  4. Adapter: iobroker.backitup (stable Release)
adapterbackitupiobroker backupbackupiobroker.backitup
2.3k Beiträge 185 Kommentatoren 1.8m Aufrufe 50 Beobachtet
  • T
    T
    toscand
    #2017
    habe ich beides nochmal geprüft mein User ist in der gruppe root und cifs-utils sind jetzt auch installiert.
    ohne root mount gleicher log.
    Kann das Problem eventuell daran liegen das meine NAS Benutzer ein ö im Namen hat?
    mit root mount bekomme ich jetzt folgendes:
    backitup.0	2019-06-01 23:02:21.610	debug	[minimal/history] backitup.0.history.html
    backitup.0	2019-06-01 23:02:21.583	debug	[minimal/clean] done
    backitup.0	2019-06-01 23:02:21.582	debug	[minimal/clean] Backup files not deleted from /opt/iobroker/backups because some errors.
    backitup.0	2019-06-01 23:02:21.577	debug	[minimal/cifs] done
    backitup.0	2019-06-01 23:02:21.570	debug	[minimal/minimal] done
    backitup.0	2019-06-01 23:02:21.543	debug	[minimal/minimal] Backup created: /opt/iobroker/backups/minimal_2019_06_01-23_02_16_backupiobroker.tar.gz
    backitup.0	2019-06-01 23:02:16.131	debug	[minimal/mount] For more details see mount(8).
    backitup.0	2019-06-01 23:02:16.130	debug	[minimal/mount] --make-runbindable recursively mark a whole subtree as unbindable
    backitup.0	2019-06-01 23:02:16.130	debug	[minimal/mount] --make-rprivate recursively mark a whole subtree as private
    backitup.0	2019-06-01 23:02:16.130	debug	[minimal/mount] --make-rslave recursively mark a whole subtree as slave
    backitup.0	2019-06-01 23:02:16.129	debug	[minimal/mount] --make-rshared recursively mark a whole subtree as shared
    backitup.0	2019-06-01 23:02:16.129	debug	[minimal/mount] --make-unbindable mark a subtree as unbindable
    backitup.0	2019-06-01 23:02:16.128	debug	[minimal/mount] --make-private mark a subtree as private
    backitup.0	2019-06-01 23:02:16.128	debug	[minimal/mount] --make-slave mark a subtree as slave
    backitup.0	2019-06-01 23:02:16.128	debug	[minimal/mount] --make-shared mark a subtree as shared
    backitup.0	2019-06-01 23:02:16.127	debug	[minimal/mount] -R, --rbind mount a subtree and all submounts somewhere else
    backitup.0	2019-06-01 23:02:16.127	debug	[minimal/mount] -M, --move move a subtree to some other place
    backitup.0	2019-06-01 23:02:16.126	debug	[minimal/mount] -B, --bind mount a subtree somewhere else (same as -o bind)
    backitup.0	2019-06-01 23:02:16.126	debug	[minimal/mount] Operations:
    backitup.0	2019-06-01 23:02:16.126	debug	[minimal/mount] <file> regular file for loopdev setup
    backitup.0	2019-06-01 23:02:16.125	debug	[minimal/mount] <directory> mountpoint for bind mounts (see --bind/rbind)
    backitup.0	2019-06-01 23:02:16.125	debug	[minimal/mount] <device> specifies device by path
    backitup.0	2019-06-01 23:02:16.125	debug	[minimal/mount] PARTUUID=<uuid> specifies device by partition UUID
    backitup.0	2019-06-01 23:02:16.124	debug	[minimal/mount] PARTLABEL=<label> specifies device by partition label
    backitup.0	2019-06-01 23:02:16.124	debug	[minimal/mount] UUID=<uuid> specifies device by filesystem UUID
    backitup.0	2019-06-01 23:02:16.123	debug	[minimal/mount] LABEL=<label> specifies device by filesystem label
    backitup.0	2019-06-01 23:02:16.123	debug	[minimal/mount] -U, --uuid <uuid> synonym for UUID=<uuid>
    backitup.0	2019-06-01 23:02:16.123	debug	[minimal/mount] -L, --label <label> synonym for LABEL=<label>
    backitup.0	2019-06-01 23:02:16.122	debug	[minimal/mount] Source:
    backitup.0	2019-06-01 23:02:16.122	debug	[minimal/mount] -V, --version output version information and exit
    backitup.0	2019-06-01 23:02:16.121	debug	[minimal/mount] -h, --help display this help and exit
    backitup.0	2019-06-01 23:02:16.121	debug	[minimal/mount] -w, --rw, --read-write mount the filesystem read-write (default)
    backitup.0	2019-06-01 23:02:16.121	debug	[minimal/mount] -v, --verbose say what is being done
    backitup.0	2019-06-01 23:02:16.120	debug	[minimal/mount] --target <target> explicitly specifies mountpoint
    backitup.0	2019-06-01 23:02:16.120	debug	[minimal/mount] --source <src> explicitly specifies source (path, label, uuid)
    backitup.0	2019-06-01 23:02:16.120	debug	[minimal/mount] -t, --types <list> limit the set of filesystem types
    backitup.0	2019-06-01 23:02:16.119	debug	[minimal/mount] -r, --read-only mount the filesystem read-only (same as -o ro)
    backitup.0	2019-06-01 23:02:16.119	debug	[minimal/mount] -O, --test-opts <list> limit the set of filesystems (use with -a)
    backitup.0	2019-06-01 23:02:16.118	debug	[minimal/mount] -o, --options <list> comma-separated list of mount options
    backitup.0	2019-06-01 23:02:16.118	debug	[minimal/mount] -n, --no-mtab don't write to /etc/mtab
    backitup.0	2019-06-01 23:02:16.118	debug	[minimal/mount] -l, --show-labels show also filesystem labels
    backitup.0	2019-06-01 23:02:16.117	debug	[minimal/mount] -i, --internal-only don't call the mount.<type> helpers
    backitup.0	2019-06-01 23:02:16.117	debug	[minimal/mount] -T, --fstab <path> alternative file to /etc/fstab
    backitup.0	2019-06-01 23:02:16.117	debug	[minimal/mount] -F, --fork fork off for each device (use with -a)
    backitup.0	2019-06-01 23:02:16.116	debug	[minimal/mount] -f, --fake dry run; skip the mount(2) syscall
    backitup.0	2019-06-01 23:02:16.116	debug	[minimal/mount] -c, --no-canonicalize don't canonicalize paths
    backitup.0	2019-06-01 23:02:16.115	debug	[minimal/mount] -a, --all mount all filesystems mentioned in fstab
    backitup.0	2019-06-01 23:02:16.115	debug	[minimal/mount] Options:
    backitup.0	2019-06-01 23:02:16.115	debug	[minimal/mount] Mount a filesystem.
    backitup.0	2019-06-01 23:02:16.114	debug	[minimal/mount] mount <operation> <mountpoint> [<target>]
    backitup.0	2019-06-01 23:02:16.114	debug	[minimal/mount] mount [options] <source> <directory>
    backitup.0	2019-06-01 23:02:16.113	debug	[minimal/mount] mount [options] [--source] <source> | [--target] <directory>
    backitup.0	2019-06-01 23:02:16.113	debug	[minimal/mount] mount -a [options]
    backitup.0	2019-06-01 23:02:16.112	debug	[minimal/mount] mount [-lhV]
    backitup.0	2019-06-01 23:02:16.112	debug	[minimal/mount] Usage:
    backitup.0	2019-06-01 23:02:16.111	debug	[minimal/mount] [IGNORED] Error: Command failed: sudo mount -t cifs -o username=xxx xxx,password=xxx,rw,file_mode=0777,dir_mode=0777 //xxx.xxx.x.xxx/Familie/03_SmartHome/Backup/ioBroker
    backitup.0	2019-06-01 23:02:16.103	debug	[minimal/mount] For more details see mount(8).
    backitup.0	2019-06-01 23:02:16.103	debug	[minimal/mount] --make-runbindable recursively mark a whole subtree as unbindable
    backitup.0	2019-06-01 23:02:16.102	debug	[minimal/mount] --make-rprivate recursively mark a whole subtree as private
    backitup.0	2019-06-01 23:02:16.102	debug	[minimal/mount] --make-rslave recursively mark a whole subtree as slave
    backitup.0	2019-06-01 23:02:16.102	debug	[minimal/mount] --make-rshared recursively mark a whole subtree as shared
    backitup.0	2019-06-01 23:02:16.101	debug	[minimal/mount] --make-unbindable mark a subtree as unbindable
    backitup.0	2019-06-01 23:02:16.101	debug	[minimal/mount] --make-private mark a subtree as private
    backitup.0	2019-06-01 23:02:16.100	debug	[minimal/mount] --make-slave mark a subtree as slave
    backitup.0	2019-06-01 23:02:16.100	debug	[minimal/mount] --make-shared mark a subtree as shared
    backitup.0	2019-06-01 23:02:16.100	debug	[minimal/mount] -R, --rbind mount a subtree and all submounts somewhere else
    backitup.0	2019-06-01 23:02:16.099	debug	[minimal/mount] -M, --move move a subtree to some other place
    backitup.0	2019-06-01 23:02:16.099	debug	[minimal/mount] -B, --bind mount a subtree somewhere else (same as -o bind)
    backitup.0	2019-06-01 23:02:16.099	debug	[minimal/mount] Operations:
    backitup.0	2019-06-01 23:02:16.098	debug	[minimal/mount] <file> regular file for loopdev setup
    backitup.0	2019-06-01 23:02:16.098	debug	[minimal/mount] <directory> mountpoint for bind mounts (see --bind/rbind)
    backitup.0	2019-06-01 23:02:16.097	debug	[minimal/mount] <device> specifies device by path
    backitup.0	2019-06-01 23:02:16.097	debug	[minimal/mount] PARTUUID=<uuid> specifies device by partition UUID
    backitup.0	2019-06-01 23:02:16.097	debug	[minimal/mount] PARTLABEL=<label> specifies device by partition label
    backitup.0	2019-06-01 23:02:16.096	debug	[minimal/mount] UUID=<uuid> specifies device by filesystem UUID
    backitup.0	2019-06-01 23:02:16.096	debug	[minimal/mount] LABEL=<label> specifies device by filesystem label
    backitup.0	2019-06-01 23:02:16.096	debug	[minimal/mount] -U, --uuid <uuid> synonym for UUID=<uuid>
    backitup.0	2019-06-01 23:02:16.095	debug	[minimal/mount] -L, --label <label> synonym for LABEL=<label>
    backitup.0	2019-06-01 23:02:16.095	debug	[minimal/mount] Source:
    backitup.0	2019-06-01 23:02:16.094	debug	[minimal/mount] -V, --version output version information and exit
    backitup.0	2019-06-01 23:02:16.094	debug	[minimal/mount] -h, --help display this help and exit
    backitup.0	2019-06-01 23:02:16.094	debug	[minimal/mount] -w, --rw, --read-write mount the filesystem read-write (default)
    backitup.0	2019-06-01 23:02:16.093	debug	[minimal/mount] -v, --verbose say what is being done
    backitup.0	2019-06-01 23:02:16.093	debug	[minimal/mount] --target <target> explicitly specifies mountpoint
    backitup.0	2019-06-01 23:02:16.092	debug	[minimal/mount] --source <src> explicitly specifies source (path, label, uuid)
    backitup.0	2019-06-01 23:02:16.092	debug	[minimal/mount] -t, --types <list> limit the set of filesystem types
    backitup.0	2019-06-01 23:02:16.092	debug	[minimal/mount] -r, --read-only mount the filesystem read-only (same as -o ro)
    backitup.0	2019-06-01 23:02:16.091	debug	[minimal/mount] -O, --test-opts <list> limit the set of filesystems (use with -a)
    backitup.0	2019-06-01 23:02:16.091	debug	[minimal/mount] -o, --options <list> comma-separated list of mount options
    backitup.0	2019-06-01 23:02:16.091	debug	[minimal/mount] -n, --no-mtab don't write to /etc/mtab
    backitup.0	2019-06-01 23:02:16.090	debug	[minimal/mount] -l, --show-labels show also filesystem labels
    backitup.0	2019-06-01 23:02:16.090	debug	[minimal/mount] -i, --internal-only don't call the mount.<type> helpers
    backitup.0	2019-06-01 23:02:16.089	debug	[minimal/mount] -T, --fstab <path> alternative file to /etc/fstab
    backitup.0	2019-06-01 23:02:16.089	debug	[minimal/mount] -F, --fork fork off for each device (use with -a)
    backitup.0	2019-06-01 23:02:16.089	debug	[minimal/mount] -f, --fake dry run; skip the mount(2) syscall
    backitup.0	2019-06-01 23:02:16.088	debug	[minimal/mount] -c, --no-canonicalize don't canonicalize paths
    backitup.0	2019-06-01 23:02:16.088	debug	[minimal/mount] -a, --all mount all filesystems mentioned in fstab
    backitup.0	2019-06-01 23:02:16.087	debug	[minimal/mount] Options:
    backitup.0	2019-06-01 23:02:16.087	debug	[minimal/mount] Mount a filesystem.
    backitup.0	2019-06-01 23:02:16.087	debug	[minimal/mount] mount <operation> <mountpoint> [<target>]
    backitup.0	2019-06-01 23:02:16.086	debug	[minimal/mount] mount [options] <source> <directory>
    backitup.0	2019-06-01 23:02:16.086	debug	[minimal/mount] mount [options] [--source] <source> | [--target] <directory>
    backitup.0	2019-06-01 23:02:16.086	debug	[minimal/mount] mount -a [options]
    backitup.0	2019-06-01 23:02:16.085	debug	[minimal/mount] mount [-lhV]
    backitup.0	2019-06-01 23:02:16.085	debug	[minimal/mount] Usage:
    backitup.0	2019-06-01 23:02:16.083	debug	[minimal/mount] [undefined
    backitup.0	2019-06-01 23:01:47.589	debug	[total] 10 00 02 */3 * *
    • T toscand
      simatecS
      simatecS
      simatec
      #2018
      @toscand
      Das könnte durchaus an Sonderzeichen liegen.
      Nimm mal einen anderen Benutzer.
      Wenn du im Passwort Sonderzeichen hast, schreibe es in Anführungszeichen.
      Linux hat auch Probleme mit zu langen Passwörtern.
      • Besuche meine Github Seite
      • HowTo Restore ioBroker
      • K
        K
        klassisch
        #2019
        habe jetzt auf einen Windows Rechner migriert. Jetzt wäre es praktisch, wenn man die history-Daten ebenfals täglich auf die Synology sichern könnte. Beim Orange Pi habe ich das über ein rsync gemacht, lange bevor es diesen praktischen Adapter hier gab. Bevor ich jetzt wieder eine Lösung für Windows schnitze, frage ih mal, ob hiermit so etwas möglich oder geplant ist.
        • K klassisch
          simatecS
          simatecS
          simatec
          #2020
          @klassisch
          Das sichern der History Daten ist für backitup geplant.
          Kommt sicher in der der nächsten Versionen.
          • K
            K
            klassisch
            #2021
            Klasse, vielen Dank für die Info! Dann muß ich nichts rumfrickeln. In der Zwischenzeit mache ich dann die history Backups einmal die Woche manuell über den TC, oder so..
            • T
              T
              toscand
              #2022
              @simatec
              ich habe mir anderem Benutzer auf dem NAS und kurzen Passwort immernoch den gleichen Fehler.
              Was könnte noch die Ursache seien?
              • T toscand
                @simatec
                simatecS
                simatecS
                simatec
                #2023
                @toscand
                Schaue mal bitte hier im Forum. Das Thema hatten wir hier schon öfter.
                Es sind sicher einige Einstellungen auf deinem NAS die nicht stimmen.
                Was ist z.B mit SMB Version?
                • D
                  D
                  daniel_iobroker
                  schrieb am zuletzt editiert von daniel_iobroker
                  #2024
                  Ich habe heute einen Umzug vom Raspi3b auf den 4er vollzogen. Hat alles ganz gut geklappt. Das einzige Problem was ich noch habe ist, dass ich das mysql backup nicht wiederherstellen kann. Das Backup liegt auf einem FTP Server. Wenn ich das gewünschte sql backup auswähle und dann auf wiederherstellen klicke, dann kommt noch der hinweis, dass iobroker gestoppt und wieder gestartet wird. Nach dem Bestätigen passiert aber nichts. Hab dann Backitup auf Debug gestellt und das einzige was im Log erscheint ist:
                  backitup.0	2019-07-15 14:17:24.213	debug	system.adapter.admin.0: logging true
                  backitup.0	2019-07-15 14:17:14.482	debug	Test: mysql_2019_07_15-13_43_29_backupiobroker.tar.gz
                  statistics.0	2019-07-15 14:17:09.550	debug	system.adapter.admin.0: logging false
                  backitup.0	2019-07-15 14:17:09.550	debug	system.adapter.admin.0: logging false
                  backitup.0	2019-07-15 14:17:07.759	debug	sendTo "list" to system.adapter.admin.0 from system.adapter.backitup.0
                  backitup.0	2019-07-15 14:17:05.723	debug	FTP connected.
                  Mehr passiert leider nicht. Auch meine geloggten Werte erscheinen z.B. im flot nicht. Nur die neuen die aktuell wieder geloggt werden
                  • D daniel_iobroker
                    simatecS
                    simatecS
                    simatec
                    #2025
                    @daniel_iobroker
                    Hast du mysqldump installiert und den richtigen Pfad zu mysqldump in den backitup Einstellungen angegeben?
                    • D
                      D
                      daniel_iobroker
                      #2026
                      @simatec Pfad habe ich keinen eingestellt, da hier immer der Standardpfad passte. Bin jetzt aber draufgekommen, warum das restore nicht klappte. Meine Backups werden ja über einen FTP Server übertragen. Das standard bzw. komplett Backup funktioniert hier einwandfrei. Bei dem Backup der sql Datenbank gibt es hier jedoch ein Problem. Das Backup wird anscheinend zuerst auf die SD Karte gemacht (gleich wie bei standard bzw. komplett Backup) und erst dann übertragen. Die SQL Datei wird jedoch IMMER fehlerhaft übertragen. Die Datei ist unvollständig und hat immer nur ein paar kb. Hab nun den alten Raspi nochmal gestartet und hab direkt über ftp auf den Pi zugegriffen und dort die Datei zuerst auf einen Rechner kopiert - kontrolliert - und dann wieder auf den neuen Pi aufgespielt. Hier klappte dann nun das einspielen des Backups über den Backitup Adapter ohne Probleme.
                      Leider wurden dadurch die neuen Daten überschrieben. Somit fehlen mir jetzt 1,5 Tage in der Aufzeichnung.
                      Vor dem Wiederherstellen habe ich vom neuen Pi auch ein Backup gemacht. Wollte danach auch diese sql Daten wiederherstellen (Damit die Lücke von Gestern auf Heute wieder vorhanden ist) dann werden jedoch wieder die Daten von davor gelöscht. Habe jetzt wieder die alten Daten wiederhergestellt, so habe ich die alten Daten wieder und mir fehlen "nur" die Daten von den letzten 1,5 Tagen.
                      • D daniel_iobroker
                        simatecS
                        simatecS
                        simatec
                        #2027
                        @daniel_iobroker
                        Danke für dein Feedback. Schaue ich mir mal an.
                        • hanssH
                          hanssH
                          hanss
                          #2028
                          @daniel_iobroker
                          Vielen Dank für die Fehlersuche.
                          Ich habe das fehlerhafte Restore zuletzt am 20.4.2019 bemängelt, hatte aber keinen Erfolg damit.
                          Jetzt hast Du den Beweis erbracht, daß tatsächlich ein Fehler vorliegt.
                          Hoffentlich wird das jetzt gefixt.
                          • hanssH hanss
                            @daniel_iobroker
                            simatecS
                            simatecS
                            simatec
                            #2029
                            @hanss sagte in Adapter: iobroker.backitup (stable Release):
                            @daniel_iobroker
                            Warum sollte es nicht gefixt werden ... hatte ich doch geschrieben!!
                            Du hast damals nicht mehr geantwortet und keine klaren Fehlerbeschreibungen gegeben.
                            Wie soll man da was fixen, wenn man nicht mal ne Antwort auf die Fragen bekommt.
                            • P
                              P
                              passuff
                              schrieb am zuletzt editiert von passuff
                              #2030
                              Backitup sichert bei mir seit ca einem Monat nicht mehr automatisch. Manuell funktioniert einwandfrei. Ich habe keinen Fehler im log. Zu den festgelegten Zeiten sind keine Einträge im log vorhanden.
                              EDIT: Habe die Zeiten im Adapter aktualisiert bzw. auf die aktuelle Zeit gestellt:
                              Folgendes taucht jetzt im Log auf:
                              host.IoBroker-VM-Debian 2019-07-20 04:42:16.639 info Restart adapter system.adapter.backitup.0 because enabled
                              host.IoBroker-VM-Debian 2019-07-20 04:42:16.638 error instance system.adapter.backitup.0 terminated with code 7 (Adapter already running)
                              host.IoBroker-VM-Debian 2019-07-20 04:42:15.794 info instance system.adapter.backitup.0 started with pid 3248
                              influxdb.0 2019-07-20 04:42:10.405 info Store 81 buffered influxDB history points
                              host.IoBroker-VM-Debian 2019-07-20 04:41:45.785 info Restart adapter system.adapter.backitup.0 because enabled
                              host.IoBroker-VM-Debian 2019-07-20 04:41:45.784 error instance system.adapter.backitup.0 terminated with code 7 (Adapter already running)
                              host.IoBroker-VM-Debian 2019-07-20 04:41:44.799 info instance system.adapter.backitup.0 started with pid 3227
                              host.IoBroker-VM-Debian 2019-07-20 04:41:14.793 info Restart adapter system.adapter.backitup.0 because enabled
                              host.IoBroker-VM-Debian 2019-07-20 04:41:14.792 error instance system.adapter.backitup.0 terminated with code 7 (Adapter already running)
                              host.IoBroker-VM-Debian 2019-07-20 04:41:14.024 info instance system.adapter.backitup.0 started with pid 3217
                              influxdb.0 2019-07-20 04:41:10.399 info Store 93 buffered influxDB history points
                              host.IoBroker-VM-Debian 2019-07-20 04:40:43.952 info Restart adapter system.adapter.backitup.0 because enabled
                              host.IoBroker-VM-Debian 2019-07-20 04:40:43.951 error instance system.adapter.backitup.0 terminated with code 7 (Adapter already running)
                              host.IoBroker-VM-Debian 2019-07-20 04:40:43.083 info instance system.adapter.backitup.0 started with pid 3196
                              host.IoBroker-VM-Debian 2019-07-20 04:40:13.069 info Restart adapter system.adapter.backitup.0 because enabled
                              host.IoBroker-VM-Debian 2019-07-20 04:40:13.069 error instance system.adapter.backitup.0 terminated with code 7 (Adapter already running)
                              backitup.0 2019-07-20 04:40:13.054 error already running
                              StabilostickS simatecS 2 Antworten Letzte Antwort
                              • P passuff
                                StabilostickS
                                StabilostickS
                                Stabilostick
                                schrieb am zuletzt editiert von Stabilostick
                                #2031
                                @passuff
                                Schalte bei der backitup-Instanz den Loglevel im Adminfenster auf „debug“. Dann iobroker mit iobroker stop und iobroker start neu starten. Was seht jetzt im Log bezgl. backitup?
                                P 1 Antwort Letzte Antwort
                                • P passuff
                                  simatecS
                                  simatecS
                                  simatec
                                  #2032
                                  @passuff
                                  So wie ich das in log sehe, läuft die Instanz zweimal
                                  Bitte befolge mal den Vorschlag von @Stabilostick
                                  • StabilostickS Stabilostick
                                    @passuff
                                    P
                                    P
                                    passuff
                                    #2033
                                    @Stabilostick
                                    Läuft wieder... Warum er für 6 Wochen ausgesetzt hatte, kann ich nicht mehr nachvollziehen...
                                    • P passuff
                                      @Stabilostick
                                      simatecS
                                      simatecS
                                      simatec
                                      #2034
                                      @passuff
                                      Wenn er schon die ganze Zeit probiert hat, die zweite Instanz zu starten, wäre das die logische Erklärung
                                      • simatecS simatec
                                        @passuff
                                        P
                                        P
                                        passuff
                                        #2035
                                        @simatec sagte in Adapter: iobroker.backitup (stable Release):
                                        Nein, das war erst nachdem ich die Ausführungszeit auf die aktuelle Zeit aktualisiert hatte. In den logs der vorherigen Tage war kein einziger backitup Eintrag. Es scheint, als war der Adapter eingefroren.
                                        • P
                                          P
                                          PatrickFro
                                          #2036
                                          Moin zusammen,
                                          seit heute habe ich leider folgende Fehler und hab dabei bemerkt, dass noch sehr viele Backups vorhanden sind, obwohl nur 3 immer verbleiben sollen.
                                          backitup.0	2019-07-21 11:23:02.561	error	[ERROR] [total/clean] Backup files not deleted from /opt/iobroker/backups because some errors.
                                          backitup.0	2019-07-21 11:23:02.560	error	[ERROR] [total/mysql] [IGNORED] Error: spawn mysqldump ENOENT
                                          Hat jemand eine Idee?
                                          33.2k
                                          84.4k
