  4. Viele Warnungen im Log vom Javascript Adapter
    1.0k
    6.1k
warnungen javascript
47 Beiträge 5 Kommentatoren 6.7k Aufrufe 1 Beobachtet
  • ostseereiterO ostseereiter
    @Shepherd
    diese sehen meine sehr ähnlich.
    javascript.0	2019-07-07 18:52:07.927	warn	at TCP.onread (net.js:601:20)
    javascript.0	2019-07-07 18:52:07.927	warn	at Socket.Readable.push (_stream_readable.js:208:10)
    javascript.0	2019-07-07 18:52:07.927	warn	at readableAddChunk (_stream_readable.js:250:11)
    javascript.0	2019-07-07 18:52:07.927	warn	at addChunk (_stream_readable.js:263:12)
    javascript.0	2019-07-07 18:52:07.926	warn	at Socket.emit (events.js:211:7)
    javascript.0	2019-07-07 18:52:07.926	warn	at emitOne (events.js:116:13)
    javascript.0	2019-07-07 18:52:07.926	warn	at Socket.realHandler (/opt/iobroker/node_modules/ws/lib/WebSocket.js:825:20)
    javascript.0	2019-07-07 18:52:07.926	warn	at Receiver.add (/opt/iobroker/node_modules/ws/lib/Receiver.js:103:24)
    javascript.0	2019-07-07 18:52:07.926	warn	at Receiver.expectHandler (/opt/iobroker/node_modules/ws/lib/Receiver.js:499:31)
    javascript.0	2019-07-07 18:52:07.926	warn	at Receiver.finish (/opt/iobroker/node_modules/ws/lib/Receiver.js:541:12)
    javascript.0	2019-07-07 18:52:07.926	warn	at Receiver.flush (/opt/iobroker/node_modules/ws/lib/Receiver.js:347:3)
    javascript.0	2019-07-07 18:52:07.926	warn	at /opt/iobroker/node_modules/ws/lib/Receiver.js:508:14
    javascript.0	2019-07-07 18:52:07.926	warn	at Receiver.applyExtensions (/opt/iobroker/node_modules/ws/lib/Receiver.js:371:5)
    javascript.0	2019-07-07 18:52:07.926	warn	at /opt/iobroker/node_modules/ws/lib/Receiver.js:536:18
    javascript.0	2019-07-07 18:52:07.926	warn	at Receiver.ontext (/opt/iobroker/node_modules/ws/lib/WebSocket.js:841:10)
    javascript.0	2019-07-07 18:52:07.926	warn	at WebSocket.emit (events.js:214:7)
    javascript.0	2019-07-07 18:52:07.925	warn	at emitTwo (events.js:126:13)
    javascript.0	2019-07-07 18:52:07.925	warn	at WebSocket.onMessage (/opt/iobroker/node_modules/ws/lib/WebSocket.js:442:14)
    javascript.0	2019-07-07 18:52:07.925	warn	at WebSocket.ws.onmessage (/opt/iobroker/node_modules/engine.io-client/lib/transports/websocket.js:146:10)
    javascript.0	2019-07-07 18:52:07.925	warn	at WS.Transport.onData (/opt/iobroker/node_modules/engine.io-client/lib/transport.js:137:8)
    javascript.0	2019-07-07 18:52:07.925	warn	at WS.Transport.onPacket (/opt/iobroker/node_modules/engine.io-client/lib/transport.js:145:8)
    javascript.0	2019-07-07 18:52:07.925	warn	at WS.Emitter.emit (/opt/iobroker/node_modules/engine.io-client/node_modules/component-emitter/index.js:133:20)
    javascript.0	2019-07-07 18:52:07.925	warn	at WS.<anonymous> (/opt/iobroker/node_modules/engine.io-client/lib/socket.js:268:10)
    javascript.0	2019-07-07 18:52:07.925	warn	at Socket.onPacket (/opt/iobroker/node_modules/engine.io-client/lib/socket.js:451:14)
    javascript.0	2019-07-07 18:52:07.925	warn	at Socket.Emitter.emit (/opt/iobroker/node_modules/engine.io-client/node_modules/compo
    aber es funktioniert ja alles.Da mache ich mir keine Sorgen
    @ostseereiter sagte in Viele Warnungen im Log vom Javascript Adapter:
    nur dass du uns die Ursache verschweigst.
    Die steht im log weiter vorne
    solltest du aber, wenn es die gleiche Ursache ist
    @Shepherd sagte in Viele Warnungen im Log vom Javascript Adapter:
    and will not work in next versions.
    • S Shepherd
      @Homoran
      Da war Logikwert drin, habe es aber mal gerade auf Zahl geändert schreibt 0 und 1 rein.
      Denke dies ist so richtig dann.
      Aber der ganze rest?
      brauche ich vielleicht den socket.io Adapter für javascript Adapter?
      Habe da schon mal was gelesen.
      und nochmal:
      @Homoran sagte in Viele Warnungen im Log vom Javascript Adapter:
      als was kommen die Werte
      • ostseereiterO Offline
        ostseereiter
        @Shepherd
        diese Warnungen kam erst als ich den javascript Adapter aktualisiert habe. Solange es läuft ist doch alles gut.
        javascript.0	2019-07-07 18:52:07.925	warn	at Socket.Emitter.emit (/opt/iobroker/node_modules/engine.io-client/node_modules/component-emitter/index.js:133:20)
        javascript.0	2019-07-07 18:52:07.925	warn	at Socket.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
        javascript.0	2019-07-07 18:52:07.925	warn	at Manager.ondata (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:322:16)
        javascript.0	2019-07-07 18:52:07.924	warn	at Decoder.add (/opt/iobroker/node_modules/socket.io-parser/index.js:246:12)
        javascript.0	2019-07-07 18:52:07.924	warn	at Decoder.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:134:20)
        javascript.0	2019-07-07 18:52:07.924	warn	at Decoder.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
        javascript.0	2019-07-07 18:52:07.924	warn	at Manager.ondecoded (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:332:8)
        javascript.0	2019-07-07 18:52:07.924	warn	at Manager.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
        javascript.0	2019-07-07 18:52:07.924	warn	at Manager.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
        javascript.0	2019-07-07 18:52:07.924	warn	at Socket.onpacket (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:228:12)
        javascript.0	2019-07-07 18:52:07.924	warn	at Socket.onevent (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:270:10)
        javascript.0	2019-07-07 18:52:07.924	warn	at Socket.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
        javascript.0	2019-07-07 18:52:07.924	warn	at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInMemClient.js:52:30)
        javascript.0	2019-07-07 18:52:07.924	warn	at Object.change (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:3705:37)
        javascript.0	2019-07-07 18:52:07.923	warn	at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:364:25)
        javascript.0	2019-07-07 18:52:07.923	warn	at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:963:38)
        javascript.0	2019-07-07 18:52:07.923	warn	at Object.<anonymous> (script.js.Flur.Flurlicht:6:5)
        javascript.0	2019-07-07 18:52:07.923	warn	at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1258:20)
        javascript.0	2019-07-07 18:52:07.917	warn	Wrong type of lightify.0.0200000000000000.bri: "string". Please fix, while deprecated and will not work in next versions.
        Gruß OSR
        Plattform
          @Shepherd
          ostseereiterO 2 Antworten Letzte Antwort
            und nochmal:
            Shepherd
            @Homoran
            Die Werte kommen von einem Shelly, 0 und 1 für auf und zu/ ein und aus.
            Wie schaue ich dies wie es kommt?
            Der Shelly ist per MQTT über Shelly Adapter verbunden.
            • S Shepherd
              @Homoran
              Das sieht nach Folgemeldungen von "Wrong type" aus. Sind nach Änderung des Datenpunkttyps noch Warnungen vorhanden ?
              Nein, für den Javascript-Adapter nicht.
                Shepherd
                schrieb am zuletzt editiert von Shepherd
                muss abwarten die meldungen kommen nach neustart nicht gleich.
                Und was haben die Warnungen mit
                At socket
                oder At Manager
                at Decoder?
                woher kommen diese?
                  ostseereiter
                  @Homoran
                  Kommt von Lightifyadapter es gibt aber keine andere Version diese wird wohl nicht mehr gepflegt.
                  Gruß OSR
                  Plattform
                  • S Shepherd
                    At socket
                    oder At Manager
                    at Decoder?
                    woher kommen diese?
                    Die geben an wo sich eine Zugriff auf diesen State mit dem Falschen Typ im Script/Adapter versteckt
                    In der Form "Zeile:Zeichen"
                      @Homoran
                      Auch bei dir ist der Typ des Datenpunktes falsch
                        ostseereiter
                        Was soll man da ändern gibt doch nur true und false
                        Gruß OSR
                        Plattform
                          Den typ!
                          Geh mal bei bri auf den Bleistift
                          ostseereiterO 1 Antwort Letzte Antwort
                            Den typ!
                            ostseereiter
                            @Homoran
                            ja da steht dies
                            Gruß OSR
                            Plattform
                              ostseereiter
                              bei on steht das:
                              Gruß OSR
                              Plattform
                                bei on steht das:
                                @ostseereiter
                                angemeckert wird das bri.
                                müsste angeblich STRING (=Text) sein.
                                entweder ist das im Adapter falsch deklariert, oder der Lightify liefert den Wert als Text und nicht als Nummer.
                                  @ostseereiter
                                  ostseereiter
                                  @Homoran
                                  Das könnte an den Adapter liegen. dann kann man da nichts machen.
                                  Gruß OSR
                                  Plattform
                                    @Homoran
                                    ja da steht dies
                                    @ostseereiter
                                    sagt aus, dass im Skript Flur.Flurlicht in Zeile 6 ein String in den Datenpunkt vom Typ Zahl geschrieben wird.
                                    HomoranH ostseereiterO 2 Antworten Letzte Antwort
                                      @ostseereiter
                                      Danke Paul!
                                      Habe jetzt am Handy nicht mehr den Code durchgewühlt
                                        @ostseereiter
                                        ostseereiter
                                        ja danke nu habe ich es habe auf Zahl im Script geändert und nun ist die Warnung weg.
                                        Schwere Geburt! Danke an alle.
                                        Gruß OSR
                                        Plattform
                                          AlCalzoneA Offline
                                          AlCalzoneA Offline
                                          AlCalzone
                                          Die Meldung ist verwirrend und wurde in den neueren Versionen des Skript-Adapters deutlicher formuliert:
                                          `You are assigning a ${actualCommonType} to the state "${id}" which expects a ${common.type}. Please fix your code to use a ${common.type} or change the state type to ${actualCommonType}.`
