<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[History Adapter lässt sich nicht installieren]]></title><description><![CDATA[<p dir="auto">Hallo</p>
<p dir="auto">kann einer von den Profis Mal hier drauf schauen? Wenn ich den History Adapter installieren möchte (über WebAdmin) dann bekomme ich den Fehler:<br />
Fertig mit Fehler: reading io-package.json SyntaxError: Unexpected end of JSON input</p>
<p dir="auto">Hab dann gelesen, man könnte es Mal mit einem upload history über SSH probieren, hier das Ergebnis: :</p>
<pre><code>iobroker upload history
got /opt/iobroker/node_modules/iobroker.history/admin
upload [6] history.admin /opt/iobroker/node_modules/iobroker.history/admin/words                                       Custom.js wordsCustom.js application/javascript
upload [5] history.admin /opt/iobroker/node_modules/iobroker.history/admin/words                                       .js words.js application/javascript
upload [4] history.admin /opt/iobroker/node_modules/iobroker.history/admin/index                                       _m.html index_m.html text/html
upload [3] history.admin /opt/iobroker/node_modules/iobroker.history/admin/index                                       .html index.html text/html
upload [2] history.admin /opt/iobroker/node_modules/iobroker.history/admin/histo                                       ry.png history.png image/png
upload [1] history.admin /opt/iobroker/node_modules/iobroker.history/admin/custo                                       m_m.html custom_m.html text/html
upload [0] history.admin /opt/iobroker/node_modules/iobroker.history/admin/custo                                       m.html custom.html text/html
Cannot find io-package.json in /opt/iobroker/node_modules/iobroker.history
module.js:675
    throw err;
SyntaxError: /opt/iobroker/node_modules/iobroker.history/io-package.json: Unexpe                                       cted end of JSON input
    at JSON.parse (&lt;anonymous&gt;)
    at Object.Module._extensions..json (module.js:672:27)
    at Module.load (module.js:566:32)
    at tryModuleLoad (module.js:506:12)
    at Function.Module._load (module.js:498:3)
    at Module.require (module.js:597:17)
    at require (internal/module.js:11:18)
    at Upload.uploadAdapter (/opt/iobroker/node_modules/iobroker.js-controller/l                                       ib/setup/setupUpload.js:219:23)
    at /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:890:52
    at Upload.upgradeAdapterObjects (/opt/iobroker/node_modules/iobroker.js-cont                                       roller/lib/setup/setupUpload.js:464:13)
</code></pre>
]]></description><link>https://forum.iobroker.net/topic/23844/history-adapter-lässt-sich-nicht-installieren</link><generator>RSS for Node</generator><lastBuildDate>Thu, 23 Apr 2026 12:07:51 GMT</lastBuildDate><atom:link href="https://forum.iobroker.net/topic/23844.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 15 Jul 2019 11:06:17 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to History Adapter lässt sich nicht installieren on Mon, 15 Jul 2019 19:07:39 GMT]]></title><description><![CDATA[<p dir="auto">Hat leider nicht geklappt. Trotzdem vielen Dank!<br />
Dem nächsten mit diesen Problem hilft es hoffentlich.</p>
<p dir="auto">Hab jetzt die SD Karte platt gemacht, waren mir zu viele Restriktionen auf dem fertigen Stretch Image. Alle Beispiele die ich ausprobieren wollte gingen in die Hose und das hat mich viel zu viel Zeit gekostet und eine Datenbank konnte ich auch nicht installieren.</p>
<p dir="auto">Hab iobroker jetzt selbst installiert, sieht bisher ganz gut aus. Aber ich lerne noch.</p>
]]></description><link>https://forum.iobroker.net/post/281329</link><guid isPermaLink="true">https://forum.iobroker.net/post/281329</guid><dc:creator><![CDATA[LED]]></dc:creator><pubDate>Mon, 15 Jul 2019 19:07:39 GMT</pubDate></item><item><title><![CDATA[Reply to History Adapter lässt sich nicht installieren on Mon, 15 Jul 2019 15:45:28 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/led" aria-label="Profile: LED">@<bdi>LED</bdi></a></p>
<p dir="auto">Mach mal bitte auf der Konsole:</p>
<pre><code>sudo -H npm cache clean -f
</code></pre>
<p dir="auto">Anschließend den Adapter (!!) löschen und neu installieren</p>
]]></description><link>https://forum.iobroker.net/post/281267</link><guid isPermaLink="true">https://forum.iobroker.net/post/281267</guid><dc:creator><![CDATA[Homoran]]></dc:creator><pubDate>Mon, 15 Jul 2019 15:45:28 GMT</pubDate></item><item><title><![CDATA[Reply to History Adapter lässt sich nicht installieren on Mon, 15 Jul 2019 13:23:55 GMT]]></title><description><![CDATA[<pre><code>iobroker list instances
system.adapter.admin.0                 : admin       -  enabled, port: 8081, bin                    d: 0.0.0.0, run as: admin
system.adapter.discovery.0             : discovery   -  enabled
system.adapter.flot.0                  : flot        -  enabled
system.adapter.rpi2.0                  : rpi2        -  enabled
system.adapter.sql.0                   : sql         -  enabled
system.adapter.terminal.0              : terminal    -  enabled, port: 8088, bin                    d: 0.0.0.0, run as: admin
system.adapter.vis-history.0           : vis-history -  enabled
system.adapter.vis.0                   : vis         -  enabled
system.adapter.web.0                   : web         -  enabled, port: 8082, bin                    d: 0.0.0.0, run as: admin
</code></pre>
]]></description><link>https://forum.iobroker.net/post/281194</link><guid isPermaLink="true">https://forum.iobroker.net/post/281194</guid><dc:creator><![CDATA[LED]]></dc:creator><pubDate>Mon, 15 Jul 2019 13:23:55 GMT</pubDate></item><item><title><![CDATA[Reply to History Adapter lässt sich nicht installieren on Mon, 15 Jul 2019 12:12:11 GMT]]></title><description><![CDATA[<p dir="auto">Was kommt bei:</p>
<p dir="auto">iobroker list instances</p>
]]></description><link>https://forum.iobroker.net/post/281168</link><guid isPermaLink="true">https://forum.iobroker.net/post/281168</guid><dc:creator><![CDATA[sigi234]]></dc:creator><pubDate>Mon, 15 Jul 2019 12:12:11 GMT</pubDate></item></channel></rss>
