  4. History Adapter lässt sich nicht installieren
history error
5 Beiträge 3 Kommentatoren 551 Aufrufe 1 Beobachtet
  • L Offline
    LED
    Hallo
    kann einer von den Profis Mal hier drauf schauen? Wenn ich den History Adapter installieren möchte (über WebAdmin) dann bekomme ich den Fehler:
    Fertig mit Fehler: reading io-package.json SyntaxError: Unexpected end of JSON input
    Hab dann gelesen, man könnte es Mal mit einem upload history über SSH probieren, hier das Ergebnis: :
    iobroker upload history
    got /opt/iobroker/node_modules/iobroker.history/admin
    upload [6] history.admin /opt/iobroker/node_modules/iobroker.history/admin/words                                       Custom.js wordsCustom.js application/javascript
    upload [5] history.admin /opt/iobroker/node_modules/iobroker.history/admin/words                                       .js words.js application/javascript
    upload [4] history.admin /opt/iobroker/node_modules/iobroker.history/admin/index                                       _m.html index_m.html text/html
    upload [3] history.admin /opt/iobroker/node_modules/iobroker.history/admin/index                                       .html index.html text/html
    upload [2] history.admin /opt/iobroker/node_modules/iobroker.history/admin/histo                                       ry.png history.png image/png
    upload [1] history.admin /opt/iobroker/node_modules/iobroker.history/admin/custo                                       m_m.html custom_m.html text/html
    upload [0] history.admin /opt/iobroker/node_modules/iobroker.history/admin/custo                                       m.html custom.html text/html
    Cannot find io-package.json in /opt/iobroker/node_modules/iobroker.history
    module.js:675
        throw err;
    SyntaxError: /opt/iobroker/node_modules/iobroker.history/io-package.json: Unexpe                                       cted end of JSON input
        at JSON.parse (<anonymous>)
        at Object.Module._extensions..json (module.js:672:27)
        at Module.load (module.js:566:32)
        at tryModuleLoad (module.js:506:12)
        at Function.Module._load (module.js:498:3)
        at Module.require (module.js:597:17)
        at require (internal/module.js:11:18)
        at Upload.uploadAdapter (/opt/iobroker/node_modules/iobroker.js-controller/l                                       ib/setup/setupUpload.js:219:23)
        at /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:890:52
        at Upload.upgradeAdapterObjects (/opt/iobroker/node_modules/iobroker.js-cont                                       roller/lib/setup/setupUpload.js:464:13)
    • sigi234S Online
      sigi234S Online
      Was kommt bei:
      iobroker list instances
      • L Offline
        LED
        system.adapter.admin.0                 : admin       -  enabled, port: 8081, bin                    d: 0.0.0.0, run as: admin
        system.adapter.discovery.0             : discovery   -  enabled
        system.adapter.flot.0                  : flot        -  enabled
        system.adapter.rpi2.0                  : rpi2        -  enabled
        system.adapter.sql.0                   : sql         -  enabled
        system.adapter.terminal.0              : terminal    -  enabled, port: 8088, bin                    d: 0.0.0.0, run as: admin
        system.adapter.vis-history.0           : vis-history -  enabled
        system.adapter.vis.0                   : vis         -  enabled
        system.adapter.web.0                   : web         -  enabled, port: 8082, bin                    d: 0.0.0.0, run as: admin
        • L LED
          @LED
          Mach mal bitte auf der Konsole:
          sudo -H npm cache clean -f
          Anschließend den Adapter (!!) löschen und neu installieren
          • L Offline
            LED
            Hat leider nicht geklappt. Trotzdem vielen Dank!
            Dem nächsten mit diesen Problem hilft es hoffentlich.
            Hab jetzt die SD Karte platt gemacht, waren mir zu viele Restriktionen auf dem fertigen Stretch Image. Alle Beispiele die ich ausprobieren wollte gingen in die Hose und das hat mich viel zu viel Zeit gekostet und eine Datenbank konnte ich auch nicht installieren.
            Hab iobroker jetzt selbst installiert, sieht bisher ganz gut aus. Aber ich lerne noch.
