  4. [Diskussion] js-controller 1.5.14 in latest
js-controller
89 Beiträge 19 Kommentatoren 7.9k Aufrufe 20 Beobachtet
  • S steimi
    ich wollte das Update wagen - kommt aber folgende Fehlermeldung als root und iobroker-user. Installation ist vom 06.07.2019 mit InstallerVersion vom 3.7.2019
    423 warn bl@0.7.0 requires a peer of stream-browserify@* but none is installed. You must install peer dependencies yourself.
    424 verbose stack Error: EACCES: permission denied, access '/opt/iobroker/node_modules/iobroker.js-controller/node_modules/code-point-at'
    425 verbose cwd /opt/iobroker
    426 verbose Linux 4.19.0-5-amd64
    427 verbose argv "/usr/bin/node" "/usr/bin/npm" "install" "iobroker.js-controller@1.5.13" "--unsafe-perm" "--production" "--save" "--prefix" "/opt/iobroker"
    428 verbose node v10.16.0
    429 verbose npm v6.9.0
    430 error path /opt/iobroker/node_modules/iobroker.js-controller/node_modules/code-point-at
    431 error code EACCES
    432 error errno -13
    433 error syscall access
    434 error Error: EACCES: permission denied, access '/opt/iobroker/node_modules/iobroker.js-controller/node_modules/code-point-at'
    434 error { [Error: EACCES: permission denied, access '/opt/iobroker/node_modules/iobroker.js-controller/node_modules/code-point-at']
    434 error stack:
    434 error 'Error: EACCES: permission denied, access '/opt/iobroker/node_modules/iobroker.js-controller/node_modules/code-point-at'',
    434 error errno: -13,
    434 error code: 'EACCES',
    434 error syscall: 'access',
    434 error path:
    434 error '/opt/iobroker/node_modules/iobroker.js-controller/node_modules/code-point-at' }
    435 error The operation was rejected by your operating system.
    435 error It is likely you do not have the permissions to access this file as the current user
    435 error
    435 error If you believe this might be a permissions issue, please double-check the
    435 error permissions of the file and its containing directories, or try running
    435 error the command again as root/Administrator (though this is not recommended).
    436 verbose exit [ -13, true ]
    apollon77A Online
    apollon77A Online
    @steimi rechte komisch. Installation Fixer mal laufen lassen?
    • K Kueppert
      Hab Verwahrung auch auf latest, js-controller wird mit aktuel auch nur 1.5.12 angeboten.
      apollon77A Online
      apollon77A Online
      @Kueppert hm ... an sich wird das Repo nachts aktualisiert. Checke es nachher.
      • apollon77A apollon77
        steimi
        schrieb am zuletzt editiert von steimi
        @apollon77 kann ich machen. Welchen soll ich für Debian Buster nehmen?
        Habt den aktuellen genommen (https://iobroker.net/fix.sh) , danach funktionierte das Update.
        • K Kueppert
          apollon77A Online
          apollon77A Online
          @Kueppert Ps hast einmal repo neu geladen (der Button mir den Pfeilen im Kreis unter „Adapter“
          BBTownB 1 Antwort Letzte Antwort
            BBTownB Offline
            BBTownB Offline
            BBTown
            schrieb am zuletzt editiert von BBTown
            @apollon77 gerade eben hat der/das Upgrade nun funktioniert
            • sigi234S Online
              sigi234S Online
              Update jetzt erfolgreich...........keine Fehler.
              • L Offline
                lonsimbt
                Das Update ist in meiner Installation im Debian Container unter proxmox 5.4 problemlos durchgelaufen. Keine Fehler oder Auffälligkeiten bisher.
                Gruß Marco
                iobroker im Container (debian Bullseye) unter proxmox 7.1
                debmatic in VM (debian Buster) unter proxmox 7.1 mit HB-RF-USB und RPI-RF-MOD
                40 HomeMatic Geräte, Phillips Hue, Ikea Tradfri, Logitech Harmony Hub, Botvac Connected, Robonect
                • dslraserD Offline
                  dslraserD Offline
                  dslraser
                  @Stabilostick sagte in [Diskussion] js-controller 1.5.13 in Latest:
                  iobroker update
                  was mache ich damit ? (läuft nicht mehr) Bin schon einmal zurück bis auf 1.4.2, dann lief wieder alles. Danach konnte ich auch wieder auf 1.5.12 updaten. 1.5.13 schlägt fehl.
                  Jetzt komme ich aber auch nicht zurück
                  npm ERR! code ELIFECYCLE
                  npm ERR! errno 1
                  npm ERR! iobroker.js-controller@1.5.13 install: `node iobroker.js setup first`
                  npm ERR! Exit status 1
                  npm ERR!
                  npm ERR! Failed at the iobroker.js-controller@1.5.13 install script.
                  npm ERR!     /root/.npm/_logs/2019-07-19T11_50_28_057Z-debug.log
                  root@iobroker:/opt/iobroker#
                  + iobroker.js-controller@1.4.2
                  added 170 packages from 98 contributors and audited 3826 packages in 25.9s
                  found 30 vulnerabilities (22 low, 8 high)
                    run `npm audit fix` to fix them, or `npm audit` for details
                  root@iobroker:/opt/iobroker# iobroker start
                  Starting iobroker controller daemon...
                  iobroker controller daemon failed to start:  Failed to write pidfile (EACCES)
                  Error: Failed to write pidfile (EACCES)
                  StabilostickS 1 3 Antworten Letzte Antwort
                  • crunchipC Offline
                    crunchipC Offline
                    hätte ich das nun nicht als root ausführen dürfen?
                    hatte zu meiner Schande vergessen, da war doch was mit benutzer und fixer skript:woman-facepalming: und aus reiner Gewohnheit als root angemeldet.
                    root@IoBroker:/opt/iobroker# iobroker upgrade self
                    Update js-controller from @1.5.12 to @1.5.13
                    NPM version: 6.9.0
                    npm install iobroker.js-controller@1.5.13 --unsafe-perm --production --save --prefix "/opt/iobroker" (System                                              call)
                    Host "IoBroker" (linux) updated
                    Execute: chmod -R 777 /opt/iobroker
                    chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/ipcam': Die Operation ist nicht erlaubt
                    chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/multicast-dns-service-types': Die Opera                                             tion ist nicht erlaubt
                    chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/multicast-dns-service-types/LICENSE': D                                             ie Operation ist nicht erlaubt
                    chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/multicast-dns-service-types/README.md':                                              Die Operation ist nicht erlaubt
                    chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/multicast-dns-service-types/index.js':                                              Die Operation ist nicht erlaubt
                    chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/multicast-dns-service-types/test.js': D                                             ie Operation ist nicht erlaubt
                    chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/multicast-dns-service-types/.travis.yml                                             ': Die Operation ist nicht erlaubt
                    chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/multicast-dns-service-types/package.jso                                             n': Die Operation ist nicht erlaubt
                    chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/multicast-dns-service-types/.npmignore'                                             : Die Operation ist nicht erlaubt
                    chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/buffer-indexof': Die Operation ist nich                                             t erlaubt
                    chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/buffer-indexof/LICENSE': Die Operation                                              ist nicht erlaubt
                    chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/buffer-indexof/bm.js': Die Operation is                                             t nicht erlaubt
                    chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/buffer-indexof/test': Die Operation ist                                              nicht erlaubt
                    chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/buffer-indexof/test/bm.js': Die Operati                                             on ist nicht erlaubt
                    chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/buffer-indexof/test/partial-match.js':                                              Die Operation ist nicht erlaubt
                    chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/buffer-indexof/test/test.js': Die Opera                                             tion ist nicht erlaubt
                    chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/buffer-indexof/test/test-buffer-indexof                                             .js': Die Operation ist nicht erlaubt
                    chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/buffer-indexof/test/multibyteneedle.js'                                             : Die Operation ist nicht erlaubt
                    chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/buffer-indexof/README.md': Die Operatio                                             n ist nicht erlaubt
                    chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/buffer-indexof/index.js': Die Operation                                              ist nicht erlaubt
                    chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/buffer-indexof/.travis.yml': Die Operat                                             ion ist nicht erlaubt
                    chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/buffer-indexof/package.json': Die Opera                                             tion ist nicht erlaubt
                    chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/dns-equal': Die Operation ist nicht erl                                             aubt
                    chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/dns-equal/LICENSE': Die Operation ist n                                             icht erlaubt
                    chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/dns-equal/README.md': Die Operation ist                                              nicht erlaubt
                    chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/dns-equal/index.js': Die Operation ist                                              nicht erlaubt
                    chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/dns-equal/test.js': Die Operation ist n                                             icht erlaubt
                    chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/dns-equal/.travis.yml': Die Operation i                                             st nicht erlaubt
                    chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/dns-equal/package.json': Die Operation                                              ist nicht erlaubt
                    chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/dns-equal/.npmignore': Die Operation is                                             t nicht erlaubt
                    chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/dns-txt': Die Operation ist nicht erlau                                             bt
                    chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/dns-txt/LICENSE': Die Operation ist nic                                             ht erlaubt
                    chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/dns-txt/README.md': Die Operation ist n                                             icht erlaubt
                    chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/dns-txt/index.js': Die Operation ist ni                                             cht erlaubt
                    chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/dns-txt/test.js': Die Operation ist nic                                             ht erlaubt
                    chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/dns-txt/.travis.yml': Die Operation ist                                              nicht erlaubt
                    chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/dns-txt/package.json': Die Operation is                                             t nicht erlaubt
                    chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/dns-txt/.npmignore': Die Operation ist                                              nicht erlaubt
                    chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/bonjour': Die Operation ist nicht erlau                                             bt
                    chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/bonjour/LICENSE': Die Operation ist nic                                             ht erlaubt
                    chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/bonjour/lib': Die Operation ist nicht e                                             rlaubt
                    chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/bonjour/lib/registry.js': Die Operation                                              ist nicht erlaubt
                    chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/bonjour/lib/mdns-server.js': Die Operat                                             ion ist nicht erlaubt
                    chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/bonjour/lib/browser.js': Die Operation                                              ist nicht erlaubt
                    chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/bonjour/lib/service.js': Die Operation                                              ist nicht erlaubt
                    chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/bonjour/test': Die Operation ist nicht                                              erlaubt
                    chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/bonjour/test/service.js': Die Operation                                              ist nicht erlaubt
                    chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/bonjour/test/bonjour.js': Die Operation                                              ist nicht erlaubt
                    chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/bonjour/README.md': Die Operation ist n                                             icht erlaubt
                    chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/bonjour/index.js': Die Operation ist ni                                             cht erlaubt
                    chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/bonjour/.travis.yml': Die Operation ist                                              nicht erlaubt
                    chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/bonjour/node_modules': Die Operation is                                             t nicht erlaubt
                    chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/bonjour/node_modules/array-flatten': Di                                             e Operation ist nicht erlaubt
                    chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/bonjour/node_modules/array-flatten/LICE                                             NSE': Die Operation ist nicht erlaubt
                    chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/bonjour/node_modules/array-flatten/arra                                             y-flatten.d.ts': Die Operation ist nicht erlaubt
                    chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/bonjour/node_modules/array-flatten/READ                                             ME.md': Die Operation ist nicht erlaubt
                    chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/bonjour/node_modules/array-flatten/arra                                             y-flatten.js': Die Operation ist nicht erlaubt
                    chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/bonjour/node_modules/array-flatten/pack                                             age.json': Die Operation ist nicht erlaubt
                    chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/bonjour/node_modules/multicast-dns': Di                                             e Operation ist nicht erlaubt
                    chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/bonjour/node_modules/multicast-dns/LICE                                             NSE': Die Operation ist nicht erlaubt
                    chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/bonjour/node_modules/multicast-dns/READ                                             ME.md': Die Operation ist nicht erlaubt
                    chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/bonjour/node_modules/multicast-dns/inde                                             x.js': Die Operation ist nicht erlaubt
                    chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/bonjour/node_modules/multicast-dns/test                                             .js': Die Operation ist nicht erlaubt
                    chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/bonjour/node_modules/multicast-dns/exam                                             ple.js': Die Operation ist nicht erlaubt
                    chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/bonjour/node_modules/multicast-dns/.tra                                             vis.yml': Die Operation ist nicht erlaubt
                    chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/bonjour/node_modules/multicast-dns/cli.                                             js': Die Operation ist nicht erlaubt
                    chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/bonjour/node_modules/multicast-dns/pack                                             age.json': Die Operation ist nicht erlaubt
                    chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/bonjour/node_modules/.bin': Die Operati                                             on ist nicht erlaubt
                    chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/bonjour/node_modules/deep-equal': Die O                                             peration ist nicht erlaubt
                    chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/bonjour/node_modules/deep-equal/LICENSE                                             ': Die Operation ist nicht erlaubt
                    chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/bonjour/node_modules/deep-equal/lib': D                                             ie Operation ist nicht erlaubt
                    chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/bonjour/node_modules/deep-equal/lib/key                                             s.js': Die Operation ist nicht erlaubt
                    chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/bonjour/node_modules/deep-equal/lib/is_                                             arguments.js': Die Operation ist nicht erlaubt
                    chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/bonjour/node_modules/deep-equal/test':                                              Die Operation ist nicht erlaubt
                    chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/bonjour/node_modules/deep-equal/test/cm                                             p.js': Die Operation ist nicht erlaubt
                    chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/bonjour/node_modules/deep-equal/readme.                                             markdown': Die Operation ist nicht erlaubt
                    chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/bonjour/node_modules/deep-equal/example                                             ': Die Operation ist nicht erlaubt
                    chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/bonjour/node_modules/deep-equal/example                                             /cmp.js': Die Operation ist nicht erlaubt
                    chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/bonjour/node_modules/deep-equal/index.j                                             s': Die Operation ist nicht erlaubt
                    chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/bonjour/node_modules/deep-equal/.travis                                             .yml': Die Operation ist nicht erlaubt
                    chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/bonjour/node_modules/deep-equal/package                                             .json': Die Operation ist nicht erlaubt
                    chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/bonjour/package.json': Die Operation is                                             t nicht erlaubt
                    chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/bonjour/.npmignore': Die Operation ist                                              nicht erlaubt
                    Chmod finished. Restart controller
                    Starting node restart.js
                    • dslraserD dslraser
                      iobroker update
                      npm ERR! errno 1
                      npm ERR!
                      StabilostickS Offline
                      Stabilostick
                      @dslraser , @crunchip
                      • Sicherstellen, dass ioBroker vor dem Update tatsächlich beendet ist.
                      • Unter Linux: Wenn beim Update Zugriffs- oder Berechtigungsfehler ausgegeben werden, dann den Installation-Fixer ausführen:
                        curl -sL https://iobroker.net/fix.sh | bash -
                        und das Update anschließend wiederholen.
                        iobroker update
                        npm ERR! errno 1
                        npm ERR!
                        Stabilostick
                        @dslraser
                        Was steht denn in root/.npm/_logs/2019-07-19T11_50_28_057Z-debug.log?
                        Hat iobroker was in seine Logdatei in logs/... geschrieben?
                        Mehr Info bitte. 🤗
                        • StabilostickS Stabilostick
                          @dslraser
                          Mehr Info bitte. 🤗
                          dslraserD Offline
                          dslraserD Offline
                          dslraser
                          @Stabilostick
                          Ich bekomme Besuch und musste alles schnell wieder lauffähig haben, dann habe ich ein Backup wieder eingespielt.
                          Ich hatte auch mal trotz Docker den Fixer laufen lassen, hat auch nichts gebracht.
                          Ich habe dann den kompletten Mount Ordner gelöscht und auch den Container.
                          Dann neuen Container und Backup eingespielt.
                          Leider habe ich Depp vergessen vorher ein frisches Backup zu machen. Das letzte ist 3 Wochen alt, nun sind alle Blocklys/Scripte ab diesem Zeitpunkt weg.
                          Ich habe allerdings eventuell die Mountordner mit Inhalt vielleicht noch im Papierkorb. Kommt man da an die fehlenden Blocklys/Scripte drann, falls noch vorhanden ?
                          StabilostickS 1 Antwort Letzte Antwort
                            crunchipC Offline
                            crunchipC Offline
                            @Stabilostick also war das schon so richtig?
                            Hab mich nur gewundert das soviel Zugriffsrechte nicht erlaubt sind, da es ja eigentlich "nur" ein update von .12 auf .13 ist
                            Probier ich´s gleich nochmal, habe vorhin einfach mein Backup zurückgespielt.
                              @Stabilostick
                              Stabilostick
                              schrieb am zuletzt editiert von Stabilostick
                              @dslraser
                              Die Scripte liegen in den DBs im Ordner iobroker-data.
                                @dslraser
                                dslraserD Offline
                                dslraserD Offline
                                dslraser
                                @Stabilostick
                                wie bekomme ich die das raus ?
                                  @Stabilostick
                                  Stabilostick
                                  @dslraser
                                  Viel geändert in der Zwischenzeit oder Rücksprung auf älteren Stand möglich?
                                    @dslraser
                                    dslraserD Offline
                                    dslraserD Offline
                                    dslraser
                                    @Stabilostick
                                    relativ viel geändert
                                      @Stabilostick
                                      Stabilostick
                                      @dslraser
                                      So ganz unbedarft würde ich einen neuen iobroker zum Wegwerfen irgendwohin installieren, dann den Ordner iobroker-data mit Inhalt in den neuen reinkopieren, ein iobroker host this machen und den iobroker starten. Dann über den Admin und den JavaScript-Adapter die Scripte/Blocklys in Textfiles exportieren. Die dann in den aktuellen ioBroker importieren und bei Erfolg den Wegwerf-ioBroker entsorgen.
                                      Vielleicht hat ja jemand eine bessere Idee? Mach dazu ggf. einen neuen Thread auf.
                                        @dslraser
                                        dslraserD Offline
                                        dslraserD Offline
                                        dslraser
                                        @Stabilostick
                                        okay, danke.
                                        aber: vergiss es, Papierkorb war nicht aktiviert....
                                        LERNEN DURCH SCHMERZEN😧
                                        StabilostickS sigi234S 2 Antworten Letzte Antwort
                                          @Stabilostick
                                          okay, danke.
                                          Stabilostick
                                          @dslraser Alles neu, macht der ...
                                          Sehe es einfach als Chance, alte Zöpfe abzuschneiden und Ordnung zu verbreiten. 😇
