  4. [gelöst] Flot Adapter defekt
    2.8k
    4.9k
    4.1k
flothab panel
76 Beiträge 5 Kommentatoren 4.6k Aufrufe 4 Beobachtet
  • AphofisA Offline
    AphofisA Offline
    Aphofis
    + system.adapter.admin.1                 : admin       -  enabled, port: 8086, bind: 0.0.0.0, run as: admin
    + system.adapter.alexa2.0                : alexa2      -  enabled
    + system.adapter.backitup.0              : backitup    -  enabled
    + system.adapter.cloud.0                 : cloud       -  enabled
      system.adapter.daswetter.0             : daswetter   -  enabled
    + system.adapter.email.0                 : email       -  enabled
      system.adapter.flot.0                  : flot        -  enabled
      system.adapter.harmony.0               : harmony     - disabled
    + system.adapter.hue.0                   : hue         -  enabled, port: 80
      system.adapter.ical.0                  : ical        -  enabled
      system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png -  enabled
      system.adapter.icons-fatcow-hosting.0  : icons-fatcow-hosting -  enabled
      system.adapter.icons-icons8.0          : icons-icons8 -  enabled
      system.adapter.icons-material-svg.0    : icons-material-svg -  enabled
      system.adapter.icons-mfd-svg.0         : icons-mfd-svg -  enabled
      system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png -  enabled
    + system.adapter.info.0                  : info        -  enabled
      system.adapter.iqontrol.0              : iqontrol    - disabled
    + system.adapter.javascript.0            : javascript  -  enabled
      system.adapter.linkeddevices.0         : linkeddevices - disabled
      system.adapter.moma.0                  : moma        - disabled
      system.adapter.node-red.0              : node-red    - disabled, port: 1880, bind: 0.0.0.0
    + system.adapter.rpi2.0                  : rpi2        -  enabled
    + system.adapter.simple-api.0            : simple-api  -  enabled, port: 8087, bind: 0.0.0.0 (SSL), run as: admin
    + system.adapter.socketio.0              : socketio    -  enabled, port: 8084, bind: 0.0.0.0 (SSL), run as: admin
    + system.adapter.sonoff.0                : sonoff      -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.sql.0                   : sql         -  enabled, port: 3306
    + system.adapter.statistics.0            : statistics  -  enabled
    + system.adapter.systeminfo.0            : systeminfo  -  enabled
    + system.adapter.telegram.0              : telegram    -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.telegram.1              : telegram    -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.text2command.1          : text2command -  enabled
      system.adapter.vis-bars.0              : vis-bars    -  enabled
      system.adapter.vis-canvas-gauges.0     : vis-canvas-gauges -  enabled
      system.adapter.vis-colorpicker.0       : vis-colorpicker -  enabled
      system.adapter.vis-fancyswitch.0       : vis-fancyswitch -  enabled
      system.adapter.vis-google-fonts.0      : vis-google-fonts -  enabled
      system.adapter.vis-history.0           : vis-history -  enabled
      system.adapter.vis-hqwidgets.0         : vis-hqwidgets -  enabled
      system.adapter.vis-justgage.0          : vis-justgage -  enabled
      system.adapter.vis-keyboard.0          : vis-keyboard -  enabled
      system.adapter.vis-material.0          : vis-material -  enabled
      system.adapter.vis-metro.0             : vis-metro   -  enabled
      system.adapter.vis-rgraph.0            : vis-rgraph  -  enabled
      system.adapter.vis-timeandweather.0    : vis-timeandweather -  enabled
      system.adapter.vis-weather.0           : vis-weather -  enabled
      system.adapter.vis.0                   : vis         -  enabled
    + system.adapter.web.0                   : web         -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + instance is alive
    • AphofisA Aphofis
      + instance is alive
      @Aphofis
      Zu viele aktive Instanzen für 1 GB RAM !
      • AphofisA Offline
        AphofisA Offline
        Aphofis
        Ist es so besser?
        + instance is alive
        nur was haben die laufenden Adapter damit zu tun das Flot nicht funktioniert???
        • AphofisA Aphofis
          Ist es so besser?
          + instance is alive
          sigi234S Online
          sigi234S Online
          @Aphofis sagte in Flot Adapter defekt:
          admin.1
          Warum admin1?
          • AphofisA Offline
            AphofisA Offline
            Aphofis
            schrieb am zuletzt editiert von Aphofis
            Sorry meiner späten Antwort keiner meiner Browser wollte eine Verbindung zum Forum aufbauen.
            Schreibe jetzt erstmal per Handy!
            Admin.1 weil mal der Admin.0 nicht mehr erreichbar war deswegen auch Port 8086 und nicht 8081
            Wie ich den Admin.0 zurück holen kann weiß ich auch nicht. Per ssh erstellen klappt nicht es wird nur ein Admin.2 erstellt aber 0 ist verschwunden.
            Nur was hat der Admin.1 mit flot zu tun!? Oder liegt es nur an den rechten.
            Hatte auch eine neue Admin Gruppe erstellt mit allen Rechten und alle Benutzer da rein gepackt. Alles läuft spitze nur der flot Adapter will nicht
            • AphofisA Offline
              AphofisA Offline
              Aphofis
              Habe jetzt den Flot Adapter noch mal neu installiert und er will einfach nicht funktionieren.
              Was kann ich bloß tun damit der Adapter endlich wieder geht.
              • AphofisA Aphofis
                sigi234S Online
                sigi234S Online
                @Aphofis
                Wie rufst du ihn auf?
                Was kommt bei F12?
                AphofisA 1 Antwort Letzte Antwort
                • sigi234S sigi234
                  @Aphofis
                  Was kommt bei F12?
                  AphofisA Offline
                  AphofisA Offline
                  Aphofis
                  @sigi234
                  Ich klicke den Button an um flot aufzurufen oder über Einstellungen eines datenpunktes sind keine Diagramme zu sehen von den in der Datenbank geloggten werte.
                  Wie meinen mit F12!?
                  Ich habe MacBook wenn’s die Taste F12 sein sollte.
                  sigi234S 2 Antworten Letzte Antwort
                  • AphofisA Aphofis
                    @sigi234
                    sigi234S Online
                    sigi234S Online
                    Wie sieht die Adresse im Browser aus?
                    • AphofisA Aphofis
                      @sigi234
                      sigi234S Online
                      sigi234S Online
                      Browserkonsole
                      • sigi234S sigi234
                        Browserkonsole
                        AphofisA Offline
                        AphofisA Offline
                        Aphofis
                        @sigi234
                        Gucke ich heute Abend
                        Nach der Arbeit!
                        Die Adresse ist:
                        http://192.168.0.30:8082/flot/edit.html
                        • AphofisA Aphofis
                          @sigi234
                          Nach der Arbeit!
                          Die Adresse ist:
                          sigi234S Online
                          sigi234S Online
                          @sigi234
                          Nach der Arbeit!
                          Die Adresse ist:
                          Zeig mal die Einstellungen vom WEB Adapter.......
                          • AphofisA Aphofis
                            @sigi234
                            Was genau meinst du zum System!?
                            Ist ein Raspberry Pi 3b+
                            Eine 16 GB Karte
                            Betriebssystem linux
                            Architektur arm
                            CPUs 4
                            Geschwindigkeit 1400 MHz
                            Modell ARMv7 Processor rev 4 (v7l)
                            RAM 926.08 MB
                            Node.js v8.16.0 (Recommended version v10.16.1)
                            NPM 6.10.1
                            Anzahl der Adapter 252
                            Betriebszeit 00:44:07
                            Browser ist Firefox unter Mac OSX Mojave
                            Popupblocker gibts nicht
                            Virenscanner auch nicht
                            Firewall ist Lulu
                            Aktive Instanzen 19
                            Vom Admin bekomme ich nach Sitzungsablauf sporadisch auch eine Permission error Meldung angezeigt per kleinem Pupup fenster.
                            Ja Flot lief schon mal !
                            In der Log steht dann noch das hier:
                            admin.1	2019-08-02 20:47:42.896	info	successful connection to socket.io from ::ffff:192.168.0.67
                            admin.1	2019-08-02 20:47:30.233	info	successful connection to socket.io from ::ffff:192.168.0.67
                            admin.1	2019-08-02 20:47:11.724	info	successful connection to socket.io from ::ffff:192.168.0.67
                            admin.1	2019-08-02 20:47:05.313	info	successful connection to socket.io from ::ffff:192.168.0.67
                            admin.1	2019-08-02 20:47:04.341	warn	No permission for "system.user.system.user.admin" to call getObjects. Need "object"."list"
                            admin.1	2019-08-02 20:47:04.333	warn	No permission for "system.user.system.user.admin" to call getStates. Need "state"."list"
                            admin.1	2019-08-02 20:47:04.211	warn	No permission for "system.user.system.user.admin" to call getObject. Need "object"."read"
                            admin.1	2019-08-02 20:47:04.202	warn	No permission for "system.user.system.user.admin" to call getObject. Need "object"."read"
                            admin.1	2019-08-02 20:47:04.194	warn	No permission for "system.user.system.user.admin" to call getObject. Need "object"."read"
                            admin.1	2019-08-02 20:47:04.184	warn	No permission for "system.user.system.user.admin" to call getUserPermissions. Need "object"."read"
                            Ist eigentlich 252 Adapter normal !?
                            Beim Update und Upgrade per ssh werden die normalen adapter angezeigt.
                            sigi234S Online
                            sigi234S Online
                            Das ist nur die Anzahl, installiert hast du 19
                            • sigi234S sigi234
                              AphofisA Offline
                              AphofisA Offline
                              Aphofis
                              @sigi234
                              Dann bin ich ja beruhigt !
                              Also wenn ich die Flot Seite Aufrufe ohne die edit.html kommt die Meldung
                              File index.html not found: permissionError
                              Aber wo muss diese Datei denn liegen im Ordner
                              /opt/ioBroker/ioBroker-Data/files/
                              Gibt es einen Ordner flot und einen Ordner flot.admin
                              In beiden Ordnern gibt es eine edit und eine index.html wo liegt denn da der Fehler in den Datei und Ordner rechten oder bei den Admin rechten selbst im ioBroker ???
                              • AphofisA Offline
                                AphofisA Offline
                                Aphofis
                                Web Adapter sieht folgendermaßen aus:
                                • AphofisA Aphofis
                                  sigi234S Online
                                  sigi234S Online
                                  Haken weg bei eingebautes simple api
                                  • sigi234S sigi234
                                    AphofisA Offline
                                    AphofisA Offline
                                    Aphofis
                                    Kommt immer noch die Meldung File edit.html
                                    Not found: permissionError
                                    Ich hab auch seid dem Admin.1
                                    Ab und an Login permissonerror auf der Hauptseite vom ioBroker muss dann Cookies löschen dann kann ich mich wieder einloggen
                                    • AphofisA Offline
                                      AphofisA Offline
                                      Aphofis
                                      Kann man nicht dem Admin.1 per ssh volle rechte irgendwie geben!? Ich hatte da mal was im Netz gesehen das man rechte per ssh an Admins vergeben kann
                                      • AphofisA Offline
                                        AphofisA Offline
                                        Aphofis
                                        Das kommt seid dem admin.1 auch ab und und und gerade jetzt mal wieder
                                        In /opt/iobroker/iobroker-data/files/
                                        Gibt es einen Ordner admin.0 und einen admin.admin aber keinen admin.1
                                        Ist das vielleicht der Fehler
                                        • AphofisA Aphofis
                                          sigi234S Online
                                          sigi234S Online
                                          Hast du mal den Fixer gemacht?
                                          curl -sL https://iobroker.net/fix.sh | bash -
