  4. [Aufruf] Nina Gefahrenmeldung Adapter
ninakatwarngefahrengefahrenwarner
383 Beiträge 64 Kommentatoren 113.1k Aufrufe 60 Beobachtet
  • NashraN Offline
    NashraN Offline
    Nashra
    Most Active Forum Testing
    #117
    Moin, was ist denn jetzt los?
    Schau vorhin ins Log und sehe dies
    nina.0	2019-08-08 17:32:24.188	info	u C���Ć�S7�����Q��Û����a�7<���o�2�h�9w�Ɲ#�9w><~◡u���2��{��J@�P��wN�XpBgʭ��Ι.��_��WNGc����(� -��,H�ͮbǎ2�ܺ�Cֆr�N~ÄH�lŁ�V�E(�5�+w5����n��e�2|�/�"GsC�a�Ұ ��W�-Ĩ䠰�9D����4�R�G��� )!��8
    nina.0	2019-08-08 17:32:24.188	info	��>E�4Φn��:6A/�9�����s~�t��!ui�W]v��!j�)6�n�ÆFĭcߔ8xe0�dO�|�a4�N逊��QU�p�d/��W��?�<l�}�a: p+�x\�����p'Ά�IӀ��&c��$B�x��������#tJ2�^,@ž{��9>���,�R��1�n�j!!"��Ev,b��Z"�=b$��`��o
    nina.0	2019-08-08 17:32:24.188	info	�ii�IH<B�6�p"ϧ�g��X��h%���2@Ĵ>�H��'l�3�D�A��G� ���-��� �l�4I��!_�c��ra%&��+ c���;�xb� ����#�c���0"�]��1L%`Y~�ݔ�Fua�d^}��)��@�D -Po�(��q, �ɀ��H '�bA���]B�G��A#��,�
    nina.0	2019-08-08 17:32:24.188	info	�@�g)0�A��\��,��>d?��Wp�!PG5��`���=��)��Gl��4!'�:D?�QdD�@�1�8��fqd�OA�ZQd��Y��AD}�!f�"d$�i� b�Bƭ!-d�iT"�HF2�A�d$IN�U��d0�I�&ĉ�@��PPɏ��j�Hc2ƌz���m}�Y��M�u�f�
    nina.0	2019-08-08 17:32:24.188	info	'�3�F:�T�a�[�Ki�5��#�/j��`my���hy�H��D��q,o ����w����9�E�1-�0����θ���v�4�7��p��H�������F�_��}�yYž_|B��-�-O}ᬊ���U�/��:��0|��<)��D���pW��.�.ٶS]�l�v�+�g��.�h�*�;8���"�V��F��u]A�+�
    nina.0	2019-08-08 17:32:24.188	info	3gr@#�8Ic�����4��Q7��h\����R�7v�����p����~����J��ޖr
    nina.0	2019-08-08 17:32:24.188	info	|�>��+�I��%?�P0.s ����L�&�pBG'�wR�'�~R#8����:ƙ:B�*n�&@!��"3�"�73�#(�`?��X�dT�mM���h3�&�ݔ�I>x8n~�ٟ�"���>�2LN���F�_k�UG#�{a�UG#��{4�����~�)[ݴM�r�����J��K�^cⲋ�n:�}��-�Ch|Aý�;��aM�
    nina.0	2019-08-08 17:32:24.188	info	�>m�Wz�[�ȩ'����T���ւe�es��������X#���F�am�M�3T X�~����L:��1wt��M���]trs��ڸ��8�� �sr��n�/�u׿���[.!�iz�߀��fqh�tqh�ߕ"߄�FJ�9���J�* ���3(,a�4| ��4�I[�4�I���IÝ4��~�( �҈( ���( ��h�XB�q8��
    nina.0	2019-08-08 17:32:24.188	info	P����1����Zi�wζ��m1U��9��=��A�T�K��ؓ0>+�xރG�@٘��k�,ޯ���h(���b�TYP�j-���dM�`fL���D'O&W�i�vi��8� ���'����k���}�&, �h0�Ih,��a�a�3 LPn�K�4�
    nina.0	2019-08-08 17:32:24.188	info	P�R�K;% � �)��[y%0Yh���Si`S��r.�
    nina.0	2019-08-08 17:32:24.188	info	���4��n5�C��r��A���f S�� �F����ˆk�ֱ�Q��� �9��&e�B�"�:>8`-�` �&��[h� ��)�p����H�y=�(�Uc�y��Q�Ǫ���pr���h�/�~IK4�^,���VE"��O�x�UC�� ?�ˆ�{,�X�D�~"�>�->l�z�Ϡjr�{��-]��咗�A����g�
    nina.0	2019-08-08 17:32:24.188	info	0y[K�-���!�i�R�D�,h�bk/�-T�c)6��d����܄5Y�eFH\>�Y��Y�}(�f) *�G���յ�@��h��b����j�r��A)xX�C�A$�CRu$�JR�4SG4UR�5璂f��`���JV;g�S6,��E�-����K�9׎�J�;2ޫ��̵��Ը}T\:A�W78�}��A��:�˃,������
    nina.0	2019-08-08 17:32:24.188	info	F�� �]^��t_�Ѷ�*�Ѻ�������ԿЧ���Ӌ����z�xQ��v񯥚�g��C����3<����o��<9����_�T;�-�J_|}��_���-v���K�^�}�>�]yџmw��l]뼢�>�oN>~_�����#g�ſ�3�;:t>T҅��f�V��j}p]���u&4� ����ո�}H���Sg�6�q�ڤzO0��a ��0�
    nina.0	2019-08-08 17:32:24.188	info	t�9�>��:|hf%�ql&�N '��Z$!J�v\���9�(-�4�"��kCuGT� � 2�h�B�PC���0��8�oH�ǥD����ǁ�ԓ���ͣ �e(�p(�H�|��������M�ۗ��%ܘy����޽wt���q`
    nina.0	2019-08-08 17:32:24.188	info	Z̬x�A�\�/�0C�c�*�AC �=��L��%(�X��*U�"��rE���XU�ߨ�S���:�d�]��Ώ�SU�<C�#�<�h
    nina.0	2019-08-08 17:32:24.188	info	ʹ6�# �Vhi�J��:]�$*�E�����%�_$w�E�����GY*��*�R�AS$mF|�G$�.�l5*W^��A�@{�Ǽ�P���l�9=�J��Ha����*# ]X�d(���j2�@�~V�f̯�����4��P�r��4p
    nina.0	2019-08-08 17:32:24.188	info	����>�`l
    nina.0	2019-08-08 17:32:24.188	info	k�̨tM3'�GW�U��%PF 0H=}�q��4����"�"��"�8��G�0]����
    nina.0	2019-08-08 17:32:24.188	info	m��Z�mY:������8��R2<}v��<]|����g��mp�7]a?�=.�X#��<yT������|u�$J(<��k�ve��k���e�+��r��[_�C���v�tM�l�Y�+��Ժn���G�
    nina.0	2019-08-08 17:32:24.188	info	� ���֠%�A-�p�:>R�pM�#v����9�{;@���h��8�P��2q�p8\��JetX5��q��H8\����W���Fe�J�J����Şw��=����i.`OQe7J�$z4���.���o����پx��:�3�_��ܯ����^���n�3S���#�l�m�b����~�Cߕ?w�Q�����޼'�^n
    nina.0	2019-08-08 17:32:24.188	info	P#1�Ž���#>�TdH8IqÇ '|�SgY0,!'�mj��]<��)�(m��$��Ob�^�@I�2%��T�V�i%ޕXx�����k��,�vܰ�' ���@w�E��{h
    nina.0	2019-08-08 17:32:24.188	info	z*7�9��$X
    nina.0	2019-08-08 17:32:24.188	info	�5�|���.?^u��2c�Y k��<�ꤸ2)H2�� ��1V$,�rg��f�ypeX�BnEg!9=)�8�ѿ1�6"si�������HH��.�X�4,��ne4��<��!� �-F�$J��kVHh���!п3R��i3�0�&R�nR�C-u���Ay���� �Wh 6��������b����g<e�epmgtY
    nina.0	2019-08-08 17:32:24.188	info	lCm :��-��֞C�y� u5a*�h��B�~"�h?Y�Jc`�*���Q��x���<rz��y2�92�|ހ,��0HX_Jӹ�"�+H�i@΄a��'��W<^8ˬ'�H�4������%��(�#��U�,��:�fR!��E�c�"ZHkV���K� a=;�B�>���63b� 7A���r�ߵ���ö_���������
    nina.0	2019-08-08 17:32:24.188	info	CK��!aiDEe$L\�i��:�33N�%L�'ɢ��
    nina.0	2019-08-08 17:32:24.188	info	�s�o��/�eW��N�mu����]�騲{w���]R�_�K���������ڶ��o���W�"��'*��>��3k>S��T�_U���ծV����fuYj�S���~���X�*��6�Zg��Jn����Um剺]�j���zsZ䜜��u��//�<��P_�m�n��V/H�$�@R��,I)WI'_%�)��2�eH>!g"�R�5�$�!Y��!�SN��I
    nina.0	2019-08-08 17:32:24.188	info	��@L]�]ێGr���y�a���E��f�X�HJ,���gz���������/��a����1gƉ��(�({��y��b�1����9����d����z��'��,��t�K�ҽZ���2y��حB�C�l\�Y�֥��֧�6���&5ɞ�:�؝>��e_
    nina.0	2019-08-08 17:32:24.185	error	Parse error:SyntaxError: Unexpected token  in JSON at position 0 {}
    Es wurde nichts am System geändert.
    Gruß Ralf
    H T 2 Antworten Letzte Antwort
    • NashraN Nashra
      hanswurst0815
      #118
      @Nashra
      Ja, das gleiche habe ich mittlerweile auch im Log.
      • T tombox
        @womber Tut mir leid. Das ist wirklich ein sehr kurzer Fehler. Es ist irgendein Netzwerkfehler. Es könnte ein Proxyproblem sein oder ssl. Sehr schwierig. Vielleicht der Pi4 der noch im Betriebssystem ein Fehler hat.
        reloxx13R Offline
        reloxx13R Offline
        reloxx13
        #119
        @tombox ssl, die benutzen eine veraltete verschlüsselung die von openssl und nodejs10 nicht mehr unterstützt wird.
        RC4 cipher
        • NashraN Nashra
          tombox
          #120
          @Nashra Die Webseite sendet manchmal komische Sachen. Ich wollte nur mal sehen wie es aussieht. Ich werde die Information dann mal in Debug verschieben
          • T tombox
            NashraN Offline
            NashraN Offline
            Nashra
            #121
            @tombox sagte in [Aufruf] Nina Gefahrenmeldung Adapter:
            Gruß Ralf
            siggi85S 1 Antwort Letzte Antwort
            • NashraN Nashra
              siggi85S Offline
              siggi85S Offline
              siggi85
              schrieb am zuletzt editiert von siggi85
              #122
              Ich habe einen Trigger auf "nina.0.Beispielwarnung.numberOfWarn" gesetzt der bei Änderung aktiv werden soll. Jedoch wird dieser Wert bei jedem Pollzyklus des Adapters auf 0 gesetzt und dann wieder hoch. Kann man das unterbinden? Wie finde ich heraus ob es eine neue Warnung oder eine bestehende gibt?
              Kann man "nina.0.Beispielwarnung.warnung01.identifier" nutzen um eine Warnung eindeutig zu identifizieren? (Aktuell bei mir der Wert: "HOCHWASSERZENTRALEN.DE.BB") Sodass man ggf. prüfen kann, ob man auf diese bereits reagiert hat?
              • siggi85S siggi85
                tombox
                #123
                @siggi85 ich werde das noch verbessern
                • T tombox
                  siggi85S Offline
                  siggi85S Offline
                  siggi85
                  #124
                  Alles klar, hat keine Priorität, Google-IOT Anbindung ist wichtiger!!! 🙈 😁
                  • siggi85S siggi85
                    tombox
                    #125
                    @siggi85 Ich habe die numberofwarns verbessert das sie nicht vorher auf 0 gesetzt werden.
                    Über github link installieren und testen ob noch alles geht
                    • L Offline
                      Lordcyber
                      schrieb am zuletzt editiert von Lordcyber
                      #126
                      ich bekomme den nicht auf Grün.
                      Bleibt auf Gelb stehen
                      AGS hab ich 08315
                      im Log steht:
                      nina.0	2019-08-24 00:48:32.028	error	{}
                      nina.0	2019-08-24 00:48:32.027	error	{"errno":"EPROTO","code":"EPROTO","syscall":"write"}
                      nina.0	2019-08-24 00:48:32.024	error	{}
                      nina.0	2019-08-24 00:48:32.024	error	{"errno":"EPROTO","code":"EPROTO","syscall":"write"}
                      nina.0	2019-08-24 00:48:32.023	error	{}
                      nina.0	2019-08-24 00:48:32.021	error	{"errno":"EPROTO","code":"EPROTO","syscall":"write"}
                      nina.0	2019-08-24 00:52:45.083	info	starting. Version 0.0.5 in /opt/iobroker/node_modules/iobroker.nina, node: v10.16.3
                      Iobroker ist neu aufgesetzt.
                      Mike
                      Thinkcentre M92 mit Proxmox / Iobroker als VM unter Debian
                      • L Lordcyber
                        AGS hab ich 08315
                        im Log steht:
                        tombox
                        #127
                        @Lordcyber sicher ein Debian buster. Siehe Hinweis im ersten Beitrag.
                        • T tombox
                          siggi85S Offline
                          siggi85S Offline
                          siggi85
                          #128
                          Sieht besser aus. :)👍
                          • arteckA Offline
                            arteckA Offline
                            arteck
                            #129
                            @tombox ich hab da einen
                            in 0.0.6
                            • arteckA arteck
                              in 0.0.6
                              tombox
                              #130
                              @arteck passiert manchmal wenn die Seite falsche Daten lieferst
                              • T tombox
                                arteckA Offline
                                arteckA Offline
                                arteck
                                #131
                                @tombox pack da ein try catch block drumherum
                                • arteckA arteck
                                  tombox
                                  #132
                                  @arteck ist schon aber trotzdem musst ein Rückmeldung passiere
                                    skokarl
                                    #133
                                    Moin,
                                    in Passau liegt eine Warnung vor.
                                    hier
                                    Ich vermute mal es ist die 09262 oder die 09275.
                                    Leider zeigt der Adpater Warnung 0 an.
                                    Ich wollte es nur mal testen. Jemand eine Idee ?
                                    • S skokarl
                                      Moin,
                                      hier
                                      sigi234S Online
                                      sigi234S Online
                                      #134
                                      @skokarl sagte in [Aufruf] Nina Gefahrenmeldung Adapter:
                                      Moin,
                                      hier
                                      Bei mir kommt auch nix.
                                      • sigi234S sigi234
                                        Moin,
                                        hier
                                        skokarl
                                        #135
                                        @sigi234
                                        müsste aber doch ?, oder nicht ?
                                        • S skokarl
                                          @sigi234
                                          sigi234S Online
                                          sigi234S Online
                                          #136
                                          @sigi234
                                          Eigentlich schon, die BSP Warung wird aber angezeigt.
