  4. Viele Warnungen im Log vom Javascript Adapter
    1.0k
    6.1k
warnungen javascript
47 Beiträge 5 Kommentatoren 6.7k Aufrufe 1 Beobachtet
  • ostseereiterO Offline
    ostseereiter
    @Shepherd
    diese sehen meine sehr ähnlich.
    javascript.0	2019-07-07 18:52:07.927	warn	at TCP.onread (net.js:601:20)
    javascript.0	2019-07-07 18:52:07.927	warn	at Socket.Readable.push (_stream_readable.js:208:10)
    javascript.0	2019-07-07 18:52:07.927	warn	at readableAddChunk (_stream_readable.js:250:11)
    javascript.0	2019-07-07 18:52:07.927	warn	at addChunk (_stream_readable.js:263:12)
    javascript.0	2019-07-07 18:52:07.926	warn	at Socket.emit (events.js:211:7)
    javascript.0	2019-07-07 18:52:07.926	warn	at emitOne (events.js:116:13)
    javascript.0	2019-07-07 18:52:07.926	warn	at Socket.realHandler (/opt/iobroker/node_modules/ws/lib/WebSocket.js:825:20)
    javascript.0	2019-07-07 18:52:07.926	warn	at Receiver.add (/opt/iobroker/node_modules/ws/lib/Receiver.js:103:24)
    javascript.0	2019-07-07 18:52:07.926	warn	at Receiver.expectHandler (/opt/iobroker/node_modules/ws/lib/Receiver.js:499:31)
    javascript.0	2019-07-07 18:52:07.926	warn	at Receiver.finish (/opt/iobroker/node_modules/ws/lib/Receiver.js:541:12)
    javascript.0	2019-07-07 18:52:07.926	warn	at Receiver.flush (/opt/iobroker/node_modules/ws/lib/Receiver.js:347:3)
    javascript.0	2019-07-07 18:52:07.926	warn	at /opt/iobroker/node_modules/ws/lib/Receiver.js:508:14
    javascript.0	2019-07-07 18:52:07.926	warn	at Receiver.applyExtensions (/opt/iobroker/node_modules/ws/lib/Receiver.js:371:5)
    javascript.0	2019-07-07 18:52:07.926	warn	at /opt/iobroker/node_modules/ws/lib/Receiver.js:536:18
    javascript.0	2019-07-07 18:52:07.926	warn	at Receiver.ontext (/opt/iobroker/node_modules/ws/lib/WebSocket.js:841:10)
    javascript.0	2019-07-07 18:52:07.926	warn	at WebSocket.emit (events.js:214:7)
    javascript.0	2019-07-07 18:52:07.925	warn	at emitTwo (events.js:126:13)
    javascript.0	2019-07-07 18:52:07.925	warn	at WebSocket.onMessage (/opt/iobroker/node_modules/ws/lib/WebSocket.js:442:14)
    javascript.0	2019-07-07 18:52:07.925	warn	at WebSocket.ws.onmessage (/opt/iobroker/node_modules/engine.io-client/lib/transports/websocket.js:146:10)
    javascript.0	2019-07-07 18:52:07.925	warn	at WS.Transport.onData (/opt/iobroker/node_modules/engine.io-client/lib/transport.js:137:8)
    javascript.0	2019-07-07 18:52:07.925	warn	at WS.Transport.onPacket (/opt/iobroker/node_modules/engine.io-client/lib/transport.js:145:8)
    javascript.0	2019-07-07 18:52:07.925	warn	at WS.Emitter.emit (/opt/iobroker/node_modules/engine.io-client/node_modules/component-emitter/index.js:133:20)
    javascript.0	2019-07-07 18:52:07.925	warn	at WS.<anonymous> (/opt/iobroker/node_modules/engine.io-client/lib/socket.js:268:10)
    javascript.0	2019-07-07 18:52:07.925	warn	at Socket.onPacket (/opt/iobroker/node_modules/engine.io-client/lib/socket.js:451:14)
    javascript.0	2019-07-07 18:52:07.925	warn	at Socket.Emitter.emit (/opt/iobroker/node_modules/engine.io-client/node_modules/compo
    aber es funktioniert ja alles.Da mache ich mir keine Sorgen
    Gruß OSR
    Plattform
      @Shepherd sagte in Viele Warnungen im Log vom Javascript Adapter:
      Wrong type of ManuelleDatenpunkte.0.Garage.TargetDoorState: "number".
      Was Hat der denn für einen Typ?
      und als was kommen die Werte für ihn?
      Shepherd
      @Homoran
      Da war Logikwert drin, habe es aber mal gerade auf Zahl geändert schreibt 0 und 1 rein.
      Denke dies ist so richtig dann.
      Aber der ganze rest?
      brauche ich vielleicht den socket.io Adapter für javascript Adapter?
      Habe da schon mal was gelesen.
      • ostseereiterO ostseereiter
        @Shepherd
        @ostseereiter sagte in Viele Warnungen im Log vom Javascript Adapter:
        nur dass du uns die Ursache verschweigst.
        Die steht im log weiter vorne
        solltest du aber, wenn es die gleiche Ursache ist
        and will not work in next versions.
        • S Shepherd
          @Homoran
          und nochmal:
          @Homoran sagte in Viele Warnungen im Log vom Javascript Adapter:
            ostseereiter
            @Shepherd
            diese Warnungen kam erst als ich den javascript Adapter aktualisiert habe. Solange es läuft ist doch alles gut.
            javascript.0	2019-07-07 18:52:07.925	warn	at Socket.Emitter.emit (/opt/iobroker/node_modules/engine.io-client/node_modules/component-emitter/index.js:133:20)
            javascript.0	2019-07-07 18:52:07.925	warn	at Socket.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
            javascript.0	2019-07-07 18:52:07.925	warn	at Manager.ondata (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:322:16)
            javascript.0	2019-07-07 18:52:07.924	warn	at Decoder.add (/opt/iobroker/node_modules/socket.io-parser/index.js:246:12)
            javascript.0	2019-07-07 18:52:07.924	warn	at Decoder.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:134:20)
            javascript.0	2019-07-07 18:52:07.924	warn	at Decoder.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
            javascript.0	2019-07-07 18:52:07.924	warn	at Manager.ondecoded (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:332:8)
            javascript.0	2019-07-07 18:52:07.924	warn	at Manager.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
            javascript.0	2019-07-07 18:52:07.924	warn	at Manager.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
            javascript.0	2019-07-07 18:52:07.924	warn	at Socket.onpacket (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:228:12)
            javascript.0	2019-07-07 18:52:07.924	warn	at Socket.onevent (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:270:10)
            javascript.0	2019-07-07 18:52:07.924	warn	at Socket.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
            javascript.0	2019-07-07 18:52:07.924	warn	at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInMemClient.js:52:30)
            javascript.0	2019-07-07 18:52:07.924	warn	at Object.change (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:3705:37)
            javascript.0	2019-07-07 18:52:07.923	warn	at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:364:25)
            javascript.0	2019-07-07 18:52:07.923	warn	at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:963:38)
            javascript.0	2019-07-07 18:52:07.923	warn	at Object.<anonymous> (script.js.Flur.Flurlicht:6:5)
            javascript.0	2019-07-07 18:52:07.923	warn	at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1258:20)
            javascript.0	2019-07-07 18:52:07.917	warn	Wrong type of lightify.0.0200000000000000.bri: "string". Please fix, while deprecated and will not work in next versions.
            Gruß OSR
            Plattform
              @Shepherd
              ostseereiterO 2 Antworten Letzte Antwort
                und nochmal:
                Shepherd
                @Homoran
                Die Werte kommen von einem Shelly, 0 und 1 für auf und zu/ ein und aus.
                Wie schaue ich dies wie es kommt?
                Der Shelly ist per MQTT über Shelly Adapter verbunden.
                • S Shepherd
                  @Homoran
                  Das sieht nach Folgemeldungen von "Wrong type" aus. Sind nach Änderung des Datenpunkttyps noch Warnungen vorhanden ?
                  Nein, für den Javascript-Adapter nicht.
                    Shepherd
                    schrieb am zuletzt editiert von Shepherd
                    muss abwarten die meldungen kommen nach neustart nicht gleich.
                    Und was haben die Warnungen mit
                    At socket
                    oder At Manager
                    at Decoder?
                    woher kommen diese?
                      ostseereiter
                      @Homoran
                      Kommt von Lightifyadapter es gibt aber keine andere Version diese wird wohl nicht mehr gepflegt.
                      Gruß OSR
                      Plattform
                      • S Shepherd
                        At socket
                        oder At Manager
                        at Decoder?
                        woher kommen diese?
                        Die geben an wo sich eine Zugriff auf diesen State mit dem Falschen Typ im Script/Adapter versteckt
                        In der Form "Zeile:Zeichen"
                          @Homoran
                          Auch bei dir ist der Typ des Datenpunktes falsch
                            ostseereiter
                            Was soll man da ändern gibt doch nur true und false
                            Gruß OSR
                            Plattform
                              Den typ!
                              Geh mal bei bri auf den Bleistift
                              ostseereiterO 1 Antwort Letzte Antwort
                                Den typ!
                                ostseereiter
                                @Homoran
                                ja da steht dies
                                Gruß OSR
                                Plattform
                                  ostseereiter
                                  bei on steht das:
                                  Gruß OSR
                                  Plattform
                                    bei on steht das:
                                    @ostseereiter
                                    angemeckert wird das bri.
                                    müsste angeblich STRING (=Text) sein.
                                    entweder ist das im Adapter falsch deklariert, oder der Lightify liefert den Wert als Text und nicht als Nummer.
                                      @ostseereiter
                                      ostseereiter
                                      @Homoran
                                      Das könnte an den Adapter liegen. dann kann man da nichts machen.
                                      Gruß OSR
                                      Plattform
                                        @Homoran
                                        ja da steht dies
                                        @ostseereiter
                                        sagt aus, dass im Skript Flur.Flurlicht in Zeile 6 ein String in den Datenpunkt vom Typ Zahl geschrieben wird.
                                        HomoranH ostseereiterO 2 Antworten Letzte Antwort
                                          @ostseereiter
                                          Danke Paul!
                                          Habe jetzt am Handy nicht mehr den Code durchgewühlt
