                nina.0	2019-08-24 00:48:32.021	error	{"errno":"EPROTO","code":"EPROTO","syscall":"write"}
                nina.0	2019-08-24 00:52:45.083	info	starting. Version 0.0.5 in /opt/iobroker/node_modules/iobroker.nina, node: v10.16.3
                Iobroker ist neu aufgesetzt.
                Mike
                Thinkcentre M92 mit Proxmox / Iobroker als VM unter Debian
                • L Lordcyber
                  AGS hab ich 08315
                  im Log steht:
                  tombox
                  #127
                  @Lordcyber sicher ein Debian buster. Siehe Hinweis im ersten Beitrag.
                  • T tombox
                    siggi85S Offline
                    siggi85S Offline
                    siggi85
                    #128
                    Sieht besser aus. :)👍
                    • arteckA Offline
                      arteckA Offline
                      arteck
                      #129
                      @tombox ich hab da einen
                      in 0.0.6
                      • arteckA arteck
                        in 0.0.6
                        tombox
                        #130
                        @arteck passiert manchmal wenn die Seite falsche Daten lieferst
                        • T tombox
                          arteckA Offline
                          arteckA Offline
                          arteck
                          #131
                          @tombox pack da ein try catch block drumherum
                          • arteckA arteck
                            tombox
                            #132
                            @arteck ist schon aber trotzdem musst ein Rückmeldung passiere
                              skokarl
                              #133
                              Moin,
                              in Passau liegt eine Warnung vor.
                              hier
                              Ich vermute mal es ist die 09262 oder die 09275.
                              Leider zeigt der Adpater Warnung 0 an.
                              Ich wollte es nur mal testen. Jemand eine Idee ?
                              • S skokarl
                                Moin,
                                hier
                                sigi234S Online
                                sigi234S Online
                                #134
                                @skokarl sagte in [Aufruf] Nina Gefahrenmeldung Adapter:
                                Moin,
                                hier
                                Bei mir kommt auch nix.
                                • sigi234S sigi234
                                  Moin,
                                  hier
                                  skokarl
                                  #135
                                  @sigi234
                                  müsste aber doch ?, oder nicht ?
                                  • S skokarl
                                    @sigi234
                                    sigi234S Online
                                    sigi234S Online
                                    #136
                                    @sigi234
                                    Eigentlich schon, die BSP Warung wird aber angezeigt.
                                      skokarl
                                      #137
                                      die Beispielwarnung ?
                                      Nee, wir wollen schon mal ne echte Warnung um zu sehen ob der Adapter überhaupt funktioniert. 😁
                                      • S skokarl
                                        tombox
                                        #138
                                        @skokarl
                                        Also hier sind alle aktuelle Warnungen
                                        https://warnung.bund.de/bbk.mowas/gefahrendurchsagen.json
                                        Da habe ich nur Warnungen für Gersthofen, Espenhain, Peine
                                        https://warnung.bund.de/bbk.dwd/unwetter.json
                                        Schwere Unwetterwarnung für Freising/Kelheim und Weilheim-Schongau
                                        siggi85S S 2 Antworten Letzte Antwort
                                        • T tombox
                                          @skokarl
                                          siggi85S Offline
                                          siggi85S Offline
                                          siggi85
                                          #139
                                          Bei uns war Mitte der Woche eine Warnung und der Adapter hat es ordnungsgemäß angezeigt.
